  4. Javascript - Blockly wird oft nicht gespeichert
    6.0k
javascript blockly
363 Beiträge 31 Kommentatoren 80.0k Aufrufe 31 Beobachtet
  • hg6806H hg6806
    @glasfaser
    Da kommt folgendes als Fehler:
    DevTools failed to load source map: Could not load content for http://192.168.178.18:8081/static/css/5710.41ed5ace.chunk.css.map: Load canceled due to load timeout
    DevTools failed to load source map: Could not load content for http://192.168.178.18:8081/adapter/javascript/static/css/62.6133d7c1.chunk.css.map: Load canceled due to load timeout
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Garagenstrom.vor_2_Monaten
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Garagenstrom.vor_2_Wochen
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Garagenstrom.vor_3_Monaten
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Garagenstrom.vor_3_Wochen
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Garagenstrom.vor_4_Monaten
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Garagenstrom.vor_4_Wochen
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Garagenstrom.vor_5_Monaten
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Garagenstrom.vor_5_Wochen
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Garagenstrom.vor_6_Monaten
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Garagenstrom.vor_6_Wochen
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Garagenstrom.vor_7_Monaten
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Garagenstrom.vor_7_Wochen
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Garagenstrom.vor_8_Monaten
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Garagenstrom.vor_8_Wochen
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Garagenstrom.vor_9_Monaten
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Garagenstrom.vor_9_Wochen
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Gartenstrom.vor_2_Monaten
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Gartenstrom.vor_2_Wochen
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Gartenstrom.vor_3_Monaten
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Gartenstrom.vor_3_Wochen
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Gartenstrom.vor_4_Monaten
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Gartenstrom.vor_4_Wochen
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Gartenstrom.vor_5_Monaten
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Gartenstrom.vor_5_Wochen
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Gartenstrom.vor_6_Monaten
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Gartenstrom.vor_6_Wochen
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Gartenstrom.vor_7_Monaten
    793.b25dfbc1.chunk.js:61 > stateChange 0_userdata.0.Sourceanalytix.Gartenstrom.vor_7_Wochen
    GlasfaserG Offline
    GlasfaserG Offline
    #328
    @hg6806
    Teste mal so mit der Browser-Konsole :
    hg6806H 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      @hg6806
      hg6806H Offline
      hg6806H Offline
      hg6806
      #329
      Das ist einiges, deshalb wieder als Text File
      Browser-Konsole.txt
      • hg6806H hg6806
        Browser-Konsole.txt
        #330
        @hg6806 sagte in Javascript - Blockly wird oft nicht gespeichert:
        Das ist einiges,
        alles ERROR?
          Das ist einiges,
          alles ERROR?
          hg6806H Offline
          hg6806H Offline
          hg6806
          #331
          Nein, nicht ein Fehler.
          Nur ein paar Warnings
          • hg6806H hg6806
            GlasfaserG Offline
            GlasfaserG Offline
            #332
            @hg6806
            Dein Log ist überfüllt von
            subscribe
            Bei der Auswahl des Objekts im Blockly Baustein ,
            klapp mal hier alle Ordner zu :
            und dann nur als Test den Ordner 0_userdata aufklappen , z.b einen Testdatenpunkt anwählen .
              @hg6806
              subscribe
              hg6806H Offline
              hg6806H Offline
              hg6806
              #333
              @glasfaser
              Ich habe es jetzt hinbekommen.
              Wahrscheinlich war tatsächlich zuviel aufgeklappt, dadurch war das System überlastet.
              Kann das sein?
              • GlasfaserG Offline
                GlasfaserG Offline
                #334
                Kann das sein?
                Meine große Vermutung ist ... ja.
                Also nach deinem Log sieht es so aus.
                @apollon77 dann wäre es auch im javascript Adapter die Begrenzung mit dem Objektbaum !?
                oder gehört das Popup zum Admin !?
                https://github.com/ioBroker/ioBroker.admin/issues/1656
                  Kann das sein?
                  #335
                  @glasfaser sagte in Javascript - Blockly wird oft nicht gespeichert:
                  Kommt quasi vom Admin ... am besten das Issue erweitern
                  • apollon77A apollon77
                    GlasfaserG Offline
                    GlasfaserG Offline
                    #336
                    @apollon77 sagte in Javascript - Blockly wird oft nicht gespeichert:
                    Erledigt .
                      Erledigt .
                      #337
                      @glasfaser Danke!
                      • hg6806H Offline
                        hg6806H Offline
                        hg6806
                        #338
                        OK, danke allen für den super Support!
                        Quintessenz, also zumindest für meinen Fall, Systemüberlastung durch zuviele offene Datenpunkte und Laden der Werte.
                        • hg6806H hg6806
                          D-H-H
                          schrieb am zuletzt editiert von D-H-H
                          #339
                          @hg6806 said in Javascript - Blockly wird oft nicht gespeichert:
                          Scheint mir mir ebenfalls gelegentlich die Ursache gewesen zu sein.
                          Folgendes löst das Problem bei mir das Kernproblem allerdings sofort und final:
                          \opt\iobroker\iobroker-data\iobroker.json
                          "noFileCache" = true
                          Die darunter liegende Hardware hat 64GB RAM, Intel I7 und SSD. System läuft auf Ubuntu Linux und langweilt sich die meiste Zeit.
                          Dennoch geschehen diese Speicherfehler unabhängig vom Browser und Plattform, von der aus aufgerufen wird.
                          Für eine Weile konnte ich den Objektbaum minimieren und die Speicherung funktioniert wieder. Aber bei nun 300+ Skripten (allesamt recht minimalistisch, keine großen dabei) und einem großen KNX System, dass darüber angesteuert wird, half nur noch das Setzen des o.g. Parameters.
                          Was nun bleibt, ist dass das System nach und nach immer träger wird und das speichern langsam länger dauert. Aber es speichert erstmal wieder und setzt mir die Skripte nicht während der Bearbeitung wieder zurück.
                          -1
                          • D D-H-H
                            #340
                            @d-h-h Hm ... also jetzt müssten wir mal ganz tief schauen ...
                            noFileCache=true hat ausschliesslich eine Auswirkung auf Server-Seite und auch nur beim Zugriff auf Dateien aus dem iobroker Storage. Alles ist hier nicht relevant.
                            Bei die r ist auch die Frage ob es im Browser langsam wird oder auf Server seite. ALso du müsstest jetzt mal gaaanz viele Infos, beschreibungen was diu genau meinst , ggf ein Video und sowas bereistellen das wir helfen können.
                            Fakt ist für mich: Dieses Setting kann an sich für das hier beschriebene Theme KEINE Auswirkung haben
                              D-H-H
                              #341
                              @apollon77 Hat es aber. Ohne die beschriebenen Einstellungen werden die verwendeten Browser - Chrome, Vivaldi und Edge - gleichermaßen langsamer. Ein Neustart des ioBroker Servers behebt jedoch alle Speicherprobleme - für eine gewisse Zeit. Egal welcher Laptop, egal welches OS, egal welcher Browser.
                              Der Server läuft derzeit wieder einige Tage - ich kann nach wie vor Speichern. Der Zeitraum, bis der Speichern Button erscheint, ist nach Änderungen ca. 1-2 Sekunden. Der Zeitraum vom drücken des Speicherbuttons bis zum erfolgreichen speichern ist wieder 1-2 Sekunden. Es geht also nicht "biltzschnell" aber man kann damit arbeiten.
                              Ohne die o.g. Änderung erscheint der Speichern Button erst gar nicht oder erst nach 1-2 MINUTEN. Teilweise werden Änderungen im Skript einfach wieder rückgängig gemacht und auf den Zustand zurückgesetzt, als das Skript aufgerufen wurde.
                              Den Speichern Button zu drücken hat manchmal Erfolg - nach 1-5 Minuten - manchmal passiert auch gar nichts. Manchmal setzt er auf Start zurück.
                              Ich besitze eine eigene Software Entwicklungsfirma - bins ja gewohnt, dass mir Devs sagen "das kann gar nicht sein" und dann in voller Bewunderung selbst vor dem Problem stehen ;)
                              Vielleicht ist es bei mir ja was anderes als bei den anderen Betroffenen hier - aber die anderen Beschreibungen hören sich für mich stark nach dem gleichen Problem an. Ein immer langsamer werdender Server, bis irgendwann der Cache voll ist.
                              Unter dem ioBroker liegt bei mir eine High Performance Maschine. Serverplatten im RAID 10. Linux Ubuntu Server 22.x. 64 GB RAM. i7 mit 3,8Ghz. Derzeit keine andren VMs am laufen.
                              Die Hardware langweilt sich - während das Speichern der Skripte scheinbar in Timeouts läuft.
                              Das hat mit dem Browser nix zu tun. Fehlermeldungen im Browser sind lediglich, dass die Gegenseite nicht mehr antwortet.
                              Könnte es sein, dass der Server etwas aus dem Cache laden will und es dort nicht findet? Oder beim Schreibvorgang in den Cache schreibt und der nichts mehr aufnimmt?
                              Ich kann gern mal einen meiner Frond-End Devs dransetzen.
                              DJMarc75D apollon77A 2 Antworten Letzte Antwort
                              • D D-H-H
                                DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                #342
                                @d-h-h bin jetzt nicht grad ein Guru oder Developer aber ein Poweruser und kann da nur sagen dass Dein Problem wohl an einem/mehreren "faulen" Skripten liegen könnte... Schleife, Cron,... Hatte Ähnliches Verhalten auch schon und nachdem ich meine Skripte kontrolliert und bereinigt hatte war dieses Verhalten verschwunden. Kann mich aber auch mal wieder täuschen.
                                Lehrling seit 1975 !!!
                                • DJMarc75D DJMarc75
                                  D-H-H
                                  #343
                                  @djmarc75 Und die Skripte sind nur faul, wenn der Cache nicht deaktiviert ist? Unwahrscheinlich.
                                  • D D-H-H
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    #344
                                    @d-h-h sagte in Javascript - Blockly wird oft nicht gespeichert:
                                    war nur ein Tipp... halte mich dann gerne weiterhin raus und lass die Profis ran.
                                    • D D-H-H
                                      #345
                                      @d-h-h Strange. Also mit so einem System sollte sie Server Seite egal sein - Bzw wenn es langsamer wird dann eindeutig im CPU Verbrauch zu sehen sein. Wie ist es da?
                                      Wie us RAM Verbrauch der Prozesse?
                                      Die meisten probs bisher bei sowas waren eher im Browser. Vor allem wenn Admin tabs über Tage offen sind und sich so mit Daten zufressen. Das hast du auch ausgeschlossen?
                                        tklein
                                        #346
                                        hi zusammen,
                                        ich habe das problem auch extrem. ich kann kaum mit blockly arbeiten/speichern.
                                        gibt es dazu neuigkeiten, wie man das beheben/umgehen kann? JS Controller ist 5.0.16 auf einem Raspi 4 mit 4 GB RAM
                                        • T tklein
                                          hi zusammen,
                                          saeft_2003
                                          #347
                                          @tklein
                                          Sind die 4GB vielleicht etwas knapp bemessen? Wie viele Instanzen hast du laufen?
