  4. [Problem und Frage] Keine Verbindung zu KNX, gibt es Enocean auf dem IoBroker
    5.7k
18 Beiträge 5 Kommentatoren 3.5k Aufrufe
  • L Offline
    Lockenfrosch
    Der Adapter scheint gestartet zu sein (grün mit Pausezeichen)
    Davor ist leider rot. Mein Log sagt:
    ! host.raspberrypi 2017-06-13 19:27:52.383 info Restart adapter system.adapter.knx.0 because enabled
    ! host.raspberrypi 2017-06-13 19:27:52.382 error instance system.adapter.knx.0 terminated with code 1 ()
    ! host.raspberrypi 2017-06-13 19:27:52.027 info instance system.adapter.knx.0 started with pid 26364
    ! host.raspberrypi 2017-06-13 19:27:41.738 info Restart adapter system.adapter.knx.0 because enabled
    ! host.raspberrypi 2017-06-13 19:27:41.737 error instance system.adapter.knx.0 terminated with code 1 ()
    ! host.raspberrypi 2017-06-13 19:27:41.397 info instance system.adapter.knx.0 started with pid 26358
    ! host.raspberrypi 2017-06-13 19:27:37.386 info Restart adapter system.adapter.knx.0 because enabled
    ! host.raspberrypi 2017-06-13 19:27:37.385 error instance system.adapter.knx.0 terminated with code 1 ()
    ! host.raspberrypi 2017-06-13 19:27:37.045 info instance system.adapter.knx.0 started with pid 26352
    ! host.raspberrypi 2017-06-13 19:27:22.013 info Restart adapter system.adapter.knx.0 because enabled
    ! host.raspberrypi 2017-06-13 19:27:22.012 error instance system.adapter.knx.0 terminated with code 1 ()
    ! host.raspberrypi 2017-06-13 19:27:21.650 info instance system.adapter.knx.0 started with pid 26346
    ! host.raspberrypi 2017-06-13 19:27:11.375 info Restart adapter system.adapter.knx.0 because enabled
    ! host.raspberrypi 2017-06-13 19:27:11.375 error instance system.adapter.knx.0 terminated with code 1 ()
    ! host.raspberrypi 2017-06-13 19:27:11.031 info instance system.adapter.knx.0 started with pid 26340
    ! host.raspberrypi 2017-06-13 19:27:07.033 info Restart adapter system.adapter.knx.0 because enabled
    ! host.raspberrypi 2017-06-13 19:27:07.032 error instance system.adapter.knx.0 terminated with code 1 ()
    ! host.raspberrypi 2017-06-13 19:27:06.660 info instance system.adapter.knx.0 started with pid 26334
    ! host.raspberrypi 2017-06-13 19:26:51.631 info Restart adapter system.adapter.knx.0 because enabled
    ! host.raspberrypi 2017-06-13 19:26:51.631 error instance system.adapter.knx.0 terminated with code 1 ()
    ! host.raspberrypi 2017-06-13 19:26:51.280 info instance system.adapter.knx.0 started with pid 26328
    ! host.raspberrypi 2017-06-13 19:26:41.009 info Restart adapter system.adapter.knx.0 because enabled
    ! host.raspberrypi 2017-06-13 19:26:41.009 error instance system.adapter.knx.0 terminated with code 1 ()
    ! host.raspberrypi 2017-06-13 19:26:40.650 info instance system.adapter.knx.0 started with pid 26322
    ! host.raspberrypi 2017-06-13 19:26:36.642 info Restart adapter system.adapter.knx.0 because enabled
    ! host.raspberrypi 2017-06-13 19:26:36.641 error instance system.adapter.knx.0 terminated with code 1 ()
    Also könnte ich auf den PI ein Z-Wave Modul anbringen und dann bidirektional verwenden?
    Danke für die schnelle Hilfe
    • paul53P Offline
      @Lockenfrosch:
      Also könnte ich auf den PI ein Z-Wave Modul anbringen und dann bidirektional verwenden? `
      Ja, für Z-Wave-Geräte. Z-Wave ist nicht Enocean und ist auch nicht kompatibel.
      • L Offline
        Lockenfrosch
        Dass Z-Wave nicht Enocean ist, ist klar. Kann man irgendwo sehen oder erfragen ob da ein entsprechender Adapter in arbeit ist? Kennt jemand sonst ein PI - fähiges Programm welches enocean und knx verbindet?
        • paul53P Offline
          @Lockenfrosch:
          Kennt jemand sonst ein PI - fähiges Programm welches enocean und knx verbindet? `
          Wenn Du Javascript programmieren kannst, gibt es das NPM-Modul https://github.com/node-enocean/node-enocean, das Du in die Konfiguration des JS-Adapters einbinden kannst. Für KNX gibt es einen Adapter.
          • L Offline
            Lockenfrosch
            Mit z-wave könnte ich leben, hat denn jemand eine Antwort für mein knx Adapter Problem?
            • Jey CeeJ Online
              Jey CeeJ Online
              Jey Cee
              Im Log steht nichts was weiter hilft. Du musst das "Log Level" im Reiter "Instanzen" auf "debug" stellen, dann gibt es mehr her.
              Um das ändern zu können musst du den Experten Modus aktivieren. Dazu gibt es Links oben einen Button, ich weiss jetzt gerade nicht aus dem Kopf welches Symbol er trägt.
              Persönlicher Support
              Spenden -> paypal.me/J3YC33
              • L Offline
                Lockenfrosch
                OK habe ich gemacht, der Log verändert sich leider nicht großartig.
                Ich habe den Adapter nach dem Umstellen auf debug einmal aus und wieder an gemacht.
                Hier der Log:
                ! host.raspberrypi 2017-06-14 09:35:38.881 info Restart adapter system.adapter.knx.0 because enabled
                ! host.raspberrypi 2017-06-14 09:35:38.881 error instance system.adapter.knx.0 terminated with code 1 ()
                ! host.raspberrypi 2017-06-14 09:35:38.545 info instance system.adapter.knx.0 started with pid 25045
                ! host.raspberrypi 2017-06-14 09:35:31.881 info Restart adapter system.adapter.knx.0 because enabled
                ! host.raspberrypi 2017-06-14 09:35:31.881 error instance system.adapter.knx.0 terminated with code 1 ()
                ! host.raspberrypi 2017-06-14 09:35:31.538 info instance system.adapter.knx.0 started with pid 25039
                ! host.raspberrypi 2017-06-14 09:35:23.379 info Restart adapter system.adapter.knx.0 because enabled
                ! host.raspberrypi 2017-06-14 09:35:23.379 error instance system.adapter.knx.0 terminated with code 1 ()
                ! host.raspberrypi 2017-06-14 09:35:23.025 info instance system.adapter.knx.0 started with pid 25033
                ! host.raspberrypi 2017-06-14 09:35:16.411 info Restart adapter system.adapter.knx.0 because enabled
                ! host.raspberrypi 2017-06-14 09:35:16.410 error instance system.adapter.knx.0 terminated with code 1 ()
                ! host.raspberrypi 2017-06-14 09:35:16.069 info instance system.adapter.knx.0 started with pid 25027
                ! host.raspberrypi 2017-06-14 09:35:08.525 info Restart adapter system.adapter.knx.0 because enabled
                ! host.raspberrypi 2017-06-14 09:35:08.525 error instance system.adapter.knx.0 terminated with code 1 ()
                ! host.raspberrypi 2017-06-14 09:35:08.175 info instance system.adapter.knx.0 started with pid 25021
                ! host.raspberrypi 2017-06-14 09:35:01.519 info Restart adapter system.adapter.knx.0 because enabled
                ! host.raspberrypi 2017-06-14 09:35:01.519 error instance system.adapter.knx.0 terminated with code 1 ()
                ! host.raspberrypi 2017-06-14 09:35:01.191 info instance system.adapter.knx.0 started with pid 25015
                ! host.raspberrypi 2017-06-14 09:34:53.004 info Restart adapter system.adapter.knx.0 because enabled
                ! host.raspberrypi 2017-06-14 09:34:53.003 error instance system.adapter.knx.0 terminated with code 1 ()
                ! host.raspberrypi 2017-06-14 09:34:52.644 info instance system.adapter.knx.0 started with pid 25009
                ! host.raspberrypi 2017-06-14 09:34:52.625 info object change system.adapter.knx.0
                ! host.raspberrypi 2017-06-14 09:34:51.208 info Do not restart adapter system.adapter.knx.0 because disabled or deleted
                ! host.raspberrypi 2017-06-14 09:34:51.208 error instance system.adapter.knx.0 terminated with code 1 ()
                ! host.raspberrypi 2017-06-14 09:34:50.664 info object change system.adapter.knx.0
                ! host.raspberrypi 2017-06-14 09:34:46.050 info Restart adapter system.adapter.knx.0 because enabled
                ! host.raspberrypi 2017-06-14 09:34:46.049 error instance system.adapter.knx.0 terminated with code 1 ()
                ! host.raspberrypi 2017-06-14 09:34:45.705 info instance system.adapter.knx.0 started with pid 24997
                ! host.raspberrypi 2017-06-14 09:34:38.154 info Restart adapter system.adapter.knx.0 because enabled
                ! host.raspberrypi 2017-06-14 09:34:38.154 error instance system.adapter.knx.0 terminated with code 1 ()
                ! host.raspberrypi 2017-06-14 09:34:37.798 info instance system.adapter.knx.0 started with pid 24990
                ! host.raspberrypi 2017-06-14 09:34:37.777 info object change system.adapter.knx.0
                ! host.raspberrypi 2017-06-14 09:34:31.172 info Restart adapter system.adapter.knx.0 because enabled
                ! host.raspberrypi 2017-06-14 09:34:31.172 error instance system.adapter.knx.0 terminated with code 1 ()
                ! host.raspberrypi 2017-06-14 09:34:30.824 info instance system.adapter.knx.0 started with pid 24984
                ! host.raspberrypi 2017-06-14 09:34:20.845 info Restart adapter system.adapter.knx.0 because enabled
                ! host.raspberrypi 2017-06-14 09:34:20.844 error instance system.adapter.knx.0 terminated with code 1 ()
                • apollon77A Offline
                  Scheinbar crasht der Adapter sofort. Man kann auch versuchen den Adapter im Admin zu beenden und auf der kommandozeile im iobroker Verzeichnis mit "node node_modules/iobroker.knx/main.js -force -logs" direkt starten. Könnte mehr Infos beim Crash geben
                  • chefkoch009C Offline
                    chefkoch009
                    Hallo Lockenfrosch, hallo apollon77,
                    Welche Version des knx Adapters wird verwendet? In der Version 0.8.4 war ein Bug, welcher zu deiner Fehlerbeschreibung passt. Dieser ist in der Version 0.8.5 behoben. Bitte führen in diesem Fall ein Update auf die neue Version durch. Welches KNX/LAN GW verwendest du?
                    Chefkoch009
                    • L Offline
                      Lockenfrosch
                      Moin,
                      habe tatsächlich die 0.84 in Benutzung gehabt. Muss das ganze eben neu aufsetzen, habe das glaube ich kaputtgefummelt, werde dann berichten.
                      Beim Gateway handelt es sich um einen uMotion plus Server von Merten.
                        @chefkoch009: welche Version ist denn im stable repo? Wenn da die buggy drin ist sollten wir das ändern.
                        • L Offline
                          Lockenfrosch
                          OK,
                          ich habe nun IoBroker wieder am laufen, den adapter installiert (Version 0.83) und die Anzeige wird immerhin gelb ohne knx.proj Datei.
                          Der Indikator zeigt Verbunden mit Host = wahr
                          Lebenszeichen = wahr
                          Verbunden mit KNX = false
                          Das Einlesen der KNX Datei hat anscheinend auch geklappt, kann meine Gruppenadressen in Objekte wiederfinden.
                          Das Update auf Version 0.85 klappt leider nicht.
                          Danke für die Hilfe
                          Anbei noch eine Kopie des Log:
                          ! knx.0 2017-06-15 11:39:51.967 info /opt/iobroker/node_modules/iobroker.js-controller
                          ! knx.0 2017-06-15 11:39:51.966 info Connecting to knx GW: 192.168.178.5:3671 with phy. Adr: 1.1.102
                          ! knx.0 2017-06-15 11:39:51.952 info starting. Version 0.8.5 in /opt/iobroker/node_modules/iobroker.knx, node: v7.10.0
                          ! host.raspberrypi 2017-06-15 11:39:50.062 info instance system.adapter.knx.0 started with pid 1673
                          ! host.raspberrypi 2017-06-15 11:39:47.597 info instance system.adapter.knx.0 terminated with code 0 (OK)
                          ! knx.0 2017-06-15 11:39:47.566 info terminating
                          ! host.raspberrypi 2017-06-15 11:39:47.542 info stopInstance system.adapter.knx.0 killing pid 1662
                          ! host.raspberrypi 2017-06-15 11:39:47.541 info object change system.adapter.knx.0
                          ! knx.0 2017-06-15 11:39:30.302 info /opt/iobroker/node_modules/iobroker.js-controller
                          ! knx.0 2017-06-15 11:39:30.301 info Connecting to knx GW: 192.168.1.10:3671 with phy. Adr: 1.1.0
                          ! knx.0 2017-06-15 11:39:30.286 info starting. Version 0.8.5 in /opt/iobroker/node_modules/iobroker.knx, node: v7.10.0
                          ! iobroker 2017-06-15 11:39:27.357 info exit 0
                          ! iobroker 2017-06-15 11:39:27.328 info host.raspberrypi object system.adapter.knx.0 created
                          ! host.raspberrypi 2017-06-15 11:39:27.321 info instance system.adapter.knx.0 started with pid 1662
                          ! host.raspberrypi 2017-06-15 11:39:27.302 info object change system.adapter.knx.0
                          ! iobroker 2017-06-15 11:39:27.266 info host.raspberrypi object system.adapter.knx.0.alive created
                          ! iobroker 2017-06-15 11:39:27.234 info host.raspberrypi object system.adapter.knx.0.connected created
                          ! iobroker 2017-06-15 11:39:27.202 info host.raspberrypi object system.adapter.knx.0.memHeapUsed created
                          ! iobroker 2017-06-15 11:39:27.172 info host.raspberrypi object system.adapter.knx.0.memHeapTotal created
                          ! iobroker 2017-06-15 11:39:27.139 info host.raspberrypi object system.adapter.knx.0.memRss created
                          ! iobroker 2017-06-15 11:39:27.109 info host.raspberrypi object system.adapter.knx.0.uptime created
                          ! iobroker 2017-06-15 11:39:27.079 info host.raspberrypi object system.adapter.knx.0.inputCount created
                          ! iobroker 2017-06-15 11:39:27.049 info host.raspberrypi object system.adapter.knx.0.outputCount created
                          ! iobroker 2017-06-15 11:39:27.020 info host.raspberrypi object knx.0.info created
                          ! iobroker 2017-06-15 11:39:26.991 info host.raspberrypi object knx.0.info.connection created
                          ! iobroker 2017-06-15 11:39:26.983 info host.raspberrypi create instance knx
                          ! iobroker 2017-06-15 11:39:26.951 info host.raspberrypi object system.adapter.knx created
                          ! iobroker 2017-06-15 11:39:26.838 info upload [0] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/index.html index.html text/html
                          ! iobroker 2017-06-15 11:39:26.771 info upload [1] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/knx.png knx.png image/png
                          ! iobroker 2017-06-15 11:39:26.694 info upload [2] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/zip/inflate.js zip/inflate.js application/javascript
                          ! iobroker 2017-06-15 11:39:26.629 info upload [3] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/zip/z-worker.js zip/z-worker.js application/javascript
                          ! iobroker 2017-06-15 11:39:26.566 info upload [4] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/zip/zip-ext.js zip/zip-ext.js application/javascript
                          ! iobroker 2017-06-15 11:39:26.450 info upload [5] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/zip/zip.js zip/zip.js application/javascript
                          ! iobroker 2017-06-15 11:39:26.417 info got /opt/iobroker/node_modules/iobroker.knx/admin
                          ! iobroker 2017-06-15 11:39:26.399 info host.raspberrypi install adapter knx
                          ! iobroker 2017-06-15 11:39:26.308 info WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.3 install: node-gyp rebuildnpm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                          ! iobroker 2017-06-15 11:39:26.305 info WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.3 (node_modules/mdns):npm
                          ! iobroker 2017-06-15 11:39:26.298 info npm
                          ! iobroker 2017-06-15 11:39:21.815 info node-gyp -v v3.5.0gyp ERR! not ok
                          ! iobroker 2017-06-15 11:39:21.809 info gyp ERR!
                          ! iobroker 2017-06-15 11:39:21.809 info gyp ERR! node -v v7.10.0
                          ! iobroker 2017-06-15 11:39:21.809 info gyp ERR! cwd /opt/iobroker/node_modules/mdns
                          ! iobroker 2017-06-15 11:39:21.809 info gyp ERR! System Linux 4.9.24-v7+gyp ERR! command '/usr/bin/nodejs' '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js' 'rebuild'
                          ! iobroker 2017-06-15 11:39:21.805 info gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
                          ! iobroker 2017-06-15 11:39:21.805 info gyp ERR! stack at ChildProcess.emit (events.js:194:7)
                          ! iobroker 2017-06-15 11:39:21.805 info gyp ERR! stack at emitTwo (events.js:106:13)
                          ! iobroker 2017-06-15 11:39:21.805 info gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                          ! iobroker 2017-06-15 11:39:21.805 info ERR! build error gyp ERR! stack Error: make failed with exit code: 2
                          ! iobroker 2017-06-15 11:39:21.798 info gyp
                          ! iobroker 2017-06-15 11:39:21.786 info make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
                          ! iobroker 2017-06-15 11:39:20.423 info compilation terminated.
                          ! iobroker 2017-06-15 11:39:20.423 info ^
                          ! iobroker 2017-06-15 11:39:20.423 info #include
                          ! iobroker 2017-06-15 11:39:20.423 info In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
                          ! iobroker 2017-06-15 11:38:56.024 info npm install iobroker.knx –production --prefix '/opt/iobroker' (System call)
                          ! iobroker 2017-06-15 11:38:54.453 info add knx
                          ! iobroker 2017-06-15 11:38:30.381 info exit 0
                          ! host.raspberrypi 2017-06-15 11:38:30.250 info object deleted system.adapter.knx.0
                          ! host.raspberrypi 2017-06-15 11:38:30.246 info object change system.adapter.knx.0
                          ! iobroker 2017-06-15 11:38:30.241 error Not exists
                          ! host.raspberrypi 2017-06-15 11:38:29.923 error Cannot write files: /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/knx.admin/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/knx.admin/_data.json'
                          ! iobroker 2017-06-15 11:38:29.008 info host.raspberrypi Deleting 196 object(s).
                          ! iobroker 2017-06-15 11:38:29.001 info host.raspberrypi Counted 193 states of knx
                          ! iobroker 2017-06-15 11:38:28.986 info host.raspberrypi Counted 1 channels of knx
                          ! iobroker 2017-06-15 11:38:28.982 info host.raspberrypi Counted 1 adapters for knx
                          ! iobroker 2017-06-15 11:38:28.971 info host.raspberrypi Counted 1 instances of knx
                          ! iobroker 2017-06-15 11:38:28.956 info host.raspberrypi Counted 9 states (system.adapter.knx.) from states
                          ! iobroker 2017-06-15 11:38:28.953 info host.raspberrypi Counted 1 states (knx.
                          ) from states
                          ! iobroker 2017-06-15 11:38:28.932 info host.raspberrypi Counted 1 states (io.knx.*) from states
                          ! iobroker 2017-06-15 11:38:28.790 info host.raspberrypi delete /opt/iobroker/node_modules/iobroker.knx
                          ! iobroker 2017-06-15 11:38:27.415 info del knx
                          ! iobroker 2017-06-15 11:38:17.253 info exit 0
                          ! iobroker 2017-06-15 11:38:17.234 info Adapter 'knx' updated
                          ! iobroker 2017-06-15 11:38:17.169 info upload [0] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/index.html index.html text/html
                          ! iobroker 2017-06-15 11:38:17.091 info upload [1] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/knx.png knx.png image/png
                          ! iobroker 2017-06-15 11:38:17.015 info upload [2] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/zip/inflate.js zip/inflate.js application/javascript
                          ! iobroker 2017-06-15 11:38:16.949 info upload [3] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/zip/z-worker.js zip/z-worker.js application/javascript
                          ! iobroker 2017-06-15 11:38:16.877 info upload [4] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/zip/zip-ext.js zip/zip-ext.js application/javascript
                          ! iobroker 2017-06-15 11:38:16.759 info upload [5] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/zip/zip.js zip/zip.js application/javascript
                          ! iobroker 2017-06-15 11:38:16.732 info got /opt/iobroker/node_modules/iobroker.knx/admin
                          ! iobroker 2017-06-15 11:38:09.269 info npm install –production (System call) in '/opt/iobroker/node_modules/iobroker.knx'
                          ! iobroker 2017-06-15 11:38:09.216 info optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                          ! iobroker 2017-06-15 11:38:09.212 info optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.3 install: node-gyp rebuildnpm WARN
                          ! iobroker 2017-06-15 11:38:09.208 info optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.3 (node_modules/mdns):npm WARN
                          ! iobroker 2017-06-15 11:38:09.204 info WARN
                          ! iobroker 2017-06-15 11:38:09.202 info npm
                          ! iobroker 2017-06-15 11:38:05.585 info gyp ERR! not ok
                          ! iobroker 2017-06-15 11:38:05.585 info gyp ERR! node-gyp -v v3.5.0
                          ! iobroker 2017-06-15 11:38:05.585 info gyp ERR! node -v v7.10.0
                          ! iobroker 2017-06-15 11:38:05.585 info gyp ERR! command '/usr/bin/nodejs' '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js' 'rebuild'gyp ERR! cwd /opt/iobroker/node_modules/mdns
                          ! iobroker 2017-06-15 11:38:05.581 info gyp ERR! System Linux 4.9.24-v7+
                          ! iobroker 2017-06-15 11:38:05.581 info gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
                          ! iobroker 2017-06-15 11:38:05.581 info gyp ERR! stack at ChildProcess.emit (events.js:194:7)
                          ! iobroker 2017-06-15 11:38:05.581 info gyp ERR! stack at emitTwo (events.js:106:13)
                          ! iobroker 2017-06-15 11:38:05.581 info gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                          ! iobroker 2017-06-15 11:38:05.577 info ERR! build error
                          ! iobroker 2017-06-15 11:38:05.571 info gyp
                          ! iobroker 2017-06-15 11:38:05.559 info make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
                          ! iobroker 2017-06-15 11:38:04.194 info compilation terminated.
                          ! iobroker 2017-06-15 11:38:04.186 info ^
                          ! iobroker 2017-06-15 11:38:04.186 info #include
                          ! iobroker 2017-06-15 11:38:04.186 info In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
                          ! iobroker 2017-06-15 11:37:38.311 info npm install iobroker.knx@0.8.5 –production --prefix '/opt/iobroker' (System call)
                          ! iobroker 2017-06-15 11:37:36.657 info upgrade knx@0.8.5
                          ! host.raspberrypi 2017-06-15 11:37:28.091 info instance system.adapter.knx.0 terminated with code 0 (OK)
                          ! host.raspberrypi 2017-06-15 11:37:27.985 info stopInstance system.adapter.knx.0 killing pid 1526
                          ! host.raspberrypi 2017-06-15 11:37:27.984 info stopInstance system.adapter.knx.0
                          ! knx.0 2017-06-15 11:37:28.005 info terminating
                          ! host.raspberrypi 2017-06-15 11:37:27.983 info object change system.adapter.knx.0
                          ! knx.0 2017-06-15 11:37:19.153 info /opt/iobroker/node_modules/iobroker.js-controller
                          ! knx.0 2017-06-15 11:37:19.152 info Connecting to knx GW: 192.168.178.5:3671 with phy. Adr: 1.1.102
                          ! knx.0 2017-06-15 11:37:19.145 info starting. Version 0.8.5 in /opt/iobroker/node_modules/iobroker.knx, node: v7.10.0
                          ! knx.0 2017-06-15 11:37:19.067 debug statesDB connected
                          ! knx.0 2017-06-15 11:37:18.965 debug objectDB connected
                          ! iobroker 2017-06-15 11:37:16.820 info exit 0
                          ! iobroker 2017-06-15 11:37:16.806 info Adapter 'knx' updated
                          ! iobroker 2017-06-15 11:37:16.741 info upload [0] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/index.html index.html text/html
                          ! iobroker 2017-06-15 11:37:16.667 info upload [1] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/knx.png knx.png image/png
                          ! iobroker 2017-06-15 11:37:16.590 info upload [2] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/zip/inflate.js zip/inflate.js application/javascript
                          ! iobroker 2017-06-15 11:37:16.528 info upload [3] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/zip/z-worker.js zip/z-worker.js application/javascript
                          ! iobroker 2017-06-15 11:37:16.463 info upload [4] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/zip/zip-ext.js zip/zip-ext.js application/javascript
                          ! iobroker 2017-06-15 11:37:16.399 info Adapter 'system.adapter.knx.0' restarted.
                          ! host.raspberrypi 2017-06-15 11:37:16.384 info instance system.adapter.knx.0 started with pid 1526
                          ! host.raspberrypi 2017-06-15 11:37:16.372 info 'system.adapter.knx.0' enabled
                          ! host.raspberrypi 2017-06-15 11:37:16.372 info object change system.adapter.knx.0
                          ! host.raspberrypi 2017-06-15 11:37:16.370 info instance system.adapter.knx.0 terminated with code 0 (OK)
                          ! knx.0 2017-06-15 11:37:16.349 info terminating
                          ! host.raspberrypi 2017-06-15 11:37:16.333 info stopInstance system.adapter.knx.0 killing pid 1347
                          ! host.raspberrypi 2017-06-15 11:37:16.332 info stopInstance system.adapter.knx.0
                          ! host.raspberrypi 2017-06-15 11:37:16.331 info 'system.adapter.knx.0' disabled
                          ! host.raspberrypi 2017-06-15 11:37:16.331 info object change system.adapter.knx.0
                          ! iobroker 2017-06-15 11:37:16.325 info upload [5] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/zip/zip.js zip/zip.js application/javascript
                          ! iobroker 2017-06-15 11:37:16.297 info got /opt/iobroker/node_modules/iobroker.knx/admin
                          ! iobroker 2017-06-15 11:37:08.806 info npm install –production (System call) in '/opt/iobroker/node_modules/iobroker.knx'
                          ! iobroker 2017-06-15 11:37:08.751 info WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                          ! iobroker 2017-06-15 11:37:08.749 info npm
                          ! iobroker 2017-06-15 11:37:08.744 info optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.3 install: node-gyp rebuild
                          ! iobroker 2017-06-15 11:37:08.742 info WARN
                          ! iobroker 2017-06-15 11:37:08.740 info SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.3 (node_modules/mdns):npm
                          ! iobroker 2017-06-15 11:37:08.738 info optional
                          ! iobroker 2017-06-15 11:37:08.737 info WARN
                          ! iobroker 2017-06-15 11:37:08.736 info npm
                          ! iobroker 2017-06-15 11:37:05.170 info gyp ERR! not ok
                          ! iobroker 2017-06-15 11:37:05.168 info gyp ERR! node-gyp -v v3.5.0
                          ! iobroker 2017-06-15 11:37:05.168 info gyp ERR! node -v v7.10.0
                          ! iobroker 2017-06-15 11:37:05.168 info ERR! command '/usr/bin/nodejs' '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js' 'rebuild'gyp ERR! cwd /opt/iobroker/node_modules/mdns
                          ! iobroker 2017-06-15 11:37:05.166 info gyp ERR! System Linux 4.9.24-v7+gyp
                          ! iobroker 2017-06-15 11:37:05.164 info gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
                          ! iobroker 2017-06-15 11:37:05.164 info gyp ERR! stack at ChildProcess.emit (events.js:194:7)
                          ! iobroker 2017-06-15 11:37:05.164 info gyp ERR! stack at emitTwo (events.js:106:13)
                          ! iobroker 2017-06-15 11:37:05.164 info Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                          ! iobroker 2017-06-15 11:37:05.162 info gyp ERR! stack
                          ! iobroker 2017-06-15 11:37:05.160 info ERR! build error
                          ! iobroker 2017-06-15 11:37:05.159 info
                          ! iobroker 2017-06-15 11:37:05.155 info gyp
                          ! iobroker 2017-06-15 11:37:05.147 info make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
                          ! iobroker 2017-06-15 11:37:03.780 info compilation terminated.
                          ! iobroker 2017-06-15 11:37:03.780 info ^
                          ! iobroker 2017-06-15 11:37:03.780 info #include
                          ! iobroker 2017-06-15 11:37:03.780 info In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
                          ! iobroker 2017-06-15 11:36:37.799 info npm install iobroker.knx@0.8.5 –production --prefix '/opt/iobroker' (System call)
                          ! iobroker 2017-06-15 11:36:36.231 info upgrade knx@0.8.5
                          ! knx.0 2017-06-15 09:25:42.590 info /opt/iobroker/node_modules/iobroker.js-controller
                          ! knx.0 2017-06-15 09:25:42.590 info Connecting to knx GW: 192.168.178.5:3671 with phy. Adr: 1.1.102
                          ! knx.0 2017-06-15 09:25:42.583 info starting. Version 0.8.5 in /opt/iobroker/node_modules/iobroker.knx, node: v7.10.0
                          ! knx.0 2017-06-15 09:25:42.521 debug statesDB connected
                          ! knx.0 2017-06-15 09:25:42.463 debug objectDB connected
                          ! iobroker 2017-06-15 09:25:40.944 info exit 0
                          ! iobroker 2017-06-15 09:25:40.925 info Adapter 'knx' updated
                          ! iobroker 2017-06-15 09:25:40.851 info upload [0] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/index.html index.html text/html
                          ! iobroker 2017-06-15 09:25:40.765 info upload [1] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/knx.png knx.png image/png
                          ! iobroker 2017-06-15 09:25:40.673 info upload [2] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/zip/inflate.js zip/inflate.js application/javascript
                          ! iobroker 2017-06-15 09:25:40.606 info upload [3] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/zip/z-worker.js zip/z-worker.js application/javascript
                          ! iobroker 2017-06-15 09:25:40.535 info Adapter 'system.adapter.knx.0' restarted.
                          ! host.raspberrypi 2017-06-15 09:25:40.529 info instance system.adapter.knx.0 started with pid 1347
                          ! host.raspberrypi 2017-06-15 09:25:40.519 info 'system.adapter.knx.0' enabled
                          ! host.raspberrypi 2017-06-15 09:25:40.518 info object change system.adapter.knx.0
                          ! host.raspberrypi 2017-06-15 09:25:40.501 info instance system.adapter.knx.0 terminated with code 0 (OK)
                          ! iobroker 2017-06-15 09:25:40.492 info upload [4] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/zip/zip-ext.js zip/zip-ext.js application/javascript
                          ! knx.0 2017-06-15 09:25:40.458 info terminating
                          ! host.raspberrypi 2017-06-15 09:25:40.442 info stopInstance system.adapter.knx.0 killing pid 1263
                          ! host.raspberrypi 2017-06-15 09:25:40.439 info 'system.adapter.knx.0' disabled
                          ! host.raspberrypi 2017-06-15 09:25:40.439 info object change system.adapter.knx.0
                          ! iobroker 2017-06-15 09:25:40.320 info upload [5] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/zip/zip.js zip/zip.js application/javascript
                          ! iobroker 2017-06-15 09:25:40.286 info got /opt/iobroker/node_modules/iobroker.knx/admin
                          ! iobroker 2017-06-15 09:25:28.342 info npm install –production (System call) in '/opt/iobroker/node_modules/iobroker.knx'
                          ! iobroker 2017-06-15 09:25:28.285 info npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                          ! iobroker 2017-06-15 09:25:28.285 info WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.3 (node_modules/mdns):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.3 install: node-gyp rebuild
                          ! iobroker 2017-06-15 09:25:28.282 info npm
                          ! iobroker 2017-06-15 09:25:24.617 info gyp ERR! not ok
                          ! iobroker 2017-06-15 09:25:24.617 info gyp ERR! node-gyp -v v3.5.0
                          ! iobroker 2017-06-15 09:25:24.617 info gyp ERR! node -v v7.10.0
                          ! iobroker 2017-06-15 09:25:24.617 info gyp ERR! cwd /opt/iobroker/node_modules/mdns
                          ! iobroker 2017-06-15 09:25:24.617 info gyp ERR! command '/usr/bin/nodejs' '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js' 'rebuild'
                          ! iobroker 2017-06-15 09:25:24.617 info gyp ERR! System Linux 4.9.24-v7+
                          ! iobroker 2017-06-15 09:25:24.617 info gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
                          ! iobroker 2017-06-15 09:25:24.617 info gyp ERR! stack at ChildProcess.emit (events.js:194:7)
                          ! iobroker 2017-06-15 09:25:24.617 info gyp ERR! stack at emitTwo (events.js:106:13)
                          ! iobroker 2017-06-15 09:25:24.617 info gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                          ! iobroker 2017-06-15 09:25:24.608 info ERR! build error
                          ! iobroker 2017-06-15 09:25:24.604 info gyp
                          ! iobroker 2017-06-15 09:25:24.589 info make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
                          ! iobroker 2017-06-15 09:25:23.201 info compilation terminated.
                          ! iobroker 2017-06-15 09:25:23.201 info ^
                          ! iobroker 2017-06-15 09:25:23.201 info #include
                          ! iobroker 2017-06-15 09:25:23.201 info In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
                          ! iobroker 2017-06-15 09:24:50.785 info npm install iobroker.knx@0.8.5 –production --prefix '/opt/iobroker' (System call)
                          ! iobroker 2017-06-15 09:24:49.153 info upgrade knx@0.8.5
                          ! admin.0 2017-06-15 09:24:24.507 info Repository received successfully.
                          ! host.raspberrypi 2017-06-15 09:24:22.846 info Update repository 'default' under 'http://download.iobroker.net/sources-dist.json'
                          ! admin.0 2017-06-15 09:24:22.790 info Request actual repository...
                          ! admin.0 2017-06-15 09:24:22.694 info received all objects
                          ! knx.0 2017-06-15 09:24:22.602 info /opt/iobroker/node_modules/iobroker.js-controller
                          ! knx.0 2017-06-15 09:24:22.601 info Connecting to knx GW: 192.168.178.5:3671 with phy. Adr: 1.1.102
                          ! knx.0 2017-06-15 09:24:22.593 info starting. Version 0.8.5 in /opt/iobroker/node_modules/iobroker.knx, node: v7.10.0
                          ! knx.0 2017-06-15 09:24:22.524 debug statesDB connected
                          ! knx.0 2017-06-15 09:24:22.431 debug objectDB connected
                          ! admin.0 2017-06-15 09:24:22.316 info received all states
                          ! admin.0 2017-06-15 09:24:22.260 info system.adapter.admin.0: logging true
                          ! discovery.0 2017-06-15 09:24:22.255 info system.adapter.admin.0: logging true
                          ! admin.0 2017-06-15 09:24:22.000 info Change log subscriber state: true
                          ! admin.0 2017-06-15 09:24:21.767 info Use link 'http://localhost:8081' to configure.
                          ! admin.0 2017-06-15 09:24:21.766 info http server listening on port 8081
                          ! admin.0 2017-06-15 09:24:21.761 info requesting all objects
                          ! admin.0 2017-06-15 09:24:21.757 info requesting all states
                          ! admin.0 2017-06-15 09:24:21.650 info starting. Version 1.7.6 in /opt/iobroker/node_modules/iobroker.admin, node: v7.10.0
                          ! discovery.0 2017-06-15 09:24:19.850 info starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v7.10.0
                          ! host.raspberrypi 2017-06-15 09:24:19.684 info instance system.adapter.knx.0 started with pid 1263
                          ! host.raspberrypi 2017-06-15 09:24:16.031 info instance system.adapter.discovery.0 started with pid 1213
                          ! host.raspberrypi 2017-06-15 09:24:11.891 info instance system.adapter.admin.0 started with pid 1131
                          ! host.raspberrypi 2017-06-15 09:24:11.642 info starting 3 instances
                          ! host.raspberrypi 2017-06-15 09:24:11.603 info 3 instances found
                          ! host.raspberrypi 2017-06-15 09:24:11.558 info InMemoryDB connected
                          ! host.raspberrypi 2017-06-15 09:24:11.543 info inMem-objects listening on port 9001
                          ! host.raspberrypi 2017-06-15 09:24:11.384 info inMem-states listening on port 9000
                          ! host.raspberrypi 2017-06-15 09:24:11.029 info ip addresses: 192.168.178.12 fe80::1765:799d:615c:ed88
                          ! host.raspberrypi 2017-06-15 09:24:11.027 info hostname: raspberrypi, node: v7.10.0
                          ! host.raspberrypi 2017-06-15 09:24:11.026 info Copyright (c) 2014-2017 bluefox, hobbyquaker
                          ! host.raspberrypi 2017-06-15 09:24:11.010 info iobroker.js-controller version 1.0.3 js-controller starting
                          ! host.raspberrypi 2017-06-15 09:23:38.319 info terminated
                          ! host.raspberrypi 2017-06-15 09:23:38.169 info All instances are stopped.
                          ! host.raspberrypi 2017-06-15 09:23:38.168 info instance system.adapter.knx.0 terminated with code 0 (OK)
                          ! host.raspberrypi 2017-06-15 09:23:38.167 info All instances are stopped.
                          ! host.raspberrypi 2017-06-15 09:23:38.166 info instance system.adapter.admin.0 terminated with code 0 (OK)
                          ! host.raspberrypi 2017-06-15 09:23:38.148 info All instances are stopped.
                          ! host.raspberrypi 2017-06-15 09:23:38.139 info instance system.adapter.discovery.0 terminated with code 0 (OK)
                          ! admin.0 2017-06-15 09:23:38.139 info terminating
                          ! knx.0 2017-06-15 09:23:38.122 info terminating
                          ! discovery.0 2017-06-15 09:23:38.118 info terminating
                          ! host.raspberrypi 2017-06-15 09:23:38.104 info stopInstance system.adapter.knx.0 killing pid 1829
                          ! host.raspberrypi 2017-06-15 09:23:38.103 info stopInstance system.adapter.knx.0
                          ! host.raspberrypi 2017-06-15 09:23:38.099 info stopInstance system.adapter.discovery.0 killing pid 1531
                          ! host.raspberrypi 2017-06-15 09:23:38.098 info stopInstance system.adapter.admin.0 killing pid 1144
                          ! host.raspberrypi 2017-06-15 09:23:38.097 info stopInstance system.adapter.admin.0
                          ! admin.0 2017-06-15 09:23:38.106 info terminating http server on port 8081
                          ! host.raspberrypi 2017-06-15 09:23:38.095 info received SIGTERM
                          ! knx.0 2017-06-15 09:19:22.045 info /opt/iobroker/node_modules/iobroker.js-controller
                          ! knx.0 2017-06-15 09:19:22.045 info Connecting to knx GW: 192.168.178.5:3671 with phy. Adr: 1.1.102
                          ! knx.0 2017-06-15 09:19:22.038 info starting. Version 0.8.5 in /opt/iobroker/node_modules/iobroker.knx, node: v7.10.0
                          ! knx.0 2017-06-15 09:19:21.975 debug statesDB connected
                          ! knx.0 2017-06-15 09:19:21.917 debug objectDB connected
                          ! iobroker 2017-06-15 09:19:18.918 info exit 0
                          ! iobroker 2017-06-15 09:19:18.896 info Adapter 'knx' updated
                          ! iobroker 2017-06-15 09:19:18.825 info upload [0] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/index.html index.html text/html
                          ! iobroker 2017-06-15 09:19:18.745 info upload [1] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/knx.png knx.png image/png
                          ! iobroker 2017-06-15 09:19:18.660 info upload [2] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/zip/inflate.js zip/inflate.js application/javascript
                          ! iobroker 2017-06-15 09:19:18.597 info upload [3] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/zip/z-worker.js zip/z-worker.js application/javascript
                          ! iobroker 2017-06-15 09:19:18.530 info upload [4] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/zip/zip-ext.js zip/zip-ext.js application/javascript
                          ! iobroker 2017-06-15 09:19:18.456 info Adapter 'system.adapter.knx.0' restarted.
                          ! host.raspberrypi 2017-06-15 09:19:18.436 info instance system.adapter.knx.0 started with pid 1829
                          ! host.raspberrypi 2017-06-15 09:19:18.426 info 'system.adapter.knx.0' enabled
                          ! host.raspberrypi 2017-06-15 09:19:18.425 info object change system.adapter.knx.0
                          ! host.raspberrypi 2017-06-15 09:19:18.424 info instance system.adapter.knx.0 terminated with code 0 (OK)
                          ! knx.0 2017-06-15 09:19:18.403 info terminating
                          ! iobroker 2017-06-15 09:19:18.395 info upload [5] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/zip/zip.js zip/zip.js application/javascript
                          ! host.raspberrypi 2017-06-15 09:19:18.379 info stopInstance system.adapter.knx.0 killing pid 1712
                          ! host.raspberrypi 2017-06-15 09:19:18.378 info stopInstance system.adapter.knx.0
                          ! host.raspberrypi 2017-06-15 09:19:18.378 info 'system.adapter.knx.0' disabled
                          ! host.raspberrypi 2017-06-15 09:19:18.377 info object change system.adapter.knx.0
                          ! iobroker 2017-06-15 09:19:18.353 info got /opt/iobroker/node_modules/iobroker.knx/admin
                          ! iobroker 2017-06-15 09:19:10.852 info npm install –production (System call) in '/opt/iobroker/node_modules/iobroker.knx'
                          ! iobroker 2017-06-15 09:19:10.798 info WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.3 install: node-gyp rebuildnpm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                          ! iobroker 2017-06-15 09:19:10.796 info npm
                          ! iobroker 2017-06-15 09:19:10.791 info optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.3 (node_modules/mdns):
                          ! iobroker 2017-06-15 09:19:10.790 info WARN
                          ! iobroker 2017-06-15 09:19:10.788 info npm
                          ! iobroker 2017-06-15 09:19:07.116 info gyp ERR! node-gyp -v v3.5.0gyp ERR! not ok
                          ! iobroker 2017-06-15 09:19:07.114 info gyp ERR! node -v v7.10.0
                          ! iobroker 2017-06-15 09:19:07.114 info gyp ERR! cwd /opt/iobroker/node_modules/mdns
                          ! iobroker 2017-06-15 09:19:07.114 info gyp ERR! command '/usr/bin/nodejs' '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js' 'rebuild'
                          ! iobroker 2017-06-15 09:19:07.114 info gyp ERR! System Linux 4.9.24-v7+
                          ! iobroker 2017-06-15 09:19:07.114 info gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
                          ! iobroker 2017-06-15 09:19:07.114 info gyp ERR! stack at ChildProcess.emit (events.js:194:7)
                          ! iobroker 2017-06-15 09:19:07.114 info gyp ERR! stack at emitTwo (events.js:106:13)
                          ! iobroker 2017-06-15 09:19:07.114 info gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                          ! iobroker 2017-06-15 09:19:07.101 info build error
                          ! iobroker 2017-06-15 09:19:07.099 info ERR!
                          ! iobroker 2017-06-15 09:19:07.097 info
                          ! iobroker 2017-06-15 09:19:07.093 info gyp
                          • L Offline
                            Lockenfrosch
                            Wie ich gerade festgestellt habe kann ich anscheinend nichts updaten, das Teil das discover heißt lässt sich auch nicht updaten. Hilfe!
                              chefkoch009
                              hallo Lockenfrosch,
                              schau mal in deine PN.
                              chefkoch009
                                chefkoch009
                                Kurze Erklärung zur Fehlerbehebung bei Lockenfrosch.
                                Der discovery Adapter ließe sich aufgrund der Fehlermeldung mdns Errors nicht aktualisieren. Der Adapter würde manuell deinstalliert und entfernt. Anschließend wurde er mit npm Install neu installiert und mit iobroker add discovery wieder hinzugefügt.
                                Nun ließ sich auch der knx Adapter installieren. Dieser konnte jedoch keine Verbindung zum knx GW aufbauen. Dabei stellte sich heraus, das das GW nach dem Start des Adapters seine Arbeit einstellte und erst wieder nach einem Neustart funktionierte.
                                Vermutlich kommt das Gateway nicht mit der Anzahl an anfragen pro Zeiteinheit zurecht. Deshalb habe ich in der knx Adapterversion 0.8.6 unter Adapter Einstellungen einen slider zur Verfügung gestellt, mit dem eine Sendeverzögerung eingestellt werden kann.
                                Dies bitte ich zu testen und würde mich über eine Rückmeldung im thread iobroker Tester/knx Adapter überholt freuen.
                                chefkoch009
                                • L Offline
                                  Lockenfrosch
                                  Moin, leider hat das nicht geklappt, schreibe das ganze noch in den anderen thread. Gibt es die Möglichkeit den knx Adapter mit einer USB Schnittstelle zu betreiben?
