  4. [How-to] Node.js ioBroker richtig updaten-2021/22 Edition
    6.8k
812 Beiträge 97 Kommentatoren 458.0k Aufrufe 83 Beobachtet
    @chinaboy sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
    sudo apt update
    sudo apt install libc6=2.28-10+rpt2+rpi1+deb10u1
    sudo reboot
    chinaboy
    #677
    @thomas-braun said in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
    pi@raspberrypi:~ $ sudo apt update
    OK:1 http://archive.raspberrypi.org/debian buster InRelease
    OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    OK:3 https://deb.nodesource.com/node_14.x buster InRelease
    OK:4 https://packages.grafana.com/oss/deb stable InRelease
    OK:5 https://repos.influxdata.com/debian buster InRelease
    Aktualisierung für 112 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
    pi@raspberrypi:~ $ sudo apt install libc6=2.28-10+rpt2+rpi1+deb10u1
    Vorgeschlagene Pakete:
      glibc-doc
      libc6
    1 aktualisiert, 0 neu installiert, 0 zu entfernen und 111 nicht aktualisiert.
    4 nicht vollständig installiert oder entfernt.
    Es müssen noch 0 B von 2.351 kB an Archiven heruntergeladen werden.
    Nach dieser Operation werden 4.096 B Plattenplatz freigegeben.
    Changelogs werden gelesen... Fertig
    Unquoted string "gnuo" may clash with future reserved word at /usr/share/perl/5.28/Exporter.pm line 81.
    Bareword found where operator expected at /usr/share/perl/5.28/Exporter.pm line 84, near "3ub"
            (Missing operator before ub?)
    Unquoted string "ub" may clash with future reserved word at /usr/share/perl/5.28/Exporter.pm line 84.
    Bareword found where operator expected at /usr/share/perl/5.28/Exporter.pm line 84, near "ub export"
            (Do you need to predeclare ub?)
    debconf: Perl may be unconfigured (Unrecognized character \x1F; marked by <-- HERE after 3ub export<-- HERE near column 11 at /usr/share/perl/5.28/Exporter.pm line 84.
    Compilation failed in require at /usr/share/perl/5.28/Carp.pm line 222.
    Compilation failed in require at /usr/lib/arm-linux-gnueabihf/perl/5.28/IO/File.pm line 7.
    BEGIN failed--compilation aborted at /usr/lib/arm-linux-gnueabihf/perl/5.28/IO/File.pm line 7.
    Compilation failed in require at /usr/share/perl/5.28/FileHandle.pm line 9.
    Compilation failed in require at (eval 1) line 3.
    BEGIN failed--compilation aborted at (eval 1) line 3.
    ) -- aborting
    (Lese Datenbank ... 55443 Dateien und Verzeichnisse sind derzeit installiert.)
    Vorbereitung zum Entpacken von .../libc6_2.28-10+rpt2+rpi1+deb10u1_armhf.deb ...
    Compilation failed in require at /usr/share/perl/5.28/base.pm line 135.
            ...propagated at /usr/share/perl/5.28/base.pm line 157.
    BEGIN failed--compilation aborted at /usr/share/perl5/Debconf/Log.pm line 7.
    Compilation failed in require at /usr/share/perl5/Debconf/Db.pm line 7.
    BEGIN failed--compilation aborted at /usr/share/perl5/Debconf/Db.pm line 7.
    Compilation failed in require at /usr/share/debconf/frontend line 6.
    BEGIN failed--compilation aborted at /usr/share/debconf/frontend line 6.
    dpkg: Fehler beim Bearbeiten des Archivs /var/cache/apt/archives/libc6_2.28-10+rpt2+rpi1+deb10u1_armhf.deb (--unpack):
     »neues libc6:armhf-Skript des Paketes pre-installation«-Unterprozess gab den Fehlerwert 255 zurück
    Fehler traten auf beim Bearbeiten von:
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    pi@raspberrypi:~ $
    • C chinaboy
        glibc-doc
        libc6
      ) -- aborting
      pi@raspberrypi:~ $
      #678
      @chinaboy
      Keine Ahnung was du da zerschossen hast.
      Mal irgendwann irgendwie irgendwas am Paketmanager vorbei ins System gepflügt? Sieht mir nämlich danach aus.
      Ist aber für diesen Thread auch OT. Mach bei Bedarf einen eigenen auf, das hat mit nodejs nix zu tun
      C 1 Antwort Letzte Antwort
        @chinaboy
        chinaboy
        #679
        Schon mal Danke für deine Hilfe.
        Ich versuch jetzt mal ein Backup einzuspielen auf einem neuen System16.x
        Kannst du mir sagen wie ich bei einem Multihost System 1xMaster/1xSlave ein Backup richtig einspiele, hab das noch nie gemacht.
        Muss ich das System vorher trennen oder geht das auch im Verbund?
        Zuerst Slave dann Master oder reicht es nur auf dem Master das Backup einzuspielen?
        Hab das noch nie gemacht, wäre cool wenns dazu einm kleines Kochrezept gibt.
          andygla
          #680
          Bei mir funktioniert das leider nicht. ich bekomme folgende Meldung:
          nodejs is already the newest version (12.22.12-deb-1nodesource1).
          Hat jemand eine Lösung dafür?
          Danke.
          • A andygla
            Danke.
            #681
            @andygla
            Lösung: Repository einrichten.
            Wie biste denn da jetzt unterwegs?
            uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            anschauen.
            A 2 Antworten Letzte Antwort
              @andygla
              anschauen.
              andygla
              #682
              sudo ln -s /usr/bin/node /usr/bin/nodejs uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                @andygla
                anschauen.
                andygla
                #683
                Danke.
                Das ist das Ergebnis.
                armv7l
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v12.22.12
                v12.22.12
                6.14.16
                pi
                /home/pi
                • A andygla
                  Danke.
                  armv7l
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v12.22.12
                  v12.22.12
                  6.14.16
                  pi
                  /home/pi
                  #684
                  @andygla
                  Bitte in CodeTags posten, danke.
                  iobroker stop
                  sudo apt update
                  sudo apt full-upgrade
                  sudo reboot
                    @andygla
                    iobroker stop
                    sudo apt update
                    sudo reboot
                    andygla
                    #685
                    Sorry absoluter rookie.
                    pi@raspberrypi:~ $
                    pi@raspberrypi:~ $ iobroker stop
                    Get:1 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
                    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                    Get:3 https://packages.grafana.com/oss/deb stable InRelease [12.1 kB]
                    Hit:4 https://repos.influxdata.com/debian buster InRelease
                    Hit:5 https://phoscon.de/apt/deconz buster InRelease
                    Hit:6 https://deb.nodesource.com/node_12.x buster InRelease
                    E: Repository 'http://archive.raspberrypi.org/debian buster InRelease' changed its 'Suite' value from 'testing' to 'oldstable'
                    N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
                    Do you want to accept these changes and continue updating from this repository? [y/N] y
                    Err:3 https://packages.grafana.com/oss/deb stable InRelease
                      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 8C8C34C524098CB6
                    Reading package lists... Done
                    W: GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 8C8C34C524098CB6
                    E: The repository 'https://packages.grafana.com/oss/deb stable InRelease' is not signed.
                    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                    N: See apt-secure(8) manpage for repository creation and user configuration details.
                    pi@raspberrypi:~ $ sudo apt-get  install -y nodejs
                    Thomas BraunT 3 Antworten Letzte Antwort
                    • A andygla
                      pi@raspberrypi:~ $
                      #686
                      @andygla
                      Zu Grafana:
                      sudo apt-get install -y apt-transport-https
                      sudo apt-get install -y software-properties-common wget
                      wget -q -O - https://packages.grafana.com/gpg.key | sudo apt-key add -
                      sudo apt update
                      • A andygla
                        pi@raspberrypi:~ $
                        #687
                        @andygla
                        Zu nodejs:
                        curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
                        sudo apt update
                        sudo apt install nodejs
                        • A andygla
                          pi@raspberrypi:~ $
                          #688
                          @andygla
                          Und dann regelmäßig das System auf Stand halten.
                          Das ist offenbar noch nie gemacht worden, der suite change ist nämlich schon fast ein Jahr her. Seither ist apt also nicht mehr angepackt worden...
                          Regelmäßig alle paar Wochen:
                          sudo apt update
                          sudo reboot
                            @andygla
                            sudo apt update
                            sudo reboot
                            andygla
                            #689
                            hat funktioniert. Vielen Dank!!!
                              spacecowboy.21
                              #690
                              Ich bräuchte mal eure hilfe.
                              Ich habe versucht Node.js zu auf die 16.x Version zu bekommen.
                              Das update ist auch ohne Fehler durchgelaufen.
                              Node sollte ja auch gleich sein. Ist es aber nicht.
                              x86_64
                              /usr/bin/nodejs
                              /usr/local/bin/node
                              /usr/local/bin/npm
                              v16.16.0
                              v14.18.2
                              8.15.1
                              root
                              /opt/iobroker
                              Hit:1 http://archive.ubuntu.com/ubuntu bionic InRelease
                              Hit:2 https://deb.nodesource.com/node_16.x bullseye InRelease
                              Hit:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
                              Hit:4 http://archive.ubuntu.com/ubuntu bionic-security InRelease
                              Building dependency tree
                              All packages are up to date.
                              nodejs:
                                Installed: 16.16.0-deb-1nodesource1
                                Candidate: 16.16.0-deb-1nodesource1
                                Version table:
                               *** 16.16.0-deb-1nodesource1 500
                                      500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                                   8.10.0~dfsg-2ubuntu0.4 500
                                      500 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
                                   8.10.0~dfsg-2ubuntu0.2 500
                                      500 http://archive.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
                                   8.10.0~dfsg-2 500
                                      500 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
                              wie bekomme ich das wieder gerade?
                              • S spacecowboy.21
                                x86_64
                                /usr/bin/nodejs
                                /usr/local/bin/node
                                /usr/local/bin/npm
                                v16.16.0
                                v14.18.2
                                8.15.1
                                root
                                /opt/iobroker
                                nodejs:
                                  Version table:
                                     8.10.0~dfsg-2 500
                                #691
                                @spacecowboy-21
                                Wie und was hast du gemacht? Insbesondere als root im Zusammenhang mit node14...
                                https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                                Eigentlich IMMER das gleiche...
                                NICHT als root rumhampeln, NICHT am Paketmanager vorbei irgendwas ins System donnern.
                                  @spacecowboy-21
                                  spacecowboy.21
                                  #692
                                  Ok da hast du recht. Ich habe das ganze in mit root durchgeführt.
                                  Habe nun das ganze ohne root gemacht. Stehe aber noch vor dem gleichem Problem.
                                  Was kann ich noch machen?
                                  • S spacecowboy.21
                                    #693
                                    @spacecowboy-21
                                    Was hast du denn jetzt gemacht? HowTo gelesen? Falsche Pfade gelöscht?
                                      @spacecowboy-21
                                      spacecowboy.21
                                      #694
                                      ja die falschen Pfade habe ich gelöscht.
                                      das habe ich auch gemacht. Nicht unter root!
                                      sudo rm -rf /usr/local/lib/node*
                                      sudo rm -rf /usr/local/include/node*
                                      sudo rm -rf /usr/local/bin/node*
                                      Habe dann die Anleitung Punkt für Punkt abgearbeitet.
                                      sudo apt install nodejs --reinstall
                                      Danach
                                      iobroker fix
                                      Und es läuft wieder!
                                      Danke!!
                                      • Thomas BraunT Online
                                        #695
                                        @spacecowboy-21
                                        sagt? Du hast gesehen, dass du da auch die falsche Distribution drin hattest?
                                        • apollon77A apollon77
                                          MOD-EDIT: Diese Anleitung ist veraltet. Update und Fix der nodejs Installation ist mittlerweile in dem Befehl iob nodejs-update enthalten
                                          in diesem Artikel möchte ich einen Überblick geben, wie inzwischen (meint anno 2021 mit einem js-controller 3.x bzw 4.x) Node.js Updates bei ioBroker ausgeführt werden sollten bzw können.
                                          Was ist Node.js und warum muss man es updaten?
                                          Node.js ist die Laufzeitumgebung der Programmiersprache JavaScript, in der ioBroker geschrieben ist. Ohne Node.js funktioniert ioBroker nicht. Node.js hast Du initial selbst installiert oder der ioBroker-Installer hat dies für dich getan.
                                          Wie bei vielen Open-Source-Technologien üblich, entwickelt sich Node.js schnell weiter. Kleinere Updates, die die Stabilität und Sicherheit steigern oder gar neue Funktionen hinzufügen, erscheinen regelmäßig.
                                          Node.js-Versionen mit gerader Hauptversionsnummer werden als LTS-Versionen (Long Term Support) bezeichnet und einige Jahre gepflegt (z.B. 12.x). Jedes Jahr kommt eine neue Version ins LTS - in diesem Jahr (2021) ist das Node.js 16, welche im April veröffentlicht wurde und ab Oktober 2021 eine LTS Version wird.
                                          Im gleichem Zug erreichen frühere LTS-Versionen ihr Lebensende (EOL, End of Life). So hat Node.js 8 im April 2020 den EOL-Status erhalten und bekommt damit keine Updates mehr, Nodejs 10.x wird Ende April 2021 Ihr Lebensende erreichen. Es wird also keine Sicherheits-Updates mehr geben! Node.js 12.x wird im April 2022 eol geben.
                                          Alle Node.js-Versionen mit ungeraden Versionsnummern sind Entwicklungsversionen und sollten nicht produktiv genutzt werden.
                                          ioBroker nutzt viele Module und Erweiterungen aus der JavaScript Open-Source Szene, und dort kommt es regelmäßig vor, dass Versionen die EOL gehen zeitnah danach auch nicht weiter unterstützt werden. Das hat im ersten Schritt keine echte Auswirkung, aber mittelfristig wird es also Adapter, und später auch den js-controller geben, der EOL Versionen von Node.js nicht mehr unterstützt.
                                          Node.js 10 wird mit dem js-controller 3.x voll unterstützt. Ab dem js-controller 4.0 (Februar 2022) ist Node.js 10.x nicht mehr untertsützt.
                                          Auf welche Node.js Version updaten?
                                          Aktuell empfiehlt ioBroker die Nutzung von Node.js 16.x.
                                          Folgende Adapter haben momentan Probleme mit Node.js 14:
                                          • jeelink
                                          Folgende Adapter haben momentan Probleme mit Node.js 16:
                                          • jeelink?
                                          *Node.js 16.x wird auch vom js-controller 3.3 grundsätzlich unterstützt, aber nur mit npm 6! npm 7 bzw 8 sind mit dem js-controller 4.0 nutzbar.
                                          Update vorbereiten
                                          Node.js Version prüfen
                                          Bevor man beginnt, sollte man in der Befehlszeile mit dem Befehl
                                          node -v
                                          überprüfen, welche Version von Node.js gerade installiert ist. Eine gute Idee ist es, diese Versionsangabe auch mit der Node.js-Version im Übersichts-Fenster des ioBroker-Admins für diesen Host zu vergleichen. Sollten sich die Versionen unterscheiden, sind mehrere Node.js-Varianten installiert, was zu Problemen führen kann. Diese Probleme müssen VOR dem Update dann behoben werden! Anleitung zB unter https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian/2
                                          Betriebssystem prüfen
                                          Dann auch prüfen was man für ein Betriebssystem hat. Vor allem im Raspi Umfeld sind gern auch älterer Systeme auf basis von "Debian jessie" oder "Debian wheezy" im Einsatz. Für die gibt es nichts was höher ist als Nodejs 10, da steht dann ggf auch ein Betriebssystemupdate an, was wir hier aber nicht behandeln können.
                                          Unterstützte Linux Distributionen sind unter https://github.com/nodesource/distributions#debian-and-ubuntu-based-distributions aufgelistet.
                                          Unter Debian und Ubuntu gibt es mit lsb_release -a eine Ausgabe was man aktuell nutzt.
                                          js-controller Version prüfen
                                          Weiterhin bitte prüfen welche js-controller Version Installiert ist (ebenfalls auf dem Host-Tab im Admin einsehbar).
                                          Bei Versionen VOR js-controller 3.x, wenn möglich bitte zuerst den js-controller aktualisieren. Am besten auf mindestens die 3.2! Hierzu gibt es extra Threads im Forum wie z.B. https://forum.iobroker.net/topic/42385/js-controller-3-2-jetzt-im-stable bzw https://forum.iobroker.net/topic/52886/js-controller-4-0-x-jetzt-für-alle-user-im-stable
                                          Adapter aktualisieren
                                          Damit es nach dem Update zu keinen Inkompatibilitäten oder Probleme kommt, sollte man alle Adapter prüfen und aktualisieren. Vor allem Adapter mit nativen Bestandteilen, wie alles mit Serialport oder Bluetooth können Probleme bereiten. Hier am besten die Adapter-Readme's per Admin oder im GitHub prüfen, ob neue Versionen zur Verfügung stehen die die geplante Node.js Version explizit erst unterstützen.
                                          Bei Updates wo es größere Versionssprünge bei npm gibt (zb Node.js 14->16 updated npm von 6.x auf 8.x) kann es sehr hilfreich sein wenn man schaut ob Adapter die von GitHub installiert wurden inzwischen in der gleichen version auf auf npm liegen und dann ggf von dort nochmals installieren oder updaten. Im Admin werden Adapter die per GitHub installiert wurden gesondert mit einem GitHub Symbol angezeigt. Das hilft auch im Vorfeld Probleme zu vermeiden.
                                          Wenn man diesen Schritt nicht durchführt kann es zu unnötigen Problemen beim update der Adapter kommen!
                                          Backup erstellen
                                          Zuerst muss natürlich unbedingt ein Backup erstellt werden. Dazu kann z.B. der BackItUp-Adapter genutzt oder der Kommandozeilenbefehl
                                          cd /opt/iobroker
                                          iobroker backup
                                          ausgeführt werden. Das Backup sollte aktuell sein, damit möglichst keine Daten verloren gehen.
                                          Node.js updaten
                                          Für Windows-Systeme kann ich leider gerade nichts genaues sagen, wir schauen das wir das noch ergänzen. Aufruf an die Community: Wer Schritte hat gern als eigener Post oder hier einbringen :-) Danke
                                          Einen Post aus der Community gab es dazu: https://forum.iobroker.net/post/624003
                                          Linux-Systeme
                                          ioBroker stoppen
                                          Zuerst ioBroker stoppen, damit Updates keine Nebeneffekte oder Abstürze verursachen.
                                          iobroker stop
                                          Bitte anschließend im Webbrowser prüfen, dass der ioBroker-Admin danach wirklich nicht mehr läuft. Sollte er weiterhin aufrufbar sein, dann den Rechner neu starten und nochmals „iobroker stop“ ausführen und erneut testen. Für die Techniker unter uns: Man kann auch mit einem Tool wie "top" prüfen, ob noch Prozesse existieren, die mit "io." beginnen. Die dann am besten mit einem beherzten "sudo kill -9 <ProzessID>" zwangsbeenden.
                                          Node.js updaten
                                          Jetzt aktualisiert man Node.js auf die gewünschte neue Version.
                                          Unter Linux reicht es, dazu den Nodesource-Installationsbefehl für das jeweilige Betriebssystem auszuführen. Verschiedene Varianten (auch Root und Nicht-Root) sind unter https://github.com/nodesource/distributions#debinstall gelistet.
                                          Zum Beispiel lauten die Befehle für einen Raspberry Pi der ein Debian bzw. Raspbian-Image verwendet wie folgt, wenn man nicht als root-User (z.B. richtig mit dem User "pi") angemeldet ist:
                                          curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
                                          sudo apt install -y nodejs
                                          Für Node.js 16 einfach in der URL oben anstelle der 14 eine 16 reinschreiben.
                                          Für macOS gibt einen Installer auf https://nodejs.org/en/download/ , den man einfach ausführt.
                                          Ob die Aktualisierung geklappt hat, kann man wieder mit dem Befehl
                                          node -v
                                          überprüfen.
                                          Auch die npm Version sollte mit
                                          npm -v
                                          geprüft werden. Mit einem js-controller <4 sicherstellen das idealerweise keine 7.x/8.x von npm installiert ist!
                                          ioBroker fixer ausführen
                                          Da die Installation von Node.js einige Einstellungen am System verändert haben kann, ist es jetzt ratsam, den ioBroker-Installationsfixer aufzurufen. Das geschieht mit dem Befehl
                                          iobroker fix
                                          Er stellt unter anderem die für den Betrieb von ioBroker notwendigen Sicherheitseinstellungen wieder her und prüft und korrigiert alle Berechtigungen. Das kann einen Augenblick dauern, bitte Geduld haben.
                                          Erster ioBroker Neustart NACH Update
                                          Einige genutzte JavaScript Module haben binäre Teile, welche bei einem Node.js Update nicht mehr kompatibel sind und neu erstellt werden müssen.
                                          Automatische Rebuilds
                                          ioBroker versucht seit dem js-controller 3.0 automatisch die Adapter zu erkennen die nicht starten weil Sie aktualisiert werden müssen. Dies funktioniert so das die typischen Fehlermeldungen erkannt werden und ioBroker dann die Aktualisierung versucht.
                                          js-controller 3.x
                                          Zuerst wird ein "rebuild" des betroffenen Adapters ausgeführt, falls das nicht hilft werden die Adapter-Abhängigkeiten aktualisiert.
                                          js-controller 4.0
                                          Zuerst wird versucht alle Adapter zu rebuilden, falls das nicht hilft wird versucht zielgerichtet die relevanten Module neu zu bauen.
                                          Daher kann es sein das der Adapter mehrfach ersucht wird neu zu starten. Hier bitte UNBEDINGT Geduld haben! Erst wenn der Adapter dauerhaft rot bleibt und auch im Log steht das der Rebuild nicht geklappt hat aktiv werden!
                                          Bei einigen Adaptern (zB iot die optionale native Abhängigkeiten haben) funktioniert die automatische Erkennung nicht und das rebuild muss manuell angestoßen werden. Dies kann dadurch erkannt werden das der Adapter "Rot" bleibt und nicht startet oder einzelne Funktionen nicht gehen und das als Fehler im Log steht. Dann sollte das Log geprüft werden (neben Admin stehen Logfiles auch unter /opt/iobroker/log/... zur Verfügung.
                                          Manuelle Rebuilds
                                          Hier zu gibt es iobroker rebuild, bzw die Kommandos die im Log angezeigt werden falls der Automatische Rebuild nicht funktioniert.
                                          Sonderfälle (z.B. Serialport)
                                          Leider gibt es Sonderfälle, wo auch die obigen Optionen das Rebuild nicht erledigen, einer davon ist Serialport.
                                          Dort kann ein Log zB (auch nach allen Rebuild Versuchen) wie folgt aussehen
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.788 | error | Caught by controller[0]: }
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.788 | error | Caught by controller[0]: ]
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.788 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/compiled/12.16.3/linux/arm/serialport.node'
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.787 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/build/default/serialport.node',
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.787 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/Release/serialport.node',
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.787 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/out/Release/serialport.node',
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.787 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/Debug/serialport.node',
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.787 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/out/Debug/serialport.node',
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.786 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/build/Release/serialport.node',
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.786 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/build/Debug/serialport.node',
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.786 | error | Caught by controller[0]: '/opt/iobroker/node_modules/serialport/build/serialport.node',
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.786 | error | Caught by controller[0]: tries: [
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.786 | error | Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1133:30) {
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.785 | error | Caught by controller[0]: at Object. (/opt/iobroker/node_modules/serialport/lib/bindings/auto-detect.js:16:22)
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.785 | error | Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.785 | error | Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1019:19)
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.785 | error | Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.785 | error | Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.784 | error | Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.784 | error | Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1133:30)
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.784 | error | Caught by controller[0]: at Object. (/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.784 | error | Caught by controller[0]: at bindings (/opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:93:9)
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.783 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/compiled/12.16.3/linux/arm/serialport.node
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.783 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/build/default/serialport.node
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.783 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/Release/serialport.node
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.783 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/out/Release/serialport.node
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.782 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/Debug/serialport.node
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.782 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/out/Debug/serialport.node
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.782 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/build/Release/serialport.node
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.782 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/build/Debug/serialport.node
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.781 | error | Caught by controller[0]: → /opt/iobroker/node_modules/serialport/build/serialport.node
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.781 | error | Caught by controller[0]: Error: Could not locate the bindings file. Tried:
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.781 | error | Caught by controller[0]: ^
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.780 | error | Caught by controller[0]: throw err
                                          host.SmartHomeCenter | 2020-05-10 09:28:01.780 | error | Caught by controller[0]: /opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:96
                                          Es gibt auch andere Fehlermeldungen die aber alle auf das gleiche hinauslaufen.
                                          Die einfachste Option ist es dann manuell im richtigen Verzeichnis neu zu bauen.
                                          In dem Fall das Verzeichenis mit "bindings" suchen - oben ist das /opt/iobroker/node_modules/serialport/node_modules/bindings ... bei neueren Versionen kann es auch etwas wie /opt/iobroker/node_modules/serialport/node_modules/@serialport/bindings sein.
                                          Dann in dieses Verzeichnis wechseln und npm install --production ausführen. Danach den Adapter nochmal sneu starten, das sollte dann tun.
                                          Ein weiterer Fall sind Adapter mit canvas Modul (ggf echarts oder Mihome-vacuum) wo es Probleme gebe kann.
                                          Andere Sonderfälle muss man sich im Detail ansehen. Bitte unten Posten und wir unterstützen.
                                          Weitere Notfall Optionen
                                          Im früheren Artikel unter https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten sind noch weitere manuelle Möglichkeiten beschrieben ioBroker wieder zum laufen zu bekommen, aber diese sollten an sich nicht mehr nötig sein, gehen aber natürlich auch noch!
                                          Dieser Artikel gilt also auch weiterhin.
                                          Jetzt viel Erfolg und gebt bitte Feedback wie git es geklappt hat oder welche Probleme Ihr habt.
                                          Ingo
                                          chucky666C Online
                                          chucky666C Online
                                          chucky666
                                          #696
                                          Hallo Zusammen,
                                          mir wird das Update angezeigt , kann man das gefahrlos Updaten ? oder gibt es mit der Version probleme ?
                                          Node.js
                                          v16.15.1 (Es gibt eine neuere Version: v16.16.0)
