  4. Update JS-Controller: Scripte weg, Backup funkt. nicht
    5.6k
26 Beiträge 3 Kommentatoren 2.7k Aufrufe 3 Beobachtet
    @derrapf
    mount
    sagt?
    derrapf
    @thomas-braun Boah!
    Der sagt total viel
    pi@rock64:/mnt/nas$ mount
    sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
    proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
    udev on /dev type devtmpfs (rw,nosuid,relatime,size=1960728k,nr_inodes=490182,mode=755)
    devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
    tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=406912k,mode=755)
    /dev/mmcblk0p1 on / type ext4 (rw,noatime,errors=remount-ro,commit=600)
    securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
    tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
    tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
    tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
    cgroup2 on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate)
    cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,name=systemd)
    pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
    bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
    cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
    cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb)
    cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
    cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
    cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)
    cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
    cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
    cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
    cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
    cgroup on /sys/fs/cgroup/rdma type cgroup (rw,nosuid,nodev,noexec,relatime,rdma)
    cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
    hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
    mqueue on /dev/mqueue type mqueue (rw,relatime)
    debugfs on /sys/kernel/debug type debugfs (rw,relatime)
    systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=42,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
    configfs on /sys/kernel/config type configfs (rw,relatime)
    fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
    sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
    /dev/zram2 on /tmp type ext4 (rw,nosuid,relatime,discard)
    /dev/mmcblk0p1 on /var/log.hdd type ext4 (rw,noatime,errors=remount-ro,commit=600)
    /dev/zram1 on /var/log type ext4 (rw,relatime,discard)
    tracefs on /sys/kernel/debug/tracing type tracefs (rw,relatime)
    tmpfs on /run/user/0 type tmpfs (rw,nosuid,nodev,relatime,size=406908k,mode=700)
    tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=406908k,mode=700,uid=1000,gid=1000)
    //192.168.111.180/Medien/server-extern/rock64/backit_up/iobroker on /opt/iobroker/backups type cifs (rw,relatime,vers=2.1,                                          cache=strict,username=backup,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.111.180,file_mode=0777,dir_mode=0777,soft,noun                                          ix,serverino,mapposix,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1)
    pi@rock64:/mnt/nas$
    Ich hab auch mal versucht ein Backup zu machen. Auch hier kommt jetzt ein Fehler:
    Started iobroker ...
    [DEBUG] [mount] - mount activ... umount is started before mount!!
    [DEBUG] [mount] - device is busy... wait 2 Minutes!!
    [DEBUG] [mount] - noserverino option: false
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=backup,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.111.180/Medien/server-extern/rock64/backit_up/iobroker /opt/iobroker/backups"
    [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.111.180/Medien/server-extern/rock64/backit_up/iobroker /opt/iobroker/backups"
    [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.111.180/Medien/server-extern/rock64/backit_up/iobroker /opt/iobroker/backups
    mount error(16): Device or resource busy
    Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
    [ERROR] [mount] - Error: Command failed: sudo mount -t cifs -o username=backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.111.180/Medien/server-extern/rock64/backit_up/iobroker /opt/iobroker/backups
    Jetzt ist es wohl total verschraubt..
    Gruss Ralf
    • D derrapf
      @thomas-braun Boah!
      Der sagt total viel
      pi@rock64:/mnt/nas$
      Gruss Ralf
      @derrapf sagte in Update JS-Controller: Scripte weg, Backup funkt. nicht:
      Das ist noch gemountet.
      Deswegen auch:
      Aber warum jetzt per smb/cifs? Hattest du nicht eben per nfs gemountet?
        Deswegen auch:
        derrapf
        Genau. In der fstab stand "192.168.111.180:/volume1/Medien/server-extern/rock64 /mnt/nas nfs defaults,rw,users,x-systemd.automount,x-systemd.requires=network-online.target 0 0 "
        D.h. der Backitup hat das falsch gemounted? Ich schau mal ob man da was einstellen kann...
        Ah hier
        Soll ich das mal auf NFS umstellen?
        Gruss Ralf
        • D derrapf
          Ah hier
          Gruss Ralf
          derrapf
          @derrapf
          Nee, jetzt kommt
          [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.111.180:/Medien/server-extern/rock64/backit_up/iobroker /opt/iobroker/backups"
          [ERROR] [mount] - [undefined mount.nfs: access denied by server while mounting 192.168.111.180:/Medien/server-extern/rock64/backit_up/iobroker
          [ERROR] [mount] - Error: Command failed: sudo mount 192.168.111.180:/Medien/server-extern/rock64/backit_up/iobroker /opt/iobroker/backups
          • D derrapf
            @derrapf
            Nee, jetzt kommt
            @derrapf
            Auf dem NFS-Server muss der iobroker entsprechende Rechte haben, also als user eingerichtet sein.
              @derrapf
              derrapf
              schrieb am zuletzt editiert von derrapf
              Ok. Ich hab mal den user iobroker auf der Synolgy angelegt.
              Jetzt hat das Backup geklappt:
              [DEBUG] [mount] - mount successfully completed
              [DEBUG] [mount] - done
              [DEBUG] [iobroker] - host.rock64 9429 states saved
              [DEBUG] [iobroker] - host.rock64 16884 objects saved
              [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2022_10_25-17_31_08_backupiobroker.tar.gz
              [DEBUG] [iobroker] - done
              [DEBUG] [javascripts] - Try deleting the old javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
              [DEBUG] [javascripts] - old javascript_tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
              [DEBUG] [javascripts] - Created javascript_tmp directory
              [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
              [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
              [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_10_25-17_31_57_backupiobroker.tar.gz
              [DEBUG] [javascripts] - done
              [DEBUG] [cifs] - used copy path: /Medien/server-extern/rock64/backit_up/iobroker
              [DEBUG] [cifs] - done
              [DEBUG] [clean] - done
              [DEBUG] [historyHTML] - new history html values created
              [DEBUG] [historyHTML] - done
              [DEBUG] [historyJSON] - new history json values created
              [DEBUG] [historyJSON] - done
              [DEBUG] [umount] - mount activ, umount is started ...
              [DEBUG] [umount] - umount successfully completed
              [DEBUG] [umount] - done
              [EXIT] 0
              Jetzt muss ich nur noch versuchen ein Backup mit Scripten zurückzuspielen, denn das jetzige Tar file mit den Scripten ist 1kB gross. Da wird nicht viel drin sein.
              Ich frage mich immer noch warum die Scripte nach dem JS-Controller Update weg waren...
              Ich melde mich und sage ob ich den Restore hinbekommen habe.
              Gruss Ralf
              D Thomas BraunT 2 Antworten Letzte Antwort
              • D derrapf
                [EXIT] 0
                Gruss Ralf
                derrapf
                Nee..
                Restore geht immer noch nicht
                Started restore ...
                [DEBUG] [javascripts] - Start Javascript Restore ...
                [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                [DEBUG] [javascripts] - decompress started ...
                [ERROR] [javascripts] - Error: EPERM: operation not permitted, utime '/opt/iobroker/backups/tmpScripts/'
                [ERROR] [javascripts] - Javascript Restore not completed
                [EXIT] 0
                Gruss Ralf
                • D derrapf
                  [EXIT] 0
                  Gruss Ralf
                  @derrapf
                  Irgendwie geht das hier kreuz und quer...
                  NFS? CIFS? Was soll es denn nun sein?
                    @derrapf
                    derrapf
                    Ja, sag's mir. Keine Ahnung.
                    Ob NFS, CIFS oder rote Beete: Ist mir eigentlich egal: Hauptsache es funktioniert.
                    Im Backitup ist CIFS eingestellt. NFS hab ich auch ausprobiert (siehe oben) aber damit hat es nicht funktioniert. Siehe auch oben. Mit CIFS geht wenigstens der Backup jetzt.
                    NFS war ja nur in der fstab eingestellt ,die ich ja jetzt auf Anweisung auskommentiert habe.
                    So sieht grad die Einstellung im BackitUp Adapter aus:
                    Wenn da was falsch ist stelle ich es gerne um.
                    Fehler beim Restore
                    Started restore ...
                    [EXIT] 0
                    Ich hab nochmal "mount" ausgeführt:
                    Jetzt ist nichts mehr vom Synology gemounted oder?
                    Gruss Ralf
                    • D derrapf
                      Fehler beim Restore
                      Started restore ...
                      [EXIT] 0
                      Gruss Ralf
                      Nein.
                      Spricht die synology nicht smb 3.1.1?
                        Nein.
                        derrapf
                        Ich hab mal nachgesehen. Da war noch SMB2 eingestellt. Ist es so richtig?
                        Was soll ich als Mindest SMB Protokoll einschalten? SMB2 oder SMB1?
                        Gruss Ralf
                        • D derrapf
                          Gruss Ralf
                          @derrapf
                          Ich kenne die synology nicht. Aber smb1 wird unter keinen Umständen mehr empfohlen. Wenn nicht 3 geht, dann maximal2. Und mach das oprtunistic locking aus, wenn es nicht benötigt wird.
                            @derrapf
                            derrapf
                            @thomas-braun Ich habe es jetzt mal so eingestellt:
                            Wenn ich einen Restore mache kommt wieder folgender Fehler:
                            Started restore ...
                            [EXIT] 0
                            Backup geht aber ohne Fehler.
                            Ich hab auf der Syno mal das Protokoll abgegriffen:
                            Protokoll,Uhrzeit,IP-Adresse,Benutzer,Ereignis,Datei/Ordner,Dateigröße,Dateiname,
                            SMB,2022/10/25 21:22:23,192.168.111.176,iobroker,create,Ordner,NA,/Medien/server-extern/rock64/backit_up/iobroker/tmpScripts
                            SMB,2022/10/25 21:22:23,192.168.111.176,iobroker,delete,Ordner,NA,/Medien/server-extern/rock64/backit_up/iobroker/tmpScripts
                            SMB,2022/10/25 21:19:34,192.168.111.176,iobroker,delete,Ordner,NA,/Medien/server-extern/rock64/backit_up/iobroker/tmpScripts
                            SMB,2022/10/25 21:15:31,192.168.111.176,iobroker,delete,Ordner,NA,/Medien/server-extern/rock64/backit_up/iobroker/tmpScripts
                            SMB,2022/10/25 21:11:56,192.168.111.68,ralf,delete,Datei,20.00 KB,"/Daten/hobby/3D-Drucken/Werkzeug, Vorrichtungen/rz3100E918boxo"
                            Viel erkennen tut mal leider nicht.
                            Gruss Ralf
                            • D derrapf
                              Started restore ...
                              [EXIT] 0
                              Gruss Ralf
                              Sollte mit Backitup 2.5.10 nicht mehr vorkommen.
                                derrapf
                                @thomas-braun Super. Danke!
