  4. Iobroker kann NodeJS nicht installieren (gelöst)
    5.8k
9 Beiträge 3 Kommentatoren 289 Aufrufe 2 Beobachtet
  • stefu87_CHS Offline
    stefu87_CHS Offline
    stefu87_CH
    schrieb am zuletzt editiert von stefu87_CH
    Hallo
    Mein Arbeitskollege möchte Zuhause auch mit Visu anfangen, jetzt wollte ich ihm auf seinem NUC mit Proxmox den Iobroker installieren, bekomme aber Fehlermeldungen. Wer kann mir sagen, warum ich NodeJS nicht installieren kann?
    Ubuntu 18.04.1 LTS Iobroker tty1
    Iobroker login: admin
    Password:
    Welcome to Ubuntu 18.04.1 LTS (GNU/Linux 5.15.30-2-pve x86_64)
     * Documentation:  https://help.ubuntu.com
     * Management:     https://landscape.canonical.com
     * Support:        https://ubuntu.com/advantage
    Failed to connect to https://changelogs.ubuntu.com/meta-release-lts. Check your Internet connection or proxy settings
    The programs included with the Ubuntu system are free software;
    Ubuntu comes with ABSOLUTELY NO WARRANTY, to the extent permitted by
    applicable law.
    To run a command as administrator (user "root"), use "sudo <command>".
    See "man sudo_root" for details.
    admin@Iobroker:~$ sudo apt-get update && sudo apt-get upgrade
    [sudo] password for admin:
    Err:1 http://archive.ubuntu.com/ubuntu bionic InRelease
      Temporary failure resolving 'archive.ubuntu.com'
    Err:2 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
    Err:3 http://archive.ubuntu.com/ubuntu bionic-security InRelease
    Reading package lists... Done
    W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/bionic/InRelease  Temporary failure resolving 'archive.ubuntu.com'
    W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/bionic-updates/InRelease  Temporary failure resolving 'archive.ubuntu.com'
    W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/bionic-security/InRelease  Temporary failure resolving 'archive.ubuntu.com'
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Calculating upgrade... Done
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    admin@Iobroker:~$ node -v
    Command 'node' not found, but can be installed with:
    sudo apt install nodejs
    admin@Iobroker:~$ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash -
    Command 'curl' not found, but can be installed with:
    sudo apt install curl
    admin@Iobroker:~$ sudo apt install curl
    The following additional packages will be installed:
      libasn1-8-heimdal libcurl4 libgssapi3-heimdal libhcrypto4-heimdal libheimbase1-heimdal libheimntlm0-heimdal libhx509-5-heimdal libkrb5-26-heimdal libldap-2.4-2
      libldap-common libnghttp2-14 libroken18-heimdal librtmp1 libwind0-heimdal
    The following NEW packages will be installed:
      curl libasn1-8-heimdal libcurl4 libgssapi3-heimdal libhcrypto4-heimdal libheimbase1-heimdal libheimntlm0-heimdal libhx509-5-heimdal libkrb5-26-heimdal libldap-2.4-2
    0 upgraded, 15 newly installed, 0 to remove and 0 not upgraded.
    Need to get 1480 kB of archives.
    After this operation, 4934 kB of additional disk space will be used.
    Do you want to continue? [Y/n] y
    Err:1 http://archive.ubuntu.com/ubuntu bionic/main amd64 libroken18-heimdal amd64 7.5.0+dfsg-1
    Err:2 http://archive.ubuntu.com/ubuntu bionic/main amd64 libasn1-8-heimdal amd64 7.5.0+dfsg-1
    Err:3 http://archive.ubuntu.com/ubuntu bionic/main amd64 libheimbase1-heimdal amd64 7.5.0+dfsg-1
    Err:4 http://archive.ubuntu.com/ubuntu bionic/main amd64 libhcrypto4-heimdal amd64 7.5.0+dfsg-1
    Err:5 http://archive.ubuntu.com/ubuntu bionic/main amd64 libwind0-heimdal amd64 7.5.0+dfsg-1
    Err:6 http://archive.ubuntu.com/ubuntu bionic/main amd64 libhx509-5-heimdal amd64 7.5.0+dfsg-1
    Err:7 http://archive.ubuntu.com/ubuntu bionic/main amd64 libkrb5-26-heimdal amd64 7.5.0+dfsg-1
    Err:8 http://archive.ubuntu.com/ubuntu bionic/main amd64 libheimntlm0-heimdal amd64 7.5.0+dfsg-1
    Err:9 http://archive.ubuntu.com/ubuntu bionic/main amd64 libgssapi3-heimdal amd64 7.5.0+dfsg-1
    Err:10 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 libldap-common all 2.4.45+dfsg-1ubuntu1.1
    Err:11 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 libldap-2.4-2 amd64 2.4.45+dfsg-1ubuntu1.1
    Err:12 http://archive.ubuntu.com/ubuntu bionic/main amd64 libnghttp2-14 amd64 1.30.0-1ubuntu1
    Err:13 http://archive.ubuntu.com/ubuntu bionic/main amd64 librtmp1 amd64 2.4+20151223.gitfa8646d.1-1
    Ign:14 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 libcurl4 amd64 7.58.0-2ubuntu3.5
    Ign:15 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 curl amd64 7.58.0-2ubuntu3.5
    Err:14 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 libcurl4 amd64 7.58.0-2ubuntu3.5
    Err:15 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 curl amd64 7.58.0-2ubuntu3.5
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/h/heimdal/libroken18-heimdal_7.5.0+dfsg-1_amd64.deb  Temporary failure resolving 'archive.ubuntu.com'
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/h/heimdal/libasn1-8-heimdal_7.5.0+dfsg-1_amd64.deb  Temporary failure resolving 'archive.ubuntu.com'
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/h/heimdal/libheimbase1-heimdal_7.5.0+dfsg-1_amd64.deb  Temporary failure resolving 'archive.ubuntu.com'
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/h/heimdal/libhcrypto4-heimdal_7.5.0+dfsg-1_amd64.deb  Temporary failure resolving 'archive.ubuntu.com'
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/h/heimdal/libwind0-heimdal_7.5.0+dfsg-1_amd64.deb  Temporary failure resolving 'archive.ubuntu.com'
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/h/heimdal/libhx509-5-heimdal_7.5.0+dfsg-1_amd64.deb  Temporary failure resolving 'archive.ubuntu.com'
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/h/heimdal/libkrb5-26-heimdal_7.5.0+dfsg-1_amd64.deb  Temporary failure resolving 'archive.ubuntu.com'
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/h/heimdal/libheimntlm0-heimdal_7.5.0+dfsg-1_amd64.deb  Temporary failure resolving 'archive.ubuntu.com'
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/h/heimdal/libgssapi3-heimdal_7.5.0+dfsg-1_amd64.deb  Temporary failure resolving 'archive.ubuntu.com'
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/o/openldap/libldap-common_2.4.45+dfsg-1ubuntu1.1_all.deb  Temporary failure resolving 'archive.ubuntu.com'
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/o/openldap/libldap-2.4-2_2.4.45+dfsg-1ubuntu1.1_amd64.deb  Temporary failure resolving 'archive.ubuntu.com'
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/n/nghttp2/libnghttp2-14_1.30.0-1ubuntu1_amd64.deb  Temporary failure resolving 'archive.ubuntu.com'
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/r/rtmpdump/librtmp1_2.4+20151223.gitfa8646d.1-1_amd64.deb  Temporary failure resolving 'archive.ubuntu.com'
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/c/curl/libcurl4_7.58.0-2ubuntu3.5_amd64.deb  Temporary failure resolving 'archive.ubuntu.com'
    E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/c/curl/curl_7.58.0-2ubuntu3.5_amd64.deb  Temporary failure resolving 'archive.ubuntu.com'
    E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
    admin@Iobroker:~$
    Die Anforderung sudo apt install curl hab ich schon ausgeführt.
    Cores: 1 × 8 = 8 cores
    Threads: 16
    mit Proxmox
    LXC Container mit Iobroker
    • stefu87_CHS stefu87_CH
      Hallo
      Password:
      applicable law.
      admin@Iobroker:~$
      @stefu87_ch sagte in Iobroker kann NodeJS nicht installieren:
        Hallo
        Password:
        applicable law.
        admin@Iobroker:~$
        @stefu87_ch
        Die Kiste kommt nicht raus aus dem Netzwerk.
          @stefu87_ch
          stefu87_CHS Offline
          stefu87_CHS Offline
          stefu87_CH
          @thomas-braun sagte in Iobroker kann NodeJS nicht installieren:
          @stefu87_ch
          Und wie kann ich das überprüfen?
          Netzwerkkarte ist die richtige eingetragen
          Threads: 16
          mit Proxmox
            @stefu87_ch
            @stefu87_ch
            Bei ProxMurks bin ich raus.
            Ich würde aber auch (wenn es denn schon ubuntu sein muss...) auch was aktuelleres nehmen. 22.04 LTS ist das im Moment. Die 18.04 stirbt in einem Jahr aus.
              @stefu87_ch
              stefu87_CHS Offline
              stefu87_CHS Offline
              stefu87_CH
              @stefu87_ch
              Danke für den Tipp.
              Wenn ich das mit den Netzwerk hinkriege, werde ich auf das aktuelle gehen.
              Threads: 16
              mit Proxmox
                @stefu87_ch
                bist du per puty drauf?
                dann kommt die VM nur nicht ins Internet.
                oder spielt ihr da auch mit Containern?
                  stefu87_CHS Offline
                  stefu87_CHS Offline
                  stefu87_CH
                  Hab den Fehler selbst gefunden. Es ist der Mensch, der an der Tastatur und an der Maus ist.
                  Habe nicht gemerkt, das ich nicht DHCP angewählt habe sondern auf Statisch gelassen habe und keine IP Adresse eingegen habe. Dadurch ist der Fehler entstanden.
                  Threads: 16
                  mit Proxmox
                    @stefu87_ch
                    Und installier nodejs NICHT zuvor von Hand, das machst du über den iobroker-Installer.
