  4. Zigbee Adapter lässt sich nicht mehr installieren
15 Beiträge 2 Kommentatoren 576 Aufrufe 2 Beobachtet
  • J jfwillow
    ok Repo auf 'Stable'. Backup- und Alexa-Adapter brauchten ein Update....hat funktioniert, aber dauert gefühlt eine Ewigkeit bis die Updates durch sind.
    *** BASE SYSTEM ***
    Architecture:   armv7l
    Docker:         false
    Virtualization: none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     08:42:07 up 2 days, 23:12,  1 user,  load average: 2.45, 1.26, 1.06
    CPU threads: 4
    *** Time and Time Zones ***
    Sat Nov 12 07:42:07 UTC 2022
    Sat Nov 12 08:42:07 CET 2022
    CET +0100
    Europe/Vienna
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G        2.6G        511M         84M        741M        1.7G
    Swap:           99M         99M        0.0K
    Total:         3.9G        2.7G        511M
             3838 M total memory
             2586 M used memory
             1116 M active memory
             2086 M inactive memory
              511 M free memory
               84 M buffer memory
              656 M swap cache
               99 M total swap
               99 M used swap
                0 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4       29G   12G   17G  42% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G  2.4M  1.9G   1% /dev/shm
    tmpfs          tmpfs     1.9G  129M  1.8G   7% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     384M     0  384M   0% /run/user/998
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.3G    /var/
    495M    /var/lib
    387M    /var/cache
    381M    /var/cache/apt
    319M    /var/cache/apt/archives
    /opt/iobroker/backups:
    1.5G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    865M    /opt/iobroker/iobroker-data/
    444M    /opt/iobroker/iobroker-data/history
    208M    /opt/iobroker/iobroker-data/files
    145M    /opt/iobroker/iobroker-data/backup-objects
    48M     /opt/iobroker/iobroker-data/files/javascript.admin
    25M     /opt/iobroker/iobroker-data/objects.jsonl
    17M     /opt/iobroker/iobroker-data/states.jsonl
    12M     /opt/iobroker/iobroker-data/objects.json.migrated
    12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.18.1
    /usr/bin/node           v16.18.1
    /usr/bin/npm            8.19.2
    nodejs:
      Installed: 16.18.1-deb-1nodesource1
      Candidate: 16.18.1-deb-1nodesource1
      Version table:
     *** 16.18.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u2 500
            500 https://archive.raspbian.org/raspbian buster/main armhf Packages
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.23
    admin:          6.2.23
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    ioBroker-Instances
    Adapter    "admin"        : 6.2.23   , installed 6.2.23
    Adapter    "alexa2"       : 3.21.0   , installed 3.21.0
    Adapter    "backitup"     : 2.5.4    , installed 2.5.4
    Adapter    "ble"          : 0.13.0   , installed 0.13.0
    Adapter    "chromecast"   : 2.3.1    , installed 3.0.3
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "history"      : 2.2.0    , installed 2.2.0
    Adapter    "ical"         : 1.13.1   , installed 1.13.2
    Adapter    "influxdb"     : 3.1.8    , installed 3.1.8
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.9   , installed 1.11.9
    Adapter    "javascript"   : 6.0.3    , installed 6.0.3
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "meross"       : 1.14.0   , installed 1.14.0
    Adapter    "mihome-vacuum": 3.4.2    , installed 3.8.3
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
    Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
    Adapter    "plex"         : 0.9.1    , installed 0.9.1
    Adapter    "shelly"       : 6.0.0    , installed 6.2.0
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.2
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
    Adapter    "telegram"     : 1.14.1   , installed 1.14.1
    Adapter    "text2command" : 2.2.2    , installed 2.2.2
    Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
    Adapter    "trashschedule": 2.0.3    , installed 2.0.3
    Adapter    "vis-canvas-gauges": 0.1.5, installed 1.0.1
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "yeelight-2"   : 1.1.2    , installed 1.2.0
    Objects and States
    Objects:        11389
    States:         8720
    Get:1 http://giteduberger.fr rpimonitor/ InRelease [1933 B]
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://archive.raspbian.org/raspbian buster InRelease
    Hit:4 https://repos.influxdata.com/debian buster InRelease
    Hit:5 https://deb.nodesource.com/node_16.x buster InRelease
    Hit:6 http://archive.raspberrypi.org/debian buster InRelease
    Fetched 1933 B in 3s (711 B/s)
    Reading package lists... Done
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          18376      657/lighttpd
    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      998        17646238   24085/pihole-FTL
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16826      658/sshd
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        16600      547/influxd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18386820   16043/io.sonoff.0
    tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      998        17647877   24085/pihole-FTL
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18385666   15787/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18385659   15787/iobroker.js-c
    tcp6       0      0 :::80                   :::*                    LISTEN      0          18377      657/lighttpd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18387529   15805/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18392931   16957/io.web.0
    tcp6       0      0 :::53                   :::*                    LISTEN      998        17646240   24085/pihole-FTL
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        18726      547/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          16836      658/sshd
    tcp6       0      0 :::3000                 :::*                    LISTEN      109        18903      683/grafana-server
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       18389437   16103/io.harmony.0
    tcp6       0      0 ::1:4711                :::*                    LISTEN      998        17647878   24085/pihole-FTL
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       18389438   16103/io.harmony.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       18389310   16028/io.shelly.0
    udp        0      0 0.0.0.0:53              0.0.0.0:*                           998        17646237   24085/pihole-FTL
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13680      529/dhcpcd
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       18387892   15953/io.mihome-vac
    udp        0      0 0.0.0.0:52910           0.0.0.0:*                           108        13626      341/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       18386562   15908/io.chromecast
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13624      341/avahi-daemon: r
    udp6       0      0 :::36811                :::*                                108        13627      341/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          17383070   529/dhcpcd
    udp6       0      0 :::53                   :::*                                998        17646239   24085/pihole-FTL
    udp6       0      0 :::5353                 :::*                                108        13625      341/avahi-daemon: r
    @jfwillow
    Ich sehe nichts wirklich auffälliges bei dir.
    Den Serial Port hast du freigeschaltet?
    • J Offline
      jfwillow
      denke schon
      pi@iobroker:~ $ ls -l /dev/serial/by-id
      insgesamt 0
      lrwxrwxrwx 1 root root 13 Nov  9 09:27 usb-Texas_Instruments_CC2538_USB_CDC-if00 -> ../../ttyACM0
      • J jfwillow
        denke schon
        insgesamt 0
        @jfwillow
        In
        sudo raspi-config
        Unter Interfaces mal geschaut?
          @jfwillow
          In
          sudo raspi-config
          jfwillow
          ehrlich gesagt nein.
          login-shell und serial interface beide auf enable oder nur das interface?
          • J jfwillow
            @jfwillow
            Nur das Interface.
            Einloggen willst du dich nicht.
              @jfwillow
              Nur das Interface.
              jfwillow
              Zuerst einmal danke für deine Hilfe!
              Interface enabled und reboot.
              Hat sich nichts geändert beim Versuch den Zigbee-Adapter zu installieren. Leider fehlgeschlagen.
              • J jfwillow
                @jfwillow
                Schaufel mal etwas RAM frei, bevor der Adapter installiert wird.
                Andere Instanzen stoppen z. B.
                  @jfwillow
                  jfwillow
                  Hat leider nicht wirklich was gebracht. Hab so ziemlich alles gestoppt. Trotzdem hat der Installationsversuch ewig gedauert und ist dann mit Error 25 abgebrochen. Mir ist aufgefallen, dass der SWAP immer mit 70% ausgelastet ist, hab in daraufhin deaktiviert...leider auch keine Veränderung :-(
                  Kurze Frage noch zum Bluetooth-Adapter...der ja auch seit dem Nnode.js-Update spinnt (also Gelb bleibt)...kannst du, oder jemand anderer, eventuell mit der Fehlermeldung etwas anfangen?
                  ble.0
                  2022-11-15 09:57:15.632	error	Cannot find module '@abandonware/bluetooth-hci-socket'Require stack:- /opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/hci.js- /opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/bindings.js- /opt/iobroker/node_modules/@abandonware/noble/lib/resolve-bindings.js- /opt/iobroker/node_modules/@abandonware/noble/index.js- /opt/iobroker/node_modules/iobroker.ble/build/scanProcess.js
                  • J jfwillow
                    ble.0
                    @jfwillow sagte in Zigbee Adapter lässt sich nicht mehr installieren:
                    Äähhh, den Notausgang mauerst du auch noch zu? Das ist ja mega sinnvoll.... (nicht).
                    Der SWAP-Bereich wird ja gerade in 'Notsituationen' genutzt, wenn der reguläre Arbeitsspeicher zur Neige gegangen ist.
                    Edit: Der war ja auch oben schon übervoll. Hab ich gar nicht gesehen:
                    *** MEMORY ***
                    Swap:           99M         99M        0.0K
                    Zu Bluetooth:
                    cd /opt/iobroker/node_modules/iobroker.ble
                    sudo -H -u iobroker npm install --omit=dev
                    • J Offline
                      jfwillow
                      @thomas-braun sagte in Zigbee Adapter lässt sich nicht mehr installieren:
                      Zu Bluetooth:
                      Hat leider nichts gebracht. Ist zwar fehlerlos durch gelaufen, der Adapter ist aber weiterhin gelb bei identischer Fehlermeldung.
                      Wird wohl auf eine Neuinstallation hinauslaufen. Schade, weil ausser Zigbee und Bluetooth, gefühlt alles tadellos funktioniert. Mal abgesehen von der gefühlten Ewigkeit bei Adapter-Updates/Neuinstallationen.
