  4. Vis speichert Änderungen nicht
    1.9k
43 Beiträge 21 Kommentatoren 11.8k Aufrufe 3 Beobachtet
  • ChaotC Offline
    ChaotC Offline
    Chaot
    Ich kann weder eine geänderte Version installieren noch manuell VIS neu installieren.
    Das hier habe ich im Log:
    • host.Haus 2018-02-12 17:48:00.051 info Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    iobroker 2018-02-12 17:47:59.779 info exit 0
    iobroker 2018-02-12 17:47:59.755 error Cannot parse /opt/iobroker/node_modules/iobroker.js-controller/adapter/vis/io-package.json:Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/adapter/vi
    iobroker 2018-02-12 17:47:59.666 info /npm-debug.log
    iobroker 2018-02-12 17:47:59.661 info npm ERR! Please include the following file with any support request:npm ERR!
    iobroker 2018-02-12 17:47:59.660 info
    iobroker 2018-02-12 17:47:59.522 info ERR! npm owner ls iobroker.visnpm ERR! There is likely additional logging output above.
    iobroker 2018-02-12 17:47:59.521 info Or if that isn't available, you can get their info via:npm
    iobroker 2018-02-12 17:47:59.514 info npm ERR!
    iobroker 2018-02-12 17:47:59.514 info npm ERR! npm bugs iobroker.vis
    iobroker 2018-02-12 17:47:59.514 info ERR! node main.js –installnpm ERR! You can get information on how to open an issue for this project with:
    iobroker 2018-02-12 17:47:59.511 info npm
    iobroker 2018-02-12 17:47:59.511 info npm ERR! Tell the author that this fails on your system:
    iobroker 2018-02-12 17:47:59.511 info npm ERR! not with npm itself.
    iobroker 2018-02-12 17:47:59.511 info npm ERR! If you do, this is most likely a problem with the iobroker.vis package,
    iobroker 2018-02-12 17:47:59.511 info npm ERR! Make sure you have the latest version of node.js and npm installed.
    iobroker 2018-02-12 17:47:59.511 info npm ERR! Failed at the iobroker.vis@1.1.2 install script 'node main.js --install'.
    iobroker 2018-02-12 17:47:59.511 info ERR! iobroker.vis@1.1.2 install: `node main.js --install`npm ERR! Exit status 1
    iobroker 2018-02-12 17:47:59.510 info npm
    iobroker 2018-02-12 17:47:59.510 info ERR! code ELIFECYCLE
    iobroker 2018-02-12 17:47:59.508 info npm ERR! npm v3.10.10npm
    iobroker 2018-02-12 17:47:59.506 info npm ERR! node v6.12.3
    iobroker 2018-02-12 17:47:59.506 info ERR! Linux 4.9.59-v7+npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "[https://github.com/iobroker/ioBroker.vis/tarball/master](https://github.com/iobroker/ioBroker.vis/tarball/master)" "--production" "--prefix" "/opt/iobroker"
    iobroker 2018-02-12 17:47:59.504 info npm
    iobroker 2018-02-12 17:47:59.498 info npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported pla
    iobroker 2018-02-12 17:47:59.494 info WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/chokidar/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.3: wante
    iobroker 2018-02-12 17:47:59.493 info npm
    iobroker 2018-02-12 17:47:57.252 info at startup (bootstrap_node.js:149:9)
    iobroker 2018-02-12 17:47:57.252 info at run (bootstrap_node.js:383:7)
    iobroker 2018-02-12 17:47:57.252 info at Module.runMain (module.js:604:10)
    iobroker 2018-02-12 17:47:57.252 info at Function.Module._load (module.js:438:3)
    iobroker 2018-02-12 17:47:57.252 info at tryModuleLoad (module.js:446:12)
    iobroker 2018-02-12 17:47:57.252 info at Module.load (module.js:487:32)
    iobroker 2018-02-12 17:47:57.252 info at Object.Module._extensions..js (module.js:579:10)
    iobroker 2018-02-12 17:47:57.252 info at Module._compile (module.js:542:28)
    iobroker 2018-02-12 17:47:57.252 info at Object.runInThisContext (vm.js:97:10)
    iobroker 2018-02-12 17:47:57.252 info at createScript (vm.js:56:10)
    iobroker 2018-02-12 17:47:57.252 info SyntaxError: Unexpected token ,
    iobroker 2018-02-12 17:47:57.252 info ^
    iobroker 2018-02-12 17:47:57.252 info /opt/iobroker/node_modules/iobroker.vis/main.js:250 , function () {
    iobroker 2018-02-12 17:47:08.670 info npm install [https://github.com/iobroker/ioBroker.vis/tarball/master](https://github.com/iobroker/ioBroker.vis/tarball/master) --production --prefix "/opt/iobroker" (System call)
    iobroker 2018-02-12 17:47:08.092 info install [https://github.com/iobroker/ioBroker.vis/tarball/master](https://github.com/iobroker/ioBroker.vis/tarball/master)
    iobroker 2018-02-12 17:47:06.903 info url "[https://github.com/iobroker/ioBroker.vis/tarball/master](https://github.com/iobroker/ioBroker.vis/tarball/master)" vis
    Bei mir speicher VIS auch nicht mehr nachdem ich versucht habe ein HTML widget zu erstellen.
    Edit:
    Das Downgrade hat funktioniert doch. Aus der Tabellenansicht ist kein Downgrade möglich. Als ich in die andere Ansicht mit den großen Symbolen gewechselt habe war der Menuepunkt aktiv.
    Downgrade auf 1.0.4 und VIS reagiert wieder.
    • Rene.HomeR Offline
      Rene.HomeR Offline
      Rene.Home
      Ein downgrad wollte ich nicht machen. Ich komme mit meinem workaround super klar.
      • H Nicht stören
        H Nicht stören
        Hansi1234
        Ich hole dieses Thema wieder hoch, da ich auch das Problem habe, dass VIS mein Hintergrundbild nicht speichert. Nach jedem neuem Laden des Editors ist der Hintergrund im Editor zwar da, aber wenn ich das Runtime (also die VIS selber) öffne, ist der Hintergrund wieder weg. Unter den Einstellung bei "image" ist der Pfad auch wieder gelöscht.
        VIS: 1.4.15
        JS-Controller: 4.0.23
        Node.js: v14.18.1
        NPM: 6.14.15
        • H Hansi1234
          VIS: 1.4.15
          Node.js: v14.18.1
          NPM: 6.14.15
          HomoranH Offline
          HomoranH Offline
          @hansi1234 sagte in Vis speichert Änderungen nicht:
          bitte nicht nach 5 Jahren!
          Seitdem hat sich einiges massiv geändert!
          Bitte neuen Thread aufmachen
            Maxtor62
            Sehe ich nicht so. habe im Moment das gleiche Problem wie Hansi1234.
            Alles ist auf dem neuesten Stand. Daran kann es nicht liegen.
            Kann keine Änderung machen. Bekomme dann die Meldung "Verbindungsfehler"
            Wer meint er ist was, hat aufgehört was zu werden
            • M Maxtor62
              HomoranH Offline
              HomoranH Offline
              @maxtor62 sagte in Vis speichert Änderungen nicht:
              das ist was anderes (oder nicht?) zu Verbindungsfehler gibt es genug Threads mit Lösung
              hab ich hier im Thread den Verbindungsfehler übersehen?
                Maxtor62
                Das ganze hat heute angefangen, als ich ein Widget importiert habe.
                Die Threads zum Verbindungsfehler helfen da nicht weiter.
                • M Maxtor62
                  HomoranH Offline
                  HomoranH Offline
                  @maxtor62 dann mach einen neuen Thread auf!
                  MidiCompM 1 Antwort Letzte Antwort
                    MidiCompM Offline
                    MidiCompM Offline
                    MidiComp
                    schrieb am zuletzt editiert von MidiComp
                    @Maxtor62
                    Schau mal hier https://forum.iobroker.net/topic/57073/vis-verbindugsfehler-lösung?_=1660306287204
                    CU
                    Alles was man beschreiben kann, kann man auch programmierenen.
                    iobroker * node-red * S7 1200 * nodeMCU * MyScada HMI * Tasmota * echo show, spot, dot usw.
                    WR - Growatt, PYLONTECH LiFePO4 Speicher 48V
                    • MidiCompM MidiComp
                      @Maxtor62
                      HomoranH Offline
                      HomoranH Offline
                      @midicomp sagte in Vis speichert Änderungen nicht:
                      @Maxtor62
                      das bringt jetzt gar nichts.
                      1.) Wissen wir gar nicht was bei @Maxtor62 überhaupt vorliegt.
                      2.) Wenn da ein Bug vorliegen sollte, nutzt esxden Entwicklern nichts, wenn da jetzt rumgeschraubt wird
                      3.) sollte @Maxtor62 einen neuen Thread aufmachen, weil seine Symptome anscheinend anders gelagert sind
                        @Maxtor62
                        MidiCompM Offline
                        MidiCompM Offline
                        MidiComp
                        @homoran said in Vis speichert Änderungen nicht:
                        Sorry, habe nur gut gemeint... falls unerwünscht bitte löschen.
                        CU
