<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[(GELÖST) HM-REGA.0 bricht ständig ab]]></title><description><![CDATA[<p dir="auto">Hallo zusammen,</p>
<p dir="auto">bin gerade am Einrichten von IOBROKER bei nem Kumpel. Er hat eine CCU3 und der Rega Adapter bricht daurend die Verbindung ab.</p>
<p dir="auto">Hier das Log:</p>
<pre><code>2022-08-01 13:11:34.930 - info: hm-rega.0 (3072) ReGaHSS 192.168.178.167 up
2022-08-01 13:12:00.095 - info: host.iobroker instance system.adapter.blueconnect.0 started with pid 3919
2022-08-01 13:12:02.237 - info: blueconnect.0 (3919) starting. Version 0.0.1 (non-npm: mameier1234/ioBroker.blueconnect#d0d27f26f61a6b5b2d7d2c9fa11f891625491c85) in /opt/iobroker/node_modules/iobroker.blueconnect, node: v14.19.1, js-controller: 4.0.23
2022-08-01 13:12:12.287 - info: blueconnect.0 (3919) cleaned everything up...
2022-08-01 13:12:12.296 - info: blueconnect.0 (3919) Terminated (NO_ERROR): Without reason
2022-08-01 13:12:12.824 - info: host.iobroker instance system.adapter.blueconnect.0 terminated with code 0 (NO_ERROR)
2022-08-01 13:13:00.094 - info: host.iobroker instance system.adapter.blueconnect.0 started with pid 3935
2022-08-01 13:13:02.254 - info: blueconnect.0 (3935) starting. Version 0.0.1 (non-npm: mameier1234/ioBroker.blueconnect#d0d27f26f61a6b5b2d7d2c9fa11f891625491c85) in /opt/iobroker/node_modules/iobroker.blueconnect, node: v14.19.1, js-controller: 4.0.23
2022-08-01 13:13:04.958 - warn: hm-rega.0 (3072) "Write(system.Date("%F %X").ToTime().ToInteger());" timed out after 90 seconds
2022-08-01 13:13:04.962 - error: hm-rega.0 (3072) post request error: Aborted due to timeout
2022-08-01 13:13:04.963 - error: hm-rega.0 (3072) CCU 192.168.178.167 unreachable
2022-08-01 13:13:11.395 - info: admin.0 (1505) ==&gt; Connected system.user.admin from ::ffff:192.168.178.161
2022-08-01 13:13:12.304 - info: blueconnect.0 (3935) cleaned everything up...
2022-08-01 13:13:12.368 - info: blueconnect.0 (3935) Terminated (NO_ERROR): Without reason
2022-08-01 13:13:12.925 - info: host.iobroker instance system.adapter.blueconnect.0 terminated with code 0 (NO_ERROR)
2022-08-01 13:13:34.999 - info: hm-rega.0 (3072) ReGaHSS 192.168.178.167 up
2022-08-01 13:13:37.140 - info: admin.0 (1505) &lt;== Disconnect system.user.admin from ::ffff:192.168.178.161
</code></pre>
<p dir="auto">Firewall Einstellungen der CCU:<br />
<img src="/assets/uploads/files/1659352770656-012bb8ac-899c-4503-9e7a-1a4450f64309-grafik.png" alt="012bb8ac-899c-4503-9e7a-1a4450f64309-grafik.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Die RPC Adapter funktionieren einwandfei. Hat jemand noch einen Tip für mich?</p>
]]></description><link>https://forum.iobroker.net/topic/56846/gelöst-hm-rega-0-bricht-ständig-ab</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 02:33:58 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/56846.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 01 Aug 2022 11:20:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to (GELÖST) HM-REGA.0 bricht ständig ab on Mon, 01 Aug 2022 15:14:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a><br />
Danke für den Hinweis</p>
]]></description><link>https://forum.iobroker.net/post/837101</link><guid isPermaLink="true">https://forum.iobroker.net/post/837101</guid><dc:creator><![CDATA[UV-on-fire]]></dc:creator><pubDate>Mon, 01 Aug 2022 15:14:38 GMT</pubDate></item><item><title><![CDATA[Reply to (GELÖST) HM-REGA.0 bricht ständig ab on Mon, 01 Aug 2022 12:24:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reutli" aria-label="Profile: reutli">@<bdi>reutli</bdi></a> sagte in <a href="/post/837046">(GELÖST) HM-REGA.0 bricht ständig ab</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uv-on-fire" aria-label="Profile: uv-on-fire">@<bdi>uv-on-fire</bdi></a><br />
Klar wenn API von iobroker nicht auf die Logikschicht zugreifen darf.... dann kann das nicht gehen.</p>
</blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uv-on-fire" aria-label="Profile: UV-on-fire">@<bdi>UV-on-fire</bdi></a><br />
da kannst/solltest du aber auch nur die ioBroker IP freigeben!<br />
musst nicht alles offen haben</p>
]]></description><link>https://forum.iobroker.net/post/837056</link><guid isPermaLink="true">https://forum.iobroker.net/post/837056</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Mon, 01 Aug 2022 12:24:50 GMT</pubDate></item><item><title><![CDATA[Reply to (GELÖST) HM-REGA.0 bricht ständig ab on Mon, 01 Aug 2022 12:15:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reutli" aria-label="Profile: reutli">@<bdi>reutli</bdi></a><br />
Hatte ich entweder übersehen oder war in der Anleitung die ich hatte nicht drin. Danke für die Hilfe.</p>
]]></description><link>https://forum.iobroker.net/post/837050</link><guid isPermaLink="true">https://forum.iobroker.net/post/837050</guid><dc:creator><![CDATA[UV-on-fire]]></dc:creator><pubDate>Mon, 01 Aug 2022 12:15:38 GMT</pubDate></item><item><title><![CDATA[Reply to (GELÖST) HM-REGA.0 bricht ständig ab on Mon, 01 Aug 2022 12:12:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uv-on-fire" aria-label="Profile: uv-on-fire">@<bdi>uv-on-fire</bdi></a><br />
]]></description><link>https://forum.iobroker.net/post/837046</link><guid isPermaLink="true">https://forum.iobroker.net/post/837046</guid><dc:creator><![CDATA[reutli]]></dc:creator><pubDate>Mon, 01 Aug 2022 12:12:06 GMT</pubDate></item><item><title><![CDATA[Reply to (GELÖST) HM-REGA.0 bricht ständig ab on Mon, 01 Aug 2022 11:58:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reutli" aria-label="Profile: reutli">@<bdi>reutli</bdi></a><br />
Adresse stimmt. RPC zeigt mir auch die Geräte an.</p>
<p dir="auto">Hab den Api Zugriff auf voll gesetzt und alle Ports geöffnet dann gings. Danach Ports wieder auf blockiert und geht immer noch. War wohl der Api Zugriff. Werde das beobachten.</p>
]]></description><link>https://forum.iobroker.net/post/837040</link><guid isPermaLink="true">https://forum.iobroker.net/post/837040</guid><dc:creator><![CDATA[UV-on-fire]]></dc:creator><pubDate>Mon, 01 Aug 2022 11:58:03 GMT</pubDate></item><item><title><![CDATA[Reply to (GELÖST) HM-REGA.0 bricht ständig ab on Mon, 01 Aug 2022 11:46:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uv-on-fire" aria-label="Profile: uv-on-fire">@<bdi>uv-on-fire</bdi></a></p>
<p dir="auto">Un die Einstellungen im Adapter posten.</p>
<pre><code>CCU 192.168.178.167 unreachable
</code></pre>
<p dir="auto">ist eigentlich ein deutliches Zeichen. CCU3 ist definitiv auf der IP?</p>
<p dir="auto">Welches System, wie und wann eingerichtet?</p>
]]></description><link>https://forum.iobroker.net/post/837034</link><guid isPermaLink="true">https://forum.iobroker.net/post/837034</guid><dc:creator><![CDATA[reutli]]></dc:creator><pubDate>Mon, 01 Aug 2022 11:46:46 GMT</pubDate></item><item><title><![CDATA[Reply to (GELÖST) HM-REGA.0 bricht ständig ab on Mon, 01 Aug 2022 11:37:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uv-on-fire" aria-label="Profile: uv-on-fire">@<bdi>uv-on-fire</bdi></a></p>
<p dir="auto">Erst mal zum Testen CCU Firewall Einstellungen Alle Ports offen.<br />
Script Api Zugriff erlauben.</p>
]]></description><link>https://forum.iobroker.net/post/837029</link><guid isPermaLink="true">https://forum.iobroker.net/post/837029</guid><dc:creator><![CDATA[SpacerX]]></dc:creator><pubDate>Mon, 01 Aug 2022 11:37:56 GMT</pubDate></item></channel></rss>
