  3. Einsteigerfragen
  4. Admininterface Docker
    5.6k
41 Beiträge 4 Kommentatoren 3.9k Aufrufe 3 Beobachtet
  • M Marc73
    @glasfaser
    so jetzt habe ich es:
    root@buanet-iobroker1:/opt/iobroker# iobroker logs --watch
    2022-10-19 17:49:29.412 - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
    2022-10-19 17:49:29.419 - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-10-19 17:49:29.420 - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
    2022-10-19 17:49:29.422 - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
    2022-10-19 17:49:29.932 - info: host.buanet-iobroker1 connected to Objects and States
    2022-10-19 17:49:30.002 - info: host.buanet-iobroker1 Node.js version has changed from unknown to 16.18.0
    2022-10-19 17:49:30.104 - info: host.buanet-iobroker1 added notifications configuration of host
    2022-10-19 17:49:30.378 - info: host.buanet-iobroker1 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2022-10-19 17:49:30.415 - info: host.buanet-iobroker1 3 instances found
    2022-10-19 17:49:30.429 - info: host.buanet-iobroker1 starting 3 instances
    2022-10-19 17:49:30.512 - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 892
    2022-10-19 17:49:30.730 - info: host.buanet-iobroker1 Created UUID: aaee033c-655b-48a6-95a5-316efcdd06c9
    2022-10-19 17:49:33.284 - info: admin.0 (892) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
    2022-10-19 17:49:33.406 - info: admin.0 (892) requesting all states
    2022-10-19 17:49:33.408 - info: admin.0 (892) requesting all objects
    2022-10-19 17:49:33.537 - info: admin.0 (892) received all objects
    2022-10-19 17:49:33.584 - info: admin.0 (892) Request actual repository...
    2022-10-19 17:49:33.599 - info: host.buanet-iobroker1 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2022-10-19 17:49:33.648 - info: admin.0 (892) http server listening on port 8081
    2022-10-19 17:49:33.649 - info: admin.0 (892) Use link "http://localhost:8081" to configure.
    2022-10-19 17:49:33.660 - info: admin.0 (892) socket.io server listening on port 8081
    2022-10-19 17:49:33.831 - warn: admin.0 (892) Repository cannot be read: Active repo - stable
    2022-10-19 17:49:33.834 - warn: admin.0 (892) Active repository "stable" cannot be read
    2022-10-19 17:49:34.502 - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 915
    2022-10-19 17:49:38.083 - info: admin.0 (892) Repository received successfully.
    2022-10-19 17:49:38.525 - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 930
    2022-10-19 17:49:38.649 - info: discovery.0 (915) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
    2022-10-19 17:49:40.652 - info: backitup.0 (930) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
    2022-10-19 17:49:40.738 - info: backitup.0 (930) [iobroker] backup was activated at 02:40 every 1 day(s)
    2022-10-19 17:57:39.509 - info: host.buanet-iobroker1 received SIGTERM
    2022-10-19 17:57:39.513 - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
    2022-10-19 17:57:39.514 - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
    2022-10-19 17:57:39.515 - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
    2022-10-19 17:57:39.523 - info: discovery.0 (915) Got terminate signal TERMINATE_YOURSELF
    2022-10-19 17:57:39.523 - info: admin.0 (892) Got terminate signal TERMINATE_YOURSELF
    2022-10-19 17:57:39.530 - info: backitup.0 (930) Got terminate signal TERMINATE_YOURSELF
    2022-10-19 17:57:39.525 - info: discovery.0 (915) terminating
    2022-10-19 17:57:39.529 - info: discovery.0 (915) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-10-19 17:57:39.534 - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
    2022-10-19 17:57:39.532 - info: backitup.0 (930) cleaned everything up...
    2022-10-19 17:57:39.534 - info: backitup.0 (930) terminating
    2022-10-19 17:57:39.536 - info: backitup.0 (930) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-10-19 17:57:39.537 - info: admin.0 (892) terminating http server on port 8081
    2022-10-19 17:57:39.540 - info: admin.0 (892) terminating
    2022-10-19 17:57:39.547 - info: admin.0 (892) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-10-19 17:57:39.573 - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
    2022-10-19 17:57:39.573 - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
    2022-10-19 17:57:40.126 - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-10-19 17:57:40.162 - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-10-19 17:57:40.172 - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-10-19 17:57:40.173 - info: host.buanet-iobroker1 All instances are stopped.
    2022-10-19 17:57:40.407 - info: host.buanet-iobroker1 terminated
    2022-10-19 18:02:18.785 - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
    2022-10-19 18:02:18.793 - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-10-19 18:02:18.794 - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
    2022-10-19 18:02:18.795 - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
    2022-10-19 18:02:19.479 - info: host.buanet-iobroker1 connected to Objects and States
    2022-10-19 18:02:19.579 - info: host.buanet-iobroker1 added notifications configuration of host
    2022-10-19 18:02:20.088 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
    2022-10-19 18:02:20.096 - info: host.buanet-iobroker1 3 instances found
    2022-10-19 18:02:20.110 - info: host.buanet-iobroker1 starting 3 instances
    2022-10-19 18:02:20.163 - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 423
    2022-10-19 18:02:20.184 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
    2022-10-19 18:02:20.198 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
    2022-10-19 18:02:20.210 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
    2022-10-19 18:02:20.222 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
    2022-10-19 18:02:20.236 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
    2022-10-19 18:02:20.249 - info: host.buanet-iobroker1 Some obsolete host states deleted.
    2022-10-19 18:02:22.494 - info: admin.0 (423) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
    2022-10-19 18:02:22.553 - info: admin.0 (423) requesting all states
    2022-10-19 18:02:22.555 - info: admin.0 (423) requesting all objects
    2022-10-19 18:02:22.995 - info: admin.0 (423) received all objects
    2022-10-19 18:02:23.160 - info: admin.0 (423) Request actual repository...
    2022-10-19 18:02:23.305 - info: admin.0 (423) http server listening on port 8081
    2022-10-19 18:02:23.305 - info: admin.0 (423) Use link "http://localhost:8081" to configure.
    2022-10-19 18:02:23.328 - info: admin.0 (423) socket.io server listening on port 8081
    2022-10-19 18:02:23.371 - info: host.buanet-iobroker1 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2022-10-19 18:02:24.183 - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 450
    2022-10-19 18:02:25.857 - info: admin.0 (423) Repository received successfully.
    2022-10-19 18:02:30.146 - info: backitup.0 (465) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
    2022-10-19 18:02:30.220 - info: backitup.0 (465) [iobroker] backup was activated at 02:40 every 1 day(s)
    2022-10-19 18:03:05.539 - info: host.buanet-iobroker1 received SIGTERM
    2022-10-19 18:03:05.543 - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
    2022-10-19 18:03:05.545 - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
    2022-10-19 18:03:05.548 - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
    2022-10-19 18:03:05.567 - info: admin.0 (423) Got terminate signal TERMINATE_YOURSELF
    2022-10-19 18:03:05.568 - info: discovery.0 (450) Got terminate signal TERMINATE_YOURSELF
    2022-10-19 18:03:05.571 - info: discovery.0 (450) terminating
    2022-10-19 18:03:05.573 - info: discovery.0 (450) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-10-19 18:03:05.579 - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
    2022-10-19 18:03:05.578 - info: backitup.0 (465) Got terminate signal TERMINATE_YOURSELF
    2022-10-19 18:03:05.574 - info: admin.0 (423) terminating http server on port 8081
    2022-10-19 18:03:05.583 - info: admin.0 (423) terminating
    2022-10-19 18:03:05.585 - info: admin.0 (423) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-10-19 18:03:05.584 - info: backitup.0 (465) cleaned everything up...
    2022-10-19 18:03:05.588 - info: backitup.0 (465) terminating
    2022-10-19 18:03:05.597 - info: backitup.0 (465) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-10-19 18:03:05.619 - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
    2022-10-19 18:03:05.620 - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
    2022-10-19 18:03:06.190 - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-10-19 18:03:06.204 - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-10-19 18:03:06.237 - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-10-19 18:03:06.238 - info: host.buanet-iobroker1 All instances are stopped.
    2022-10-19 18:03:06.490 - info: host.buanet-iobroker1 terminated
    2022-10-19 18:05:44.520 - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
    2022-10-19 18:05:44.529 - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-10-19 18:05:44.530 - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
    2022-10-19 18:05:44.531 - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
    2022-10-19 18:05:45.283 - info: host.buanet-iobroker1 connected to Objects and States
    2022-10-19 18:05:45.314 - info: host.buanet-iobroker1 added notifications configuration of host
    2022-10-19 18:05:45.704 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
    2022-10-19 18:05:45.712 - info: host.buanet-iobroker1 3 instances found
    2022-10-19 18:05:45.726 - info: host.buanet-iobroker1 starting 3 instances
    2022-10-19 18:05:45.779 - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 424
    2022-10-19 18:05:45.799 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
    2022-10-19 18:05:45.813 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
    2022-10-19 18:05:45.827 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
    2022-10-19 18:05:45.839 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
    2022-10-19 18:05:45.852 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
    2022-10-19 18:05:45.866 - info: host.buanet-iobroker1 Some obsolete host states deleted.
    2022-10-19 18:05:48.102 - info: admin.0 (424) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
    2022-10-19 18:05:48.186 - info: admin.0 (424) requesting all states
    2022-10-19 18:05:48.187 - info: admin.0 (424) requesting all objects
    2022-10-19 18:05:48.624 - info: admin.0 (424) received all objects
    2022-10-19 18:05:48.766 - info: admin.0 (424) Request actual repository...
    2022-10-19 18:05:48.806 - info: admin.0 (424) http server listening on port 8081
    2022-10-19 18:05:48.809 - info: admin.0 (424) Use link "http://localhost:8081" to configure.
    2022-10-19 18:05:48.849 - info: admin.0 (424) socket.io server listening on port 8081
    2022-10-19 18:05:49.047 - info: host.buanet-iobroker1 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2022-10-19 18:05:49.891 - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 451
    2022-10-19 18:05:51.277 - info: admin.0 (424) Repository received successfully.
    2022-10-19 18:05:52.117 - info: discovery.0 (451) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
    2022-10-19 18:05:53.769 - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 466
    2022-10-19 18:05:55.931 - info: backitup.0 (466) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
    2022-10-19 18:05:56.012 - info: backitup.0 (466) [iobroker] backup was activated at 02:40 every 1 day(s)
    2022-10-19 18:20:47.231 - info: host.buanet-iobroker1 received SIGTERM
    2022-10-19 18:20:47.235 - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
    2022-10-19 18:20:47.239 - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
    2022-10-19 18:20:47.239 - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
    2022-10-19 18:20:47.260 - info: discovery.0 (451) Got terminate signal TERMINATE_YOURSELF
    2022-10-19 18:20:47.251 - info: admin.0 (424) Got terminate signal TERMINATE_YOURSELF
    2022-10-19 18:20:47.269 - info: backitup.0 (466) Got terminate signal TERMINATE_YOURSELF
    2022-10-19 18:20:47.263 - info: discovery.0 (451) terminating
    2022-10-19 18:20:47.265 - info: discovery.0 (451) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-10-19 18:20:47.277 - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
    2022-10-19 18:20:47.271 - info: backitup.0 (466) cleaned everything up...
    2022-10-19 18:20:47.273 - info: backitup.0 (466) terminating
    2022-10-19 18:20:47.275 - info: backitup.0 (466) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-10-19 18:20:47.277 - info: admin.0 (424) terminating http server on port 8081
    2022-10-19 18:20:47.279 - info: admin.0 (424) terminating
    2022-10-19 18:20:47.281 - info: admin.0 (424) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-10-19 18:20:47.317 - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
    2022-10-19 18:20:47.318 - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
    2022-10-19 18:20:47.898 - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-10-19 18:20:47.939 - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-10-19 18:20:47.941 - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-10-19 18:20:47.941 - info: host.buanet-iobroker1 All instances are stopped.
    2022-10-19 18:20:48.071 - info: host.buanet-iobroker1 terminated
    2022-10-19 18:21:21.726 - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
    2022-10-19 18:21:21.733 - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-10-19 18:21:21.734 - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
    2022-10-19 18:21:21.735 - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
    2022-10-19 18:21:22.466 - info: host.buanet-iobroker1 connected to Objects and States
    2022-10-19 18:21:22.493 - info: host.buanet-iobroker1 added notifications configuration of host
    2022-10-19 18:21:22.879 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
    2022-10-19 18:21:22.888 - info: host.buanet-iobroker1 3 instances found
    2022-10-19 18:21:22.905 - info: host.buanet-iobroker1 starting 3 instances
    2022-10-19 18:21:22.960 - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 411
    2022-10-19 18:21:23.001 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
    2022-10-19 18:21:23.018 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
    2022-10-19 18:21:23.044 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
    2022-10-19 18:21:23.074 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
    2022-10-19 18:21:23.087 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
    2022-10-19 18:21:23.101 - info: host.buanet-iobroker1 Some obsolete host states deleted.
    2022-10-19 18:21:25.330 - info: admin.0 (411) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
    2022-10-19 18:21:25.394 - info: admin.0 (411) requesting all states
    2022-10-19 18:21:25.396 - info: admin.0 (411) requesting all objects
    2022-10-19 18:21:25.954 - info: admin.0 (411) received all objects
    2022-10-19 18:21:26.139 - info: admin.0 (411) Request actual repository...
    2022-10-19 18:21:26.200 - info: admin.0 (411) http server listening on port 8081
    2022-10-19 18:21:26.201 - info: admin.0 (411) Use link "http://localhost:8081" to configure.
    2022-10-19 18:21:26.228 - info: admin.0 (411) socket.io server listening on port 8081
    2022-10-19 18:21:26.472 - info: host.buanet-iobroker1 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2022-10-19 18:21:26.983 - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 446
    2022-10-19 18:21:29.010 - info: admin.0 (411) Repository received successfully.
    2022-10-19 18:21:29.323 - info: discovery.0 (446) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
    2022-10-19 18:21:30.942 - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 465
    2022-10-19 18:21:33.135 - info: backitup.0 (465) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
    2022-10-19 18:21:33.204 - info: backitup.0 (465) [iobroker] backup was activated at 02:40 every 1 day(s)
    GlasfaserG Offline
    GlasfaserG Offline
    @marc73
    Sehe keinen Fehler .... warum er in Schleife mit dem Logo hängt.
    Erstelle zum Test einen neuen Container , aber im Host (nicht bridgemodus)
    • M Marc73
      @glasfaser
      was mir hier aufgefallen ist:
      was ist das das ist nicht meine externe Adresse und auch keine aus meinem Netz..
      grüße Und danke
      Marco
      GlasfaserG Offline
      GlasfaserG Offline
      @marc73 sagte in Admininterface Docker:
      172.17.0.3
      die kommt vom bridgemodus
      • GlasfaserG Glasfaser
        @marc73
        Marc73
        @glasfaser
        habe ich gemacht neuer Container macht genau das gleiche.
        Ich muss jetzt erstmal Feierabend machen werden da noch weiter suchen.
        Ich habe auch andere Geräte probiert und auch schon eine ältere Version überall das gleiche.
        Danke erstmal ich bleibe drann.
        Grüße Marco
        • M Marc73
          @glasfaser
          Grüße Marco
          GlasfaserG Offline
          GlasfaserG Offline
          Entwickler-Konsole im Browser mit F12 aufrufen und in der Konsole schauen / posten was dort an Inhalt / Fehler / oder Warn enthalten ist .
            @marc73
            Das sind echt wenig Informationen .
            So kann man nur raten ...
            Anderen Browser mal versucht ?
            Popup Blocker aktiv
            Firewall aktiv
            Was steht im Log.
            GlasfaserG Offline
            GlasfaserG Offline
            @marc73
            @glasfaser sagte in Admininterface Docker:
            Popup Blocker aktiv
            Firewall aktiv
            Was war hiermit !?
              Marc73
              @glasfaser
              @glasfaser
              Moin Popup Blocker oder Firewall sind nicht dran schuld.
              Auf dem Synology läuft noch Grafana, influxDB und mein Controller für Unify alle ohne Probleme.
              Jetzt habe ich den Firefox mit Konsole (F12 --> Konsole) aufgemacht und da sind folgende Meldungen:
              [2022-10-21T08:54:28.284Z] No READY flag received in 3 seconds. Re-init instrument.ts:123:32
              [2022-10-21T08:54:28.284Z] Start reconnect 5 instrument.ts:123:32
              Firefox kann keine Verbindung zu dem Server unter ws://192.168.254.200:8081/?sid=1666342465275&name=admin aufbauen. socket.io.js:140:21
              Die Verbindung zu ws://192.168.254.200:8081/?sid=1666342465275&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
              [2022-10-21T08:54:28.287Z] Reconnect is already running 5 instrument.ts:123:32
              Beim genauen hin schauen wird dieses hier abgebrochen mit einer Ladezeit von 186 Sec:
              https://sentry.iobroker.net/api/58/envelope/?sentry_key=43643152dab3481db69950ba866ee9d6&sentry_version=7&sentry_client=sentry.javascript.browser%2F7.12.1
              Eine eine Idee wo es da klemmen kann??
              Grüße Marco
              • M Marc73
                @glasfaser
                @glasfaser
                Grüße Marco
                GlasfaserG Offline
                GlasfaserG Offline
                @marc73
                ich habe was gefunden :
                Er kann nichts von der URL lesen / erreichen .
                zeige mal
                iobroker repo list
                und in der Dockerkonsole ... geht ein
                wget http://download.iobroker.net/sources-dist.json
                wird dann etwas runtergeladen !?
                EDIT :
                Und eine große Bitte ...
                pack die Ausgabe in Code-Tags >/< wie schon oben angegeben , so kann man es besser lesen und übersieht es nicht wenn doch Fehler vorhanden sind !!
                  @marc73
                  zeige mal
                  iobroker repo list
                  EDIT :
                  Marc73
                  @glasfaser
                  root@buanet-iobroker1:/opt/iobroker# iobroker repo list
                  Active repo(s): stable
                  root@buanet-iobroker1:/opt/iobroker# wget http://download.iobroker.net/sources-dist.json
                  --2022-10-22 08:31:18--  http://download.iobroker.net/sources-dist.json
                  Resolving download.iobroker.net (download.iobroker.net)... 79.143.182.215, 2a02:c205:0:855::1
                  Connecting to download.iobroker.net (download.iobroker.net)|79.143.182.215|:80... connected.
                  HTTP request sent, awaiting response... 301 Moved Permanently
                  Location: http://repo.iobroker.live/sources-dist.json [following]
                  --2022-10-22 08:31:18--  http://repo.iobroker.live/sources-dist.json
                  Resolving repo.iobroker.live (repo.iobroker.live)... 172.67.180.22, 104.21.88.137, 2606:4700:3031::6815:5889, ...
                  Connecting to repo.iobroker.live (repo.iobroker.live)|172.67.180.22|:80... connected.
                  HTTP request sent, awaiting response... 200 OK
                  Length: 2876934 (2,7M) [application/json]
                  Saving to: ‘sources-dist.json.1’
                  sources-dist.json.1                                100%[================================================================================================================>]   2,74M  2,37MB/s    in 1,2s
                  2022-10-22 08:31:20 (2,37 MB/s) - ‘sources-dist.json.1’ saved [2876934/2876934]
                  moin ja läd was runter.
                  Grüße marco
                  • M Marc73
                    @glasfaser
                    Grüße marco
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @marc73
                    Füge eine weitere Repo URL dazu :
                    iobroker repo add live-stable http://iobroker.live/repo/sources-dist.json
                    iobroker repo unset stable
                    iobroker repo set live-stable
                    iobroker update
                    Danach mal den Container neu starten
                      @marc73
                      iobroker update
                      Marc73
                      @glasfaser
                      2022-10-22 13:08:23.653  - info: admin.0 (425) received all objects
                      2022-10-22 13:08:23.675  - warn: admin.0 (425) Repository cannot be read: Active repo - live-stable
                      2022-10-22 13:08:23.676  - warn: admin.0 (425) Active repository "live-stable" cannot be read
                      2022-10-22 13:08:23.880  - info: admin.0 (425) http server listening on port 8081
                      2022-10-22 13:08:23.881  - info: admin.0 (425) Use link "http://localhost:8081" to configure.
                      2022-10-22 13:08:23.891  - info: admin.0 (425) socket.io server listening on port 8081
                      2022-10-22 13:08:24.655  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 452
                      2022-10-22 13:08:26.670  - info: discovery.0 (452) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
                      2022-10-22 13:08:28.639  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 467
                      2022-10-22 13:08:30.631  - info: backitup.0 (467) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
                      2022-10-22 13:08:30.705  - info: backitup.0 (467) [iobroker] backup was activated at 02:40 every 1 day(s)
                      habe ich gemacht leider siehe
                      Zeile 3:
                      Admin ist nicht zu laden :-(
                      • M Marc73
                        @glasfaser
                        Zeile 3:
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @marc73
                        dann ... nur zum TEST auf Beta
                        iobroker repo unset live-stable
                        iobroker repo set beta
                        • M Marc73
                          @glasfaser
                          Zeile 3:
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Also der ioBroker Logo Ladekreis ... im Browser !?
                          • M Marc73
                            Hallo Ich bin etwas verzweifelt.
                            Ich habe den iobroker auf einem Ubuntuserver ohne Probleme zum Laufen bekommen. Da ich ein Synology besitze habe ich gedacht ich machen das mal im Docker.
                            Installation hat gut geklappt mit buanet-iobroker webseite startet auch.
                            es kommt aber kein login.
                            Was habe ich falsch gemacht???
                            Grüße Marco
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Da ich ein Synology
                            im Docker.
                            Es ist schon merkwürdig, das es per wget im Container funktioniert ,
                            aber ....
                            schau mal in der Firewall in der Syn eventuell Blockt da etwas !?
                              Da ich ein Synology
                              im Docker.
                              aber ....
                              Marc73
                              @glasfaser @glasfaser
                              so ich habe jetzt nocheinmal die Firewall in er SYN aus gemacht und im Router hatte ich noch ein Portforwarding auf port 8081 auf einen Controller.
                              Auf meinem Ubunutserver läuft das es allerdings alles.
                              hier jetzt noch einmal das Protokoll dauert immer etwas muss ich leider zusammensetzen man kann nicht alles aus dem Terminal kopieren.
                              2022-10-22 08:34:40.902  - info: host.buanet-iobroker1 received SIGTERM
                              2022-10-22 08:34:40.924  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
                              2022-10-22 08:34:40.926  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
                              2022-10-22 08:34:40.926  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                              2022-10-22 08:34:40.966  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
                              2022-10-22 08:34:41.006  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
                              2022-10-22 08:34:41.006  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
                              2022-10-22 08:34:40.940  - info: admin.0 (411) Got terminate signal TERMINATE_YOURSELF
                              2022-10-22 08:34:41.009  - info: admin.0 (411) terminating http server on port 8081
                              2022-10-22 08:34:41.017  - info: admin.0 (411) terminating
                              2022-10-22 08:34:41.019  - info: admin.0 (411) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2022-10-22 08:34:40.957  - info: backitup.0 (465) Got terminate signal TERMINATE_YOURSELF
                              2022-10-22 08:34:41.028  - info: backitup.0 (465) cleaned everything up...
                              2022-10-22 08:34:41.031  - info: backitup.0 (465) terminating
                              2022-10-22 08:34:41.044  - info: backitup.0 (465) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2022-10-22 08:34:40.951  - info: discovery.0 (446) Got terminate signal TERMINATE_YOURSELF
                              2022-10-22 08:34:41.037  - info: discovery.0 (446) terminating
                              2022-10-22 08:34:41.044  - info: discovery.0 (446) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2022-10-22 08:34:41.638  - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2022-10-22 08:34:41.668  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2022-10-22 08:34:41.682  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2022-10-22 08:34:41.683  - info: host.buanet-iobroker1 All instances are stopped.
                              2022-10-22 08:34:41.761  - info: host.buanet-iobroker1 terminated
                              2022-10-22 08:35:21.399  - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
                              2022-10-22 08:35:21.406  - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                              2022-10-22 08:35:21.407  - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
                              2022-10-22 08:35:21.408  - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
                              2022-10-22 08:35:22.436  - info: host.buanet-iobroker1 connected to Objects and States
                              2022-10-22 08:35:22.471  - info: host.buanet-iobroker1 added notifications configuration of host
                              2022-10-22 08:35:22.901  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
                              2022-10-22 08:35:22.909  - info: host.buanet-iobroker1 3 instances found
                              2022-10-22 08:35:22.923  - info: host.buanet-iobroker1 starting 3 instances
                              2022-10-22 08:35:23.027  - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 421
                              2022-10-22 08:35:23.046  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
                              2022-10-22 08:35:23.107  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
                              2022-10-22 08:35:23.123  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
                              2022-10-22 08:35:23.155  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
                              2022-10-22 08:35:23.188  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
                              2022-10-22 08:35:23.201  - info: host.buanet-iobroker1 Some obsolete host states deleted.
                              2022-10-22 08:35:26.039  - info: admin.0 (421) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
                              2022-10-22 08:35:26.096  - info: admin.0 (421) requesting all states
                              2022-10-22 08:35:26.097  - info: admin.0 (421) requesting all objects
                              2022-10-22 08:35:26.648  - info: admin.0 (421) received all objects
                              2022-10-22 08:35:26.814  - info: admin.0 (421) Request actual repository...
                              2022-10-22 08:35:26.929  - info: admin.0 (421) http server listening on port 8081
                              2022-10-22 08:35:26.933  - info: admin.0 (421) Use link "http://localhost:8081" to configure.
                              2022-10-22 08:35:26.968  - info: admin.0 (421) socket.io server listening on port 8081
                              2022-10-22 08:35:27.249  - info: host.buanet-iobroker1 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                              2022-10-22 08:35:27.435  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 444
                              2022-10-22 08:35:31.110  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 459
                              2022-10-22 08:35:31.476  - info: admin.0 (421) Repository received successfully.
                              2022-10-22 08:35:32.085  - info: discovery.0 (444) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
                              2022-10-22 08:35:33.912  - info: backitup.0 (459) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
                              2022-10-22 08:35:33.984  - info: backitup.0 (459) [iobroker] backup was activated at 02:40 every 1 day(s)
                              2022-10-22 13:07:43.210  - info: host.buanet-iobroker1 received SIGTERM
                              2022-10-22 13:07:43.216  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
                              2022-10-22 13:07:43.217  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
                              2022-10-22 13:07:43.217  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                              2022-10-22 13:07:43.230  - info: admin.0 (421) Got terminate signal TERMINATE_YOURSELF
                              2022-10-22 13:07:43.238  - info: admin.0 (421) terminating http server on port 8081
                              2022-10-22 13:07:43.241  - info: admin.0 (421) terminating
                              2022-10-22 13:07:43.243  - info: admin.0 (421) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2022-10-22 13:07:43.239  - info: discovery.0 (444) Got terminate signal TERMINATE_YOURSELF
                              2022-10-22 13:07:43.247  - info: backitup.0 (459) Got terminate signal TERMINATE_YOURSELF
                              2022-10-22 13:07:43.249  - info: discovery.0 (444) terminating
                              2022-10-22 13:07:43.251  - info: discovery.0 (444) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2022-10-22 13:07:43.256  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
                              2022-10-22 13:07:43.257  - info: backitup.0 (459) cleaned everything up...
                              2022-10-22 13:07:43.259  - info: backitup.0 (459) terminating
                              2022-10-22 13:07:43.261  - info: backitup.0 (459) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2022-10-22 13:07:43.294  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
                              2022-10-22 13:07:43.295  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
                              2022-10-22 13:07:43.873  - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2022-10-22 13:07:43.884  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2022-10-22 13:07:43.924  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2022-10-22 13:07:43.925  - info: host.buanet-iobroker1 All instances are stopped.
                              2022-10-22 13:07:44.064  - info: host.buanet-iobroker1 terminated
                              2022-10-22 13:08:18.617  - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
                              2022-10-22 13:08:18.625  - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                              2022-10-22 13:08:18.626  - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
                              2022-10-22 13:08:18.627  - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
                              2022-10-22 13:08:20.102  - info: host.buanet-iobroker1 connected to Objects and States
                              2022-10-22 13:08:20.130  - info: host.buanet-iobroker1 added notifications configuration of host
                              2022-10-22 13:08:20.580  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
                              2022-10-22 13:08:20.589  - info: host.buanet-iobroker1 3 instances found
                              2022-10-22 13:08:20.603  - info: host.buanet-iobroker1 starting 3 instances
                              2022-10-22 13:08:20.670  - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 425
                              2022-10-22 13:08:20.715  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
                              2022-10-22 13:08:20.802  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
                              2022-10-22 13:08:20.838  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
                              2022-10-22 13:08:20.868  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
                              2022-10-22 13:08:20.903  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
                              2022-10-22 13:08:20.929  - info: host.buanet-iobroker1 Some obsolete host states deleted.
                              2022-10-22 13:08:23.129  - info: admin.0 (425) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
                              2022-10-22 13:08:23.206  - info: admin.0 (425) requesting all states
                              2022-10-22 13:08:23.208  - info: admin.0 (425) requesting all objects
                              2022-10-22 13:23:36.922  - info: host.buanet-iobroker1 received SIGTERM
                              2022-10-22 13:23:36.927  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
                              2022-10-22 13:23:36.929  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
                              2022-10-22 13:23:36.929  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                              2022-10-22 13:23:36.941  - info: discovery.0 (452) Got terminate signal TERMINATE_YOURSELF
                              2022-10-22 13:23:36.940  - info: admin.0 (425) Got terminate signal TERMINATE_YOURSELF
                              2022-10-22 13:23:36.948  - info: backitup.0 (467) Got terminate signal TERMINATE_YOURSELF
                              2022-10-22 13:23:36.948  - info: admin.0 (425) terminating http server on port 8081
                              2022-10-22 13:23:36.950  - info: admin.0 (425) terminating
                              2022-10-22 13:23:36.952  - info: admin.0 (425) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2022-10-22 13:23:36.944  - info: discovery.0 (452) terminating
                              2022-10-22 13:23:36.946  - info: discovery.0 (452) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2022-10-22 13:23:36.951  - info: backitup.0 (467) cleaned everything up...
                              2022-10-22 13:23:36.952  - info: backitup.0 (467) terminating
                              2022-10-22 13:23:36.954  - info: backitup.0 (467) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2022-10-22 13:23:36.959  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
                              2022-10-22 13:23:36.999  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
                              2022-10-22 13:23:37.000  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
                              2022-10-22 13:23:37.576  - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2022-10-22 13:23:37.607  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2022-10-22 13:23:37.608  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2022-10-22 13:23:37.608  - info: host.buanet-iobroker1 All instances are stopped.
                              2022-10-22 13:23:37.929  - info: host.buanet-iobroker1 terminated
                              2022-10-22 13:24:13.013  - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
                              2022-10-22 13:24:13.020  - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                              2022-10-22 13:24:13.022  - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
                              2022-10-22 13:24:13.023  - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
                              2022-10-22 13:24:14.441  - info: host.buanet-iobroker1 connected to Objects and States
                              2022-10-22 13:24:14.475  - info: host.buanet-iobroker1 added notifications configuration of host
                              2022-10-22 13:24:14.914  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
                              2022-10-22 13:24:14.923  - info: host.buanet-iobroker1 3 instances found
                              2022-10-22 13:24:14.937  - info: host.buanet-iobroker1 starting 3 instances
                              2022-10-22 13:24:14.999  - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 426
                              2022-10-22 13:24:15.026  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
                              2022-10-22 13:24:15.083  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
                              2022-10-22 13:24:15.096  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
                              2022-10-22 13:24:15.109  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
                              2022-10-22 13:24:15.123  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
                              2022-10-22 13:24:15.154  - info: host.buanet-iobroker1 Some obsolete host states deleted.
                              2022-10-22 13:24:17.368  - info: admin.0 (426) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
                              2022-10-22 13:24:17.459  - info: admin.0 (426) requesting all states
                              2022-10-22 13:24:17.461  - info: admin.0 (426) requesting all objects
                              2022-10-22 13:24:18.173  - info: admin.0 (426) received all objects
                              2022-10-22 13:24:18.197  - warn: admin.0 (426) No repository source configured
                              2022-10-22 13:24:18.649  - info: admin.0 (426) Request actual repository...
                              2022-10-22 13:24:18.686  - info: admin.0 (426) http server listening on port 8081
                              2022-10-22 13:24:18.688  - info: admin.0 (426) Use link "http://localhost:8081" to configure.
                              2022-10-22 13:24:18.712  - info: admin.0 (426) socket.io server listening on port 8081
                              2022-10-22 13:24:19.201  - info: host.buanet-iobroker1 Updating repository "live-stable" under "http://iobroker.live/repo/sources-dist.json"
                              2022-10-22 13:24:19.331  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 453
                              2022-10-22 13:24:20.196  - info: host.buanet-iobroker1 Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
                              2022-10-22 13:24:27.708  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 464
                              2022-10-22 13:24:27.963  - info: admin.0 (426) Repository received successfully.
                              2022-10-22 13:24:28.336  - info: discovery.0 (453) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
                              2022-10-22 13:24:30.424  - info: backitup.0 (464) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
                              2022-10-22 13:24:30.514  - info: backitup.0 (464) [iobroker] backup was activated at 02:40 every 1 day(s)
                              2022-10-22 13:28:42.223  - info: host.buanet-iobroker1 received SIGTERM
                              2022-10-22 13:28:42.227  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
                              2022-10-22 13:28:42.228  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
                              2022-10-22 13:28:42.228  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                              2022-10-22 13:28:42.235  - info: admin.0 (426) Got terminate signal TERMINATE_YOURSELF
                              2022-10-22 13:28:42.245  - info: discovery.0 (453) Got terminate signal TERMINATE_YOURSELF
                              2022-10-22 13:28:42.246  - info: backitup.0 (464) Got terminate signal TERMINATE_YOURSELF
                              2022-10-22 13:28:42.248  - info: discovery.0 (453) terminating
                              2022-10-22 13:28:42.250  - info: discovery.0 (453) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2022-10-22 13:28:42.238  - info: admin.0 (426) terminating http server on port 8081
                              2022-10-22 13:28:42.240  - info: admin.0 (426) terminating
                              2022-10-22 13:28:42.253  - info: admin.0 (426) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2022-10-22 13:28:42.248  - info: backitup.0 (464) cleaned everything up...
                              2022-10-22 13:28:42.250  - info: backitup.0 (464) terminating
                              2022-10-22 13:28:42.255  - info: backitup.0 (464) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2022-10-22 13:28:42.260  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
                              2022-10-22 13:28:42.299  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
                              2022-10-22 13:28:42.300  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
                              2022-10-22 13:28:42.875  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2022-10-22 13:28:42.915  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2022-10-22 13:28:42.920  - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2022-10-22 13:28:42.921  - info: host.buanet-iobroker1 All instances are stopped.
                              2022-10-22 13:28:43.071  - info: host.buanet-iobroker1 terminated
                              2022-10-22 13:29:17.425  - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
                              2022-10-22 13:29:17.432  - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                              2022-10-22 13:29:17.433  - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
                              2022-10-22 13:29:17.434  - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
                              2022-10-22 13:29:19.096  - info: host.buanet-iobroker1 connected to Objects and States
                              2022-10-22 13:29:19.128  - info: host.buanet-iobroker1 added notifications configuration of host
                              2022-10-22 13:29:19.516  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
                              2022-10-22 13:29:19.524  - info: host.buanet-iobroker1 3 instances found
                              2022-10-22 13:29:19.537  - info: host.buanet-iobroker1 starting 3 instances
                              2022-10-22 13:29:19.604  - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 425
                              2022-10-22 13:29:19.630  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
                              2022-10-22 13:29:19.739  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
                              2022-10-22 13:29:19.752  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
                              2022-10-22 13:29:19.769  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
                              2022-10-22 13:29:19.829  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
                              2022-10-22 13:29:19.842  - info: host.buanet-iobroker1 Some obsolete host states deleted.
                              2022-10-22 13:29:21.954  - info: admin.0 (425) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
                              2022-10-22 13:29:22.059  - info: admin.0 (425) requesting all states
                              2022-10-22 13:29:22.060  - info: admin.0 (425) requesting all objects
                              2022-10-22 13:29:23.568  - info: admin.0 (425) received all objects
                              2022-10-22 13:29:23.634  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 448
                              2022-10-22 13:29:24.016  - info: admin.0 (425) Request actual repository...
                              2022-10-22 13:29:24.058  - info: admin.0 (425) http server listening on port 8081
                              2022-10-22 13:29:24.061  - info: admin.0 (425) Use link "http://localhost:8081" to configure.
                              2022-10-22 13:29:24.085  - info: admin.0 (425) socket.io server listening on port 8081
                              2022-10-22 13:29:24.850  - info: host.buanet-iobroker1 Updating repository "live-stable" under "http://iobroker.live/repo/sources-dist.json"
                              2022-10-22 13:29:25.885  - info: host.buanet-iobroker1 Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
                              2022-10-22 13:29:26.136  - info: discovery.0 (448) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
                              2022-10-22 13:29:27.813  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 467
                              2022-10-22 13:29:28.189  - info: admin.0 (425) Repository received successfully.
                              2022-10-22 13:29:29.895  - info: backitup.0 (467) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
                              2022-10-22 13:29:29.984  - info: backitup.0 (467) [iobroker] backup was activated at 02:40 every 1 day(s)
                              2022-10-22 13:35:35.192  - info: host.buanet-iobroker1 received SIGTERM
                              2022-10-22 13:35:35.198  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
                              2022-10-22 13:35:35.198  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
                              2022-10-22 13:35:35.201  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                              2022-10-22 13:35:35.211  - info: backitup.0 (467) Got terminate signal TERMINATE_YOURSELF
                              2022-10-22 13:35:35.209  - info: admin.0 (425) Got terminate signal TERMINATE_YOURSELF
                              2022-10-22 13:35:35.211  - info: discovery.0 (448) Got terminate signal TERMINATE_YOURSELF
                              2022-10-22 13:35:35.212  - info: backitup.0 (467) cleaned everything up...
                              2022-10-22 13:35:35.214  - info: backitup.0 (467) terminating
                              2022-10-22 13:35:35.216  - info: backitup.0 (467) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2022-10-22 13:35:35.221  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
                              2022-10-22 13:35:35.217  - info: discovery.0 (448) terminating
                              2022-10-22 13:35:35.221  - info: discovery.0 (448) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2022-10-22 13:35:35.214  - info: admin.0 (425) terminating http server on port 8081
                              2022-10-22 13:35:35.220  - info: admin.0 (425) terminating
                              2022-10-22 13:35:35.224  - info: admin.0 (425) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2022-10-22 13:35:35.258  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
                              2022-10-22 13:35:35.259  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
                              2022-10-22 13:35:35.829  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2022-10-22 13:35:35.855  - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2022-10-22 13:35:35.887  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2022-10-22 13:35:35.888  - info: host.buanet-iobroker1 All instances are stopped.
                              2022-10-22 13:35:36.149  - info: host.buanet-iobroker1 terminated
                              2022-10-22 13:36:13.277  - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
                              2022-10-22 13:36:13.285  - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                              2022-10-22 13:36:13.288  - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
                              2022-10-22 13:36:15.271  - info: host.buanet-iobroker1 connected to Objects and States
                              2022-10-22 13:36:15.303  - info: host.buanet-iobroker1 added notifications configuration of host
                              2022-10-22 13:36:15.689  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
                              2022-10-22 13:36:15.697  - info: host.buanet-iobroker1 3 instances found
                              2022-10-22 13:36:15.710  - info: host.buanet-iobroker1 starting 3 instances
                              2022-10-22 13:36:15.779  - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 426
                              2022-10-22 13:36:15.800  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
                              2022-10-22 13:36:15.855  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
                              2022-10-22 13:36:15.868  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
                              2022-10-22 13:36:15.882  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
                              2022-10-22 13:36:15.896  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
                              2022-10-22 13:36:15.910  - info: host.buanet-iobroker1 Some obsolete host states deleted.
                              2022-10-22 13:36:18.138  - info: admin.0 (426) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
                              2022-10-22 13:36:18.201  - info: admin.0 (426) requesting all states
                              2022-10-22 13:36:18.202  - info: admin.0 (426) requesting all objects
                              2022-10-22 13:36:19.653  - info: admin.0 (426) received all objects
                              2022-10-22 13:36:19.881  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 449
                              2022-10-22 13:36:20.384  - info: admin.0 (426) http server listening on port 8081
                              2022-10-22 13:36:20.385  - info: admin.0 (426) Use link "http://localhost:8081" to configure.
                              2022-10-22 13:36:20.396  - info: admin.0 (426) socket.io server listening on port 8081
                              2022-10-22 13:36:21.894  - info: discovery.0 (449) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
                              2022-10-22 13:36:23.752  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 468
                              2022-10-22 13:36:25.918  - info: backitup.0 (468) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
                              2022-10-22 13:36:25.997  - info: backitup.0 (468) [iobroker] backup was activated at 02:40 every 1 day(s)
                              ^C
                              • M Marc73
                                ^C
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Ist OK ...
                                Und immer noch :
                                Gehe mal beim Browser im inkognito Modus , was ist dann
                                  Ist OK ...
                                  Und immer noch :
                                  Marc73
                                  @glasfaser
                                  ja ist leider immer noch passiert nix.
                                  immer noch startlogo und nix passiert
                                  • M Marc73
                                    @glasfaser
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @marc73
                                    Ich habe keine Idee mehr .... :(
                                    bzw. ist es sehr merkwürdig das " nichts " funktioniert und immer der gleiche Fehler ist .
                                    Laut Log hast du bridgemodus , was ist im Host ?
                                    die Syn mal neu gestartet ... glaube aber nicht das es daran liegt
                                    , obwohl es gab mal einen User wo das Docker Paket einen Schuß weg hatte.
                                    Er hat das Docker zusatzpaket gelöscht , neu installiert und den ioBroker Docker neu angelegt , danach lief es
                                      @marc73
                                      @glasfaser hab ich's nur übersehen oder gibt es noch kein Browserlog?
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        https://forum.iobroker.net/post/877149
                                          Marc73
                                          ich hatte ja auch schonmal alles gelöscht.
                                          Ist ja glücklicherweise noch nicht´s drann aber ich verstehe es auch nicht.
                                          Ich werde mal genau das machen alles weg und neu + Neustart vom SYN.
                                          Ich hatte ja auch schonmal eine ältere Version probiert V6.(weiß ich nicht mehr) da war das gleiche Problem.
                                          Alles andere läuft:
                                          Unifi-controller, influxdb, grafana.
                                          Ich werfe mal alles raus und mache mal neu melde mich dann wieder kurzfristig.
                                          Danke euch allen erstmal.
