  4. Nach Umstieg auf Proxmox: Sonoff startet nicht
sonoffproxmox
9 Beiträge 4 Kommentatoren 647 Aufrufe 4 Beobachtet
  • qqolliQ Offline
    qqolliQ Offline
    qqolli
    Leider wird der Sonoff-Adapter nicht grün. Hier die Einstellungen:
    Wie bringe ich den wieder zum laufen?
    • qqolliQ qqolli
      @qqolli
      Wie schaut denn ein Neu-Start des Adapters im Log File aus?
      qqolliQ 1 Antwort Letzte Antwort
        @qqolli
        qqolliQ Offline
        qqolliQ Offline
        qqolli
        Es ist die Version 2.5.1 und im Debug stehen eigentlich keine Fehlermeldungen aber trotzdem gelb:
        sonoff.0
        2022-08-27 13:38:15.840	debug	stateChange sonoff.0.Sonoff_P1_2.alive: {"val":false,"ack":true,"ts":1661607495833,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1661602548902}
        sonoff.0
        2022-08-27 13:38:15.839	debug	stateChange sonoff.0.Sonoff_P1_1.alive: {"val":false,"ack":true,"ts":1661607495832,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1661602548902}
        sonoff.0
        2022-08-27 13:38:15.839	debug	stateChange sonoff.0.Sonoff_Duo_2.alive: {"val":false,"ack":true,"ts":1661607495832,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1661602548902}
        sonoff.0
        2022-08-27 13:38:15.837	debug	stateChange sonoff.0.Sonoff_Duo_1.alive: {"val":false,"ack":true,"ts":1661607495832,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1661602548902}
        sonoff.0
        2022-08-27 13:38:15.837	debug	stateChange sonoff.0.Sonoff_6.alive: {"val":false,"ack":true,"ts":1661607495832,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1661602548895}
        sonoff.0
        2022-08-27 13:38:15.837	debug	stateChange sonoff.0.Sonoff_5.alive: {"val":false,"ack":true,"ts":1661607495832,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1661602548895}
        sonoff.0
        2022-08-27 13:38:15.836	debug	stateChange sonoff.0.Sonoff_4.alive: {"val":false,"ack":true,"ts":1661607495832,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1661602548894}
        sonoff.0
        2022-08-27 13:38:15.835	debug	stateChange sonoff.0.Sonoff_3.alive: {"val":false,"ack":true,"ts":1661607495832,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1661602548894}
        sonoff.0
        2022-08-27 13:38:15.835	debug	stateChange sonoff.0.Sonoff_2.alive: {"val":false,"ack":true,"ts":1661607495832,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1661602548894}
        sonoff.0
        2022-08-27 13:38:15.835	debug	stateChange sonoff.0.Sonoff_1.alive: {"val":false,"ack":true,"ts":1661607495832,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1661602548894}
        sonoff.0
        2022-08-27 13:38:15.834	debug	stateChange sonoff.0.Carport.alive: {"val":false,"ack":true,"ts":1661607495832,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1661602548894}
        sonoff.0
        2022-08-27 13:38:15.833	debug	stateChange sonoff.0.5M4v5fvz3yHEtXmU3qqacs.alive: {"val":false,"ack":true,"ts":1661607495832,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1657020901910}
        sonoff.0
        2022-08-27 13:38:15.833	debug	stateChange sonoff.0.0zhc77f4UlJP11aU9pcuz7.alive: {"val":false,"ack":true,"ts":1661607495832,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1657020901910}
        sonoff.0
        2022-08-27 13:38:15.794	debug	stateChange sonoff.0.info.connection: {"val":"","ack":true,"ts":1661607495752,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1661602548852}
        sonoff.0
        2022-08-27 13:38:15.734	info	Starting MQTT authenticated server on port 1883
        sonoff.0
        2022-08-27 13:38:15.710	info	starting. Version 2.5.1 in /opt/iobroker/node_modules/iobroker.sonoff, node: v16.17.0, js-controller: 4.0.23
        sonoff.0
        2022-08-27 13:38:15.541	debug	Plugin sentry Initialize Plugin (enabled=true)
        sonoff.0
        2022-08-27 13:38:15.485	debug	States connected to redis: 127.0.0.1:9000
        sonoff.0
        2022-08-27 13:38:15.467	debug	States create User PubSub Client
        sonoff.0
        2022-08-27 13:38:15.466	debug	States create System PubSub Client
        sonoff.0
        2022-08-27 13:38:15.458	debug	Redis States: Use Redis connection: 127.0.0.1:9000
        sonoff.0
        2022-08-27 13:38:15.440	debug	Objects connected to redis: 127.0.0.1:9001
        sonoff.0
        2022-08-27 13:38:15.437	debug	Objects client initialize lua scripts
        sonoff.0
        2022-08-27 13:38:15.400	debug	Objects create User PubSub Client
        sonoff.0
        2022-08-27 13:38:15.399	debug	Objects create System PubSub Client
        sonoff.0
        2022-08-27 13:38:15.398	debug	Objects client ready ... initialize now
        sonoff.0
        2022-08-27 13:38:15.377	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
        Der Host sagt dazu:
        host.ioBroker
        2022-08-27 13:38:15.031	info	instance system.adapter.sonoff.0 started with pid 2246
        host.ioBroker
        2022-08-27 13:38:14.923	info	"system.adapter.sonoff.0" enabled
        E 1 Antwort Letzte Antwort
        • qqolliQ qqolli
          sonoff.0
          sonoff.0
          sonoff.0
          sonoff.0
          sonoff.0
          sonoff.0
          sonoff.0
          sonoff.0
          sonoff.0
          sonoff.0
          sonoff.0
          sonoff.0
          sonoff.0
          sonoff.0
          sonoff.0
          sonoff.0
          sonoff.0
          sonoff.0
          sonoff.0
          sonoff.0
          sonoff.0
          sonoff.0
          sonoff.0
          sonoff.0
          sonoff.0
          sonoff.0
          sonoff.0
          Der Host sagt dazu:
          host.ioBroker
          host.ioBroker
          Einstein67
          @qqolli said in Nach Umstieg auf Proxmox: Sonoff startet nicht:
          aber trotzdem gelb
          Weil der neue ioBroker vermutlich eine andere IP hat, und die Sonoffs sich nicht mehr verbinden können?!?
          • E Einstein67
            aber trotzdem gelb
            qqolliQ Offline
            qqolliQ Offline
            qqolli
            @einstein67
            Stimmt. Vorher war es die xx.21 jetzt die xx.101. Habe zwei Sonoff auf die neue IP umgestellt, bleibt aber weiterhin gelb. Oder wird der erst grün, wenn ich ALLE auf die neue IP umgestellt habe?
            • qqolliQ qqolli
              @einstein67
              Einstein67
              @qqolli Sobald die erste Telemetrie-Periode in Tasmota (Standard 300s) abgelaufen ist müsste die Instanz grün werden.
              qqolliQ 2 Antworten Letzte Antwort
              • E Einstein67
                qqolliQ Offline
                qqolliQ Offline
                qqolli
                @einstein67
                Ah, ok dann warte ich mal. Hatte den Adapter angehalten, und alle Objekte im Sonoff.0 gelöscht und dann den Adapter neu gestartet.
                • qqolliQ qqolli
                  @einstein67
                  Meister MopperM Online
                  Meister Mopper
                  @qqolli sagte in Nach Umstieg auf Proxmox: Sonoff startet nicht:
                  Wenn Du mit den Sonoff states eine Datenbank fütterst, vergiss nicht, die Fütterung neu einzurichten. Die sind ja jetzt weg.
                  Proxmox und HA - dank KI/AI endlich "blocklyfrei"
                  • E Einstein67
                    qqolliQ Offline
                    qqolliQ Offline
                    qqolli
                    @einstein67
                    Super, geht. Muss halt alle Sonoffs auf die neue IP umstellen. Hatte ich nicht daran gedacht, sonst hätte ich den Proxmox auf die selbe IP eingestellt. Na ja, aus Fehlern kann man ja auch eine Menge lernen :-)
