  4. Bitte rflink, modbus, mysensors Testen (serialport upgrade)
53 Beiträge 8 Kommentatoren 10.3k Aufrufe
    knopers1
    ok, Danke Rainer… Unter Haupteinstellungen sieht man nicht viel...siehe Bild.
    ich habe alles neu aufgesetzt! Anbei der Auszug aus der Konsole von derb Installation!
    Welcome to ARMBIAN 5.25 stable Debian GNU/Linux 8 (jessie) 3.4.113-sun8i
    System load:   1.20             Up time:       7 hours
    Memory usage:  8 % of 2014Mb    IP:            192.168.1.99
    CPU temp:      34°C
    Usage of /:    7% of 29G        storage/:      7% of 29G
    Last login: Mon Jun  5 13:15:16 2017 from lenovo-pc.fritz.box
    root@orangepiplus2e:~# sudo npm install https://github.com/ioBroker/ioBroker.rflink/tarball/master --production
    > serialport@4.0.7 install /root/node_modules/avrgirl-arduino/node_modules/serialport
    > node-pre-gyp install --fallback-to-build
    node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v48-linux-arm.tar.gz
    node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.10.3 (node-v48 ABI) (falling back to source compile with node-gyp)
    make: Entering directory '/root/node_modules/avrgirl-arduino/node_modules/serialport/build'
      CXX(target) Release/obj.target/serialport/src/serialport.o
    ../src/serialport.cpp: In function ‘int getIntFromObject(v8::Local<v8::object>, std::string)’:
    ../src/serialport.cpp:90:52: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
       return getValueFromObject(options, key)->ToInt32()->Int32Value();
    ../src/serialport.cpp: In function ‘double getDoubleFromObject(v8::Local<v8::object>, std::string)’:
    ../src/serialport.cpp:102:53: warning: ‘v8::Local <v8::number>v8::Value::ToNumber() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8166): Use maybe version [-Wdeprecated-declarations]
       return getValueFromObject(options, key)->ToNumber()->NumberValue();
    ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
    ../src/serialport.cpp:174:31: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
         int fd = argv[1]->ToInt32()->Int32Value();
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:193:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
       int fd = info[0]->ToInt32()->Int32Value();
    ../src/serialport.cpp:217:116: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
       baton->baudRate = Nan::Get(options, Nan::New<v8::string>("baudRate").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Write(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:252:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:369:32: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
       baton->fd = info[0]->ToInt32()->Int32Value();
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:480:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:528:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:585:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
      CXX(target) Release/obj.target/serialport/src/serialport_unix.o
    ../src/serialport_unix.cpp: In function ‘OpenBatonPlatformOptions* ParsePlatformOptions(const v8::Local<v8::object>&)’:
    ../src/serialport_unix.cpp:44:109: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
       result->vmin = Nan::Get(options, Nan::New<v8::string>("vmin").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
    ../src/serialport_unix.cpp:45:111: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
       result->vtime = Nan::Get(options, Nan::New<v8::string>("vtime").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
      CXX(target) Release/obj.target/serialport/src/serialport_poller.o
    ../src/serialport_poller.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE SerialportPoller::New(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport_poller.cpp:86:31: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
       obj->fd_ = info[0]->ToInt32()->Int32Value();
      SOLINK_MODULE(target) Release/obj.target/serialport.node
      COPY Release/serialport.node
    make: Leaving directory '/root/node_modules/avrgirl-arduino/node_modules/serialport/build'
    > serialport@4.0.7 install /root/node_modules/iobroker.rflink/node_modules/serialport
    make: Entering directory '/root/node_modules/iobroker.rflink/node_modules/serialport/build'
    make: Leaving directory '/root/node_modules/iobroker.rflink/node_modules/serialport/build'
    /root
    └─┬ iobroker.rflink@1.1.5
      ├─┬ avrgirl-arduino@1.11.12
      │ ├─┬ async@2.4.1
      │ │ └── lodash@4.17.4
      │ ├─┬ awty@0.1.0
      │ │ └── isval@0.0.2
      │ ├── browser-serialport@2.0.3  (git://github.com/noopkat/browser-serialport.git#a1cecbee1276bfe78b0491f8d13544c70859ff36)
      │ ├── chip.avr.avr109@1.1.0
      │ ├── colors@1.1.2
      │ ├── graceful-fs@4.1.11
      │ ├── intel-hex@0.1.1
      │ ├── minimist@1.2.0
      │ ├─┬ serialport@4.0.7
      │ │ ├── nan@2.6.2
      │ │ └─┬ node-pre-gyp@0.6.32
      │ │   ├─┬ mkdirp@0.5.1
      │ │   │ └── minimist@0.0.8
      │ │   ├─┬ nopt@3.0.6
      │ │   │ └── abbrev@1.0.9
      │ │   ├─┬ npmlog@4.0.1
      │ │   │ ├─┬ are-we-there-yet@1.1.2
      │ │   │ │ ├── delegates@1.0.0
      │ │   │ │ └─┬ readable-stream@2.2.2
      │ │   │ │   ├── buffer-shims@1.0.0
      │ │   │ │   ├── core-util-is@1.0.2
      │ │   │ │   ├── inherits@2.0.3
      │ │   │ │   ├── isarray@1.0.0
      │ │   │ │   ├── process-nextick-args@1.0.7
      │ │   │ │   ├── string_decoder@0.10.31
      │ │   │ │   └── util-deprecate@1.0.2
      │ │   │ ├── console-control-strings@1.1.0
      │ │   │ ├─┬ gauge@2.7.2
      │ │   │ │ ├── aproba@1.0.4
      │ │   │ │ ├── has-unicode@2.0.1
      │ │   │ │ ├── object-assign@4.1.0
      │ │   │ │ ├── signal-exit@3.0.2
      │ │   │ │ ├─┬ string-width@1.0.2
      │ │   │ │ │ ├── code-point-at@1.1.0
      │ │   │ │ │ └─┬ is-fullwidth-code-point@1.0.0
      │ │   │ │ │   └── number-is-nan@1.0.1
      │ │   │ │ ├─┬ strip-ansi@3.0.1
      │ │   │ │ │ └── ansi-regex@2.0.0
      │ │   │ │ ├── supports-color@0.2.0
      │ │   │ │ └── wide-align@1.1.0
      │ │   │ └── set-blocking@2.0.0
      │ │   ├─┬ rc@1.1.6
      │ │   │ ├── deep-extend@0.4.1
      │ │   │ ├── ini@1.3.4
      │ │   │ ├── minimist@1.2.0
      │ │   │ └── strip-json-comments@1.0.4
      │ │   ├─┬ request@2.79.0
      │ │   │ ├── aws-sign2@0.6.0
      │ │   │ ├── aws4@1.5.0
      │ │   │ ├── caseless@0.11.0
      │ │   │ ├─┬ combined-stream@1.0.5
      │ │   │ │ └── delayed-stream@1.0.0
      │ │   │ ├── extend@3.0.0
      │ │   │ ├── forever-agent@0.6.1
      │ │   │ ├─┬ form-data@2.1.2
      │ │   │ │ └── asynckit@0.4.0
      │ │   │ ├─┬ har-validator@2.0.6
      │ │   │ │ ├─┬ chalk@1.1.3
      │ │   │ │ │ ├── ansi-styles@2.2.1
      │ │   │ │ │ ├── escape-string-regexp@1.0.5
      │ │   │ │ │ ├─┬ has-ansi@2.0.0
      │ │   │ │ │ │ └── ansi-regex@2.0.0
      │ │   │ │ │ ├─┬ strip-ansi@3.0.1
      │ │   │ │ │ └── supports-color@2.0.0
      │ │   │ │ ├─┬ is-my-json-valid@2.15.0
      │ │   │ │ │ ├── generate-function@2.0.0
      │ │   │ │ │ ├─┬ generate-object-property@1.2.0
      │ │   │ │ │ │ └── is-property@1.0.2
      │ │   │ │ │ ├── jsonpointer@4.0.0
      │ │   │ │ │ └── xtend@4.0.1
      │ │   │ │ └─┬ pinkie-promise@2.0.1
      │ │   │ │   └── pinkie@2.0.4
      │ │   │ ├─┬ hawk@3.1.3
      │ │   │ │ ├── boom@2.10.1
      │ │   │ │ ├── cryptiles@2.0.5
      │ │   │ │ ├── hoek@2.16.3
      │ │   │ │ └── sntp@1.0.9
      │ │   │ ├─┬ http-signature@1.1.1
      │ │   │ │ ├── assert-plus@0.2.0
      │ │   │ │ ├─┬ jsprim@1.3.1
      │ │   │ │ │ ├── extsprintf@1.0.2
      │ │   │ │ │ ├── json-schema@0.2.3
      │ │   │ │ │ └── verror@1.3.6
      │ │   │ │ └─┬ sshpk@1.10.1
      │ │   │ │   ├── asn1@0.2.3
      │ │   │ │   ├── assert-plus@1.0.0
      │ │   │ │   ├── bcrypt-pbkdf@1.0.0
      │ │   │ │   ├── dashdash@1.14.1
      │ │   │ │   ├── ecc-jsbn@0.1.1
      │ │   │ │   ├── getpass@0.1.6
      │ │   │ │   ├── jodid25519@1.0.2
      │ │   │ │   ├── jsbn@0.1.0
      │ │   │ │   └── tweetnacl@0.14.4
      │ │   │ ├── is-typedarray@1.0.0
      │ │   │ ├── isstream@0.1.2
      │ │   │ ├── json-stringify-safe@5.0.1
      │ │   │ ├─┬ mime-types@2.1.13
      │ │   │ │ └── mime-db@1.25.0
      │ │   │ ├── oauth-sign@0.8.2
      │ │   │ ├── qs@6.3.0
      │ │   │ ├── stringstream@0.0.5
      │ │   │ ├─┬ tough-cookie@2.3.2
      │ │   │ │ └── punycode@1.4.1
      │ │   │ ├── tunnel-agent@0.4.3
      │ │   │ └── uuid@3.0.1
      │ │   ├─┬ rimraf@2.5.4
      │ │   │ └─┬ glob@7.1.1
      │ │   │   ├── fs.realpath@1.0.0
      │ │   │   ├─┬ inflight@1.0.6
      │ │   │   │ └── wrappy@1.0.2
      │ │   │   ├─┬ minimatch@3.0.3
      │ │   │   │ └─┬ brace-expansion@1.1.6
      │ │   │   │   ├── balanced-match@0.4.2
      │ │   │   │   └── concat-map@0.0.1
      │ │   │   ├─┬ once@1.4.0
      │ │   │   └── path-is-absolute@1.0.1
      │ │   ├── semver@5.3.0
      │ │   ├─┬ tar@2.2.1
      │ │   │ ├── block-stream@0.0.9
      │ │   │ ├─┬ fstream@1.0.10
      │ │   │ │ └── graceful-fs@4.1.11
      │ │   │ └── inherits@2.0.3
      │ │   └─┬ tar-pack@3.3.0
      │ │     ├─┬ debug@2.2.0
      │ │     │ └── ms@0.7.1
      │ │     │ ├── graceful-fs@4.1.11
      │ │     ├─┬ fstream-ignore@1.0.5
      │ │     │ └─┬ minimatch@3.0.3
      │ │     ├─┬ once@1.3.3
      │ │     ├─┬ readable-stream@2.1.5
      │ │     └── uid-number@0.0.6
      │ ├─┬ stk500@1.0.4  (git://github.com/noopkat/js-stk500v1.git#e116a1f72abdafc7d57eb0ee58221556d2b5def4)
      │ │ ├── async@0.9.2
      │ │ └── buffer-equal@0.0.1
      │ └─┬ stk500-v2@1.0.2
      │   └── async@0.9.2
      ├─┬ request@2.81.0
      │ ├── aws4@1.6.0
      │ ├── caseless@0.12.0
      │ ├── extend@3.0.1
      │ ├─┬ form-data@2.1.4
      │ ├─┬ har-validator@4.2.1
      │ │ ├─┬ ajv@4.11.8
      │ │ │ ├── co@4.6.0
      │ │ │ └─┬ json-stable-stringify@1.0.1
      │ │ │   └── jsonify@0.0.0
      │ │ └── har-schema@1.0.5
      │ ├─┬ hawk@3.1.3
      │ │ ├── boom@2.10.1
      │ │ ├── hoek@2.16.3
      │ │ └── sntp@1.0.9
      │ │ ├─┬ jsprim@1.4.0
      │ │ └─┬ sshpk@1.13.0
      │ │   ├── asn1@0.2.3
      │ │   ├── bcrypt-pbkdf@1.0.1
      │ │   ├─┬ dashdash@1.14.1
      │ │   │ └── assert-plus@1.0.0
      │ │   ├─┬ getpass@0.1.7
      │ │   ├── jsbn@0.1.1
      │ │   └── tweetnacl@0.14.5
      │ ├─┬ mime-types@2.1.15
      │ │ └── mime-db@1.27.0
      │ ├── performance-now@0.2.0
      │ ├── qs@6.4.0
      │ ├── safe-buffer@5.1.0
      │ ├── tunnel-agent@0.6.0
      │ └── uuid@3.0.1
      └─┬ serialport@4.0.7
        ├─┬ commander@2.9.0
        │ └── graceful-readlink@1.0.1
        ├─┬ debug@2.6.8
        │ └── ms@2.0.0
        ├─┬ lie@3.1.1
        │ └── immediate@3.0.6
        ├── nan@2.6.2
          ├─┬ mkdirp@0.5.1
          ├─┬ nopt@3.0.6
          │ └── abbrev@1.0.9
          ├─┬ npmlog@4.0.1
          │ ├─┬ gauge@2.7.2
          ├─┬ rc@1.1.6
          │ ├── ini@1.3.4
          ├─┬ request@2.79.0
          │ ├── aws4@1.5.0
          │ ├── extend@3.0.0
          │ │ ├─┬ chalk@1.1.3
          │ ├─┬ hawk@3.1.3
          │ │ ├── boom@2.10.1
          │ │ ├── hoek@2.16.3
          │ │ └── sntp@1.0.9
          │ │   ├── asn1@0.2.3
          │ │   ├── jsbn@0.1.0
          │ ├── qs@6.3.0
          │ └── uuid@3.0.1
          ├─┬ rimraf@2.5.4
          │ └─┬ glob@7.1.1
          │   ├─┬ once@1.4.0
          ├── semver@5.3.0
          ├─┬ tar@2.2.1
          └─┬ tar-pack@3.3.0
            ├─┬ debug@2.2.0
            │ └── ms@0.7.1
            ├─┬ fstream@1.0.10
            ├─┬ once@1.3.3
            │ └── wrappy@1.0.2
            │ ├── isarray@1.0.0
    npm WARN enoent ENOENT: no such file or directory, open '/root/package.json'
    npm WARN root No description
    npm WARN root No repository field.
    npm WARN root No README data
    npm WARN root No license field.
    root@orangepiplus2e:~#</v8::int32></v8::string></v8::int32></v8::string></v8::int32></v8::object></v8::int32></v8::int32></v8::int32></v8::int32></v8::int32></v8::string></v8::int32></v8::int32></v8::int32></v8::number></v8::object></v8::int32></v8::object></v8::int32></v8::string></v8::int32></v8::string></v8::int32></v8::object></v8::int32></v8::int32></v8::int32></v8::int32></v8::int32></v8::string></v8::int32></v8::int32></v8::int32></v8::number></v8::object></v8::int32></v8::object>
    Die ersten Zeilen spucken schon Fehler aus!
    ****> serialport@4.0.7 install /root/node_modules/avrgirl-arduino/node_modules/serialport
    node-pre-gyp install –fallback-to-build****
    ****node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAd … arm.tar.gz
    node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.10.3 (node-v48 ABI) (falling back to source compile with node-gyp)****
    Ideeen ????
      @knopers1:
      ok, Danke Rainer… Unter Haupteinstellungen sieht man nicht viel...siehe Bild. `
      Man sieht, dass du das "default" Repository und damit das stable ausgewählt hast, das erklärt auch, dass deine angebotene rf-Link Version relativ alt ist.
        knopers1
        o.k, kommen wir der Sache etwa näher???
        der Link unten funktioniert nicht. Kein Wunder dass es Fehler spuckt…
        Welche Repository soll ich als default wählen?
        node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAd ... arm.tar.gz
          @knopers1:
          o.k, kommen wir der Sache etwa näher??? `
          Nee, wir entfernen uns schon wieder vom bestmöglichen!
          default ist ok = stable
          WENN du auf latest gehen WILLST nicht die Pfade ändern, sondern unter Haupteinstellungen im pulldown default gegen latest tauschen.
          Da du aber sogar die Github-Version hast bist du auf dem allerneuesten Stand.
          @knopers1:
          der Link unten funktioniert nicht. Kein Wunder dass es Fehler spuckt… `
          Das sind keine Fehler!
          Die Installation überprüft ob es für deine Hardware passende fertige Pakete gibt - und findet keine.
          Das ist vollkommen normal.
          Jetzt sagt sich die Installation: Mist, dann muss ich das Paket selber bauen :( und macht das dann auch.
          • apollon77A Offline
            Und die Installation danach sieht ok aus. serialport ist installiert.
            AM besten mal in Debug laufen lassen und Log schicken. Log vom Aufruf der Admin-Seite reicht
              Hier mein log:
              rflink.0	2017-06-05 20:43:36.055	debug	sendTo "readNewVersion" to system.adapter.admin.0 from system.adapter.rflink.0
              rflink.0	2017-06-05 20:43:35.955	debug	sendTo "listUart" to system.adapter.admin.0 from system.adapter.rflink.0
              rflink.0	2017-06-05 20:43:35.952	info	List of port: [{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyS1"},{"comName":"/dev/ttyS2"},{"comName":"/dev/ttyS3"}]
              rflink.0	2017-06-05 20:43:35.850	debug	inMem message messagebox.system.adapter.rflink.0 messagebox.system.adapter.rflink.0 command=listUart, message=null, from=system.adapter.admin.0, message=null, id=12, ack=false, time=1496688215043, _
              rflink.0	2017-06-05 20:43:35.045	debug	inMem message messagebox.system.adapter.rflink.0 messagebox.system.adapter.rflink.0 command=readNewVersion, message=null, from=system.adapter.admin.0, message=null, id=11, ack=false, time=1496688215
              rflink.0	2017-06-05 20:43:32.342	error	No serial port defined
              rflink.0	2017-06-05 20:43:32.195	info	starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.rflink, node: v6.10.3
              rflink.0	2017-06-05 20:43:32.141	debug	statesDB connected
              rflink.0	2017-06-05 20:43:32.091	debug	objectDB connected
              in der Konfig gibt es nur /dev/ttyS0 bis S3 kein USB und kein AMA0 (?)
              Daher kann ich da auch nichts sinnvolles auswählen
                knopers1
                bei mir unter Instanzen taucht nach der Installation kein RFLINK-Adapter auf.
                Ich versuchte es gerade frisch vom Github.
                host.orangepiplus2e	2017-06-05 20:49:47.100	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                iobroker	2017-06-05 20:49:45.945	info	exit 0
                iobroker	2017-06-05 20:49:45.828	info	upload [0] rflink.admin /opt/iobroker/node_modules/iobroker.rflink/admin/index.html index.html text/html
                iobroker	2017-06-05 20:49:45.726	info	upload [1] rflink.admin /opt/iobroker/node_modules/iobroker.rflink/admin/parse.js parse.js application/javascript
                iobroker	2017-06-05 20:49:41.871	info	upload [2] rflink.admin /opt/iobroker/node_modules/iobroker.rflink/admin/rflink.png rflink.png image/png
                iobroker	2017-06-05 20:49:41.842	info	got /opt/iobroker/node_modules/iobroker.rflink/admin
                iobroker	2017-06-05 20:49:36.494	info	npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/stk500/package.json'
                iobroker	2017-06-05 20:49:36.490	info	npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/mdns/package.json'
                iobroker	2017-06-05 20:49:36.468	info	└── stk500@1.0.4 (git://github.com/noopkat/js-stk500v1.git#e116a1f72abdafc7d57eb0ee58221556d2b5def4)
                iobroker	2017-06-05 20:49:36.468	info	├── browser-serialport@2.0.3 (git://github.com/noopkat/browser-serialport.git#a1cecbee1276bfe78b0491f8d13544c70859ff36)
                iobroker	2017-06-05 20:49:36.468	info	└─┬ avrgirl-arduino@1.11.12
                iobroker	2017-06-05 20:49:36.468	info	iobroker@1.0.0 /opt/iobroker└─┬ iobroker.rflink@1.1.5
                iobroker	2017-06-05 20:48:25.543	info	npm install https://github.com/ioBroker/ioBroker.rflink/tarball/master --production --prefix "/opt/iobroker" (System call)
                iobroker	2017-06-05 20:48:24.988	info	install https://github.com/ioBroker/ioBroker.rflink/tarball/master
                iobroker	2017-06-05 20:48:22.950	info	url "https://github.com/ioBroker/ioBroker.rflink/tarball/master" rflink --debug
                  knopers1
                  @ Rainer…
                  schau Dir bitte das Bild an. Unter Adapter sieht man die installierte und verfügbare Version des RFLink Adapters richtig?
                  beides in der Version 1.1.5. Unter Instanzen tauch der Adapter bei mir nicht auf... Wie ist das möglich? Deshalb dachte ich die ganze Zeit, dass der Adapter nicht installiert worden ist... Kann es sein dass es nur ein Anzeigefehler ist? Irgendwo muß es doch installiert sein...
                    @knopers1:
                    Unter Adapter sieht man die installierte und verfügbare Version des RFLink Adapters richtig? `
                    Ja!
                    @knopers1:
                    Unter Instanzen tauch der Adapter bei mir nicht auf… Wie ist das möglich? `
                    Deswegen hatte ich vorhin darauf bestanden dir den Unterschied zwischen Installation des Adapters und Erzeugung einer Instanz zu erklären, …
                    Du hast immer noch keine Instanz erzeugt!
                      knopers1
                      @Rainer, ich habe es am laufen :D
