  4. iobroker kann überhaupt nix mehr installieren oder updaten
    5.8k
63 Beiträge 5 Kommentatoren 5.4k Aufrufe 4 Beobachtet
    @neinneinhilfe
    uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    im Terminal, Ausgaben hier in CodeTags eingebettet reinkopieren.
    Dann
    iobroker update
    iobroker upgrade admin --debug
    N Offline
    N Offline
    neinneinhilfe
    @thomas-braun said in iobroker kann überhaupt nix mehr installieren oder updaten:
    @neinneinhilfe
    Dann
    iobroker update
    Das?
    This upgrade of "admin" will at least introduce the following changes:
    -> 6.2.20:
    Corrected GUI issues
    -> 6.2.19:
    Corrected some issues
    -> 6.2.18:
    Corrected GUI bugs on custom settings
    -> 6.2.17:
    Corrected GUI bug on intro tab
    -> 6.2.16:
    Corrected many GUI issues
    Added `stable` flag for repositories
    Added reset button for repositories
    Improved `writeFile` function for socket communication
    -> 6.2.14:
    Fix for OAuth2 authentication response success page
    -> 6.2.13:
    Corrected JSON config
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade admin from @5.3.8 to @6.2.20 now? [(y)es, (n)o]: y
    Update admin from @5.3.8 to @6.2.20
    host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
    NPM version: 8.15.0
    Installing iobroker.admin@6.2.20... (System call)
    npm ERR! code EJSONPARSE
    npm ERR! path /opt/iobroker/package.json
    npm ERR! JSON.parse Unexpected end of JSON input while parsing "\n"
    npm ERR! JSON.parse Failed to parse JSON data.
    npm ERR! JSON.parse Note: package.json must be actual JSON, not just JavaScript.
    npm ERR!     /home/iobroker/.npm/_logs/2022-09-04T12_27_06_001Z-debug-0.log
    upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
    host.raspberrypi Adapter "system.adapter.admin.0" is started
    • N neinneinhilfe
      @neinneinhilfe
      Dann
      iobroker update
      Das?
      -> 6.2.20:
      -> 6.2.19:
      -> 6.2.18:
      -> 6.2.17:
      -> 6.2.16:
      -> 6.2.14:
      -> 6.2.13:
      NPM version: 8.15.0
      @neinneinhilfe sagte in iobroker kann überhaupt nix mehr installieren oder updaten:
      iobroker stop
      rm /opt/iobroker/package.json
      iobroker start
      • N neinneinhilfe
        @neinneinhilfe
        Dann
        iobroker update
        Das?
        -> 6.2.20:
        -> 6.2.19:
        -> 6.2.18:
        -> 6.2.17:
        -> 6.2.16:
        -> 6.2.14:
        -> 6.2.13:
        NPM version: 8.15.0
        Und wo ist die Ein- und Ausgabe zu
        N 1 Antwort Letzte Antwort
          N Offline
          N Offline
          neinneinhilfe
          pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v16.17.0
          v16.17.0
          8.15.0
          pi
          /home/pi
          Hit:1 http://archive.raspberrypi.org/debian buster InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:3 https://repos.influxdata.com/debian stretch InRelease
          Hit:4 https://deb.nodesource.com/node_16.x buster InRelease
          Hit:5 https://phoscon.de/apt/deconz buster InRelease
          Hit:6 https://packages.grafana.com/oss/deb stable InRelease
          Reading package lists... Done
          Building dependency tree
          1 package can be upgraded. Run 'apt list --upgradable' to see it.
          nodejs:
            Installed: 16.17.0-deb-1nodesource1
            Candidate: 16.17.0-deb-1nodesource1
            Version table:
           *** 16.17.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
               10.24.0~dfsg-1~deb10u1 500
          • N neinneinhilfe
            armv7l
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v16.17.0
            v16.17.0
            8.15.0
            pi
            /home/pi
            nodejs:
              Version table:
            Falsch, musst 'buster' statt 'stretch' lauten.
              N Offline
              N Offline
              neinneinhilfe
              stretch
              ÄÄhh bitte was? Bin Neuling ^^
              • N neinneinhilfe
                stretch
                @neinneinhilfe
                Nach welcher windigen Anleitung wurde denn influxdb installiert?
                Jedenfalls muss die Datei
                /etc/apt/sources.list.d/influxdb.list
                so aussehen:
                deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/debian buster stable
                  @neinneinhilfe
                  so aussehen:
                  N Offline
                  N Offline
                  neinneinhilfe
                  @neinneinhilfe
                  so aussehen:
                  Und wie kann ich das ganz nun beheben?
                  • N neinneinhilfe
                    @neinneinhilfe
                    so aussehen:
                    Im einfachsten Fall mit dem Editor nano
                    sudo nano /etc/apt/sources.list.d/influxdb.list
                      N Offline
                      N Offline
                      neinneinhilfe
                      schrieb am zuletzt editiert von neinneinhilfe
                      Einfach umbenennen oder wie?
                      • N neinneinhilfe
                        @neinneinhilfe
                        Nee, nicht umbenennen, den Inhalt der Datei anpassen.
                        Halt statt 'stretch' 'buster' eintragen.
                          @neinneinhilfe
                          N Offline
                          N Offline
                          neinneinhilfe
                          @neinneinhilfe
                          pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                          ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                          armv7l
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v16.17.0
                          v16.17.0
                          8.15.0
                          pi
                          /home/pi
                          Hit:3 https://repos.influxdata.com/debian buster InRelease
                          Hit:5 https://packages.grafana.com/oss/deb stable InRelease
                          Hit:6 https://phoscon.de/apt/deconz buster InRelease
                          nodejs:
                            Version table:
                          pi@raspberrypi:~ $
                          Das hat er nun geändert und nun kann ich auch wieder updates machen?
                          • N neinneinhilfe
                            @neinneinhilfe
                            armv7l
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v16.17.0
                            v16.17.0
                            8.15.0
                            pi
                            /home/pi
                            nodejs:
                              Version table:
                            pi@raspberrypi:~ $
                            @neinneinhilfe
                            Jetzt sind deine Paketquellen richtig gesetzt. Hat mit iobroker nicht direkt was zu tun.
                            iobroker stop
                            iobroker start
                            iobroker update
                            iobroker upgrade all -y
                            sagt?
                              @neinneinhilfe
                              iobroker stop
                              iobroker start
                              iobroker update
                              sagt?
                              N Offline
                              N Offline
                              neinneinhilfe
                              pi@raspberrypi:~ $ iobroker upgrade all -y
                              Update vis-timeandweather from @1.1.7 to @1.2.2
                              NPM version: 8.15.0
                              Installing iobroker.vis-timeandweather@1.2.2... (System call)
                              INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-timeandweather/www" was not found! Nothing was uploaded or deleted.
                              Adapter "system.adapter.vis.0" restarted.
                              upload [1] vis-timeandweather.admin /opt/iobroker/node_modules/iobroker.vis-timeandweather/admin/index.html index.html text/html
                              upload [0] vis-timeandweather.admin /opt/iobroker/node_modules/iobroker.vis-timeandweather/admin/timeandweather.png timeandweather.png image/png
                              Update openweathermap from @0.2.5 to @0.3.0
                              NPM version: 8.15.0
                              Installing iobroker.openweathermap@0.3.0... (System call)
                              upload [3] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/index.html index.html text/html
                              upload [2] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/index_m.html index_m.html text/html
                              upload [1] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/openweathermap.png openweathermap.png image/png
                              upload [0] openweathermap.admin /opt/iobroker/node_modules/iobroker.openweathermap/admin/words.js words.js application/javascript
                              Update hue from @3.7.0 to @3.7.1
                              NPM version: 8.15.0
                              Installing iobroker.hue@3.7.1... (System call)
                              upload [14] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/hue.jpeg hue.jpeg image/jpeg
                              upload [13] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [12] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [11] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [10] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [9] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [8] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [7] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [6] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [5] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [4] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [3] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/index.html index.html text/html
                              upload [2] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/index_m.html index_m.html text/html
                              upload [1] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/instruction.png instruction.png image/png
                              upload [0] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/words.js words.js application/javascript
                              NPM version: 8.15.0
                              Update youtube from @3.0.1 to @4.0.0
                              NPM version: 8.15.0
                              Installing iobroker.youtube@4.0.0... (System call)
                              upload [12] youtube.admin /opt/iobroker/node_modules/iobroker.youtube/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [11] youtube.admin /opt/iobroker/node_modules/iobroker.youtube/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [10] youtube.admin /opt/iobroker/node_modules/iobroker.youtube/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [9] youtube.admin /opt/iobroker/node_modules/iobroker.youtube/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [8] youtube.admin /opt/iobroker/node_modules/iobroker.youtube/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [7] youtube.admin /opt/iobroker/node_modules/iobroker.youtube/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [6] youtube.admin /opt/iobroker/node_modules/iobroker.youtube/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [5] youtube.admin /opt/iobroker/node_modules/iobroker.youtube/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [4] youtube.admin /opt/iobroker/node_modules/iobroker.youtube/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [3] youtube.admin /opt/iobroker/node_modules/iobroker.youtube/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [2] youtube.admin /opt/iobroker/node_modules/iobroker.youtube/admin/index_m.html index_m.html text/html
                              upload [1] youtube.admin /opt/iobroker/node_modules/iobroker.youtube/admin/jsonConfig.json jsonConfig.json application/json
                              upload [0] youtube.admin /opt/iobroker/node_modules/iobroker.youtube/admin/youtube.png youtube.png image/png
                              Cannot check dependencies: Invalid version of "admin". Installed "5.3.8", required ">=6.1.6
                              Update shelly from @5.3.2 to @6.0.0
                              NPM version: 8.15.0
                              Installing iobroker.shelly@6.0.0... (System call)
                              upload [13] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [12] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [11] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [10] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [9] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [8] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [7] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [6] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [5] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [4] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [3] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
                              upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/jsonConfig.json jsonConfig.json application/json
                              upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
                              upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
                              Cannot check dependencies: Invalid version of "admin". Installed "5.3.8", required ">=5.4.3
                              Update javascript from @5.7.0 to @6.0.0
                              NPM version: 8.15.0
                              Installing iobroker.javascript@6.0.0... (System call)
                              upload [103] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                              upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
                              upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
                              upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/quote1.png google-blockly/media/quote1.png image/png
                              upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/pt.js google-blockly/msg/js/pt.js application/javascript
                              upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_time.js google-blockly/own/blocks_time.js application/javascript
                              upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/fr.js google-blockly/own/msg/fr.js application/javascript
                              upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/plugins/bundle.js plugins/bundle.js application/javascript
                              upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/runtime-main.a42c4e84.js static/js/runtime-main.a42c4e84.js application/javascript
                              upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/configure.js vs/configure.js application/javascript
                              upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.css vs/editor/editor.main.css text/css
                              upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.js vs/editor/editor.main.js application/javascript
                              upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.de.js vs/editor/editor.main.nls.de.js application/javascript
                              upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.es.js vs/editor/editor.main.nls.es.js application/javascript
                              upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.fr.js vs/editor/editor.main.nls.fr.js application/javascript
                              upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.it.js vs/editor/editor.main.nls.it.js application/javascript
                              upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                              upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                              upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                              upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                              upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                              upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                              upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                              upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                              upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                              upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                              upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                              upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                              upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                              upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                              pi@raspberrypi:~ $
                              Hat irgendwie nicht geklappt....
                              • N neinneinhilfe
                                NPM version: 8.15.0
                                NPM version: 8.15.0
                                NPM version: 8.15.0
                                NPM version: 8.15.0
                                NPM version: 8.15.0
                                NPM version: 8.15.0
                                NPM version: 8.15.0
                                pi@raspberrypi:~ $
                                Die Befehle davor auch ausgeführt?
                                Bitte nix weglassen, man muss das sehen, hier steht keine Glauskugel und ich kann dir auch nicht über die Schulter schauen.
                                iobroker update
                                  iobroker update
                                  N Offline
                                  N Offline
                                  neinneinhilfe
                                  iobroker update
                                  Habe das genau so ausgeführt.....
                                  iobroker stop
                                  iobroker start
                                  iobroker update
                                  Bei upgrade admin --debug kann das hier:
                                  pi@raspberrypi:~ $ iobroker update
                                  Used repository: stable
                                  Adapter    "admin"        : 6.2.20   , installed 5.3.8  [Updatable]
                                  Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
                                  Adapter    "alpha2"       : 1.0.0    , installed 1.0.3
                                  Adapter    "backitup"     : 2.4.10   , installed 2.4.10
                                  Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                                  Adapter    "device-reminder": 1.2.9  , installed 1.2.9
                                  Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                                  Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                                  Adapter    "history"      : 2.2.0    , installed 2.2.0
                                  Adapter    "homekit-controller": 0.5.1, installed 0.5.1
                                  Adapter    "hue"          : 3.7.1    , installed 3.7.0  [Updatable]
                                  Adapter    "influxdb"     : 3.1.7    , installed 3.1.7
                                  Adapter    "info"         : 1.9.19   , installed 1.9.19
                                  Adapter    "javascript"   : 6.0.0    , installed 5.7.0  [Updatable]
                                  Controller "js-controller": 4.0.23   , installed 4.0.23
                                  Adapter    "mqtt"         : 4.0.7    , installed 3.0.6  [Updatable]
                                  Adapter    "nuki"         : 1.6.0    , installed 1.6.0
                                  Adapter    "nuki-extended": 2.3.1    , installed 2.3.1
                                  Adapter    "openweathermap": 0.3.0   , installed 0.2.5  [Updatable]
                                  Adapter    "parcel"       : 0.0.20   , installed 0.0.20
                                  Adapter    "pushover"     : 3.0.2    , installed 3.0.2
                                  Adapter    "roomba"       : 1.1.4    , installed 1.1.4
                                  Adapter    "shelly"       : 6.0.0    , installed 5.3.2  [Updatable]
                                  Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                                  Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                                  Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                                  Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
                                  Adapter    "text2command" : 2.2.2    , installed 2.2.2
                                  Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                                  Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
                                  Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
                                  Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                                  Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                                  Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
                                  Adapter    "wled"         : 0.6.7    , installed 0.6.7
                                  Adapter    "yahka"        : 0.13.1   , installed 0.13.1
                                  Adapter    "youtube"      : 4.0.0    , installed 3.0.1  [Updatable]
                                  pi@raspberrypi:~ $ iobroker upgrade admin --debug
                                  -> 6.2.20:
                                  -> 6.2.19:
                                  -> 6.2.18:
                                  -> 6.2.17:
                                  -> 6.2.16:
                                  -> 6.2.14:
                                  -> 6.2.13:
                                  NPM version: 8.15.0
                                  npm ERR! builtins is not a function
                                  npm ERR!     /home/iobroker/.npm/_logs/2022-09-04T13_05_01_481Z-debug-0.log
                                  pi@raspberrypi:~ $
                                  • N neinneinhilfe
                                    iobroker update
                                    iobroker stop
                                    iobroker start
                                    iobroker update
                                    -> 6.2.20:
                                    -> 6.2.19:
                                    -> 6.2.18:
                                    -> 6.2.17:
                                    -> 6.2.16:
                                    -> 6.2.14:
                                    -> 6.2.13:
                                    NPM version: 8.15.0
                                    pi@raspberrypi:~ $
                                    @neinneinhilfe
                                    iobroker update
                                      @neinneinhilfe
                                      iobroker update
                                      N Offline
                                      N Offline
                                      neinneinhilfe
                                      @neinneinhilfe
                                      iobroker update
                                      pi@raspberrypi:~ $
                                      • N neinneinhilfe
                                        @neinneinhilfe
                                        iobroker update
                                        pi@raspberrypi:~ $
                                        @neinneinhilfe
                                        cd /opt/iobroker
                                        npm ls
                                          @neinneinhilfe
                                          cd /opt/iobroker
                                          npm ls
                                          N Offline
                                          N Offline
                                          neinneinhilfe
                                          cd /opt/iobroker
                                          pi@raspberrypi:~ $ cd /opt/iobroker
                                          pi@raspberrypi:/opt/iobroker $ npm ls
                                          iobroker.core@1.0.0 /opt/iobroker
                                          ├── @abandonware/bluetooth-hci-socket@0.5.3-8 extraneous
                                          ├── @abandonware/noble@1.9.2-15 extraneous
                                          ├── @alcalzone/esbuild-register@2.5.1-1 extraneous
                                          ├── @alcalzone/jsonl-db@2.5.2 extraneous
                                          ├── @alcalzone/pak@0.7.0 extraneous
                                          ├── @apollon/iobroker-tools@0.2.0 extraneous
                                          ├── @colors/colors@1.5.0 extraneous
                                          ├── @dabh/diagnostics@2.0.3 extraneous
                                          ├── @datalust/winston-seq@1.0.2 extraneous
                                          ├── @googleapis/drive@3.0.1 extraneous
                                          ├── @greenlock/manager@3.1.0 extraneous
                                          ├── @harmonyhub/discover@1.0.9 extraneous
                                          ├── @homebridge/ciao@1.1.5 extraneous
                                          ├── @influxdata/influxdb-client-apis@1.27.0 extraneous
                                          ├── @influxdata/influxdb-client@1.27.0 extraneous
                                          ├── @iobroker/adapter-core@2.6.0 extraneous
                                          ├── @iobroker/db-base@4.0.23 extraneous
                                          ├── @iobroker/db-objects-file@4.0.23 extraneous
                                          ├── @iobroker/db-objects-jsonl@4.0.23 extraneous
                                          ├── @iobroker/db-objects-redis@4.0.23 extraneous
                                          ├── @iobroker/db-states-file@4.0.23 extraneous
                                          ├── @iobroker/db-states-jsonl@4.0.23 extraneous
                                          ├── @iobroker/db-states-redis@4.0.23 extraneous
                                          ├── @iobroker/js-controller-adapter@4.0.23 extraneous
                                          ├── @iobroker/js-controller-cli@4.0.23 extraneous
                                          ├── @iobroker/js-controller-common-db@4.0.23 extraneous
                                          ├── @iobroker/js-controller-common@4.0.23 extraneous
                                          ├── @iobroker/plugin-base@1.2.1 extraneous
                                          ├── @iobroker/plugin-sentry@1.2.0 extraneous
                                          ├── @leichtgewicht/ip-codec@2.0.4 extraneous
                                          ├── @mapbox/node-pre-gyp@1.0.9 extraneous
                                          ├── @material/animation@7.0.0 extraneous
                                          ├── @material/base@7.0.0 extraneous
                                          ├── @material/button@7.0.0 extraneous
                                          ├── @material/card@7.0.0 extraneous
                                          ├── @material/density@7.0.0 extraneous
                                          ├── @material/dom@7.0.0 extraneous
                                          ├── @material/elevation@7.0.0 extraneous
                                          ├── @material/feature-targeting@7.0.0 extraneous
                                          ├── @material/ripple@7.0.0 extraneous
                                          ├── @material/rtl@7.0.0 extraneous
                                          ├── @material/shape@7.0.0 extraneous
                                          ├── @material/switch@7.0.0 extraneous
                                          ├── @material/theme@7.0.0 extraneous
                                          ├── @material/touch-target@7.0.0 extraneous
                                          ├── @material/typography@7.0.0 extraneous
                                          ├── @root/acme@3.1.0 extraneous
                                          ├── @root/asn1@1.0.0 extraneous
                                          ├── @root/csr@0.8.1 extraneous
                                          ├── @root/encoding@1.0.1 extraneous
                                          ├── @root/greenlock-express@4.0.4 extraneous
                                          ├── @root/greenlock@4.0.5 extraneous
                                          ├── @root/keypairs@0.9.0 extraneous
                                          ├── @root/mkdirp@1.0.0 extraneous
                                          ├── @root/pem@1.0.4 extraneous
                                          ├── @root/request@1.8.2 extraneous
                                          ├── @root/x509@0.7.2 extraneous
                                          ├── @sentry/core@6.18.1 extraneous
                                          ├── @sentry/hub@6.18.1 extraneous
                                          ├── @sentry/integrations@6.18.1 extraneous
                                          ├── @sentry/minimal@6.18.1 extraneous
                                          ├── @sentry/node@6.18.1 extraneous
                                          ├── @sentry/tracing@6.18.1 extraneous
                                          ├── @sentry/types@6.18.1 extraneous
                                          ├── @sentry/utils@6.18.1 extraneous
                                          ├── @serialport/binding-mock@10.2.2 extraneous
                                          ├── @serialport/bindings-cpp@10.7.0 extraneous
                                          ├── @serialport/bindings-interface@1.2.2 extraneous
                                          ├── @serialport/parser-byte-length@10.3.0 extraneous
                                          ├── @serialport/parser-cctalk@10.3.0 extraneous
                                          ├── @serialport/parser-delimiter@10.3.0 extraneous
                                          ├── @serialport/parser-inter-byte-timeout@10.3.0 extraneous
                                          ├── @serialport/parser-packet-length@10.3.0 extraneous
                                          ├── @serialport/parser-readline@10.3.0 extraneous
                                          ├── @serialport/parser-ready@10.3.0 extraneous
                                          ├── @serialport/parser-regex@10.3.0 extraneous
                                          ├── @serialport/parser-slip-encoder@10.3.0 extraneous
                                          ├── @serialport/parser-spacepacket@10.3.0 extraneous
                                          ├── @serialport/stream@10.3.0 extraneous
                                          ├── @sindresorhus/is@4.6.0 extraneous
                                          ├── @szmarczak/http-timer@4.0.6 extraneous
                                          ├── @tootallnate/once@2.0.0 extraneous
                                          ├── @types/bl@5.0.2 extraneous
                                          ├── @types/cacheable-request@6.0.2 extraneous
                                          ├── @types/caseless@0.12.2 extraneous
                                          ├── @types/http-cache-semantics@4.0.1 extraneous
                                          ├── @types/http-proxy@1.17.8 extraneous
                                          ├── @types/iobroker@4.0.1 extraneous
                                          ├── @types/keyv@3.1.3 extraneous
                                          ├── @types/node@17.0.21 extraneous
                                          ├── @types/readable-stream@2.3.14 extraneous
                                          ├── @types/request@2.48.8 extraneous
                                          ├── @types/responselike@1.0.0 extraneous
                                          ├── @types/tough-cookie@4.0.2 extraneous
                                          ├── abab@2.0.6 extraneous
                                          ├── abbrev@1.1.1 extraneous
                                          ├── abort-controller@3.0.0 extraneous
                                          ├── accepts@1.3.8 extraneous
                                          ├── acme-http-01-standalone@3.0.5 extraneous
                                          ├── acorn-globals@6.0.0 extraneous
                                          ├── acorn-walk@8.2.0 extraneous
                                          ├── acorn@8.7.0 extraneous
                                          ├── after@0.8.2 extraneous
                                          ├── agent-base@6.0.2 extraneous
                                          ├── ajv@6.12.6 extraneous
                                          ├── alcalzone-shared@4.0.1 extraneous
                                          ├── alexa-cookie2@4.0.1 extraneous
                                          ├── alexa-remote2@4.1.2 extraneous
                                          ├── ansi-regex@5.0.1 extraneous
                                          ├── ansi-styles@4.3.0 extraneous
                                          ├── anymatch@3.1.2 extraneous
                                          ├── aproba@2.0.0 extraneous
                                          ├── are-we-there-yet@2.0.0 extraneous
                                          ├── array-flatten@1.1.1 extraneous
                                          ├── array.prototype.findindex@2.2.0 extraneous
                                          ├── arraybuffer.slice@0.0.7 extraneous
                                          ├── arrify@2.0.1 extraneous
                                          ├── asn1@0.2.6 extraneous
                                          ├── assert-plus@1.0.0 extraneous
                                          ├── async-limiter@1.0.1 extraneous
                                          ├── async-retry@1.3.3 extraneous
                                          ├── async@0.2.10 extraneous
                                          ├── asynckit@0.4.0 extraneous
                                          ├── at-least-node@1.0.0 extraneous
                                          ├── autobind-decorator@2.4.0 extraneous
                                          ├── available-typed-arrays@1.0.5 extraneous
                                          ├── aws-sign2@0.7.0 extraneous
                                          ├── aws4@1.11.0 extraneous
                                          ├── axios@0.21.4 extraneous
                                          ├── backo2@1.0.2 extraneous
                                          ├── balanced-match@1.0.2 extraneous
                                          ├── base-64@1.0.0 extraneous
                                          ├── base64-arraybuffer@0.1.4 extraneous
                                          ├── base64-js@1.5.1 extraneous
                                          ├── base64id@2.0.0 extraneous
                                          ├── bcrypt-pbkdf@1.0.2 extraneous
                                          ├── bignumber.js@9.0.2 extraneous
                                          ├── binary-extensions@2.2.0 extraneous
                                          ├── bindings@1.5.0 extraneous
                                          ├── bl@1.2.3 extraneous
                                          ├── blob@0.0.5 extraneous
                                          ├── bluebird@3.7.2 extraneous
                                          ├── body-parser@1.19.2 extraneous
                                          ├── bonjour-hap@3.6.3 extraneous
                                          ├── bonjour@3.5.0 extraneous
                                          ├── bottleneck@2.19.5 extraneous
                                          ├── brace-expansion@1.1.11 extraneous
                                          ├── braces@3.0.2 extraneous
                                          ├── browser-process-hrtime@1.0.0 extraneous
                                          ├── buffer-equal-constant-time@1.0.1 extraneous
                                          ├── buffer-from@1.1.2 extraneous
                                          ├── buffer-indexof@1.1.1 extraneous
                                          ├── buffer@5.7.1 extraneous
                                          ├── bufferhelper@0.2.1 extraneous
                                          ├── busboy@0.3.1 extraneous
                                          ├── button-events@1.0.2 extraneous
                                          ├── byte-length@1.0.2 extraneous
                                          ├── bytes@3.1.2 extraneous
                                          ├── cacheable-lookup@5.0.4 extraneous
                                          ├── cacheable-request@7.0.2 extraneous
                                          ├── call-bind@1.0.2 extraneous
                                          ├── callback-stream@1.1.0 extraneous
                                          ├── callsite@1.0.0 extraneous
                                          ├── capitalize@2.0.4 extraneous
                                          ├── caseless@0.12.0 extraneous
                                          ├── cert-info@1.5.1 extraneous
                                          ├── charenc@0.0.2 extraneous
                                          ├── chokidar@3.5.3 extraneous
                                          ├── chownr@1.1.4 extraneous
                                          ├── ci-info@3.3.2 extraneous
                                          ├── cli@0.4.5 extraneous
                                          ├── cliff@0.1.10 extraneous
                                          ├── cliui@7.0.4 extraneous
                                          ├── clone-response@1.0.2 extraneous
                                          ├── cluster-key-slot@1.1.0 extraneous
                                          ├── coap-packet@0.1.14 extraneous
                                          ├── coap@0.24.0 extraneous
                                          ├── coffee-compiler@0.3.2 extraneous
                                          ├── coffee-script@1.12.7 extraneous
                                          ├── coiot-coap@1.0.0 extraneous
                                          ├── color-convert@1.9.3 extraneous
                                          ├── color-name@1.1.3 extraneous
                                          ├── color-string@1.9.1 extraneous
                                          ├── color-support@1.1.3 extraneous
                                          ├── color@3.2.1 extraneous
                                          ├── colors@1.0.3 extraneous
                                          ├── colorspace@1.1.4 extraneous
                                          ├── combined-stream@1.0.8 extraneous
                                          ├── commander@6.2.1 extraneous
                                          ├── commist@1.1.0 extraneous
                                          ├── component-bind@1.0.0 extraneous
                                          ├── component-emitter@1.3.0 extraneous
                                          ├── component-inherit@0.0.3 extraneous
                                          ├── compressible@2.0.18 extraneous
                                          ├── compression@1.7.4 extraneous
                                          ├── concat-map@0.0.1 extraneous
                                          ├── concat-stream@1.6.2 extraneous
                                          ├── connect-flash@0.1.1 extraneous
                                          ├── console-control-strings@1.1.0 extraneous
                                          ├── content-disposition@0.5.4 extraneous
                                          ├── content-type@1.0.4 extraneous
                                          ├── cookie-parser@1.4.6 extraneous
                                          ├── cookie-signature@1.0.6 extraneous
                                          ├── cookie@0.4.2 extraneous
                                          ├── core-util-is@1.0.2 extraneous
                                          ├── cron-parser@3.5.0 extraneous
                                          ├── cross-spawn@7.0.3 extraneous
                                          ├── crypt@0.0.2 extraneous
                                          ├── crypto@1.0.1 extraneous
                                          ├── cssom@0.5.0 extraneous
                                          ├── cssstyle@2.3.0 extraneous
                                          ├── cycle@1.0.3 extraneous
                                          ├── d@1.0.1 extraneous
                                          ├── daemonize2@0.4.2 extraneous
                                          ├── dashdash@1.14.1 extraneous
                                          ├── data-urls@3.0.2 extraneous
                                          ├── debug@2.6.9 extraneous
                                          ├── decache@4.6.1 extraneous
                                          ├── decimal.js@10.3.1 extraneous
                                          ├── decompress-response@6.0.0 extraneous
                                          ├── deep-clone@3.0.3 extraneous
                                          ├── deep-equal@1.1.1 extraneous
                                          ├── deep-is@0.1.4 extraneous
                                          ├── defer-to-connect@2.0.1 extraneous
                                          ├── define-properties@1.1.3 extraneous
                                          ├── delayed-stream@1.0.0 extraneous
                                          ├── delegates@1.0.0 extraneous
                                          ├── denque@1.5.1 extraneous
                                          ├── depd@1.1.2 extraneous
                                          ├── destroy@1.0.4 extraneous
                                          ├── detect-libc@2.0.1 extraneous
                                          ├── dev-null@0.1.1 extraneous
                                          ├── dgram@1.0.1 extraneous
                                          ├── dicer@0.3.0 extraneous
                                          ├── diskusage@1.1.3 extraneous
                                          ├── dns-equal@1.0.0 extraneous
                                          ├── dns-packet@1.3.4 extraneous
                                          ├── dns-txt@2.0.2 extraneous
                                          ├── dnssd@0.4.1 extraneous
                                          ├── domexception@4.0.0 extraneous
                                          ├── dorita980@3.1.11 extraneous
                                          ├── dropbox-v2-api@2.5.3 extraneous
                                          ├── duplexer@0.1.2 extraneous
                                          ├── duplexify@3.7.1 extraneous
                                          ├── ecc-jsbn@0.1.2 extraneous
                                          ├── ecdsa-sig-formatter@1.0.11 extraneous
                                          ├── eckles@1.4.1 extraneous
                                          ├── ee-first@1.1.1 extraneous
                                          ├── emoji-regex@8.0.0 extraneous
                                          ├── enabled@2.0.0 extraneous
                                          ├── encodeurl@1.0.2 extraneous
                                          ├── end-of-stream@1.4.4 extraneous
                                          ├── engine.io-client@3.5.2 extraneous
                                          ├── engine.io-parser@2.2.1 extraneous
                                          ├── engine.io@3.5.0 extraneous
                                          ├── epoll@2.0.10 extraneous
                                          ├── es-abstract@1.20.1 extraneous
                                          ├── es-get-iterator@1.1.2 extraneous
                                          ├── es-shim-unscopables@1.0.0 extraneous
                                          ├── es-to-primitive@1.2.1 extraneous
                                          ├── es5-ext@0.10.53 extraneous
                                          ├── es6-iterator@2.0.3 extraneous
                                          ├── es6-map@0.1.5 extraneous
                                          ├── es6-promise@4.2.8 extraneous
                                          ├── es6-set@0.1.5 extraneous
                                          ├── es6-symbol@3.1.3 extraneous
                                          ├── esbuild@0.11.23 extraneous
                                          ├── escalade@3.1.1 extraneous
                                          ├── escape-html@1.0.3 extraneous
                                          ├── escodegen@2.0.0 extraneous
                                          ├── esprima@4.0.1 extraneous
                                          ├── estraverse@5.3.0 extraneous
                                          ├── esutils@2.0.3 extraneous
                                          ├── etag@1.8.1 extraneous
                                          ├── event-emitter@0.3.5 extraneous
                                          ├── event-stream@4.0.1 extraneous
                                          ├── event-target-shim@5.0.1 extraneous
                                          ├── eventemitter3@3.1.2 extraneous
                                          ├── execa@5.1.1 extraneous
                                          ├── express-fileupload@1.3.1 extraneous
                                          ├── express-session@1.17.2 extraneous
                                          ├── express@4.17.3 extraneous
                                          ├── ext@1.6.0 extraneous
                                          ├── extend@3.0.2 extraneous
                                          ├── extsprintf@1.3.0 extraneous
                                          ├── eyes@0.1.8 extraneous
                                          ├── fast-deep-equal@3.1.3 extraneous
                                          ├── fast-json-stable-stringify@2.1.0 extraneous
                                          ├── fast-levenshtein@2.0.6 extraneous
                                          ├── fast-srp-hap@2.0.4 extraneous
                                          ├── fast-text-encoding@1.0.4 extraneous
                                          ├── fast-xml-parser@3.21.1 extraneous
                                          ├── fastseries@2.0.0 extraneous
                                          ├── fecha@4.2.3 extraneous
                                          ├── file-stream-rotator@0.6.1 extraneous
                                          ├── file-type@3.9.0 extraneous
                                          ├── file-uri-to-path@1.0.0 extraneous
                                          ├── fill-range@7.0.1 extraneous
                                          ├── finalhandler@1.1.2 extraneous
                                          ├── fn.name@1.1.0 extraneous
                                          ├── follow-redirects@1.14.3 extraneous
                                          ├── for-each@0.3.3 extraneous
                                          ├── forever-agent@0.6.1 extraneous
                                          ├── form-data@2.3.3 extraneous
                                          ├── forwarded@0.2.0 extraneous
                                          ├── fresh@0.5.2 extraneous
                                          ├── from@0.1.7 extraneous
                                          ├── fs-constants@1.0.0 extraneous
                                          ├── fs-extra@10.1.0 extraneous
                                          ├── fs-minipass@2.1.0 extraneous
                                          ├── fs.realpath@1.0.0 extraneous
                                          ├── ftp@0.3.10 extraneous
                                          ├── function-bind@1.1.1 extraneous
                                          ├── function.prototype.name@1.1.5 extraneous
                                          ├── functions-have-names@1.2.3 extraneous
                                          ├── futoin-hkdf@1.4.3 extraneous
                                          ├── gauge@3.0.2 extraneous
                                          ├── gaxios@5.0.1 extraneous
                                          ├── gcp-metadata@5.0.0 extraneous
                                          ├── get-caller-file@2.0.5 extraneous
                                          ├── get-intrinsic@1.1.1 extraneous
                                          ├── get-ssl-certificate@2.3.3 extraneous
                                          ├── get-stream@5.2.0 extraneous
                                          ├── get-symbol-description@1.0.0 extraneous
                                          ├── getpass@0.1.7 extraneous
                                          ├── glob-parent@5.1.2 extraneous
                                          ├── glob-stream@6.1.0 extraneous
                                          ├── glob@7.2.0 extraneous
                                          ├── glossy@0.1.7 extraneous
                                          ├── google-auth-library@8.1.1 extraneous
                                          ├── google-p12-pem@4.0.0 extraneous
                                          ├── googleapis-common@5.1.0 extraneous
                                          ├── got@11.8.3 extraneous
                                          ├── graceful-fs@4.2.9 extraneous
                                          ├── greenlock-express@4.0.3 extraneous
                                          ├── greenlock-manager-fs@3.1.1 extraneous
                                          ├── greenlock-store-fs@3.2.2 extraneous
                                          ├── greenlock@4.0.4 extraneous
                                          ├── gtoken@6.1.0 extraneous
                                          ├── hap-controller@0.8.1 extraneous
                                          ├── hap-nodejs@0.9.8 extraneous
                                          ├── har-schema@2.0.0 extraneous
                                          ├── har-validator@5.1.5 extraneous
                                          ├── harmonyhubws@1.0.6 extraneous
                                          ├── has-bigints@1.0.2 extraneous
                                          ├── has-binary2@1.0.3 extraneous
                                          ├── has-cors@1.1.0 extraneous
                                          ├── has-property-descriptors@1.0.0 extraneous
                                          ├── has-symbols@1.0.3 extraneous
                                          ├── has-tostringtag@1.0.0 extraneous
                                          ├── has-unicode@2.0.1 extraneous
                                          ├── has@1.0.3 extraneous
                                          ├── he@1.2.0 extraneous
                                          ├── help-me@1.1.0 extraneous
                                          ├── hex-rgb@4.3.0 extraneous
                                          ├── hot-patcher@0.5.0 extraneous
                                          ├── html-encoding-sniffer@3.0.0 extraneous
                                          ├── http-cache-semantics@4.1.0 extraneous
                                          ├── http-cookie-agent@1.0.6 extraneous
                                          ├── http-errors@1.8.1 extraneous
                                          ├── http-parser-js@0.5.8 extraneous
                                          ├── http-proxy-agent@5.0.0 extraneous
                                          ├── http-proxy-middleware@2.0.3 extraneous
                                          ├── http-proxy-response-rewrite@0.0.1 extraneous
                                          ├── http-proxy@1.18.1 extraneous
                                          ├── http-signature@1.2.0 extraneous
                                          ├── http2-wrapper@1.0.3 extraneous
                                          ├── https-proxy-agent@5.0.0 extraneous
                                          ├── https@1.0.0 extraneous
                                          ├── human-signals@2.1.0 extraneous
                                          ├── iconv-lite@0.4.24 extraneous
                                          ├── ieee754@1.2.1 extraneous
                                          ├── immediate@3.0.6 extraneous
                                          ├── indexof@0.0.1 extraneous
                                          ├── inflight@1.0.6 extraneous
                                          ├── influx@4.2.3 extraneous
                                          ├── inherits@2.0.4 extraneous
                                          ├── int64-buffer@1.0.1 extraneous
                                          ├── internal-slot@1.0.3 extraneous
                                          ├── iobroker.admin@5.3.8 extraneous
                                          ├── iobroker.alexa2@3.11.2 extraneous
                                          ├── iobroker.alpha2@1.0.3 extraneous (git+ssh://git@github.com/Eisbaeeer/ioBroker.alpha2.git#803bd6302dca3e4b44164d23e58a8a096e21e972)
                                          ├── iobroker.backitup@2.4.10 extraneous
                                          ├── iobroker.deconz@1.3.21 extraneous
                                          ├── iobroker.device-reminder@1.2.9 extraneous
                                          ├── iobroker.discovery@3.0.5 extraneous
                                          ├── iobroker.harmony@1.2.2 extraneous
                                          ├── iobroker.history@2.2.0 extraneous
                                          ├── iobroker.homekit-controller@0.5.1 extraneous
                                          ├── iobroker.hue@3.7.0 extraneous
                                          ├── iobroker.icons-mfd-svg@1.1.0 extraneous
                                          ├── iobroker.influxdb@3.1.7 extraneous
                                          ├── iobroker.info@1.9.19 extraneous
                                          ├── iobroker.javascript@5.7.0 extraneous
                                          ├── iobroker.js-controller@4.0.23 extraneous
                                          ├── iobroker.mqtt@3.0.6 extraneous
                                          ├── iobroker.nuki-extended@2.3.1 extraneous
                                          ├── iobroker.nuki@1.6.0 extraneous
                                          ├── iobroker.openweathermap@0.2.5 extraneous
                                          ├── iobroker.parcel@0.0.20 extraneous
                                          ├── iobroker.pushover@3.0.2 extraneous
                                          ├── iobroker.roomba@1.1.4 extraneous
                                          ├── iobroker.rpi2@1.3.2 extraneous
                                          ├── iobroker.shelly@5.3.2 extraneous
                                          ├── iobroker.simple-api@2.7.0 extraneous
                                          ├── iobroker.smartmeter@3.3.4 extraneous
                                          ├── iobroker.socketio@4.2.0 extraneous
                                          ├── iobroker.sonoff@2.5.1 extraneous
                                          ├── iobroker.telegram@1.13.0 extraneous
                                          ├── iobroker.text2command@2.2.2 extraneous
                                          ├── iobroker.tr-064@4.2.16 extraneous
                                          ├── iobroker.vis-bars@0.1.4 extraneous
                                          ├── iobroker.vis-colorpicker@1.2.0 extraneous
                                          ├── iobroker.vis-history@1.0.0 extraneous
                                          ├── iobroker.vis-hqwidgets@1.2.0 extraneous
                                          ├── iobroker.vis-jqui-mfd@1.0.12 extraneous
                                          ├── iobroker.vis-justgage@1.0.2 extraneous
                                          ├── iobroker.vis-material-advanced@1.7.2 extraneous
                                          ├── iobroker.vis-metro@1.2.0 extraneous
                                          ├── iobroker.vis-players@0.1.6 extraneous
                                          ├── iobroker.vis-rgraph@0.0.2 extraneous
                                          ├── iobroker.vis-timeandweather@1.1.7 extraneous
                                          ├── iobroker.vis@1.4.15 extraneous
                                          ├── iobroker.web@4.3.0 extraneous
                                          ├── iobroker.wled@0.6.7 extraneous
                                          ├── iobroker.ws.server@1.0.1 extraneous
                                          ├── iobroker.ws@1.3.0 extraneous
                                          ├── iobroker.yahka@0.13.1 extraneous
                                          ├── iobroker.youtube@3.0.1 extraneous
                                          ├── ioredis@4.28.5 extraneous
                                          ├── ip@1.1.5 extraneous
                                          ├── ipaddr.js@1.9.1 extraneous
                                          ├── is-absolute@1.0.0 extraneous
                                          ├── is-arguments@1.1.1 extraneous
                                          ├── is-arrayish@0.3.2 extraneous
                                          ├── is-bigint@1.0.4 extraneous
                                          ├── is-binary-path@2.1.0 extraneous
                                          ├── is-boolean-object@1.1.2 extraneous
                                          ├── is-buffer@1.1.6 extraneous
                                          ├── is-callable@1.2.4 extraneous
                                          ├── is-date-object@1.0.5 extraneous
                                          ├── is-extglob@2.1.1 extraneous
                                          ├── is-fullwidth-code-point@3.0.0 extraneous
                                          ├── is-generator-function@1.0.10 extraneous
                                          ├── is-glob@4.0.3 extraneous
                                          ├── is-map@2.0.2 extraneous
                                          ├── is-nan@1.3.2 extraneous
                                          ├── is-negated-glob@1.0.0 extraneous
                                          ├── is-negative-zero@2.0.2 extraneous
                                          ├── is-number-object@1.0.7 extraneous
                                          ├── is-number@7.0.0 extraneous
                                          ├── is-plain-obj@3.0.0 extraneous
                                          ├── is-potential-custom-element-name@1.0.1 extraneous
                                          ├── is-regex@1.1.4 extraneous
                                          ├── is-relative@1.0.0 extraneous
                                          ├── is-set@2.0.2 extraneous
                                          ├── is-shared-array-buffer@1.0.2 extraneous
                                          ├── is-stream@2.0.1 extraneous
                                          ├── is-string@1.0.7 extraneous
                                          ├── is-symbol@1.0.4 extraneous
                                          ├── is-typed-array@1.1.9 extraneous
                                          ├── is-typedarray@1.0.0 extraneous
                                          ├── is-unc-path@1.0.0 extraneous
                                          ├── is-weakmap@2.0.1 extraneous
                                          ├── is-weakref@1.0.2 extraneous
                                          ├── is-weakset@2.0.2 extraneous
                                          ├── is-windows@1.0.2 extraneous
                                          ├── is@3.3.0 extraneous
                                          ├── isarray@1.0.0 extraneous
                                          ├── isexe@2.0.0 extraneous
                                          ├── isstream@0.1.2 extraneous
                                          ├── js-sdsl@2.1.4 extraneous
                                          ├── jsbn@0.1.1 extraneous
                                          ├── jsdom@19.0.0 extraneous
                                          ├── jshashes@1.0.8 extraneous
                                          ├── json-bigint@1.0.0 extraneous
                                          ├── json-buffer@3.0.1 extraneous
                                          ├── json-schema-traverse@0.4.1 extraneous
                                          ├── json-schema@0.4.0 extraneous
                                          ├── json-stable-stringify-without-jsonify@1.0.1 extraneous
                                          ├── json-stringify-safe@5.0.1 extraneous
                                          ├── jsonata@1.8.6 extraneous
                                          ├── jsonc-parser@3.0.0 extraneous
                                          ├── jsonfile@6.1.0 extraneous
                                          ├── jsonwebtoken@8.5.1 extraneous
                                          ├── jsprim@1.4.2 extraneous
                                          ├── jszip@3.10.0 extraneous
                                          ├── jwa@2.0.0 extraneous
                                          ├── jws@4.0.0 extraneous
                                          ├── keypairs@1.2.14 extraneous
                                          ├── keyv@4.1.1 extraneous
                                          ├── kuler@2.0.0 extraneous
                                          ├── layerr@0.1.2 extraneous
                                          ├── le-acme-core@2.1.4 extraneous
                                          ├── le-challenge-fs@2.0.9 extraneous
                                          ├── le-sni-auto@2.1.9 extraneous
                                          ├── leven@2.1.0 extraneous
                                          ├── levn@0.3.0 extraneous
                                          ├── libsodium-wrappers@0.7.10 extraneous
                                          ├── libsodium@0.7.10 extraneous
                                          ├── lie@3.1.1 extraneous
                                          ├── loadavg-windows@1.1.1 extraneous
                                          ├── localforage@1.10.0 extraneous
                                          ├── lodash.defaults@4.2.0 extraneous
                                          ├── lodash.flatten@4.4.0 extraneous
                                          ├── lodash.includes@4.3.0 extraneous
                                          ├── lodash.isarguments@3.1.0 extraneous
                                          ├── lodash.isboolean@3.0.3 extraneous
                                          ├── lodash.isinteger@4.0.4 extraneous
                                          ├── lodash.isnumber@3.0.3 extraneous
                                          ├── lodash.isplainobject@4.0.6 extraneous
                                          ├── lodash.isstring@4.0.1 extraneous
                                          ├── lodash.once@4.1.1 extraneous
                                          ├── lodash@4.17.21 extraneous
                                          ├── logform@2.4.1 extraneous
                                          ├── long-timeout@0.1.1 extraneous
                                          ├── lowercase-keys@2.0.0 extraneous
                                          ├── lru_map@0.3.3 extraneous
                                          ├── lru-cache@6.0.0 extraneous
                                          ├── luxon@1.28.0 extraneous
                                          ├── macaddress@0.5.1 extraneous
                                          ├── make-dir@3.1.0 extraneous
                                          ├── map-stream@0.0.7 extraneous
                                          ├── md5@2.3.0 extraneous
                                          ├── mdns-discovery@0.2.6 extraneous
                                          ├── media-typer@0.3.0 extraneous
                                          ├── merge-descriptors@1.0.1 extraneous
                                          ├── merge-stream@2.0.0 extraneous
                                          ├── methods@1.1.2 extraneous
                                          ├── micromatch@4.0.4 extraneous
                                          ├── mime-db@1.51.0 extraneous
                                          ├── mime-types@2.1.34 extraneous
                                          ├── mime@1.6.0 extraneous
                                          ├── mimic-fn@2.1.0 extraneous
                                          ├── mimic-response@1.0.1 extraneous
                                          ├── minimatch@3.1.2 extraneous
                                          ├── minimist@1.2.6 extraneous
                                          ├── minipass@3.3.4 extraneous
                                          ├── minizlib@2.1.2 extraneous
                                          ├── mkdirp-classic@0.5.3 extraneous
                                          ├── mkdirp@1.0.4 extraneous
                                          ├── moment@2.29.3 extraneous
                                          ├── mqtt-connection@4.1.0 extraneous
                                          ├── mqtt-packet@6.10.0 extraneous
                                          ├── mqtt@2.18.9 extraneous
                                          ├── ms@2.0.0 extraneous
                                          ├── multicast-dns-service-types@1.1.0 extraneous
                                          ├── multicast-dns@6.2.3 extraneous
                                          ├── mute-stream@0.0.8 extraneous
                                          ├── nan@2.15.0 extraneous
                                          ├── nearest-color@0.4.4 extraneous
                                          ├── negotiator@0.6.3 extraneous
                                          ├── nested-property@4.0.0 extraneous
                                          ├── netmask@2.0.2 extraneous
                                          ├── next-tick@1.0.0 extraneous
                                          ├── node-addon-api@1.7.2 extraneous
                                          ├── node-dht-sensor@0.4.3 extraneous
                                          ├── node-fetch@2.6.7 extraneous
                                          ├── node-forge@1.3.1 extraneous
                                          ├── node-gyp-build@4.5.0 extraneous
                                          ├── node-hkdf-sync@1.0.0 extraneous
                                          ├── node-hue-api@4.0.11 extraneous
                                          ├── node-inspect@2.0.0 extraneous
                                          ├── node-mndp@0.0.3 extraneous
                                          ├── node-persist@0.0.11 extraneous
                                          ├── node-rest-client@3.1.1 extraneous
                                          ├── node-schedule@2.1.0 extraneous
                                          ├── node-ssdp@4.0.1 extraneous
                                          ├── node-telegram-bot-api@0.57.0 extraneous
                                          ├── node-wol@0.1.1 extraneous
                                          ├── node.extend@2.0.2 extraneous
                                          ├── nopt@5.0.0 extraneous
                                          ├── normalize-path@3.0.0 extraneous
                                          ├── normalize-url@6.1.0 extraneous
                                          ├── npm-run-path@4.0.1 extraneous
                                          ├── npmlog@5.0.1 extraneous
                                          ├── nuki-bridge-api@1.8.0 extraneous
                                          ├── nuki-web-api@2.2.1 extraneous
                                          ├── number-allocator@1.0.10 extraneous
                                          ├── nwsapi@2.2.1 extraneous
                                          ├── oauth-sign@0.9.0 extraneous
                                          ├── object-assign@4.1.1 extraneous
                                          ├── object-hash@2.2.0 extraneous
                                          ├── object-inspect@1.12.0 extraneous
                                          ├── object-is@1.1.5 extraneous
                                          ├── object-keys@1.1.1 extraneous
                                          ├── object.assign@4.1.2 extraneous
                                          ├── on-finished@2.3.0 extraneous
                                          ├── on-headers@1.0.2 extraneous
                                          ├── once@1.4.0 extraneous
                                          ├── one-time@1.0.0 extraneous
                                          ├── onetime@5.1.2 extraneous
                                          ├── open-sml@1.0.4 extraneous
                                          ├── optionator@0.8.3 extraneous
                                          ├── ordered-read-streams@1.0.1 extraneous
                                          ├── p-cancelable@2.1.1 extraneous
                                          ├── p-finally@1.0.0 extraneous
                                          ├── p-map@2.1.0 extraneous
                                          ├── p-queue@6.6.2 extraneous
                                          ├── p-timeout@3.2.0 extraneous
                                          ├── pako@1.0.11 extraneous
                                          ├── parse5@6.0.1 extraneous
                                          ├── parseqs@0.0.6 extraneous
                                          ├── parseuri@0.0.6 extraneous
                                          ├── parseurl@1.3.3 extraneous
                                          ├── passport-local@1.0.0 extraneous
                                          ├── passport-strategy@1.0.0 extraneous
                                          ├── passport@0.5.2 extraneous
                                          ├── path-dirname@1.0.2 extraneous
                                          ├── path-is-absolute@1.0.1 extraneous
                                          ├── path-key@3.1.1 extraneous
                                          ├── path-posix@1.0.0 extraneous
                                          ├── path-to-regexp@0.1.7 extraneous
                                          ├── pause-stream@0.0.11 extraneous
                                          ├── pause@0.0.1 extraneous
                                          ├── performance-now@2.1.0 extraneous
                                          ├── picocolors@1.0.0 extraneous
                                          ├── picomatch@2.3.1 extraneous
                                          ├── pidusage@3.0.0 extraneous
                                          ├── pkginfo@0.3.1 extraneous
                                          ├── prelude-ls@1.1.2 extraneous
                                          ├── process-nextick-args@2.0.1 extraneous
                                          ├── promisify-child-process@4.1.1 extraneous
                                          ├── prompt@1.3.0 extraneous
                                          ├── proper-lockfile@4.1.2 extraneous
                                          ├── proxy-addr@2.0.7 extraneous
                                          ├── psl@1.8.0 extraneous
                                          ├── pump@3.0.0 extraneous
                                          ├── pumpify@1.5.1 extraneous
                                          ├── punycode@2.1.1 extraneous
                                          ├── pushover-notifications@1.2.2 extraneous
                                          ├── q@1.1.2 extraneous
                                          ├── qs@6.9.7 extraneous
                                          ├── querystring@0.2.1 extraneous
                                          ├── querystringify@2.2.0 extraneous
                                          ├── quick-lru@5.1.1 extraneous
                                          ├── random-bytes@1.0.0 extraneous
                                          ├── range-parser@1.2.1 extraneous
                                          ├── rasha@1.2.5 extraneous
                                          ├── raw-body@2.4.3 extraneous
                                          ├── read@1.0.7 extraneous
                                          ├── readable-stream@2.3.7 extraneous
                                          ├── readdirp@3.6.0 extraneous
                                          ├── readline-sync@1.4.10 extraneous
                                          ├── readline@1.3.0 extraneous
                                          ├── redirect-https@1.3.1 extraneous
                                          ├── redis-commands@1.7.0 extraneous
                                          ├── redis-errors@1.2.0 extraneous
                                          ├── redis-parser@3.0.0 extraneous
                                          ├── regexp.prototype.flags@1.4.3 extraneous
                                          ├── reinterval@1.1.0 extraneous
                                          ├── remove-trailing-separator@1.1.0 extraneous
                                          ├── request-promise-core@1.1.4 extraneous
                                          ├── request-promise-native@1.0.9 extraneous
                                          ├── request-promise@4.2.6 extraneous
                                          ├── request@2.88.2 extraneous
                                          ├── require-directory@2.1.1 extraneous
                                          ├── requires-port@1.0.0 extraneous
                                          ├── resolve-alpn@1.2.1 extraneous
                                          ├── respjs@4.2.0 extraneous
                                          ├── responselike@2.0.0 extraneous
                                          ├── retry@0.12.0 extraneous
                                          ├── revalidator@0.1.8 extraneous
                                          ├── rfdc@1.3.0 extraneous
                                          ├── rgb-hex@3.0.0 extraneous
                                          ├── rimraf@3.0.2 extraneous
                                          ├── rpi-gpio-buttons@2.0.1 extraneous
                                          ├── rpi-gpio@2.1.7 extraneous
                                          ├── rsa-compat@1.9.4 extraneous
                                          ├── safe-buffer@5.1.2 extraneous
                                          ├── safe-replace@1.1.0 extraneous
                                          ├── safe-stable-stringify@2.3.1 extraneous
                                          ├── safer-buffer@2.1.2 extraneous
                                          ├── sax@1.2.4 extraneous
                                          ├── saxes@5.0.1 extraneous
                                          ├── semaphore@1.0.5 extraneous
                                          ├── semver@7.3.5 extraneous
                                          ├── send@0.17.2 extraneous
                                          ├── seq-logging@1.1.1 extraneous
                                          ├── serialport@10.4.0 extraneous
                                          ├── serve-static@1.14.2 extraneous
                                          ├── set-blocking@2.0.0 extraneous
                                          ├── setimmediate@1.0.5 extraneous
                                          ├── setprototypeof@1.2.0 extraneous
                                          ├── shebang-command@2.0.0 extraneous
                                          ├── shebang-regex@3.0.0 extraneous
                                          ├── shelly-iot@1.1.2 extraneous
                                          ├── side-channel@1.0.4 extraneous
                                          ├── signal-exit@3.0.7 extraneous
                                          ├── simple-swizzle@0.2.2 extraneous
                                          ├── smartmeter-obis@3.0.2 extraneous
                                          ├── socket.io-adapter@1.1.2 extraneous
                                          ├── socket.io-client@2.4.0 extraneous
                                          ├── socket.io-parser@3.4.1 extraneous
                                          ├── socket.io@2.4.1 extraneous
                                          ├── socksv5@0.0.6 extraneous
                                          ├── sorted-array-functions@1.3.0 extraneous
                                          ├── source-map-support@0.5.21 extraneous
                                          ├── source-map@0.6.1 extraneous
                                          ├── split@1.0.1 extraneous
                                          ├── split2@2.2.0 extraneous
                                          ├── sshpk@1.17.0 extraneous
                                          ├── stack-trace@0.0.10 extraneous
                                          ├── standard-as-callback@2.1.0 extraneous
                                          ├── statuses@1.5.0 extraneous
                                          ├── stealthy-require@1.1.1 extraneous
                                          ├── stream-combiner@0.2.2 extraneous
                                          ├── stream-shift@1.0.1 extraneous
                                          ├── streamsearch@0.1.2 extraneous
                                          ├── string_decoder@1.1.1 extraneous
                                          ├── string-width@4.2.3 extraneous
                                          ├── string.prototype.trimend@1.0.5 extraneous
                                          ├── string.prototype.trimstart@1.0.5 extraneous
                                          ├── strip-ansi@6.0.1 extraneous
                                          ├── strip-final-newline@2.0.0 extraneous
                                          ├── strnum@1.0.5 extraneous
                                          ├── suncalc2@1.8.1 extraneous
                                          ├── symbol-tree@3.2.4 extraneous
                                          ├── sync-exec@0.6.2 extraneous
                                          ├── systeminformation@5.11.15 extraneous
                                          ├── tar-fs@2.1.1 extraneous
                                          ├── tar-stream@2.2.0 extraneous
                                          ├── tar@6.1.11 extraneous
                                          ├── tcp-ping@0.1.1 extraneous
                                          ├── text-hex@1.0.0 extraneous
                                          ├── through@2.3.8 extraneous
                                          ├── through2-filter@3.0.0 extraneous
                                          ├── through2@2.0.5 extraneous
                                          ├── thunky@1.1.0 extraneous
                                          ├── to-absolute-glob@2.0.2 extraneous
                                          ├── to-array@0.1.4 extraneous
                                          ├── to-regex-range@5.0.1 extraneous
                                          ├── toidentifier@1.0.1 extraneous
                                          ├── tough-cookie@4.0.0 extraneous
                                          ├── tr-O64@0.2.4 extraneous
                                          ├── tr46@0.0.3 extraneous
                                          ├── triple-beam@1.3.0 extraneous
                                          ├── tslib@1.14.1 extraneous
                                          ├── tunnel-agent@0.6.0 extraneous
                                          ├── tweetnacl@0.14.5 extraneous
                                          ├── type-check@0.3.2 extraneous
                                          ├── type-is@1.6.18 extraneous
                                          ├── type@1.2.0 extraneous
                                          ├── typedarray@0.0.6 extraneous
                                          ├── typescript@4.7.3 extraneous
                                          ├── uid-safe@2.1.5 extraneous
                                          ├── ultron@1.1.1 extraneous
                                          ├── unbox-primitive@1.0.2 extraneous
                                          ├── unc-path-regex@0.1.2 extraneous
                                          ├── unique-stream@2.3.1 extraneous
                                          ├── universalify@2.0.0 extraneous
                                          ├── unix-dgram@2.0.4 extraneous
                                          ├── unpipe@1.0.0 extraneous
                                          ├── uri-js@4.4.1 extraneous
                                          ├── url-join@4.0.1 extraneous
                                          ├── url-parse@1.5.10 extraneous
                                          ├── url-template@2.0.8 extraneous
                                          ├── ursa-optional@0.9.10 extraneous
                                          ├── usb@1.9.2 extraneous
                                          ├── util-deprecate@1.0.2 extraneous
                                          ├── util@0.12.4 extraneous
                                          ├── utils-merge@1.0.1 extraneous
                                          ├── uuid@8.3.2 extraneous
                                          ├── vary@1.1.2 extraneous
                                          ├── verror@1.10.0 extraneous
                                          ├── virtual-tsc@0.6.2 extraneous
                                          ├── vm2@3.9.9 extraneous
                                          ├── vows@0.5.13 extraneous
                                          ├── w3c-hr-time@1.0.2 extraneous
                                          ├── w3c-xmlserializer@3.0.0 extraneous
                                          ├── wake_on_lan@1.0.0 extraneous
                                          ├── weak-daemon@1.0.3 extraneous
                                          ├── webdav@4.10.0 extraneous
                                          ├── webidl-conversions@3.0.1 extraneous
                                          ├── websocket-stream@5.5.2 extraneous
                                          ├── whatwg-encoding@2.0.0 extraneous
                                          ├── whatwg-mimetype@3.0.0 extraneous
                                          ├── whatwg-url@5.0.0 extraneous
                                          ├── which-boxed-primitive@1.0.2 extraneous
                                          ├── which-collection@1.0.1 extraneous
                                          ├── which-typed-array@1.1.8 extraneous
                                          ├── which@2.0.2 extraneous
                                          ├── wide-align@1.1.5 extraneous
                                          ├── winston-daily-rotate-file@4.7.1 extraneous
                                          ├── winston-seq-updated@1.0.4 extraneous
                                          ├── winston-syslog@2.6.0 extraneous
                                          ├── winston-transport@4.5.0 extraneous
                                          ├── winston@3.8.1 extraneous
                                          ├── word-wrap@1.2.3 extraneous
                                          ├── wrap-ansi@7.0.0 extraneous
                                          ├── wrappy@1.0.2 extraneous
                                          ├── ws@8.5.0 extraneous
                                          ├── xml-name-validator@4.0.0 extraneous
                                          ├── xml2js@0.4.23 extraneous
                                          ├── xmlbuilder@11.0.1 extraneous
                                          ├── xmlchars@2.2.0 extraneous
                                          ├── xmlhttprequest-ssl@1.6.3 extraneous
                                          ├── xregexp@2.0.0 extraneous
                                          ├── xtend@4.0.2 extraneous
                                          ├── y18n@5.0.8 extraneous
                                          ├── yallist@4.0.0 extraneous
                                          ├── yargs-parser@21.0.1 extraneous
                                          ├── yargs@17.5.1 extraneous
                                          └── yeast@0.1.2 extraneous
