  3. Entwicklung
  4. (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?
    6.5k
herdsmanzigbee
129 Beiträge 13 Kommentatoren 31.7k Aufrufe 12 Beobachtet
    @diamand2k22
    Bookmarks...
    Und ich kenne 'meine' HowTos und weiß was da drin steht. :-)
    Diamand2k22
    pi4b@pi4b:~$ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
    pi4b@pi4b:~$ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && ec        ho "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nod        ejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_T        YPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt        update && apt policy nodejs
    aarch64
    Kein Docker
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.18.1
    v16.18.1
    9.1.1
    4.0.23
    pi4b
    pi4b adm dialout cdrom sudo audio video plugdev games users input render netdev        gpio i2c spi iobroker
    tty
    /home/pi4b
    OK:1 http://deb.debian.org/debian bullseye InRelease
    OK:2 http://deb.debian.org/debian bullseye-updates InRelease
    OK:3 http://security.debian.org/debian-security bullseye-security InRelease
    OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
    OK:5 https://repos.influxdata.com/debian bullseye InRelease
    OK:6 https://packages.grafana.com/oss/deb stable InRelease
    OK:7 https://deb.nodesource.com/node_16.x bullseye InRelease
    Aktualisierung für 2 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, u        m sie anzuzeigen.
    nodejs:
      Installiert:           16.18.1-deb-1nodesource1
      Installationskandidat: 16.18.1-deb-1nodesource1
      Versionstabelle:
     *** 16.18.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u1 500
            500 http://security.debian.org/debian-security bullseye-security/main ar        m64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    pi4b@pi4b:~$
    sudo apt upgrade oder?
    • D Diamand2k22
      aarch64
      Kein Docker
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.18.1
      v16.18.1
      9.1.1
      4.0.23
      pi4b
      tty
      /home/pi4b
      nodejs:
        Versionstabelle:
      pi4b@pi4b:~$
      @diamand2k22
      sudo apt install --reinstall nodejs
      sudo apt full-upgrade
      Künftig die Finger von sowas wie npm install -g npm lassen.
        @diamand2k22
        Diamand2k22
        okay danke dir!
        • AsgothianA Asgothian
          @austrogaucho
          auf eigene Gefahr:
          • Herdsman und Herdsman converters Paket lokalisieren (entweder auf /opt/iobroker/node-modules oder /opt/iobroker/node-modules/iobroker.zigbee/node-modules)
          • Auf der Konsole In das entsprechende Verzeichnis gehen (/opt/iobroker oder /opt/iobroker/iobroker.zigbee)
          • zigbee adapter anhalten
          • per npm install zigbee-herdsman und npm install zigbee-herdsman-converters die aktuellen Versionen installieren
          • zigbee adapter starten und hoffen das alles läuft.
          Disclaimer - damit kann der Zigbee Adapter komplett instabil werden - wir haben das nicht getestet und werden das auch nicht testen. Wenn es nicht geht muss der Adapter vollständig deinstalliert (incl. zigbee-herdsman und zigbee-herdsman-converters) und dann neu installiert werden.
          A.
          Diamand2k22
          @asgothian said in (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?:
          @austrogaucho
          auf eigene Gefahr:
          A.
          @Thomas-Braun
          Ist dann diese Vorgehensweise noch aktuell wenn ich herdsmann converters updaten will?
          • D Diamand2k22
            @austrogaucho
            auf eigene Gefahr:
            A.
            @Thomas-Braun
            @diamand2k22 sagte in (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?:
            Warum willst du das überhaupt?
            Das ganze ist nämlich ggf. etwas rumpelig.
              Diamand2k22
              naja hab hier so doofe Heizkörperthermostate die nur mit aktuellern herdsmann convertern funktionieren.
              https://github.com/Koenkk/zigbee-herdsman-converters/tree/master/devices
              • D Diamand2k22
                @diamand2k22
                Hast du es zuvor mit der github-Version des zigbee-Adapters versucht?
                Das scheint mir besser zu sein als da module einfach reinzuballern.
                  @diamand2k22
                  Diamand2k22
                  die version aus github ist installiert oder wie meinst du?
                  • D Diamand2k22
                    @diamand2k22
                    cd /opt/iobroker && npm ls | grep zigbee
                      @diamand2k22
                      Diamand2k22
                      Ausgabe ist:
                      permitted by applicable law.
                      Last login: Mon Nov 14 21:41:15 2022 from 192.168.178.42
                      pi4b@pi4b:~$ cd /opt/iobroker && npm ls | grep zigbee
                      ├── iobroker.zigbee@1.7.6
                      ├── zigbee-herdsman-converters@14.0.666
                      └── zigbee-herdsman@0.14.71
                      pi4b@pi4b:/opt/iobroker$
                      • D Diamand2k22
                        Ausgabe ist:
                        @diamand2k22
                        Das ist nicht die github - Version.
                        Davon abgesehen ist
                        zigbee-herdsman
                        mal daneben geworfen worden. Das sollte nicht so hoch im Tree liegen.
                        • D Diamand2k22
                          Ausgabe ist:
                          @diamand2k22
                          Aktuelles github sähe so aus:
                          echad@chet:/opt/iobroker $ npm ls --depth=3 | grep zigbee
                          └─┬ iobroker.zigbee@1.7.6 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#84c9eb7accca10de87143e20c4494413a5a16873)
                            ├─┬ zigbee-herdsman-converters@14.0.666
                            │ └── zigbee-herdsman@0.14.73 deduped
                            └─┬ zigbee-herdsman@0.14.73
                            @diamand2k22
                            Davon abgesehen ist
                            zigbee-herdsman
                            Diamand2k22
                            Holy Shit, du machst mich fertig :-D das mit den daneben werfen kann ich bestätigen. kann man das rückgängig machen?
                            die version von github kann ich dann über
                            installieren?
                            • D Diamand2k22
                              installieren?
                              @diamand2k22
                              cd /opt/iobroker
                              npm uninstall zigbee-herdsman-converters
                              Und ich rede von der zigbee-Adapter github-Installation.
                              Mach das über 'die Katze', nicht die Weltkugel.
                              Die Katze nach dem zigbee-Adapter suchen lassen.
                                @diamand2k22
                                cd /opt/iobroker
                                Diamand2k22
                                schrieb am zuletzt editiert von Diamand2k22
                                ok kapiert, man lernt viel dazu!
                                nach der github installation wohl zigbee neu konfigurieren oder?
                                pi4b@pi4b:/opt/iobroker$ npm uninstall zigbee-herdsman-converters
                                removed 2 packages in 7s
                                65 packages are looking for funding
                                  run `npm fund` for details
                                removed 3 packages in 6s
                                • D Diamand2k22
                                  danach wohl zigbee neu konfigurieren oder?
                                  Nö, sollte nicht notwendig sein.
                                    Diamand2k22
                                    ok jetzt sieht es so aus
                                    pi4b@pi4b:/opt/iobroker$ npm ls --depth=3 | grep zigbee
                                      ├─┬ zigbee-herdsman-converters@14.0.575
                                      │ └── zigbee-herdsman@0.14.46 deduped
                                      └─┬ zigbee-herdsman@0.14.46
                                    jetzt installiere ich die github version u. hoffentlich klappt es.
                                    • D Diamand2k22
                                      @diamand2k22
                                      Dann sollte dann zigbee-herdsman-converters@14.0.666 installiert sein.
                                      Die zigbee-herdsman-converters@14.0.667 ist erst zwei Stunden alt, die ist noch nicht drin. Aber ich hoffe deine Thermostate sind nicht ausgerechnet erst da enthalten.
                                        @diamand2k22
                                        Diamand2k22
                                        shit...jetzt haben wir es glaub ich geschafft, jetzt läuft der adapter nicht mehr :-/...
                                        Ah,ok das ist die me167.js seh ich grad
                                        2022-11-14 22:48:32.397 - error: zigbee.0 (210117) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        2022-11-14 22:48:32.398 - error: zigbee.0 (210117) unhandled promise rejection: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/me167.js'
                                        2022-11-14 22:48:32.677 - error: zigbee.0 (210117) Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/me167.js'
                                        at Object.openSync (node:fs:590:3)
                                        at Object.readFileSync (node:fs:458:35)
                                        at Zigbee.getExternalDefinition (/opt/iobroker/node_modules/iobroker.zigbee/main.js:221:38)
                                        at getExternalDefinition.next ()
                                        at Zigbee.applyExternalConverters (/opt/iobroker/node_modules/iobroker.zigbee/main.js:235:20)
                                        at Zigbee.onReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:182:14)
                                        at Zigbee.emit (node:events:513:28)
                                        at Zigbee.emit (node:domain:489:12)
                                        at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9132:26
                                        2022-11-14 22:48:32.680 - error: zigbee.0 (210117) Exception-Code: ENOENT: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/me167.js'
                                        2022-11-14 22:48:32.714 - info: zigbee.0 (210117) cleaned everything up...
                                        2022-11-14 22:48:32.717 - info: zigbee.0 (210117) terminating
                                        2022-11-14 22:48:32.722 - warn: zigbee.0 (210117) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        2022-11-14 22:48:33.308 - error: host.pi4b Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                        2022-11-14 22:48:33.309 - error: host.pi4b Caught by controller[1]: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/me167.js'
                                        2022-11-14 22:48:33.309 - error: host.pi4b Caught by controller[1]: at Object.openSync (node:fs:590:3)
                                        2022-11-14 22:48:33.309 - error: host.pi4b Caught by controller[1]: at Object.readFileSync (node:fs:458:35)
                                        2022-11-14 22:48:33.309 - error: host.pi4b Caught by controller[1]: at Zigbee.getExternalDefinition (/opt/iobroker/node_modules/iobroker.zigbee/main.js:221:38)
                                        2022-11-14 22:48:33.309 - error: host.pi4b Caught by controller[1]: at getExternalDefinition.next ()
                                        2022-11-14 22:48:33.309 - error: host.pi4b Caught by controller[1]: at Zigbee.applyExternalConverters (/opt/iobroker/node_modules/iobroker.zigbee/main.js:235:20)
                                        2022-11-14 22:48:33.309 - error: host.pi4b Caught by controller[1]: at Zigbee.onReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:182:14)
                                        2022-11-14 22:48:33.309 - error: host.pi4b Caught by controller[1]: at Zigbee.emit (node:events:513:28)
                                        2022-11-14 22:48:33.310 - error: host.pi4b Caught by controller[1]: at Zigbee.emit (node:domain:489:12)
                                        2022-11-14 22:48:33.310 - error: host.pi4b Caught by controller[1]: at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9132:26
                                        2022-11-14 22:48:33.310 - error: host.pi4b instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                        2022-11-14 22:48:33.310 - info: host.pi4b Restart adapter system.adapter.zigbee.0 because enabled
                                        2022-11-14 22:48:33.310 - warn: host.pi4b Do not restart adapter system.adapter.zigbee.0 because restart loop detected
                                        • D Diamand2k22
                                          Wir? Du!
                                          Bei mir läuft der Adapter in der github-Version.
