  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Tuya Steckdose offline - Alexa erreichbar
    5.1k
tuyatuya adaptersteckdoseoffline
60 Beiträge 4 Kommentatoren 6.3k Aufrufe 4 Beobachtet
  • M martin
    @ofbeqnpolkkl6mby5e13
      "type": "device",
      "common": {
        "name": "Lichterkette",
        "read": true
      "native": {
        "virtual": false,
        "dpName": {},
        "lon": "",
        "uuid": "62a8f9502ac83f45",
        "mac": "7cf666e9a50e",
        "iconUrl": "https://images.tuyaeu.com/smart/icon/001461896993159bfIWI/a56c46dd3528a344d88889e7db8730d3.png",
        "runtimeEnv": "prod",
        "lat": "",
        "devId": "bfbd7f165f11dacd8eyb0t",
        "devKey": "",
        "dpMaxTime": 1649260540243,
        "productId": "uvbhl96dsubgimll",
        "activeTime": 1649260511,
        "categoryCode": "wf_ble_cz",
        "moduleMap": {
          "wifi": {
            "upgradeStatus": 0,
            "cdv": "1.0.0",
            "bv": "40.00",
            "pv": "2.2",
            "verSw": "1.1.4",
            "isOnline": true,
            "id": 69742222,
            "cadv": "1.0.3"
          "mcu": {
            "upgradeStatus": 0,
            "cdv": "",
            "verSw": "1.1.4",
            "isOnline": true,
            "id": 69742221,
            "cadv": ""
        "devAttribute": 579,
        "timezoneId": "Europe/Berlin",
        "category": "cz",
        "localKey": "02fc513f01f67533",
        "schema": [
            "mode": "rw",
            "code": "switch_1",
            "name": "开关1",
            "property": {
              "type": "bool"
            "iconname": "icon-dp_power2",
            "id": 1,
            "type": "obj"
            "mode": "rw",
            "code": "countdown_1",
            "name": "开关1倒计时",
            "property": {
              "unit": "s",
              "min": 0,
              "max": 86400,
              "scale": 0,
              "step": 1,
              "type": "value"
            "iconname": "icon-dp_time2",
            "id": 9,
            "type": "obj"
            "mode": "ro",
            "code": "add_ele",
            "name": "增加电量",
            "property": {
              "min": 0,
              "max": 50000,
              "scale": 3,
              "step": 100,
              "type": "value"
            "id": 17,
            "type": "obj"
            "mode": "ro",
            "code": "cur_current",
            "name": "当前电流",
            "property": {
              "unit": "mA",
              "min": 0,
              "max": 30000,
              "scale": 0,
              "step": 1,
              "type": "value"
            "id": 18,
            "type": "obj"
            "mode": "ro",
            "code": "cur_power",
            "name": "当前功率采样",
            "property": {
              "unit": "W",
              "min": 0,
              "max": 80000,
              "scale": 1,
              "step": 1,
              "type": "value"
            "id": 19,
            "type": "obj"
            "mode": "ro",
            "code": "cur_voltage",
            "name": "当前电压采样",
            "property": {
              "unit": "V",
              "min": 0,
              "max": 5000,
              "scale": 1,
              "step": 1,
              "type": "value"
            "id": 20,
            "type": "obj"
            "mode": "ro",
            "code": "test_bit",
            "name": "产测结果位",
            "property": {
              "min": 0,
              "max": 5,
              "scale": 0,
              "step": 1,
              "type": "value"
            "id": 21,
            "type": "obj"
            "mode": "ro",
            "code": "voltage_coe",
            "name": "电压校准系数",
            "property": {
              "min": 0,
              "max": 1000000,
              "scale": 0,
              "step": 1,
              "type": "value"
            "id": 22,
            "type": "obj"
            "mode": "ro",
            "code": "electric_coe",
            "name": "电流校准系数",
            "property": {
              "min": 0,
              "max": 1000000,
              "scale": 0,
              "step": 1,
              "type": "value"
            "id": 23,
            "type": "obj"
            "mode": "ro",
            "code": "power_coe",
            "name": "功率校准系数",
            "property": {
              "min": 0,
              "max": 1000000,
              "scale": 0,
              "step": 1,
              "type": "value"
            "id": 24,
            "type": "obj"
            "mode": "ro",
            "code": "electricity_coe",
            "name": "电量校准系数",
            "property": {
              "min": 0,
              "max": 1000000,
              "scale": 0,
              "step": 1,
              "type": "value"
            "id": 25,
            "type": "obj"
            "mode": "ro",
            "code": "fault",
            "name": "故障告警",
            "property": {
              "label": [
                "ov_cr",
                "ov_vol",
                "ov_pwr",
                "ls_cr",
                "ls_vol",
                "ls_pow"
              "type": "bitmap",
              "maxlen": 6
            "id": 26,
            "type": "obj"
            "mode": "rw",
            "code": "relay_status",
            "name": "上电状态设置",
            "property": {
              "range": [
                "off",
                "on",
                "memory"
              "type": "enum"
            "iconname": "icon-zhuangtai",
            "id": 38,
            "type": "obj"
            "mode": "rw",
            "code": "light_mode",
            "name": "指示灯状态设置",
            "property": {
              "range": [
                "relay",
                "pos",
                "none",
                "on"
              "type": "enum"
            "iconname": "icon-dp_light",
            "id": 40,
            "type": "obj"
            "mode": "rw",
            "code": "child_lock",
            "name": "童锁开关",
            "property": {
              "type": "bool"
            "id": 41,
            "type": "obj"
            "mode": "rw",
            "code": "cycle_time",
            "name": "循环定时",
            "property": {
              "type": "string",
              "maxlen": 255
            "iconname": "icon-dp_time3",
            "id": 42,
            "type": "obj"
            "mode": "rw",
            "code": "random_time",
            "name": "随机定时",
            "property": {
              "type": "string",
              "maxlen": 255
            "id": 43,
            "type": "obj"
            "mode": "rw",
            "code": "switch_inching",
            "name": "点动开关参数",
            "property": {
              "type": "string",
              "maxlen": 255
            "id": 44,
            "type": "obj"
        "productKey": "keyjup78v54myhan",
        "schemaExt": [
            "complexType": "",
            "id": 1,
            "inputStyle": "",
            "inputType": "plain"
            "complexType": "",
            "id": 9,
            "inputStyle": "",
            "inputType": " "
            "complexType": "",
            "id": 38,
            "inputStyle": "",
            "inputType": " "
            "complexType": "",
            "id": 40,
            "inputStyle": "",
            "complexType": "",
            "id": 41,
            "inputStyle": "",
        "version": "3.3",
        "ip": "192.168.177.176",
        "gwId": "bfbd7f165f11dacd8eyb0t",
        "active": 2,
        "ablilty": 0,
        "encrypt": true
      "_id": "tuya.0.bfbd7f165f11dacd8eyb0t",
      "acl": {
        "object": 1636,
        "owner": "system.user.admin",
      "from": "system.adapter.tuya.0",
      "user": "system.user.admin",
      "ts": 1663839313274
    O Offline
    O Offline
    oFbEQnpoLKKl6mbY5e13
    @martin
    Soweit ich das beurteilen kann, sieht das i. O. aus.
    Die Firmwareversion ist aber eine andere als von dir weiter oben genannt. Spiel aber keine Rolle, da wir nicht wissen, ob sie vorher eine andere war.
    Und ich habe das richtig verstanden, dass genau diese zwei BSEED nicht mehr funktionieren und du keine weiteren Steckdosen des gleichen Modells hast, die noch funktionieren?
    • O oFbEQnpoLKKl6mbY5e13
      @martin
      martin
      Ja, genau diese beiden Bseed funktionieren nicht mehr über iobroker. Über Alexa und die SmartLife App kann ich sie noch bedienen. Andere Bseed Geräte habe ich nicht.
      Alle anderen installierten Tuya Geräte funktionieren tadellos.
      O 1 Antwort Letzte Antwort
      • M martin
        O Offline
        O Offline
        @martin
        Ich weiß nicht, ob man was über das Schema erreichen kann. Mal Entwickler fragen.
        @apollon77
        Zwei Steckdosen (Objektdaten siehe oben) des gleichen Modells funktionieren von einem auf den anderen Tag nicht mehr über den Tuya-Adapter. Alle anderen Tuya-Geräte funktionieren weiterhin. Die betroffenen Geräte werden als Offline eingestuft, obwohl sie vom iobroker-System zumindest per ping erreichbar sind.
        Geräte wurde schon mal stromlos gemacht. Keine Besserung.
        Hast du noch eine Idee, was man probieren kann? Schema ändern?
          @martin
          @apollon77
          @ofbeqnpolkkl6mby5e13 sagte in Tuya Steckdose offline - Alexa erreichbar:
          @martin
          @apollon77
          Ich hab das Problem mit meiner Doorbell, die ging von heut auf morgen nicht mehr, die Datenpunkte werden angelegt, aber der Tuya Adapter sagt unbekanntes Schema, und der Status ist auch immer auf false, obwohl in der App erreichbar und dort funktioinert auch alles. Hab se auch mehrmals neu angelernt, das funktioniert alles einwandfrei, aber anscheinend hat sich das bei Tuya selbst geaendert ... :-(
          @apollon77 arbeitet soweit ich weiss, an einem groesseren Update des Tuya-Adapters.. wird aber noch dauern..
          Bin auch gerade am ueberlegen, ob ich bis dahin den HAM installiere mit Web-Plugin..
          Kennt ihr uebrigens das hier: IPC Terminal ist aber nur fuer die Cameras nutzbar.
            @martin
            @apollon77
            O Offline
            O Offline
            @ilovegym sagte in Tuya Steckdose offline - Alexa erreichbar:
            Ich nutze sowohl den Tuya-Adapter als auch den HAM-Adapter. Das Problem mit allen Tuya-Web-Plugins ist, dass sie bei weitem nicht so viele Schemen bieten, wie sie der Tuya-Adapter in den Jahren gesammelt hat. Das hat leider die Auswirkung, dass man meist nur ein- und ausschalten kann.
            Ich überlege, ob ich zu Tasmota wechsel...
            ? apollon77A 2 Antworten Letzte Antwort
              @ofbeqnpolkkl6mby5e13 also wenn da n esp drin ist, dann nix wie tasmota drauf.. dann hast du Ruhe.
                O Offline
                O Offline
                @ilovegym
                Die meisten sollten per ota zu flashen sein. Ich habe aber 4 Flächenleuchten, bei denen ich nicht weiß, ob die von Tasmota in allen Funktionen unterstütz werden. Das Hauptproblem ist jedoch die fehlende App ohne VPN-Zugang.
                • M martin
                  Hallo zusammen!
                  Ich habe das Problem, dass bei mir 2 Tuya Steckdosen seit ein paar Tagen offline sind und von iobroker nicht mehr gesteuert werden können.
                  Über Alexa und die App kann ich sie aber steuern.
                  Habe jetzt schon mal über Proxy aktualisiert, aber da passiert auch nichts.
                  Wie kriege ich die im Tuya Adapter wieder online?
                  @martin So .. was sagt denn das Log wenn du mal Debug Log aktivierst ... weil das Log hier zeigt keine Fehler bei den beiden genannten Steckdosen.
                  (Und das "große Update) hat nur mit dem Proxy bzw Linking Prozess was zu tun, sonst mit nix. Also wenn die Geräte mal drin sind sollten Sie gehen
                    @ofbeqnpolkkl6mby5e13 Meine "neue Cloud Implementierung" wird auch Schemas au der Cloud abfragen :-)
                    • apollon77A apollon77
                      O Offline
                      O Offline
                      @apollon77
                      Das klingt sehr vielversprechend! Und Batteriegeräte können so auch verwendet werden!
                      Da ich im Moment keine ernsthaften Probleme mit dem Tuya-Adapter habe, werde ich noch warten.
                      Wenn du einen Tester mit vielen Geräten brauchst, weiß du ja, wo du mich findest... 😬
                        @apollon77
                        Sorry aber Nein!. Wie gesagt betrifft das ausschliesslich das Linking! Ich habe in der Cloud Doku nochnichts gefunden wie man an die Werte der Geräte rankäme .. vllt find ichs noch.
                          martin
                          @apollon77
                          tuya.0
                          Zeit
                          debug
                          Nachricht
                          tuya.0
                          2022-09-23 11:41:52.183	warn	71131573c44f33b9ae4c: Error on Reconnectconnect EHOSTUNREACH 192.168.177.123:6668
                          tuya.0
                          2022-09-23 11:41:52.134	warn	bf9585629c6547f571qjqn: Error on Reconnectconnect EHOSTUNREACH 192.168.177.156:6668
                          tuya.0
                          2022-09-23 11:41:52.124	warn	711315732462ab419b76: Error on Reconnectconnect EHOSTUNREACH 192.168.177.122:6668
                          tuya.0
                          2022-09-23 11:41:52.122	warn	01200229600194538c88: Error on Reconnectconnect EHOSTUNREACH 192.168.177.82:6668
                          tuya.0
                          2022-09-23 11:41:52.120	warn	250710602cf432a253ce: Error on Reconnectconnect EHOSTUNREACH 192.168.177.127:6668
                          tuya.0
                          2022-09-23 11:41:52.099	warn	711315732462ab41fd42: Error on Reconnectconnect EHOSTUNREACH 192.168.177.124:6668
                          tuya.0
                          2022-09-23 11:41:52.096	warn	04200408b4e62d192311: Error on Reconnectconnect EHOSTUNREACH 192.168.177.83:6668
                          tuya.0
                          2022-09-23 11:41:52.091	warn	02200513dc4f2219ad01: Error on Reconnectconnect EHOSTUNREACH 192.168.177.88:6668
                          tuya.0
                          2022-09-23 11:41:19.127	error	71131573c44f33b9ae4c: connect EHOSTUNREACH 192.168.177.123:6668
                          tuya.0
                          2022-09-23 11:41:19.039	error	711315732462ab419b76: connect EHOSTUNREACH 192.168.177.122:6668
                          tuya.0
                          2022-09-23 11:41:19.036	error	bf9585629c6547f571qjqn: connect EHOSTUNREACH 192.168.177.156:6668
                          tuya.0
                          2022-09-23 11:41:19.033	error	250710602cf432a253ce: connect EHOSTUNREACH 192.168.177.127:6668
                          tuya.0
                          2022-09-23 11:41:19.031	error	01200229600194538c88: connect EHOSTUNREACH 192.168.177.82:6668
                          tuya.0
                          2022-09-23 11:41:19.009	error	02200513dc4f2219ad01: connect EHOSTUNREACH 192.168.177.88:6668
                          tuya.0
                          2022-09-23 11:41:19.002	error	04200408b4e62d192311: connect EHOSTUNREACH 192.168.177.83:6668
                          tuya.0
                          2022-09-23 11:41:18.978	error	711315732462ab41fd42: connect EHOSTUNREACH 192.168.177.124:6668
                          tuya.0
                          2022-09-23 11:41:16.075	info	Listen for encrypted local Tuya devices on port 6667
                          tuya.0
                          2022-09-23 11:41:16.074	info	Listen for local Tuya devices on port 6666
                          tuya.0
                          2022-09-23 11:41:16.066	info	Existing devices initialized
                          tuya.0
                          2022-09-23 11:41:16.063	info	71131573c44f33b9ae4c Init with IP=192.168.177.123, Key=1b09e5a634d314e4, Version=3.3
                          tuya.0
                          2022-09-23 11:41:15.991	info	25071060c44f33a64b64 Init with IP=192.168.177.20, Key=073ecce2a61c3436, Version=3.3
                          tuya.0
                          2022-09-23 11:41:15.968	info	01200229600194538c88 Init with IP=192.168.177.82, Key=48c20967b7dd1bd3, Version=3.1
                          tuya.0
                          2022-09-23 11:41:15.966	info	250710602cf432a253ce Init with IP=192.168.177.127, Key=4304f000bb61aa08, Version=3.3
                          tuya.0
                          2022-09-23 11:41:15.964	info	bf9585629c6547f571qjqn Init with IP=192.168.177.156, Key=5190be1aca9a2914, Version=3.3
                          tuya.0
                          2022-09-23 11:41:15.954	info	711315732462ab419b76 Init with IP=192.168.177.122, Key=ced061f48b491d45, Version=3.3
                          tuya.0
                          2022-09-23 11:41:15.932	info	04200408b4e62d192311 Init with IP=192.168.177.83, Key=8d1cc9f308d0b281, Version=3.1
                          tuya.0
                          2022-09-23 11:41:15.928	info	bf06509ab67fb98f01zuzt Init with IP=192.168.177.175, Key=c69e56e0c054d79d, Version=3.3
                          tuya.0
                          2022-09-23 11:41:15.926	info	02200513dc4f2219ad01 Init with IP=192.168.177.88, Key=0a2a37818be809b2, Version=3.1
                          tuya.0
                          2022-09-23 11:41:15.910	info	711315732462ab41fd42 Init with IP=192.168.177.124, Key=53ee13dd52c9c8fa, Version=3.3
                          tuya.0
                          2022-09-23 11:41:15.907	info	38325110cc50e3262c9d Init with IP=192.168.177.92, Key=a9e51fa781f87443, Version=3.1
                          tuya.0
                          2022-09-23 11:41:15.897	info	38325110cc50e3d44d56 Init with IP=192.168.177.91, Key=e69a8c527d07591d, Version=3.1
                          tuya.0
                          2022-09-23 11:41:15.852	info	71131573c44f33b9aab6 Init with IP=192.168.177.136, Key=6b5c1bd579ef3e85, Version=3.3
                          tuya.0
                          2022-09-23 11:41:15.845	info	bfbd7f165f11dacd8eyb0t Init with IP=192.168.177.176, Key=02fc513f01f67533, Version=3.3
                          tuya.0
                          2022-09-23 11:41:15.792	info	02200513dc4f22191527 Init with IP=192.168.177.87, Key=20eee215bc384b55, Version=3.1
                          tuya.0
                          2022-09-23 11:41:13.848	info	starting. Version 3.6.15 in /opt/iobroker/node_modules/iobroker.tuya, node: v16.17.0, js-controller: 4.0.23
                          tuya.0
                          2022-09-23 11:41:00.509	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          tuya.0
                          2022-09-23 11:41:00.506	info	terminating
                          tuya.0
                          2022-09-23 11:40:57.497	info	Got terminate signal TERMINATE_YOURSELF
                          • M martin
                            @apollon77
                            tuya.0
                            Zeit
                            debug
                            Nachricht
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            tuya.0
                            @martin Da sist kein Debug log :-)
                            Instanzen - Expertenmodus - tuya.0 aufklappen - Loglevel auf debug setzen - Adapter startet neu
                              martin
                              @apollon77
                              tuya.0
                              2022-09-23 11:44:59.876	error	04200408b4e62d192311: connect EHOSTUNREACH 192.168.177.83:6668
                              tuya.0
                              2022-09-23 11:44:59.875	debug	04200408b4e62d192311: Error from device (0): App still open on your mobile phone? Error: Error from socket: connect EHOSTUNREACH 192.168.177.83:6668
                              tuya.0
                              2022-09-23 11:44:59.873	error	711315732462ab419b76: connect EHOSTUNREACH 192.168.177.122:6668
                              tuya.0
                              2022-09-23 11:44:59.872	debug	711315732462ab419b76: Error from device (0): App still open on your mobile phone? Error: Error from socket: connect EHOSTUNREACH 192.168.177.122:6668
                              tuya.0
                              2022-09-23 11:44:59.869	error	71131573c44f33b9ae4c: connect EHOSTUNREACH 192.168.177.123:6668
                              tuya.0
                              2022-09-23 11:44:59.867	debug	71131573c44f33b9ae4c: Error from device (0): App still open on your mobile phone? Error: Error from socket: connect EHOSTUNREACH 192.168.177.123:6668
                              tuya.0
                              2022-09-23 11:44:59.672	error	711315732462ab41fd42: connect EHOSTUNREACH 192.168.177.124:6668
                              tuya.0
                              2022-09-23 11:44:59.671	debug	711315732462ab41fd42: Error from device (0): App still open on your mobile phone? Error: Error from socket: connect EHOSTUNREACH 192.168.177.124:6668
                              tuya.0
                              2022-09-23 11:44:59.644	error	bf9585629c6547f571qjqn: connect EHOSTUNREACH 192.168.177.156:6668
                              tuya.0
                              2022-09-23 11:44:59.639	debug	bf9585629c6547f571qjqn: Error from device (0): App still open on your mobile phone? Error: Error from socket: connect EHOSTUNREACH 192.168.177.156:6668
                              tuya.0
                              2022-09-23 11:44:59.622	error	250710602cf432a253ce: connect EHOSTUNREACH 192.168.177.127:6668
                              tuya.0
                              2022-09-23 11:44:59.621	debug	250710602cf432a253ce: Error from device (0): App still open on your mobile phone? Error: Error from socket: connect EHOSTUNREACH 192.168.177.127:6668
                              tuya.0
                              2022-09-23 11:44:59.620	error	01200229600194538c88: connect EHOSTUNREACH 192.168.177.82:6668
                              tuya.0
                              2022-09-23 11:44:59.618	debug	01200229600194538c88: Error from device (0): App still open on your mobile phone? Error: Error from socket: connect EHOSTUNREACH 192.168.177.82:6668
                              tuya.0
                              2022-09-23 11:44:59.615	error	02200513dc4f2219ad01: connect EHOSTUNREACH 192.168.177.88:6668
                              tuya.0
                              2022-09-23 11:44:59.614	debug	02200513dc4f2219ad01: Error from device (0): App still open on your mobile phone? Error: Error from socket: connect EHOSTUNREACH 192.168.177.88:6668
                              tuya.0
                              2022-09-23 11:44:59.129	debug	Discovered encrypted device and store for later usage: 192.168.177.175:59727 - 000055aa0000000000000023000000bc00000000d09766676f3369eb10b5e9f132fd802a767b83ba80a047aaee7a02ef36fcd666e9fa5892fbceb90adaa9167784a9522630a5251fa07caf847e6f65edcfed6509c2d91fea632b8557eb918162c1fc96744dc7fe823e307927fb0a44b0dfae2c8da2a472bd72b20e15e0f77b889f46b89a20780716567ce38ac1d583e9669fe8f07d7e79a6dfb57c0a4c8708d6f9ab77bf7e7bc2b0475ba61eee07a4dbd5d12ada69b0f3f78df370eb711c32ea7ae2d9a2121be6d60000aa55
                              tuya.0
                              2022-09-23 11:44:58.189	debug	stateChange tuya.0.38325110cc50e3d44d56.6 {"val":237.8,"ack":true,"ts":1663926297548,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1663926149062}
                              tuya.0
                              2022-09-23 11:44:58.182	debug	stateChange tuya.0.38325110cc50e3d44d56.5 {"val":14.8,"ack":true,"ts":1663926297548,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1663926297548}
                              tuya.0
                              2022-09-23 11:44:58.174	debug	stateChange tuya.0.38325110cc50e3d44d56.4 {"val":62,"ack":true,"ts":1663926297548,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1663926297548}
                              tuya.0
                              2022-09-23 11:44:58.168	debug	stateChange tuya.0.38325110cc50e3d44d56.2 {"val":0,"ack":true,"ts":1663926297548,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1545412634808}
                              tuya.0
                              2022-09-23 11:44:58.160	debug	stateChange tuya.0.38325110cc50e3d44d56.1 {"val":true,"ack":true,"ts":1663926297498,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1561195827799}
                              tuya.0
                              2022-09-23 11:44:57.912	debug	Discovered encrypted device and store for later usage: 192.168.177.176:59727 - 000055aa0000000000000023000000bc00000000d09766676f3369eb10b5e9f132fd802ae02534f66108d24bdd343bddcd92bb1a47d7a0e537c6da23a8abef35f281306dffa491b5b8fa1918f7d3db38bdb8b4afc2d91fea632b8557eb918162c1fc96744dc7fe823e307927fb0a44b0dfae2c8da2a472bd72b20e15e0f77b889f46b89a20780716567ce38ac1d583e9669fe8f07d7e79a6dfb57c0a4c8708d6f9ab77bf7e7bc2b0475ba61eee07a4dbd5d12ada69b0f3f78df370eb711c32ea7ae2d9a2c6a9bd5d0000aa55
                              tuya.0
                              2022-09-23 11:44:57.555	debug	stateChange tuya.0.38325110cc50e3d44d56.online {"val":true,"ack":true,"ts":1663926297105,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1663926297105}
                              tuya.0
                              2022-09-23 11:44:57.546	debug	stateChange tuya.0.bfbd7f165f11dacd8eyb0t.online {"val":false,"ack":true,"ts":1663926297104,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1663926297104}
                              tuya.0
                              2022-09-23 11:44:57.537	debug	stateChange tuya.0.02200513dc4f22191527.6 {"val":226.1,"ack":true,"ts":1663926297101,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1650008637273}
                              tuya.0
                              2022-09-23 11:44:57.529	debug	stateChange tuya.0.02200513dc4f22191527.5 {"val":294.9,"ack":true,"ts":1663926297101,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1650008633295}
                              tuya.0
                              2022-09-23 11:44:57.521	debug	stateChange tuya.0.02200513dc4f22191527.4 {"val":1300,"ack":true,"ts":1663926297101,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1650008629293}
                              tuya.0
                              2022-09-23 11:44:57.512	debug	stateChange tuya.0.02200513dc4f22191527.2 {"val":0,"ack":true,"ts":1663926297101,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1545074369778}
                              tuya.0
                              2022-09-23 11:44:57.505	debug	stateChange tuya.0.02200513dc4f22191527.1 {"val":true,"ack":true,"ts":1663926297100,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1545075750169}
                              tuya.0
                              2022-09-23 11:44:57.102	debug	stateChange tuya.0.02200513dc4f22191527.online {"val":true,"ack":true,"ts":1663926296854,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1663926296854}
                              tuya.0
                              2022-09-23 11:44:57.097	debug	stateChange tuya.0.bf06509ab67fb98f01zuzt.online {"val":false,"ack":true,"ts":1663926296854,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1663926296854}
                              tuya.0
                              2022-09-23 11:44:56.858	debug	stateChange tuya.0.bfbd7f165f11dacd8eyb0t.online {"val":true,"ack":true,"ts":1663926296797,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1663926296797}
                              tuya.0
                              2022-09-23 11:44:56.855	debug	stateChange tuya.0.71131573c44f33b9aab6.7 {"val":false,"ack":true,"ts":1663926296796,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1600796446236}
                              tuya.0
                              2022-09-23 11:44:56.837	debug	38325110cc50e3d44d56: Received data: {"1":true,"2":0,"4":62,"5":148,"6":2378}
                              tuya.0
                              2022-09-23 11:44:56.823	debug	38325110cc50e3d44d56: Connected to device
                              tuya.0
                              2022-09-23 11:44:56.820	debug	bfbd7f165f11dacd8eyb0t: Disconnected from device
                              tuya.0
                              2022-09-23 11:44:56.819	info	Listen for encrypted local Tuya devices on port 6667
                              tuya.0
                              2022-09-23 11:44:56.817	info	Listen for local Tuya devices on port 6666
                              tuya.0
                              2022-09-23 11:44:56.809	info	Existing devices initialized
                              tuya.0
                              2022-09-23 11:44:56.807	info	38325110cc50e3d44d56 Init with IP=192.168.177.91, Key=e69a8c527d07591d, Version=3.1
                              tuya.0
                              2022-09-23 11:44:56.806	info	71131573c44f33b9ae4c Init with IP=192.168.177.123, Key=1b09e5a634d314e4, Version=3.3
                              tuya.0
                              2022-09-23 11:44:56.798	info	711315732462ab419b76 Init with IP=192.168.177.122, Key=ced061f48b491d45, Version=3.3
                              tuya.0
                              2022-09-23 11:44:56.789	info	04200408b4e62d192311 Init with IP=192.168.177.83, Key=8d1cc9f308d0b281, Version=3.1
                              tuya.0
                              2022-09-23 11:44:56.768	debug	02200513dc4f22191527: Received data: {"1":true,"2":0,"4":1300,"5":2949,"6":2261}
                              tuya.0
                              2022-09-23 11:44:56.723	debug	02200513dc4f22191527: Connected to device
                              tuya.0
                              2022-09-23 11:44:56.715	debug	bf06509ab67fb98f01zuzt: Disconnected from device
                              tuya.0
                              2022-09-23 11:44:56.668	debug	bfbd7f165f11dacd8eyb0t: Connected to device
                              tuya.0
                              2022-09-23 11:44:56.658	debug	71131573c44f33b9aab6: Received data: {"1":false,"2":0,"4":0,"5":0,"6":2302,"7":false}
                              tuya.0
                              2022-09-23 11:44:56.616	debug	connected set to true
                              tuya.0
                              2022-09-23 11:44:56.594	info	711315732462ab41fd42 Init with IP=192.168.177.124, Key=53ee13dd52c9c8fa, Version=3.3
                              tuya.0
                              2022-09-23 11:44:56.568	debug	38325110cc50e3262c9d: Received data: {"1":false,"2":0,"4":0,"5":0,"6":2337}
                              tuya.0
                              2022-09-23 11:44:56.560	info	bf9585629c6547f571qjqn Init with IP=192.168.177.156, Key=5190be1aca9a2914, Version=3.3
                              tuya.0
                              2022-09-23 11:44:56.552	info	bfbd7f165f11dacd8eyb0t Init with IP=192.168.177.176, Key=02fc513f01f67533, Version=3.3
                              tuya.0
                              2022-09-23 11:44:56.550	info	02200513dc4f2219ad01 Init with IP=192.168.177.88, Key=0a2a37818be809b2, Version=3.1
                              tuya.0
                              2022-09-23 11:44:56.548	info	01200229600194538c88 Init with IP=192.168.177.82, Key=48c20967b7dd1bd3, Version=3.1
                              tuya.0
                              2022-09-23 11:44:56.546	debug	bf06509ab67fb98f01zuzt: Connected to device
                              tuya.0
                              2022-09-23 11:44:56.543	debug	71131573c44f33b9aab6: Connected to device
                              tuya.0
                              2022-09-23 11:44:56.540	debug	38325110cc50e3262c9d: Connected to device
                              tuya.0
                              2022-09-23 11:44:56.530	info	250710602cf432a253ce Init with IP=192.168.177.127, Key=4304f000bb61aa08, Version=3.3
                              tuya.0
                              2022-09-23 11:44:56.527	info	02200513dc4f22191527 Init with IP=192.168.177.87, Key=20eee215bc384b55, Version=3.1
                              tuya.0
                              2022-09-23 11:44:56.468	info	71131573c44f33b9aab6 Init with IP=192.168.177.136, Key=6b5c1bd579ef3e85, Version=3.3
                              tuya.0
                              2022-09-23 11:44:56.443	info	38325110cc50e3262c9d Init with IP=192.168.177.92, Key=a9e51fa781f87443, Version=3.1
                              tuya.0
                              2022-09-23 11:44:56.429	info	bf06509ab67fb98f01zuzt Init with IP=192.168.177.175, Key=c69e56e0c054d79d, Version=3.3
                              tuya.0
                              2022-09-23 11:44:56.208	debug	25071060c44f33a64b64: Received data: {"1":false,"9":0,"18":0,"19":0,"20":2387,"21":1,"22":765,"23":33064,"24":23488,"25":890}
                              tuya.0
                              2022-09-23 11:44:56.163	debug	25071060c44f33a64b64: Connected to device
                              tuya.0
                              2022-09-23 11:44:56.120	info	25071060c44f33a64b64 Init with IP=192.168.177.20, Key=073ecce2a61c3436, Version=3.3
                              tuya.0
                              2022-09-23 11:44:49.512	debug	connected set to false
                              tuya.0
                              2022-09-23 11:44:49.478	debug	bf06509ab67fb98f01zuzt Register onChange for 44
                              tuya.0
                              2022-09-23 11:44:49.477	debug	bf06509ab67fb98f01zuzt Register onChange for 43
                              tuya.0
                              2022-09-23 11:44:49.476	debug	bf06509ab67fb98f01zuzt Register onChange for 42
                              tuya.0
                              2022-09-23 11:44:49.476	debug	bf06509ab67fb98f01zuzt Register onChange for 41
                              tuya.0
                              2022-09-23 11:44:49.475	debug	bf06509ab67fb98f01zuzt Register onChange for 40
                              tuya.0
                              2022-09-23 11:44:49.474	debug	bf06509ab67fb98f01zuzt Register onChange for 38
                              tuya.0
                              2022-09-23 11:44:49.472	debug	bf06509ab67fb98f01zuzt Register onChange for 9
                              tuya.0
                              2022-09-23 11:44:49.472	debug	bf06509ab67fb98f01zuzt Register onChange for 1
                              tuya.0
                              2022-09-23 11:44:49.471	debug	bf06509ab67fb98f01zuzt: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_1","id":1,"role":"switch"},{"type":"number","unit":"s","max":86400,"read":true,"write":true,"name":"countdown_1","id":9,"role":"level"},{"type":"number","max":50000,"scale":3,"read":true,"write":false,"name":"add_ele","id":17,"role":"value"},{"type":"number","unit":"mA","max":30000,"read":true,"write":false,"name":"cur_current","id":18,"role":"value"},{"type":"number","unit":"W","max":80000,"scale":1,"read":true,"write":false,"name":"cur_power","id":19,"role":"value"},{"type":"number","unit":"V","max":5000,"scale":1,"read":true,"write":false,"name":"cur_voltage","id":20,"role":"value"},{"type":"number","max":5,"read":true,"write":false,"name":"test_bit","id":21,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"voltage_coe","id":22,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"electric_coe","id":23,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"power_coe","id":24,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"electricity_coe","id":25,"role":"value"},{"type":"number","read":true,"write":false,"name":"fault","id":26,"role":"value"},{"type":"number","states":{"0":"off","1":"on","2":"memory"},"read":true,"write":true,"name":"relay_status","id":38,"role":"level"},{"type":"number","states":{"0":"relay","1":"pos","2":"none","3":"on"},"read":true,"write":true,"name":"light_mode","id":40,"role":"level"},{"type":"boolean","read":true,"write":true,"name":"child_lock","id":41,"role":"switch"},{"type":"string","read":true,"write":true,"name":"cycle_time","id":42,"role":"text"},{"type":"string","read":true,"write":true,"name":"random_time","id":43,"role":"text"},{"type":"string","read":true,"write":true,"name":"switch_inching","id":44,"role":"text"}]
                              tuya.0
                              2022-09-23 11:44:49.469	debug	bf06509ab67fb98f01zuzt: Create device objects if not exist
                              tuya.0
                              2022-09-23 11:44:49.466	debug	bfbd7f165f11dacd8eyb0t Register onChange for 44
                              tuya.0
                              2022-09-23 11:44:49.465	debug	bfbd7f165f11dacd8eyb0t Register onChange for 43
                              tuya.0
                              2022-09-23 11:44:49.465	debug	bfbd7f165f11dacd8eyb0t Register onChange for 42
                              tuya.0
                              2022-09-23 11:44:49.464	debug	bfbd7f165f11dacd8eyb0t Register onChange for 41
                              tuya.0
                              2022-09-23 11:44:49.463	debug	bfbd7f165f11dacd8eyb0t Register onChange for 40
                              tuya.0
                              2022-09-23 11:44:49.462	debug	bfbd7f165f11dacd8eyb0t Register onChange for 38
                              tuya.0
                              2022-09-23 11:44:49.461	debug	bfbd7f165f11dacd8eyb0t Register onChange for 9
                              tuya.0
                              2022-09-23 11:44:49.460	debug	bfbd7f165f11dacd8eyb0t Register onChange for 1
                              tuya.0
                              2022-09-23 11:44:49.459	debug	bfbd7f165f11dacd8eyb0t: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_1","id":1,"role":"switch"},{"type":"number","unit":"s","max":86400,"read":true,"write":true,"name":"countdown_1","id":9,"role":"level"},{"type":"number","max":50000,"scale":3,"read":true,"write":false,"name":"add_ele","id":17,"role":"value"},{"type":"number","unit":"mA","max":30000,"read":true,"write":false,"name":"cur_current","id":18,"role":"value"},{"type":"number","unit":"W","max":80000,"scale":1,"read":true,"write":false,"name":"cur_power","id":19,"role":"value"},{"type":"number","unit":"V","max":5000,"scale":1,"read":true,"write":false,"name":"cur_voltage","id":20,"role":"value"},{"type":"number","max":5,"read":true,"write":false,"name":"test_bit","id":21,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"voltage_coe","id":22,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"electric_coe","id":23,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"power_coe","id":24,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"electricity_coe","id":25,"role":"value"},{"type":"number","read":true,"write":false,"name":"fault","id":26,"role":"value"},{"type":"number","states":{"0":"off","1":"on","2":"memory"},"read":true,"write":true,"name":"relay_status","id":38,"role":"level"},{"type":"number","states":{"0":"relay","1":"pos","2":"none","3":"on"},"read":true,"write":true,"name":"light_mode","id":40,"role":"level"},{"type":"boolean","read":true,"write":true,"name":"child_lock","id":41,"role":"switch"},{"type":"string","read":true,"write":true,"name":"cycle_time","id":42,"role":"text"},{"type":"string","read":true,"write":true,"name":"random_time","id":43,"role":"text"},{"type":"string","read":true,"write":true,"name":"switch_inching","id":44,"role":"text"}]
                              tuya.0
                              2022-09-23 11:44:49.458	debug	bfbd7f165f11dacd8eyb0t: Create device objects if not exist
                              tuya.0
                              2022-09-23 11:44:49.456	debug	bf9585629c6547f571qjqn Register onChange for 44
                              tuya.0
                              2022-09-23 11:44:49.455	debug	bf9585629c6547f571qjqn Register onChange for 43
                              tuya.0
                              2022-09-23 11:44:49.454	debug	bf9585629c6547f571qjqn Register onChange for 42
                              tuya.0
                              2022-09-23 11:44:49.454	debug	bf9585629c6547f571qjqn Register onChange for 41
                              tuya.0
                              2022-09-23 11:44:49.453	debug	bf9585629c6547f571qjqn Register onChange for 40
                              tuya.0
                              2022-09-23 11:44:49.451	debug	bf9585629c6547f571qjqn Register onChange for 39
                              tuya.0
                              2022-09-23 11:44:49.451	debug	bf9585629c6547f571qjqn Register onChange for 9
                              tuya.0
                              2022-09-23 11:44:49.450	debug	bf9585629c6547f571qjqn Register onChange for 1
                              tuya.0
                              2022-09-23 11:44:49.449	debug	bf9585629c6547f571qjqn: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_1","id":1,"role":"switch"},{"type":"number","unit":"s","max":86400,"read":true,"write":true,"name":"countdown_1","id":9,"role":"level"},{"type":"number","states":{"0":"0","1":"1","2":"2"},"read":true,"write":true,"name":"relay_status","id":39,"role":"level"},{"type":"number","states":{"0":"relay","1":"pos","2":"none"},"read":true,"write":true,"name":"light_mode","id":40,"role":"level"},{"type":"boolean","read":true,"write":true,"name":"child_lock","id":41,"role":"switch"},{"type":"string","read":true,"write":true,"name":"cycle_time","id":42,"role":"text"},{"type":"string","read":true,"write":true,"name":"random_time","id":43,"role":"text"},{"type":"string","read":true,"write":true,"name":"switch_inching","id":44,"role":"text"}]
                              tuya.0
                              2022-09-23 11:44:49.447	debug	bf9585629c6547f571qjqn: Create device objects if not exist
                              tuya.0
                              2022-09-23 11:44:49.445	debug	71131573c44f33b9aab6 Register onChange for 2
                              tuya.0
                              2022-09-23 11:44:49.444	debug	71131573c44f33b9aab6 Register onChange for 1
                              tuya.0
                              2022-09-23 11:44:49.444	debug	71131573c44f33b9aab6: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_on","id":1,"role":"switch"},{"type":"number","unit":"秒","max":86400,"read":true,"write":true,"name":"countdown","id":2,"role":"level"},{"type":"number","unit":"度","max":500000,"scale":3,"read":true,"write":false,"name":"add_ele","id":3,"role":"value"},{"type":"number","unit":"mA","max":30000,"read":true,"write":false,"name":"cur_current","id":4,"role":"value"},{"type":"number","unit":"W","max":50000,"scale":1,"read":true,"write":false,"name":"cur_power","id":5,"role":"value"},{"type":"number","unit":"V","max":2500,"scale":1,"read":true,"write":false,"name":"cur_voltage","id":6,"role":"value"},{"type":"boolean","unit":"当电流处于16.3A和18A之间时,预警,20秒后关闭电源","read":true,"write":false,"name":"over_current_alarm","id":7,"role":"sensor"}]
                              tuya.0
                              2022-09-23 11:44:49.442	debug	71131573c44f33b9aab6: Create device objects if not exist
                              tuya.0
                              2022-09-23 11:44:49.440	debug	711315732462ab419b76 Register onChange for 2
                              tuya.0
                              2022-09-23 11:44:49.440	debug	711315732462ab419b76 Register onChange for 1
                              tuya.0
                              2022-09-23 11:44:49.439	debug	711315732462ab419b76: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_on","id":1,"role":"switch"},{"type":"number","unit":"秒","max":86400,"read":true,"write":true,"name":"countdown","id":2,"role":"level"},{"type":"number","unit":"度","max":500000,"scale":3,"read":true,"write":false,"name":"add_ele","id":3,"role":"value"},{"type":"number","unit":"mA","max":30000,"read":true,"write":false,"name":"cur_current","id":4,"role":"value"},{"type":"number","unit":"W","max":50000,"scale":1,"read":true,"write":false,"name":"cur_power","id":5,"role":"value"},{"type":"number","unit":"V","max":2500,"scale":1,"read":true,"write":false,"name":"cur_voltage","id":6,"role":"value"},{"type":"boolean","unit":"当电流处于16.3A和18A之间时,预警,20秒后关闭电源","read":true,"write":false,"name":"over_current_alarm","id":7,"role":"sensor"}]
                              tuya.0
                              2022-09-23 11:44:49.438	debug	711315732462ab419b76: Create device objects if not exist
                              tuya.0
                              2022-09-23 11:44:49.436	debug	71131573c44f33b9ae4c Register onChange for 2
                              tuya.0
                              2022-09-23 11:44:49.435	debug	71131573c44f33b9ae4c Register onChange for 1
                              tuya.0
                              2022-09-23 11:44:49.434	debug	71131573c44f33b9ae4c: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_on","id":1,"role":"switch"},{"type":"number","unit":"秒","max":86400,"read":true,"write":true,"name":"countdown","id":2,"role":"level"},{"type":"number","unit":"度","max":500000,"scale":3,"read":true,"write":false,"name":"add_ele","id":3,"role":"value"},{"type":"number","unit":"mA","max":30000,"read":true,"write":false,"name":"cur_current","id":4,"role":"value"},{"type":"number","unit":"W","max":50000,"scale":1,"read":true,"write":false,"name":"cur_power","id":5,"role":"value"},{"type":"number","unit":"V","max":2500,"scale":1,"read":true,"write":false,"name":"cur_voltage","id":6,"role":"value"},{"type":"boolean","unit":"当电流处于16.3A和18A之间时,预警,20秒后关闭电源","read":true,"write":false,"name":"over_current_alarm","id":7,"role":"sensor"}]
                              tuya.0
                              2022-09-23 11:44:49.433	debug	71131573c44f33b9ae4c: Create device objects if not exist
                              tuya.0
                              2022-09-23 11:44:49.430	debug	711315732462ab41fd42 Register onChange for 2
                              tuya.0
                              2022-09-23 11:44:49.429	debug	711315732462ab41fd42 Register onChange for 1
                              tuya.0
                              2022-09-23 11:44:49.428	debug	711315732462ab41fd42: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_on","id":1,"role":"switch"},{"type":"number","unit":"秒","max":86400,"read":true,"write":true,"name":"countdown","id":2,"role":"level"},{"type":"number","unit":"度","max":500000,"scale":3,"read":true,"write":false,"name":"add_ele","id":3,"role":"value"},{"type":"number","unit":"mA","max":30000,"read":true,"write":false,"name":"cur_current","id":4,"role":"value"},{"type":"number","unit":"W","max":50000,"scale":1,"read":true,"write":false,"name":"cur_power","id":5,"role":"value"},{"type":"number","unit":"V","max":2500,"scale":1,"read":true,"write":false,"name":"cur_voltage","id":6,"role":"value"},{"type":"boolean","unit":"当电流处于16.3A和18A之间时,预警,20秒后关闭电源","read":true,"write":false,"name":"over_current_alarm","id":7,"role":"sensor"}]
                              tuya.0
                              2022-09-23 11:44:49.427	debug	711315732462ab41fd42: Create device objects if not exist
                              tuya.0
                              2022-09-23 11:44:49.425	debug	25071060c44f33a64b64 Register onChange for 17
                              tuya.0
                              2022-09-23 11:44:49.424	debug	25071060c44f33a64b64 Register onChange for 9
                              tuya.0
                              2022-09-23 11:44:49.423	debug	25071060c44f33a64b64 Register onChange for 1
                              tuya.0
                              2022-09-23 11:44:49.422	debug	25071060c44f33a64b64: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_1","id":1,"role":"switch"},{"type":"number","unit":"s","max":86400,"read":true,"write":true,"name":"countdown_1","id":9,"role":"level"},{"type":"number","max":50000,"scale":3,"read":true,"write":true,"name":"add_ele","id":17,"role":"level"},{"type":"number","unit":"mA","max":30000,"read":true,"write":false,"name":"cur_current","id":18,"role":"value"},{"type":"number","unit":"W","max":50000,"scale":1,"read":true,"write":false,"name":"cur_power","id":19,"role":"value"},{"type":"number","unit":"V","max":5000,"scale":1,"read":true,"write":false,"name":"cur_voltage","id":20,"role":"value"},{"type":"number","max":5,"read":true,"write":false,"name":"test_bit","id":21,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"voltage_coe","id":22,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"electric_coe","id":23,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"power_coe","id":24,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"electricity_coe","id":25,"role":"value"},{"type":"number","unit":"ov_cr:过流保护","read":true,"write":false,"name":"fault","id":26,"role":"value"}]
                              tuya.0
                              2022-09-23 11:44:49.420	debug	25071060c44f33a64b64: Create device objects if not exist
                              tuya.0
                              2022-09-23 11:44:49.418	debug	250710602cf432a253ce Register onChange for 17
                              tuya.0
                              2022-09-23 11:44:49.417	debug	250710602cf432a253ce Register onChange for 9
                              tuya.0
                              2022-09-23 11:44:49.416	debug	250710602cf432a253ce Register onChange for 1
                              tuya.0
                              2022-09-23 11:44:49.415	debug	250710602cf432a253ce: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_1","id":1,"role":"switch"},{"type":"number","unit":"s","max":86400,"read":true,"write":true,"name":"countdown_1","id":9,"role":"level"},{"type":"number","max":50000,"scale":3,"read":true,"write":true,"name":"add_ele","id":17,"role":"level"},{"type":"number","unit":"mA","max":30000,"read":true,"write":false,"name":"cur_current","id":18,"role":"value"},{"type":"number","unit":"W","max":50000,"scale":1,"read":true,"write":false,"name":"cur_power","id":19,"role":"value"},{"type":"number","unit":"V","max":5000,"scale":1,"read":true,"write":false,"name":"cur_voltage","id":20,"role":"value"},{"type":"number","max":5,"read":true,"write":false,"name":"test_bit","id":21,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"voltage_coe","id":22,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"electric_coe","id":23,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"power_coe","id":24,"role":"value"},{"type":"number","max":1000000,"read":true,"write":false,"name":"electricity_coe","id":25,"role":"value"},{"type":"number","unit":"ov_cr:过流保护","read":true,"write":false,"name":"fault","id":26,"role":"value"}]
                              tuya.0
                              2022-09-23 11:44:49.414	debug	250710602cf432a253ce: Create device objects if not exist
                              tuya.0
                              2022-09-23 11:44:49.411	debug	38325110cc50e3262c9d Register onChange for 7
                              tuya.0
                              2022-09-23 11:44:49.410	debug	38325110cc50e3262c9d Register onChange for 2
                              tuya.0
                              2022-09-23 11:44:49.410	debug	38325110cc50e3262c9d Register onChange for 1
                              tuya.0
                              2022-09-23 11:44:49.408	debug	38325110cc50e3262c9d: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_on","id":1,"role":"switch"},{"type":"number","unit":"秒","max":86400,"read":true,"write":true,"name":"countdown","id":2,"role":"level"},{"type":"number","unit":"度","max":500000,"scale":3,"read":true,"write":false,"name":"add_ele","id":3,"role":"value"},{"type":"number","unit":"mA","max":30000,"read":true,"write":false,"name":"cur_current","id":4,"role":"value"},{"type":"number","unit":"W","max":50000,"scale":1,"read":true,"write":false,"name":"cur_power","id":5,"role":"value"},{"type":"number","unit":"V","max":2500,"scale":1,"read":true,"write":false,"name":"cur_voltage","id":6,"role":"value"},{"type":"boolean","unit":"设备输出时可通过此控件控制红灯亮灭","read":true,"write":true,"name":"LED","id":7,"role":"switch"}]
                              tuya.0
                              2022-09-23 11:44:49.407	debug	38325110cc50e3262c9d: Create device objects if not exist
                              tuya.0
                              2022-09-23 11:44:49.405	debug	38325110cc50e3d44d56 Register onChange for 7
                              tuya.0
                              2022-09-23 11:44:49.403	debug	38325110cc50e3d44d56 Register onChange for 2
                              tuya.0
                              2022-09-23 11:44:49.402	debug	38325110cc50e3d44d56 Register onChange for 1
                              • M martin
                                @apollon77
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                tuya.0
                                @martin Ist halt seehr kurz das Log ... aber du siehst das das Gerät die Verbindung beendet hat (Disconnected from device) ... bei dem einen mal. Ich denke das andere kommt das gleiche.
                                Wenn Die App definitiv nicht mehr läuft bzw nichts anderes lokal auf das Gerät zugreift dann ggf mal Geräte neu starten und stromlos machen.
                                  martin
                                  @apollon77
                                  Das mit dem stromlos machen habe ich mehrmals versucht. Leider ohne Erfolg.
                                  • M martin
                                    @apollon77
                                    @martin Dann kann ich leider gerade nichts sagen ... "Disconnected from device" heisst das das Gerät die Netzwerkverbindung beendet hat ... Gabs irgendwelche Firmware updates bei den Geräten? Ggf probleme bei der WLAN erreichbarkeit?
                                      O Offline
                                      O Offline
                                      @apollon77 sagte in Tuya Steckdose offline - Alexa erreichbar:
                                      Bedeutet das, dass weiterhin mittels UDP über den lokalen Port kommuniziert wird?
                                        @ofbeqnpolkkl6mby5e13 Es ist TCP, aber ja kommunikation immer noch Lokal. Nur "wie kommt man an den LocalKey für die verschlüsselung" läuft über die Tuya dev-cloud. (UDP ist nur "discovery")
                                          O Offline
                                          O Offline
                                          @apollon77
                                          Okay, also dann doch Tasmota und Abschied vom Tuya-Adapter und App.
