  4. Ich kann nichts mehr installieren / updaten
    6.7k
80 Beiträge 6 Kommentatoren 12.4k Aufrufe 5 Beobachtet
    @fiso
    iobroker upgrade node-red@3.3.1 --debug
    FISO
    pi@iobroker-master:/opt/iobroker $ iobroker upgrade node-red@3.3.1 --debug
    This downgrade of "node-red" will remove the following changes:
    -> 4.0.0
    IMPORTANT: Node.js 14.x now needed at least
    Upgrade to node-red 3.0.2, enable runtime-state features and switch editor to monaco-editor
    Correctly escape backslashes when writing setting file on Windows
    BE CAREFUL: THIS IS A MAJOR DOWNGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to downgrade node-red from @4.0.0 to @3.3.1 now? [(y)es, (n)o]: y
    Update node-red from @4.0.0 to @3.3.1
    NPM version: 8.11.0
    Installing iobroker.node-red@3.3.1... (System call)
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/acorn
    npm ERR! dest /opt/iobroker/node_modules/.acorn-zHERliMH
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/acorn' -> '/opt/iobroker/node_modules/.acorn-zHERliMH'
    npm ERR!     /home/iobroker/.npm/_logs/2022-08-16T10_55_26_188Z-debug-0.log
    host.iobroker-master Cannot install iobroker.node-red@3.3.1: 217
    • F FISO
      -> 4.0.0
      NPM version: 8.11.0
      npm ERR! errno -39
      @fiso
      cd /opt/iobroker/node_modules
      for i in $(ls -d .[^.]*-*/); do rm -rf ${i%%/}; done
      F 1 Antwort Letzte Antwort
        @fiso
        FISO
        pi@iobroker-master:/opt/iobroker $ cd /opt/iobroker/node_modules
        pi@iobroker-master:/opt/iobroker/node_modules $ for i in $(ls -d .[^.]*-*/); do rm -rf ${i%%/}; done
        pi@iobroker-master:/opt/iobroker/node_modules $ iobroker upgrade node-red@3.3.1 --debug
        -> 4.0.0
        NPM version: 8.11.0
        npm ERR! path /opt/iobroker/node_modules/@babel/runtime
        npm ERR! dest /opt/iobroker/node_modules/@babel/.runtime-cSN2FFol
        npm ERR! errno -39
        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@babel/runtime' -> '/opt/iobroker/node_modules/@babel/.runtime-cSN2FFol'
        npm ERR!     /home/iobroker/.npm/_logs/2022-08-16T10_58_07_136Z-debug-0.log
        • F FISO
          -> 4.0.0
          NPM version: 8.11.0
          npm ERR! errno -39
          @fiso sagte in Ich kann nichts mehr installieren / updaten:
          cd /opt/iobroker/node_modules/@babel
          Und so weiter für weitere Verzeichnisse mit versteckten Verzeichnissen mit kryptischen Endungen.
            FISO
            schrieb am zuletzt editiert von FISO
            Danke, das hat dann funktioniert. Er konnte Node dann downgraden. Hab dann Node-Red im iobroker deinstalliert (hat auch geklappt), aber ich kann den Adapter nun garnichtmehr installieren. Es kommt immer folgende Fehlermeldung:
            $ iobroker add node-red auto --host iobroker-master --debug
            NPM version: 8.11.0Installing iobroker.node-red@4.0.0... (System call)
            host.iobroker-master Cannot install iobroker.node-red@4.0.0: 217
            ERROR: Process exited with code 25
            Was mir aufgefallen ist: Ich kann zumindest wieder neue Adapter installieren, das ging vorher nicht.
            den SQL Adapter wollte ich auch upgraden, aber es kommt folgende fehlermeldung:
            271 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/mkdirp': '/opt/iobroker/node_modules/node-gyp/node_modules/.mkdirp-MLo1vYTP',
            271 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/.bin/mkdirp': '/opt/iobroker/node_modules/node-gyp/node_modules/.bin/.mkdirp-Ct4LiqGE',
            271 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/is-fullwidth-code-point': '/opt/iobroker/node_modules/node-gyp/node_modules/.is-fullwidth-code-point-9zDQVrU4',
            271 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/npmlog': '/opt/iobroker/node_modules/node-gyp/node_modules/.npmlog-8fhQ4cOQ',
            271 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/readable-stream': '/opt/iobroker/node_modules/node-gyp/node_modules/.readable-stream-aZybdzCg',
            271 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/signal-exit': '/opt/iobroker/node_modules/node-gyp/node_modules/.signal-exit-LQ9rNd2v',
            271 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/string-width': '/opt/iobroker/node_modules/node-gyp/node_modules/.string-width-iQNhIdLT',
            271 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/strip-ansi': '/opt/iobroker/node_modules/node-gyp/node_modules/.strip-ansi-X1jmnUZh',
            271 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/tar': '/opt/iobroker/node_modules/node-gyp/node_modules/.tar-dy93EdLL',
            271 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/wide-align': '/opt/iobroker/node_modules/node-gyp/node_modules/.wide-align-HvDrjN4p',
            271 silly reify   '/opt/iobroker/node_modules/signal-exit': '/opt/iobroker/node_modules/.signal-exit-myKgrl00',
            271 silly reify   '/opt/iobroker/node_modules/socks': '/opt/iobroker/node_modules/.socks-Ly3eN6mV',
            271 silly reify   '/opt/iobroker/node_modules/socks-proxy-agent/node_modules/agent-base': '/opt/iobroker/node_modules/socks-proxy-agent/node_modules/.agent-base-kgXOEHfK',
            271 silly reify   '/opt/iobroker/node_modules/sqlite3': '/opt/iobroker/node_modules/.sqlite3-8qPhwEH9',
            271 silly reify   '/opt/iobroker/node_modules/tar': '/opt/iobroker/node_modules/.tar-NeTPgzH9',
            271 silly reify   '/opt/iobroker/node_modules/wide-align': '/opt/iobroker/node_modules/.wide-align-CJ7lqbuZ',
            271 silly reify   '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/chownr': '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/.chownr-8LatjZPf',
            271 silly reify   '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/mkdirp': '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/.mkdirp-zZ32xAdE',
            271 silly reify   '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/.bin/mkdirp': '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/.bin/.mkdirp-r2nTdSNU',
            271 silly reify   '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/tar': '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/.tar-MtfJh6vz'
            271 silly reify }
            272 timing reify:rollback:retireShallow Completed in 13ms
            273 timing command:install Completed in 10495ms
            274 verbose stack Error: ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/tar' -> '/opt/iobroker/node_modules/iobroker.js-controller/no$
            275 verbose cwd /opt/iobroker
            276 verbose Linux 5.10.103-v7l+
            277 verbose node v16.16.0
            278 verbose npm  v8.11.0
            279 error code ENOTEMPTY
            280 error syscall rename
            281 error path /opt/iobroker/node_modules/iobroker.js-controller/node_modules/tar
            282 error dest /opt/iobroker/node_modules/iobroker.js-controller/node_modules/.tar-k92wKR6q
            283 error errno -39
            284 error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/tar' -> '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/.tar$
            285 verbose exit -39
            286 timing npm Completed in 10790ms
            287 verbose unfinished npm timer reify 1660650749107
            288 verbose unfinished npm timer reify:retireShallow 1660650759551
            289 verbose code -39
            290 error A complete log of this run can be found in:
            290 error     /home/iobroker/.npm/_logs/2022-08-16T11_52_28_826Z-debug-0.log
            nachdem ich die verzeichnisse umbenannt habe erhalte ich noch folgende fehlermeldungen:
            $ iobroker upgrade sql@2.1.8 --debug
            Update sql from @2.1.7 to @2.1.8
            NPM version: 8.11.0Installing iobroker.sql@2.1.8... (System call)
            npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-08-16T12_14_18_123Z-debug-0.log
            host.iobroker-master Cannot install iobroker.sql@2.1.8: 217
            • F FISO
              271 silly reify }
              283 error errno -39
              Dann schau in das volle log rein.
                FISO
                0 verbose cli /usr/bin/node /usr/bin/npm
                1 info using npm@8.11.0
                2 info using node@v16.16.0
                3 timing npm:load:whichnode Completed in 0ms
                4 timing config:load:defaults Completed in 6ms
                5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms
                6 timing config:load:builtin Completed in 4ms
                7 timing config:load:cli Completed in 7ms
                8 timing config:load:env Completed in 0ms
                9 timing config:load:file:/opt/iobroker/.npmrc Completed in 4ms
                10 timing config:load:project Completed in 14ms
                11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
                12 timing config:load:user Completed in 1ms
                13 timing config:load:file:/usr/etc/npmrc Completed in 1ms
                14 timing config:load:global Completed in 1ms
                15 timing config:load:validate Completed in 1ms
                16 timing config:load:credentials Completed in 4ms
                17 timing config:load:setEnvs Completed in 4ms
                18 timing config:load Completed in 46ms
                19 timing npm:load:configload Completed in 48ms
                20 timing npm:load:mkdirpcache Completed in 4ms
                21 timing npm:load:mkdirplogs Completed in 1ms
                22 verbose title npm install iobroker.sql@2.1.8
                23 verbose argv "install" "--save-exact" "iobroker.sql@2.1.8"
                24 timing npm:load:setTitle Completed in 4ms
                25 timing config:load:flatten Completed in 13ms
                26 timing npm:load:display Completed in 18ms
                27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
                28 verbose logfile /home/iobroker/.npm/_logs/2022-08-16T12_14_18_123Z-debug-0.log
                29 timing npm:load:logFile Completed in 22ms
                30 timing npm:load:timers Completed in 1ms
                31 timing npm:load:configScope Completed in 0ms
                32 timing npm:load Completed in 102ms
                33 timing arborist:ctor Completed in 3ms
                34 silly logfile start cleaning logs, removing 2 files
                35 silly logfile done cleaning log files
                36 timing idealTree:init Completed in 3715ms
                37 timing idealTree:userRequests Completed in 31ms
                38 silly idealTree buildDeps
                39 silly fetch manifest iobroker.sql@2.1.8
                40 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
                41 http fetch GET 200 https://registry.npmjs.org/iobroker.sql 4928ms (cache revalidated)
                42 silly placeDep ROOT iobroker.sql@2.1.8 REPLACE for: iobroker.inst@2.0.3 want: 2.1.8
                43 silly fetch manifest sqlite3@^5.0.11
                44 http fetch GET 200 https://registry.npmjs.org/sqlite3 72ms (cache revalidated)
                45 timing idealTree:#root Completed in 5064ms
                46 silly placeDep ROOT sqlite3@5.0.11 OK for: iobroker.sql@2.1.8 want: ^5.0.11
                47 silly fetch manifest tar@^6.1.11
                48 silly fetch manifest node-gyp@8.x
                49 http fetch GET 200 https://registry.npmjs.org/tar 84ms (cache revalidated)
                50 http fetch GET 200 https://registry.npmjs.org/node-gyp 113ms (cache revalidated)
                51 timing idealTree:node_modules/iobroker.sql Completed in 137ms
                52 silly placeDep ROOT node-gyp@8.4.1 OK for: sqlite3@5.0.11 want: 8.x
                53 silly placeDep ROOT tar@6.1.11 REPLACE for: sqlite3@5.0.11 want: ^6.1.11
                54 silly fetch manifest env-paths@^2.2.0
                55 silly fetch manifest graceful-fs@^4.2.6
                56 silly fetch manifest make-fetch-happen@^9.1.0
                57 silly fetch manifest npmlog@^6.0.0
                58 silly fetch manifest semver@^7.3.5
                59 http fetch GET 200 https://registry.npmjs.org/graceful-fs 68ms (cache revalidated)
                60 http fetch GET 200 https://registry.npmjs.org/npmlog 96ms (cache revalidated)
                61 http fetch GET 200 https://registry.npmjs.org/env-paths 119ms (cache revalidated)
                62 http fetch GET 200 https://registry.npmjs.org/semver 121ms (cache revalidated)
                63 http fetch GET 200 https://registry.npmjs.org/make-fetch-happen 166ms (cache revalidated)
                64 timing idealTree:node_modules/sqlite3 Completed in 203ms
                65 silly placeDep ROOT env-paths@2.2.1 OK for: node-gyp@8.4.1 want: ^2.2.0
                66 silly placeDep ROOT graceful-fs@4.2.10 REPLACE for: node-gyp@8.4.1 want: ^4.2.6
                67 silly placeDep ROOT make-fetch-happen@9.1.0 OK for: node-gyp@8.4.1 want: ^9.1.0
                68 silly placeDep ROOT npmlog@6.0.2 OK for: node-gyp@8.4.1 want: ^6.0.0
                69 silly placeDep node_modules/node-gyp semver@7.3.7 OK for: node-gyp@8.4.1 want: ^7.3.5
                70 silly fetch manifest agentkeepalive@^4.1.3
                71 silly fetch manifest cacache@^15.2.0
                72 silly fetch manifest is-lambda@^1.0.1
                73 silly fetch manifest minipass-collect@^1.0.2
                74 silly fetch manifest minipass-fetch@^1.3.2
                75 silly fetch manifest minipass-flush@^1.0.5
                76 silly fetch manifest minipass-pipeline@^1.2.4
                77 silly fetch manifest promise-retry@^2.0.1
                78 silly fetch manifest socks-proxy-agent@^6.0.0
                79 silly fetch manifest ssri@^8.0.0
                80 silly fetch manifest are-we-there-yet@^3.0.0
                81 silly fetch manifest gauge@^4.0.3
                82 http fetch GET 200 https://registry.npmjs.org/is-lambda 138ms (cache revalidated)
                83 http fetch GET 200 https://registry.npmjs.org/agentkeepalive 143ms (cache revalidated)
                84 http fetch GET 200 https://registry.npmjs.org/minipass-fetch 144ms (cache revalidated)
                85 http fetch GET 200 https://registry.npmjs.org/cacache 153ms (cache revalidated)
                86 http fetch GET 200 https://registry.npmjs.org/minipass-collect 178ms (cache revalidated)
                87 http fetch GET 200 https://registry.npmjs.org/minipass-flush 178ms (cache revalidated)
                88 http fetch GET 200 https://registry.npmjs.org/minipass-pipeline 179ms (cache revalidated)
                89 http fetch GET 200 https://registry.npmjs.org/ssri 191ms (cache revalidated)
                90 http fetch GET 200 https://registry.npmjs.org/socks-proxy-agent 203ms (cache revalidated)
                91 http fetch GET 200 https://registry.npmjs.org/are-we-there-yet 205ms (cache revalidated)
                92 http fetch GET 200 https://registry.npmjs.org/gauge 207ms (cache revalidated)
                93 http fetch GET 200 https://registry.npmjs.org/promise-retry 215ms (cache revalidated)
                94 timing idealTree:node_modules/node-gyp Completed in 269ms
                95 timing idealTree:node_modules/env-paths Completed in 0ms
                96 timing idealTree:node_modules/graceful-fs Completed in 0ms
                97 silly placeDep ROOT agentkeepalive@4.2.1 OK for: make-fetch-happen@9.1.0 want: ^4.1.3
                98 silly placeDep ROOT cacache@15.3.0 OK for: make-fetch-happen@9.1.0 want: ^15.2.0
                99 silly placeDep ROOT is-lambda@1.0.1 OK for: make-fetch-happen@9.1.0 want: ^1.0.1
                100 silly placeDep ROOT minipass-collect@1.0.2 OK for: make-fetch-happen@9.1.0 want: ^1.0.2
                101 silly placeDep ROOT minipass-fetch@1.4.1 OK for: make-fetch-happen@9.1.0 want: ^1.3.2
                102 silly placeDep ROOT minipass-flush@1.0.5 OK for: make-fetch-happen@9.1.0 want: ^1.0.5
                103 silly placeDep ROOT minipass-pipeline@1.2.4 OK for: make-fetch-happen@9.1.0 want: ^1.2.4
                104 silly placeDep ROOT promise-retry@2.0.1 OK for: make-fetch-happen@9.1.0 want: ^2.0.1
                105 silly placeDep ROOT socks-proxy-agent@6.2.1 OK for: make-fetch-happen@9.1.0 want: ^6.0.0
                106 silly placeDep ROOT ssri@8.0.1 OK for: make-fetch-happen@9.1.0 want: ^8.0.0
                107 silly fetch manifest debug@^4.1.0
                108 silly fetch manifest humanize-ms@^1.2.1
                109 silly fetch manifest @npmcli/fs@^1.0.0
                110 silly fetch manifest @npmcli/move-file@^1.0.1
                111 silly fetch manifest chownr@^2.0.0
                112 silly fetch manifest infer-owner@^1.0.4
                113 silly fetch manifest mkdirp@^1.0.3
                114 silly fetch manifest p-map@^4.0.0
                115 silly fetch manifest promise-inflight@^1.0.1
                116 silly fetch manifest unique-filename@^1.1.1
                117 silly fetch manifest minipass-sized@^1.0.3
                118 silly fetch manifest err-code@^2.0.2
                119 silly fetch manifest agent-base@^6.0.2
                120 silly fetch manifest debug@^4.3.3
                121 silly fetch manifest socks@^2.6.2
                122 http fetch GET 200 https://registry.npmjs.org/infer-owner 200ms (cache revalidated)
                123 http fetch GET 200 https://registry.npmjs.org/chownr 203ms (cache revalidated)
                124 http fetch GET 200 https://registry.npmjs.org/humanize-ms 213ms (cache revalidated)
                125 http fetch GET 200 https://registry.npmjs.org/promise-inflight 195ms (cache revalidated)
                126 http fetch GET 200 https://registry.npmjs.org/@npmcli%2fmove-file 211ms (cache revalidated)
                127 http fetch GET 200 https://registry.npmjs.org/unique-filename 197ms (cache revalidated)
                128 http fetch GET 200 https://registry.npmjs.org/mkdirp 206ms (cache revalidated)
                129 http fetch GET 200 https://registry.npmjs.org/minipass-sized 198ms (cache revalidated)
                130 http fetch GET 200 https://registry.npmjs.org/debug 226ms (cache revalidated)
                131 http fetch GET 200 https://registry.npmjs.org/err-code 203ms (cache revalidated)
                132 http fetch GET 200 https://registry.npmjs.org/@npmcli%2ffs 230ms (cache revalidated)
                133 http fetch GET 200 https://registry.npmjs.org/p-map 223ms (cache revalidated)
                134 http fetch GET 200 https://registry.npmjs.org/agent-base 222ms (cache revalidated)
                135 http fetch GET 200 https://registry.npmjs.org/debug 248ms (cache revalidated)
                136 http fetch GET 200 https://registry.npmjs.org/socks 262ms (cache revalidated)
                137 timing idealTree:node_modules/make-fetch-happen Completed in 353ms
                138 silly placeDep node_modules/agentkeepalive debug@4.3.4 OK for: agentkeepalive@4.2.1 want: ^4.1.0
                139 silly placeDep ROOT humanize-ms@1.2.1 OK for: agentkeepalive@4.2.1 want: ^1.2.1
                140 silly fetch manifest ms@2.1.2
                141 http fetch GET 200 https://registry.npmjs.org/ms 51ms (cache revalidated)
                142 timing idealTree:node_modules/agentkeepalive Completed in 63ms
                143 silly placeDep ROOT @npmcli/fs@1.1.1 OK for: cacache@15.3.0 want: ^1.0.0
                144 silly placeDep ROOT @npmcli/move-file@1.1.2 OK for: cacache@15.3.0 want: ^1.0.1
                145 silly placeDep ROOT chownr@2.0.0 OK for: cacache@15.3.0 want: ^2.0.0
                146 silly placeDep ROOT infer-owner@1.0.4 OK for: cacache@15.3.0 want: ^1.0.4
                147 silly placeDep node_modules/cacache mkdirp@1.0.4 OK for: cacache@15.3.0 want: ^1.0.3
                148 silly placeDep node_modules/cacache p-map@4.0.0 OK for: cacache@15.3.0 want: ^4.0.0
                149 silly placeDep ROOT promise-inflight@1.0.1 OK for: cacache@15.3.0 want: ^1.0.1
                150 silly placeDep ROOT unique-filename@1.1.1 OK for: cacache@15.3.0 want: ^1.1.1
                151 silly fetch manifest @gar/promisify@^1.0.1
                152 silly fetch manifest mkdirp@^1.0.4
                153 silly fetch manifest unique-slug@^2.0.0
                154 http fetch GET 200 https://registry.npmjs.org/unique-slug 45ms (cache revalidated)
                155 http fetch GET 200 https://registry.npmjs.org/@gar%2fpromisify 73ms (cache revalidated)
                156 timing idealTree:node_modules/cacache Completed in 110ms
                157 silly placeDep ROOT @gar/promisify@1.1.3 OK for: @npmcli/fs@1.1.1 want: ^1.0.1
                158 silly placeDep node_modules/@npmcli/fs semver@7.3.7 OK for: @npmcli/fs@1.1.1 want: ^7.3.5
                159 timing idealTree:node_modules/@npmcli/fs Completed in 8ms
                160 timing idealTree:node_modules/@gar/promisify Completed in 0ms
                161 silly placeDep node_modules/@npmcli/move-file mkdirp@1.0.4 OK for: @npmcli/move-file@1.1.2 want: ^1.0.4
                162 timing idealTree:node_modules/@npmcli/move-file Completed in 7ms
                163 timing idealTree:node_modules/chownr Completed in 1ms
                164 timing idealTree:node_modules/humanize-ms Completed in 0ms
                165 timing idealTree:node_modules/infer-owner Completed in 0ms
                166 timing idealTree:node_modules/is-lambda Completed in 0ms
                167 timing idealTree:node_modules/minipass-collect Completed in 0ms
                168 silly placeDep ROOT minipass-sized@1.0.3 OK for: minipass-fetch@1.4.1 want: ^1.0.3
                169 timing idealTree:node_modules/minipass-fetch Completed in 5ms
                170 timing idealTree:node_modules/minipass-flush Completed in 0ms
                171 timing idealTree:node_modules/minipass-pipeline Completed in 0ms
                172 timing idealTree:node_modules/minipass-sized Completed in 0ms
                173 silly placeDep ROOT are-we-there-yet@3.0.1 OK for: npmlog@6.0.2 want: ^3.0.0
                174 silly placeDep ROOT gauge@4.0.4 OK for: npmlog@6.0.2 want: ^4.0.3
                175 silly fetch manifest readable-stream@^3.6.0
                176 silly fetch manifest signal-exit@^3.0.7
                177 silly fetch manifest string-width@^4.2.3
                178 silly fetch manifest strip-ansi@^6.0.1
                179 silly fetch manifest wide-align@^1.1.5
                180 http fetch GET 200 https://registry.npmjs.org/signal-exit 52ms (cache revalidated)
                181 http fetch GET 200 https://registry.npmjs.org/strip-ansi 65ms (cache revalidated)
                182 http fetch GET 200 https://registry.npmjs.org/readable-stream 76ms (cache revalidated)
                183 http fetch GET 200 https://registry.npmjs.org/string-width 83ms (cache revalidated)
                184 http fetch GET 200 https://registry.npmjs.org/wide-align 84ms (cache revalidated)
                185 timing idealTree:node_modules/npmlog Completed in 108ms
                186 silly placeDep node_modules/are-we-there-yet readable-stream@3.6.0 OK for: are-we-there-yet@3.0.1 want: ^3.6.0
                187 timing idealTree:node_modules/are-we-there-yet Completed in 5ms
                188 silly placeDep ROOT signal-exit@3.0.7 REPLACE for: gauge@4.0.4 want: ^3.0.7
                189 silly placeDep node_modules/gauge string-width@4.2.3 OK for: gauge@4.0.4 want: ^4.2.3
                190 silly placeDep node_modules/gauge strip-ansi@6.0.1 OK for: gauge@4.0.4 want: ^6.0.1
                191 silly placeDep ROOT wide-align@1.1.5 REPLACE for: gauge@4.0.4 want: ^1.1.5
                192 silly fetch manifest is-fullwidth-code-point@^3.0.0
                193 silly fetch manifest ansi-regex@^5.0.1
                194 http fetch GET 200 https://registry.npmjs.org/is-fullwidth-code-point 68ms (cache revalidated)
                195 http fetch GET 200 https://registry.npmjs.org/ansi-regex 68ms (cache revalidated)
                196 timing idealTree:node_modules/gauge Completed in 96ms
                197 timing idealTree:node_modules/promise-inflight Completed in 0ms
                198 silly placeDep ROOT err-code@2.0.3 OK for: promise-retry@2.0.1 want: ^2.0.2
                199 timing idealTree:node_modules/promise-retry Completed in 4ms
                200 timing idealTree:node_modules/err-code Completed in 0ms
                201 timing idealTree:node_modules/signal-exit Completed in 0ms
                202 silly placeDep ROOT agent-base@6.0.2 REPLACE for: socks-proxy-agent@6.2.1 want: ^6.0.2
                203 silly placeDep node_modules/socks-proxy-agent debug@4.3.4 OK for: socks-proxy-agent@6.2.1 want: ^4.3.3
                204 silly placeDep ROOT socks@2.7.0 OK for: socks-proxy-agent@6.2.1 want: ^2.6.2
                205 silly fetch manifest ip@^2.0.0
                206 silly fetch manifest smart-buffer@^4.2.0
                207 http fetch GET 200 https://registry.npmjs.org/ip 50ms (cache revalidated)
                208 http fetch GET 200 https://registry.npmjs.org/smart-buffer 58ms (cache revalidated)
                209 timing idealTree:node_modules/socks-proxy-agent Completed in 81ms
                210 timing idealTree:node_modules/agent-base Completed in 0ms
                211 silly placeDep node_modules/socks ip@2.0.0 OK for: socks@2.7.0 want: ^2.0.0
                212 silly placeDep ROOT smart-buffer@4.2.0 OK for: socks@2.7.0 want: ^4.2.0
                213 timing idealTree:node_modules/socks Completed in 7ms
                214 timing idealTree:node_modules/smart-buffer Completed in 0ms
                215 timing idealTree:node_modules/ssri Completed in 0ms
                216 timing idealTree:node_modules/tar Completed in 0ms
                217 silly placeDep ROOT unique-slug@2.0.2 OK for: unique-filename@1.1.1 want: ^2.0.0
                218 timing idealTree:node_modules/unique-filename Completed in 5ms
                219 timing idealTree:node_modules/unique-slug Completed in 0ms
                220 timing idealTree:node_modules/wide-align Completed in 0ms
                221 timing idealTree:node_modules/@npmcli/fs/node_modules/semver Completed in 0ms
                222 timing idealTree:node_modules/@npmcli/move-file/node_modules/mkdirp Completed in 0ms
                223 silly placeDep node_modules/agentkeepalive ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
                224 timing idealTree:node_modules/agentkeepalive/node_modules/debug Completed in 3ms
                225 timing idealTree:node_modules/agentkeepalive/node_modules/ms Completed in 0ms
                226 timing idealTree:node_modules/are-we-there-yet/node_modules/readable-stream Completed in 0ms
                227 timing idealTree:node_modules/cacache/node_modules/mkdirp Completed in 0ms
                228 timing idealTree:node_modules/cacache/node_modules/p-map Completed in 0ms
                229 silly placeDep node_modules/gauge is-fullwidth-code-point@3.0.0 OK for: string-width@4.2.3 want: ^3.0.0
                230 timing idealTree:node_modules/gauge/node_modules/string-width Completed in 3ms
                231 timing idealTree:node_modules/gauge/node_modules/is-fullwidth-code-point Completed in 0ms
                232 silly placeDep node_modules/gauge ansi-regex@5.0.1 OK for: strip-ansi@6.0.1 want: ^5.0.1
                233 timing idealTree:node_modules/gauge/node_modules/strip-ansi Completed in 4ms
                234 timing idealTree:node_modules/gauge/node_modules/ansi-regex Completed in 0ms
                235 timing idealTree:node_modules/node-gyp/node_modules/semver Completed in 0ms
                236 silly placeDep node_modules/socks-proxy-agent ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
                237 timing idealTree:node_modules/socks-proxy-agent/node_modules/debug Completed in 3ms
                238 timing idealTree:node_modules/socks-proxy-agent/node_modules/ms Completed in 0ms
                239 timing idealTree:node_modules/socks/node_modules/ip Completed in 0ms
                240 timing idealTree:buildDeps Completed in 6558ms
                241 timing idealTree:fixDepFlags Completed in 41ms
                242 timing idealTree Completed in 10413ms
                243 timing reify:loadTrees Completed in 10416ms
                244 timing reify:diffTrees Completed in 159ms
                245 silly reify mark retired [ '/opt/iobroker/node_modules/agent-base' ]
                246 silly reify mark retired [ '/opt/iobroker/node_modules/graceful-fs' ]
                247 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.sql' ]
                248 silly reify mark retired [ '/opt/iobroker/node_modules/node-gyp/node_modules/ansi-regex' ]
                249 silly reify mark retired [ '/opt/iobroker/node_modules/node-gyp/node_modules/are-we-there-yet' ]
                250 silly reify mark retired [ '/opt/iobroker/node_modules/node-gyp/node_modules/gauge' ]
                251 silly reify mark retired [ '/opt/iobroker/node_modules/node-gyp/node_modules/graceful-fs' ]
                252 silly reify mark retired [
                252 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/is-fullwidth-code-point'
                252 silly reify ]
                253 silly reify mark retired [
                253 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/mkdirp',
                253 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/.bin/mkdirp'
                253 silly reify ]
                254 silly reify mark retired [ '/opt/iobroker/node_modules/node-gyp/node_modules/npmlog' ]
                255 silly reify mark retired [ '/opt/iobroker/node_modules/node-gyp/node_modules/readable-stream' ]
                256 silly reify mark retired [ '/opt/iobroker/node_modules/node-gyp/node_modules/signal-exit' ]
                257 silly reify mark retired [ '/opt/iobroker/node_modules/node-gyp/node_modules/string-width' ]
                258 silly reify mark retired [ '/opt/iobroker/node_modules/node-gyp/node_modules/strip-ansi' ]
                259 silly reify mark retired [ '/opt/iobroker/node_modules/node-gyp/node_modules/tar' ]
                260 silly reify mark retired [ '/opt/iobroker/node_modules/node-gyp/node_modules/wide-align' ]
                261 silly reify mark retired [ '/opt/iobroker/node_modules/signal-exit' ]
                262 silly reify mark retired [ '/opt/iobroker/node_modules/socks' ]
                263 silly reify mark retired [
                263 silly reify   '/opt/iobroker/node_modules/socks-proxy-agent/node_modules/agent-base'
                263 silly reify ]
                264 silly reify mark retired [ '/opt/iobroker/node_modules/sqlite3' ]
                265 silly reify mark retired [ '/opt/iobroker/node_modules/tar' ]
                266 silly reify mark retired [ '/opt/iobroker/node_modules/wide-align' ]
                267 silly reify mark retired [
                267 silly reify   '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/chownr'
                267 silly reify ]
                268 silly reify mark retired [
                268 silly reify   '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/mkdirp',
                268 silly reify   '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/.bin/mkdirp'
                268 silly reify ]
                269 silly reify mark retired [ '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/tar' ]
                270 silly reify moves {
                270 silly reify   '/opt/iobroker/node_modules/agent-base': '/opt/iobroker/node_modules/.agent-base-ZzrsLltQ',
                270 silly reify   '/opt/iobroker/node_modules/graceful-fs': '/opt/iobroker/node_modules/.graceful-fs-i6Qs7iN3',
                270 silly reify   '/opt/iobroker/node_modules/iobroker.sql': '/opt/iobroker/node_modules/.iobroker.sql-Fn6FdfaN',
                270 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/ansi-regex': '/opt/iobroker/node_modules/node-gyp/node_modules/.ansi-regex-eL7byA1O',
                270 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/are-we-there-yet': '/opt/iobroker/node_modules/node-gyp/node_modules/.are-we-there-yet-2tsPr0vj',
                270 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/gauge': '/opt/iobroker/node_modules/node-gyp/node_modules/.gauge-jCwNXEj3',
                270 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/graceful-fs': '/opt/iobroker/node_modules/node-gyp/node_modules/.graceful-fs-sMDmNP2m',
                270 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/is-fullwidth-code-point': '/opt/iobroker/node_modules/node-gyp/node_modules/.is-fullwidth-code-point-9zDQVrU4',
                270 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/mkdirp': '/opt/iobroker/node_modules/node-gyp/node_modules/.mkdirp-MLo1vYTP',
                270 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/.bin/mkdirp': '/opt/iobroker/node_modules/node-gyp/node_modules/.bin/.mkdirp-Ct4LiqGE',
                270 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/npmlog': '/opt/iobroker/node_modules/node-gyp/node_modules/.npmlog-8fhQ4cOQ',
                270 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/readable-stream': '/opt/iobroker/node_modules/node-gyp/node_modules/.readable-stream-aZybdzCg',
                270 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/signal-exit': '/opt/iobroker/node_modules/node-gyp/node_modules/.signal-exit-LQ9rNd2v',
                270 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/string-width': '/opt/iobroker/node_modules/node-gyp/node_modules/.string-width-iQNhIdLT',
                270 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/strip-ansi': '/opt/iobroker/node_modules/node-gyp/node_modules/.strip-ansi-X1jmnUZh',
                270 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/tar': '/opt/iobroker/node_modules/node-gyp/node_modules/.tar-dy93EdLL',
                270 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/wide-align': '/opt/iobroker/node_modules/node-gyp/node_modules/.wide-align-HvDrjN4p',
                270 silly reify   '/opt/iobroker/node_modules/signal-exit': '/opt/iobroker/node_modules/.signal-exit-myKgrl00',
                270 silly reify   '/opt/iobroker/node_modules/socks': '/opt/iobroker/node_modules/.socks-Ly3eN6mV',
                270 silly reify   '/opt/iobroker/node_modules/socks-proxy-agent/node_modules/agent-base': '/opt/iobroker/node_modules/socks-proxy-agent/node_modules/.agent-base-kgXOEHfK',
                270 silly reify   '/opt/iobroker/node_modules/sqlite3': '/opt/iobroker/node_modules/.sqlite3-8qPhwEH9',
                270 silly reify   '/opt/iobroker/node_modules/tar': '/opt/iobroker/node_modules/.tar-NeTPgzH9',
                270 silly reify   '/opt/iobroker/node_modules/wide-align': '/opt/iobroker/node_modules/.wide-align-CJ7lqbuZ',
                270 silly reify   '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/chownr': '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/.chownr-8LatjZPf',
                270 silly reify   '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/mkdirp': '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/.mkdirp-zZ32xAdE',
                270 silly reify   '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/.bin/mkdirp': '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/.bin/.mkdirp-r2nTdSNU',
                270 silly reify   '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/tar': '/opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/.tar-MtfJh6vz'
                270 silly reify }
                271 timing reify:rollback:retireShallow Completed in 22ms
                272 timing command:install Completed in 10714ms
                273 verbose stack Error: ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/node-gyp/node_modules/mkdirp' -> '/opt/iobroker/node_modules/node-gyp/node_modules/.mkdirp-MLo1vY$
                274 verbose cwd /opt/iobroker
                275 verbose Linux 5.10.103-v7l+
                276 verbose node v16.16.0
                277 verbose npm  v8.11.0
                278 error code ENOTEMPTY
                279 error syscall rename
                280 error path /opt/iobroker/node_modules/node-gyp/node_modules/mkdirp
                281 error dest /opt/iobroker/node_modules/node-gyp/node_modules/.mkdirp-MLo1vYTP
                282 error errno -39
                283 error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/node-gyp/node_modules/mkdirp' -> '/opt/iobroker/node_modules/node-gyp/node_modules/.mkdirp-MLo1vYTP'
                284 verbose exit -39
                285 timing npm Completed in 11052ms
                286 verbose unfinished npm timer reify 1660652058449
                287 verbose unfinished npm timer reify:retireShallow 1660652069071
                288 verbose code -39
                289 error A complete log of this run can be found in:
                289 error     /home/iobroker/.npm/_logs/2022-08-16T12_14_18_123Z-debug-0.log
                GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                • F FISO
                  252 silly reify ]
                  253 silly reify ]
                  263 silly reify ]
                  267 silly reify ]
                  268 silly reify ]
                  270 silly reify }
                  282 error errno -39
                  GlasfaserG Offline
                  GlasfaserG Offline
                  • F FISO
                    252 silly reify ]
                    253 silly reify ]
                    263 silly reify ]
                    267 silly reify ]
                    268 silly reify ]
                    270 silly reify }
                    282 error errno -39
                    cd /opt/iobroker/node_modules/node-gyp/node_modules/
                    Ggf. weitere Verzeichnisse ebenso behandeln.
                      FISO
                      was würde denn passieren, wenn ich den ordner "Node_modules" komplett lösche? Mir scheint es dass das nen chaos drin ist, wie die Suche nach der Nadel um Heuhaufen....
                      • F FISO
                        @fiso
                        Probier es aus...
                        • F Offline
                          FISO
                          Ich glaub mein System ist nun schrott...
                          pi@iobroker-master:/home/iobroker $ sudo iobroker update        node:internal/modules/cjs/loader:936
                            throw err;
                          Error: Cannot find module 'graceful-fs'
                          Require stack:
                          - /opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib/fs/index.js
                          - /opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib/index.js
                          - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                          - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                              at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                              at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                              at Module.require (node:internal/modules/cjs/loader:1005:19)
                              at require (node:internal/modules/cjs/helpers:102:18)
                              at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-                                             extra/lib/fs/index.js:5:12)
                              at Module._compile (node:internal/modules/cjs/loader:1105:14)
                              at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
                              at Module.load (node:internal/modules/cjs/loader:981:32)
                              at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                              at Module.require (node:internal/modules/cjs/loader:1005:19) {
                            code: 'MODULE_NOT_FOUND',
                            requireStack: [
                              '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib/fs/index.js'                                             ,
                              '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib/index.js',
                              '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                              '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                          Ist das system noch rettbar?
                          • F FISO
                              throw err;
                            Require stack:
                              requireStack: [
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Kein SUDO vor iobroker Befehle !!!!
                            • GlasfaserG Glasfaser
                              FISO
                              @glasfaser ok, aber das Modul graceful-fs kann er immer noch net finden
                              • F FISO
                                @fiso
                                Finger weg von sudo! Warum ist diese Unart immer noch so verbreitet?
                                cd /opt/iobroker
                                sudo -H -u iobroker npm install iobroker.js-controller
                                  @fiso
                                  cd /opt/iobroker
                                  FISO
                                  erstmal vielen Dank euch beiden für eure Hilfe! Ist ja nicht selbstverständlich....
                                  Langsam aber sicher hab ich das Gefühl, ich werd vom "System" verarscht....
                                  Langsam breitet sich bei mir der Frust aus.....
                                  • F FISO
                                    Das kommt vom löschen des modules-Verzeichnis, würde ich sagen.
                                    Und die angemeckerten Verzeichnisse kommen von der Verwendung von 'sudo iobroker', würde ich sagen.
                                      FISO
                                      @thomas-braun Der Witz ist eigentlich, ich hab das Modul-Verzeichnis nichtmal gelöscht. Ich hab eigentlich nur die Verzeichnisse umbenannt die beim update des SQL Adapters angekreidet wurden,....
                                      • F FISO
                                        @fiso
                                        Was immer alles so gemacht wird...
                                        Deswegen werden die ja auch gelöscht und nicht umbenannt.
                                          @fiso
                                          FISO
                                          @thomas-braun Ich hab den ganzen Ordner Modules mal platt gemacht. Interessanterweise konnte ich dann den JS-Controller installieren.... Daraufhin konnte iobroker wieder starten. Jetzt versuch ich grad den SQL Adapter upzugraden... bin gespannt ;)
                                          So, er hat doch tatsächlich den Adapter installiert... bin einerseits begeistert, andererseits verärgert weil ich gut 6h damit verblödet habe... Oh mann.. Ich danke dir auf jedenfall für deine Mühe, euch beiden!
