  4. Probleme bei Adapter Updates
    5.8k
updatesadapter
50 Beiträge 3 Kommentatoren 5.7k Aufrufe 2 Beobachtet
  • A aski71
    Auch das, wenn's hilft. ;-) Aber ich kann mir nicht vorstellen, dass jemand hier 5174 Zeilen Logdatei lesen möchte.
    Und leider sehe ich in dieser Logdatei, auf die unten verwiesen wird und deren Ende ich oben gepostet habe nicht, wo das zugehörige Log anfängt.
    Aber I/O war:
    /opt/iobroker$ sudo iobroker upgrade vis-canvas-gauges --debug
    This upgrade of "vis-canvas-gauges" will introduce the following changes:
    -> 1.0.1:
    Added workaround for firefox canvas problem
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade vis-canvas-gauges from @0.1.5 to @1.0.1 now? [(y)es, (n)o]: y
    Update vis-canvas-gauges from @0.1.5 to @1.0.1
    NPM version: 8.15.0
    Installing iobroker.vis-canvas-gauges@1.0.1... (System call)
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated appium-logger@2.1.0: Moved into appium-support
    npm WARN deprecated core-js@1.2.7: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
    npm WARN deprecated core-js@2.6.12: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
    npm ERR! code 127
    npm ERR! path /opt/iobroker/node_modules/underscore
    npm ERR! command failed
    npm ERR! command sh /tmp/postinstall-4edfe6af.sh
    npm ERR! /tmp/postinstall-4edfe6af.sh: 1: /tmp/postinstall-4edfe6af.sh: patch-package: not found
    npm ERR!     /home/iobroker/.npm/_logs/2022-09-23T21_13_20_174Z-debug-0.log
    host.homie Cannot install iobroker.vis-canvas-gauges@1.0.1: 127
    aski71
    @aski71 Ah, moment...
    /opt/iobroker$ sudo ln -s /usr/bin/node /usr/bin/nodejs
    ln: failed to create symbolic link '/usr/bin/nodejs': File exists
    /opt/iobroker$ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    x86_64
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.17.0
    v16.17.0
    8.15.0
    4.0.23
    ak
    ak adm cdrom sudo dip plugdev lxd sambashare lpadmin iobroker
    /opt/iobroker
    Ign:1 http://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.4 InRelease
    Hit:2 http://ppa.launchpad.net/certbot/certbot/ubuntu bionic InRelease
    Hit:3 http://de.archive.ubuntu.com/ubuntu bionic InRelease
    Hit:4 http://de.archive.ubuntu.com/ubuntu bionic-updates InRelease
    Hit:5 https://deb.nodesource.com/node_16.x bionic InRelease
    Hit:6 http://de.archive.ubuntu.com/ubuntu bionic-backports InRelease
    Hit:7 https://repo.mosquitto.org/debian buster InRelease
    Hit:8 http://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.4 Release
    Hit:9 https://repo.mosquitto.org/debian jessie InRelease
    Hit:10 http://security.ubuntu.com/ubuntu bionic-security InRelease
    Hit:11 https://repo.mosquitto.org/debian stretch InRelease
    Hit:12 https://dl.ubnt.com/unifi/debian stable InRelease
    Reading package lists... Done
    Building dependency tree
    2 packages can be upgraded. Run 'apt list --upgradable' to see them.
    nodejs:
      Installed: 16.17.0-1nodesource1
      Candidate: 16.17.1-1nodesource1
      Version table:
         16.17.1-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bionic/main amd64 Packages
     *** 16.17.0-1nodesource1 100
         8.10.0~dfsg-2ubuntu0.4 500
            500 http://de.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
         8.10.0~dfsg-2ubuntu0.2 500
            500 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
         8.10.0~dfsg-2 500
            500 http://de.archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
      @aski71 sagte in Probleme bei Adapter Updates:
      Verboten!
      iobroker NIE NIE NIEMALS per sudo/root anpacken.
      Fix das:
      iobroker stop
      iobroker fix
      iobroker start
      aski71
      @thomas-braun said in Probleme bei Adapter Updates:
      Verboten!
      Fix das:
      iobroker stop
      iobroker fix
      iobroker start
      Das ging bei mir noch nie ohne sudo.
      • A aski71
        x86_64
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.17.0
        v16.17.0
        8.15.0
        4.0.23
        ak
        /opt/iobroker
        nodejs:
          Version table:
             8.10.0~dfsg-2 500
        @aski71
        Was soll denn das für ein Frankenstein-Zoo an Paketquellen sein?
        Da geht ja ALLES kreuz und quer...
        • A aski71
          Verboten!
          Fix das:
          iobroker stop
          iobroker fix
          iobroker start
          Doch, in senkrechten Installationen geht das natürlich ohne sudo.
          Du hast das aber irgendwas wild falsch zusammenstöpselt.
            @aski71
            aski71
            @aski71
            Keine Ahnung. Ich habe nie was anderes gemacht, als die üblichen Upgrades über das iobroker Kommando.
            Respektive Systemupgrades via apt.
            Thomas BraunT A 2 Antworten Letzte Antwort
              aski71
              Dann gab es wohl wild falsch zusammen gestöpselte Anleitungen.
              • A aski71
                @aski71
                Das kann nicht sein.
                Muss auf bionic lauten, nicht auf xenial:
                Muss auf bionic lauten, nicht auf buster/jessie/stretch:
                • A aski71
                  @aski71
                  aski71
                  @aski71 said in Probleme bei Adapter Updates:
                  @aski71
                  Und wie entfrankensteine ich das nun am besten?
                  • A aski71
                    @aski71
                    @aski71
                    Schau dir die /etc/apt/sources.list.d/mosquitto.list (oder so ähnlich) an.
                    Da dürfte der Hauptquark drin stehen. Davon abgesehen ist mosquitto in den main Repos von 'bionic', soweit ich das sehe.
                    Ist aber OT für das Thema hier.
                      @aski71
                      aski71
                      @aski71
                      Wenn ich mir das oder so ähnlich anschaue, stehe ich garantiert davor, wie der Ochse vor'm Berg, wenn mir keiner sagt, wie das richtig aussehen muss.
                      Vor allem frage ich mich aber, warum das überhaupt falsch ist.
                      • A aski71
                        @aski71
                        Vermutlich, weil du die Anleitung von hier:
                        https://mosquitto.org/blog/2013/01/mosquitto-debian-repository/
                        falsch verstanden hast.
                        Da steht:
                        Then one of the following, depending on which version of debian you are using:
                        sudo wget http://repo.mosquitto.org/debian/mosquitto-jessie.list
                        sudo wget http://repo.mosquitto.org/debian/mosquitto-stretch.list
                        sudo wget http://repo.mosquitto.org/debian/mosquitto-buster.list
                        Du hast aber keine der drei Debian-Versionen, du hast ein Ubuntu 'Bionic' laufen.
                        sudo rm /etc/apt/sources.list.d/mosquitto-*
                        sudo apt update
                        apt policy mosquitto
                          Da steht:
                          sudo apt update
                          aski71
                          Da steht:
                          sudo apt update
                          Ich sehe diese Dateien tatsächlich zum allererstenmal und hab da noch nie was drin gebastelt.
                          ak@homie:/etc/apt/sources.list.d$ ls -l
                          total 38
                          -rw-r--r-- 1 root root  62 Feb 22  2022 100-ubnt-unifi.list
                          -rw-r--r-- 1 root root  70 Dec 27  2018 certbot-ubuntu-certbot-bionic.list
                          -rw-r--r-- 1 root root 177 Dec 27  2018 certbot-ubuntu-certbot-xenial.list
                          -rw-r--r-- 1 root root 134 Dec 20  2018 certbot-ubuntu-certbot-xenial.list.distUpgrade
                          -rw-r--r-- 1 root root 179 Dec 27  2018 certbot-ubuntu-certbot-xenial.list.save
                          -rw-r--r-- 1 root root  94 Jan 25  2019 mongodb-org-3.4.list
                          -rw-r--r-- 1 root root  50 Jun 25  2019 mosquitto-buster.list
                          -rw-r--r-- 1 root root  50 Aug  8  2018 mosquitto-jessie.list
                          -rw-r--r-- 1 root root  51 Aug  8  2018 mosquitto-stretch.list
                          -rw-r--r-- 1 root root 204 Feb  9  2022 nodesource.list
                          -rw-r--r-- 1 root root 108 Dec 20  2018 nodesource.list.distUpgrade
                          -rw-r--r-- 1 root root 198 Dec 27  2018 nodesource.list.save
                          Das sind die Dateien, die ich vorfinde. Die Mücken also alle löschen?
                          • A aski71
                            Da steht:
                            sudo apt update
                            total 38
                            Alles überflüssig/falsch.
                            Löschen:
                            sudo rm /etc/apt/sources.list.d/certbot-ubuntu-certbot-xenial*
                            sudo rm /etc/apt/sources.list.d/mosquitto*
                            sudo rm /etc/apt/sources.list.d/nodesource.list.*
                            sudo rm /etc/apt/sources.list.d/mongodb*
                            sudo apt update
                            apt policy mosquitto mongodb
                              Löschen:
                              sudo apt update
                              aski71
                              Löschen:
                              sudo apt update
                              In den cerbot files war ohnehin alles auskommentiert.
                              In der nodesource.list nicht.
                              Ich hab das jetzt mal gemacht. Es lief nun durch, aber nun bekomme ich folgende INFO: Directory not found.
                              ak@homie:/opt/iobroker$ sudo apt policy mosquitto mongodb
                              mosquitto:
                                Installed: 2.0.12-0mosquitto1~stretch1
                                Candidate: 2.0.12-0mosquitto1~stretch1
                                Version table:
                               *** 2.0.12-0mosquitto1~stretch1 100
                                   1.4.15-2ubuntu0.18.04.3 500
                                   1.4.15-2 500
                              mongodb:
                                Installed: (none)
                                Candidate: 1:3.6.3-0ubuntu1.4
                                Version table:
                                   1:3.6.3-0ubuntu1.4 500
                                   1:3.6.3-0ubuntu1 500
                              ak@homie:/opt/iobroker$ sudo iob upgrade vis-canvas-gauges
                              -> 1.0.1:
                              NPM version: 8.15.0
                              added 2 packages, removed 650 packages, and changed 886 packages in 2m
                              70 packages are looking for funding
                                run `npm fund` for details
                              INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-canvas-gauges/www" was not found! Nothing was uploaded or deleted.
                              Adapter "system.adapter.vis.0" restarted.
                              Update "system.adapter.vis-canvas-gauges.0"
                              upload [0] vis-canvas-gauges.admin /opt/iobroker/node_modules/iobroker.vis-canvas-gauges/admin/vis-canvas-gauges.png vis-canvas-gauges.png image/png
                              • A aski71
                                Löschen:
                                sudo apt update
                                mosquitto:
                                  Version table:
                                     1.4.15-2 500
                                mongodb:
                                  Installed: (none)
                                  Version table:
                                -> 1.0.1:
                                NPM version: 8.15.0
                                Lass den Mist mit sudo an Stellen, wo es nicht hingehört...
                                iobroker stop
                                iobroker fix
                                iobroker start
                                Wenn der iobroker wieder läuft:
                                iobroker update
                                Btw: Der mosquitto ist in der Version für Debian Stretch installiert. Kann u. U. ungünstig werden.
                                • A aski71
                                  Löschen:
                                  sudo apt update
                                  mosquitto:
                                    Version table:
                                       1.4.15-2 500
                                  mongodb:
                                    Installed: (none)
                                    Version table:
                                  -> 1.0.1:
                                  NPM version: 8.15.0
                                  aski71
                                  @aski71 Die anderen Adapter Updates scheinen jetzt aber durchzulaufen. Vielen Dank für Deine Hilfe @thomas-braun !
                                  • A aski71
                                    @aski71
                                    Hast du den iobroker fix ausgeführt?
                                    Wo ist die Ausgabe zu iobroker update?
                                    • A aski71
                                      @aski71
                                      Zu mosquitto:
                                      sudo apt-add-repository ppa:mosquitto-dev/mosquitto-ppa
                                      sudo apt update
                                        @aski71
                                        Zu mosquitto:
                                        sudo apt update
                                        aski71
                                        @aski71
                                        Zu mosquitto:
                                        sudo apt update
                                        Benötige ich das? Hatte oben verstanden, dass nein.
                                        • A aski71
                                          @aski71
                                          Zu mosquitto:
                                          sudo apt update
                                          @aski71
                                          Das sollte deinen mosquitto wieder auf ein Repo setzen.
                                          Im Moment hängt der in der falschen Version in der Luft.
