  4. Test Adapter Grünbeck v0.0.x
gruenbeckgrünbecksc18sc23
508 Beiträge 58 Kommentatoren 153.6k Aufrufe 53 Beobachtet
  • T tombox
    @smartboart Ja wäre gut zu wissen ob es mit der 0.0.34 geht
    smartboartS Offline
    smartboartS Offline
    smartboart
    #352
    @tombox
    unten mal 2 install logs...
    beide älteren Versionen gleicher Fehler.
    $ iobroker upgrade gruenbeck@0.0.41 --debug
    Update gruenbeck from @0.0.33 to @0.0.41
    NPM version: 6.14.17
    Installing iobroker.gruenbeck@0.0.41... (System call)
    npm WARN deprecated regex@0.1.1: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info.
    npm WARN deprecated statemachines@0.1.0: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info.
    npm WARN deprecated nomnom@1.5.2: Package no longer supported. Contact support@npmjs.com for more info.
    npm WARN deprecated sorted-array@1.1.0: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info.
    npm WARN crc@4.1.1 requires a peer of buffer@>=6.0.3 but none is installed. You must install peer dependencies yourself.
    npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
    + iobroker.gruenbeck@0.0.41added 2 packages from 2 contributors, removed 1 package and updated 5 packages in 30.193s
    93 packages are looking for funding run `npm fund` for details
    Update "system.adapter.gruenbeck.0"
    upload [5] gruenbeck.admin /opt/iobroker/node_modules/iobroker.gruenbeck/admin/admin.d.ts admin.d.ts video/mp2t
    upload [4] gruenbeck.admin /opt/iobroker/node_modules/iobroker.gruenbeck/admin/gruenbeck.png gruenbeck.png image/png
    upload [3] gruenbeck.admin /opt/iobroker/node_modules/iobroker.gruenbeck/admin/icon.png icon.png image/png
    upload [2] gruenbeck.admin /opt/iobroker/node_modules/iobroker.gruenbeck/admin/index_m.html index_m.html text/html
    upload [1] gruenbeck.admin /opt/iobroker/node_modules/iobroker.gruenbeck/admin/style.css style.css text/css
    upload [0] gruenbeck.admin /opt/iobroker/node_modules/iobroker.gruenbeck/admin/words.js words.js application/javascript
    Process exited with code 0
    $ iobroker upgrade gruenbeck@0.0.33 --debug
    Update gruenbeck from @0.0.34 to @0.0.33
    Installing iobroker.gruenbeck@0.0.33... (System call)
    npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
    npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    + iobroker.gruenbeck@0.0.33updated 1 package in 27.706s
      ArnoD
      #353
      @tombox
      War bei mir auch nach dem Update auf Nodejs 16.
      Bin aber heute wieder zurück auf Node.js v 14.20.0 und NPM 6.14.17, dachte damit das Problem lösen zu können, aber leider ohne Erfolg.
      System:
      • A ArnoD
        @tombox
        System:
        tombox
        #354
        @arnod Nein also nodejs16 is nich das problem bitte auf nodejs 16 und npm 8 bleiben und mal 0.0.34 probieren
          ArnoD
          #355
          ok nodejs 16 ist wieder drauf, versuche jetzt die 0.0.34
            ArnoD
            #356
            Ok Version 0.0.34 installiert und das gleiche Problem
            LOG:
            gruenbeck.0
            	2022-07-11 21:02:30.742	debug	Error: Parse Error: Missing expected CR after header value at Socket.socketOnData (node:_http_client:494:22) at Socket.emit (node:events:527:28) at Socket.emit (node:domain:475:12) at addChunk (node:internal/streams/readable:315:12) at readableAddChunk (node:internal/streams/readable:289:9) at Socket.Readable.push (node:internal/streams/readable:228:10) at TCP.onStreamRead (node:internal/stream_base_commons:190:23)
            gruenbeck.0
            	2022-07-11 21:02:30.742	info	Device cannot handle new connections this is normal. Adapter pause all requests for 1min
            gruenbeck.0
            	2022-07-11 21:02:30.741	debug	statechange: 4 446
            gruenbeck.0
            	2022-07-11 21:02:28.766	debug	sendRequest
            gruenbeck.0
            	2022-07-11 21:02:28.766	debug	id=0000&code=245&show=D_D_1|D_A_4_1|D_A_4_2|D_A_4_3|D_C_1_1|D_C_2_1|D_C_5_1|D_C_4_1|D_C_4_2|D_C_4_3|D_C_6_1|D_C_7_1|D_A_2_2|D_A_2_3|D_C_3_6_1|D_C_8_1|D_C_8_2|D_C_3_6_2|D_C_3_6_3|D_C_3_6_4|D_C_3_6_5|D_C_3_7_1|D_C_3_7_2|D_C_3_7_3|D_Y_5|D_Y_7|D_Y_6|D_Y_8_11|D_Y_10_1|D_B_1|D_A_1_1|D_A_1_2|D_A_1_3|D_A_2_1|D_A_3_1|D_A_3_2|D_K_1|D_K_2|D_K_3|D_K_4|D_K_7|D_K_8|D_K_9|D_Y_2_1|D_Y_4_1|D_Y_2_2|D_Y_4_2|D_Y_2_3|D_Y_4_3|D_Y_2_4|D_Y_4_4|D_Y_2_5|D_Y_4_5|D_Y_2_6|D_Y_4_6|D_Y_2_7|D_Y_4_7|D_Y_2_8|D_Y_4_8|D_Y_2_9|D_Y_4_9|D_Y_2_10|D_Y_4_10|D_Y_2_11|D_Y_4_11|D_Y_2_12|D_Y_4_12|D_Y_2_13|D_Y_4_13|D_Y_2_14|D_Y_4_14~
            gruenbeck.0
            	2022-07-11 21:02:27.734	debug	Resume connections.
            gruenbeck.0
            	2022-07-11 21:01:27.733	debug	Error: Parse Error: Missing expected CR after header value at Socket.socketOnData (node:_http_client:494:22) at Socket.emit (node:events:527:28) at Socket.emit (node:domain:475:12) at addChunk (node:internal/streams/readable:315:12) at readableAddChunk (node:internal/streams/readable:289:9) at Socket.Readable.push (node:internal/streams/readable:228:10) at TCP.onStreamRead (node:internal/stream_base_commons:190:23)
            gruenbeck.0
            	2022-07-11 21:01:27.732	info	Device cannot handle new connections this is normal. Adapter pause all requests for 1min
            gruenbeck.0
            	2022-07-11 21:01:27.731	debug	statechange: 4 446
            gruenbeck.0
            	2022-07-11 21:01:25.731	debug	sendRequest
            gruenbeck.0
            	2022-07-11 21:01:25.730	debug	id=0000&code=245&show=D_D_1|D_A_4_1|D_A_4_2|D_A_4_3|D_C_1_1|D_C_2_1|D_C_5_1|D_C_4_1|D_C_4_2|D_C_4_3|D_C_6_1|D_C_7_1|D_A_2_2|D_A_2_3|D_C_3_6_1|D_C_8_1|D_C_8_2|D_C_3_6_2|D_C_3_6_3|D_C_3_6_4|D_C_3_6_5|D_C_3_7_1|D_C_3_7_2|D_C_3_7_3|D_Y_5|D_Y_7|D_Y_6|D_Y_8_11|D_Y_10_1|D_B_1|D_A_1_1|D_A_1_2|D_A_1_3|D_A_2_1|D_A_3_1|D_A_3_2|D_K_1|D_K_2|D_K_3|D_K_4|D_K_7|D_K_8|D_K_9|D_Y_2_1|D_Y_4_1|D_Y_2_2|D_Y_4_2|D_Y_2_3|D_Y_4_3|D_Y_2_4|D_Y_4_4|D_Y_2_5|D_Y_4_5|D_Y_2_6|D_Y_4_6|D_Y_2_7|D_Y_4_7|D_Y_2_8|D_Y_4_8|D_Y_2_9|D_Y_4_9|D_Y_2_10|D_Y_4_10|D_Y_2_11|D_Y_4_11|D_Y_2_12|D_Y_4_12|D_Y_2_13|D_Y_4_13|D_Y_2_14|D_Y_4_14~
            gruenbeck.0
            	2022-07-11 21:01:25.727	debug	[INFO] Configured polling interval: 15000
            gruenbeck.0
            	2022-07-11 21:01:25.726	debug	Starting gruenbeck adapter with:192.168.1.230
            gruenbeck.0
            	2022-07-11 21:01:25.673	info	starting. Version 0.0.34 in /opt/iobroker/node_modules/iobroker.gruenbeck, node: v16.16.0, js-controller: 4.0.23
            gruenbeck.0
            	2022-07-11 21:01:23.143	debug	Plugin sentry Initialize Plugin (enabled=true)
            host.iobroker
            	2022-07-11 21:01:17.982	info	instance system.adapter.gruenbeck.0 started with pid 2677
            host.iobroker
            	2022-07-11 21:01:17.480	info	"system.adapter.gruenbeck.0" enabled
            • A ArnoD
              tombox
              #357
              @arnod @smartboart
              Ich habe mal die alte Variante wie daten geholt werden aktualisiert. Installiert mal die github version wie es sich dann verhält
              • T tombox
                @arnod @smartboart
                smartboartS Offline
                smartboartS Offline
                smartboart
                #358
                @tombox habe ich gemacht...keine Änderung.mal sehen was ArnoD schreibt..irgendwas muss sich ja beim Update des Systems negativ auswirken...hab jetzt auch Node und npm auf die empfohlene version gehoben...bringt auch nix...ne idee zu den Installations Meldungen im install log? Oder kann man die vernachlässigen.?
                T A 3 Antworten Letzte Antwort
                • smartboartS smartboart
                  tombox
                  #359
                  @smartboart Und Adapter stoppen. Gerät 5min Stromlos. starten und dann adapter starten bringt auch nichts?
                    tombox
                    #360
                    @smartboart Also ich konnte soweit das Problem identifizieren
                    Node v14.20.0
                    Node v16.16.0
                    Node v18.5.0
                    hat ein striktere http header parsing eingebaut.
                    https://github.com/nodejs/node/commit/f2407748e3
                    Damit werden die inkorrekten ausgaben von gruenbeck als fehler gewertet.
                    Bisher habe ich keine gute Lösung außer Node v16.15.1 installieren
                    A smartboartS T 4 Antworten Letzte Antwort
                    • T tombox
                      Node v14.20.0
                      Node v16.16.0
                      Node v18.5.0
                      ArnoD
                      #361
                      @tombox
                      Ok dann probier ich heute Abend mal Node v16.15.1
                        ArnoD
                        #362
                        @smartboart
                        Hast du auch das Problem, dass sich VIS Edit nicht mehr verbindet?
                        Ich kann an der View keine Änderungen mehr machen.
                        Ob das auch damit zusammenhängt?
                        • A ArnoD
                          @smartboart
                          smartboartS Offline
                          smartboartS Offline
                          smartboart
                          #363
                          @arnod sagte in Test Adapter Grünbeck v0.0.x:
                          @smartboart
                          Hi..Nein ich habe keine Probleme mit dem vis Editor...
                          • T tombox
                            Node v14.20.0
                            Node v16.16.0
                            Node v18.5.0
                            smartboartS Offline
                            smartboartS Offline
                            smartboart
                            #364
                            @tombox ok...super..immerhin ist es erklärbar..Danke für die Analyse unseres Problems. Ich hoffe wir finden dafür eine Lösung...
                            • T tombox
                              Node v14.20.0
                              Node v16.16.0
                              Node v18.5.0
                              smartboartS Offline
                              smartboartS Offline
                              smartboart
                              #365
                              @tombox besteht die Chance das im adapter zu entzerren und präziesere kürzere Abfragen zu starten? Eine Folge von requests nacheinander ...
                              An der gruenbeck kiste wird sich sicher nichts ändern.
                              Und ob die Node Entwickler hier handlungsbedarf sehen ist bestimmt fraglich oder?
                              • T tombox
                                Node v14.20.0
                                Node v16.16.0
                                Node v18.5.0
                                tombox
                                #366
                                @tombox Das hat nichts mit der schnellen Überlastung der Gruenbeck zu tun.
                                Jeder Antwort ob kurz oder lang von Gruenbeck ist laut NodeJS falsch und wird nicht akzeptiert.
                                • T tombox
                                  smartboartS Offline
                                  smartboartS Offline
                                  smartboart
                                  schrieb am zuletzt editiert von smartboart
                                  #367
                                  @tombox ok das ist natürlich bescheiden...über kurz oder lang wird die sc18 dann dumm? Issue eröffnen auf github zu dem Problem?
                                    tombox
                                    #368
                                    @smartboart Wir warten mal ab was nodejs sagt es wird wahrscheinlich nicht das einzige Gerät sein was nicht korrekte response zurück gibt und wenn dann gibt es immer ein workaround
                                    https://github.com/nodejs/node/issues/43798
                                    smartboartS Thomas BraunT 2 Antworten Letzte Antwort
                                    • T tombox
                                      smartboartS Offline
                                      smartboartS Offline
                                      smartboart
                                      #369
                                      @tombox super!
                                        ArnoD
                                        #370
                                        @tombox
                                        wie kann ich eine bestimmte Version von node installieren?
                                        curl -sL https://deb.nodesource.com/setup_16.15.1 | sudo -E bash -
                                        geht schon mal nicht.
                                        • A ArnoD
                                          @tombox
                                          tombox
                                          #371
                                          @arnod also setup_16.x bleibt der apt befehl müsste anders sein aber kann es leider nicht testen
                                          sudo apt install -y nodejs=16.15.1-deb-1nodesource1
                                          apt list --all-versions nodejs
                                          müsstest du alle versionen auflisten können
                                          da_WoodyD A 2 Antworten Letzte Antwort
