  4. iobroker kaputt nach NodeJS Update
75 Beiträge 3 Kommentatoren 6.0k Aufrufe 4 Beobachtet
  • M michaelheiml
    @michaelheiml
    Hab wie im anderen Thread nach
    npm install
    noch
    npm prune
    ausgeführt, mit dem Ergebnis
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/iobroker.admin
    npm ERR! dest /opt/iobroker/node_modules/.iobroker.admin-TtUA2igk
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.admin' -> '/opt/iobroker/node_modules/.iobroker.admin-TtUA2igk'
    npm ERR!     /home/iobroker/.npm/_logs/2022-10-10T20_52_25_777Z-debug-0.log
    @michaelheiml
    for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
      @michaelheiml
      michaelheiml
      schrieb am zuletzt editiert von michaelheiml
      Ausgeführt, und jetzt? (Das ist der Befehl zum Löschen der versteckten Ordner, nicht?)
      pi@raspberrypi:/opt/iobroker $ npm list
      iobroker.inst@3.0.0 /opt/iobroker
      ├── bower@1.8.14 extraneous
      ├── iobroker.admin@6.2.22 invalid: "stable" from the root project
      ├── iobroker.backitup@2.4.12 invalid: "stable" from the root project
      ├── iobroker.discovery@3.0.3 invalid: "stable" from the root project
      ├── iobroker.flot@1.11.0
      ├── iobroker.habpanel@0.5.0 extraneous
      ├── iobroker.js-controller@4.0.23 invalid: "stable" from the root project
      ├── iobroker.upnp@1.0.19
      └── iobroker.vis@1.4.15
      npm ERR! code ELSPROBLEMS
      npm ERR! extraneous: bower@1.8.14 /opt/iobroker/node_modules/bower
      npm ERR! invalid: iobroker.admin@6.2.22 /opt/iobroker/node_modules/iobroker.admin
      npm ERR! invalid: iobroker.backitup@2.4.12 /opt/iobroker/node_modules/iobroker.backitup
      npm ERR! invalid: iobroker.discovery@3.0.3 /opt/iobroker/node_modules/iobroker.discovery
      npm ERR! extraneous: iobroker.habpanel@0.5.0 /opt/iobroker/node_modules/iobroker.habpanel
      npm ERR! invalid: iobroker.js-controller@4.0.23 /opt/iobroker/node_modules/iobroker.js-controller
      npm ERR!     /home/iobroker/.npm/_logs/2022-10-10T20_57_41_547Z-debug-0.log
      Thomas BraunT M 2 Antworten Letzte Antwort
      • M michaelheiml
        @michaelheiml
        Hast du die package.json umbenannt?
        • M michaelheiml
          michaelheiml
          @michaelheiml
          Oh, ich komme wieder auf die Webseite. Muss ich das verstehen?
          Ja, vis, upnp, flot und habpanel hatte ich installiert (dachte gerade, wenn die jetzt gelistet sind, wird iobroker versuchen, meine Module wiederherzustellen -> daher Zugriffsversuch auf die Seite)
            @michaelheiml
            michaelheiml
            Nein. Aber es steht jetzt mehr drin.
            Ich versteh nicht, was hier passiert gerade.
            http://192.168.1.254:8081/#tab-adapters ist wieder erreichbar, aber es sind nur 4 meiner früheren Adapter sichtbar.
            • M michaelheiml
              @michaelheiml
              iobroker update
                @michaelheiml
                iobroker update
                michaelheiml
                @thomas-braun said in iobroker kaputt nach NodeJS Update:
                iobroker update
                pi@raspberrypi:/opt/iobroker $ iobroker update
                Used repository: stable
                Adapter    "admin"        : 6.2.22   , installed 6.2.22
                Adapter    "backitup"     : 2.4.12   , installed 2.4.12
                Adapter    "discovery"    : 3.0.5    , installed 3.0.3  [Updatable]
                Adapter    "flot"         : 1.11.0   , installed 1.11.0
                Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                Controller "js-controller": 4.0.23   , installed 4.0.23
                Adapter    "upnp"         : 1.0.21   , installed 1.0.19 [Updatable]
                • M michaelheiml
                  @michaelheiml sagte in iobroker kaputt nach NodeJS Update:
                  Hau dein Backup rein.
                    michaelheiml
                    Moment, da muss ich jetzt nur noch rausfinden, wie das geht, mach ich zum ersten Mal.
                    Ok, läuft..
                      michaelheiml
                      Schlägt fehl.
                      [ERROR] [iobroker] host.raspberrypi Cannot extract from file "/opt/iobroker/backups/iobroker_2022_10_10-02_00_10_backupiobroker.tar.gz": ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.js-controller/tmp'
                      Außerdem versucht iobroker jetzt, alle Adapter nachzuinstallieren, aber wieder mit den Fehlermeldungen dass das nicht geht (da war ich heute auch schon mal):
                      iobroker npm-install: host.raspberrypi Cannot install iobroker.weatherunderground@3.4.2: 217
                      Fehler 217 erscheint bei jedem Modul
                      iobroker npm-install: exit 25
                      zumindest sind meine gesamten Instanzen und Objekte wieder da, trotz des Log Eintrag Fehlers von BackItUp
                      • M michaelheiml
                        Schlägt fehl.
                        @michaelheiml
                        again...
                          @michaelheiml
                          again...
                          michaelheiml
                          #66
                          Gemacht, und dann? iob stop und iob start zum Neustarten?
                          • M michaelheiml
                            #67
                            @michaelheiml
                            Läuft das Backup noch im Hintergrund?
                              @michaelheiml
                              michaelheiml
                              #68
                              Wie sehe ich das? (Ob das Backup im Hintergrund noch läuft)
                              Im Übrigen, nach iob stop hätte ich jetzt eben iob update eingegeben, mit dem Ergebnis
                              pi@raspberrypi:/opt/iobroker $ iob stop
                              pi@raspberrypi:/opt/iobroker $ iob update
                              node:internal/modules/cjs/loader:959
                                throw err;
                              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                  at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
                                  at Function.Module._load (node:internal/modules/cjs/loader:804:27)
                                  at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                                  at node:internal/main/run_main_module:17:47 {
                                code: 'MODULE_NOT_FOUND',
                                requireStack: []
                              iob start -> startet aber iobroker wieder..
                              • M michaelheiml
                                  throw err;
                                  requireStack: []
                                #69
                                Wie sehe ich das?
                                Nach iob stop gar nicht mehr, das hast du weggeknallt, wenn es denn noch lief.
                                Im Log File sieht man, ob da noch was läuft.
                                iobroker logs --watch
                                in einem zweiten Terminal mitlaufen lassen.
                                  Wie sehe ich das?
                                  michaelheiml
                                  #70
                                  ok.. nevermind. iob start startet den Webservice jetzt auch nicht mehr neu. Keine Ahnung was da schief läuft.
                                    Wie sehe ich das?
                                    michaelheiml
                                    #71
                                    pi@raspberrypi:/opt/iobroker $ iobroker logs --watch
                                      throw err;
                                      requireStack: []
                                    • M michaelheiml
                                        throw err;
                                        requireStack: []
                                      #72
                                      @michaelheiml
                                      Ich bin jetzt weg.
                                      Installier es neu, das wird vermutlich nix gescheites mehr geben.
                                      M 3 Antworten Letzte Antwort
                                        @michaelheiml
                                        Ich bin jetzt weg.
                                        michaelheiml
                                        #73
                                        npm list
                                        ├── UNMET DEPENDENCY iobroker.admin@stable
                                        ├── UNMET DEPENDENCY iobroker.backitup@stable
                                        ├── UNMET DEPENDENCY iobroker.discovery@stable
                                        ├── UNMET DEPENDENCY iobroker.js-controller@stable
                                          @michaelheiml
                                          Ich bin jetzt weg.
                                          michaelheiml
                                          #74
                                          OK danke trotzdem für deine Bemühungen.
