  4. MiVacuum Adapter läuft nicht mehr
    6.3k
21 Beiträge 3 Kommentatoren 775 Aufrufe 3 Beobachtet
  • L lustig29
    Hab jetzt alles so gemacht und ausgeführt. Leider funktioniert der Adapter immer noch nicht.
    @lustig29
    Log des Adapterstarts? Vielleicht auch auf Debug Level setzen.
    L 1 Antwort Letzte Antwort
      @lustig29
      lustig29
      mihome-vacuum.0
      2022-07-09 12:56:15.804	info	IOT enabled, create state
      mihome-vacuum.0
      2022-07-09 12:56:15.675	info	starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.16.0, js-controller: 4.0.23
      host.raspberrypi
      2022-07-09 12:56:13.057	info	instance system.adapter.mihome-vacuum.0 started with pid 2085
      host.raspberrypi
      2022-07-09 12:56:10.596	info	instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.raspberrypi
      2022-07-09 12:56:09.869	info	stopInstance system.adapter.mihome-vacuum.0 send kill signal
      mihome-vacuum.0
      2022-07-09 12:56:09.823	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      mihome-vacuum.0
      2022-07-09 12:56:09.820	info	terminating
      mihome-vacuum.0
      2022-07-09 12:56:09.818	error	Socket Close
      mihome-vacuum.0
      2022-07-09 12:56:09.814	info	Got terminate signal TERMINATE_YOURSELF
      host.raspberrypi
      2022-07-09 12:56:09.643	info	stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
      • L lustig29
        mihome-vacuum.0
        mihome-vacuum.0
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        host.raspberrypi
        @lustig29
        Log Level auf 'Debug' gesetzt?
          @lustig29
          lustig29
          mihome-vacuum.0
          2022-07-09 13:25:45.159	debug	Helo message Timeout
          mihome-vacuum.0
          2022-07-09 13:25:43.155	debug	server started on 0.0.0.0:53421
          mihome-vacuum.0
          2022-07-09 13:25:43.150	info	IOT enabled, create state
          mihome-vacuum.0
          2022-07-09 13:25:43.145	debug	MIIO: Config: ip: token:
          mihome-vacuum.0
          2022-07-09 13:25:43.144	debug	Create State for deviceInfowifi_signal
          mihome-vacuum.0
          2022-07-09 13:25:43.144	debug	Create State for deviceInfofw_ver
          mihome-vacuum.0
          2022-07-09 13:25:43.143	debug	Create State for deviceInfomodel
          mihome-vacuum.0
          2022-07-09 13:25:43.143	debug	Create State for deviceInfomac
          mihome-vacuum.0
          2022-07-09 13:25:43.142	debug	Create State for deviceInfo
          mihome-vacuum.0
          2022-07-09 13:25:43.115	debug	load Map creator... true
          mihome-vacuum.0
          2022-07-09 13:25:43.020	info	starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.16.0, js-controller: 4.0.23
          mihome-vacuum.0
          2022-07-09 13:25:42.587	debug	Plugin sentry Initialize Plugin (enabled=true)
          host.raspberrypi
          2022-07-09 13:25:40.337	info	instance system.adapter.mihome-vacuum.0 started with pid 2397
          host.raspberrypi
          2022-07-09 13:25:37.776	info	instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          mihome-vacuum.0
          2022-07-09 13:25:37.114	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          mihome-vacuum.0
          2022-07-09 13:25:37.112	info	terminating
          mihome-vacuum.0
          2022-07-09 13:25:37.111	error	Socket Close
          mihome-vacuum.0
          2022-07-09 13:25:37.108	info	Got terminate signal TERMINATE_YOURSELF
          host.raspberrypi
          2022-07-09 13:25:37.111	info	stopInstance system.adapter.mihome-vacuum.0 send kill signal
          host.raspberrypi
          2022-07-09 13:25:37.099	info	stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
          • L lustig29
            mihome-vacuum.0
            mihome-vacuum.0
            mihome-vacuum.0
            mihome-vacuum.0
            mihome-vacuum.0
            mihome-vacuum.0
            mihome-vacuum.0
            mihome-vacuum.0
            mihome-vacuum.0
            mihome-vacuum.0
            mihome-vacuum.0
            mihome-vacuum.0
            host.raspberrypi
            host.raspberrypi
            mihome-vacuum.0
            mihome-vacuum.0
            mihome-vacuum.0
            mihome-vacuum.0
            host.raspberrypi
            host.raspberrypi
            @lustig29 sagte in MiVacuum Adapter läuft nicht mehr:
            Dein Stabubsauger ist verreist, nicht erreichbar.
            Wie sehen die Einstellungen im Adapter dazu aus?
            IP gesetzt? Token richtig?
            Bei mir startet der so:
            2022-07-09 13:29:58.925  - info: mihome-vacuum.0 (236418) starting. Version 3.6.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v18.4.0, js-controller: 4.0.23
            2022-07-09 13:29:59.004  - debug: mihome-vacuum.0 (236418) load Map creator... true
            2022-07-09 13:29:59.047  - debug: mihome-vacuum.0 (236418) Create State for deviceInfo
            2022-07-09 13:29:59.050  - debug: mihome-vacuum.0 (236418) Create State for deviceInfomac
            2022-07-09 13:29:59.052  - debug: mihome-vacuum.0 (236418) Create State for deviceInfomodel
            2022-07-09 13:29:59.053  - debug: mihome-vacuum.0 (236418) Create State for deviceInfofw_ver
            2022-07-09 13:29:59.054  - debug: mihome-vacuum.0 (236418) Create State for deviceInfowifi_signal
            2022-07-09 13:29:59.055  - debug: mihome-vacuum.0 (236418) MIIO: Config: ip:192.168.178.32 token: HIER_STAND_EIN_TOKEN
            2022-07-09 13:29:59.061  - info: mihome-vacuum.0 (236418) IOT enabled, create state
            2022-07-09 13:29:59.066  - debug: mihome-vacuum.0 (236418) server started on 0.0.0.0:53421
            2022-07-09 13:29:59.077  - debug: mihome-vacuum.0 (236418) Receive <<< Helo <<< 2141002000000000046c689562c966c6ffffffffffffffffffffffffffffffff
            2022-07-09 13:29:59.080  - debug: mihome-vacuum.0 (236418) MAIN: Connected to device, try to get model..
            L 2 Antworten Letzte Antwort
              lustig29
              Ip Adresse war falsch.:man-facepalming:
              Oh man, sorry das ich dich damit beschäftigt habe.
                lustig29
                Bei meinen Eltern ist dasselbe Problem. Da stimmt aber die Ip....
                mihome-vacuum.0
                2022-07-09 13:48:08.595	debug	Helo message Timeout
                mihome-vacuum.0
                2022-07-09 13:48:06.592	debug	server started on 0.0.0.0:53421
                mihome-vacuum.0
                2022-07-09 13:48:06.586	info	IOT enabled, create state
                mihome-vacuum.0
                2022-07-09 13:48:06.582	debug	MIIO: Config: ip:192.168.0.232 token:
                mihome-vacuum.0
                2022-07-09 13:48:06.580	debug	Create State for deviceInfowifi_signal
                mihome-vacuum.0
                2022-07-09 13:48:06.580	debug	Create State for deviceInfofw_ver
                mihome-vacuum.0
                2022-07-09 13:48:06.579	debug	Create State for deviceInfomodel
                mihome-vacuum.0
                2022-07-09 13:48:06.578	debug	Create State for deviceInfomac
                mihome-vacuum.0
                2022-07-09 13:48:06.577	debug	Create State for deviceInfo
                mihome-vacuum.0
                2022-07-09 13:48:06.542	debug	load Map creator... true
                mihome-vacuum.0
                2022-07-09 13:48:06.432	info	starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.16.0, js-controller: 4.0.23
                mihome-vacuum.0
                2022-07-09 13:48:06.016	debug	Plugin sentry Initialize Plugin (enabled=true)
                mihome-vacuum.0
                2022-07-09 13:48:05.826	debug	States connected to redis: 127.0.0.1:9000
                mihome-vacuum.0
                2022-07-09 13:48:05.768	debug	States create User PubSub Client
                mihome-vacuum.0
                2022-07-09 13:48:05.766	debug	States create System PubSub Client
                mihome-vacuum.0
                2022-07-09 13:48:05.723	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                mihome-vacuum.0
                2022-07-09 13:48:05.678	debug	Objects connected to redis: 127.0.0.1:9001
                mihome-vacuum.0
                2022-07-09 13:48:05.670	debug	Objects client initialize lua scripts
                mihome-vacuum.0
                2022-07-09 13:48:05.581	debug	Objects create User PubSub Client
                mihome-vacuum.0
                2022-07-09 13:48:05.580	debug	Objects create System PubSub Client
                mihome-vacuum.0
                2022-07-09 13:48:05.577	debug	Objects client ready ... initialize now
                mihome-vacuum.0
                2022-07-09 13:48:05.515	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                • L lustig29
                  mihome-vacuum.0
                  mihome-vacuum.0
                  mihome-vacuum.0
                  mihome-vacuum.0
                  mihome-vacuum.0
                  mihome-vacuum.0
                  mihome-vacuum.0
                  mihome-vacuum.0
                  mihome-vacuum.0
                  mihome-vacuum.0
                  mihome-vacuum.0
                  mihome-vacuum.0
                  mihome-vacuum.0
                  mihome-vacuum.0
                  mihome-vacuum.0
                  mihome-vacuum.0
                  mihome-vacuum.0
                  mihome-vacuum.0
                  mihome-vacuum.0
                  mihome-vacuum.0
                  mihome-vacuum.0
                  mihome-vacuum.0
                  @lustig29
                  Das dürfte aber auch aus der Netzwerk-Ecke kommen.
                    @lustig29
                    lustig29
                    ihome-vacuum.0
                    2022-07-09 22:48:28.892	debug	Create State for deviceInfo
                    mihome-vacuum.0
                    2022-07-09 22:48:28.855	debug	load Map creator... true
                    mihome-vacuum.0
                    2022-07-09 22:48:28.762	info	starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.16.0, js-controller: 4.0.23
                    mihome-vacuum.0
                    2022-07-09 22:48:28.293	debug	Plugin sentry Initialize Plugin (enabled=true)
                    mihome-vacuum.0
                    2022-07-09 22:48:28.110	debug	States connected to redis: 127.0.0.1:9000
                    mihome-vacuum.0
                    2022-07-09 22:48:28.052	debug	States create User PubSub Client
                    mihome-vacuum.0
                    2022-07-09 22:48:28.050	debug	States create System PubSub Client
                    mihome-vacuum.0
                    2022-07-09 22:48:28.015	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                    mihome-vacuum.0
                    2022-07-09 22:48:27.894	debug	Objects connected to redis: 127.0.0.1:9001
                    mihome-vacuum.0
                    2022-07-09 22:48:27.863	debug	Objects client initialize lua scripts
                    mihome-vacuum.0
                    2022-07-09 22:48:27.717	debug	Objects create User PubSub Client
                    mihome-vacuum.0
                    2022-07-09 22:48:27.715	debug	Objects create System PubSub Client
                    mihome-vacuum.0
                    2022-07-09 22:48:27.712	debug	Objects client ready ... initialize now
                    mihome-vacuum.0
                    2022-07-09 22:48:27.642	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                    • L lustig29
                      Systemdata Linux
                      Hardwaresystem: Raspi 4
                      Arbeitsspeicher: 4GB
                      Festplattenart: HDD
                      Betriebssystem: Ubuntu/Windows/Mac
                      Node-Version: 16.16.0
                      Nodejs-Version: 10.x.x
                      NPM-Version: 8.11.0
                      Installationsart: Skript/Manuell
                      Image genutzt: Ja/Nein
                      Ort/Name der Imagedatei: Link
                      Seit ein paar Tagen läuft mein MiVacuum Adapter leider nicht mehr. Ist diesbezüglich schon was bekannt? Oder gibt es vielleicht schon eine Lösung?
                      mihome-vacuum.0
                      2022-07-09 12:04:42.371	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      mihome-vacuum.0
                      2022-07-09 12:04:42.369	info	terminating
                      mihome-vacuum.0
                      2022-07-09 12:04:42.367	error	Socket Close
                      host.raspberrypi
                      2022-07-09 12:04:42.365	info	stopInstance system.adapter.mihome-vacuum.0 send kill signal
                      mihome-vacuum.0
                      2022-07-09 12:04:42.363	info	Got terminate signal TERMINATE_YOURSELF
                      mihome-vacuum.0
                      2022-07-09 12:04:48.393	info	IOT enabled, create state
                      mihome-vacuum.0
                      2022-07-09 12:04:48.262	info	starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.16.0, js-controller: 4.0.23
                      tritor
                      schrieb am zuletzt editiert von tritor
                      @lustig29
                      hatte ich auch. Was bei mir geholfen hat, war den S5max aus der Xiaomi App löschen, ausloggen und dann wieder eingeloggt und Gerät neu hinzugefügt.
                      Dann die Zugangsdaten im Adapter neu eingegeben und siehe da, das Gerät wurde gefunden und auch das Token war dann neu. Dann ging auch der Adapter wieder auf grün.
                      Gernot
                      Host: i9 server Proxmox , Debian 13.4 for ioBroker
                      ioBroker: 7.9.2, Node.js: 22.22.2, NPM: 10.9.4, JS-controller: 7.2.1
                      Wetterstation: HP1000SEPro V1.9.7 Easeweather V1.7.5
                      Grafana 13.0.1 / InfluxDB 2.8.0
