  4. Bitte um Hilfe für mein Smarthome Projekt
    5.8k
40 Beiträge 4 Kommentatoren 2.1k Aufrufe 5 Beobachtet
    @wendy2702
    Hier einige Fehler aus dem Fehlerlog:
    2022-07-28 00:00:05.002 - error: trashschedule.0 (1764) no events found in ical instance - check configuration and restart instance
    2022-07-28 00:00:20.027 - error: trashschedule.0 (1764) no events found in ical instance - check configuration and restart instance
    2022-07-28 00:00:22.774 - error: birthdays.0 (16189) [ical] unable to parse ical data (invalid file format?): TypeError: Cannot read properties of undefined (reading 'property')
    2022-07-28 00:00:22.778 - error: birthdays.0 (16189) No birthdays found in any configured source - please check configuration and retry
    2022-07-28 00:30:19.649 - error: trashschedule.0 (1764) no events found in ical instance - check configuration and restart instance
    2022-07-28 01:00:05.002 - error: trashschedule.0 (1764) no events found in ical instance - check configuration and restart instance
    2022-07-28 01:00:19.765 - error: trashschedule.0 (1764) no events found in ical instance - check configuration and restart instance
    2022-07-28 01:30:19.672 - error: trashschedule.0 (1764) no events found in ical instance - check configuration and restart instance
    2022-07-28 01:30:24.732 - info: ical.0 (23008) Terminated (NO_ERROR): Without reason
    2022-07-28 02:00:05.017 - error: trashschedule.0 (1764) no events found in ical instance - check configuration and restart instance
    2022-07-28 02:00:19.673 - error: trashschedule.0 (1764) no events found in ical instance - check configuration and restart instance
    2022-07-28 02:00:24.731 - info: ical.0 (25290) Terminated (NO_ERROR): Without reason
    2022-07-28 02:30:19.683 - error: trashschedule.0 (1764) no events found in ical instance - check configuration and restart instance
    2022-07-28 02:30:24.765 - info: ical.0 (27557) Terminated (NO_ERROR): Without reason
    2022-07-28 03:00:05.003 - error: trashschedule.0 (1764) no events found in ical instance - check configuration and restart instance
    2022-07-28 03:00:19.622 - error: trashschedule.0 (1764) no events found in ical instance - check configuration and restart instance
    2022-07-28 03:00:24.684 - info: ical.0 (29824) Terminated (NO_ERROR): Without reason
    2022-07-28 03:30:19.597 - error: trashschedule.0 (1764) no events found in ical instance - check configuration and restart instance
    2022-07-28 03:30:24.657 - info: ical.0 (32732) Terminated (NO_ERROR): Without reason
    2022-07-28 04:00:05.005 - error: trashschedule.0 (1764) no events found in ical instance - check configuration and restart instance
    2022-07-28 04:00:19.726 - error: trashschedule.0 (1764) no events found in ical instance - check configuration and restart instance
    2022-07-28 04:00:24.797 - info: ical.0 (2839) Terminated (NO_ERROR): Without reason
    2022-07-28 04:30:19.481 - error: trashschedule.0 (1764) no events found in ical instance - check configuration and restart instance
    2022-07-28 04:30:24.545 - info: ical.0 (5131) Terminated (NO_ERROR): Without reason
    2022-07-28 05:00:05.003 - error: trashschedule.0 (1764) no events found in ical instance - check configuration and restart instance
    2022-07-28 05:00:19.695 - error: trashschedule.0 (1764) no events found in ical instance - check configuration and restart instance
    2022-07-28 05:00:24.755 - info: ical.0 (7383) Terminated (NO_ERROR): Without reason
    Ich hoffe das es reicht.
    wendy2702W Online
    wendy2702W Online
    @esox du hast leider das loggen nicht auf debug gestellt.
    • wendy2702W wendy2702
      @wendy2702 Okay, mein Fehler. Habs jetzt umgestellt auf debug und sammle nochmal neue Daten.
        @esox So, hab gestern auf debug gestellt un heute das rauskopiert:
        trashschedule.0
        	2022-07-29 13:00:19.623	error	no events found in ical instance - check configuration and restart instance
        trashschedule.0
        	2022-07-29 13:00:05.013	error	no events found in ical instance - check configuration and restart instance
        ical.0
        	2022-07-29 13:00:24.699	info	Terminated (NO_ERROR): Without reason
        trashschedule.0
        ical.0
        	2022-07-29 13:00:19.602	info	processing URL: Pappe/Papier https://xxxxxxxxxxxxxxxxxxxxxxxxxxxx
        ical.0
        	2022-07-29 13:00:19.549	info	processing URL: Geburtstage https://xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
        ical.0
        	2022-07-29 13:00:19.546	info	processing URL: Wertstofftonne https://xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
        ical.0
        	2022-07-29 13:00:19.541	info	processing URL: Mülltonne https://xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
        ical.0
        	2022-07-29 13:00:17.751	info	starting. Version 1.13.1 in /opt/iobroker/node_modules/iobroker.ical, node: v18.2.0, js-controller: 4.0.23
        trashschedule.0
        Ich hoffe das ist richtig, kenne mich noch nicht so damit aus, die einzelnen Modis wie debug error und info.
        HomoranH GlasfaserG 2 Antworten Letzte Antwort
          trashschedule.0
          trashschedule.0
          ical.0
          trashschedule.0
          ical.0
          ical.0
          ical.0
          ical.0
          ical.0
          trashschedule.0
          @esox sagte in Bitte um Hilfe für mein Smarthome Projekt:
          sieht nicht so aus, alles höchstens info.
          was hast du denn umgestellt?
          die logstufe der Instanz, oder nur den Filter im log
            trashschedule.0
            trashschedule.0
            ical.0
            trashschedule.0
            ical.0
            ical.0
            ical.0
            ical.0
            ical.0
            trashschedule.0
            GlasfaserG Offline
            GlasfaserG Offline
            node: v18.2.0,
            Mhh ... Nodejs 18 !?
            ist nicht die empfohlende Version !
            Zeige mal :
            cd /opt/iobroker
            npm ls | grep -E 'github.com|ERR'
            iobroker update -i
            uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
              GlasfaserG Offline
              GlasfaserG Offline
              @Esox
              @homoran sagte in Bitte um Hilfe für mein Smarthome Projekt:
              siehe hier , wie man das umstellt
              https://forum.iobroker.net/topic/56557/backup-wiederherstellung-nicht-möglich/165
              • GlasfaserG Glasfaser
                @Esox
                @glasfaser Habs mal ausgeführt:
                ├── iobroker.alexa2@3.18.6 (git+ssh://git@github.com/Apollon77/ioBroker.alexa2.git#8a13327ff667f3589ea3100650b9328545be8c42)
                ├── iobroker.heatingcontrol@2.9.1 (git+ssh://git@github.com/rg-engineering/ioBroker.heatingcontrol.git#23994523dac119cfb0fbec262e84bb38544939e9)
                ├── iobroker.icons-material-png@0.1.1 (git+ssh://git@github.com/ioBroker/ioBroker.icons-material-png.git#94ebd8d8b379df4bbee2d90b4a99fe9ba3906e55)
                ├── iobroker.influxdb@3.1.7 (git+ssh://git@github.com/ioBroker/ioBroker.influxdb.git#7a0898111f31f8236f81fdfff462152f34e8501e)
                armv7l
                /usr/bin/nodejs
                /home/pi/.nvm/versions/node/v18.1.0/bin/node
                /home/pi/.nvm/versions/node/v18.1.0/bin/npm
                v18.2.0
                v18.1.0
                8.8.0
                pi
                /opt/iobroker
                @Homoran
                Habs jetzt nochmal in den Instanzen umgestellt, wie vorgeschlage. Sorry, hatte es nicht besser gewusst.
                gelöscht
                Ich hoffe jetzt ist es richtig.
                Danke für die Mühen
                  armv7l
                  /usr/bin/nodejs
                  v18.2.0
                  v18.1.0
                  8.8.0
                  pi
                  /opt/iobroker
                  @Homoran
                  gelöscht
                  Danke für die Mühen
                  GlasfaserG Offline
                  GlasfaserG Offline
                  usr/bin/nodejs
                  v18.2.0
                  v18.1.0
                  8.8.0
                  Da ist ja alles quer im Garten . richte es auf Nodejs16 ein
                  wie ... steht hier im Thread
                  https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                  Dann wäre auch die große Frage .. . nach welcher Anleitung hast du das hinbekommen !? .
                  ? GlasfaserG 2 Antworten Letzte Antwort
                    armv7l
                    /usr/bin/nodejs
                    v18.2.0
                    v18.1.0
                    8.8.0
                    pi
                    /opt/iobroker
                    @Homoran
                    gelöscht
                    Danke für die Mühen
                    GlasfaserG Offline
                    GlasfaserG Offline
                    calendar from URL: https://calendar.google.com/
                    Bitte deine URL im Log unkennlich machen !!
                    @Homoran wärst du so nett ... ✏
                    ich denke mal er wird erst Morgen wieder antworten .
                      @glasfaser hab alles gelöscht, bin am Handy, da war das unformatiert und so der schnellste weg
                        usr/bin/nodejs
                        v18.2.0
                        v18.1.0
                        8.8.0
                        @glasfaser Okay, verstehe zwar nicht alles, aber ich versuchs mal und stelle es auf Nodes 16 um.
                        Meine Letzte Iobroker Installation, wo alles lief, war wohl noch eine ältere Node Version. Daenn da hatte ich mit den jetzt zickenden Adaptern überhaupt keine Probleme. Danke
                        Danke fürs löschen der URL´s . Hab nicht drauf geachtet.
                          usr/bin/nodejs
                          v18.2.0
                          v18.1.0
                          8.8.0
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Das sollteste du alles umstellen !
                          @glasfaser sagte in Bitte um Hilfe für mein Smarthome Projekt:
                          usr/bin/nodejs
                          v18.2.0
                          v18.1.0
                          8.8.0
                          Deine Nodejs / NPM ist komplett durcheinander und auch im falschen Verzeichniss.
                          Die Installation wäre im Verzeichniss ... richtig und die Ausgabe .... :
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v16.16.0
                          v16.16.0
                          8.11.0
                          ? 2 Antworten Letzte Antwort
                            usr/bin/nodejs
                            v18.2.0
                            v18.1.0
                            8.8.0
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v16.16.0
                            v16.16.0
                            8.11.0
                            @glasfaser Reicht es denn aus wenn ich nach dieser Anleitung verfahre und auf Node 16 update?
                            Ich hoffe....
                              Ich hoffe....
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Ich hoffe....
                              Nein , du mußt alles löschen , denn wie schon gesagt hast du es im falschen Verzeichniss.
                              deshalb habe ich dir oben schon den Link dazu gegeben !
                              Im Link Teil 1.1 ab CHECK
                                Ich hoffe....
                                @glasfaser Jo, habe ich schon verstanden. Ich wollte in dem Link beide Sachen durcharbeiten:
                                Teil 1: Installation und Update
                                Teil 2: Installationen geradeziehen (siehe 2. Posting im Thread)
                                Dann wollte ich mal sehen was passiert und mich dann wieder melden, Okay?
                                Ich babe die fehlerhaften Adapter im Iobroker deinstalliert.
                                Nach eingabe von: npm ls | grep -E 'github.com|ERR' kommen immer noch die Fehler:
                                Was nun?
                                  Was nun?
                                  @esox So, hat zwar ein paar Tage gedauert, aber heute bin ich zu gekommen,
                                  Habe den Thread Nodejs-Installation und Upgrades unter Debian durchgearbeitet. Das Ergebnis:
                                  npm -v
                                  Ergebnis: 8.8.0
                                  nodejs -v
                                  Ergebnis: v16.16.0
                                  Und was nun? Kann ich Alexa2 und Co wieder installieren? Werden sie auch laufen?
                                  Bitte um passende Antworten, eilt aber nicht.
                                    npm -v
                                    Ergebnis: 8.8.0
                                    nodejs -v
                                    Ergebnis: v16.16.0
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    Das Ergebnis: .............................
                                    Und was nun?
                                    Diese Ergebnis sagt nicht viel aus,!!
                                    Zeigen !
                                    cd /opt/iobroker
                                      usr/bin/nodejs
                                      v18.2.0
                                      v18.1.0
                                      8.8.0
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      v16.16.0
                                      v16.16.0
                                      8.11.0
                                      @glasfaser Okay, verstehe zwar nicht alles, aber **ich versuchs** mal **und stelle es auf Nodes 16 um.**
                                      usr/bin/nodejs
                                      v18.2.0
                                      v18.1.0
                                      8.8.0
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      v16.16.0
                                      v16.16.0
                                      8.11.0
                                      Wie stelle ich das auf die anderen Pfade um? Hab ich noch nie gemacht, bin auf der Konsole nicht so bewandert wie man das ´verschiebt´ oder umleitet???
                                        Was nun?
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        Ich habe gedacht du hast alles durchgearbeitet .
                                        Bitte die Ausgabe ...
                                          @glasfaser npm ls | grep -E 'github.com|ERR'
                                          ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                                          armv7l
                                          /usr/bin/nodejs
                                          v16.16.0
                                          v18.1.0
                                          8.8.0
                                          pi
                                          /opt/iobroker
                                          Get:1 file:/var/cache/openmediavault/archives  InRelease
                                          Ign:1 file:/var/cache/openmediavault/archives  InRelease
                                          Get:2 file:/var/cache/openmediavault/archives  Release
                                          Ign:2 file:/var/cache/openmediavault/archives  Release
                                          Get:3 file:/var/cache/openmediavault/archives  Packages
                                          Ign:3 file:/var/cache/openmediavault/archives  Packages
                                          Get:4 file:/var/cache/openmediavault/archives  Translation-en
                                          Ign:4 file:/var/cache/openmediavault/archives  Translation-en
                                          Hit:5 http://archive.raspberrypi.org/debian buster InRelease
                                          Hit:6 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                          Hit:7 http://httpredir.debian.org/debian buster-backports InRelease
                                          Hit:8 http://packages.openmediavault.org/public usul InRelease
                                          Get:9 https://download.docker.com/linux/debian buster InRelease [54.0 kB]
                                          Hit:10 https://deb.nodesource.com/node_16.x buster InRelease
                                          Get:11 https://openmediavault-plugin-developers.github.io/packages/debian usul InRelease [3928 B]
                                          Get:12 https://openmediavault.github.io/packages usul InRelease [12.7 kB]
                                          Fetched 70.6 kB in 6s (11.2 kB/s)
                                          Reading package lists... Done
                                          Building dependency tree
                                          19 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                          nodejs:
                                            Installed: 16.16.0-deb-1nodesource1
                                            Candidate: 16.16.0-deb-1nodesource1
                                            Version table:
                                           *** 16.16.0-deb-1nodesource1 500
                                                  500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                                               10.24.0~dfsg-1~deb10u1 500
                                          Das sind die Ergebnise zu Deinen Befehlen. Danke für Deine Mühe, ich weiß das es nervt einem Nerd zu Helfen.
