  4. Adapter updaten nicht mehr nach Update auf Node.js 16.17.0
    5.7k
94 Beiträge 7 Kommentatoren 17.0k Aufrufe 6 Beobachtet
  • I iobrokerle
    @thomas-braun said in Adapter updaten nicht mehr nach Update auf Node.js 16.17.0:
    iobroker add ble --debug
    NPM version: 8.15.0
    Installing iobroker.ble@0.13.0... (System call)
    npm WARN old lockfile
    npm WARN old lockfile The package-lock.json file was created with an old version of npm,
    npm WARN old lockfile so supplemental metadata must be fetched from the registry.
    npm WARN old lockfile This is a one-time fix-up, please be patient...
    npm WARN tarball tarball data for iobroker.icons-ultimate-png@https://github.com/ioBroker/ioBroker.icons-ultimate-png/tarball/master (sha512-ZauMOfdp4ublYvWRd6mFp64dZ9T5k7z0aX/GcX3ljGziXyNVFtV3iUADNWoBGOk/vLPawTV7w2JpbMmTsHKNMQ==) seems to be corrupted. Trying again.
    npm WARN tarball tarball data for iobroker.vis-jqui-mfd@https://github.com/ioBroker/ioBroker.vis-jqui-mfd/tarball/master (sha512-INXgmBMn8dXk+ySYR6Hx+ZAC8x36xGKAk8IKet0N8m4xe/Q4EiwzCsOlMbtQsWG/PrtUDopnvLMqNB3EDQnCHg==) seems to be corrupted. Trying again.
    npm ERR! code EINTEGRITY
    npm ERR! sha512-INXgmBMn8dXk+ySYR6Hx+ZAC8x36xGKAk8IKet0N8m4xe/Q4EiwzCsOlMbtQsWG/PrtUDopnvLMqNB3EDQnCHg== integrity checksum failed when using sha512: wanted sha512-INXgmBMn8dXk+ySYR6Hx+ZAC8x36xGKAk8IKet0N8m4xe/Q4EiwzCsOlMbtQsWG/PrtUDopnvLMqNB3EDQnCHg== but got sha512-aIDxplY3tckVzKezokybf2Ki4MQdHn7DKw+ipKbVUvmkmT88o3KFhxEie1xLO5bF3zDUAAhayGPASuYSacYieQ==. (285658 bytes)
    npm ERR!     /home/iobroker/.npm/_logs/2022-09-25T13_12_37_930Z-debug-0.log
    host.raspberry-iob Cannot install iobroker.ble@0.13.0: 1
    @iobrokerle
    cd /opt/iobroker
    sudo -H -u iobroker npm cache clear --force
    iobroker update
    iobroker upgrade
    I 1 Antwort Letzte Antwort
      @iobrokerle
      cd /opt/iobroker
      iobroker update
      iobroker upgrade
      I Offline
      I Offline
      iobrokerle
      schrieb am zuletzt editiert von iobrokerle
      iobroker update iobroker upgrade
      pi@raspberry-iob:/opt/iobroker $ sudo -H -u iobroker npm cache clear --force
      npm WARN using --force Recommended protections disabled.
      Die beiden liefen durch:
      iobroker update
      iobroker upgrade
      Jetzt nochmal BLE installieren?
      • I iobrokerle
        iobroker update
        iobroker upgrade
        @iobrokerle
          @iobrokerle
          I Offline
          I Offline
          iobrokerle
          Immer noch:
          pi@raspberry-iob:/opt/iobroker $ iobroker add ble --debug
          NPM version: 8.15.0
          npm ERR!     /home/iobroker/.npm/_logs/2022-09-25T13_23_05_714Z-debug-0.log
          • I iobrokerle
            Immer noch:
            NPM version: 8.15.0
            @iobrokerle
            iobroker update
              @iobrokerle
              iobroker update
              I Offline
              I Offline
              iobrokerle
              iobroker update
              pi@raspberry-iob:/opt/iobroker $ iobroker update
              Used repository: stable
              Adapter    "admin"        : 6.2.22   , installed 6.2.22
              Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
              Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
              Adapter    "devices"      : 1.0.12   , installed 1.0.12
              Adapter    "discovery"    : 3.0.5    , installed 3.0.5
              Adapter    "ds18b20"      : 1.6.0    , installed 1.6.0
              Adapter    "echarts"      : 1.0.12   , installed 1.0.12
              Adapter    "email"        : 1.1.3    , installed 1.1.3
              Adapter    "firetv"       : 1.0.0    , installed 1.0.0
              Adapter    "flot"         : 1.11.0   , installed 1.11.0
              Adapter    "history"      : 2.2.0    , installed 2.2.0
              Adapter    "info"         : 1.9.19   , installed 1.9.19
              Adapter    "javascript"   : 6.0.3    , installed 6.0.3
              Controller "js-controller": 4.0.23   , installed 4.0.23
              Adapter    "node-red"     : 4.0.0    , installed 3.3.1  [Updatable]
              Adapter    "proxy"        : 1.3.1    , installed 1.3.1
              Adapter    "shelly"       : 6.0.0    , installed 6.0.0
              Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
              Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
              Adapter    "statistics"   : 2.2.0    , installed 2.2.0
              Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
              Adapter    "telegram"     : 1.14.1   , installed 1.14.1
              Adapter    "text2command" : 2.2.2    , installed 2.2.2
              Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
              Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
              Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
              Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
              Adapter    "weatherunderground": 3.4.2, installed 3.4.2
              • I iobrokerle
                Immer noch:
                NPM version: 8.15.0
                @iobrokerle
                iobroker upgrade vis-jqui-mfd@1.0.12
                  @iobrokerle
                  I Offline
                  I Offline
                  iobrokerle
                  pi@raspberry-iob:/opt/iobroker $ iobroker upgrade vis-jqui-mfd@1.0.12
                  Would you like to reinstall version 1.0.12 of vis-jqui-mfd now? [(y)es, (n)o]: y
                  Update vis-jqui-mfd from @1.0.12 to @1.0.12
                  NPM version: 8.15.0
                  Installing iobroker.vis-jqui-mfd@1.0.12... (System call)
                  INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-jqui-mfd/www" was not found! Nothing was uploaded or deleted.
                  Adapter "system.adapter.vis.0" restarted.
                  upload [0] vis-jqui-mfd.admin /opt/iobroker/node_modules/iobroker.vis-jqui-mfd/admin/jqui-mfd.png jqui-mfd.png image/png
                  • I iobrokerle
                    NPM version: 8.15.0
                    @iobrokerle
                    cd /opt/iobroker
                    npm prune
                    npm ls
                      @iobrokerle
                      cd /opt/iobroker
                      npm prune
                      npm ls
                      I Offline
                      I Offline
                      iobrokerle
                      cd /opt/iobroker
                      pi@raspberry-iob:/opt/iobroker $ npm prune
                      npm ERR! sha512-ZauMOfdp4ublYvWRd6mFp64dZ9T5k7z0aX/GcX3ljGziXyNVFtV3iUADNWoBGOk/vLPawTV7w2JpbMmTsHKNMQ== integrity checksum failed when using sha512: wanted sha512-ZauMOfdp4ublYvWRd6mFp64dZ9T5k7z0aX/GcX3ljGziXyNVFtV3iUADNWoBGOk/vLPawTV7w2JpbMmTsHKNMQ== but got sha512-drue5OEPkI+l3Uiatv6ltEKCEFrMcVteIy3oYdt2Y1Nc/aS3bLXuYGt7RkKgTz9a2suOqKCsA4UWBn7y9vPRuw==. (1670356 bytes)
                      npm ERR!     /home/iobroker/.npm/_logs/2022-09-25T13_37_04_055Z-debug-0.log
                      pi@raspberry-iob:/opt/iobroker $ npm ls
                      iobroker.inst@2.0.3 /opt/iobroker
                      ├── @abandonware/bluetooth-hci-socket@0.5.3-8 extraneous
                      ├── @abandonware/noble@1.9.2-15 extraneous
                      ├── @types/caseless@0.12.2 extraneous
                      ├── @types/request@2.48.8 extraneous
                      ├── @types/tough-cookie@4.0.2 extraneous
                      ├── bignumber.js@9.0.2 extraneous
                      ├── coffeescript@1.12.7 extraneous
                      ├── colors@1.4.0
                      ├── fs-extra@7.0.1
                      ├── http-cookie-agent@1.0.5 extraneous
                      ├── iobroker-react-components@1.0.0 extraneous
                      ├── iobroker.admin@6.2.22
                      ├── iobroker.alexa2@3.19.9
                      ├── UNMET DEPENDENCY iobroker.ble@0.13.0
                      ├── UNMET DEPENDENCY iobroker.bmw@2.5.3
                      ├── iobroker.coronavirus-statistics@0.8.7
                      ├── UNMET DEPENDENCY iobroker.daswetter@3.1.2
                      ├── iobroker.devices@1.0.12
                      ├── iobroker.discovery@3.0.5
                      ├── iobroker.ds18b20@1.6.0
                      ├── iobroker.echarts@1.0.12
                      ├── iobroker.email@1.1.3
                      ├── iobroker.firetv@1.0.0
                      ├── iobroker.flot@1.11.0
                      ├── iobroker.history@2.2.0
                      ├── iobroker.icons-ultimate-png@1.0.1
                      ├── iobroker.info@1.9.19
                      ├── iobroker.javascript@6.0.3
                      ├── iobroker.js-controller@4.0.23
                      ├── iobroker.node-red@3.3.1
                      ├── iobroker.proxy@1.3.1
                      ├── iobroker.shelly@6.0.0
                      ├── iobroker.simple-api@2.7.0
                      ├── iobroker.socketio@4.2.0
                      ├── iobroker.sonoff@2.5.1
                      ├── iobroker.statistics@2.2.0
                      ├── iobroker.tankerkoenig@2.1.1
                      ├── iobroker.telegram@1.14.1
                      ├── iobroker.text2command@2.2.2
                      ├── iobroker.vis-bars@0.1.4
                      ├── iobroker.vis-fancyswitch@1.1.0
                      ├── iobroker.vis-history@1.0.0
                      ├── iobroker.vis-hqwidgets@1.3.0
                      ├── iobroker.vis-icontwo@ extraneous
                      ├── iobroker.vis-inventwo@3.3.1
                      ├── iobroker.vis-jqui-mfd@1.0.12
                      ├── iobroker.vis-map@1.0.4
                      ├── iobroker.vis-materialdesign@0.3.0
                      ├── iobroker.vis-metro@1.2.0
                      ├── iobroker.vis-timeandweather@1.2.2
                      ├── iobroker.vis-weather@2.5.5
                      ├── iobroker.vis@1.4.15
                      ├── iobroker.weatherunderground@3.4.2
                      ├── iobroker.web@4.3.0
                      ├── iobroker@2.0.3
                      ├── json-bigint@1.0.0 extraneous
                      ├── node-inspect@2.0.0 extraneous
                      ├── node-schedule@2.1.0 extraneous
                      ├── picocolors@1.0.0 extraneous
                      ├── semver@5.7.1
                      ├── setimmediate@1.0.5 extraneous
                      ├── suncalc2@1.8.1 extraneous
                      ├── typescript@4.7.4 extraneous
                      ├── usb@1.9.2 extraneous
                      ├── virtual-tsc@0.6.2 extraneous
                      ├── wake_on_lan@1.0.0 extraneous
                      ├── xml2json-light@1.0.6 extraneous
                      ├── xmlhttprequest@1.8.0 extraneous
                      └── yargs@7.1.0
                      npm ERR! code ELSPROBLEMS
                      npm ERR! extraneous: @abandonware/bluetooth-hci-socket@0.5.3-8 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
                      npm ERR! extraneous: @abandonware/noble@1.9.2-15 /opt/iobroker/node_modules/@abandonware/noble
                      npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
                      npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
                      npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
                      npm ERR! extraneous: bignumber.js@9.0.2 /opt/iobroker/node_modules/bignumber.js
                      npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                      npm ERR! extraneous: http-cookie-agent@1.0.5 /opt/iobroker/node_modules/http-cookie-agent
                      npm ERR! extraneous: iobroker-react-components@1.0.0 /opt/iobroker/node_modules/iobroker-react-components
                      npm ERR! missing: iobroker.ble@0.13.0, required by iobroker.inst@2.0.3
                      npm ERR! missing: iobroker.bmw@2.5.3, required by iobroker.inst@2.0.3
                      npm ERR! missing: iobroker.daswetter@3.1.2, required by iobroker.inst@2.0.3
                      npm ERR! extraneous: iobroker.vis-icontwo@ /opt/iobroker/node_modules/iobroker.vis-icontwo
                      npm ERR! extraneous: json-bigint@1.0.0 /opt/iobroker/node_modules/json-bigint
                      npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                      npm ERR! extraneous: node-schedule@2.1.0 /opt/iobroker/node_modules/node-schedule
                      npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                      npm ERR! extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
                      npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                      npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
                      npm ERR! extraneous: usb@1.9.2 /opt/iobroker/node_modules/usb
                      npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                      npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                      npm ERR! extraneous: xml2json-light@1.0.6 /opt/iobroker/node_modules/xml2json-light
                      npm ERR! extraneous: xmlhttprequest@1.8.0 /opt/iobroker/node_modules/xmlhttprequest
                      npm ERR!     /home/iobroker/.npm/_logs/2022-09-25T13_38_05_337Z-debug-0.log
                      Thomas BraunT I 2 Antworten Letzte Antwort
                      • I iobrokerle
                        cd /opt/iobroker
                        ├── colors@1.4.0
                        ├── fs-extra@7.0.1
                        ├── iobroker@2.0.3
                        ├── semver@5.7.1
                        └── yargs@7.1.0
                        @iobrokerle sagte in Adapter updaten nicht mehr nach Update auf Node.js 16.17.0:
                        icons-ultimate-png
                        Die gleiche Nummer jetzt mit dem Adapter
                        iobroker upgrade icons-ultimate-png@1.0.1
                        • I iobrokerle
                          cd /opt/iobroker
                          ├── colors@1.4.0
                          ├── fs-extra@7.0.1
                          ├── iobroker@2.0.3
                          ├── semver@5.7.1
                          └── yargs@7.1.0
                          I Offline
                          I Offline
                          iobrokerle
                          @iobrokerle
                          pi@raspberry-iob:/opt/iobroker $ iobroker upgrade icons-ultimate-png@1.0.1
                          Would you like to reinstall version 1.0.1 of icons-ultimate-png now? [(y)es, (n)o]: y
                          Update icons-ultimate-png from @1.0.1 to @1.0.1
                          NPM version: 8.15.0
                          Installing iobroker.icons-ultimate-png@1.0.1... (System call)
                          upload [1000] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/1.png 1.png image/png
                          upload [950] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/143.png 143.png image/png
                          upload [900] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/189.png 189.png image/png
                          upload [850] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/233.png 233.png image/png
                          upload [800] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/279.png 279.png image/png
                          upload [750] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/323.png 323.png image/png
                          upload [700] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/369.png 369.png image/png
                          upload [650] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/413.png 413.png image/png
                          upload [600] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/459.png 459.png image/png
                          upload [550] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/503.png 503.png image/png
                          upload [500] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/549.png 549.png image/png
                          upload [450] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/594.png 594.png image/png
                          upload [400] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/639.png 639.png image/png
                          upload [350] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/684.png 684.png image/png
                          upload [300] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/729.png 729.png image/png
                          upload [250] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/774.png 774.png image/png
                          upload [200] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/819.png 819.png image/png
                          upload [150] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/864.png 864.png image/png
                          upload [100] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/909.png 909.png image/png
                          upload [90] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/918.png 918.png image/png
                          upload [80] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/927.png 927.png image/png
                          upload [70] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/936.png 936.png image/png
                          upload [60] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/945.png 945.png image/png
                          upload [50] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/954.png 954.png image/png
                          upload [40] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/963.png 963.png image/png
                          upload [30] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/972.png 972.png image/png
                          upload [20] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/981.png 981.png image/png
                          upload [19] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/982.png 982.png image/png
                          upload [18] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/983.png 983.png image/png
                          upload [17] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/984.png 984.png image/png
                          upload [16] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/985.png 985.png image/png
                          upload [15] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/986.png 986.png image/png
                          upload [14] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/987.png 987.png image/png
                          upload [13] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/988.png 988.png image/png
                          upload [12] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/989.png 989.png image/png
                          upload [11] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/99.png 99.png image/png
                          upload [10] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/990.png 990.png image/png
                          upload [9] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/991.png 991.png image/png
                          upload [8] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/992.png 992.png image/png
                          upload [7] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/993.png 993.png image/png
                          upload [6] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/994.png 994.png image/png
                          upload [5] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/995.png 995.png image/png
                          upload [4] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/996.png 996.png image/png
                          upload [3] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/997.png 997.png image/png
                          upload [2] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/998.png 998.png image/png
                          upload [1] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/999.png 999.png image/png
                          upload [0] icons-ultimate-png /opt/iobroker/node_modules/iobroker.icons-ultimate-png/www/index.html index.html text/html
                          upload [1] icons-ultimate-png.admin /opt/iobroker/node_modules/iobroker.icons-ultimate-png/admin/icons-ultimate-png.png icons-ultimate-png.png image/png
                          upload [0] icons-ultimate-png.admin /opt/iobroker/node_modules/iobroker.icons-ultimate-png/admin/index.html index.html text/html
                          • I iobrokerle
                            @iobrokerle
                            NPM version: 8.15.0
                            @iobrokerle
                            Dann die drei Adapter von oben versuchen zu installieren.
                              @iobrokerle
                              I Offline
                              I Offline
                              iobrokerle
                              Immer noch 😖
                              NPM version: 8.15.0
                              npm ERR!     /home/iobroker/.npm/_logs/2022-09-25T13_51_31_032Z-debug-0.log
                              • I iobrokerle
                                Immer noch 😖
                                NPM version: 8.15.0
                                Dann schmeiß den
                                Adapter raus.
                                  Dann schmeiß den
                                  Adapter raus.
                                  I Offline
                                  I Offline
                                  iobrokerle
                                  Will auch nicht 😠
                                  $ iobroker del icons-ultimate-png
                                  Delete adapter "icons-ultimate-png"
                                  host.raspberry-iob Counted 1 meta of icons-ultimate-png
                                  host.raspberry-iob Counted 1 adapter for icons-ultimate-png
                                  host.raspberry-iob Counted 1 states of system.adapter.icons-ultimate-png
                                  host.raspberry-iob Counted 1 states (system.adapter.icons-ultimate-png.*) from states
                                  host.raspberry-iob file icons-ultimate-png deleted
                                  host.raspberry-iob file icons-ultimate-png.admin deleted
                                  host.raspberry-iob object icons-ultimate-png deleted
                                  host.raspberry-iob object icons-ultimate-png.admin deleted
                                  host.raspberry-iob Deleting 3 object(s).
                                  host.raspberry-iob Deleting 1 state(s).
                                  Error deleting adapter icons-ultimate-png from disk: host.raspberry-iob: Cannot uninstall iobroker.icons-ultimate-png: 1
                                  You might have to delete it yourself!
                                  Process exited with code 0
                                  Bei der Adapterübersicht ist er aber trotzdem drausen
                                  • I iobrokerle
                                    Will auch nicht 😠
                                    Wenn du den brauchst:
                                    iob add icons-ultimate-png --debug
                                      I Offline
                                      I Offline
                                      iobrokerle
                                      NPM version: 8.15.0
                                      npm ERR!     /home/iobroker/.npm/_logs/2022-09-25T14_01_13_021Z-debug-0.log
                                      • I iobrokerle
                                        NPM version: 8.15.0
                                        @iobrokerle
                                          @iobrokerle
                                          I Offline
                                          I Offline
                                          iobrokerle
                                          icons-ultimate-png
                                          icons-ultimate-png Installation hat funktioniert und ist auch nach de Start in den Adaptern dabei.
                                          Das oben war der Versuch BLE zu installieren.
                                          $ iobroker add ble --host raspberry-iob
                                          NPM version: 8.15.0
                                          ERROR: Process exited with code 25
