  4. Raspberry Pi NodeJS update aber NPM hat die flasche Version
    5.7k
16 Beiträge 3 Kommentatoren 4.3k Aufrufe 2 Beobachtet
  • D djsirius
    Jetzt habe ich sehr wahrscheinlich irgendwas zerschossen! 😞
    pi@ioBroker-RasPi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
    /usr/bin/nodejs
    v16.17.1
    /usr/bin/node
    v16.17.1
    /usr/bin/npm
    /usr/lib/node_modules/npm/node_modules/socks-proxy-agent/dist/index.js:110
    class SocksProxyAgent extends agent_base_1.Agent {
    TypeError: Class extends value undefined is not a constructor or null
        at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/socks-proxy-agent/dist/index.js:110:44)
        at Module._compile (node:internal/modules/cjs/loader:1126:14)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
        at Module.load (node:internal/modules/cjs/loader:1004:32)
        at Function.Module._load (node:internal/modules/cjs/loader:839:12)
        at Module.require (node:internal/modules/cjs/loader:1028:19)
        at require (node:internal/modules/cjs/helpers:102:18)
        at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/make-fetch-happen/lib/agent.js:174:29)
        at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/make-fetch-happen/lib/remote.js:7:18)
    @djsirius
    Und die letzte Version des Checks ist:
    uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      @djsirius
      djsirius
      @thomas-braun said in Raspberry Pi NodeJS update aber NPM hat die flasche Version:
      pi@ioBroker-RasPi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.17.1
      v16.17.1
      djsirius
      • D djsirius
        armv7l
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.17.1
        v16.17.1
        @djsirius
        Hast du reinstalliert?
          @djsirius
          djsirius
          ja, hab ich gemacht.
          pi@ioBroker-RasPi:~ $ iobroker stop
          pi@ioBroker-RasPi:~ $ sudo apt install --reinstall nodejs
          0 aktualisiert, 0 neu installiert, 1 erneut installiert, 0 zu entfernen und 0 nicht aktualisiert.
          Es müssen noch 0 B von 24,1 MB an Archiven heruntergeladen werden.
          Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
          (Lese Datenbank ... 60491 Dateien und Verzeichnisse sind derzeit installiert.)
          Vorbereitung zum Entpacken von .../nodejs_16.17.1-deb-1nodesource1_armhf.deb ...
          Entpacken von nodejs (16.17.1-deb-1nodesource1) über (16.17.1-deb-1nodesource1) ...
          nodejs (16.17.1-deb-1nodesource1) wird eingerichtet ...
          Trigger für man-db (2.8.5-2) werden verarbeitet ...
          djsirius
          • D djsirius
            @djsirius
            sudo rm -rf /usr/lib/node_modules/npm
              @djsirius
              djsirius
              @thomas-braun hat funktioniert! 👍
              Vielen Dank!
              djsirius
              • D djsirius
                Vielen Dank!
                @djsirius
                Wie sieht
                nun aus?
                  @djsirius
                  Wie sieht
                  nun aus?
                  djsirius
                  armv7l
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v16.17.1
                  v16.17.1
                  8.15.0
                  4.0.23
                  pi
                  pi adm tty dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                  /home/pi
                  OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                  OK:2 http://archive.raspberrypi.org/debian buster InRelease
                  OK:3 http://repo.mysql.com/apt/debian buster InRelease
                  OK:4 https://deb.nodesource.com/node_16.x buster InRelease
                  Alle Pakete sind aktuell.
                  N: Das Laden der konfigurierten Datei »mysql-apt-config/binary-armhf/Packages« wird übersprungen, da das Depot »http://repo.mysql.com/apt/debian buster InRelease« die Architektur »armhf« nicht unterstützt.
                  N: Das Laden der konfigurierten Datei »mysql-8.0/binary-armhf/Packages« wird übersprungen, da das Depot »http://repo.mysql.com/apt/debian buster InRelease« die Architektur »armhf« nicht unterstützt.
                  N: Das Laden der konfigurierten Datei »mysql-tools/binary-armhf/Packages« wird übersprungen, da das Depot »http://repo.mysql.com/apt/debian buster InRelease« die Architektur »armhf« nicht unterstützt.
                  nodejs:
                    Installiert:           16.17.1-deb-1nodesource1
                    Installationskandidat: 16.17.1-deb-1nodesource1
                    Versionstabelle:
                   *** 16.17.1-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                       10.24.0~dfsg-1~deb10u2 500
                  djsirius
                  • D djsirius
                    armv7l
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v16.17.1
                    v16.17.1
                    8.15.0
                    4.0.23
                    pi
                    /home/pi
                    nodejs:
                      Versionstabelle:
                    @djsirius
                    Schau dir das mysql Repository an. Da stimmt was nicht.
                      @djsirius
                      djsirius
                      @djsirius
                      wo finde ich das?
                      djsirius
                      • D djsirius
                        @djsirius
                        wo finde ich das?
                        @djsirius
                        Keine Ahnung. Ich hab das nicht angelegt.
                        cat  /etc/apt/sources.list.d/mysql.list
                        zeigt was? mysql wird nicht für deinen Prozessor über dieses Repo bereitgestellt. Kann also gelöscht werden.
                          @djsirius
                          djsirius
                          @thomas-braun Hi, hab ich gemacht, danke!
                          djsirius
