  4. Canvas Package korrekt installieren
    5.4k
32 Beiträge 3 Kommentatoren 2.7k Aufrufe 5 Beobachtet
    @damrak2022 Hinter dem Kommando cd (Change directory) kommt ein Leerzeichen.
    Damrak2022D Offline
    Damrak2022D Offline
    Damrak2022
    @thomas-braun Ich muss mal nachfragen da im Protokoll stand das kein Canvas installiert ist. Also habe ich es nach Deiner Anleitung nachinstalliert und vorher alles aktualisiert und auch einen fix durchgeführt.
    Nun bekomme ich diese Ausgabe:
    pi@homebridge:~ $ sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
    Reading package lists... Done
    build-essential is already the newest version (12.9).
    libgif-dev is already the newest version (5.1.9-2).
    libjpeg-dev is already the newest version (1:2.0.6-4).
    librsvg2-dev is already the newest version (2.50.3+dfsg-1).
    libpango1.0-dev is already the newest version (1.46.2-3).
    libcairo2-dev is already the newest version (1.16.0-5+rpt1).
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    pi@homebridge:~ $ cd /opt/iobroker/node_modules/iobroker.mihome-vacuum
    pi@homebridge:/opt/iobroker/node_modules/iobroker.mihome-vacuum $ npm install canvas --unsafe-perm=true
    npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
    npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
    npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
    npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    added 678 packages, and audited 679 packages in 2m
    55 packages are looking for funding
      run `npm fund` for details
    6 high severity vulnerabilities
    To address issues that do not require attention, run:
      npm audit fix
    To address all issues (including breaking changes), run:
      npm audit fix --force
    Run `npm audit` for details.
    Ist das jetzt alles korrekt oder muss ich hier irgendwo Hand anlegen. Falls ja, was muss ich genau eingeben?
    Im Log steht allerdings immer noch:
    2022-10-13 22:54:21.038	warn	CANVAS package not installed....please install Canvas package manually or disable Map in config see also https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/blob/master/lib/canvaserror.md
    Mit besten Grüßen
    Andy
    • Damrak2022D Damrak2022
        npm audit fix
      @damrak2022
      cd /opt/iobroker
      npm ls canvas
        @damrak2022
        cd /opt/iobroker
        npm ls canvas
        Damrak2022D Offline
        Damrak2022D Offline
        Damrak2022
        @thomas-braun sagte in (Gelöst) Canvas Package korrekt installieren:
        npm ls canvas
        pi@homebridge:/opt/iobroker $ npm ls canvas
        iobroker.inst@3.0.0 /opt/iobroker
        ├─┬ iobroker.echarts@1.0.12
        │ ├── canvas@2.9.3
        │ └─┬ jsdom@19.0.0
        │   └── canvas@2.9.3 deduped
        ├─┬ iobroker.iot@1.11.9
        ├─┬ iobroker.mihome-vacuum@3.4.2
        │ └── canvas@2.10.1
        └─┬ iobroker.parcel@0.0.23
          └─┬ jsdom@20.0.1
        Aber weiterhin die Meldung im Log:
        2022-10-14 00:36:14.562	warn	CANVAS package not installed....please install Canvas package manually or disable Map in config see also https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/blob/master/lib/canvaserror.md
        Wieso habe ich immer noch diese Warnmeldung und was kann ich jetzt noch machen?
        Mit besten Grüßen
        Andy
          npm ls canvas
          │ ├── canvas@2.9.3
          │ └─┬ jsdom@19.0.0
          │ └── canvas@2.10.1
            └─┬ jsdom@20.0.1
          @damrak2022 sagte in Canvas Package korrekt installieren:
          Installier den mal neu. Log File beobachten.
            Damrak2022D Offline
            Damrak2022D Offline
            Damrak2022
            @thomas-braun Sorry Thomas, wie muss ich da vorgehen?
            Mit besten Grüßen
            Andy
              @damrak2022
              In einem Terminal:
              iob logs --watch | uniq
              Dann den Adapter rauswerfen und neuinstallieren.
                @damrak2022
                In einem Terminal:
                Damrak2022D Offline
                Damrak2022D Offline
                Damrak2022
                @thomas-braun sagte in Canvas Package korrekt installieren:
                Der Befehl läuft im Terminal ewig. Aber ich muss wahrscheinlich warten bis der fertig ist, oder?
                Und dann soll ich den mihome Adapter löschen und neu installieren, richtig?
                Mit besten Grüßen
                Andy
                  Natürlich läuft der 'ewig', der schaut permanent in das Log File. Der wird nie 'fertig'.
                  Mit STRG-C kommst du da wieder raus.
                  Aber du sollst ja beobachten, was im LogFile passiert, wenn du den Adapter reinstallierst.
                    Damrak2022D Offline
                    Damrak2022D Offline
                    Damrak2022
                    @thomas-braun Das steht im Log
                    2022-10-14 22:01:30.464  - error: host.homebridge instance system.adapter.mihome-vacuum.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                    2022-10-14 22:01:30.465  - info: host.homebridge Do not restart adapter system.adapter.mihome-vacuum.0 because desired by instance
                    2022-10-14 22:01:45.190  - info: host.homebridge iobroker removed 3 packages in 14s179 packages are looking for funding  run `npm fund` for details
                    2022-10-14 22:01:46.272  - info: host.homebridge iobroker exit 0
                    2022-10-14 22:01:59.641  - info: host.homebridge iobroker add mihome-vacuum --host homebridge
                    2022-10-14 22:02:03.199  - info: host.homebridge iobroker NPM version: 8.15.0
                    2022-10-14 22:02:03.205  - info: host.homebridge iobroker Installing iobroker.mihome-vacuum@3.4.2... (System call)
                    2022-10-14 22:02:17.622  - info: host.homebridge iobroker
                    2022-10-14 22:02:17.626  - info: host.homebridge iobroker added 3 packages in 13s179 packages are looking for funding  run `npm fund` for details
                    2022-10-14 22:02:17.683  - info: host.homebridge iobroker host.homebridge install adapter mihome-vacuum
                    2022-10-14 22:02:17.854  - info: host.homebridge iobroker These apt-get packages were already installed: libcairo2-dev, libpango1.0-dev, libjpeg-dev, libgif-dev, librsvg2-dev
                    2022-10-14 22:02:17.917  - info: host.homebridge iobroker upload [20] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
                    2022-10-14 22:02:18.142  - info: host.homebridge iobroker upload [19] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/de/translations.json i18n/de/translations.json application/json
                    2022-10-14 22:02:18.166  - info: host.homebridge iobroker upload [18] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/en/translations.json i18n/en/translations.json application/json
                    2022-10-14 22:02:18.182  - info: host.homebridge iobroker upload [17] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/es/translations.json i18n/es/translations.json application/json
                    2022-10-14 22:02:18.195  - info: host.homebridge iobroker upload [16] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                    2022-10-14 22:02:18.208  - info: host.homebridge iobroker upload [15] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/it/translations.json i18n/it/translations.json application/json
                    2022-10-14 22:02:18.220  - info: host.homebridge iobroker upload [14] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                    2022-10-14 22:02:18.233  - info: host.homebridge iobroker upload [13] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                    2022-10-14 22:02:18.248  - info: host.homebridge iobroker upload [12] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                    2022-10-14 22:02:18.262  - info: host.homebridge iobroker upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                    2022-10-14 22:02:18.278  - info: host.homebridge iobroker upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                    2022-10-14 22:02:18.298  - info: host.homebridge iobroker upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
                    2022-10-14 22:02:18.308  - info: host.homebridge iobroker upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
                    2022-10-14 22:02:18.321  - info: host.homebridge iobroker upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
                    2022-10-14 22:02:18.336  - info: host.homebridge iobroker upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
                    2022-10-14 22:02:18.367  - info: host.homebridge iobroker upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
                    2022-10-14 22:02:18.382  - info: host.homebridge iobroker upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
                    2022-10-14 22:02:18.395  - info: host.homebridge iobroker upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
                    2022-10-14 22:02:18.409  - info: host.homebridge iobroker upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
                    2022-10-14 22:02:18.426  - info: host.homebridge iobroker upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
                    2022-10-14 22:02:18.453  - info: host.homebridge iobroker upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
                    2022-10-14 22:02:18.611  - info: host.homebridge iobroker host.homebridge object system.adapter.mihome-vacuum created/updated
                    2022-10-14 22:02:18.774  - info: host.homebridge iobroker host.homebridge create instance mihome-vacuum
                    2022-10-14 22:02:18.789  - info: host.homebridge iobroker host.homebridge object system.adapter.mihome-vacuum.0.alive created
                    2022-10-14 22:02:18.804  - info: host.homebridge iobroker host.homebridge object system.adapter.mihome-vacuum.0.connected created
                    2022-10-14 22:02:18.820  - info: host.homebridge iobroker host.homebridge object system.adapter.mihome-vacuum.0.compactMode created
                    2022-10-14 22:02:18.838  - info: host.homebridge iobroker host.homebridge object system.adapter.mihome-vacuum.0.cpu created
                    2022-10-14 22:02:18.856  - info: host.homebridge iobroker host.homebridge object system.adapter.mihome-vacuum.0.cputime created
                    2022-10-14 22:02:18.875  - info: host.homebridge iobroker host.homebridge object system.adapter.mihome-vacuum.0.memHeapUsed created
                    2022-10-14 22:02:18.894  - info: host.homebridge iobroker host.homebridge object system.adapter.mihome-vacuum.0.memHeapTotal created
                    2022-10-14 22:02:18.920  - info: host.homebridge iobroker host.homebridge object system.adapter.mihome-vacuum.0.memRss created
                    2022-10-14 22:02:18.948  - info: host.homebridge iobroker host.homebridge object system.adapter.mihome-vacuum.0.uptime created
                    2022-10-14 22:02:18.971  - info: host.homebridge iobroker host.homebridge object system.adapter.mihome-vacuum.0.inputCount created
                    2022-10-14 22:02:18.995  - info: host.homebridge iobroker host.homebridge object system.adapter.mihome-vacuum.0.outputCount created
                    2022-10-14 22:02:19.015  - info: host.homebridge iobroker host.homebridge object system.adapter.mihome-vacuum.0.eventLoopLag created
                    2022-10-14 22:02:19.033  - info: host.homebridge iobroker host.homebridge object system.adapter.mihome-vacuum.0.sigKill created
                    2022-10-14 22:02:19.050  - info: host.homebridge iobroker host.homebridge object system.adapter.mihome-vacuum.0.logLevel created
                    2022-10-14 22:02:19.063  - info: host.homebridge iobroker host.homebridge object mihome-vacuum.0.info created
                    2022-10-14 22:02:19.076  - info: host.homebridge iobroker host.homebridge object mihome-vacuum.0.info.connection created
                    2022-10-14 22:02:19.089  - info: host.homebridge iobroker host.homebridge object mihome-vacuum.0 created
                    2022-10-14 22:02:19.113  - info: host.homebridge iobroker host.homebridge object system.adapter.mihome-vacuum.0 created
                    2022-10-14 22:02:20.246  - info: host.homebridge iobroker exit 0
                    2022-10-14 22:02:23.581  - info: admin.0 (3554) ==> Connected system.user.admin from ::ffff:192.168.178.22
                    Und so sieht es bei Canvas aus:
                    │ ├── canvas@2.9.3
                    │ └─┬ jsdom@19.0.0
                      └─┬ jsdom@20.0.1
                    Aber nach dem aktivieren der Karte kommt wieder der Fehler im Log:
                    2022-10-14 22:09:37.199	warn	CANVAS package not installed....please install Canvas package manually or disable Map in config see also https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/blob/master/lib/canvaserror.md
                    mihome-vacuum.0
                    2022-10-14 22:09:37.014	warn	CANVAS package not installed....please install Canvas package manually or disable Map in config see also https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/blob/master/lib/canvaserror.md
                    Mit besten Grüßen
                    Andy
                      │ ├── canvas@2.9.3
                      │ └─┬ jsdom@19.0.0
                        └─┬ jsdom@20.0.1
                      mihome-vacuum.0
                      @damrak2022
                      Keine Ahnung.
                        @damrak2022
                        Keine Ahnung.
                        Damrak2022D Offline
                        Damrak2022D Offline
                        Damrak2022
                        @thomas-braun Okay, ich hate irgendwo was von dem Befehl "npm -i" gelesen. Kann ich den bedenkenlos ausführen?
                        Mit besten Grüßen
                        Andy
                          @damrak2022
                          Kommt drauf an wo.
                          Aber besser von 'npm' direkt die Finger lassen.
                            @damrak2022
                            Kommt drauf an wo.
                            Damrak2022D Offline
                            Damrak2022D Offline
                            Damrak2022
                            @thomas-braun Okay, danke
                            Mit besten Grüßen
                            Andy
                              @damrak2022
                              Error at installation
                              if your installation runs in error. The canvas package could not be installed
                              npm ERR! canvas@2.6.1 install: node-pre-gyp install --fallback-to-build npm ERR! Exit status 1
                              Please install canvas and the libs manually with:
                              switch into :
                              Damrak2022D Offline
                              Damrak2022D Offline
                              Damrak2022
                              Nachdem ich jetzt Canvas auf dem neuen System aufspielen wollte, bekomme ich diese Meldungen:
                              Andy@homebridge:~ $ sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                              build-essential ist schon die neueste Version (12.9).
                              libgif-dev ist schon die neueste Version (5.1.9-2).
                              libjpeg-dev ist schon die neueste Version (1:2.0.6-4).
                              librsvg2-dev ist schon die neueste Version (2.50.3+dfsg-1).
                              libpango1.0-dev ist schon die neueste Version (1.46.2-3).
                              libcairo2-dev ist schon die neueste Version (1.16.0-5+rpt1).
                              0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                              Andy@homebridge:~ $ cd /opt/iobroker/node_modules/iobroker.mihome-vacuum
                              Andy@homebridge:/opt/iobroker/node_modules/iobroker.mihome-vacuum $ npm install canvas --unsafe-perm=true
                              added 655 packages, and audited 656 packages in 2m
                              54 packages are looking for funding
                              7 vulnerabilities (1 moderate, 6 high)
                                npm audit fix
                              To address all issues possible (including breaking changes), run:
                              Some issues need review, and may require choosing
                              a different dependency.
                              Ich habe das mal abgefragt. Also ist es anscheinend doch sauber installiert, oder?
                              Andy@homebridge:/opt/iobroker $ npm ls canvas
                              ├─┬ iobroker.iot@1.14.2
                              │ ├── canvas@2.11.2
                              │ └─┬ jsdom@20.0.3
                              │   └── canvas@2.11.2 deduped
                              └─┬ iobroker.mihome-vacuum@3.9.5
                                └── canvas@2.11.2
                              Mit besten Grüßen
                              Andy
                                  npm audit fix
                                │ ├── canvas@2.11.2
                                │ └─┬ jsdom@20.0.3
                                  └── canvas@2.11.2
                                Ja.
                                  Ja.
                                  Damrak2022D Offline
                                  Damrak2022D Offline
                                  Damrak2022
                                  Mit besten Grüßen
                                  Andy
