  4. iobroker (buanet docker) adapter lassen sich nicht updaten
    5.8k
11 Beiträge 3 Kommentatoren 1.0k Aufrufe 2 Beobachtet
  • E ehome
    ich habe momentan das Problem, dass sich Adapter nicht aktualisieren lassen, weder über das WEB-Frontend noch auf der Konsole.
    Beispiel
    root@iobroker:/opt/iobroker# iob update | grep sql
    Adapter    "sql"          : 2.2.0    , installed 2.1.8  [Updatable]
    root@iobroker:/opt/iobroker# iob upgrade
    This upgrade of "sql" will introduce the following changes:
    -> 2.2.0:
    IMPORTANT: Node.js 14.x is now needed at minimum!
    Fix potential crash cases with upcoming js-controller versions
    Would you like to upgrade sql from @2.1.8 to @2.2.0 now? [(y)es, (n)o]: y
    Update sql from @2.1.8 to @2.2.0
    host.iobroker Adapter "system.adapter.sql.1" is stopped.
    NPM version: 8.15.0
    Installing iobroker.sql@2.2.0... (System call)
    upload [13] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [12] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [11] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [10] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [9] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [8] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [7] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [5] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [4] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [3] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/jsonConfig.json jsonConfig.json application/json
    upload [2] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/jsonCustom.json jsonCustom.json application/json
    upload [1] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/sql.png sql.png image/png
    upload [0] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/words.js words.js application/javascript
    host.iobroker Adapter "system.adapter.sql.1" is started
    root@iobroker:/opt/iobroker# iob update | grep Updatable
    Adapter    "history"      : 2.2.4    , installed 2.2.3  [Updatable]
    Adapter    "influxdb"     : 3.2.0    , installed 3.1.8  [Updatable]
    Adapter    "info"         : 1.9.21   , installed 1.9.19 [Updatable]
    Das gleiche bei den anderen Adaptern.
    Im log stehen keinerlei Fehlermeldungen diesbezüglich.
    Docker Image-Version:
    "Image": "buanet/iobroker:latest-v7" (label "org.opencontainers.image.version": "v7.0.1")
    Node-Version: v16.17.0
    Ich bin vor einigen Tagen von der docker-image Version von latest-v6 auf latest-v7 gewechselt, da gab es das
    Problem noch nicht .
    Beim Starten des Containers fallen mir auch keine Fehlermeldungen auf, die auf Probleme diesbezüglich hinweisen.
    -----             Step 2 of 5: Detecting ioBroker installation             -----
    Existing installation of ioBroker detected in /opt/iobroker.
    -----             Step 3 of 5: Checking ioBroker installation              -----
    (Re)Setting folder permissions (This might take a while! Please be patient!)... Done.
    Fixing "sudo-bug" by replacing sudo in iobroker with gosu... Done.
    -----                Step 4 of 5: Applying special settings                -----
    Some adapters have special requirements/ settings which can be activated by the use of environment variables.
    For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
    Checking multihost setup...
    Multihost is set as "master" by ENV and no external objects db is set.
    Setting host of objects db to "0.0.0.0" to allow external communication... Done.
    Multihost is set as "master" by ENV and no external states db is set.
    Setting host of states db to "0.0.0.0" to allow external communication... Done.
    Done.
    -----                    Step 5 of 5: ioBroker startup                     -----
    Starting ioBroker...
    2022-09-22 07:52:24.920  - ^[[32minfo^[[39m: host.iobroker iobroker.js-controller version 4.0.23 js-controller starting
    2022-09-22 07:52:24.923  - ^[[32minfo^[[39m: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-09-22 07:52:24.923  - ^[[32minfo^[[39m: host.iobroker hostname: iobroker, node: v16.17.0
    2022-09-22 07:52:24.923  - ^[[32minfo^[[39m: host.iobroker ip addresses: 192.168.0.6
    Kennt jemand das Problem bzw. hat jemand ggf. eine Lösung dafür ?
    GlasfaserG Offline
    GlasfaserG Offline
    @ehome sagte in iobroker (buanet docker) adapter lassen sich nicht updaten:
    hast du vorher schon im alten Container ein upgrade auf Nodejs16 gemacht !?
    Zeige mal :
    iobroker upgrade iobroker.sql@2.2.0 --debug
    cd /opt/iobroker
    npm ls | grep -E 'github.com|ERR'
    iobroker update -i
    uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    E GlasfaserG 2 Antworten Letzte Antwort
    • GlasfaserG Glasfaser
      Zeige mal :
      cd /opt/iobroker
      iobroker update -i
      ehome
      @glasfaser said in iobroker (buanet docker) adapter lassen sich nicht updaten:
      @glafaser Vielen Dank für deine Antwort,
      puh ehrlich gesagt weiss ich nicht, ob ich im alten Container den update irgendwann gemacht habe, werde wohl langsam vergesslich ...
      Hier der Output deiner Befehle:
      root@iobroker:/opt/iobroker# npm ls | grep -E 'github.com|ERR'
      ├── iobroker.solaredge@0.2.0 (git+ssh://git@github.com/92lleo/ioBroker.solaredge.git#189bb28347e0cfeffaa6b2b0b21c2534d827fbf9)
      root@iobroker:/opt/iobroker# sudo ln -s /usr/bin/node /usr/bin/nodejs
      root@iobroker:/opt/iobroker# uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      x86_64
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.17.0
      v16.17.0
      8.15.0
      root
      /opt/iobroker
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
      Reading package lists... Done
      All packages are up to date.
      nodejs:
        Installed: 16.17.0-deb-1nodesource1
        Candidate: 16.17.0-deb-1nodesource1
        Version table:
       *** 16.17.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
           12.22.12~dfsg-1~deb11u1 500
              500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
           12.22.5~dfsg-2~11u1 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
        Zeige mal :
        cd /opt/iobroker
        iobroker update -i
        GlasfaserG Offline
        GlasfaserG Offline
        @ehome
        @glasfaser sagte in iobroker (buanet docker) adapter lassen sich nicht updaten:
        Zeige mal :
        und der Rest fehlt auch
        iobroker update -i
        E 1 Antwort Letzte Antwort
          @ehome
          Zeige mal :
          iobroker update -i
          ehome
          @glasfaser
          ups, sorry.
          Also:
          -> 2.2.0:
          NPM version: 8.15.0
          npm WARN old lockfile
          npm WARN old lockfile The package-lock.json file was created with an old version of npm,
          npm WARN old lockfile so supplemental metadata must be fetched from the registry.
          npm WARN old lockfile This is a one-time fix-up, please be patient...
          npm WARN tarball tarball data for iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master (sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==) seems to be corrupted. Trying again.
          npm WARN old lockfile Error: sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== integrity checksum failed when using sha512: wanted sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== but got sha512-ZH4lj95sM6IpZEL2H1HR0hXTo6GMqbUBPbQyylgdRd6TDEdU+fgohUVGW4gPI0UnrAzqM/kx5+mozLqCVh2DCg==. (64751136 bytes)
          npm WARN old lockfile     at IntegrityStream.[_onEnd] (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:118:19)
          npm WARN old lockfile     at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:88:19)
          npm WARN old lockfile     at IntegrityStream.[maybeEmitEnd] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:440:12)
          npm WARN old lockfile     at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/minipass/index.js:484:25)
          npm WARN old lockfile     at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:90:18)
          npm WARN old lockfile     at IntegrityStream.[resume] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:318:12)
          npm WARN old lockfile     at IntegrityStream.resume (/usr/lib/node_modules/npm/node_modules/minipass/index.js:322:24)
          npm WARN old lockfile     at CachingMinipassPipeline.emit (/usr/lib/node_modules/npm/node_modules/minipass-pipeline/index.js:105:19)
          npm WARN old lockfile     at CachingMinipassPipeline.emit (/usr/lib/node_modules/npm/node_modules/make-fetch-happen/lib/pipeline.js:37:18)
          npm WARN old lockfile     at CachingMinipassPipeline.[resume] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:312:10)
          npm WARN old lockfile  Could not fetch metadata for iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master Error: sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== integrity checksum failed when using sha512: wanted sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== but got sha512-ZH4lj95sM6IpZEL2H1HR0hXTo6GMqbUBPbQyylgdRd6TDEdU+fgohUVGW4gPI0UnrAzqM/kx5+mozLqCVh2DCg==. (64751136 bytes)
          npm WARN old lockfile     at CachingMinipassPipeline.[resume] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:312:10) {
          npm WARN old lockfile   code: 'EINTEGRITY',
          npm WARN old lockfile   found: Integrity { sha512: [ [Hash] ] },
          npm WARN old lockfile   expected: [
          npm WARN old lockfile     Hash {
          npm WARN old lockfile       source: 'sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==',
          npm WARN old lockfile       digest: 'qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==',
          npm WARN old lockfile       algorithm: 'sha512',
          npm WARN old lockfile       options: []
          npm WARN old lockfile     }
          npm WARN old lockfile   ],
          npm WARN old lockfile   sri: Integrity { sha512: [ [Hash] ] }
          npm ERR! code EINTEGRITY
          npm ERR! sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== integrity checksum failed when using sha512: wanted sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== but got sha512-ZH4lj95sM6IpZEL2H1HR0hXTo6GMqbUBPbQyylgdRd6TDEdU+fgohUVGW4gPI0UnrAzqM/kx5+mozLqCVh2DCg==. (64751136 bytes)
          npm ERR!     /opt/iobroker/.npm/_logs/2022-09-22T07_08_23_704Z-debug-0.log
          jetzt sehe ich auch Fehlermeldungen - mit dem debug hätt ich auch selber drauf kommen können .... da gibt es bei mir meherere von:
          root@iobroker:/opt/iobroker# find . -name package-lock.json
          ./node_modules/@abandonware/bluetooth-hci-socket/package-lock.json
          ./node_modules/@abandonware/noble/package-lock.json
          ./node_modules/minipass-sized/package-lock.json
          ./node_modules/npm-normalize-package-bin/package-lock.json
          ./node_modules/iobroker.javascript/package-lock.json
          ./package-lock.json
          iobroker update -i
          root@iobroker:/opt/iobroker# iobroker update -i
          Adapter    "admin"        : 6.2.22   , installed 6.2.22
          Adapter    "alias-manager": 1.2.6    , installed 1.2.6
          Adapter    "backitup"     : 2.4.12   , installed 2.4.12
          Adapter    "daswetter"    : 3.1.4    , installed 3.1.4
          Adapter    "device-watcher": 1.0.0   , installed 1.0.0
          Adapter    "devices"      : 1.0.12   , installed 1.0.12
          Adapter    "discovery"    : 3.0.5    , installed 3.0.5
          Adapter    "echarts"      : 1.0.12   , installed 1.0.12
          Adapter    "email"        : 1.1.3    , installed 1.1.3
          Adapter    "eventlist"    : 1.0.1    , installed 1.0.1
          Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
          Adapter    "flot"         : 1.11.0   , installed 1.11.0
          Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
          Adapter    "hm-rega"      : 3.0.43   , installed 3.0.43
          Adapter    "hm-rpc"       : 1.15.15  , installed 1.15.15
          Adapter    "homeconnect"  : 1.0.2    , installed 1.0.2
          Adapter    "jarvis"       : 3.0.13   , installed 3.0.13
          Adapter    "javascript"   : 6.0.3    , installed 6.0.3
          Controller "js-controller": 4.0.23   , installed 4.0.23
          Adapter    "kecontact"    : 1.4.1    , installed 1.4.1
          Adapter    "lametric"     : 2.0.0    , installed 2.0.0
          Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
          Adapter    "logparser"    : 1.1.0    , installed 1.1.0
          Adapter    "lovelace"     : 2.2.0    , installed 2.2.0
          Adapter    "modbus"       : 5.0.5    , installed 5.0.5
          Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
          Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
          Adapter    "nut"          : 1.5.1    , installed 1.5.1
          Adapter    "parser"       : 1.2.1    , installed 1.2.1
          Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
          Adapter    "pushover"     : 3.0.3    , installed 3.0.3
          Adapter    "radar2"       : 2.0.3    , installed 2.0.3
          Adapter    "renault"      : 0.0.14   , installed 0.0.14
          Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
          Adapter    "simple-api"   : 2.7.1    , installed 2.7.1
          Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
          Adapter    "socketio"     : 6.1.10   , installed 6.1.10
          Adapter    "sonos"        : 2.2.3    , installed 2.2.3
          Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
          Adapter    "statistics"   : 2.2.0    , installed 2.2.0
          Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
          Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
          Adapter    "trashschedule": 2.0.3    , installed 2.0.3
          Adapter    "unifi"        : 0.6.1    , installed 0.6.1
          Adapter    "viessmann"    : 1.3.7    , installed 1.3.7
          Adapter    "vis-material" : 0.1.3    , installed 0.1.3
          Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
          Adapter    "web"          : 5.2.5    , installed 5.2.5
          Adapter    "ws"           : 2.1.5    , installed 2.1.5
          Adapter    "yahka"        : 0.13.1   , installed 0.13.1
          Adapter    "zoe2"         : 0.2.5    , installed 0.2.5
          ln: failed to create symbolic link '/usr/bin/nodejs': File exists
          x86_64
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v16.17.0
          v16.17.0
          8.15.0
          root
          /opt/iobroker
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          nodejs:
            Version table:
          GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
          • E ehome
            @glasfaser
            ups, sorry.
            Also:
            -> 2.2.0:
            NPM version: 8.15.0
            ./package-lock.json
            iobroker update -i
            x86_64
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v16.17.0
            v16.17.0
            8.15.0
            root
            /opt/iobroker
            nodejs:
              Version table:
            GlasfaserG Offline
            GlasfaserG Offline
            @ehome
            pkill -u iobroker
            rm /opt/iobroker/package*
            danach den Container neu starten .
            • E ehome
              @glasfaser
              ups, sorry.
              Also:
              -> 2.2.0:
              NPM version: 8.15.0
              ./package-lock.json
              iobroker update -i
              x86_64
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v16.17.0
              v16.17.0
              8.15.0
              root
              /opt/iobroker
              nodejs:
                Version table:
              Den npm cache mal leeren und den Adapter mit den iobroker.icons-open-icon-library-png nochmal installieren.
                @ehome
                pkill -u iobroker
                ehome
                @glasfaser
                alles startete, habe daraufhin ein update eines Adapters probiert - dann ging nix mehr.
                Habe daraufhin Container wieder neu gestartet:
                node:internal/modules/cjs/loader:959
                  throw err;
                Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                    at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
                    at Function.Module._load (node:internal/modules/cjs/loader:804:27)
                    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                    at node:internal/main/run_main_module:17:47 {
                  code: 'MODULE_NOT_FOUND',
                  requireStack: []
                /opt/scripts/iobroker_startup.sh: line 212: [: !=: unary operator expected
                Done.
                  throw err;
                Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/controller.js'
                  requireStack: []
                jetzt starte nicht mal mehr iobroker
                • E ehome
                  @glasfaser
                    throw err;
                    requireStack: []
                  Done.
                    throw err;
                    requireStack: []
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @ehome
                  cd /opt/iobroker
                  sudo -H -u iobroker npm install iobroker.js-controller
                  iobroker update -i
                  iobroker upgrade
                  Container danach wieder neu starten
                  • E ehome
                    @glasfaser
                      throw err;
                      requireStack: []
                    Done.
                      throw err;
                      requireStack: []
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Was hast du gemacht ... weil du schreibst
                    dann ging nix mehr.
                    Fehler im Log oder .... !?
                      dann ging nix mehr.
                      ehome
                      dann ging nix mehr.
                      ich habe
                      1. erfolgreich versucht ruhig zu bleiben
                      2. einen Kaffee geholt
                      3. geschaut ob mein Backup gestern gelaufen ist
                      Nach der Installation von iobroker.js-controller dem Update und upgrade
                      läuft jetzt alles wieder - soweit ich es sehen kann.
                      Allerdings hat er nach dem Start alle Adapter neu installiert.
                      Vielen lieben Dank - läuft alles und Adapter lassen sich wieder updaten.
