  4. IoBroker startet nicht mehr - bitte um Hilfe
    5.8k
16 Beiträge 3 Kommentatoren 1.5k Aufrufe 3 Beobachtet
  • D Darius 0
    Upgrade bricht mit Fehlermeldung ab
    pi@raspberrypi-4iob:~ $ iobroker upgrade node-red@4.0.0 --debug
    Would you like to reinstall version 4.0.0 of node-red now? [(y)es, (n)o]: y
    Update node-red from @4.0.0 to @4.0.0
    NPM version: 8.15.0
    Installing iobroker.node-red@4.0.0... (System call)
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/@babel/runtime
    npm ERR! dest /opt/iobroker/node_modules/@babel/.runtime-cSN2FFol
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@babel/runtime' -> '/opt/iobroker/node_modules/@babel/.runtime-cSN2FFol'
    npm ERR!     /home/iobroker/.npm/_logs/2022-09-19T18_45_52_001Z-debug-0.log
    host.raspberrypi-4iob Cannot install iobroker.node-red@4.0.0: 217
    @darius-0
    https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8/2
      @darius-0
      Darius 0
      Kommando ausgeführt und die Installation von NodeRed nochmal durchlaufen lassen - diesmal ohne Fehler.
      IoB läßt sich aber noch nicht starten..
      pi@raspberrypi-4iob:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
      NPM version: 8.15.0
      npm WARN deprecated debug@4.2.0: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
      changed 105 packages in 33s
      141 packages are looking for funding
        run `npm fund` for details
      Update "system.adapter.node-red.0"
      upload [14] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/bcrypt.min.js bcrypt.min.js application/javascript
      upload [13] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [12] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [11] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [10] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [9] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [8] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [7] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [6] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [5] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [4] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [3] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index.html index.html text/html
      upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index_m.html index_m.html text/html
      upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
      upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
      pi@raspberrypi-4iob:~ $ iobroker start
      • D Darius 0
        NPM version: 8.15.0
        @darius-0
        iobroker update
        iobroker status
        iobroker list instances
          @darius-0
          iobroker update
          iobroker status
          Darius 0
          pi@raspberrypi-4iob:~ $ iobroker update
          iobroker status
          Used repository: stable
          Adapter    "admin"        : 6.2.22   , installed 6.2.22
          Adapter    "alarm"        : 3.1.1    , installed 3.1.1
          Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
          Adapter    "backitup"     : 2.4.10   , installed 2.4.10
          Adapter    "deconz"       : 1.3.21   , installed 2.0.5
          Adapter    "devices"      : 1.0.12   , installed 1.0.12
          Adapter    "discovergy"   : 0.5.8    , installed 0.5.9-0
          Adapter    "discovery"    : 3.0.5    , installed 3.0.5
          Adapter    "fb-checkpresence": 1.1.19, installed 1.1.19
          Adapter    "flot"         : 1.11.0   , installed 1.11.0
          Adapter    "history"      : 2.2.0    , installed 2.2.0
          Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
          Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
          Adapter    "ical"         : 1.13.1   , installed 1.13.1
          Adapter    "influxdb"     : 3.1.8    , installed 3.1.7  [Updatable]
          Adapter    "info"         : 1.9.19   , installed 1.9.19
          Adapter    "iot"          : 1.11.9   , installed 1.11.9
          Adapter    "javascript"   : 6.0.3    , installed 6.0.3
          Controller "js-controller": 4.0.23   , installed 4.0.23
          Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
          Adapter    "modbus"       : 5.0.5    , installed 5.0.5
          Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
          Adapter    "node-red"     : 4.0.0    , installed 4.0.0
          Adapter    "shelly"       : 6.0.0    , installed 6.0.0
          Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
          Adapter    "smartcontrol" : 1.2.1    , installed 1.2.1
          Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
          Adapter    "synology"     : 2.1.9    , installed 2.1.9
          Adapter    "tesla-motors" : 1.3.0    , installed 1.3.0
          Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
          Adapter    "trashschedule": 2.0.3    , installed 2.0.3
          Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
          Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
          Adapter    "vis-hqwidgets": 1.3.0    , installed 1.2.0  [Updatable]
          Adapter    "vis-icontwo"  : 0.89.0   , installed 0.89.0
          Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
          Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
          Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
          Objects type: jsonl
          States  type: jsonl
          + system.adapter.admin.0                  : admin                 : raspberrypi-4iob                         -  enabled, port: 8081, bind:                                            0.0.0.0, run as: admin
          + system.adapter.alarm.0                  : alarm                 : raspberrypi-4iob                         - disabled
          + system.adapter.alexa2.0                 : alexa2                : raspberrypi-4iob                         - disabled
          + system.adapter.backitup.0               : backitup              : raspberrypi-4iob                         -  enabled
          + system.adapter.deconz.0                 : deconz                : raspberrypi-4iob                         - disabled, port: 80
            system.adapter.devices.0                : devices               : raspberrypi-4iob                         - disabled
          + system.adapter.discovergy.0             : discovergy            : raspberrypi-4iob                         - disabled
            system.adapter.discovery.0              : discovery             : raspberrypi-4iob                         - disabled
          + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi-4iob                         - disabled
          + system.adapter.hm-rega.0                : hm-rega               : raspberrypi-4iob                         - disabled
            system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi-4iob                         - disabled, port: 18701
          + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi-4iob                         - disabled, port: 12001
          + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi-4iob                         - disabled, port: 12010
            system.adapter.ical.0                   : ical                  : raspberrypi-4iob                         - disabled
            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi-4iob                         - disabled
            system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi-4iob                         - disabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi-4iob                         - disabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi-4iob                         - disabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi-4iob                         - disabled
            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi-4iob                         - disabled
          + system.adapter.influxdb.0               : influxdb              : raspberrypi-4iob                         - disabled, port: 8086
          + system.adapter.info.0                   : info                  : raspberrypi-4iob                         - disabled
          + system.adapter.javascript.0             : javascript            : raspberrypi-4iob                         - disabled
          + system.adapter.lgtv.0                   : lgtv                  : raspberrypi-4iob                         - disabled
          + system.adapter.modbus.0                 : modbus                : raspberrypi-4iob                         - disabled
          + system.adapter.node-red.0               : node-red              : raspberrypi-4iob                         - disabled, port: 1880, bind:                                            0.0.0.0
          + system.adapter.ping.0                   : ping                  : raspberrypi-4iob                         - disabled
            system.adapter.scenes.0                 : scenes                : raspberrypi-4iob                         - disabled
          + system.adapter.shelly.0                 : shelly                : raspberrypi-4iob                         - disabled, port: 1882, bind:                                            0.0.0.0
            system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi-4iob                         - disabled
          + system.adapter.sonoff.0                 : sonoff                : raspberrypi-4iob                         - disabled, port: 1883, bind:                                            0.0.0.0
          + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi-4iob                         - disabled
            system.adapter.synology.0               : synology              : raspberrypi-4iob                         - disabled, port: 9900
          + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi-4iob                         - disabled
          + system.adapter.trashschedule.0          : trashschedule         : raspberrypi-4iob                         - disabled
            system.adapter.vis-bars.0               : vis-bars              : raspberrypi-4iob                         - disabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi-4iob                         - disabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi-4iob                         - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi-4iob                         - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi-4iob                         - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi-4iob                         - disabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi-4iob                         - disabled
            system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi-4iob                         - disabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi-4iob                         - disabled
            system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi-4iob                         - disabled
            system.adapter.vis-material.0           : vis-material          : raspberrypi-4iob                         - disabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi-4iob                         - disabled
            system.adapter.vis-metro.0              : vis-metro             : raspberrypi-4iob                         - disabled
            system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi-4iob                         - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi-4iob                         - disabled
            system.adapter.vis.0                    : vis                   : raspberrypi-4iob                         - disabled
          + system.adapter.web.0                    : web                   : raspberrypi-4iob                         - disabled, port: 8082, bind:                                            0.0.0.0, run as: admin
          + instance is alive
          • D Darius 0
            iobroker status
            Objects type: jsonl
            States  type: jsonl
            + instance is alive
            @darius-0 sagte in IoBroker startet nicht mehr - bitte um Hilfe:
            Läuft.
              Läuft.
              Darius 0
              ja - aber leider komme ich auf das Web interface :8081 nicht drauf... antwortet nicht..
              • D Darius 0
                antwortet nicht..
                Ja irgendwas wird das Ding schon antworten.
                  antwortet nicht..
                  Darius 0
                  ok, jetzt hat sich nach einer Ewigkeit das Web interface aufrufen lassen - aber alle adapter bis auf admin und backitup sind inaktiv - einfach starten? war das so zu erwarten?
                  • D Darius 0
                    @darius-0
                    Laut deiner
                    laufen die.
                    Bitte Konsolenausgaben auch IMMER vollständig, d.h. inkl. der Eingabezeilen (inkl. login prompt) posten. Dann kann man sich daran orientieren wo die Ausgabe des einen Befehls aufhört und was neues anfängt.
                      @darius-0
                      Laut deiner
                      laufen die.
                      Darius 0
                      Also zunächst einmal - ein mega dankeschön für die prompte Hilfe, wäre sonst verzweifelt. Habe alle Adapter im Admin interface einfach gestartet und es scheint alles zu laufen. Node Red meldet sich mit V4, also passt und arbeitet!
                      Danke nochmal und einen schönen Restabend!
                      Gruss aus BW, Darius
                        iobroker stop
                        iobroker update
                        iobroker start
                        Und ich sage immer noch, der node-red-Adapter verhält sich irgendwie merkwürdig bei der Installation, @mickym
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @thomas-braun Das liegt ggf. daran, dass irgendwas mit dem Repository nicht passt. Über npm lässt sich der Adapter nicht upgraden, wenn das stable Repository ausgewählt ist. Man muss also immer kurz ins beta Repository wecheln.
                        Bei mir ist halt immer noch die 4.0.0 von github drin. Ich denke, dass sich vielleicht einiges ändert - wenn der Adapter ins stable geht.
                        Bei mir sieht es halt derzeit so aus:
                        pi@MWHome2:/opt/iobroker $ npm ls
                        iobroker.inst@3.0.0 /opt/iobroker
                        ├── iobroker.admin@6.2.22
                        ├── iobroker.backitup@2.4.10
                        ├── iobroker.dwd@2.8.3
                        ├── iobroker.flot@1.11.0
                        ├── iobroker.info@1.9.19
                        ├── iobroker.javascript@6.0.3
                        ├── iobroker.js-controller@4.0.23
                        ├── iobroker.linux-control@1.1.3
                        ├── iobroker.mercedesme@0.0.56
                        ├── iobroker.mqtt@4.0.7
                        ├── iobroker.node-red@4.0.0 (git+ssh://git@github.com/ioBroker/ioBroker.node-red.git#049d7bdddc747071fc7379551d4bd7a66d690c57)
                        ├── iobroker.pi-hole@1.3.4
                        ├── iobroker.ping@1.5.3
                        ├── iobroker.simple-api@2.7.0
                        ├── iobroker.socketio@4.2.0
                        ├── iobroker.sourceanalytix@0.4.14
                        ├── iobroker.sql@2.1.8
                        ├── iobroker.tr-064@4.2.16
                        ├── iobroker.vis-hqwidgets@1.3.0
                        ├── iobroker.vis@1.4.15
                        ├── iobroker.web@4.3.0
                        └── iobroker.yahka@0.13.1
                        • mickymM mickym
                          @mickym
                          node-red
                          github:	4.0.0
                          latest:	4.0.0 for 36 days
                          stable:	4.0.0 for 36 days
                            @mickym
                            node-red
                            github:	4.0.0
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @thomas-braun Hmm dann hätte dieser Fall ja auch direkt upgraden können - dann hab ich wohl falsch gelegen mit meiner Empfehlung.
                            https://forum.iobroker.net/topic/58007/node-red-bleit-immer-auf-version-2-2-3-stehen/2
                            Wobei hier lags ja auch wieder daran, dass doch wieder Müllverzeichnisse im node_modules vorhanden waren.
