  4. Ring Doorbell Bild versenden
ring adapter
86 Beiträge 21 Kommentatoren 20.8k Aufrufe 18 Beobachtet
  • D denjo
    kann mir jemand sagen was diese fehlermeldung zu sagen hat???
    writeFile	2020-11-14 21:43:58.109	warn	will not write this file (doorbell_49207736/livestream.mp4) in future versions: ring.0 is not an object of type "meta"
    ring.0	2020-11-14 21:43:58.087	warn	(1734) writeFile will not write this file (doorbell_49207736/livestream.mp4) in future versions: ring.0 is not an object of type "meta"
    MyMeyer
    @denjo Schon ein Lösung dazu gefunden ?
    Error: Error setSanpshot()): Error: Could not create Snapshot for 45172445 in getSnapshot(). Error: Snapshot for Haustür failed to refresh after 70 attempts. This is normal behavior since th
    ring.0 2020-11-18 08:17:38.885 warn (28878) writeFile will not write this file (doorbell_45172445/livestream.mp4) in future versions: ring.0 is not an object of type "meta"
    MyMeyer
    >>> Hardware: Intel I5 mit ****Debian ProxMox OS: Debian **** <<< >>> Network with UniFi <<<
    >>> HomeMatic CCU-2 (Wired und Funk) / Philips HUE / Echo.DOT / Echo.SHOW / Xiaomi Smart-Home / Xiaomi Robot Vacuum Cleaner / Synology DS 918+ / Shelly 1&2 <<<
    • M MCU
      @denjo https://support.ring.com/hc/de/articles/204384784-Die-Ring-App-herunterladen
      andyb
      schrieb am zuletzt editiert von andyb
      Kann mir jemand helfen.....ich bekomme keinen Snap und kein Video.
      Augenscheinlich tut alles, aber es werden keine Dateien erzeugt, Verzeichnis bleibt leer. Berechtigungen sind vergeben.
      host.iob2	2020-11-21 08:59:47.530	warn	writeFile will not write this file (doorbell_32387933/snapshot.jpg) in future versions: ring.0 is not an object of type "meta"
      ring.0	2020-11-21 08:59:47.498	warn	(16269) writeFile will not write this file (doorbell_32387933/snapshot.jpg) in future versions: ring.0 is not an object of type "meta"
      ring.0	2020-11-21 08:59:47.486	info	(16269) Done creating snapshot
      host.iob2	2020-11-21 08:59:39.481	warn	writeFile will not write this file (doorbell_32387933/livestream.mp4) in future versions: ring.0 is not an object of type "meta"
      ring.0	2020-11-21 08:59:39.342	warn	(16269) writeFile will not write this file (doorbell_32387933/livestream.mp4) in future versions: ring.0 is not an object of type "meta"
      ring.0	2020-11-21 08:59:39.300	info	(16269) Done creating livestream
      ring.0	2020-11-21 08:59:28.442	info	(16269) Starting creating livestream with recording time 10 sec.
      ring.0	2020-11-21 08:59:11.497	info	(16269) Starting creating snapshot
      ring.0	2020-11-21 08:59:11.403	info	(16269) Ding Dong for Id 32387933 (on_demand, ringing)
      ring.0	2020-11-21 08:59:11.389	info	(16269) Ding Dong for Id 32387933 (on_demand, ringing)
      ring.0	2020-11-21 08:59:01.077	info	(16269) Starting Ring Device for Id 32387933
      ring.0	2020-11-21 08:58:59.323	info	(16269) Starting Adapter ring.0 in version 1.1.5-beta
      ring.0	2020-11-21 08:58:59.260	info	(16269) starting. Version 1.1.5-beta in /opt/iobroker/node_modules/iobroker.ring, node: v10.22.1, js-controller: 3.1.6
      host.iob2	2020-11-21 08:58:52.779	info	instance system.adapter.ring.0 started with pid 16269
      C E 2 Antworten Letzte Antwort
      • A andyb
        ChrisXY
        Komisch ich bekomme livestreams gespeichert aber kein snapshot .. wenn ich es manuell auslöse hab ich folgendes im LOG:
        (7660) Error: Error setSanpshot()): Error: Could not create Snapshot for 49417401 in getSnapshot(). Error: Motion detection is disabled for Haustür, which prevents snapshots from this camera. This c
        Will ungern motion aktivieren das zieht ja nur akku .. möchte einfach ein Foto haben wenn es klingelt
        • A andyb
          erniecs
          @andyb
          genau so ist es bei mir auch, wenn ich die Datei aus dem Verzeichnis raus lösche, dann speichert er 3-4 mal die Bilder, danach aktualisiert er die Datei wieder nicht mehr.
          • D denjo
            @lobomau https://github.com/schmupu/ioBroker.ring
            erniecs
            @denjo sagte in Ring Doorbell Bild versenden:
            Wo finde ich da die Version 1.1.5 ? Im Änderungsprotokoll steht 1.1.5 aber zum Download gibts nur 1.1.3
            bin etwas verwirrt
              mandragora
              schrieb am zuletzt editiert von mandragora
              Hallo und erstmals vielen Dank fürs sharen vom Blockly
              Ich hab noch eine kleine Frage und ein Problem damit
              Es werden bei mir die beiden Files angelegt.
              Wenn nun jemand klingelt werden neue Files erzeugt und ich bekomm die Nachrichten auch nach Telegram.
              Allerdings kein Bild und Video sonder nur die Pfade
              Was mach ich hier falsch bzw. was könnte ich hier übersehen haben ?
              Wäre fein wenn mir jemand auf die Sprünge helfen könnte.
              Vielen Dank schon mal für eure Hilfe.
              lg
              mandragora
              ioBroker auf Synology DS218+ (Docker); VIS: 2x8" Tablets; Homematic CCU2 und Komponenten; Echo DOT; Unifi Ap-Ac Pro; Landroid S; Jovision IPCams
              • D denjo
                So also, ist klar das ihr Telegram einrichten müsst und den Rest seht ihr an den Bildern hoffe ich, falls fragen sind einfach fragen.10-11-_2020_14-33-29.png 10-11-_2020_14-30-35.png 10-11-_2020_14-29-31.png
                teilchenb
                @denjo
                Vielen Dank für deine tolle Anleitung.
                Ich habe bei mir folgendes festgestellt (was auch durch einige Folgebeiträge von anderen evtl. bereits geäußert wurde):
                Nach deiner Anleitung werden im konfigurierten "Pfad Schnappschuss /Livestream" die Dateien erzeugt sobald die "Request-Button" ausgelöst werden. Beim Blick in das Schnappschussverzeichnis habe ich dann aber festgestellt, das immer nach ca. 10 Sekunden ("Aufnahmezeit im Livestream in Sek." in meiner Konfiguration) zuerst die lievestream.mp4 erstellt wird, die dann auch in Telegram angezeigt wird und erst nach ca. 40 Sekunden die snapshot.jpg-Datei, weshalb in Telegram immer nur der Link zur Datei auftaucht.
                Ist es möglich immer erst einen Schnappschuss machen zu lassen und dann einen Livestream oder liegt das an der Hardware?
                Wenn ich die Aufnahmedauer für den Livestream auf 0 Sekunden mache, erhalte ich hin und wieder mal eine snapshot.jpg-datei nach ca. 4 Sekunden.
                Ich würde auch wohl gänzlich auf die livestream.mp4 verzichten.
                Viele Grüße, teilchenB
                • T teilchenb
                  @denjo
                  denjo
                  @teilchenb also, nur nochmal zur Info ich bin kein Profi. Und habe mir das alles mal zusammen gebaut und bei mir funktioniert es immer noch tadellos. Habt ihr auch die Verzögerung eingebaut und auch die richtige Version des Adapters?
                  • D denjo
                    denjo
                    schrieb am zuletzt editiert von denjo
                    Hallo an alle, also da ring kaputt gegangen ist und ich jetzt eine neue habe habe ich meine einstellungen angepasst und jetzt läuft alles tadellos. ihr müsst im adapter die zeit auf 10 sek stellen und wie im screenshot zu sehen eine verzögerung noch einbauen von 2 sek, dann bekommt auch ein video per telegram gesenden und nicht den link.
                    • D denjo
                      @denjo ich wollte das nach deiner Anleitung machen, habe aber nicht mal den "if there ist a Doorbell press event" Datenpunkt.
                      Bei mir schaut das so aus. Kannst du helfen?
                      D lobomauL 2 Antworten Letzte Antwort
                        denjo
                        @jayba ich kann nur sagen das ich datenpunkt habe, würde den Adapter mal neu installieren oder so. Welche Version hast denn drauf
                        • D denjo
                          @denjo hab ich gestern schon neu installiert und es auch mit der 3.1.7 versucht aber die Datenpunkte bekomme ich nicht. Ich nutze die Ring Pro mit einem Abo. Kannst du mir mal deine Datenpunkte zeigen?
                            denjo
                              lobomauL Offline
                              lobomauL Offline
                              lobomau
                              schrieb am zuletzt editiert von lobomau
                              @jayba hast du schon mal geklingelt bei dir?
                              Also ich habe es auch bei mir neu installiert und es sieht aus wie bei dir. Wenn ich gleich nach Hause komme, werde ich mal bei mir klingeln und gehe davon aus, dass der Datenpunkt dann bei mir erscheint.
                              Bei mir läuft Version 3.1.3.
                              Ansonsten habe ich die Funktionen Bilder und Videos an telegram senden ausprobiert und es funktioniert :-)
                              Edit.: nee, kommt kein DP dazu. Aber man wird den hier wohl nehmen können als trigger. Wenn aktualisiert und Wert = ding:
                              ring.0.doorbell_21374xxx.History.kind
                              Host: NUC8i3 mit Proxmox:
                              • Slave: Pi4
                              D ? 2 Antworten Letzte Antwort
                              • lobomauL lobomau
                                denjo
                                @lobomau @JayBa wie ich gerade sehe funktioniert bei mir auch nix mehr. der datenpunkt ist bei mir auch nicht mehr da.
                                so habe jetzt wieder auf version 3.0.1 runter installiert und alles funktioniert.
                                Das geht mit diesen befehl
                                iobroker upgrade ring@3.0.1
                                wenn ich alles neu installiere version 3.1.3 und neuen token erstelle und auch nur iobroker bei ring angemledet, fuktioniert es einmal, danach nicht mehr. deswegen sie alle versionen über 3.0.1 unbrauchbar und defekt oder sowas.
                                • D denjo
                                  @denjo bei mir hat das Downgrade auch nicht funktioniert. Hab jetzt nochmal die neu angebotene Beta 3.1.7 genommen aber auch da ändert sich nichts.
                                  Hast du besondere Einstellungen on der App? Hab gehört man muss irgendwas einstellen, damit der Adapter funktioniert
                                  Hast du Video oder Snapshot in einer VIS eingebunden? Falls ja, wie hast du das gemacht?
                                    denjo
                                    @jayba man muss die version 3.0.1 haben und am besten vorher auf ring.com alle Geräte einmal löschen. Und nein live Video geht in der vis nicht mit ring. Foto würde gehen ja
                                    • lobomauL lobomau
                                      @lobomau und was machst du dann draus? der einzig halbwegs aktuelle DP ist die History URL aber da steckt ja ne sich ständig verändernde Amazon Adresse dahinter. Wie kann ich das dann weiter bearbeiten?
                                        lobomauL Offline
                                        lobomauL Offline
                                        lobomau
                                        @jayba wie oben geschrieben müsste "ring.0.doorbell_21374xxx.History.kind". Trigger auf Aktualisierung stellen. Ich benutze zur Zeit noch IFTTT als trigger. Leider geht bei mir nicht mehr der Klingelton auf den Alexa-Geräten mehr seitdem ich es hinbekommen habe den ring-Adapter in betrieb zu nehmen (aber Adapter AUS macht es auch nicht wieder funktionsfähig)
                                        So sieht die history von "ring.0.doorbell_21374xxx.History.kind" bei mir aus:
                                        ```timestamp	value	acknowledged	from
                                        2022-10-31T16:56:58.512Z	motion	true	influxdb.0
                                        2022-10-31T19:04:36.626Z	ding	true	ring.0
                                        2022-10-31T19:06:37.198Z	on_demand	true	ring.0
                                        2022-10-31T19:20:41.071Z	motion	true	ring.0
                                        2022-10-31T19:30:43.734Z	ding	true	ring.0
                                        2022-10-31T19:32:44.143Z	motion	true	ring.0
                                        2022-10-31T19:36:45.103Z	on_demand	true	ring.0
                                        2022-10-31T19:38:45.617Z	ding	true	ring.0
                                        2022-10-31T19:42:46.670Z	on_demand	true	ring.0
                                        2022-10-31T19:44:47.254Z	ding	true	ring.0
                                        • Slave: Pi4
                                        • lobomauL lobomau
                                          denjo
                                          @lobomau welche Version benutzt du von ring
