  4. Node Red startet nicht nach Raspberry OS update
    5.8k
84 Beiträge 4 Kommentatoren 10.7k Aufrufe 3 Beobachtet
  • E etzeste13
    @mickym said in Node Red startet nicht nach Raspberry OS update:
    npm install
    folgende meldung...
    pi@RasPi3B3:/opt/iobroker $ npm install
    npm ERR! code ENOTDIR
    npm ERR! syscall stat
    npm ERR! path /home/iobroker/.npm/_cacache/content-v2/sha512/17/06/0df1a30050029f8f7ec9ac5018a8e08974fa7e57a8c65380af859213df16e877c8250d01a6e5e9d176e66443acec6f692fcd3c0e50df249ca2e3dd43c4d1
    npm ERR! errno ENOTDIR
    npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/form-data: ENOTDIR: not a directory, stat '/home/iobroker/.npm/_cacache/content-v2/sha512/17/06/0df1a30050029f8f7ec9ac5018a8e08974fa7e57a8c65380af859213df16e877c8250d01a6e5e9d176e66443acec6f692fcd3c0e50df249ca2e3dd43c4d1'
    npm ERR!     /home/iobroker/.npm/_logs/2022-09-01T20_00_41_101Z-debug-0.log
    mickymM Offline
    mickymM Offline
    mickym
    @etzeste13 mach mal
    npm cache clean -f
    E mickymM 2 Antworten Letzte Antwort
    • mickymM mickym
      @etzeste13 mach mal
      npm cache clean -f
      etzeste13
      npm cache clean -f
      erledigt
      pi@RasPi3B3:/opt/iobroker $ npm cache clean -f
      npm WARN using --force Recommended protections disabled.
      • mickymM mickym
        @etzeste13 mach mal
        npm cache clean -f
        mickymM Offline
        mickymM Offline
        mickym
        Dann nochmal
        npm install
        E 1 Antwort Letzte Antwort
        • mickymM mickym
          Dann nochmal
          npm install
          etzeste13
          npm install
          ist durch
          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
          npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
          npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
          npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
          npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
          added 911 packages in 5m
          74 packages are looking for funding
            run `npm fund` for details
          • E etzeste13
            npm install
            ist durch
            mickymM Offline
            mickymM Offline
            mickym
            @etzeste13 Schaut doch gut aus.
            nun wieder
            npm list
            • mickymM mickym
              nun wieder
              npm list
              etzeste13
              npm list
              iobroker.inst@3.0.0 /opt/iobroker
              ├── iobroker.admin@6.2.20
              ├── iobroker.backitup@2.4.12
              ├── iobroker.discovery@3.0.5
              ├── iobroker.info@1.9.19
              ├── iobroker.js-controller@4.0.23
              ├── iobroker.modbus@5.0.5
              ├── iobroker.node-red@3.3.1
              └── iobroker.rpi2@1.3.2
              • E etzeste13
                npm list
                mickymM Offline
                mickymM Offline
                mickym
                @etzeste13 na das schaut doch gut aus. Schau ob Dein iobroker wieder startet
                iob start
                • mickymM mickym
                  iob start
                  etzeste13
                  schrieb am zuletzt editiert von etzeste13
                  @mickym tadellos, er läuft wieder.... respekt...!!!! jetzt muss ich noch schauen ob auch der node Red asapter wieder funktioniert...
                  • E etzeste13
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @etzeste13 Na dann solltest Du wieder problemlos updaten können. ;)
                    • mickymM mickym
                      etzeste13
                      @mickym du meinst gleich den js-controller nochmals updaten..?
                      • E etzeste13
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @etzeste13 Wenn Du willst - alles halt mal auf neuesten Stand bringen - du hast Ja nun das aktuelle Node JS - drauf. Bist hoffentlich im Stable Repository unterwegs und nun sollten auch die Updates wieder funktionieren, indem wir deinen altem Schmus weggeschmissen haben.Kannst auch NodeRed Adapter wieder installieren - alles was Du halt brauchst.
                        • mickymM mickym
                          etzeste13
                          @mickym
                          OK, dann versuche ich gleich vorher nochmals den js- controller auf stand zu bringen.... bei diesem versuch hat sich vorher ja alles verabschiedet....
                          und danach bringe ich die Adapter wieder auf stand...
                          bin natürtlich nur stable unterwegst mit meinem background...;-)
                          vielen vielen Dank für deine Zeit und Hilfe!!!
                          mickymM Thomas BraunT 2 Antworten Letzte Antwort
                          • E etzeste13
                            @mickym
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @etzeste13 Na ich hab wahrscheinlich weniger Zeit als andere investiert - und mein Vorgehen finden hier nicht alle gut - deswegen habe ich es nur gemacht, weil es für Dich nichts mehr zu verlieren gab - wenn Du bereit warst, neu zu installieren. ;)
                            • E etzeste13
                              @mickym
                              @etzeste13 sagte in Node Red startet nicht nach Raspberry OS update:
                              Der ist doch aktuell?
                              mickymM E 2 Antworten Letzte Antwort
                                mickymM Offline
                                mickymM Offline
                                mickym
                                Stimmt das ist aktuell. :) Wahrscheinlich gleich mitgekommen, weil neu gemacht.
                                  etzeste13
                                  hab ich dann auch gleich gemerkt... ;-)
                                  novhmals besten dank für eure Unterstützung!!
                                  • E etzeste13
                                    etzeste13
                                    @etzeste13 aber node red geht weiterhin nicht...
                                    ich befürchte fast, dass ich nodes verwende die in diesen versionen nicht mehr unterstützt werden... wie findet man das den raus, oder vielleicht am besten wieder was down-graden?
                                    2022-09-01 22:31:03.664  - info: node-red.0 (3757) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                                    2022-09-01 22:31:15.181  - warn: node-red.0 (3757) 1 Sep 22:31:15 - [warn] Projekte deaktiviert: editorTheme.projects.enabled=false
                                    2022-09-01 22:31:15.278  - warn: node-red.0 (3757) 1 Sep 22:31:15 - [warn] Encrypted credentials not found
                                    2022-09-01 22:31:15.413  - warn: node-red.0 (3757) 1 Sep 22:31:15 - [warn] [modbus-client:SPR8] Client -> fsm init state after new
                                    2022-09-01 22:31:15.415  - warn: node-red.0 (3757) 1 Sep 22:31:15 - [warn] [modbus-client:SPR8] Client -> first fsm init in 500 ms Serial@/dev/ttyUSB0:19200bit/s default Unit-Id: 1
                                    2022-09-01 22:31:15.610  - info: node-red.0 (4177) Sets unsupported
                                    2022-09-01 22:31:15.615  - info: node-red.0 (4177) Sets unsupported
                                    2022-09-01 22:31:15.944  - error: node-red.0 (3757) 1 Sep 22:31:15 - [error] Error: Module did not self-register: '/opt/iobroker/iobroker-data/node-red/node_modules/@serialport/bindings/build/Release/bindings.node'.
                                        at Object.Module._extensions..node (node:internal/modules/cjs/loader:1210:18)
                                        at Module.load (node:internal/modules/cjs/loader:1004:32)
                                        at Function.Module._load (node:internal/modules/cjs/loader:839:12)
                                        at Module.require (node:internal/modules/cjs/loader:1028:19)
                                        at require (node:internal/modules/cjs/helpers:102:18)
                                        at bindings (/opt/iobroker/iobroker-data/node-red/node_modules/bindings/bindings.js:112:48)
                                        at Object.<anonymous> (/opt/iobroker/iobroker-data/node-red/node_modules/@serialport/bindings/lib/linux.js:2:36)
                                        at Module._compile (node:internal/modules/cjs/loader:1126:14)
                                        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
                                    2022-09-01 22:31:15.974  - info: node-red.0 (3757) node-red exited with 1
                                    • E etzeste13
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      @etzeste13 Wie hast Du das den rausgefunden. ;) Wenn Du den Node-Red Adapter installierst - dann hast Du ja erst mal noch gar nichts drin - hast Du einfach Deine flows.json reinkopiert?
                                      • mickymM mickym
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        @mickym Hast Du denn Dein alten Verzeichnis noch zur Verfügung - ich kenn mich nur nicht mit master und slaves aus. Wo liegt denn Dein node-red Datenverzeichnis?
                                        • mickymM mickym
                                          etzeste13
                                          @mickym ich habe einfach aus dem browser-cache den ich im firefox noch offen hatte nach dem installieren des adapters auf aktualisieren gedrückt... und geschaut was passiert.... kopiert hatte ich noch gar nix..
