  4. Test Adapter weishaupt WEM Portal v0.0.x
weishauptwemwem portal
163 Beiträge 29 Kommentatoren 39.3k Aufrufe 26 Beobachtet
  • T tombox
    @emil70 Nein hat eigentlich bisher bei allen funktioniert
    E Online
    E Online
    emil70
    #106
    @tombox
    Ok, nutze den Adapter schon länger. Bei mir steht da auch nix drin ausser "null"
    Habe hier auch ständig Fehlermeldungen
    2022-11-13 13:36:58.679 - error: weishaupt-wem.0 (22946) TypeError: Cannot read properties of null (reading 'textContent')
    2022-11-13 13:36:58.683 - error: weishaupt-wem.0 (22946) TypeError: Cannot read properties of null (reading 'textContent')
    und
    weishaupt-wem.0 2022-11-13 14:06:31.950	error	Failed to get status
    weishaupt-wem.0 2022-11-13 14:06:31.944	error	Not able to parse device name and status try to relogin
    weishaupt-wem.0 2022-11-13 14:06:31.942	error	TypeError: Cannot read properties of null (reading 'textContent') at Request._callback (/opt/iobroker/node_modules/iobroker.weishaupt-wem/main.js:344:92) at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22) at Request.emit (node:events:513:28) at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10) at Request.emit (node:events:513:28) at Gunzip.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12) at Object.onceWrapper (node:events:627:28) at Gunzip.emit (node:events:513:28) at endReadableNT (node:internal/streams/readable:1358:12) at processTicksAndRejections (node:internal/process/task_queues:83:21)
    weishaupt-wem.0 2022-11-13 14:06:31.938	error	TypeError: Cannot read properties of null (reading 'textContent')
    weishaupt-wem.0 2022-11-13 13:36:58.693	error	Failed to get status
    weishaupt-wem.0 2022-11-13 13:36:58.687	error	Not able to parse device name and status try to relogin
    weishaupt-wem.0 2022-11-13 13:36:58.683	error	TypeError: Cannot read properties of null (reading 'textContent') at Request._callback (/opt/iobroker/node_modules/iobroker.weishaupt-wem/main.js:344:92) at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22) at Request.emit (node:events:513:28) at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10) at Request.emit (node:events:513:28) at Gunzip.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12) at Object.onceWrapper (node:events:627:28) at Gunzip.emit (node:events:513:28) at endReadableNT (node:internal/streams/readable:1358:12) at processTicksAndRejections (node:internal/process/task_queues:83:21)
    weishaupt-wem.0 2022-11-13 13:36:58.679	error	TypeError: Cannot read properties of null (reading 'textContent')
    Weiß jemnand was dazu??
    gruss emil70
    iobroker,pihole,homematic,motioneys,solaranlage laufen auf Proxmox (16 x AMD Ryzen 7 6800H with Radeon Graphics )
    W 1 Antwort Letzte Antwort
    • E emil70
      @tombox
      und
      W Offline
      W Offline
      Wolfi 0
      #107
      @emil70
      So sehen die Fehlermeldungen bei mir auch aus.
      Ich glaube übrigens nicht, dass das etwas mit der Fachmannebene zu tun hat, da diese Werte ja ausgelesen werden. Nur eben die "Standardwerte" nicht, die es auch in der normalen Benutzerebene gibt.
      Ist es denkbar, dass Weishaupt Variablennamen geändert hat? Ich kann leider kein JavaScript, mir ist nicht so ganz klar, wo in der main.js die Werte für z.B. WWSollNormal ausgelesen werden. Kann man das irgendwie spezifisch testen?
      • W Wolfi 0
        Hallo Forum,
        auch von mir Danke für die Arbeit am Weishaupt-Adapter.
        Leider bekomme ich ihn nicht komplett zum Laufen.
        Beim Starten des Adapters kommt folgende Meldung im Protokoll:
        In der Folge werden auch die Remote-Werte nicht ausgelesen und können auch nicht gesendet werden:
        Woran liegt es, dass die dataPointid nicht gefunden wird?
        Ich hab auch mit den Custom-Befehlen rungemurkst, mal geht es, mal geht es nicht und der Adapter stürzt dann öfters ab.
        Wenn die Remote-Variablen sauber ausgelesen und gesetzt werden könnten, wäre das ja auch insofern toll, dass ich dann das Bestätigt-Flag erhalte, oder?
        Bin für jede Hilfe dankbar (bin leider nicht so der Checker 😕 )...
        Danke!
        tombox
        #108
        @wolfi-0 Bräuchte ich mal die Zugangsdaten. Es ist wichtig dass nur eine Anlage im Account ist.
        • W Wolfi 0
          @emil70
          tombox
          #109
          @wolfi-0 Also deine Url für WWSollNormal ist nicht die standard mässig sonder custom
          https://www.wemportal.com/Web/UControls/Weishaupt/DataDisplay/WwpsParameterDetails.aspx?entityvalue=46005D0100000001CC40003A380300110104&readdata=True&rwndrnd=0.0107517697694679
          Es scheint so dass dieser Befehl eigentlich für jede Anlage anders ist
          Etwaige Fehlermeldung kann ich nicht sehen
          welche Werte fehlen denn genau
          • T tombox
            W Offline
            W Offline
            Wolfi 0
            #110
            @tombox
            Die aus dem Remoteordner:
            • W Wolfi 0
              @tombox
              tombox
              #111
              @wolfi-0 Die werden nie gefüllt
              • T tombox
                W Offline
                W Offline
                Wolfi 0
                #112
                @tombox
                Ach die werden gar nicht ausgelesen?
                • W Wolfi 0
                  @tombox
                  tombox
                  #113
                  @wolfi-0 nein sind nur remote zustände die nur zum ausführen gedacht sind
                  • T tombox
                    W Offline
                    W Offline
                    Wolfi 0
                    #114
                    @tombox
                    Ok, schade.
                    Deshalb wird man aber auch nie ein bestätigt-Flag bekommen können, dass ein Wert auch wirklich gesetzt wurde.
                    Irgendeine Möglichkeit auch diese Werte auszulesen?
                    Und Danke für Deinen Einsatz!
                    • W Wolfi 0
                      @tombox
                      Ok, schade.
                      tombox
                      #115
                      @wolfi-0 Kannst du ein screenshot machen wo du ein wert hast der dir fehlt
                      • T tombox
                        W Offline
                        W Offline
                        Wolfi 0
                        #116
                        @tombox
                        Es fehlt mir z.B. der folgende Wert (wie gesagt, eigentlich alle aus dem Remoteordner und noch mehr):
                        WWSollNormal
                        Hier sämtliche Werte die ausgelesen und angezeigt werden:
                        Aber ich glaube ich kapiere jetzt, wo das Problem liegt:
                        Alle angezeigten Werte stammen aus dem Portalmenüpunkt "Info" aus der Fachmannebene.
                        Die von mir gesuchten Werte stammen aus anderen Menüpunkten:
                        Heizkreisbetriebsart - ?
                        Pumpebetriebsart - ?
                        RaumAbsenkTemp: "Heizkreis 1" sowie "Heizkreis 2"
                        RaumKomfortTemp: "Heizkreis 1" sowie "Heizkreis 2"
                        RaumNormalTemp: "Heizkreis 1" sowie "Heizkreis 2"
                        Systembetriebsart: "Systembetriebsart"
                        WWPush: "Warmwasser"
                        WWSollAbsenk: "Warmwasser"
                        WWSollNormal: "Warmwasser"
                        (Blau wäre jetzt beispielhaft mal der gesuchte Wert WWSollNormal)
                        -> Die Frage ist also, ob es möglich ist, auch die Werte aus den anderen Menüpunkten auszugeben?
                        • T tombox
                          @willor dann bräuchte ich zugang zu dem account um das zu realisieren
                          proton
                          #117
                          Hi @tombox , hat sich inzwischen etwas getan bzgl. der Unterstützung mehrerer Anlagen in einem Portal-Account (siehe Anfrage von Willor aus 2021)? Zu Vergleichszwecken habe ich die Anlage eines Freundes (die gleiche wie meine) eingebunden, um die Werte zu vergleichen. Seitdem funktioniert aber der Adapter nicht mehr. Alternativ würde ich wie oben vorgeschlagen auf eine andere Mail-Adresse und damit anderen Account ausweichen.
                          • P proton
                            tombox
                            #118
                            @proton Unterstützung von Mehrgeräte Accounts wäre zu aufwendig
                            P 1 Antwort Letzte Antwort
                            • T tombox
                              proton
                              #119
                              @tombox Ok, kann ich nachvollziehen, nachdem ich mal in den Code reingeschaut habe... Aber hätte ja sein können, dass da was in Planung ist ;-) Dann weiche ich doch auf einen 2. Account aus, ist eh nur zum Vergleichen, da meine Anlage neu ist und aus meiner Sicht noch nicht wirklich effizient läuft.
                              Aber danke für den Adapter!! Sehr wertvoll für mich, insbesondere das Aufzeichnen der Werte und Abgleichen mit meinen anderen Sensoren.
                                TomTom24
                                #120
                                sieht so aus, als wenn beim Volumenstrom die Einheit mit in den Wert geschrieben wird.
                                Kann das bitte gefixt werden?
                                Danke Tom
                                • T TomTom24
                                  Danke Tom
                                  tombox
                                  #121
                                  @tomtom24 was ist der genaue Pfad von dem wert und was steht da drin
                                  • J Offline
                                    Juri88
                                    #122
                                    Hallo liebe Leute,
                                    ich habe eine Wärmepumpe (BiBlock) und versuche diese über den Adapter zu steuern (Maximal Leistung in % beim Heizen). Aber irgendwie bin ich zu blöd.
                                    Konkret gehe ich folgende Schritte.
                                    Ich ziehe mir die URL hier
                                    Suche dann nach "iframe"
                                    und kopiere die URL
                                    Danach schaue ich unter "<optionen" nach den "Werten"
                                    In dem Fall kann ich ganz normal die "Zahl" nehmen.
                                    Das ganze füge ich dann im IOB als Wert ein.
                                    In meinem Fall wollte ich den Wert auf 80% legen.
                                    Das bestätige ich dann mit "Werte setzen" und bekomme folgenden Log. angezeigt.
                                    Kann mir jemand sagen, was ich hier falsch mache?
                                    • J Juri88
                                      Hallo liebe Leute,
                                      und kopiere die URL
                                      tombox
                                      #123
                                      @juri88 Bitte das Portal wemportal.com nutzen nicht wemportal.de
                                      • T tombox
                                        Juri88
                                        #124
                                        @tombox Danke! :) Das war es natürlich !
                                        • T tombox
                                          TomTom24
                                          #125
                                          @tombox Pfad - weishaupt-wem.0.Tom Oberwiera.Volumenstrom
                                          Da ist die Einheit mit in den Wert gerutscht - 1.9m3/h - sollte also als Wert nur 1.9 auswerfen.
                                          Hab das jetzt mit einem Script gefixt, aber schöner wäre es, wenn das gefixt werden könnte.
                                          Danke.👍
