  4. (GELÖST) HM-REGA.0 bricht ständig ab
    5.8k
8 Beiträge 4 Kommentatoren 661 Aufrufe 3 Beobachtet
  • U Offline
    U Offline
    UV-on-fire
    schrieb am zuletzt editiert von UV-on-fire
    bin gerade am Einrichten von IOBROKER bei nem Kumpel. Er hat eine CCU3 und der Rega Adapter bricht daurend die Verbindung ab.
    Hier das Log:
    2022-08-01 13:11:34.930 - info: hm-rega.0 (3072) ReGaHSS 192.168.178.167 up
    2022-08-01 13:12:00.095 - info: host.iobroker instance system.adapter.blueconnect.0 started with pid 3919
    2022-08-01 13:12:02.237 - info: blueconnect.0 (3919) starting. Version 0.0.1 (non-npm: mameier1234/ioBroker.blueconnect#d0d27f26f61a6b5b2d7d2c9fa11f891625491c85) in /opt/iobroker/node_modules/iobroker.blueconnect, node: v14.19.1, js-controller: 4.0.23
    2022-08-01 13:12:12.287 - info: blueconnect.0 (3919) cleaned everything up...
    2022-08-01 13:12:12.296 - info: blueconnect.0 (3919) Terminated (NO_ERROR): Without reason
    2022-08-01 13:12:12.824 - info: host.iobroker instance system.adapter.blueconnect.0 terminated with code 0 (NO_ERROR)
    2022-08-01 13:13:00.094 - info: host.iobroker instance system.adapter.blueconnect.0 started with pid 3935
    2022-08-01 13:13:02.254 - info: blueconnect.0 (3935) starting. Version 0.0.1 (non-npm: mameier1234/ioBroker.blueconnect#d0d27f26f61a6b5b2d7d2c9fa11f891625491c85) in /opt/iobroker/node_modules/iobroker.blueconnect, node: v14.19.1, js-controller: 4.0.23
    2022-08-01 13:13:04.958 - warn: hm-rega.0 (3072) "Write(system.Date("%F %X").ToTime().ToInteger());" timed out after 90 seconds
    2022-08-01 13:13:04.962 - error: hm-rega.0 (3072) post request error: Aborted due to timeout
    2022-08-01 13:13:04.963 - error: hm-rega.0 (3072) CCU 192.168.178.167 unreachable
    2022-08-01 13:13:11.395 - info: admin.0 (1505) ==> Connected system.user.admin from ::ffff:192.168.178.161
    2022-08-01 13:13:12.304 - info: blueconnect.0 (3935) cleaned everything up...
    2022-08-01 13:13:12.368 - info: blueconnect.0 (3935) Terminated (NO_ERROR): Without reason
    2022-08-01 13:13:12.925 - info: host.iobroker instance system.adapter.blueconnect.0 terminated with code 0 (NO_ERROR)
    2022-08-01 13:13:34.999 - info: hm-rega.0 (3072) ReGaHSS 192.168.178.167 up
    2022-08-01 13:13:37.140 - info: admin.0 (1505) <== Disconnect system.user.admin from ::ffff:192.168.178.161
    Firewall Einstellungen der CCU:
    Die RPC Adapter funktionieren einwandfei. Hat jemand noch einen Tip für mich?
    S R 2 Antworten Letzte Antwort
    • U UV-on-fire
      Hier das Log:
      SpacerX
      @uv-on-fire
      Erst mal zum Testen CCU Firewall Einstellungen Alle Ports offen.
      Script Api Zugriff erlauben.
      DS720|Nuc8i3BEH|Proxmox|RaspberryMatic|ioBroker|influxDB2|Grafana
      • U UV-on-fire
        Hier das Log:
        reutli
        @uv-on-fire
        Un die Einstellungen im Adapter posten.
        ist eigentlich ein deutliches Zeichen. CCU3 ist definitiv auf der IP?
        Welches System, wie und wann eingerichtet?
        iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
        *Wer freundlich ist, dem wird freundlich geholfen *
        U 1 Antwort Letzte Antwort
        • R reutli
          @uv-on-fire
          U Offline
          U Offline
          UV-on-fire
          @reutli
          Adresse stimmt. RPC zeigt mir auch die Geräte an.
          Hab den Api Zugriff auf voll gesetzt und alle Ports geöffnet dann gings. Danach Ports wieder auf blockiert und geht immer noch. War wohl der Api Zugriff. Werde das beobachten.
          R 1 Antwort Letzte Antwort
          • U UV-on-fire
            @reutli
            reutli
            @uv-on-fire
            Klar wenn API von iobroker nicht auf die Logikschicht zugreifen darf.... dann kann das nicht gehen.
            U HomoranH 2 Antworten Letzte Antwort
            • R reutli
              @uv-on-fire
              U Offline
              U Offline
              UV-on-fire
              @reutli
              Hatte ich entweder übersehen oder war in der Anleitung die ich hatte nicht drin. Danke für die Hilfe.
              • R reutli
                @uv-on-fire
                @reutli sagte in (GELÖST) HM-REGA.0 bricht ständig ab:
                @uv-on-fire
                @UV-on-fire
                da kannst/solltest du aber auch nur die ioBroker IP freigeben!
                musst nicht alles offen haben
                  @uv-on-fire
                  @UV-on-fire
                  U Offline
                  U Offline
                  UV-on-fire
                  Danke für den Hinweis
