  3. Einsteigerfragen
  4. backitup kein Backup von iobroker
    5.6k
53 Beiträge 4 Kommentatoren 3.2k Aufrufe 3 Beobachtet
  • N Neuling mit großem Interesse
    @thomas-braun said in backitup kein Backup von iobroker:
    free -ht --mega
    login as: pi
    pi@192.168.178.73's password:
    Linux raspberrypi 5.15.32-v7l+ #1538 SMP Thu Mar 31 19:39:41 BST 2022 armv7l
    permitted by applicable law.
    Last login: Mon Jul 11 13:04:15 2022 from 192.168.178.32
    pi@raspberrypi:~ $ iobroker stop
    pi@raspberrypi:~ $ iobroker fix
    library: loaded
    Library version=2022-06-15
        Welcome to the ioBroker installation fixer!
        Script version: 2022-06-03
        You might need to enter your password a couple of times.
        Installing prerequisites (1/3)
    Holen:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
    OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
    OK:3 https://repos.influxdata.com/debian bullseye InRelease
    OK:4 https://packages.grafana.com/enterprise/deb stable InRelease
    OK:5 https://deb.nodesource.com/node_16.x bullseye InRelease
    Holen:6 https://download.sublimetext.com apt/stable/ InRelease [2.536 B]
    Es wurden 17,5 kB in 2 s geholt (10,7 kB/s).
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/3)
        Checking autostart (3/3)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@raspberrypi:~ $ iobroker start
    pi@raspberrypi:~ $ free -ht --mega
                  gesamt       benutzt     frei      gemns.  Puffer/Cache verf▒gbar
    Speicher:       7,9G        1,1G        3,9G        102M        2,9G        6,5G
    Swap:           1,0G          0B        1,0G
    Gesamt:         8,9G        1,1G        5,0G
    Speicher:       7,9G        2,2G        2,7G        102M        2,9G        5,6G
    Swap:           1,0G          0B        1,0G
    Gesamt:         8,9G        2,2G        3,8G
    pi@raspberrypi:~ $
    Ohne Erfolg
    [Started iobroker ...
    [DEBUG] [iobroker] - host.raspberrypi 11574 states saved
    [DEBUG] [iobroker] - host.raspberrypi 13365 objects saved
    [ERROR] [iobroker] -
    <--- Last few GCs --->
    [20040:0x402ffc8]    24847 ms: Mark-sweep (reduce) 586.3 (594.7) -> 586.3 (589.9) MB, 132.8 / 0.0 ms  (+ 0.0 ms in 0 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 2249 ms) (average mu = 0.964, current mu = 0.942) last [20040:0x402ffc8]    24932 ms: Mark-sweep (reduce) 586.3 (589.9) -> 586.2 (589.9) MB, 84.6 / 0.0 ms  (average mu = 0.945, current mu = 0.001) last resort GC in old space requested
    <--- JS stacktrace --->
    [ERROR] [iobroker] - FATAL ERROR: CALL_AND_RETRY_LAST Allocation failed - JavaScript heap out of memory
    [DEBUG] [iobroker] - done
    [DEBUG] [mysql] - MySql-Backup started ...
    [DEBUG] [mysql] - MySql File deleted!
    [DEBUG] [mysql] - MySql-Backup for is finish
    [DEBUG] [mysql] - done
    [DEBUG] [historyDB] - compress from historyDB started ...
    [DEBUG] [historyDB] - Backup created: /opt/iobroker/backups/historyDB_2022_07_11-13_40_18_backupiobroker.tar.gz
    [DEBUG] [historyDB] - done
    [DEBUG] [grafana] - Start Grafana Backup ...
    [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
    [DEBUG] [grafana] - Created dashboard directory
    [DEBUG] [grafana] - Created dashboards_manually_restore directory
    [DEBUG] [grafana] - Created datasource directory
    [DEBUG] [grafana] - start Grafana request ...
    [DEBUG] [grafana] - Grafana is available ... Status: 200
    [DEBUG] [grafana] - found Dashboard: duty-gate
    [DEBUG] [grafana] - found Dashboard: lux
    [DEBUG] [grafana] - found Dashboard: tomaten-bodentemperatur
    [DEBUG] [grafana] - found Dashboard: anwesenheit
    [DEBUG] [grafana] - found Dashboard: radieschen-lux
    [DEBUG] [grafana] - found Dashboard: pool
    [DEBUG] [grafana] - start Grafana backup compress ...
    [DEBUG] [grafana] - Backup created: /opt/iobroker/backups/grafana_2022_07_11-13_40_19_backupiobroker.tar.gz
    [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
    [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
    [DEBUG] [grafana] - done
    [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - found Script: Raspberry_Temperaturüberwachung
    [DEBUG] [javascripts] - found Script: Müll
    [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
    [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2022_07_11-13_40_25_backupiobroker.tar.gz
    [DEBUG] [javascripts] - done
    [DEBUG] [cifs] - used copy path: /media/usbstick
    [DEBUG] [cifs] - Copy iobroker_2022_07_11-13_39_50_backupiobroker.tar.gz...
    [ERROR] [cifs] - Error: ENOENT: no such file or directory, open '/opt/iobroker/backups/iobroker_2022_07_11-13_39_50_backupiobroker.tar.gz'
    [DEBUG] [cifs] - Copy mysql_2022_07_11-13_40_15_backupiobroker.tar.gz...
    [DEBUG] [cifs] - Copy historyDB_2022_07_11-13_40_18_backupiobroker.tar.gz...
    [DEBUG] [cifs] - Copy grafana_2022_07_11-13_40_19_backupiobroker.tar.gz...
    [DEBUG] [cifs] - Copy javascripts_2022_07_11-13_40_25_backupiobroker.tar.gz...
    [DEBUG] [cifs] - done
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [EXIT] 0](link url)
    @neuling-mit-großem-interesse sagte in backitup kein Backup von iobroker:
    Ohne Erfolg
    Was?
    bitte alles zeigen!
    Man weiß ja gar nicht wer da gerade was tut
    N 1 Antwort Letzte Antwort
      Ohne Erfolg
      Was?
      bitte alles zeigen!
      N Offline
      N Offline
      Hallo!
      Was meinst du mit alles zeigen?
      Wie mein Benutzername schon sagt... absoluter Neuling.... Welche Informationen werden benötigt?
        free -ht --mega
        login as: pi
        library: loaded
        Installed gcc-c++
        Autostart enabled!
        Swap:           1,0G          0B        1,0G
        Swap:           1,0G          0B        1,0G
        pi@raspberrypi:~ $
        Ohne Erfolg
        [EXIT] 0](link url)
        N Offline
        N Offline
        Auf die Frage hin was ist sublimetext.... Ich hatte einen texteditor instalieren wollen und dieser landete beim falschen benutzer... ist deinstaliert....
        Danach habe ich die obigen Schritte wiederholt...
        library: loaded
        OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
        OK:5 https://packages.grafana.com/enterprise/deb stable InRelease
        Installed gcc-c++
        Autostart enabled!
        Speicher:       7,9G        901M        5,1G         59M        1,9G        6,7G
        Swap:           1,0G          0B        1,0G
        Gesamt:         8,9G        901M        6,1G
        Speicher:       7,9G        1,6G        4,4G         59M        1,9G        6,0G
        Swap:           1,0G          0B        1,0G
        Gesamt:         8,9G        1,6G        5,4G
        pi@raspberrypi:~ $
        jetzt ist der texteditor nicht mehr teil des fixes...
        dann habe ich eine neu instanz von Backitup erstellt in der dann nur iobroker gesichert werden soll....
        alles ausser iobroker selber geht.
        [DEBUG] [iobroker] - host.raspberrypi 11599 states saved
        [DEBUG] [iobroker] - host.raspberrypi 13397 objects saved
        [32392:0x4fbafc8]    23688 ms: Mark-sweep (reduce) 586.4 (593.5) -> 586.4 (590.5) MB, 114.8 / 0.0 ms  (+ 0.0 ms in 0 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 2269 ms) (average mu = 0.970, current mu = 0.951) last [32392:0x4fbafc8]    23765 ms: Mark-sweep (reduce) 586.4 (590.5) -> 586.4 (589.8) MB, 77.4 / 0.0 ms  (average mu = 0.951, current mu = 0.001) last resort GC in old space requested
        [EXIT] 0
          library: loaded
          Installed gcc-c++
          Autostart enabled!
          Swap:           1,0G          0B        1,0G
          Swap:           1,0G          0B        1,0G
          pi@raspberrypi:~ $
          [EXIT] 0
          GlasfaserG Offline
          GlasfaserG Offline
          Warum fragst du in einem neuen Thread !?
          https://forum.iobroker.net/topic/56255/node-js-16x-und-alte-12x-gleichzeitig
          das ist doch der Screenshot von ganz oben von dir und betrifft doch diesen Thread
          @neuling-mit-großem-interesse sagte in Node.js 16x und alte 12x gleichzeitig?:
          ok Danke
          Ich bin auf der Suche nach möglichen Fehlern weshalb mein Backup nicht erstellt wird.
          Zeige mal :
          du -hs /opt/iobroker/iobroker-data/files/*
          • GlasfaserG Glasfaser
            ok Danke
            Zeige mal :
            N Offline
            N Offline
            @glasfaser
            Ich suche noch nach dem Fehler....Und da ich die node-js auch aktualisiert hatte dachte ich mir auch danach zu schauen bzw. zu Fragen...
            pi@raspberrypi:/opt/iobroker $ du -hs /opt/iobroker/iobroker-data/files/*
            8,0K    /opt/iobroker/iobroker-data/files/0_userdata.0
            252K    /opt/iobroker/iobroker-data/files/admin.admin
            1,2M    /opt/iobroker/iobroker-data/files/alexa2.admin
            420K    /opt/iobroker/iobroker-data/files/backitup.admin
            732K    /opt/iobroker/iobroker-data/files/ble.admin
            4,9M    /opt/iobroker/iobroker-data/files/daswetter.admin
            472K    /opt/iobroker/iobroker-data/files/discovery.admin
            908K    /opt/iobroker/iobroker-data/files/fb-checkpresence.admin
            1,4M    /opt/iobroker/iobroker-data/files/flot
            12K     /opt/iobroker/iobroker-data/files/flot.admin
            180K    /opt/iobroker/iobroker-data/files/history.admin
            64K     /opt/iobroker/iobroker-data/files/hm-rega
            160K    /opt/iobroker/iobroker-data/files/hm-rega.admin
            2,5M    /opt/iobroker/iobroker-data/files/hm-rpc.admin
            84K     /opt/iobroker/iobroker-data/files/ical.admin
            2,7M    /opt/iobroker/iobroker-data/files/info.admin
            32M     /opt/iobroker/iobroker-data/files/javascript.admin
            188K    /opt/iobroker/iobroker-data/files/node-red.admin
            104K    /opt/iobroker/iobroker-data/files/pushover.admin
            48K     /opt/iobroker/iobroker-data/files/ring.admin
            48K     /opt/iobroker/iobroker-data/files/rpi2.admin
            76K     /opt/iobroker/iobroker-data/files/smartgarden.admin
            224K    /opt/iobroker/iobroker-data/files/sql.admin
            68K     /opt/iobroker/iobroker-data/files/tankerkoenig.admin
            188K    /opt/iobroker/iobroker-data/files/trashschedule.admin
            7,0M    /opt/iobroker/iobroker-data/files/vis
            488K    /opt/iobroker/iobroker-data/files/vis.0
            52K     /opt/iobroker/iobroker-data/files/vis.admin
            7,9M    /opt/iobroker/iobroker-data/files/web
            5,7M    /opt/iobroker/iobroker-data/files/web.admin
            N GlasfaserG 2 Antworten Letzte Antwort
              @glasfaser
              N Offline
              N Offline
              Ordnergröße 1,8 GB
                @glasfaser
                GlasfaserG Offline
                GlasfaserG Offline
                Ja das ist mir klar ...
                Du bekommst doch schon hier im Thread Hilfe .
                das wäre genauso , als würdest du nach Spanien fliegen und dort nach deinem Problem suchen ... aber dort sind andere User .... und das ganze fängt von neuen an.
                So bleibt dein ( Problem ) erstmal für alle an einem Ort !
                  N Offline
                  N Offline
                  @glasfaser
                  ok
                    @glasfaser
                    ok
                    N Offline
                    N Offline
                    Ich sehe gerade das in dem Unterordner backup-objects alleine 600MB Dateien sind.
                    states und objects.jsonl.gz
                    vom 09.07.2022 bis heute
                      Wie groß sind die?
                      Hier sind die äußerst übersichtlich kompakt.
                      ncdu 1.15.1 ~ Use the arrow keys to navigate, press ? for help        --- /opt/iobroker/iobroker-data/backup-objects -------------------------------------------------------------------------------------------------------------
                                               /..        4.0 MiB [##########]  2022-07-11_15-38_objects.jsonl.gz
                          4.0 MiB [##########]  2022-07-11_13-38_objects.jsonl.gz
                          4.0 MiB [##########]  2022-07-11_17-38_objects.jsonl.gz
                          4.0 MiB [######### ]  2022-07-11_09-38_objects.jsonl.gz
                          4.0 MiB [######### ]  2022-07-11_05-38_objects.jsonl.gz
                          4.0 MiB [######### ]  2022-07-11_11-38_objects.jsonl.gz
                          4.0 MiB [######### ]  2022-07-11_01-38_objects.jsonl.gz
                          4.0 MiB [######### ]  2022-07-11_07-38_objects.jsonl.gz
                          4.0 MiB [######### ]  2022-07-11_03-38_objects.jsonl.gz
                          4.0 MiB [######### ]  2022-07-10_21-38_objects.jsonl.gz
                          4.0 MiB [######### ]  2022-07-10_19-38_objects.jsonl.gz
                          4.0 MiB [######### ]  2022-07-09_21-04_objects.jsonl.gz
                          4.0 MiB [######### ]  2022-07-10_01-04_objects.jsonl.gz
                          4.0 MiB [######### ]  2022-07-09_23-04_objects.jsonl.gz
                          4.0 MiB [######### ]  2022-07-10_03-04_objects.jsonl.gz
                          4.0 MiB [######### ]  2022-07-10_07-04_objects.jsonl.gz
                          4.0 MiB [######### ]  2022-07-10_09-04_objects.jsonl.gz
                          4.0 MiB [######### ]  2022-07-10_05-04_objects.jsonl.gz
                          4.0 MiB [######### ]  2022-07-10_12-53_objects.jsonl.gz
                          4.0 MiB [######### ]  2022-07-10_14-53_objects.jsonl.gz
                          4.0 MiB [######### ]  2022-07-10_16-53_objects.jsonl.gz
                          3.9 MiB [######### ]  2022-07-10_23-38_objects.jsonl.gz
                          3.9 MiB [######### ]  2022-07-09_17-04_objects.jsonl.gz
                          3.9 MiB [######### ]  2022-07-09_19-04_objects.jsonl.gz
                        348.0 KiB [          ]  2022-07-10_09-04_states.jsonl.gz
                        348.0 KiB [          ]  2022-07-11_17-38_states.jsonl.gz
                        344.0 KiB [          ]  2022-07-10_03-04_states.jsonl.gz
                        344.0 KiB [          ]  2022-07-10_21-38_states.jsonl.gz
                        344.0 KiB [          ]  2022-07-10_19-38_states.jsonl.gz
                        344.0 KiB [          ]  2022-07-11_03-38_states.jsonl.gz
                        344.0 KiB [          ]  2022-07-10_16-53_states.jsonl.gz
                        344.0 KiB [          ]  2022-07-10_12-53_states.jsonl.gz
                        344.0 KiB [          ]  2022-07-10_14-53_states.jsonl.gz
                        344.0 KiB [          ]  2022-07-11_15-38_states.jsonl.gz
                        344.0 KiB [          ]  2022-07-10_07-04_states.jsonl.gz
                        344.0 KiB [          ]  2022-07-09_23-04_states.jsonl.gz
                      • GlasfaserG Offline
                        GlasfaserG Offline
                        127.0.0.1:39240
                        127.0.0.1:33942
                        Zeige mal
                        iobroker setup custom
                          127.0.0.1:39240
                          127.0.0.1:33942
                          Zeige mal
                          N Offline
                          N Offline
                          @glasfaser said in backitup kein Backup von iobroker:
                          pi@raspberrypi:/opt/iobroker/iobroker-data/backup-objects $ iobroker setup custom
                          Current configuration:
                          - Objects database:
                            - Type: jsonl
                            - Host/Unix Socket: 127.0.0.1
                            - Port: 9001
                          - States database:
                            - Type: jsonl
                            - Port: 9000
                          - Data Directory: ../../iobroker-data/
                          Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]:
                            - Objects database:
                              - Type: jsonl
                              - Port: 9001
                            - States database:
                              - Type: jsonl
                              - Port: 9000
                            N Offline
                            N Offline
                            dieses Fenster?
                            Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                              dieses Fenster?
                              Hier läuft das auf 0.0.0.0. , nicht auf localhost
                              - Objects database:
                                - Type: jsonl
                                - Host/Unix Socket: 0.0.0.0
                                - Port: 9001
                              - States database:
                                - Type: jsonl
                                - Port: 9000
                                dieses Fenster?
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Ausgabe von
                                netstat -n -a
                                  Ausgabe von
                                  netstat -n -a
                                  N Offline
                                  N Offline
                                  @glasfaser
                                  pi@raspberrypi:/opt/iobroker/iobroker-data/backup-objects $ ls -l
                                  insgesamt 622444
                                  -rw-rwxr--+ 1 iobroker iobroker  2354586  9. Jul 04:29 2022-07-09_04-29_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 26002233  9. Jul 04:29 2022-07-09_04-29_states.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker  2354600  9. Jul 06:29 2022-07-09_06-29_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 26001930  9. Jul 06:30 2022-07-09_06-29_states.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker  2354574  9. Jul 08:29 2022-07-09_08-29_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 26001812  9. Jul 08:29 2022-07-09_08-29_states.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker  2354588  9. Jul 10:29 2022-07-09_10-29_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 26001885  9. Jul 10:29 2022-07-09_10-29_states.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker  2354693  9. Jul 12:29 2022-07-09_12-29_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 26001719  9. Jul 12:30 2022-07-09_12-29_states.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker  2357008  9. Jul 14:29 2022-07-09_14-29_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 26001491  9. Jul 14:30 2022-07-09_14-29_states.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker  2357011  9. Jul 16:29 2022-07-09_16-29_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 26001920  9. Jul 16:30 2022-07-09_16-29_states.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker  2358936  9. Jul 21:40 2022-07-09_21-40_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 26002780  9. Jul 21:40 2022-07-09_21-40_states.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker  2359193  9. Jul 23:40 2022-07-09_23-40_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 26002528  9. Jul 23:41 2022-07-09_23-40_states.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker  2360125 10. Jul 01:40 2022-07-10_01-40_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 26002230 10. Jul 01:40 2022-07-10_01-40_states.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker  2360239 10. Jul 03:40 2022-07-10_03-40_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 24769257 10. Jul 03:41 2022-07-10_03-40_states.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker  2362730 10. Jul 05:40 2022-07-10_05-40_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 22743471 10. Jul 05:40 2022-07-10_05-40_states.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker  2363056 10. Jul 07:40 2022-07-10_07-40_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 22743526 10. Jul 07:41 2022-07-10_07-40_states.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker  2363063 10. Jul 09:40 2022-07-10_09-40_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 22744250 10. Jul 09:40 2022-07-10_09-40_states.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker  2363058 10. Jul 11:40 2022-07-10_11-40_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 22745078 10. Jul 11:40 2022-07-10_11-40_states.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker  2363384 10. Jul 13:40 2022-07-10_13-40_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 22744725 10. Jul 13:40 2022-07-10_13-40_states.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker  2363967 10. Jul 17:21 2022-07-10_17-21_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 22760736 10. Jul 17:22 2022-07-10_17-21_states.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker  2369971 10. Jul 19:54 2022-07-10_19-54_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 22764209 10. Jul 19:55 2022-07-10_19-54_states.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker  2369837 11. Jul 01:16 2022-07-11_01-16_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 22752844 11. Jul 01:17 2022-07-11_01-16_states.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker  2372027 11. Jul 03:40 2022-07-11_03-40_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 22753286 11. Jul 03:40 2022-07-11_03-40_states.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker  2368272 11. Jul 07:09 2022-07-11_07-09_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 22765515 11. Jul 07:10 2022-07-11_07-09_states.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker  2368266 11. Jul 09:09 2022-07-11_09-09_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 22765469 11. Jul 09:10 2022-07-11_09-09_states.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker  2368260 11. Jul 11:09 2022-07-11_11-09_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 22765283 11. Jul 11:10 2022-07-11_11-09_states.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker  2370627 11. Jul 13:09 2022-07-11_13-09_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 22765295 11. Jul 13:10 2022-07-11_13-09_states.jsonl.gz
                                    @glasfaser
                                    insgesamt 622444
                                    N Offline
                                    N Offline
                                    pi@raspberrypi:/opt/iobroker/iobroker-data/backup-objects $ netstat -n -a
                                    Aktive Internetverbindungen (Server und stehende Verbindungen)
                                    Proto Recv-Q Send-Q Local Address           Foreign Address         State
                                    tcp        0      0 192.168.178.73:2072     0.0.0.0:*               LISTEN
                                    tcp        0      0 192.168.178.73:2073     0.0.0.0:*               LISTEN
                                    tcp        0      0 192.168.178.73:42000    0.0.0.0:*               LISTEN
                                    tcp        0      0 192.168.178.73:42001    0.0.0.0:*               LISTEN
                                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN
                                    tcp        0      0 192.168.178.73:49292    0.0.0.0:*               LISTEN
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
                                    tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN
                                    tcp        0      0 192.168.178.73:1880     0.0.0.0:*               LISTEN
                                    tcp        0      0 192.168.178.73:8701     0.0.0.0:*               LISTEN
                                    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36732         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34718         TIME_WAIT
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36692         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36700         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36680         VERBUNDEN
                                    tcp        0      0 127.0.0.1:33936         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36744         VERBUNDEN
                                    tcp        0      0 127.0.0.1:34000         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34058         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33958         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36796         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36650         VERBUNDEN
                                    tcp        0      0 192.168.178.73:45496    192.168.178.47:2000     TIME_WAIT
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34060         VERBUNDEN
                                    tcp        0      0 192.168.178.73:2073     192.168.178.47:42118    TIME_WAIT
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36672         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36810         VERBUNDEN
                                    tcp        0      0 127.0.0.1:34036         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34004         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36770         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33992         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36646         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36712         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36764         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33980         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33904         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36752         VERBUNDEN
                                    tcp        0      0 127.0.0.1:33950         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:37456         TIME_WAIT
                                    tcp        0      0 127.0.0.1:36624         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36784         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36700         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33898         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36702         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36668         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36666         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33964         VERBUNDEN
                                    tcp        0      0 127.0.0.1:34042         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33912         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33946         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36636         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33950         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34054         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36802         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34076         VERBUNDEN
                                    tcp        0      0 127.0.0.1:45413         127.0.0.1:39500         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36726         VERBUNDEN
                                    tcp        0      0 127.0.0.1:34044         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33928         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36642         VERBUNDEN
                                    tcp        0      0 192.168.178.73:45506    192.168.178.47:2000     TIME_WAIT
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34064         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36688         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36744         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36756         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33996         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34038         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34066         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36638         VERBUNDEN
                                    tcp        0      0 127.0.0.1:34032         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36696         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34720         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36812         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36812         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36800         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33974         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36632         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36798         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34724         VERBUNDEN
                                    tcp        0      0 192.168.178.73:46670    192.168.178.47:2010     TIME_WAIT
                                    tcp        0      0 127.0.0.1:33924         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36740         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33898         VERBUNDEN
                                    tcp        0      0 127.0.0.1:33974         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36656         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36752         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33920         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33938         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34002         VERBUNDEN
                                    tcp        0      0 192.168.178.73:2073     192.168.178.47:42040    TIME_WAIT
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36704         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36784         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33976         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 192.168.178.73:45450    52.94.232.230:443       VERBUNDEN
                                    tcp        0      0 192.168.178.73:34896    52.31.56.250:443        VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36656         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36626         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36772         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33928         VERBUNDEN
                                    tcp        0      0 192.168.178.73:34894    52.31.56.250:443        TIME_WAIT
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33908         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33972         VERBUNDEN
                                    tcp        0      0 127.0.0.1:34072         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36756         VERBUNDEN
                                    tcp        0      0 192.168.178.73:42001    192.168.178.47:47472    VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36772         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36814         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33934         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34068         VERBUNDEN
                                    tcp        0      0 127.0.0.1:34066         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33982         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33978         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33922         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33968         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34078         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36690         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34036         VERBUNDEN
                                    tcp        0      0 127.0.0.1:33896         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36794         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36726         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33984         VERBUNDEN
                                    tcp        0      0 192.168.178.73:53988    192.168.178.47:8701     VERBUNDEN
                                    tcp        0      0 127.0.0.1:34018         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36620         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33956         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:34722         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33938         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36724         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36716         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33968         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36776         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33948         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:37452         TIME_WAIT
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36728         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36798         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:34062         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33896         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33994         VERBUNDEN
                                    tcp        0      0 127.0.0.1:33940         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33902         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36672         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33970         VERBUNDEN
                                    tcp        0      0 127.0.0.1:33930         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36754         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:37462         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33914         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36776         VERBUNDEN
                                    tcp        0      0 127.0.0.1:34006         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36674         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36768         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33894         VERBUNDEN
                                    tcp        0      0 127.0.0.1:33994         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:34038         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36644         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36694         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36660         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36648         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33910         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:37450         TIME_WAIT
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34006         VERBUNDEN
                                    tcp        0      0 127.0.0.1:33892         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36690         VERBUNDEN
                                    tcp        0      0 127.0.0.1:37462         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33924         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36652         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34716         TIME_WAIT
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36792         VERBUNDEN
                                    tcp        0      0 127.0.0.1:33960         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 192.168.178.73:36812    108.177.15.188:5228     VERBUNDEN
                                    tcp        0      0 127.0.0.1:33926         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33962         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33942         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36646         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36652         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33948         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33966         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36676         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36800         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36708         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33952         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36714         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36674         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 192.168.178.73:2010     192.168.178.47:59574    TIME_WAIT
                                    tcp        0      0 127.0.0.1:36706         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36810         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36734         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36660         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33964         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34022         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36624         VERBUNDEN
                                    tcp        0      0 192.168.178.73:2010     192.168.178.47:59410    TIME_WAIT
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34008         VERBUNDEN
                                    tcp        0      0 192.168.178.73:2010     192.168.178.47:59532    TIME_WAIT
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34044         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36782         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36738         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36648         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:37460         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36684         127.0.0.1:9000          VERBUNDEN
                                    tcp        0  11360 192.168.178.73:22       192.168.178.32:54464    VERBUNDEN
                                    tcp        0      0 127.0.0.1:33966         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36754         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33998         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33912         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36664         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33962         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36682         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33888         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:34040         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:34720         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36658         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36766         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34714         TIME_WAIT
                                    tcp        0      0 127.0.0.1:36688         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33970         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36680         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34046         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36692         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36728         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36644         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33916         VERBUNDEN
                                    tcp        0      0 192.168.178.73:45448    52.94.232.230:443       VERBUNDEN
                                    tcp        0      0 192.168.178.73:2073     192.168.178.47:42042    TIME_WAIT
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36682         VERBUNDEN
                                    tcp        0      0 127.0.0.1:34060         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36808         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36730         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33922         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36640         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36796         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34062         VERBUNDEN
                                    tcp        0      0 192.168.178.73:2073     192.168.178.47:42208    VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34056         VERBUNDEN
                                    tcp        0      0 127.0.0.1:34022         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36712         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33918         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36806         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33934         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34034         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36686         VERBUNDEN
                                    tcp        0      0 127.0.0.1:33914         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33952         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36724         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36654         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36770         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33936         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36694         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36730         VERBUNDEN
                                    tcp        0      0 192.168.178.73:41516    34.120.160.131:443      VERBUNDEN
                                    tcp        0      0 127.0.0.1:36792         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36620         VERBUNDEN
                                    tcp        0      0 127.0.0.1:33984         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33932         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36802         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36698         VERBUNDEN
                                    tcp        0      0 127.0.0.1:34054         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36738         VERBUNDEN
                                    tcp        0      0 127.0.0.1:33916         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36628         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33890         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34072         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33980         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36708         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34042         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36702         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33940         VERBUNDEN
                                    tcp        0      0 127.0.0.1:34724         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 192.168.178.73:2073     192.168.178.47:42198    VERBUNDEN
                                    tcp        0      0 127.0.0.1:33944         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:34002         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33942         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 192.168.178.73:2073     192.168.178.47:42166    TIME_WAIT
                                    tcp        0      0 127.0.0.1:34016         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36780         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36662         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36698         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 192.168.178.73:45502    192.168.178.47:2000     TIME_WAIT
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33932         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33976         VERBUNDEN
                                    tcp        0      0 127.0.0.1:33904         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36782         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36634         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36664         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36710         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:34056         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36732         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34032         VERBUNDEN
                                    tcp        0      0 127.0.0.1:33998         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36638         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36734         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33906         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36766         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36794         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:34034         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:34078         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33978         VERBUNDEN
                                    tcp        0      0 127.0.0.1:33958         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36668         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33910         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36662         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:34004         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33992         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36804         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36768         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36666         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:33972         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36716         VERBUNDEN
                                    tcp        0      0 127.0.0.1:33906         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34000         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33890         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33926         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36654         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33888         VERBUNDEN
                                    tcp        0      0 192.168.178.73:45500    192.168.178.47:2000     TIME_WAIT
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36814         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33892         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36808         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34016         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36806         VERBUNDEN
                                    tcp        0      0 127.0.0.1:34030         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36658         VERBUNDEN
                                    tcp        0      0 127.0.0.1:34008         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34070         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36804         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34030         VERBUNDEN
                                    tcp        0      0 192.168.178.73:45504    192.168.178.47:2000     TIME_WAIT
                                    tcp        0      0 127.0.0.1:33996         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33918         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36622         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36764         VERBUNDEN
                                    tcp        0      0 192.168.178.73:53990    192.168.178.47:8701     VERBUNDEN
                                    tcp        0    159 127.0.0.1:36696         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:37458         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36670         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33946         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36710         VERBUNDEN
                                    tcp        0      0 127.0.0.1:34070         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36636         VERBUNDEN
                                    tcp        0      0 192.168.178.73:2010     192.168.178.47:59450    TIME_WAIT
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33902         VERBUNDEN
                                    tcp        0      0 127.0.0.1:34068         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34722         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36714         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33956         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36780         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36634         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36628         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36686         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 192.168.178.73:2010     192.168.178.47:59618    VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36626         VERBUNDEN
                                    tcp        0      0 127.0.0.1:34058         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 192.168.178.73:45498    192.168.178.47:2000     TIME_WAIT
                                    tcp        0      0 192.168.178.73:2073     192.168.178.47:42204    VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33920         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36704         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34018         VERBUNDEN
                                    tcp        0      0 127.0.0.1:36740         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36670         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33930         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33960         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36706         VERBUNDEN
                                    tcp        0      0 127.0.0.1:34064         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:39500         127.0.0.1:45413         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36684         VERBUNDEN
                                    tcp        0      0 127.0.0.1:34046         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36676         VERBUNDEN
                                    tcp        0      0 127.0.0.1:33894         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33982         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:36622         VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:34040         VERBUNDEN
                                    tcp        0      0 127.0.0.1:33908         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 192.168.178.73:2073     192.168.178.47:41998    TIME_WAIT
                                    tcp        0      0 127.0.0.1:9000          127.0.0.1:37458         VERBUNDEN
                                    tcp        0      0 192.168.178.73:51988    52.46.148.49:443        VERBUNDEN
                                    tcp        0      0 127.0.0.1:36650         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36642         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:34076         127.0.0.1:9001          VERBUNDEN
                                    tcp        0      0 127.0.0.1:37460         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36640         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:36632         127.0.0.1:9000          VERBUNDEN
                                    tcp        0      0 127.0.0.1:9001          127.0.0.1:33944         VERBUNDEN
                                    tcp6       0      0 :::3306                 :::*                    LISTEN
                                    tcp6       0      0 ::1:3350                :::*                    LISTEN
                                    tcp6       0      0 :::22                   :::*                    LISTEN
                                    tcp6       0      0 :::8082                 :::*                    LISTEN
                                    tcp6       0      0 :::8081                 :::*                    LISTEN
                                    tcp6       0      0 :::3456                 :::*                    LISTEN
                                    tcp6       0      0 :::3000                 :::*                    LISTEN
                                    tcp6       0      0 ::1:631                 :::*                    LISTEN
                                    tcp6       0      0 :::5900                 :::*                    LISTEN
                                    tcp6       0      0 :::3389                 :::*                    LISTEN
                                    tcp6       0      0 127.0.0.1:3306          127.0.0.1:56886         TIME_WAIT
                                    tcp6       0      0 127.0.0.1:3306          127.0.0.1:56888         TIME_WAIT
                                    tcp6       0      0 127.0.0.1:3306          127.0.0.1:56884         TIME_WAIT
                                    tcp6       0      0 127.0.0.1:3306          127.0.0.1:56904         TIME_WAIT
                                    tcp6       0      0 127.0.0.1:3306          127.0.0.1:56906         TIME_WAIT
                                    tcp6       0      0 127.0.0.1:3306          127.0.0.1:56882         TIME_WAIT
                                    tcp6       0      0 127.0.0.1:3306          127.0.0.1:56900         TIME_WAIT
                                    tcp6       0      0 127.0.0.1:3306          127.0.0.1:56908         TIME_WAIT
                                    tcp6       0      0 192.168.178.73:8081     192.168.178.32:54275    VERBUNDEN
                                    tcp6       0      0 127.0.0.1:3306          127.0.0.1:56902         TIME_WAIT
                                    tcp6       0      0 127.0.0.1:3306          127.0.0.1:56914         TIME_WAIT
                                    tcp6       0      0 127.0.0.1:3306          127.0.0.1:56896         TIME_WAIT
                                    tcp6       0      0 127.0.0.1:3306          127.0.0.1:56894         TIME_WAIT
                                    tcp6       0      0 127.0.0.1:3306          127.0.0.1:56898         TIME_WAIT
                                    tcp6       0      0 127.0.0.1:3306          127.0.0.1:56892         TIME_WAIT
                                    tcp6       0      0 127.0.0.1:3306          127.0.0.1:56912         TIME_WAIT
                                    tcp6       0      0 127.0.0.1:3306          127.0.0.1:56890         TIME_WAIT
                                    tcp6       0      0 127.0.0.1:3306          127.0.0.1:56910         TIME_WAIT
                                    udp        0      0 0.0.0.0:631             0.0.0.0:*
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*
                                    udp        0      0 0.0.0.0:43789           0.0.0.0:*
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*
                                    udp6       0      0 :::5353                 :::*
                                    udp6       0      0 :::56281                :::*
                                    udp6       0      0 :::546                  :::*
                                    raw6       0      0 :::58                   :::*                    7
                                    Aktive Sockets in der UNIX-Dom▒ne (Server und stehende Verbindungen)
                                    Proto RefCnt Flags       Type       State         I-Node   Pfad
                                    unix  2      [ ACC ]     STREAM     H▒RT          19669    /tmp/ssh-M6Mxd0vkZRe3/agent.1331
                                    unix  2      [ ACC ]     STREAM     H▒RT          15400    /tmp/.vnc-vncservice/vncserver-x11.CtrlComms
                                    unix  2      [ ]         DGRAM      VERBUNDEN     17274    /tmp/dhcpcd-pi/libdhcpcd-wpa-1324.0
                                    unix  2      [ ]         DGRAM      VERBUNDEN     17275    /tmp/dhcpcd-pi/libdhcpcd-wpa-1324.1
                                    unix  2      [ ]         DGRAM                    15356    /run/user/1000/systemd/notify
                                    unix  2      [ ACC ]     STREAM     H▒RT          15359    /run/user/1000/systemd/private
                                    unix  2      [ ACC ]     STREAM     H▒RT          19461    /run/user/1000/bus
                                    unix  2      [ ACC ]     STREAM     H▒RT          19463    /run/user/1000/gnupg/S.dirmngr
                                    unix  2      [ ACC ]     STREAM     H▒RT          19465    /run/user/1000/gnupg/S.gpg-agent.browser
                                    unix  2      [ ACC ]     STREAM     H▒RT          19467    /run/user/1000/gnupg/S.gpg-agent.extra
                                    unix  2      [ ACC ]     STREAM     H▒RT          13753    @/tmp/.X11-unix/X0
                                    unix  2      [ ACC ]     STREAM     H▒RT          19469    /run/user/1000/gnupg/S.gpg-agent.ssh
                                    unix  2      [ ACC ]     STREAM     H▒RT          19471    /run/user/1000/gnupg/S.gpg-agent
                                    unix  4      [ ]         DGRAM      VERBUNDEN     10817    /run/systemd/notify
                                    unix  2      [ ACC ]     STREAM     H▒RT          19473    /run/user/1000/pipewire-0
                                    unix  2      [ ACC ]     STREAM     H▒RT          10820    /run/systemd/private
                                    unix  2      [ ACC ]     STREAM     H▒RT          19475    /run/user/1000/pk-debconf-socket
                                    unix  2      [ ACC ]     STREAM     H▒RT          10822    /run/systemd/userdb/io.systemd.DynamicUser
                                    unix  2      [ ACC ]     STREAM     H▒RT          19477    /run/user/1000/pulse/native
                                    unix  2      [ ACC ]     STREAM     H▒RT          10823    /run/systemd/io.system.ManagedOOM
                                    unix  2      [ ACC ]     STREAM     H▒RT          19479    /run/user/1000/snapd-session-agent.socket
                                    unix  2      [ ]         DGRAM                    10831    /run/systemd/journal/syslog
                                    unix  2      [ ACC ]     STREAM     H▒RT          10833    /run/systemd/fsck.progress
                                    unix  21     [ ]         DGRAM      VERBUNDEN     10838    /run/systemd/journal/dev-log
                                    unix  7      [ ]         DGRAM      VERBUNDEN     10840    /run/systemd/journal/socket
                                    unix  2      [ ACC ]     STREAM     H▒RT          10842    /run/systemd/journal/stdout
                                    unix  2      [ ACC ]     SEQPAKET   H▒RT          10844    /run/udev/control
                                    unix  2      [ ACC ]     STREAM     H▒RT          17807    /run/user/1000/pcmanfm-socket--0
                                    unix  2      [ ACC ]     STREAM     H▒RT          19819    /run/user/1000/menu-cached-:0
                                    unix  2      [ ACC ]     STREAM     H▒RT          10895    /run/systemd/journal/io.systemd.journal
                                    unix  2      [ ACC ]     STREAM     H▒RT          14353    /run/avahi-daemon/socket
                                    unix  2      [ ACC ]     STREAM     H▒RT          14355    /run/cups/cups.sock
                                    unix  2      [ ACC ]     STREAM     H▒RT          14357    /run/dbus/system_bus_socket
                                    unix  2      [ ACC ]     STREAM     H▒RT          14359    /run/snapd.socket
                                    unix  2      [ ACC ]     STREAM     H▒RT          14361    /run/snapd-snap.socket
                                    unix  2      [ ACC ]     STREAM     H▒RT          14363    /run/thd.socket
                                    unix  2      [ ACC ]     STREAM     H▒RT          13522    /run/dhcpcd.sock
                                    unix  2      [ ACC ]     STREAM     H▒RT          13523    /run/dhcpcd.unpriv.sock
                                    unix  4      [ ]         DGRAM      VERBUNDEN     13722    /var/run/wpa_supplicant/wlan0
                                    unix  2      [ ]         DGRAM                    12102    /var/run/wpa_supplicant/p2p-dev-wlan0
                                    unix  2      [ ACC ]     STREAM     H▒RT          19693    @/tmp/dbus-w8ByxioP3U
                                    unix  2      [ ACC ]     STREAM     H▒RT          12199    /run/mysqld/mysqld.sock
                                    unix  2      [ ]         DGRAM      VERBUNDEN     13250    /tmp/.vncserver-license/0.574
                                    unix  2      [ ACC ]     STREAM     H▒RT          13754    /tmp/.X11-unix/X0
                                    unix  2      [ ACC ]     STREAM     H▒RT          17735    /tmp/ssh-aPulhHMVd1rL/agent.1232
                                    unix  3      [ ]         STREAM     VERBUNDEN     23114
                                    unix  3      [ ]         STREAM     VERBUNDEN     10948
                                    unix  3      [ ]         STREAM     VERBUNDEN     17238
                                    unix  3      [ ]         STREAM     VERBUNDEN     19833
                                    unix  2      [ ]         DGRAM                    18532
                                    unix  3      [ ]         STREAM     VERBUNDEN     144719
                                    unix  3      [ ]         STREAM     VERBUNDEN     22356
                                    unix  3      [ ]         STREAM     VERBUNDEN     23057
                                    unix  3      [ ]         STREAM     VERBUNDEN     22625
                                    unix  3      [ ]         STREAM     VERBUNDEN     18690    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     17357    /run/user/1000/menu-cached-:0
                                    unix  3      [ ]         STREAM     VERBUNDEN     19507    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     17648    /run/user/1000/bus
                                    unix  3      [ ]         STREAM     VERBUNDEN     19661    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     17293    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     15695
                                    unix  3      [ ]         STREAM     VERBUNDEN     18160
                                    unix  3      [ ]         STREAM     VERBUNDEN     13685    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     24682
                                    unix  3      [ ]         STREAM     VERBUNDEN     17271
                                    unix  3      [ ]         STREAM     VERBUNDEN     17178
                                    unix  3      [ ]         STREAM     VERBUNDEN     12140
                                    unix  3      [ ]         STREAM     VERBUNDEN     21927
                                    unix  3      [ ]         STREAM     VERBUNDEN     17959
                                    unix  3      [ ]         STREAM     VERBUNDEN     13221    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     24731
                                    unix  2      [ ]         DGRAM      VERBUNDEN     14253
                                    unix  3      [ ]         STREAM     VERBUNDEN     22015
                                    unix  3      [ ]         STREAM     VERBUNDEN     14375
                                    unix  3      [ ]         STREAM     VERBUNDEN     23361
                                    unix  3      [ ]         STREAM     VERBUNDEN     24175
                                    unix  3      [ ]         STREAM     VERBUNDEN     23001
                                    unix  3      [ ]         STREAM     VERBUNDEN     20277
                                    unix  3      [ ]         STREAM     VERBUNDEN     17234
                                    unix  3      [ ]         STREAM     VERBUNDEN     22407
                                    unix  3      [ ]         STREAM     VERBUNDEN     24327
                                    unix  2      [ ]         DGRAM      VERBUNDEN     13674
                                    unix  3      [ ]         STREAM     VERBUNDEN     19357
                                    unix  3      [ ]         STREAM     VERBUNDEN     17834
                                    unix  3      [ ]         STREAM     VERBUNDEN     16006    @/tmp/.X11-unix/X0
                                    unix  3      [ ]         STREAM     VERBUNDEN     144718
                                    unix  3      [ ]         STREAM     VERBUNDEN     22510
                                    unix  3      [ ]         STREAM     VERBUNDEN     15232
                                    unix  3      [ ]         STREAM     VERBUNDEN     23059
                                    unix  3      [ ]         STREAM     VERBUNDEN     17225
                                    unix  3      [ ]         STREAM     VERBUNDEN     17539
                                    unix  3      [ ]         STREAM     VERBUNDEN     18162
                                    unix  3      [ ]         STREAM     VERBUNDEN     17270
                                    unix  3      [ ]         STREAM     VERBUNDEN     17925
                                    unix  2      [ ]         DGRAM      VERBUNDEN     18623
                                    unix  2      [ ]         DGRAM      VERBUNDEN     14576
                                    unix  3      [ ]         STREAM     VERBUNDEN     13116
                                    unix  3      [ ]         STREAM     VERBUNDEN     17893
                                    unix  3      [ ]         STREAM     VERBUNDEN     17017
                                    unix  3      [ ]         STREAM     VERBUNDEN     13718    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     24204
                                    unix  3      [ ]         STREAM     VERBUNDEN     18122
                                    unix  2      [ ]         DGRAM                    17650
                                    unix  3      [ ]         STREAM     VERBUNDEN     14453
                                    unix  3      [ ]         STREAM     VERBUNDEN     20251
                                    unix  3      [ ]         DGRAM      VERBUNDEN     15092
                                    unix  3      [ ]         STREAM     VERBUNDEN     24733
                                    unix  3      [ ]         STREAM     VERBUNDEN     22293
                                    unix  3      [ ]         STREAM     VERBUNDEN     18670
                                    unix  3      [ ]         STREAM     VERBUNDEN     19565
                                    unix  2      [ ]         DGRAM      VERBUNDEN     18827
                                    unix  3      [ ]         STREAM     VERBUNDEN     16986
                                    unix  3      [ ]         STREAM     VERBUNDEN     16922
                                    unix  3      [ ]         STREAM     VERBUNDEN     14590
                                    unix  3      [ ]         STREAM     VERBUNDEN     13025
                                    unix  3      [ ]         STREAM     VERBUNDEN     16009    @/tmp/.X11-unix/X0
                                    unix  3      [ ]         STREAM     VERBUNDEN     19574
                                    unix  3      [ ]         STREAM     VERBUNDEN     12036
                                    unix  3      [ ]         DGRAM      VERBUNDEN     14089
                                    unix  2      [ ]         STREAM     VERBUNDEN     142108
                                    unix  3      [ ]         STREAM     VERBUNDEN     18830    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     14442    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     13747    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     13249
                                    unix  3      [ ]         STREAM     VERBUNDEN     16882    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     22457
                                    unix  3      [ ]         STREAM     VERBUNDEN     17263
                                    unix  3      [ ]         STREAM     VERBUNDEN     19844    /run/user/1000/bus
                                    unix  3      [ ]         DGRAM      VERBUNDEN     15093
                                    unix  3      [ ]         STREAM     VERBUNDEN     22454
                                    unix  3      [ ]         STREAM     VERBUNDEN     15122    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     13120
                                    unix  3      [ ]         STREAM     VERBUNDEN     14438
                                    unix  2      [ ]         DGRAM      VERBUNDEN     13532
                                    unix  3      [ ]         STREAM     VERBUNDEN     24203
                                    unix  3      [ ]         STREAM     VERBUNDEN     20246    /run/user/1000/bus
                                    unix  2      [ ]         DGRAM      VERBUNDEN     15331
                                    unix  3      [ ]         STREAM     VERBUNDEN     13675    /run/dbus/system_bus_socket
                                    unix  2      [ ]         DGRAM      VERBUNDEN     15323
                                    unix  3      [ ]         STREAM     VERBUNDEN     17141    @/tmp/.X11-unix/X0
                                    unix  3      [ ]         DGRAM      VERBUNDEN     10962
                                    unix  3      [ ]         STREAM     VERBUNDEN     19758
                                    unix  3      [ ]         STREAM     VERBUNDEN     22013
                                    unix  3      [ ]         STREAM     VERBUNDEN     17963
                                    unix  3      [ ]         STREAM     VERBUNDEN     18548
                                    unix  2      [ ]         STREAM     VERBUNDEN     16778
                                    unix  2      [ ]         DGRAM      VERBUNDEN     13266
                                    unix  3      [ ]         STREAM     VERBUNDEN     19852    /run/user/1000/bus
                                    unix  3      [ ]         STREAM     VERBUNDEN     17976
                                    unix  3      [ ]         STREAM     VERBUNDEN     16662
                                    unix  3      [ ]         STREAM     VERBUNDEN     25941
                                    unix  3      [ ]         STREAM     VERBUNDEN     150805
                                    unix  3      [ ]         STREAM     VERBUNDEN     23359
                                    unix  3      [ ]         STREAM     VERBUNDEN     17260
                                    unix  3      [ ]         STREAM     VERBUNDEN     19902    /run/user/1000/pulse/native
                                    unix  3      [ ]         STREAM     VERBUNDEN     14485    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     19904    /run/user/1000/bus
                                    unix  3      [ ]         STREAM     VERBUNDEN     23363
                                    unix  3      [ ]         STREAM     VERBUNDEN     21925
                                    unix  3      [ ]         STREAM     VERBUNDEN     17061    @/tmp/.X11-unix/X0
                                    unix  3      [ ]         STREAM     VERBUNDEN     13181    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     20224    /run/dhcpcd.unpriv.sock
                                    unix  3      [ ]         STREAM     VERBUNDEN     19834    @/tmp/dbus-w8ByxioP3U
                                    unix  3      [ ]         STREAM     VERBUNDEN     19358
                                    unix  3      [ ]         STREAM     VERBUNDEN     18002
                                    unix  3      [ ]         STREAM     VERBUNDEN     17660    /run/user/1000/bus
                                    unix  3      [ ]         STREAM     VERBUNDEN     22357
                                    unix  3      [ ]         STREAM     VERBUNDEN     19854    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     18454
                                    unix  3      [ ]         STREAM     VERBUNDEN     17448    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     15694
                                    unix  3      [ ]         STREAM     VERBUNDEN     24202
                                    unix  3      [ ]         STREAM     VERBUNDEN     19950    @/dbus-vfs-daemon/socket-DSlJMB25
                                    unix  3      [ ]         STREAM     VERBUNDEN     17138    @/tmp/.X11-unix/X0
                                    unix  2      [ ]         DGRAM      VERBUNDEN     14255
                                    unix  3      [ ]         STREAM     VERBUNDEN     17235    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     17794
                                    unix  3      [ ]         STREAM     VERBUNDEN     17090
                                    unix  3      [ ]         STREAM     VERBUNDEN     17371
                                    unix  3      [ ]         STREAM     VERBUNDEN     17958
                                    unix  3      [ ]         STREAM     VERBUNDEN     21293
                                    unix  3      [ ]         STREAM     VERBUNDEN     23113
                                    unix  3      [ ]         STREAM     VERBUNDEN     17646
                                    unix  3      [ ]         STREAM     VERBUNDEN     23360
                                    unix  3      [ ]         STREAM     VERBUNDEN     17196    /run/user/1000/bus
                                    unix  3      [ ]         STREAM     VERBUNDEN     14505
                                    unix  3      [ ]         STREAM     VERBUNDEN     25944
                                    unix  3      [ ]         STREAM     VERBUNDEN     17781    /run/user/1000/bus
                                    unix  2      [ ]         DGRAM      VERBUNDEN     18528
                                    unix  3      [ ]         STREAM     VERBUNDEN     17068
                                    unix  3      [ ]         STREAM     VERBUNDEN     22408
                                    unix  3      [ ]         STREAM     VERBUNDEN     22291
                                    unix  3      [ ]         STREAM     VERBUNDEN     24328
                                    unix  3      [ ]         STREAM     VERBUNDEN     22509
                                    unix  3      [ ]         STREAM     VERBUNDEN     23056
                                    unix  2      [ ]         DGRAM      VERBUNDEN     20259
                                    unix  3      [ ]         STREAM     VERBUNDEN     17801    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     17637
                                    unix  3      [ ]         DGRAM      VERBUNDEN     10818
                                    unix  3      [ ]         STREAM     VERBUNDEN     24201
                                    unix  3      [ ]         STREAM     VERBUNDEN     18006
                                    unix  3      [ ]         STREAM     VERBUNDEN     13123    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     150803
                                    unix  3      [ ]         STREAM     VERBUNDEN     22998
                                    unix  3      [ ]         STREAM     VERBUNDEN     22624
                                    unix  3      [ ]         STREAM     VERBUNDEN     17226    /run/user/1000/bus
                                    unix  3      [ ]         STREAM     VERBUNDEN     17538
                                    unix  3      [ ]         STREAM     VERBUNDEN     13746
                                    unix  3      [ ]         STREAM     VERBUNDEN     18063
                                    unix  2      [ ]         DGRAM                    13110
                                    unix  3      [ ]         STREAM     VERBUNDEN     12182
                                    unix  3      [ ]         STREAM     VERBUNDEN     17224    /run/systemd/journal/stdout
                                    unix  3      [ ]         DGRAM      VERBUNDEN     15090
                                    unix  3      [ ]         STREAM     VERBUNDEN     24326
                                    unix  2      [ ]         DGRAM      VERBUNDEN     17755
                                    unix  2      [ ]         DGRAM                    16921
                                    unix  3      [ ]         STREAM     VERBUNDEN     14457    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     24732
                                    unix  3      [ ]         STREAM     VERBUNDEN     19457
                                    unix  3      [ ]         STREAM     VERBUNDEN     18828
                                    unix  3      [ ]         STREAM     VERBUNDEN     19821
                                    unix  3      [ ]         STREAM     VERBUNDEN     20250
                                    unix  3      [ ]         STREAM     VERBUNDEN     17171    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     13757
                                    unix  3      [ ]         STREAM     VERBUNDEN     18687
                                    unix  3      [ ]         STREAM     VERBUNDEN     18673    @/tmp/.X11-unix/X0
                                    unix  3      [ ]         STREAM     VERBUNDEN     19717    @/tmp/dbus-w8ByxioP3U
                                    unix  3      [ ]         STREAM     VERBUNDEN     13030
                                    unix  3      [ ]         STREAM     VERBUNDEN     16848    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     17960
                                    unix  3      [ ]         STREAM     VERBUNDEN     17091    @/tmp/.X11-unix/X0
                                    unix  3      [ ]         STREAM     VERBUNDEN     17613
                                    unix  3      [ ]         STREAM     VERBUNDEN     18072
                                    unix  3      [ ]         STREAM     VERBUNDEN     20207    /run/user/1000/bus
                                    unix  3      [ ]         STREAM     VERBUNDEN     17669    /run/user/1000/bus
                                    unix  3      [ ]         STREAM     VERBUNDEN     13667    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     23365
                                    unix  3      [ ]         STREAM     VERBUNDEN     18671    @/tmp/.X11-unix/X0
                                    unix  3      [ ]         STREAM     VERBUNDEN     17754    /run/user/1000/bus
                                    unix  2      [ ]         DGRAM                    13280
                                    unix  3      [ ]         STREAM     VERBUNDEN     21268
                                    unix  3      [ ]         STREAM     VERBUNDEN     20206    @/tmp/dbus-w8ByxioP3U
                                    unix  3      [ ]         STREAM     VERBUNDEN     22455
                                    unix  3      [ ]         STREAM     VERBUNDEN     14251    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     19901
                                    unix  3      [ ]         STREAM     VERBUNDEN     18646
                                    unix  3      [ ]         STREAM     VERBUNDEN     17236    /run/user/1000/bus
                                    unix  3      [ ]         STREAM     VERBUNDEN     19843
                                    unix  3      [ ]         STREAM     VERBUNDEN     13077
                                    unix  3      [ ]         DGRAM      VERBUNDEN     10961
                                    unix  3      [ ]         STREAM     VERBUNDEN     19695
                                    unix  3      [ ]         STREAM     VERBUNDEN     12013
                                    unix  3      [ ]         STREAM     VERBUNDEN     17229    /run/user/1000/bus
                                    unix  3      [ ]         STREAM     VERBUNDEN     18511
                                    unix  3      [ ]         STREAM     VERBUNDEN     17453    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     16917
                                    unix  2      [ ]         DGRAM      VERBUNDEN     13024
                                    unix  3      [ ]         STREAM     VERBUNDEN     14439
                                    unix  3      [ ]         STREAM     VERBUNDEN     22292
                                    unix  3      [ ]         STREAM     VERBUNDEN     18693
                                    unix  3      [ ]         STREAM     VERBUNDEN     15072
                                    unix  3      [ ]         STREAM     VERBUNDEN     17471
                                    unix  3      [ ]         STREAM     VERBUNDEN     24172
                                    unix  3      [ ]         STREAM     VERBUNDEN     17835
                                    unix  3      [ ]         STREAM     VERBUNDEN     13576
                                    unix  3      [ ]         STREAM     VERBUNDEN     19883    /run/user/1000/bus
                                    unix  3      [ ]         STREAM     VERBUNDEN     17957
                                    unix  3      [ ]         STREAM     VERBUNDEN     17069    @/tmp/.X11-unix/X0
                                    unix  3      [ ]         STREAM     VERBUNDEN     17372    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     21291
                                    unix  3      [ ]         STREAM     VERBUNDEN     22456
                                    unix  3      [ ]         STREAM     VERBUNDEN     17647
                                    unix  3      [ ]         STREAM     VERBUNDEN     21924
                                    unix  3      [ ]         STREAM     VERBUNDEN     15231    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     15094
                                    unix  3      [ ]         STREAM     VERBUNDEN     20228    /run/user/1000/bus
                                    unix  3      [ ]         STREAM     VERBUNDEN     19668
                                    unix  3      [ ]         STREAM     VERBUNDEN     23115
                                    unix  3      [ ]         STREAM     VERBUNDEN     19354
                                    unix  3      [ ]         STREAM     VERBUNDEN     16915
                                    unix  3      [ ]         STREAM     VERBUNDEN     14264
                                    unix  3      [ ]         STREAM     VERBUNDEN     15419    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     14530
                                    unix  3      [ ]         STREAM     VERBUNDEN     14484    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     17237
                                    unix  3      [ ]         STREAM     VERBUNDEN     11977
                                    unix  3      [ ]         STREAM     VERBUNDEN     18659
                                    unix  2      [ ]         DGRAM      VERBUNDEN     142781
                                    unix  3      [ ]         STREAM     VERBUNDEN     13468    /run/systemd/journal/stdout
                                    unix  2      [ ]         DGRAM      VERBUNDEN     10958
                                    unix  2      [ ]         STREAM     VERBUNDEN     13739
                                    unix  2      [ ]         STREAM     VERBUNDEN     13290
                                    unix  3      [ ]         STREAM     VERBUNDEN     19836
                                    unix  3      [ ]         STREAM     VERBUNDEN     17792
                                    unix  3      [ ]         STREAM     VERBUNDEN     24683
                                    unix  3      [ ]         DGRAM      VERBUNDEN     10819
                                    unix  3      [ ]         STREAM     VERBUNDEN     22410
                                    unix  3      [ ]         STREAM     VERBUNDEN     17175
                                    unix  3      [ ]         STREAM     VERBUNDEN     17799
                                    unix  3      [ ]         STREAM     VERBUNDEN     12183    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     13213
                                    unix  2      [ ]         DGRAM      VERBUNDEN     14534
                                    unix  3      [ ]         STREAM     VERBUNDEN     17612
                                    unix  2      [ ]         DGRAM      VERBUNDEN     11912
                                    unix  3      [ ]         STREAM     VERBUNDEN     19352
                                    unix  3      [ ]         STREAM     VERBUNDEN     18007
                                    unix  3      [ ]         STREAM     VERBUNDEN     19817
                                    unix  2      [ ]         DGRAM      VERBUNDEN     14504
                                    unix  3      [ ]         STREAM     VERBUNDEN     25943
                                    unix  3      [ ]         STREAM     VERBUNDEN     19575
                                    unix  3      [ ]         STREAM     VERBUNDEN     23364
                                    unix  3      [ ]         STREAM     VERBUNDEN     21929
                                    unix  3      [ ]         STREAM     VERBUNDEN     18660
                                    unix  3      [ ]         STREAM     VERBUNDEN     17934
                                    unix  3      [ ]         STREAM     VERBUNDEN     19823
                                    unix  2      [ ]         DGRAM      VERBUNDEN     14378
                                    unix  3      [ ]         STREAM     VERBUNDEN     17894
                                    unix  3      [ ]         STREAM     VERBUNDEN     20225    /run/dhcpcd.unpriv.sock
                                    unix  3      [ ]         STREAM     VERBUNDEN     22511
                                    unix  3      [ ]         STREAM     VERBUNDEN     22999
                                    unix  3      [ ]         STREAM     VERBUNDEN     13464
                                    unix  3      [ ]         STREAM     VERBUNDEN     17230
                                    unix  3      [ ]         STREAM     VERBUNDEN     22623
                                    unix  3      [ ]         STREAM     VERBUNDEN     20253    /run/user/1000/bus
                                    unix  3      [ ]         STREAM     VERBUNDEN     18780
                                    unix  3      [ ]         STREAM     VERBUNDEN     16919
                                    unix  3      [ ]         STREAM     VERBUNDEN     19566
                                    unix  3      [ ]         STREAM     VERBUNDEN     16883    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     17806
                                    unix  3      [ ]         STREAM     VERBUNDEN     21290
                                    unix  3      [ ]         STREAM     VERBUNDEN     17537
                                    unix  3      [ ]         STREAM     VERBUNDEN     17337    @/tmp/.X11-unix/X0
                                    unix  3      [ ]         STREAM     VERBUNDEN     17392    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     17764    /run/user/1000/bus
                                    unix  3      [ ]         STREAM     VERBUNDEN     16893    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     17981
                                    unix  3      [ ]         STREAM     VERBUNDEN     23366
                                    unix  3      [ ]         STREAM     VERBUNDEN     20245    @/tmp/dbus-w8ByxioP3U
                                    unix  3      [ ]         STREAM     VERBUNDEN     13758    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     19855    /run/user/1000/bus
                                    unix  3      [ ]         DGRAM      VERBUNDEN     15091
                                    unix  3      [ ]         STREAM     VERBUNDEN     13156    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     17018    /run/user/1000/bus
                                    unix  3      [ ]         STREAM     VERBUNDEN     16877    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     15314
                                    unix  3      [ ]         STREAM     VERBUNDEN     24730
                                    unix  3      [ ]         STREAM     VERBUNDEN     23058
                                    unix  3      [ ]         STREAM     VERBUNDEN     14593
                                    unix  3      [ ]         STREAM     VERBUNDEN     18679    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     19491
                                    unix  3      [ ]         STREAM     VERBUNDEN     13830
                                    unix  3      [ ]         STREAM     VERBUNDEN     24173
                                    unix  3      [ ]         STREAM     VERBUNDEN     21270
                                    unix  3      [ ]         STREAM     VERBUNDEN     17261
                                    unix  3      [ ]         STREAM     VERBUNDEN     24325
                                    unix  3      [ ]         STREAM     VERBUNDEN     17520    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     19359
                                    unix  3      [ ]         STREAM     VERBUNDEN     14441    /run/dbus/system_bus_socket
                                    unix  3      [ ]         DGRAM      VERBUNDEN     15357
                                    unix  3      [ ]         STREAM     VERBUNDEN     17447    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     14458    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     22354
                                    unix  3      [ ]         STREAM     VERBUNDEN     19742    @/tmp/dbus-w8ByxioP3U
                                    unix  3      [ ]         STREAM     VERBUNDEN     17638
                                    unix  3      [ ]         STREAM     VERBUNDEN     14444
                                    unix  3      [ ]         STREAM     VERBUNDEN     21267
                                    unix  3      [ ]         STREAM     VERBUNDEN     17868
                                    unix  3      [ ]         STREAM     VERBUNDEN     19696
                                    unix  3      [ ]         STREAM     VERBUNDEN     17665    /run/user/1000/pipewire-0
                                    unix  3      [ ]         STREAM     VERBUNDEN     13210    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     17014
                                    unix  3      [ ]         STREAM     VERBUNDEN     18513
                                    unix  3      [ ]         STREAM     VERBUNDEN     13933    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     18689    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     150804
                                    unix  3      [ ]         STREAM     VERBUNDEN     22626
                                    unix  3      [ ]         STREAM     VERBUNDEN     15226
                                    unix  3      [ ]         STREAM     VERBUNDEN     16601    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     19355
                                    unix  3      [ ]         STREAM     VERBUNDEN     17179
                                    unix  3      [ ]         STREAM     VERBUNDEN     23112
                                    unix  3      [ ]         STREAM     VERBUNDEN     19824    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     25942
                                    unix  3      [ ]         STREAM     VERBUNDEN     16151
                                    unix  3      [ ]         STREAM     VERBUNDEN     21926
                                    unix  3      [ ]         STREAM     VERBUNDEN     17015    @/tmp/.X11-unix/X0
                                    unix  3      [ ]         STREAM     VERBUNDEN     14871
                                    unix  3      [ ]         STREAM     VERBUNDEN     13016
                                    unix  3      [ ]         STREAM     VERBUNDEN     16004
                                    unix  3      [ ]         STREAM     VERBUNDEN     21928
                                    unix  3      [ ]         STREAM     VERBUNDEN     17205    @/tmp/.X11-unix/X0
                                    unix  3      [ ]         STREAM     VERBUNDEN     17356
                                    unix  3      [ ]         STREAM     VERBUNDEN     17071    @/tmp/.X11-unix/X0
                                    unix  3      [ ]         STREAM     VERBUNDEN     16984
                                    unix  3      [ ]         STREAM     VERBUNDEN     13198    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     9830     /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     19849    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     19799    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     18161
                                    unix  3      [ ]         STREAM     VERBUNDEN     19670
                                    unix  3      [ ]         STREAM     VERBUNDEN     18159
                                    unix  3      [ ]         STREAM     VERBUNDEN     13741    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     20276
                                    unix  3      [ ]         STREAM     VERBUNDEN     17231    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     17074    /run/user/1000/bus
                                    unix  3      [ ]         STREAM     VERBUNDEN     23000
                                    unix  3      [ ]         STREAM     VERBUNDEN     18531
                                    unix  3      [ ]         STREAM     VERBUNDEN     17782    @/tmp/.X11-unix/X0
                                    unix  3      [ ]         STREAM     VERBUNDEN     12017
                                    unix  2      [ ]         DGRAM      VERBUNDEN     10897
                                    unix  3      [ ]         STREAM     VERBUNDEN     18782
                                    unix  3      [ ]         STREAM     VERBUNDEN     17086    /run/user/1000/bus
                                    unix  3      [ ]         STREAM     VERBUNDEN     17172    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     17584    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     12178
                                    unix  3      [ ]         STREAM     VERBUNDEN     13638    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     13598    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     19353
                                    unix  3      [ ]         STREAM     VERBUNDEN     24684
                                    unix  3      [ ]         STREAM     VERBUNDEN     22016
                                    unix  3      [ ]         STREAM     VERBUNDEN     13740
                                    unix  3      [ ]         STREAM     VERBUNDEN     22409
                                    unix  3      [ ]         STREAM     VERBUNDEN     13467    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     22512
                                    unix  3      [ ]         STREAM     VERBUNDEN     17611
                                    unix  3      [ ]         STREAM     VERBUNDEN     16446    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     14373    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     22290
                                    unix  3      [ ]         STREAM     VERBUNDEN     18512
                                    unix  3      [ ]         STREAM     VERBUNDEN     17810
                                    unix  3      [ ]         STREAM     VERBUNDEN     16918
                                    unix  3      [ ]         STREAM     VERBUNDEN     17536
                                    unix  2      [ ]         DGRAM      VERBUNDEN     11986
                                    unix  3      [ ]         STREAM     VERBUNDEN     13026
                                    unix  3      [ ]         STREAM     VERBUNDEN     19851
                                    unix  3      [ ]         DGRAM      VERBUNDEN     15358
                                    unix  2      [ ]         DGRAM      VERBUNDEN     13239
                                    unix  3      [ ]         STREAM     VERBUNDEN     19360
                                    unix  3      [ ]         STREAM     VERBUNDEN     18123    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     17752    @/tmp/.X11-unix/X0
                                    unix  3      [ ]         STREAM     VERBUNDEN     14447    /run/systemd/journal/stdout
                                    unix  2      [ ]         DGRAM      VERBUNDEN     15086
                                    unix  3      [ ]         STREAM     VERBUNDEN     17262    @/tmp/.X11-unix/X0
                                    unix  3      [ ]         STREAM     VERBUNDEN     17897    /run/user/1000/bus
                                    unix  3      [ ]         STREAM     VERBUNDEN     18829
                                    unix  3      [ ]         STREAM     VERBUNDEN     17232    /run/user/1000/bus
                                    unix  3      [ ]         STREAM     VERBUNDEN     17035
                                    unix  3      [ ]         DGRAM      VERBUNDEN     14090
                                    unix  3      [ ]         STREAM     VERBUNDEN     13829
                                    unix  3      [ ]         STREAM     VERBUNDEN     20257
                                    unix  2      [ ]         DGRAM      VERBUNDEN     9778
                                    unix  3      [ ]         STREAM     VERBUNDEN     23362
                                    unix  3      [ ]         STREAM     VERBUNDEN     17668    /run/user/1000/pipewire-0
                                    unix  3      [ ]         STREAM     VERBUNDEN     22014
                                    unix  3      [ ]         STREAM     VERBUNDEN     18001
                                    unix  3      [ ]         STREAM     VERBUNDEN     17869    /run/user/1000/bus
                                    unix  3      [ ]         STREAM     VERBUNDEN     18514
                                    unix  3      [ ]         STREAM     VERBUNDEN     24685
                                    unix  3      [ ]         STREAM     VERBUNDEN     17126    /run/user/1000/bus
                                    unix  3      [ ]         STREAM     VERBUNDEN     17522    /run/dbus/system_bus_socket
                                    unix  3      [ ]         STREAM     VERBUNDEN     21269
                                    unix  3      [ ]         STREAM     VERBUNDEN     17632
                                    unix  3      [ ]         STREAM     VERBUNDEN     13569
                                    unix  3      [ ]         STREAM     VERBUNDEN     24174
                                    unix  3      [ ]         STREAM     VERBUNDEN     18075
                                    unix  3      [ ]         STREAM     VERBUNDEN     17763    /run/systemd/journal/stdout
                                    unix  3      [ ]         STREAM     VERBUNDEN     17649    /run/user/1000/bus
                                    unix  3      [ ]         STREAM     VERBUNDEN     21292
                                    unix  3      [ ]         STREAM     VERBUNDEN     22355
                                    unix  3      [ ]         STREAM     VERBUNDEN     17614
                                    unix  3      [ ]         STREAM     VERBUNDEN     150806
                                    unix  3      [ ]         STREAM     VERBUNDEN     18697
                                    unix  3      [ ]         STREAM     VERBUNDEN     15862
                                    unix  3      [ ]         STREAM     VERBUNDEN     19857
                                    unix  3      [ ]         STREAM     VERBUNDEN     13018
                                    GlasfaserG Thomas BraunT 3 Antworten Letzte Antwort
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      Dann zum Schluss
                                      ps auxww|grep io
                                        Ich würde schon mal den Desktop ausknipsen. Hier ist Kommandozeile angesagt.
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          Bist du mit WLAN verbunden ...
