  4. Probleme beim aufspielen des Backups nach Neuinstallation
    5.6k
81 Beiträge 5 Kommentatoren 10.0k Aufrufe 4 Beobachtet
  • T Tobi68
    admin.0
    558	2022-12-15 20:27:44.846	info	<== Disconnect system.user.admin from ::ffff:192.168.178.103
    admin.0
    558	2022-12-15 20:26:00.295	info	==> Connected system.user.admin from ::ffff:192.168.178.103
    admin.0
    558	2022-12-15 20:25:56.685	info	<== Disconnect system.user.admin from ::ffff:192.168.178.103
    admin.0
    558	2022-12-15 20:25:46.472	info	==> Connected system.user.admin from ::ffff:192.168.178.103
    admin.0
    558	2022-12-15 20:25:25.425	info	==> Connected system.user.admin from ::ffff:192.168.178.103
    admin.0
    558	2022-12-15 19:49:35.048	info	<== Disconnect system.user.admin from ::ffff:192.168.178.103 admin
    admin.0
    558	2022-12-15 19:37:13.995	info	<== Disconnect system.user.admin from ::ffff:192.168.178.103
    admin.0
    558	2022-12-15 19:36:12.619	info	==> Connected system.user.admin from ::ffff:192.168.178.103
    admin.0
    558	2022-12-15 19:36:12.467	info	<== Disconnect system.user.admin from ::ffff:192.168.178.103
    admin.0
    558	2022-12-15 19:36:00.955	info	==> Connected system.user.admin from ::ffff:192.168.178.103
    host.iobroker
    2022-12-15 19:35:57.992	error	Invalid request getRepository. "callback" or "from" is null
    admin.0
    558	2022-12-15 19:33:30.373	info	==> Connected system.user.admin from ::ffff:192.168.178.103
    admin.0
    558	2022-12-15 19:33:30.111	info	<== Disconnect system.user.admin from ::ffff:192.168.178.103 admin
    backitup.1
    821	2022-12-15 19:33:05.373	error	FTP: Error: /backupDir: No such file or directory.
    backitup.1
    821	2022-12-15 19:33:05.037	error	Error: Command failed: sudo mount :/sharename/backupDir /opt/iobroker/backupsmount.nfs: Failed to resolve server : Name or service not known
    backitup.1
    821	2022-12-15 19:33:03.919	info	[iobroker] backup was activated at 02:40 every 1 day(s)
    backitup.1
    821	2022-12-15 19:33:03.808	info	starting. Version 2.5.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.1, js-controller: 4.0.23
    host.iobroker
    2022-12-15 19:33:01.911	info	instance system.adapter.backitup.1 started with pid 821
    backitup.0
    805	2022-12-15 19:32:59.980	info	[iobroker] backup was activated at 02:40 every 1 day(s)
    backitup.0
    805	2022-12-15 19:32:59.839	info	starting. Version 2.5.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.1, js-controller: 4.0.23
    host.iobroker
    2022-12-15 19:32:57.936	info	instance system.adapter.backitup.0 started with pid 805
    admin.0
    558	2022-12-15 19:32:57.544	info	==> Connected system.user.admin from ::ffff:192.168.178.103
    discovery.0
    668	2022-12-15 19:32:55.689	info	starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.1, js-controller: 4.0.23
    host.iobroker
    2022-12-15 19:32:53.911	info	instance system.adapter.discovery.0 started with pid 668
    admin.0
    558	2022-12-15 19:32:53.007	warn	Cannot update rating: getaddrinfo ENOTFOUND rating.iobroker.net
    admin.0
    558	2022-12-15 19:32:52.938	info	socket.io server listening on port 8081
    admin.0
    558	2022-12-15 19:32:52.929	info	Use link "http://localhost:8081" to configure.
    admin.0
    558	2022-12-15 19:32:52.928	info	http server listening on port 8081
    admin.0
    558	2022-12-15 19:32:52.729	info	received all objects
    admin.0
    558	2022-12-15 19:32:52.438	warn	Cannot check node.js versions: Error: connect EHOSTUNREACH 2606:4700:10::6814:162e:443
    admin.0
    558	2022-12-15 19:32:52.427	warn	Cannot update news: connect EHOSTUNREACH 2001:8d8:100f:f000::2ca:443
    admin.0
    558	2022-12-15 19:32:52.341	info	requesting all objects
    admin.0
    558	2022-12-15 19:32:52.340	info	requesting all states
    admin.0
    558	2022-12-15 19:32:52.289	info	starting. Version 6.3.2 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.1, js-controller: 4.0.23
    host.iobroker
    2022-12-15 19:32:50.142	info	Some obsolete host states deleted.
    host.iobroker
    2022-12-15 19:32:50.129	info	Delete state "system.host.iobroker.versions.npmNewestNext"
    host.iobroker
    2022-12-15 19:32:50.070	info	Delete state "system.host.iobroker.versions.npmNewest"
    host.iobroker
    2022-12-15 19:32:50.022	info	Delete state "system.host.iobroker.versions.npmCurrent"
    host.iobroker
    2022-12-15 19:32:50.009	info	instance system.adapter.admin.0 started with pid 558
    host.iobroker
    2022-12-15 19:32:49.991	info	Delete state "system.host.iobroker.versions.nodeNewestNext"
    host.iobroker
    2022-12-15 19:32:49.974	info	Delete state "system.host.iobroker.versions.nodeNewest"
    host.iobroker
    2022-12-15 19:32:49.881	info	starting 4 instances
    host.iobroker
    2022-12-15 19:32:49.868	info	4 instances found
    host.iobroker
    2022-12-15 19:32:49.862	info	Delete state "system.host.iobroker.versions.nodeCurrent"
    host.iobroker
    2022-12-15 19:32:49.445	info	added notifications configuration of host
    host.iobroker
    2022-12-15 19:32:49.407	info	connected to Objects and States
    host.iobroker
    2022-12-15 19:32:48.820	info	ip addresses:
    host.iobroker
    2022-12-15 19:32:48.819	info	hostname: iobroker, node: v16.18.1
    host.iobroker
    2022-12-15 19:32:48.818	info	Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    host.iobroker
    2022-12-15 19:32:48.812	info	iobroker.js-controller version 4.0.23 js-controller starting
    host.iobroker
    2022-12-15 19:32:34.176	info	terminated
    host.iobroker
    2022-12-15 19:32:33.995	info	All instances are stopped.
    host.iobroker
    2022-12-15 19:32:33.995	info	instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    host.iobroker
    2022-12-15 19:32:33.983	info	instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    host.iobroker
    2022-12-15 19:32:33.979	info	instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    host.iobroker
    2022-12-15 19:32:33.963	info	instance system.adapter.backitup.1 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    host.iobroker
    2022-12-15 19:32:33.378	info	stopInstance system.adapter.backitup.1 send kill signal
    host.iobroker
    2022-12-15 19:32:33.377	info	stopInstance system.adapter.backitup.0 send kill signal
    host.iobroker
    2022-12-15 19:32:33.377	info	stopInstance system.adapter.discovery.0 send kill signal
    host.iobroker
    2022-12-15 19:32:33.374	info	stopInstance system.adapter.admin.0 send kill signal
    backitup.0
    7225	2022-12-15 19:32:33.372	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    admin.0
    7304	2022-12-15 19:32:33.369	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    discovery.0
    7210	2022-12-15 19:32:33.368	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    backitup.1
    7421	2022-12-15 19:32:33.368	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    discovery.0
    7210	2022-12-15 19:32:33.363	info	Got terminate signal TERMINATE_YOURSELF
    backitup.1
    7421	2022-12-15 19:32:33.364	info	Got terminate signal TERMINATE_YOURSELF
    backitup.0
    7225	2022-12-15 19:32:33.364	info	Got terminate signal TERMINATE_YOURSELF
    admin.0
    7304	2022-12-15 19:32:33.361	info	Got terminate signal TERMINATE_YOURSELF
    host.iobroker
    2022-12-15 19:32:33.342	info	stopInstance system.adapter.backitup.1 (force=false, process=true)
    host.iobroker
    2022-12-15 19:32:33.341	info	stopInstance system.adapter.backitup.0 (force=false, process=true)
    host.iobroker
    2022-12-15 19:32:33.341	info	stopInstance system.adapter.discovery.0 (force=false, process=true)
    host.iobroker
    2022-12-15 19:32:33.340	info	stopInstance system.adapter.admin.0 (force=false, process=true)
    backitup.0
    7225	2022-12-15 19:32:33.339	info	cleaned everything up...
    admin.0
    7304	2022-12-15 19:32:33.335	info	terminating http server on port 8081
    host.iobroker
    2022-12-15 19:32:33.335	info	received SIGTERM
    backitup.1
    7421	2022-12-15 19:32:33.334	info	cleaned everything up...
    admin.0
    7304	2022-12-15 19:30:05.624	info	<== Disconnect system.user.admin from ::ffff:192.168.178.103
    admin.0
    7304	2022-12-15 19:30:01.857	info	==> Connected system.user.admin from ::ffff:192.168.178.103
    admin.0
    7304	2022-12-15 19:30:01.710	info	<== Disconnect system.user.admin from ::ffff:192.168.178.103
    admin.0
    7304	2022-12-15 19:29:55.623	info	==> Connected system.user.admin from ::ffff:192.168.178.103
    admin.0
    7304	2022-12-15 19:29:55.480	info	<== Disconnect system.user.admin from ::ffff:192.168.178.103
    admin.0
    7304	2022-12-15 19:29:48.056	info	==> Connected system.user.admin from ::ffff:192.168.178.103
    host.iobroker
    2022-12-15 19:29:40.092	info	Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    backitup.1
    7421	2022-12-15 19:29:05.946	error	FTP: Error: /backupDir: No such file or directory.
    backitup.1
    7421	2022-12-15 19:29:05.598	error	Error: Command failed: sudo mount :/sharename/backupDir /opt/iobroker/backupsmount.nfs: Failed to resolve server : Name or service not known
    backitup.1
    7421	2022-12-15 19:29:04.660	info	[iobroker] backup was activated at 02:40 every 1 day(s)
    backitup.1
    7421	2022-12-15 19:29:04.543	info	starting. Version 2.5.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.1, js-controller: 4.0.23
    host.iobroker
    2022-12-15 19:29:02.673	info	instance system.adapter.backitup.1 started with pid 7421
    host.iobroker
    2022-12-15 19:29:00.128	info	instance system.adapter.backitup.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    admin.0
    7304	2022-12-15 19:28:59.711	info	<== Disconnect system.user.admin from ::ffff:192.168.178.103
    host.iobroker
    2022-12-15 19:28:59.616	info	stopInstance system.adapter.backitup.1 send kill signal
    backitup.1
    7386	2022-12-15 19:28:59.582	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    backitup.1
    7386	2022-12-15 19:28:59.581	info	terminating
    backitup.1
    7386	2022-12-15 19:28:59.580	info	cleaned everything up...
    backitup.1
    7386	2022-12-15 19:28:59.576	info	Got terminate signal TERMINATE_YOURSELF
    host.iobroker
    2022-12-15 19:28:59.569	info	stopInstance system.adapter.backitup.1 (force=false, process=true)
    backitup.1
    7386	2022-12-15 19:25:35.342	error	FTP: Error: /backupDir: No such file or directory.
    backitup.1
    7386	2022-12-15 19:25:34.973	error	Error: Command failed: sudo mount :/sharename/backupDir /opt/iobroker/backupsmount.nfs: Failed to resolve server : Name or service not known
    backitup.1
    7386	2022-12-15 19:25:33.992	info	[iobroker] backup was activated at 02:40 every 1 day(s)
    backitup.1
    7386	2022-12-15 19:25:33.884	info	starting. Version 2.5.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.1, js-controller: 4.0.23
    host.iobroker
    2022-12-15 19:25:32.042	info	instance system.adapter.backitup.1 started with pid 7386
    host.iobroker
    2022-12-15 19:25:29.568	info	instance system.adapter.backitup.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.iobroker
    2022-12-15 19:25:29.011	info	stopInstance system.adapter.backitup.1 send kill signal
    backitup.1
    7366	2022-12-15 19:25:28.975	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    backitup.1
    7366	2022-12-15 19:25:28.972	info	terminating
    backitup.1
    7366	2022-12-15 19:25:28.970	info	cleaned everything up...
    backitup.1
    7366	2022-12-15 19:25:28.966	info	Got terminate signal TERMINATE_YOURSELF
    host.iobroker
    2022-12-15 19:25:28.954	info	stopInstance system.adapter.backitup.1 (force=false, process=true)
    backitup.1
    7366	2022-12-15 19:24:43.529	error	FTP: Error: /backupDir: No such file or directory.
    backitup.1
    7366	2022-12-15 19:24:41.912	error	FTP: Error: /backupDir: No such file or directory.
    backitup.1
    7366	2022-12-15 19:24:40.430	error	Error: Command failed: sudo mount :/sharename/backupDir /opt/iobroker/backupsmount.nfs: Failed to resolve server : Name or service not known
    backitup.1
    7366	2022-12-15 19:24:39.715	info	[iobroker] backup was activated at 02:40 every 1 day(s)
    backitup.1
    7366	2022-12-15 19:24:39.597	info	starting. Version 2.5.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.1, js-controller: 4.0.23
    host.iobroker
    2022-12-15 19:24:37.748	info	instance system.adapter.backitup.1 started with pid 7366
    host.iobroker
    2022-12-15 19:24:35.225	info	instance system.adapter.backitup.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.iobroker
    2022-12-15 19:24:34.717	info	stopInstance system.adapter.backitup.1 send kill signal
    backitup.1
    7346	2022-12-15 19:24:34.682	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    backitup.1
    7346	2022-12-15 19:24:34.679	info	terminating
    backitup.1
    7346	2022-12-15 19:24:34.676	info	cleaned everything up...
    backitup.1
    7346	2022-12-15 19:24:34.673	info	Got terminate signal TERMINATE_YOURSELF
    host.iobroker
    2022-12-15 19:24:34.663	info	stopInstance system.adapter.backitup.1 (force=false, process=true)
    backitup.1
    7346	2022-12-15 19:23:40.558	error	Error: Command failed: sudo mount :/sharename/backupDir /opt/iobroker/backupsmount.nfs: Failed to resolve server : Name or service not known
    backitup.1
    7346	2022-12-15 19:23:39.876	info	[iobroker] backup was activated at 02:40 every 1 day(s)
    backitup.1
    7346	2022-12-15 19:23:39.763	info	starting. Version 2.5.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.1, js-controller: 4.0.23
    host.iobroker
    2022-12-15 19:23:37.905	info	instance system.adapter.backitup.1 started with pid 7346
    host.iobroker
    2022-12-15 19:23:35.396	info	instance system.adapter.backitup.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.iobroker
    2022-12-15 19:23:34.872	info	stopInstance system.adapter.backitup.1 send kill signal
    backitup.1
    7330	2022-12-15 19:23:34.843	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    backitup.1
    7330	2022-12-15 19:23:34.840	info	terminating
    backitup.1
    7330	2022-12-15 19:23:34.839	info	cleaned everything up...
    backitup.1
    7330	2022-12-15 19:23:34.828	info	Got terminate signal TERMINATE_YOURSELF
    host.iobroker
    2022-12-15 19:23:34.818	info	stopInstance system.adapter.backitup.1 (force=false, process=true)
    backitup.1
    7330	2022-12-15 19:22:13.362	info	[iobroker] backup was activated at 02:40 every 1 day(s)
    backitup.1
    7330	2022-12-15 19:22:13.254	info	starting. Version 2.5.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.1, js-controller: 4.0.23
    admin.0
    7304	2022-12-15 19:22:11.760	info	==> Connected system.user.admin from ::ffff:192.168.178.103
    host.iobroker
    2022-12-15 19:22:11.268	info	instance system.adapter.backitup.1 started with pid 7330
    host.iobroker
    2022-12-15 19:22:09.261	info	iobroker exit 0
    host.iobroker
    2022-12-15 19:22:08.232	info	iobroker host.iobroker object system.adapter.backitup.1 created
    host.iobroker
    2022-12-15 19:22:08.214	info	iobroker host.iobroker Set default value of backitup.1.output.line:
    host.iobroker
    2022-12-15 19:22:08.208	info	iobroker host.iobroker Set default value of backitup.1.oneClick.iobroker: false
    host.iobroker
    2022-12-15 19:22:08.202	info	iobroker host.iobroker Set default value of backitup.1.oneClick.ccu: false
    host.iobroker
    2022-12-15 19:22:08.196	info	iobroker host.iobroker Set default value of backitup.1.history.iobrokerSuccess: false
    host.iobroker
    2022-12-15 19:22:08.191	info	iobroker host.iobroker Set default value of backitup.1.history.ccuSuccess: false
    host.iobroker
    2022-12-15 19:22:08.186	info	iobroker host.iobroker Set default value of backitup.1.history.iobrokerLastTime: No backups yet
    host.iobroker
    2022-12-15 19:22:08.180	info	iobroker host.iobroker Set default value of backitup.1.history.ccuLastTime: No backups yet
    host.iobroker
    2022-12-15 19:22:08.175	info	iobroker host.iobroker Set default value of backitup.1.history.json: []
    host.iobroker
    2022-12-15 19:22:08.169	info	iobroker host.iobroker Set default value of backitup.1.history.html: No backups yet
    host.iobroker
    2022-12-15 19:22:08.164	info	iobroker host.iobroker Set default value of backitup.1.info.iobrokerNextTime: none
    host.iobroker
    2022-12-15 19:22:08.159	info	iobroker host.iobroker Set default value of backitup.1.info.ccuNextTime: none
    host.iobroker
    2022-12-15 19:22:08.153	info	iobroker host.iobroker object backitup.1.output.line created
    host.iobroker
    2022-12-15 19:22:08.147	info	iobroker host.iobroker object backitup.1.output created
    host.iobroker
    2022-12-15 19:22:08.140	info	iobroker host.iobroker object backitup.1.oneClick.iobroker created
    host.iobroker
    2022-12-15 19:22:08.133	info	iobroker host.iobroker object backitup.1.oneClick.ccu created
    host.iobroker
    2022-12-15 19:22:08.124	info	iobroker host.iobroker object backitup.1.oneClick created
    host.iobroker
    2022-12-15 19:22:08.118	info	iobroker host.iobroker object backitup.1.history.iobrokerSuccess created
    host.iobroker
    2022-12-15 19:22:08.112	info	iobroker host.iobroker object backitup.1.history.ccuSuccess created
    host.iobroker
    2022-12-15 19:22:08.104	info	iobroker host.iobroker object backitup.1.history.iobrokerLastTime created
    host.iobroker
    2022-12-15 19:22:08.098	info	iobroker host.iobroker object backitup.1.history.ccuLastTime created
    host.iobroker
    2022-12-15 19:22:08.092	info	iobroker host.iobroker object backitup.1.history.json created
    host.iobroker
    2022-12-15 19:22:08.081	info	iobroker host.iobroker object backitup.1.history.html created
    host.iobroker
    2022-12-15 19:22:08.075	info	iobroker host.iobroker object backitup.1.history created
    host.iobroker
    2022-12-15 19:22:08.069	info	iobroker host.iobroker object backitup.1.info.iobrokerNextTime created
    host.iobroker
    2022-12-15 19:22:08.062	info	iobroker host.iobroker object backitup.1.info.ccuNextTime created
    host.iobroker
    2022-12-15 19:22:08.056	info	iobroker host.iobroker object backitup.1.info.latestBackup created
    host.iobroker
    2022-12-15 19:22:08.050	info	iobroker host.iobroker object backitup.1.info created
    host.iobroker
    2022-12-15 19:22:08.043	info	iobroker host.iobroker object system.adapter.backitup.1.logLevel created
    host.iobroker
    2022-12-15 19:22:08.036	info	iobroker host.iobroker object system.adapter.backitup.1.sigKill created
    host.iobroker
    2022-12-15 19:22:08.028	info	iobroker host.iobroker object system.adapter.backitup.1.eventLoopLag created
    host.iobroker
    2022-12-15 19:22:08.020	info	iobroker host.iobroker object system.adapter.backitup.1.outputCount created
    host.iobroker
    2022-12-15 19:22:08.012	info	iobroker host.iobroker object system.adapter.backitup.1.inputCount created
    host.iobroker
    2022-12-15 19:22:08.003	info	iobroker host.iobroker object system.adapter.backitup.1.uptime created
    host.iobroker
    2022-12-15 19:22:07.994	info	iobroker host.iobroker object system.adapter.backitup.1.memRss created
    host.iobroker
    2022-12-15 19:22:07.986	info	iobroker host.iobroker object system.adapter.backitup.1.memHeapTotal created
    host.iobroker
    2022-12-15 19:22:07.976	info	iobroker host.iobroker object system.adapter.backitup.1.memHeapUsed created
    host.iobroker
    2022-12-15 19:22:07.964	info	iobroker host.iobroker object system.adapter.backitup.1.cputime created
    host.iobroker
    2022-12-15 19:22:07.953	info	iobroker host.iobroker object system.adapter.backitup.1.cpu created
    host.iobroker
    2022-12-15 19:22:07.943	info	iobroker host.iobroker object system.adapter.backitup.1.compactMode created
    host.iobroker
    2022-12-15 19:22:07.934	info	iobroker host.iobroker object system.adapter.backitup.1.connected created
    host.iobroker
    2022-12-15 19:22:07.921	info	iobroker host.iobroker object system.adapter.backitup.1.alive created
    host.iobroker
    2022-12-15 19:22:07.907	info	iobroker host.iobroker create instance backitup
    host.iobroker
    2022-12-15 19:22:06.109	info	iobroker add backitup --host iobroker
    admin.0
    7304	2022-12-15 19:21:22.793	info	==> Connected system.user.admin from ::ffff:192.168.178.103
    admin.0
    7304	2022-12-15 19:21:21.497	info	<== Disconnect system.user.admin from ::ffff:192.168.178.103 admin
    admin.0
    7304	2022-12-15 19:21:21.104	info	==> Connected system.user.admin from ::ffff:192.168.178.103
    admin.0
    7304	2022-12-15 19:21:19.361	info	socket.io server listening on port 8081
    admin.0
    7304	2022-12-15 19:21:19.353	info	Use link "http://localhost:8081" to configure.
    admin.0
    7304	2022-12-15 19:21:19.352	info	http server listening on port 8081
    admin.0
    7304	2022-12-15 19:21:19.159	info	received all objects
    admin.0
    7304	2022-12-15 19:21:18.999	warn	Cannot check node.js versions: Error: unexpected end of file
    admin.0
    7304	2022-12-15 19:21:18.747	info	requesting all objects
    admin.0
    7304	2022-12-15 19:21:18.744	info	requesting all states
    admin.0
    7304	2022-12-15 19:21:18.681	info	starting. Version 6.3.2 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.1, js-controller: 4.0.23
    host.iobroker
    2022-12-15 19:21:17.582	info	iobroker exit 0
    host.iobroker
    2022-12-15 19:21:16.590	info	instance system.adapter.admin.0 started with pid 7304
    host.iobroker
    2022-12-15 19:21:16.536	info	"system.adapter.admin.0" enabled
    host.iobroker
    2022-12-15 19:21:16.529	info	iobroker host.iobroker Adapter "system.adapter.admin.0" is started
    host.iobroker
    2022-12-15 19:21:16.520	info	iobroker upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
    host.iobroker
    2022-12-15 19:21:16.513	info	iobroker upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    host.iobroker
    2022-12-15 19:21:16.504	info	iobroker upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    host.iobroker
    2022-12-15 19:21:16.493	info	iobroker upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    host.iobroker
    2022-12-15 19:21:16.486	info	iobroker upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    host.iobroker
    2022-12-15 19:21:16.480	info	iobroker upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    host.iobroker
    2022-12-15 19:21:16.472	info	iobroker upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    host.iobroker
    2022-12-15 19:21:16.464	info	iobroker upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
    host.iobroker
    2022-12-15 19:21:16.431	info	iobroker upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    host.iobroker
    2022-12-15 19:21:16.409	info	iobroker upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
    host.iobroker
    2022-12-15 19:21:16.402	info	iobroker upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
    host.iobroker
    2022-12-15 19:21:16.381	info	iobroker upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
    host.iobroker
    2022-12-15 19:21:16.352	info	iobroker upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
    host.iobroker
    2022-12-15 19:21:16.343	info	iobroker upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
    host.iobroker
    2022-12-15 19:21:16.334	info	iobroker upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
    host.iobroker
    2022-12-15 19:21:16.327	info	iobroker upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
    host.iobroker
    2022-12-15 19:21:16.320	info	iobroker upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
    host.iobroker
    2022-12-15 19:21:16.313	info	iobroker upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
    host.iobroker
    2022-12-15 19:21:16.293	info	iobroker upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
    host.iobroker
    2022-12-15 19:21:16.280	info	iobroker upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
    host.iobroker
    2022-12-15 19:21:16.149	info	iobroker upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
    host.iobroker
    2022-12-15 19:21:14.722	info	iobroker upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
    host.iobroker
    2022-12-15 19:21:14.649	info	iobroker upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
    host.iobroker
    2022-12-15 19:21:14.575	info	iobroker upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
    host.iobroker
    2022-12-15 19:21:14.495	info	iobroker upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    @tobi68 Danke!
    Bitte erst, wie @Thomas-Braun schrieb, einmal die Konfig zeigen.
    Dann diese Instanz auf logstufe debug schalten (Expertenmodus bei Instanzen! )
    dann beim nächsten Versuch nach eventuellen Korrekturen der Konfig, das debug-log posten
      @tobi68
      Na von dem Backitup-Adapter. Welcher denn sonst?
      Tobi68
      ich hab den zwei mal..
      Muss ich zur Wiederherstellung schon alles anhaken was ich später auch mal sichern möchte?
      Klar unter dem Menue sichern habe ich noch gar nichts angegeben ist ja nix drin..
      • T Tobi68
        @tobi68 sagte in Probleme beim aufspielen des Backups nach Neuinstallation:
        Warum?
          Da fehlt der host.
          Tobi68
          ist das nicht von dem FTP der noch nicht richtig eingestellt ist?
          Google hat doch geklappt
          • T Tobi68
            wahrscheinlich!
            deswegen zeigen, damit du es richtig eingestellt bekommst
              wahrscheinlich!
              Tobi68
              @homoran verstehe ich jetzt nicht.. ich deaktivire jetzt mal FTP und nas..
              Googel passt ja
              • T Tobi68
                Googel passt ja
                Und ich verstehe jetzt nicht was du da überhaupt treibst.
                  Tobi68
                  Die hatte ich alle ausgewählt mit dem letzten Datum.
                  Starten muss ich die doch nicht oder?
                  • T Tobi68
                    Hä? Ich weiß echt nicht um was es dir jetzt geht.
                    • T Tobi68
                      Googel passt ja
                      aber daher kommt doch der Fehler.
                      willst du den nicht fixen?
                        Tobi68
                        ist das also nicht der richtige weg abgespeicherte backups wieder herzustellen?
                        Auf einem neu installierten Iobroker ohne alles? nur mit Backitup
                          Tobi68
                          nee erst mal nur die Kiste wieder laufen haben, habe ja per FTP auf die NAS und in Google gesichert..
                          • T Tobi68
                            Doch. Aber dazu muss natürlich das Backup-Medium erreichbar sein und eine funktionierende Backup-Datei (bzw. mehrere) verfügbar haben.
                            Ich würde das auch ein EINE Instanz packen, die dann funktioniert und nicht in zwei, die nur halb funktionieren.
                            Kann dein NAS nicht was gescheiteres als doofes FTP?
                            SMB/CIFS? NFS gar? Alles besser als FTP.
                            T 2 Antworten Letzte Antwort
                              Tobi68
                              Ich verstehe das jetzt nicht so ganz.. Google ist erreichbar hat geklappt, zumindest wurde alles gefunden und runter geladen.
                              Reicht das nicht?
                              Warum erscheint kein adapter im IOB
                              • T Tobi68
                                Reicht das nicht?
                                @tobi68 Bitte eins nach dem anderen!
                                was hat geklappt?
                                aber nicht wiederhergestellt?
                                Backitup macht Backups und Restore. Nur herunterladen kenne ich bei Backitup nicht
                                  Tobi68
                                  @thomas-braun sagte in Probleme beim aufspielen des Backups nach Neuinstallation:
                                  Ich kann auch gerne wieder die USB anklemmen und nach meinen FTP Einstellung suchen die ich vor Monaten mal gesetzt habe.. möchte ich mir aber ersparen , da ich dachte Google geht also reicht das doch..
                                  SMB/CIFS oder gar NFS kann die Syno bestimmt, ICH habe es halt nicht hinnbekommen. FTP und Googel hat geklappt..
                                  • T Tobi68
                                    @tobi68
                                    Google geht halt nicht immer, wenn ich @simatec da richtig in Erinnerung habe.
                                      was hat geklappt?
                                      Tobi68
                                      Ich habe Sicherungen Abrufen gemacht..
                                      Ist das falsch? nur hatte ich adapter starten nicht angehakt
                                      Die sind bei mir im download Ordner gelandet
                                      • T Tobi68
                                        @tobi68
                                        Das ist doch ein Windows da. Ich versteh überhaupt nicht wo du da herumspringst.
                                        T CodierknechtC 2 Antworten Letzte Antwort
                                          @tobi68
                                          Tobi68
                                          @tobi68
                                          ja da war was.. ich musste den Zeitpunkt verstellen.. habe aber genug backups.. eigentlich :-(
