  4. [gelöst] Admin-Adapter: Cannot check node.js versions
    5.6k
2 Beiträge 2 Kommentatoren 283 Aufrufe 2 Beobachtet
  • BananaJoeB Online
    BananaJoeB Online
    BananaJoe
    Siehe Post https://forum.iobroker.net/topic/61052/was-bedeutet-cannot-check-node-js-versions?_=1671377327350
    Immer wenn der Admin-Adapter gestartet wird kommt folgende Warnung:
    2022-12-18 16:29:06.887  - warn: admin.2 (1392685) Cannot check node.js versions: Error: unexpected end of file
    Ich habe mal probeweise den Adapter auf Debug laufen lassen, ergibt aber keine Details dazu:
    2022-12-18 16:28:42.499  - info: host.iobroker instance system.adapter.admin.2 started with pid 1392405
    2022-12-18 16:28:43.890  - debug: admin.2 (1392405) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2022-12-18 16:28:44.016  - debug: admin.2 (1392405) Objects client ready ... initialize now
    2022-12-18 16:28:44.018  - debug: admin.2 (1392405) Objects create System PubSub Client
    2022-12-18 16:28:44.026  - debug: admin.2 (1392405) Objects create User PubSub Client
    2022-12-18 16:28:44.263  - debug: admin.2 (1392405) Objects client initialize lua scripts
    2022-12-18 16:28:44.272  - debug: admin.2 (1392405) Objects connected to redis: 0.0.0.0:9001
    2022-12-18 16:28:44.359  - debug: admin.2 (1392405) Redis States: Use Redis connection: 127.0.0.1:6379
    2022-12-18 16:28:44.365  - debug: admin.2 (1392405) States create System PubSub Client
    2022-12-18 16:28:44.366  - debug: admin.2 (1392405) States create User PubSub Client
    2022-12-18 16:28:44.375  - debug: admin.2 (1392405) States connected to redis: 127.0.0.1:6379
    2022-12-18 16:28:44.459  - debug: admin.2 (1392405) Plugin sentry Do not initialize Plugin (enabled=false)
    2022-12-18 16:28:44.466  - debug: admin.2 (1392405) Plugin sentry destroyed because not initialized correctly
    2022-12-18 16:28:44.777  - info: admin.2 (1392405) starting. Version 6.3.4 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.1, js-controller: 4.0.24
    2022-12-18 16:28:44.825  - info: admin.2 (1392405) requesting all states
    2022-12-18 16:28:44.827  - info: admin.2 (1392405) requesting all objects
    2022-12-18 16:28:45.486  - warn: admin.2 (1392405) Cannot check node.js versions: Error: unexpected end of file
    2022-12-18 16:28:48.064  - info: admin.2 (1392405) received all objects
    2022-12-18 16:28:48.169  - debug: admin.2 (1392405) Using http createServer
    2022-12-18 16:28:48.341  - info: admin.2 (1392405) Request actual repository...
    2022-12-18 16:28:48.428  - info: admin.2 (1392405) http server listening on port 60082
    2022-12-18 16:28:48.428  - info: admin.2 (1392405) Use link "http://localhost:60082" to configure.
    2022-12-18 16:28:48.476  - info: admin.2 (1392405) socket.io server listening on port 60082
    2022-12-18 16:28:48.649  - info: admin.2 (1392405) ==> Connected system.user.admin from 192.168.1.32
    2022-12-18 16:28:48.690  - debug: admin.2 (1392405) Subscribes: dummy
    2022-12-18 16:28:48.702  - debug: admin.2 (1392405) Subscribes: system.adapter.discovery.0.alive
    2022-12-18 16:28:48.705  - debug: admin.2 (1392405) Subscribes: system.adapter.discovery.0.alive, system.host.*.alive
    Hier die Informationen aus dem diag.sh Skript:
                            v.2022-12-13
    Operatingsystem:        Ubuntu 22.04.1 LTS
    Installation:           vmware
    Timezone:               Europe/Berlin
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Nodejs-Installation:    /usr/bin/nodejs         v16.18.1
                            /usr/bin/node           v16.18.1
                            /usr/bin/npm            8.19.2
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.4
    Objects type: jsonl
    States  type: redis
    Pending iob updates:    0
    Active repo(s): beta
    Objects:                38478
    States:                 36203
    Size of iob-Database:
    60M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/objects.json.migrated
    24M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    1.8M    /opt/iobroker/iobroker-data/states.json.bak
    ====================== END OF SUMMARY ==================
    Die Warnung war mir vorher noch nicht aufgefallen, ich meine (ohne Beleg) das diese seit dem Update des js-controller auf 4.0.24 kommt.
    Die Meldung selbst wird ja durch den Admin-Adapter erzeugt, wie ich das sehen in der main.js in Zeile 597 (hier Zeile 7) und wird ausgegeben wenn die aufgerufene Funktion mit einem Fehler abbricht:
    // read news from server
    function updateNews() {
        adapter.timerNews && clearTimeout(adapter.timerNews);
        adapter.timerNews = null;
        checkNodeJsVersion()
            .catch(e => adapter.log.warn(`Cannot check node.js versions: ${e}`));
        let oldEtag;
        let newNews;
        let oldNews;
    Die Funktion checkNodeJsVersion habe ich mir auch angesehen ... ohne alles zu verstehen (soweit bin ich dann doch noch nicht).
    Die einzige Datei die ich dort auf anhieb finde ist in Zeile 804 das herunterladen der Liste der nodejs Versionen:
    const response = await axios('https://nodejs.org/download/release/index.json');
    was von Hand funktioniert (239KByte)
    FabioF 1 Antwort Letzte Antwort
    • BananaJoeB BananaJoe
                              v.2022-12-13
      User-ID:                1000
      X-Server:               false
                              /usr/bin/npm            8.19.2
                              admin                   6.3.4
      Objects type: jsonl
      States  type: redis
      Objects:                38478
      States:                 36203
          let oldEtag;
          let newNews;
          let oldNews;
      FabioF Offline
      FabioF Offline
      Fabio
      @bananajoe habe ich auch schau mal bitte hier: https://forum.iobroker.net/topic/61052/was-bedeutet-cannot-check-node-js-versions?_=1671377327350
      Fabio
      Iobroker:
      • Matter over Thread Hilfe
