  4. VIS - No Connection
VIS - No Connection
vis
185 Beiträge 10 Kommentatoren 22.1k Aufrufe 10 Beobachtet
  • P Offline
    Pahan
    @homoran sagte in VIS - No Connection:
    iobroker list instances
    gibt aus:
    pi@raspberrypi:~ $ iobroker list instances
      system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.admin.1                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.binance.0                : binance               : raspberrypi                              - disabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
      system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              - disabled
      system.adapter.email.0                  : email                 : raspberrypi                              - disabled
      system.adapter.eufy-security.0          : eufy-security         : raspberrypi                              - disabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
      system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              - disabled
      system.adapter.gartenbewaesserung.0     : gartenbewaesserung    : raspberrypi                              - disabled
      system.adapter.history.0                : history               : raspberrypi                              - disabled
      system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              - disabled
      system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              - disabled, port: 18701
      system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              - disabled, port: 12001
      system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              - disabled, port: 12010
      system.adapter.ical.0                   : ical                  : raspberrypi                              - disabled
      system.adapter.ical.1                   : ical                  : raspberrypi                              - disabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
      system.adapter.influxdb.0               : influxdb              : raspberrypi                              - disabled, port: 8086
      system.adapter.info.0                   : info                  : raspberrypi                              - disabled
      system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
      system.adapter.javascript.0             : javascript            : raspberrypi                              - disabled
      system.adapter.logparser.0              : logparser             : raspberrypi                              - disabled
      system.adapter.mercedesme.0             : mercedesme            : raspberrypi                              - disabled
      system.adapter.mihome-lamp.0            : mihome-lamp           : raspberrypi                              - disabled, port: 54321
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
      system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
      system.adapter.snmp.0                   : snmp                  : raspberrypi                              - disabled
      system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              - disabled
      system.adapter.sprinklecontrol.0        : sprinklecontrol       : raspberrypi                              - disabled
      system.adapter.synology.0               : synology              : raspberrypi                              - disabled, port: 5000
      system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              - disabled
      system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
      system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              - disabled
      system.adapter.upnp.0                   : upnp                  : raspberrypi                              - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
    + instance is alive
    pi@raspberrypi:~ $
    • P Pahan
      gibt aus:
      + instance is alive
      pi@raspberrypi:~ $
      @pahan sagte in VIS - No Connection:
      admin.1
      iobroker del iobroker.admin.1
      iobroker start iobroker.admin.0
      • P Pahan
        gibt aus:
        + instance is alive
        pi@raspberrypi:~ $
        HomoranH Offline
        HomoranH Offline
        beide auf Port 8081 geht ja auch nicht.
        deswegen laufen wahrscheinlich beide nicht mehr
        iobroker start admin.0
        P 1 Antwort Letzte Antwort
          Pahan
          schrieb am zuletzt editiert von Pahan
          er ist angesprungen, vielen vielen Dank für Eure Unterstützung !!!
          • P Pahan
            HomoranH Offline
            HomoranH Offline
            er ist angesprungen
            und spätestens jetzt den admin.1 löschen
            • P Offline
              Pahan
              aber jetzt mal eine generelle Frage zum Abschluss:
              ich werde es in Zukunft sein lassen, auf Beta zu laufen, diese habe ich in den Einstellungen auch schon gelöscht.
              Was empfiehlt sich nun, alle Adapter auf die stable Version downzugraden oder das doch so laufen zu lassen?
              HomoranH BananaJoeB 2 Antworten Letzte Antwort
              • P Pahan
                HomoranH Offline
                HomoranH Offline
                wenn jetzt (wirklich) keine Probleme mehr sind lässt du das Repo auf stable.
                Irgendwann sind die jetzigen Verionen dann auch da drin. Danach kommen auch dort weitere Upgrades
                • P Pahan
                  BananaJoeB Offline
                  BananaJoeB Offline
                  BananaJoe
                  Öhm, du kannst auch alles auf Beta laufen lassen (mache ich zum Beispiel). Dann solltest du aber halt eine gute Backup-Strategie haben für den Fall es es mal Mist ist (hatte ich aber erst einmal).
                  Mein ioBroker läuft in einer VM (virtuelle Maschine), da hab ich eine Kopie des kompletten Systems. Und/oder ich kann Snapshots machen (Zustand einfrieren um später dahin zurück springen zu können.)
                  Im Prinzip könnet die Komplettsicherung des Ordners /opt/iobroker reichen wenn ich mich nicht irre. Der müsste im Fehlerfall gelöscht und wieder zurückkopiert werden (unter Beibehaltung aller Besitzer und Berechtigungen).
                  Wenn man das eher scheut dann halt auf Stable bleiben (aber selbst da hätte ich gerne ein simples Backup. Ich liebe VMs einfach)
                  • BananaJoeB BananaJoe
                    Pahan
                    Hallo liebe Community,
                    ihr habt mir kürzlich sehr geholfen und ich hatte meinen iobroker zum Laufen gebracht, leider hielt das nicht lange....
                    Aktuell läuft wieder nichts, weder VIS noch die Admin Instanz ist erreichbar. Wenn ich per Shell "iobroker stop" ausführe, um diesen danach zu "fixen", dann springt der Kursor sofort nach der Eingabe in die nächste Zeile, so als ob er nichts ausgeführt hat. Nach dem Befehl "iobroker fix" passiert genau das gleiche.
                    Könnten wir uns bitte zusammen auf Fehlersuche begeben?
                    Der Befehl:
                    which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                    liefert folgendes:
                    pi@raspberrypi:/opt/iobroker $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v14.19.0
                    v14.19.0
                    6.14.16
                    pi
                    /opt/iobroker
                    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:3 https://packages.grafana.com/oss/deb stable InRelease
                    Hit:4 https://deb.nodesource.com/node_14.x bullseye InRelease
                    Hit:5 https://repos.influxdata.com/debian bullseye InRelease
                    Reading package lists... Done
                    226 packages can be upgraded. Run 'apt list --upgradable' to see them.
                    nodejs:
                      Installed: 14.19.0-deb-1nodesource1
                      Candidate: 14.20.0-deb-1nodesource1
                      Version table:
                         14.20.0-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
                     *** 14.19.0-deb-1nodesource1 100
                         12.22.12~dfsg-1~deb11u1 500
                    Das blöde ist, dass ich seit dem letzten Fix rein gar nix gemacht hatte. Ich vermute, das Problem kommt daher, weil der Speicher voll gelaufen ist und dadurch nichts mehr ging. Eine 17GB log-Datei habe ich bereits gelöscht
                    • P Pahan
                      Der Befehl:
                      liefert folgendes:
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v14.19.0
                      v14.19.0
                      6.14.16
                      pi
                      /opt/iobroker
                      nodejs:
                        Version table:
                      Das ist 'linuxisch' für 'alles okay, Befehl ausgeführt'. Fehler werden zurückgemeldet.
                      • P Pahan
                        Der Befehl:
                        liefert folgendes:
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v14.19.0
                        v14.19.0
                        6.14.16
                        pi
                        /opt/iobroker
                        nodejs:
                          Version table:
                        Das sind schon mal 226 Fehler, die per Update zu bereinigen sind:
                        iob stop
                        sudo apt update
                        sudo apt full-upgrade
                        sudo reboot
                          Pahan
                          @thomas-braun sagte in VIS - No Connection:
                          Das ist schon klar, aber es passiert sofort, früher hatte er zumindest mal eine halbe Sekunde gedauert.
                          Nach dem "iobroker fix" passiert exakt das Gleiche, nämlich nichts
                          • P Pahan
                            @pahan
                            Erst die anderen Hausaufgaben...
                              @pahan
                              Pahan
                              #66
                              alles klar, gerne.
                              Bin dabei...melde mich gleich zurück
                              • P Pahan
                                alles klar, gerne.
                                #67
                                @pahan
                                Das System auf Stand halten darfst du dann künftig eigenständig und vor allen Dingen regelmäßig!! selber machen.
                                  @pahan
                                  Pahan
                                  #68
                                  @pahan
                                  also quasi das mit dem "full-upgrade" ?
                                  Wie oft sollte man soetwas machen ? 1x Woche ?
                                  Generell bin ich davon keinesfalls abgeneigt, ganz klar !
                                  Wenn wir meinen iobroker dieses mal nochmal zum Laufen bringen, hätte ich noch gerne verstanden, wie eine Log-Datei 17GB groß werden kann und vor allem, wie man das verhindern kann.
                                  • P Pahan
                                    @pahan
                                    #69
                                    Ja.
                                    Das hängt davon ab, welche es ist und was drin steht. In einem 'runden' System sollte wenig Anlass dazu sein, das log files so hochfrequent befüllt werden müssten.
                                      Ja.
                                      Pahan
                                      #70
                                      Ok, das Upgrade werkelt langsam vor sich hin.
                                      Was wären meine nächsten Aktionen nach dem Reboot?
                                      Soll ich gleich versuchen, den iobroker direkt zu starten ? Oder vorher noch was anderes erledigen?
                                      • P Pahan
                                        #71
                                        Der startet eh von alleine. Jedenfalls im Normalfall.
                                        cd /opt/iobroker
                                        npm ls
                                        anschauen.
                                          cd /opt/iobroker
                                          npm ls
                                          anschauen.
                                          Pahan
                                          #72
                                          cd /opt/iobroker
                                          npm ls
                                          anschauen.
                                          liefert folgendes, wobei ich den Anfang abgeschnitten hatte, da der "Payload" sonst zu lange wird und nicht durchgeht
                                          ├─┬ iobroker.synology@2.1.7
                                          │ ├─┬ @iobroker/adapter-core@2.6.0
                                          │ │ └─┬ @types/iobroker@4.0.3
                                          │ │   └── @types/node@17.0.13 deduped
                                          │ ├── moment@2.29.1 deduped
                                          │ ├─┬ simple-ssh@1.1.0
                                          │ │ ├─┬ ssh2@1.10.0
                                          │ │ │ ├── asn1@0.2.6 deduped
                                          │ │ │ ├─┬ bcrypt-pbkdf@1.0.2
                                          │ │ │ │ └── tweetnacl@0.14.5 deduped
                                          │ │ │ ├─┬ cpu-features@0.0.4
                                          │ │ │ │ ├── buildcheck@0.0.3
                                          │ │ │ │ └── nan@2.15.0 deduped
                                          │ │ └── xtend@4.0.2 deduped
                                          │ └─┬ syno@3.0.0 (git+https://github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                                          │   ├── commander@4.1.1
                                          │   ├─┬ js-yaml@3.14.1
                                          │   │ ├─┬ argparse@1.0.10
                                          │   │ │ └── sprintf-js@1.0.3
                                          │   │ └── esprima@4.0.1 deduped
                                          │   ├── lodash@4.17.21 deduped
                                          │   ├── minimist@0.2.1
                                          │   ├─┬ nconf@0.10.0
                                          │   │ ├── async@1.5.2
                                          │   │ ├── ini@1.3.8
                                          │   │ ├── secure-keys@1.0.0
                                          │   │ └─┬ yargs@3.32.0
                                          │   │   ├── camelcase@2.1.1
                                          │   │   ├─┬ cliui@3.2.0
                                          │   │   │ ├── string-width@1.0.2 deduped
                                          │   │   │ ├── strip-ansi@3.0.1 deduped
                                          │   │   │ └─┬ wrap-ansi@2.1.0
                                          │   │   │   └── strip-ansi@3.0.1 deduped
                                          │   │   ├── decamelize@1.2.0
                                          │   │   ├─┬ os-locale@1.4.0
                                          │   │   │ └─┬ lcid@1.0.0
                                          │   │   │   └── invert-kv@1.0.0
                                          │   │   ├─┬ string-width@1.0.2
                                          │   │   │ ├── code-point-at@1.1.0
                                          │   │   │ ├─┬ is-fullwidth-code-point@1.0.0
                                          │   │   │ │ └── number-is-nan@1.0.1
                                          │   │   ├── window-size@0.1.4
                                          │   │   └── y18n@3.2.2
                                          │   ├── ospath@1.2.2
                                          │   ├─┬ otplib@11.0.1
                                          │   │ └── thirty-two@1.0.2
                                          │   ├── pluralize@8.0.0
                                          │   └── request@2.88.2 deduped
                                          ├─┬ iobroker.tankerkoenig@2.1.1
                                          │ ├── @iobroker/adapter-core@2.5.1 deduped
                                          │ ├── request@2.88.2 deduped
                                          │ └── xml2js@0.4.23 deduped
                                          ├─┬ iobroker.tr-064@4.2.16
                                          │ │ └─┬ @types/iobroker@4.0.2
                                          │ ├── mdns-discovery@0.2.6 deduped
                                          │ ├─┬ tr-O64@0.2.4
                                          │ │ ├── async@2.6.3 deduped
                                          │ │ ├── eyes@0.1.8
                                          │ │ ├── request@2.88.2 deduped
                                          │ │ └── xml2js@0.4.23 deduped
                                          ├─┬ iobroker.trashschedule@1.4.5
                                          │ └─┬ @iobroker/adapter-core@2.6.0
                                          ├─┬ iobroker.upnp@1.0.21
                                          │ ├── ip@1.1.5
                                          │ ├── node-schedule@2.1.0 deduped
                                          │ ├── node-ssdp@4.0.1 deduped
                                          │ ├─┬ parsexmlresponse@0.0.5
                                          │ ├─┬ portfinder@1.0.28
                                          │ │ ├─┬ debug@3.2.7
                                          │ │ │ └── ms@2.1.3
                                          │ │ └─┬ mkdirp@0.5.6
                                          │ │   └── minimist@1.2.6
                                          │ ├── xml2js@0.4.23 deduped
                                          │ └── xmldom@0.6.0
                                          ├─┬ iobroker.vis@1.4.15
                                          │ ├─┬ axios@0.26.1
                                          │ │ └── follow-redirects@1.15.1
                                          │ └── jsonwebtoken@8.5.1 deduped
                                          ├── iobroker.vis-canvas-gauges@0.1.5
                                          ├── iobroker.vis-hqwidgets@1.2.0
                                          ├─┬ iobroker.vis-icontwo@0.87.0
                                          │ ├── minimist@1.2.5
                                          │ └─┬ np@7.6.0
                                          │   ├─┬ @samverschueren/stream-to-observable@0.3.1
                                          │   │ └── any-observable@0.3.0
                                          │   ├── any-observable@0.5.1
                                          │   ├── async-exit-hook@2.0.1
                                          │   ├─┬ chalk@4.1.2
                                          │   │ ├─┬ ansi-styles@4.3.0
                                          │   │ │ └─┬ color-convert@2.0.1
                                          │   │ │   └── color-name@1.1.4
                                          │   │ └─┬ supports-color@7.2.0
                                          │   │   └── has-flag@4.0.0
                                          │   ├─┬ cosmiconfig@7.0.1
                                          │   │ ├── @types/parse-json@4.0.0
                                          │   │ ├─┬ import-fresh@3.3.0
                                          │   │ │ ├─┬ parent-module@1.0.1
                                          │   │ │ │ └── callsites@3.1.0 deduped
                                          │   │ │ └── resolve-from@4.0.0
                                          │   │ ├─┬ parse-json@5.2.0
                                          │   │ │ ├─┬ @babel/code-frame@7.16.7
                                          │   │ │ │ └─┬ @babel/highlight@7.16.10
                                          │   │ │ │   ├── @babel/helper-validator-identifier@7.16.7
                                          │   │ │ │   ├─┬ chalk@2.4.2
                                          │   │ │ │   │ ├─┬ ansi-styles@3.2.1
                                          │   │ │ │   │ │ └── color-convert@1.9.3 deduped
                                          │   │ │ │   │ ├── escape-string-regexp@1.0.5
                                          │   │ │ │   │ └─┬ supports-color@5.5.0
                                          │   │ │ │   │   └── has-flag@3.0.0
                                          │   │ │ │   └── js-tokens@4.0.0
                                          │   │ │ ├─┬ error-ex@1.3.2
                                          │   │ │ │ └── is-arrayish@0.2.1
                                          │   │ │ ├── json-parse-even-better-errors@2.3.1
                                          │   │ │ └── lines-and-columns@1.2.4
                                          │   │ ├── path-type@4.0.0
                                          │   │ └── yaml@1.10.2
                                          │   ├─┬ del@6.0.0
                                          │   │ ├─┬ globby@11.1.0
                                          │   │ │ ├── array-union@2.1.0
                                          │   │ │ ├─┬ dir-glob@3.0.1
                                          │   │ │ │ └── path-type@4.0.0 deduped
                                          │   │ │ ├─┬ fast-glob@3.2.11
                                          │   │ │ │ ├── @nodelib/fs.stat@2.0.5
                                          │   │ │ │ ├─┬ @nodelib/fs.walk@1.2.8
                                          │   │ │ │ │ ├─┬ @nodelib/fs.scandir@2.1.5
                                          │   │ │ │ │ │ ├── @nodelib/fs.stat@2.0.5 deduped
                                          │   │ │ │ │ │ └─┬ run-parallel@1.2.0
                                          │   │ │ │ │ │   └── queue-microtask@1.2.3
                                          │   │ │ │ │ └─┬ fastq@1.13.0
                                          │   │ │ │ │   └── reusify@1.0.4
                                          │   │ │ │ ├── glob-parent@5.1.2 deduped
                                          │   │ │ │ ├── merge2@1.4.1 deduped
                                          │   │ │ │ └── micromatch@4.0.4 deduped
                                          │   │ │ ├── ignore@5.2.0
                                          │   │ │ └── slash@3.0.0 deduped
                                          │   │ ├── graceful-fs@4.2.9 deduped
                                          │   │ ├── is-glob@4.0.3 deduped
                                          │   │ ├── is-path-cwd@2.2.0
                                          │   │ ├── is-path-inside@3.0.3
                                          │   │ ├─┬ p-map@4.0.0
                                          │   │ │ └─┬ aggregate-error@3.1.0
                                          │   │ │   ├── clean-stack@2.2.0
                                          │   │ │   └── indent-string@4.0.0
                                          │   │ ├── rimraf@3.0.2 deduped
                                          │   │ └── slash@3.0.0
                                          │   ├── escape-goat@3.0.0
                                          │   ├── escape-string-regexp@4.0.0
                                          │   ├─┬ execa@5.1.1
                                          │   │ ├─┬ cross-spawn@7.0.3
                                          │   │ │ ├── path-key@3.1.1
                                          │   │ │ ├─┬ shebang-command@2.0.0
                                          │   │ │ │ └── shebang-regex@3.0.0
                                          │   │ │ └── which@2.0.2 deduped
                                          │   │ ├── get-stream@6.0.1
                                          │   │ ├── human-signals@2.1.0
                                          │   │ ├── is-stream@2.0.1 deduped
                                          │   │ ├── merge-stream@2.0.0
                                          │   │ ├─┬ npm-run-path@4.0.1
                                          │   │ │ └── path-key@3.1.1 deduped
                                          │   │ ├── onetime@5.1.2 deduped
                                          │   │ ├── signal-exit@3.0.6
                                          │   │ └── strip-final-newline@2.0.0
                                          │   ├── github-url-from-git@1.5.0
                                          │   ├── has-yarn@2.1.0
                                          │   ├─┬ hosted-git-info@3.0.8
                                          │   │ └── lru-cache@6.0.0 deduped
                                          │   ├─┬ ignore-walk@3.0.4
                                          │   │ └── minimatch@3.0.4 deduped
                                          │   ├─┬ import-local@3.1.0
                                          │   │ ├─┬ pkg-dir@4.2.0
                                          │   │ │ └─┬ find-up@4.1.0
                                          │   │ │   ├─┬ locate-path@5.0.0
                                          │   │ │   │ └─┬ p-locate@4.1.0
                                          │   │ │   │   └── p-limit@2.3.0 deduped
                                          │   │ │   └── path-exists@4.0.0 deduped
                                          │   │ └─┬ resolve-cwd@3.0.0
                                          │   │   └── resolve-from@5.0.0
                                          │   ├─┬ inquirer@7.3.3
                                          │   │ ├─┬ ansi-escapes@4.3.2
                                          │   │ │ └── type-fest@0.21.3
                                          │   │ ├── chalk@4.1.2 deduped
                                          │   │ ├─┬ cli-cursor@3.1.0
                                          │   │ │ └─┬ restore-cursor@3.1.0
                                          │   │ │   ├── onetime@5.1.2 deduped
                                          │   │ │   └── signal-exit@3.0.6 deduped
                                          │   │ ├── cli-width@3.0.0
                                          │   │ ├─┬ external-editor@3.1.0
                                          │   │ │ ├── chardet@0.7.0
                                          │   │ │ ├── iconv-lite@0.4.24 deduped
                                          │   │ │ └─┬ tmp@0.0.33
                                          │   │ │   └── os-tmpdir@1.0.2
                                          │   │ ├─┬ figures@3.2.0
                                          │   │ │ └── escape-string-regexp@1.0.5
                                          │   │ ├── lodash@4.17.21 deduped
                                          │   │ ├── mute-stream@0.0.8 deduped
                                          │   │ ├── run-async@2.4.1
                                          │   │ ├── rxjs@6.6.7 deduped
                                          │   │ ├─┬ string-width@4.2.3
                                          │   │ │ ├── emoji-regex@8.0.0 deduped
                                          │   │ │ ├── is-fullwidth-code-point@3.0.0
                                          │   │ │ └── strip-ansi@6.0.1 deduped
                                          │   │ ├─┬ strip-ansi@6.0.1
                                          │   │ │ └── ansi-regex@5.0.1
                                          │   │ └── through@2.3.8 deduped
                                          │   ├─┬ is-installed-globally@0.3.2
                                          │   │ ├─┬ global-dirs@2.1.0
                                          │   │ │ └── ini@1.3.7
                                          │   │ └── is-path-inside@3.0.3 deduped
                                          │   ├── is-interactive@1.0.0
                                          │   ├─┬ is-scoped@2.1.0
                                          │   │ └── scoped-regex@2.1.0
                                          │   ├── issue-regex@3.1.0
                                          │   ├─┬ listr@0.14.3
                                          │   │ ├── @samverschueren/stream-to-observable@0.3.1 deduped
                                          │   │ ├─┬ is-observable@1.1.0
                                          │   │ │ └── symbol-observable@1.2.0
                                          │   │ ├── is-promise@2.2.2
                                          │   │ ├── is-stream@1.1.0
                                          │   │ ├── listr-silent-renderer@1.1.1
                                          │   │ ├─┬ listr-update-renderer@0.5.0
                                          │   │ │ ├─┬ chalk@1.1.3
                                          │   │ │ │ ├── ansi-styles@2.2.1
                                          │   │ │ │ ├─┬ has-ansi@2.0.0
                                          │   │ │ │ │ └── ansi-regex@2.1.1 deduped
                                          │   │ │ │ ├── strip-ansi@3.0.1 deduped
                                          │   │ │ │ └── supports-color@2.0.0
                                          │   │ │ ├─┬ cli-truncate@0.2.1
                                          │   │ │ │ ├── slice-ansi@0.0.4
                                          │   │ │ │ └── string-width@1.0.2 deduped
                                          │   │ │ ├── elegant-spinner@1.0.1
                                          │   │ │ ├─┬ figures@1.7.0
                                          │   │ │ │ ├── escape-string-regexp@1.0.5 deduped
                                          │   │ │ │ └── object-assign@4.1.1 deduped
                                          │   │ │ ├── indent-string@3.2.0
                                          │   │ │ ├─┬ log-symbols@1.0.2
                                          │   │ │ │ └── chalk@1.1.3 deduped
                                          │   │ │ ├─┬ log-update@2.3.0
                                          │   │ │ │ ├── ansi-escapes@3.2.0
                                          │   │ │ │ ├─┬ cli-cursor@2.1.0
                                          │   │ │ │ │ └─┬ restore-cursor@2.0.0
                                          │   │ │ │ │   ├─┬ onetime@2.0.1
                                          │   │ │ │ │   │ └── mimic-fn@1.2.0
                                          │   │ │ │ │   └── signal-exit@3.0.6 deduped
                                          │   │ │ │ └─┬ wrap-ansi@3.0.1
                                          │   │ │ │   ├─┬ string-width@2.1.1
                                          │   │ │ │   │ ├── is-fullwidth-code-point@2.0.0
                                          │   │ │ │   │ └── strip-ansi@4.0.0 deduped
                                          │   │ │ │   └─┬ strip-ansi@4.0.0
                                          │   │ │ │     └── ansi-regex@3.0.0
                                          │   │ │ └─┬ strip-ansi@3.0.1
                                          │   │ ├─┬ listr-verbose-renderer@0.5.0
                                          │   │ │ ├── date-fns@1.30.1
                                          │   │ │ └─┬ figures@2.0.0
                                          │   │ │   └── escape-string-regexp@1.0.5 deduped
                                          │   │ ├── p-map@2.1.0 deduped
                                          │   │ └── rxjs@6.6.7 deduped
                                          │   ├─┬ listr-input@0.2.1
                                          │   │ ├── inquirer@7.3.3 deduped
                                          │   │ ├─┬ inquirer-autosubmit-prompt@0.2.0
                                          │   │ │ ├─┬ inquirer@6.5.2
                                          │   │ │ │ ├── chalk@2.4.2 deduped
                                          │   │ │ │ ├── cli-width@2.2.1
                                          │   │ │ │ ├── external-editor@3.1.0 deduped
                                          │   │ │ │ ├─┬ figures@2.0.0
                                          │   │ │ │ │ └── escape-string-regexp@1.0.5 deduped
                                          │   │ │ │ ├── lodash@4.17.21 deduped
                                          │   │ │ │ ├── mute-stream@0.0.7
                                          │   │ │ │ ├── run-async@2.4.1 deduped
                                          │   │ │ │ ├── rxjs@6.6.7 deduped
                                          │   │ │ │ │ └─┬ strip-ansi@4.0.0
                                          │   │ │ │ │   └── ansi-regex@3.0.0
                                          │   │ │ │ ├─┬ strip-ansi@5.2.0
                                          │   │ │ │ │ └── ansi-regex@4.1.0
                                          │   │ │ │ └── through@2.3.8 deduped
                                          │   │ │ └── rxjs@6.6.7 deduped
                                          │   ├─┬ log-symbols@4.1.0
                                          │   │ └── is-unicode-supported@0.1.0
                                          │   ├─┬ meow@8.1.2
                                          │   │ ├── @types/minimist@1.2.2
                                          │   │ ├─┬ camelcase-keys@6.2.2
                                          │   │ │ ├── camelcase@5.3.1
                                          │   │ │ ├── map-obj@4.3.0
                                          │   │ │ └── quick-lru@4.0.1
                                          │   │ ├─┬ decamelize-keys@1.1.0
                                          │   │ │ ├── decamelize@1.2.0 deduped
                                          │   │ │ └── map-obj@1.0.1
                                          │   │ ├── hard-rejection@2.1.0
                                          │   │ ├─┬ minimist-options@4.1.0
                                          │   │ │ ├── arrify@1.0.1
                                          │   │ │ ├── is-plain-obj@1.1.0
                                          │   │ │ └── kind-of@6.0.3
                                          │   │ ├─┬ normalize-package-data@3.0.3
                                          │   │ │ ├─┬ hosted-git-info@4.1.0
                                          │   │ │ │ └── lru-cache@6.0.0 deduped
                                          │   │ │ ├─┬ is-core-module@2.8.1
                                          │   │ │ │ └── has@1.0.3 deduped
                                          │   │ │ ├── semver@7.3.5 deduped
                                          │   │ │ └─┬ validate-npm-package-license@3.0.4
                                          │   │ │   ├─┬ spdx-correct@3.1.1
                                          │   │ │   │ ├── spdx-expression-parse@3.0.1 deduped
                                          │   │ │   │ └── spdx-license-ids@3.0.11
                                          │   │ │   └─┬ spdx-expression-parse@3.0.1
                                          │   │ │     ├── spdx-exceptions@2.3.0
                                          │   │ │     └── spdx-license-ids@3.0.11 deduped
                                          │   │ ├── read-pkg-up@7.0.1 deduped
                                          │   │ ├─┬ redent@3.0.0
                                          │   │ │ ├── indent-string@4.0.0
                                          │   │ │ └─┬ strip-indent@3.0.0
                                          │   │ │   └── min-indent@1.0.1
                                          │   │ ├── trim-newlines@3.0.1
                                          │   │ ├── type-fest@0.18.1
                                          │   │ └── yargs-parser@20.2.9 deduped
                                          │   ├── minimatch@3.0.4 deduped
                                          │   ├─┬ new-github-release-url@1.0.0
                                          │   │ └── type-fest@0.4.1
                                          │   ├─┬ npm-name@6.0.1
                                          │   │ ├─┬ got@10.7.0
                                          │   │ │ ├── @sindresorhus/is@2.1.1
                                          │   │ │ ├── @szmarczak/http-timer@4.0.6 deduped
                                          │   │ │ ├── @types/cacheable-request@6.0.2 deduped
                                          │   │ │ ├─┬ cacheable-lookup@2.0.1
                                          │   │ │ │ ├── @types/keyv@3.1.3 deduped
                                          │   │ │ │ └── keyv@4.0.5 deduped
                                          │   │ │ ├── cacheable-request@7.0.2 deduped
                                          │   │ │ ├─┬ decompress-response@5.0.0
                                          │   │ │ │ └── mimic-response@2.1.0 deduped
                                          │   │ │ ├── duplexer3@0.1.4
                                          │   │ │ ├─┬ get-stream@5.2.0
                                          │   │ │ │ └── pump@3.0.0 deduped
                                          │   │ │ ├── lowercase-keys@2.0.0 deduped
                                          │   │ │ ├── mimic-response@2.1.0
                                          │   │ │ ├── p-cancelable@2.1.1 deduped
                                          │   │ │ ├─┬ p-event@4.2.0
                                          │   │ │ │ └─┬ p-timeout@3.2.0
                                          │   │ │ │   └── p-finally@1.0.0
                                          │   │ │ ├── responselike@2.0.0 deduped
                                          │   │ │ ├── to-readable-stream@2.1.0
                                          │   │ │ └── type-fest@0.10.0
                                          │   │ ├── is-scoped@2.1.0 deduped
                                          │   │ ├── is-url-superb@4.0.0
                                          │   │ ├── lodash.zip@4.2.0
                                          │   │ ├── org-regex@1.0.0
                                          │   │ ├─┬ p-map@3.0.0
                                          │   │ │ └── aggregate-error@3.1.0 deduped
                                          │   │ ├─┬ registry-auth-token@4.2.1
                                          │   │ │ └── rc@1.2.8 deduped
                                          │   │ ├─┬ registry-url@5.1.0
                                          │   │ └─┬ validate-npm-package-name@3.0.0
                                          │   │   └── builtins@1.0.3
                                          │   ├─┬ onetime@5.1.2
                                          │   │ └── mimic-fn@2.1.0
                                          │   ├─┬ open@7.4.2
                                          │   │ ├── is-docker@2.2.1
                                          │   │ └─┬ is-wsl@2.2.0
                                          │   │   └── is-docker@2.2.1 deduped
                                          │   ├─┬ ow@0.21.0
                                          │   │ ├── @sindresorhus/is@4.4.0
                                          │   │ ├── callsites@3.1.0
                                          │   │ ├─┬ dot-prop@6.0.1
                                          │   │ │ └── is-obj@2.0.0
                                          │   │ ├── lodash.isequal@4.5.0
                                          │   │ ├── type-fest@0.20.2
                                          │   │ └── vali-date@1.0.0
                                          │   ├─┬ p-memoize@4.0.4
                                          │   │ ├─┬ map-age-cleaner@0.1.3
                                          │   │ │ └── p-defer@1.0.0
                                          │   │ ├── mimic-fn@3.1.0
                                          │   │ └─┬ p-settle@4.1.1
                                          │   │   ├─┬ p-limit@2.3.0
                                          │   │   │ └── p-try@2.2.0
                                          │   │   └── p-reflect@2.1.0
                                          │   ├── p-timeout@4.1.0
                                          │   ├─┬ pkg-dir@5.0.0
                                          │   │ └─┬ find-up@5.0.0
                                          │   │   ├─┬ locate-path@6.0.0
                                          │   │   │ └─┬ p-locate@5.0.0
                                          │   │   │   └─┬ p-limit@3.1.0
                                          │   │   │     └── yocto-queue@0.1.0
                                          │   ├─┬ read-pkg-up@7.0.1
                                          │   │ ├─┬ find-up@4.1.0
                                          │   │ ├─┬ read-pkg@5.2.0
                                          │   │ │ ├── @types/normalize-package-data@2.4.1
                                          │   │ │ ├─┬ normalize-package-data@2.5.0
                                          │   │ │ │ ├── hosted-git-info@2.8.9
                                          │   │ │ │ ├─┬ resolve@1.22.0
                                          │   │ │ │ │ ├── is-core-module@2.8.1 deduped
                                          │   │ │ │ │ ├── path-parse@1.0.7
                                          │   │ │ │ │ └── supports-preserve-symlinks-flag@1.0.0
                                          │   │ │ │ ├── semver@5.7.1
                                          │   │ │ │ └── validate-npm-package-license@3.0.4 deduped
                                          │   │ │ ├── parse-json@5.2.0 deduped
                                          │   │ │ └── type-fest@0.6.0
                                          │   │ └── type-fest@0.8.1
                                          │   ├─┬ rxjs@6.6.7
                                          │   │ └── tslib@1.14.1 deduped
                                          │   ├── split@1.0.1 deduped
                                          │   ├── symbol-observable@3.0.0
                                          │   ├─┬ terminal-link@2.1.1
                                          │   │ ├── ansi-escapes@4.3.2 deduped
                                          │   │ └─┬ supports-hyperlinks@2.2.0
                                          │   │   ├── has-flag@4.0.0 deduped
                                          │   │   └── supports-color@7.2.0 deduped
                                          │   └─┬ update-notifier@5.1.0
                                          │     ├─┬ boxen@5.1.2
                                          │     │ ├─┬ ansi-align@3.0.1
                                          │     │ │ └─┬ string-width@4.2.3
                                          │     │ │   └─┬ strip-ansi@6.0.1
                                          │     │ ├── camelcase@6.3.0
                                          │     │ ├── cli-boxes@2.2.1
                                          │     │ ├─┬ widest-line@3.1.0
                                          │     │ └── wrap-ansi@7.0.0 deduped
                                          │     ├─┬ configstore@5.0.1
                                          │     │ ├─┬ dot-prop@5.3.0
                                          │     │ │ └── is-obj@2.0.0 deduped
                                          │     │ ├── make-dir@3.1.0 deduped
                                          │     │ ├─┬ unique-string@2.0.0
                                          │     │ │ └── crypto-random-string@2.0.0
                                          │     │ ├─┬ write-file-atomic@3.0.3
                                          │     │ │ ├── imurmurhash@0.1.4
                                          │     │ │ ├── is-typedarray@1.0.0 deduped
                                          │     │ │ ├── signal-exit@3.0.6 deduped
                                          │     │ │ └─┬ typedarray-to-buffer@3.1.5
                                          │     │ │   └── is-typedarray@1.0.0 deduped
                                          │     │ └── xdg-basedir@4.0.0 deduped
                                          │     ├── has-yarn@2.1.0 deduped
                                          │     ├── import-lazy@2.1.0
                                          │     ├─┬ is-ci@2.0.0
                                          │     │ └── ci-info@2.0.0
                                          │     ├─┬ is-installed-globally@0.4.0
                                          │     │ ├─┬ global-dirs@3.0.0
                                          │     │ │ └── ini@2.0.0
                                          │     ├── is-npm@5.0.0
                                          │     ├── is-yarn-global@0.3.0
                                          │     ├─┬ latest-version@5.1.0
                                          │     │ └─┬ package-json@6.5.0
                                          │     │   ├─┬ got@9.6.0
                                          │     │   │ ├── @sindresorhus/is@0.14.0
                                          │     │   │ ├─┬ @szmarczak/http-timer@1.1.2
                                          │     │   │ │ └── defer-to-connect@1.1.3
                                          │     │   │ ├─┬ cacheable-request@6.1.0
                                          │     │   │ │ ├── clone-response@1.0.2 deduped
                                          │     │   │ │ ├─┬ get-stream@5.2.0
                                          │     │   │ │ │ └── pump@3.0.0 deduped
                                          │     │   │ │ ├── http-cache-semantics@4.1.0 deduped
                                          │     │   │ │ ├─┬ keyv@3.1.0
                                          │     │   │ │ │ └── json-buffer@3.0.0
                                          │     │   │ │ ├── lowercase-keys@2.0.0 deduped
                                          │     │   │ │ ├── normalize-url@4.5.1
                                          │     │   │ │ └─┬ responselike@1.0.2
                                          │     │   │ │   └── lowercase-keys@1.0.1
                                          │     │   │ ├─┬ decompress-response@3.3.0
                                          │     │   │ │ └── mimic-response@1.0.1 deduped
                                          │     │   │ ├── duplexer3@0.1.4 deduped
                                          │     │   │ ├─┬ get-stream@4.1.0
                                          │     │   │ ├── lowercase-keys@1.0.1
                                          │     │   │ ├── mimic-response@1.0.1
                                          │     │   │ ├── p-cancelable@1.1.0
                                          │     │   │ ├── to-readable-stream@1.0.0
                                          │     │   │ └─┬ url-parse-lax@3.0.0
                                          │     │   │   └── prepend-http@2.0.0
                                          │     │   ├── registry-auth-token@4.2.1 deduped
                                          │     │   ├── registry-url@5.1.0 deduped
                                          │     │   └── semver@6.3.0
                                          │     ├─┬ pupa@2.1.1
                                          │     │ └── escape-goat@2.1.1
                                          │     ├─┬ semver-diff@3.1.1
                                          ├─┬ iobroker.vis-inventwo@3.3.1
                                          │ ├── minimist@1.2.5 deduped
                                          │ └── np@7.6.0 deduped
                                          ├── iobroker.vis-jqui-mfd@1.0.12
                                          ├── iobroker.vis-materialdesign@0.5.9
                                          ├─┬ iobroker.vis-plumb@1.0.2
                                          │ └─┬ @iobroker/adapter-core@1.0.3
                                          │   └─┬ @types/iobroker@1.4.13
                                          ├── iobroker.vis-rgraph@0.0.2
                                          ├── iobroker.vis-timeandweather@1.1.7
                                          ├─┬ iobroker.weatherunderground@3.4.2
                                          │ └─┬ axios@0.27.2
                                          │   ├── follow-redirects@1.15.1
                                          │   └─┬ form-data@4.0.0
                                          │     ├── asynckit@0.4.0 deduped
                                          │     ├── combined-stream@1.0.8 deduped
                                          │     └── mime-types@2.1.34 deduped
                                          ├─┬ iobroker.web@4.3.0
                                          │ ├─┬ body-parser@1.20.0
                                          │ │ ├── bytes@3.1.2
                                          │ │ ├── content-type@1.0.4 deduped
                                          │ │ ├── debug@2.6.9 deduped
                                          │ │ ├── depd@2.0.0
                                          │ │ ├── destroy@1.2.0
                                          │ │ ├─┬ http-errors@2.0.0
                                          │ │ │ ├── depd@2.0.0 deduped
                                          │ │ │ ├── inherits@2.0.4 deduped
                                          │ │ │ ├── setprototypeof@1.2.0 deduped
                                          │ │ │ ├── statuses@2.0.1 deduped
                                          │ │ │ └── toidentifier@1.0.1 deduped
                                          │ │ ├─┬ on-finished@2.4.1
                                          │ │ │ └── ee-first@1.1.1 deduped
                                          │ │ ├─┬ qs@6.10.3
                                          │ │ │ └── side-channel@1.0.4 deduped
                                          │ │ ├─┬ raw-body@2.5.1
                                          │ │ │ ├── bytes@3.1.2 deduped
                                          │ │ │ ├── http-errors@2.0.0 deduped
                                          │ │ │ └── unpipe@1.0.0 deduped
                                          │ │ ├── type-is@1.6.18 deduped
                                          │ ├── compression@1.7.4 deduped
                                          │ ├── connect-flash@0.1.1 deduped
                                          │ ├── cookie-parser@1.4.6 deduped
                                          │ ├─┬ express@4.18.1
                                          │ │ ├─┬ accepts@1.3.8
                                          │ │ │ ├── mime-types@2.1.35 deduped
                                          │ │ │ └── negotiator@0.6.3
                                          │ │ ├── array-flatten@1.1.1 deduped
                                          │ │ ├── body-parser@1.20.0 deduped
                                          │ │ ├── content-disposition@0.5.4 deduped
                                          │ │ ├── cookie@0.5.0
                                          │ │ ├── cookie-signature@1.0.6 deduped
                                          │ │ ├── encodeurl@1.0.2 deduped
                                          │ │ ├── escape-html@1.0.3 deduped
                                          │ │ ├── etag@1.8.1 deduped
                                          │ │ ├─┬ finalhandler@1.2.0
                                          │ │ │ ├── debug@2.6.9 deduped
                                          │ │ │ ├── encodeurl@1.0.2 deduped
                                          │ │ │ ├── escape-html@1.0.3 deduped
                                          │ │ │ ├── on-finished@2.4.1 deduped
                                          │ │ │ ├── parseurl@1.3.3 deduped
                                          │ │ ├── fresh@0.5.2 deduped
                                          │ │ ├── merge-descriptors@1.0.1 deduped
                                          │ │ ├── methods@1.1.2 deduped
                                          │ │ ├── path-to-regexp@0.1.7 deduped
                                          │ │ ├── proxy-addr@2.0.7 deduped
                                          │ │ ├── qs@6.10.3 deduped
                                          │ │ ├── range-parser@1.2.1 deduped
                                          │ │ ├── safe-buffer@5.2.1 deduped
                                          │ │ ├─┬ send@0.18.0
                                          │ │ │ ├── destroy@1.2.0 deduped
                                          │ │ │ ├── etag@1.8.1 deduped
                                          │ │ │ ├── fresh@0.5.2 deduped
                                          │ │ │ ├── mime@1.6.0
                                          │ │ │ ├── ms@2.1.3
                                          │ │ │ ├── range-parser@1.2.1 deduped
                                          │ │ │ └── statuses@2.0.1 deduped
                                          │ │ ├─┬ serve-static@1.15.0
                                          │ │ │ └── send@0.18.0 deduped
                                          │ │ ├── utils-merge@1.0.1 deduped
                                          │ │ └── vary@1.1.2 deduped
                                          │ ├── express-session@1.17.2 deduped
                                          │ ├── iobroker.simple-api@2.6.5 deduped
                                          │ ├── iobroker.socketio@4.2.0 deduped
                                          │ ├─┬ iobroker.ws@1.3.0
                                          │ │ ├─┬ @iobroker/adapter-core@2.6.0
                                          │ │ │ └─┬ @types/iobroker@4.0.3
                                          │ │ │   └── @types/node@17.0.13 deduped
                                          │ │ ├─┬ axios@0.26.1
                                          │ │ │ └── follow-redirects@1.15.1
                                          │ │ ├── cookie-parser@1.4.6 deduped
                                          │ │ ├── express-session@1.17.2 deduped
                                          │ │ ├─┬ iobroker.ws.server@1.0.1
                                          │ │ │ └── ws@8.4.2 deduped
                                          │ │ └── passport@0.5.2 deduped
                                          │ ├─┬ mime-types@2.1.35
                                          │ │ └── mime-db@1.52.0
                                          │ ├── passport@0.5.2 deduped
                                          │ ├── passport-local@1.0.0 deduped
                                          │ └── xtend@4.0.2
                                          └─┬ iobroker.whatsapp-cmb@0.2.2
                                          npm ERR! peer dep missing: @types/express@^4.17.13, required by http-proxy-middleware@2.0.2
                                          iobroker läuft noch nicht
