  4. npm WARN skipping integrity check
    5.8k
Geplant Angeheftet Gesperrt Verschoben Ungelöst ioBroker Allgemein
npm
22 Beiträge 4 Kommentatoren 2.5k Aufrufe 4 Beobachtet
    @dr-bakterius
    Wo hängt das Ding denn?
    cd /opt/iobroker
    npm ls browser-serialport
    Und wie bist du in Sachen nodejs/npm aufgestellt?
    Dr. BakteriusD Offline
    Dr. Bakterius
    schrieb am zuletzt editiert von Dr. Bakterius
    @thomas-braun Danke erstmal für die rasche Antwort!
    Hier die Ausgabe:
    bakterius@iobroker:/opt/iobroker$ npm ls browser-serialport
    [sudo] password for bakterius:
    iobroker.inst@2.0.3 /opt/iobroker
    `-- iobroker.rflink@2.1.6
      `-- avrgirl-arduino@4.4.0
        `-- browser-serialport@2.0.3 invalid: "https://github.com/noopkat/browser-serialport#c8628c41c11890d3058875994c15f83f2df8185b" from node_modules/avrgirl-arduino
    npm ERR! code ELSPROBLEMS
    npm ERR! invalid: browser-serialport@2.0.3 /opt/iobroker/node_modules/browser-serialport
    npm ERR!     /home/iobroker/.npm/_logs/2022-08-24T07_57_51_336Z-debug-0.log
    Aber rflink-Adapter funktioniert normal!
    Im erwähnten LOG steht folgendes:
    0 verbose cli /usr/bin/node /usr/bin/npm
    1 info using npm@8.11.0
    2 info using node@v16.16.0
    3 timing npm:load:whichnode Completed in 0ms
    4 timing config:load:defaults Completed in 6ms
    5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 8ms
    6 timing config:load:builtin Completed in 10ms
    7 timing config:load:cli Completed in 17ms
    8 timing config:load:env Completed in 1ms
    9 timing config:load:file:/opt/iobroker/.npmrc Completed in 4ms
    10 timing config:load:project Completed in 20ms
    11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
    12 timing config:load:user Completed in 1ms
    13 timing config:load:file:/usr/etc/npmrc Completed in 2ms
    14 timing config:load:global Completed in 2ms
    15 timing config:load:validate Completed in 2ms
    16 timing config:load:credentials Completed in 3ms
    17 timing config:load:setEnvs Completed in 5ms
    18 timing config:load Completed in 70ms
    19 timing npm:load:configload Completed in 70ms
    20 timing npm:load:mkdirpcache Completed in 2ms
    21 timing npm:load:mkdirplogs Completed in 1ms
    22 verbose title npm ls browser-serialport
    23 verbose argv "ls" "browser-serialport"
    24 timing npm:load:setTitle Completed in 4ms
    25 timing config:load:flatten Completed in 10ms
    26 timing npm:load:display Completed in 23ms
    27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
    28 verbose logfile /home/iobroker/.npm/_logs/2022-08-24T07_57_51_336Z-debug-0.log
    29 timing npm:load:logFile Completed in 18ms
    30 timing npm:load:timers Completed in 0ms
    31 timing npm:load:configScope Completed in 1ms
    32 timing npm:load Completed in 123ms
    33 timing arborist:ctor Completed in 3ms
    34 silly logfile start cleaning logs, removing 3 files
    35 silly logfile done cleaning log files
    36 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.admin
    37 timing command:ls Completed in 6053ms
    38 verbose stack Error: invalid: browser-serialport@2.0.3 /opt/iobroker/node_modules/browser-serialport
    38 verbose stack at LS.exec (/usr/lib/node_modules/npm/lib/commands/ls.js:205:9)
    38 verbose stack at processTicksAndRejections (node:internal/process/task_queues:96:5)
    38 verbose stack at async module.exports (/usr/lib/node_modules/npm/lib/cli.js:78:5)
    39 verbose cwd /opt/iobroker
    40 verbose Linux 5.15.39-2-pve
    41 verbose node v16.16.0
    42 verbose npm v8.11.0
    43 error code ELSPROBLEMS
    44 error invalid: browser-serialport@2.0.3 /opt/iobroker/node_modules/browser-serialport
    45 verbose exit 1
    46 timing npm Completed in 6394ms
    47 verbose code 1
    48 error A complete log of this run can be found in:
    48 error /home/iobroker/.npm/_logs/2022-08-24T07_57_51_336Z-debug-0.log
    Ist das ein Kompatibilitätsproblem mit Admin 6.x?
    Edit: Ein npm ls liefert folgenden Hinweis:
    +-- iobroker.netatmo@1.7.1 invalid: "github:PArns/ioBroker.netatmo" from the root project
    Und ich glaube, dass seit dem Update von Netatmo die Warns kommen.
    Edit2: Ein Downgrade des Netatmo-Adapters hat das iobroker.netatmo@1.7.1 invalid behoben, aber browser-serialport-Problem bleibt. Nach Upgrade per "Katze" von Netatmo kommt auch der Fehler in npm ls wieder. Ist also wohl doch ein anderes Problem...
      Hier die Ausgabe:
      45 verbose exit 1
      47 verbose code 1
      @dr-bakterius
      Bring dein nodejs auf Stand.
      Den iobroker.netatmo würde ich nochmal sauber aus dem Repo installieren, nicht aus github/ der räudigen Katze.
      netatmo
      github:	1.7.1
      latest:	1.7.1 for 4 months
      stable:	1.7.1 for 4 months
      https://github.com/noopkat/avrgirl-arduino/blob/master/package.json
      hat den 'Fehler' drin, da müsste wohl der Maintainer seine Deps mal checken.
      Dr. BakteriusD 1 Antwort Letzte Antwort
        @dr-bakterius
        netatmo
        github:	1.7.1
        Dr. Bakterius
        @thomas-braun Okay, das letzte Update / Upgrade war Anfang August. Nodejs ist jetzt auf v16.17.0.
        Netatmo habe ich von GitHub installiert, weil ich für @apollon77 etwas getestet habe. Dürfte aber eine andere Baustelle sein. Denn mit der offiziellen netatmo v1.7.1 verschwindet zwar das iobroker.netatmo@1.7.1 invalid doch browser-serialport bleibt...
          @dr-bakterius sagte in npm WARN skipping integrity check:
          Ja, ist eine andere Baustelle. War mir aber ins Auge gesprungen.
          browser-serialport:
          hat den 'Fehler' drin, da müsste wohl der Maintainer von avrgirl-arduino seine Deps mal checken, ob man das auf eine stabile Version heben kann. Das Modul scheint aber nicht mehr richtig gepflegt zu werden.
            Ich bekomme seit einiger Zeit bei jedem Adapter-Update folgende Warnung:
            npm WARN skipping integrity check for git dependency ssh://git@github.com/noopkat/browser-serialport.git
            Ich hatte mal testhalber einen Adapter direkt über NPM aktualisiert und ich vermute, dass seitdem der integrity check deaktiviert ist. Wie stelle ich den Urzustand wieder her? Habe dazu nichts gefunden...
            @dr-bakterius In irgendeiner package.json oder in der package-lock.json steht das Paket wohl drin ... musst mal suchen
            Dr. BakteriusD Thomas BraunT 2 Antworten Letzte Antwort
              browser-serialport:
              Dr. Bakterius
              @thomas-braun sagte in npm WARN skipping integrity check:
              So sieht es leider aus. 🙁
              Der rflink-Adapter wird leider auch nicht gepflegt und von da kommt scheinbar das Paket.
              Doch warum das Problem erst seit kurzem auftritt? Kommt das mit einer nodejs-Version?
              • apollon77A apollon77
                Dr. Bakterius
                @apollon77 Und was kann ich dann daran ändern? Und vor allem wie?
                  @dr-bakterius Warten bis jemand Zeit hatte rflink mal zu aktualisieren. EIn issue dort wäre mal in jedem Fall hilfreich
                    @apollon77
                    Ja, in der
                    ist die Dep drin.
                      @apollon77
                      Ja, in der
                      ist die Dep drin.
                      @thomas-braun puuh ... dann kann aber auch der rflink nichts dagegen tun ....
                      Thomas BraunT Dr. BakteriusD 2 Antworten Letzte Antwort
                        @apollon77
                        Richtig.
                          Dr. Bakterius
                          @apollon77 sagte in npm WARN skipping integrity check:
                            OliverIOO Offline
                            OliverIOO Offline
                            OliverIO
                            hab das dazu gefunden
                            https://sebhastian.com/npm-err-code-eintegrity/
                            aber ohne gewähr, das das mit iobroker funktioniert
                            Meine Adapter und Widgets
                            Links im Profil
                            • OliverIOO OliverIO
                              Dr. Bakterius
                              @oliverio Danke, dazu habe ich etliche Seiten mit Tipps gefunden. Allerdings geht es hier um etwas anderes als EINTEGRITY.
                                OliverIOO Offline
                                OliverIOO Offline
                                OliverIO
                                @dr-bakterius
                                dann solltest du den Titel anpassen
                                Links im Profil
                                  @dr-bakterius
                                  Dr. Bakterius
                                  @oliverio Wieso? Es geht 1. nicht um einen Error sondern eine Warnung, und 2. nicht um 'EINTEGRITY' sondern 'integrity check'. Das sind zwei paar Schuhe...
                                    OliverIOO Offline
                                    OliverIOO Offline
                                    OliverIO
                                    @dr-bakterius
                                    meiner meinung nach nicht.
                                    jeweils ist die lösung die package-lock.json zu entfernen
                                    und durch npm neu erstellen zu lassen.
                                    aber alles gut.
                                    Links im Profil
                                      @dr-bakterius
                                      aber alles gut.
                                      @oliverio
                                      Nutzt hier aber nix, die Dep ist hartcodiert im package.json der subdependency von avrgirl-arduino drin. Das müsste wohl dort aktualisiert werden.
                                        @dr-bakterius
                                        aber alles gut.
                                        Dr. Bakterius
                                        @oliverio Um sicher zu gehen habe ich das trotzdem mal probiert -> ändert nichts. Kann es auch nicht wie @Thomas-Braun erklärt hat.
