  4. Test Adapter Tuya 3.8.0 - BEENDET
94 Beiträge 13 Kommentatoren 18.1k Aufrufe 13 Beobachtet
  • apollon77A apollon77
    @ofbeqnpolkkl6mby5e13 aktuellste github version? dann bitte debug Log an mich per email. Bzw man nochmal nen Sync via admin(falls login Daten nicht gespeichert)
    O Offline
    O Offline
    oFbEQnpoLKKl6mbY5e13
    #80
    @apollon77
    Ja.
      "type": "device",
      "common": {
        "name": "Device 41465054f4cfa21eff44",
        "read": true
      "native": {
        "virtual": false,
        "dpName": {
          "1": "Leuchtturm",
          "2": "Lichterkette"
        "lon": "10.3062",
        "uuid": "41465054f4cfa21eff44",
        "mac": "f4cfa21eff44",
        "iconUrl": "https://images.tuyaeu.com/smart/icon/1511839633_0.png",
        "runtimeEnv": "prod",
        "lat": "52.0414",
        "devId": "41465054f4cfa21eff44",
        "dpMaxTime": 1667422875696,
        "productId": "EQD8hAQw543vzh6O",
        "activeTime": 1665658263,
        "categoryCode": "wf_kg",
        "moduleMap": {
          "wifi": {
            "upgradeStatus": 0,
            "cdv": "1.0.0",
            "bv": "5.57",
            "pv": "2.2",
            "verSw": "1.0.7",
            "isOnline": true,
            "id": 15940216,
            "cadv": ""
          "mcu": {
            "upgradeStatus": 0,
            "cdv": "",
            "verSw": "1.0.7",
            "isOnline": true,
            "id": 15940217,
            "cadv": ""
        "devAttribute": 3,
        "name": "Carport (Doppelstecker)",
        "timezoneId": "Europe/Berlin",
        "category": "kg",
        "localKey": "68ed92497a87380e",
        "schema": [
            "mode": "rw",
            "code": "switch_1",
            "name": "开关",
            "property": {
              "type": "bool"
            "iconname": "icon-dp_power",
            "id": 1,
            "type": "obj",
            "desc": ""
            "mode": "rw",
            "code": "switch_2",
            "name": "开关 2",
            "property": {
              "type": "bool"
            "id": 2,
            "type": "obj",
            "desc": ""
            "mode": "rw",
            "code": "countdown2",
            "name": "倒计时2",
            "property": {
              "unit": "",
              "min": 0,
              "max": 86400,
              "scale": 0,
              "step": 1,
              "type": "value"
            "id": 101,
            "type": "obj",
            "desc": ""
            "mode": "rw",
            "code": "countdown1",
            "name": "倒计时1",
            "property": {
              "unit": "",
              "min": 0,
              "max": 86400,
              "scale": 0,
              "step": 1,
              "type": "value"
            "id": 102,
            "type": "obj",
            "desc": ""
        "productKey": "EQD8hAQw543vzh6O",
        "schemaExt": [
            "id": 6,
            "inputStyle": "",
            "inputType": ""
        "version": "3.3",
        "ip": "192.168.0.40",
        "gwId": "41465054f4cfa21eff44",
        "active": 2,
        "ability": 0,
        "mode": 0,
        "encrypt": true,
        "devKey": ""
      "from": "system.adapter.tuya.0",
      "user": "system.user.admin",
      "ts": 1667731711824,
      "_id": "tuya.0.41465054f4cfa21eff44",
      "acl": {
        "object": 1636,
        "owner": "system.user.admin",
    "devAttribute": 3,
      @latzi ja logs wären ggf interessant. Zeig mal
      LatziL Online
      LatziL Online
      Latzi
      #81
      @apollon77 sagte in Test Adapter Tuya 3.8.0:
      Ich hab die Vorgeschichte des Starts weggelassen, da lange und ohne Besonderheiten - Fehler trat bei mir bei 10 sek Abfrageintervall auf, bei 30 sek (siehe Bild unten) gibt´s keine Fehler.
      2022-11-06 11:40:02.117 - info: tuya.0 (3595414) 00032373cc50e37a5e26 Init with IP=10.0.0.81, Key=4cbf92670f7b66d5, Version=3.3
      2022-11-06 11:40:02.118 - info: tuya.0 (3595414) 50731888600194b821ae Init with IP=10.0.0.21, Key=d18bf2c7767dcbca, Version=3.1
      2022-11-06 11:40:02.119 - info: tuya.0 (3595414) 000323732cf4321fcba3 Init with IP=10.0.0.79, Key=361cabc0f4c45d62, Version=3.3
      2022-11-06 11:40:20.238 - error: tuya.0 (3595414) uncaught exception: Converting circular structure to JSON
      --> starting at object with constructor 'Timeout'
      | property '_idlePrev' -> object with constructor 'TimersList'
      --- property '_idleNext' closes the circle
      2022-11-06 11:40:20.238 - error: tuya.0 (3595414) TypeError: Converting circular structure to JSON
      at JSON.stringify ()
      at initDevice (/opt/iobroker/node_modules/iobroker.tuya/main.js:513:81)
      at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.tuya/main.js:481:26)
      at listOnTimeout (node:internal/timers:559:17)
      at processTimers (node:internal/timers:502:7)
      2022-11-06 11:40:20.238 - error: tuya.0 (3595414) Converting circular structure to JSON
      2022-11-06 11:40:20.368 - info: tuya.0 (3595414) 050407552462ab2f85d2 Init with IP=10.0.0.109, Key=e6cac32a1ac22ffc, Version=3.3
      2022-11-06 11:40:20.520 - error: host.ioBroker Caught by controller[0]: TypeError: Converting circular structure to JSON
      2022-11-06 11:40:20.520 - error: host.ioBroker Caught by controller[0]: --> starting at object with constructor 'Timeout'
      2022-11-06 11:40:20.520 - error: host.ioBroker Caught by controller[0]: | property '_idlePrev' -> object with constructor 'TimersList'
      2022-11-06 11:40:20.520 - error: host.ioBroker Caught by controller[0]: --- property '_idleNext' closes the circle
      2022-11-06 11:40:20.520 - error: host.ioBroker Caught by controller[0]: at JSON.stringify ()
      2022-11-06 11:40:20.520 - error: host.ioBroker Caught by controller[0]: at initDevice (/opt/iobroker/node_modules/iobroker.tuya/main.js:513:81)
      2022-11-06 11:40:20.520 - error: host.ioBroker Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.tuya/main.js:481:26)
      2022-11-06 11:40:20.520 - error: host.ioBroker Caught by controller[0]: at listOnTimeout (node:internal/timers:559:17)
      2022-11-06 11:40:20.520 - error: host.ioBroker Caught by controller[0]: at processTimers (node:internal/timers:502:7)
      2022-11-06 11:40:20.520 - error: host.ioBroker instance system.adapter.tuya.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2022-11-06 11:40:20.520 - info: host.ioBroker Restart adapter system.adapter.tuya.0 because enabled
      2022-11-06 11:40:50.590 - info: host.ioBroker instance system.adapter.tuya.0 started with pid 3597382
      2022-11-06 11:40:51.198 - info: admin.0 (464) ==> Connected system.user.admin from ::ffff:10.0.0.170
      2022-11-06 11:40:51.826 - info: tuya.0 (3597382) starting. Version 3.8.0 (non-npm: Apollon77/ioBroker.tuya#d0259cae661753265dc6a71e356704e40df73dc4) in /opt/iobroker/node_modules/iobroker.tuya, node: v16.18.1, js-controller: 4.0.23
      • LatziL Latzi
        #82
        @latzi >magst es mal mit neuer GitHub version nochmal versuchen bitte mit 10s?
        LatziL 1 Antwort Letzte Antwort
        • O oFbEQnpoLKKl6mbY5e13
          @apollon77
          Ja.
            "type": "device",
            "common": {
              "read": true
            "native": {
              "virtual": false,
              "dpName": {
                "1": "Leuchtturm",
                "2": "Lichterkette"
              "lon": "10.3062",
              "lat": "52.0414",
              "moduleMap": {
                "wifi": {
                  "upgradeStatus": 0,
                  "cdv": "1.0.0",
                  "bv": "5.57",
                  "pv": "2.2",
                  "verSw": "1.0.7",
                  "isOnline": true,
                  "id": 15940216,
                  "cadv": ""
                "mcu": {
                  "upgradeStatus": 0,
                  "cdv": "",
                  "verSw": "1.0.7",
                  "isOnline": true,
                  "id": 15940217,
                  "cadv": ""
              "devAttribute": 3,
              "category": "kg",
              "schema": [
                  "mode": "rw",
                  "code": "switch_1",
                  "name": "开关",
                  "property": {
                    "type": "bool"
                  "id": 1,
                  "type": "obj",
                  "desc": ""
                  "mode": "rw",
                  "code": "switch_2",
                  "name": "开关 2",
                  "property": {
                    "type": "bool"
                  "id": 2,
                  "type": "obj",
                  "desc": ""
                  "mode": "rw",
                  "name": "倒计时2",
                  "property": {
                    "unit": "",
                    "min": 0,
                    "max": 86400,
                    "scale": 0,
                    "step": 1,
                    "type": "value"
                  "id": 101,
                  "type": "obj",
                  "desc": ""
                  "mode": "rw",
                  "name": "倒计时1",
                  "property": {
                    "unit": "",
                    "min": 0,
                    "max": 86400,
                    "scale": 0,
                    "step": 1,
                    "type": "value"
                  "id": 102,
                  "type": "obj",
                  "desc": ""
              "schemaExt": [
                  "id": 6,
                  "inputStyle": "",
                  "inputType": ""
              "version": "3.3",
              "active": 2,
              "ability": 0,
              "mode": 0,
              "encrypt": true,
              "devKey": ""
            "acl": {
              "object": 1636,
          "devAttribute": 3,
          #83
          @ofbeqnpolkkl6mby5e13 Dann volles debug log bitte ... kapiere ich nicht warum das bei dir passiert ... bei anderen gehen die Namen wieder mit neuestem Github. Das wurde auch erfolgreich installiert ohne Fehler?
          O 1 Antwort Letzte Antwort
            O Offline
            O Offline
            #84
            @apollon77
            Ja. Es ist auch nur dieses eine Gerät.
              LatziL Online
              LatziL Online
              Latzi
              #85
              👏 👍 Bingo Ingo!!! (hast du vermutlich noch nie gehört ;-) )
                @apollon77
                #86
                @ofbeqnpolkkl6mby5e13 Dann mal Debug log senden bitte
                • LatziL Latzi
                  #87
                  @latzi noch niiiiieeee ;-))
                    LatziL Online
                    LatziL Online
                    Latzi
                    #88
                    @apollon77
                    dachte ich mir ;-))
                    Mir fiel eben auf, dass nur 6 meiner 37 Geräte "online" sind (10 sind auch wirklich offline), die vermeindlichen "Offline"-Geräte kann ich aber problemlos bedienen (in der App sind sie auch als online dargestellt). Hab das Abfrageintervall schon verändert und einige Male den Adapter neu gestartet, ändert aber nur insofern etwas, dass manche Geräte dazukommen, andere weg - bleibt nicht jedesmal gleich.
                    Sehr seltsam.
                    • LatziL Latzi
                      @apollon77
                      dachte ich mir ;-))
                      Sehr seltsam.
                      #89
                      @latzi Also hier sollte das Logfile (auch ohne debug) aber zeigen welche Geräte gerade lokale Verbindungsprobleme haben. bedenke bitte das wenn die App offen ist der Adapter sich nicht lokal verbinden kann weil pot die App diese lokale Verbindung blockiert. Steht aber dann auch im Log.
                      Und die App bzw seit neuestem der Adapter bedienen halt über die Cloud wenn Sie keine lokale Verbindung bekommen
                      • apollon77A Offline
                        #90
                        So dann an alle. Bitte nochmal GitHub aktualisieren und checkt nochmal alles auf Herz und Nieren. Wenn nichts mehr kommt (Warte noch auf ein Log wegen Namen von @oFbEQnpoLKKl6mbY5e13 ) würde ich den Alpha Test dann bald beenden und Beta releasen
                          O Offline
                          O Offline
                          #91
                          @apollon77
                          Kommt kein Log mehr von mir. Ich habe es manuell umbenannt. Es bleibt erhalten.
                            #92
                            Na dann ... Bitte alle nochmal updaten und checken!!
                              LatziL Online
                              LatziL Online
                              Latzi
                              #93
                              genau das war mein Problem - vielen Dank!!!
                                #94
                                Hallo alle zusammen,
                                ich bedenke mich ganz Herzlich für Euren Test-Eifer! Die 3.8.1 als aktuellste Version ist auf dem Weg ins Beta Repo und daher mache ichhier zu und nen neuen Thread auf.
                                Vielen Dank für Eure Unterstützung beim Checken des Groß-Updates. Kinderkrankheiten haben wir denke ich gut wegbekommen.
                                ACHTUNG: GitHub version ist jetzt wieder Dev-Spielwiese für noch weitere Themen und kann kaputt sein!!
