  4. zigbee 64 bit???
    5.8k
zigbee 64 bit???
zigbee stick
30 Beiträge 6 Kommentatoren 2.7k Aufrufe 5 Beobachtet
    @denjo
    iobroker update -i
    uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    sagt?
    denjo
    @thomas-braun sagte in zigbee 64 bit???:
    sudo ln -s /usr/bin/node /usr/bin/nodejs uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    pi@raspberrypi:~ $ iobroker update -i
    Adapter    "admin"        : 5.3.8    , installed 5.3.8
    Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
    Adapter    "amazon-dash"  : 1.1.0    , installed 1.1.0
    Adapter    "backitup"     : 2.4.9    , installed 2.4.9
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
    Adapter    "devices"      : 1.0.10   , installed 1.0.10
    Adapter    "discovery"    : 3.0.3    , installed 3.0.3
    Adapter    "easee"        : 1.0.5    , installed 1.0.5
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "ical"         : 1.12.1   , installed 1.12.1
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.4   , installed 1.11.4
    Adapter    "javascript"   : 5.7.0    , installed 5.7.0
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "material"     : 1.1.2    , installed 1.1.2
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mihome-vacuum": 3.3.3    , installed 3.4.1
    Adapter    "mqtt"         : 3.0.6    , installed 3.0.6
    Adapter    "node-red"     : 3.3.0    , installed 3.3.0
    Adapter    "nuki-extended": 2.3.1    , installed 2.3.1
    Adapter    "openweathermap": 0.2.4   , installed 0.2.4
    Adapter    "ring"         : 1.2.8    , installed 3.0.0-beta.13
    Adapter    "shelly"       : 5.3.2    , installed 5.3.2
    Adapter    "simple-api"   : 2.6.5    , installed 2.6.5
    Adapter    "smartthings"  : 0.0.3    , installed 0.0.3
    Adapter    "tado"         : 0.3.15   , installed 0.3.15
    Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
    Adapter    "telegram"     : 1.12.6   , installed 1.12.6
    Adapter    "terminal"     : 0.2.5    , installed 0.2.5
    Adapter    "trashschedule": 2.0.2    , installed 2.0.2
    Adapter    "tuya"         : 3.6.15   , installed 3.6.15
    Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
    Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
    Adapter    "vis-icontwo"  : 0.87.0   , installed 0.87.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
    Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
    Adapter    "worx"         : 1.5.5    , installed 1.5.5
    Adapter    "yahka"        : 0.13.1   , installed 0.13.1
    Adapter    "yeelight-2"   : 1.1.2    , installed 1.1.2
    Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
    pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
    ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
    aarch64
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.15.1
    v16.15.1
    8.11.0
    pi
    /home/pi
    OK:1 http://security.debian.org/debian-security bullseye-security InRelease
    OK:2 http://deb.debian.org/debian bullseye InRelease
    OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
    OK:4 http://deb.debian.org/debian bullseye-updates InRelease
    OK:5 https://deb.nodesource.com/node_16.x bullseye InRelease
    Aktualisierung für 5 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
    nodejs:
      Installiert:           16.15.1-deb-1nodesource1
      Installationskandidat: 16.15.1-deb-1nodesource1
      Versionstabelle:
     *** 16.15.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    pi@raspberrypi:~ $
      @denjo sagte in zigbee 64 bit???:
      aber ich hatte vorher keine probleme
      aber wie bereits beschrieben ist dann der Adapter unschuldig 😇
      was nutzt du denn für Hardware?
      passende 64 Bit Treiber installiert?
      denjo
      @homoran Raspberry pi 4 8GB muss ich irgendwie noch treiber drauf installieren?
      Thomas BraunT OliverIOO 2 Antworten Letzte Antwort
      • D denjo
        Nein.
        Aber hau die 5 Updates (dürfte Firmware sein) auf das System. Reboot erforderlich.
          Nein.
          denjo
          @thomas-braun könntest du mir das genauer erklären?
          • D denjo
            Was? Wie man sein System updated?
              denjo
              schrieb am zuletzt editiert von denjo
              @thomas-braun du meinst sicherlich nicht sudo apt-get update bzw upgrade oder???
              • D denjo
                @denjo
                Doch, das meine ich. Auch wenn ich apt bevorzuge:
                iobroker stop
                sudo apt update
                sudo apt full-upgrade
                sudo reboot
                Und welcher Stick ist das da eigentlich?
                ls -l /dev/serial/by-id/
                dürfte es verraten.
                  @denjo
                  iobroker stop
                  sudo apt update
                  sudo reboot
                  dürfte es verraten.
                  denjo
                  pi@raspberrypi:~ $ ls -l /dev/serial/by-id/
                  insgesamt 0
                  lrwxrwxrwx 1 root root 13 12. Jun 15:23 usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f87fbb8463c9eb11b1448b4f1d69213e-if00-port0 -> ../../ttyUSB0
                  • D denjo
                    insgesamt 0
                    @denjo
                    Also der Sonoff-Stick.
                    Welche Firmware?
                    Was passiert in
                    dmesg -wT
                    wenn der Stick entfernt und wieder eingesteckt wird?
                      @denjo
                      Welche Firmware?
                      Was passiert in
                      dmesg -wT
                      denjo
                      so nach update keine verbesserung
                      pi@raspberrypi:~ $ dmesg -wT
                      [Mo Jun 13 18:56:30 2022] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
                      [Mo Jun 13 18:56:30 2022] Linux version 5.15.32-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1538 SMP PREEMPT Thu Mar 31 19:40:39 BST 2022
                      [Mo Jun 13 18:56:30 2022] random: fast init done
                      [Mo Jun 13 18:56:30 2022] Machine model: Raspberry Pi 4 Model B Rev 1.4
                      [Mo Jun 13 18:56:30 2022] efi: UEFI not found.
                      [Mo Jun 13 18:56:30 2022] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
                      [Mo Jun 13 18:56:30 2022] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
                      [Mo Jun 13 18:56:30 2022] Zone ranges:
                      [Mo Jun 13 18:56:30 2022]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
                      [Mo Jun 13 18:56:30 2022]   DMA32    [mem 0x0000000040000000-0x00000000ffffffff]
                      [Mo Jun 13 18:56:30 2022]   Normal   [mem 0x0000000100000000-0x00000001ffffffff]
                      [Mo Jun 13 18:56:30 2022] Movable zone start for each node
                      [Mo Jun 13 18:56:30 2022] Early memory node ranges
                      [Mo Jun 13 18:56:30 2022]   node   0: [mem 0x0000000000000000-0x000000003b2fffff]
                      [Mo Jun 13 18:56:30 2022]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
                      [Mo Jun 13 18:56:30 2022]   node   0: [mem 0x0000000100000000-0x00000001ffffffff]
                      [Mo Jun 13 18:56:30 2022] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
                      [Mo Jun 13 18:56:30 2022] On node 0, zone DMA32: 256 pages in unavailable ranges
                      [Mo Jun 13 18:56:30 2022] percpu: Embedded 28 pages/cpu s77144 r8192 d29352 u114688
                      [Mo Jun 13 18:56:30 2022] pcpu-alloc: s77144 r8192 d29352 u114688 alloc=28*4096
                      [Mo Jun 13 18:56:30 2022] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                      [Mo Jun 13 18:56:30 2022] Detected PIPT I-cache on CPU0
                      [Mo Jun 13 18:56:30 2022] CPU features: detected: Spectre-v2
                      [Mo Jun 13 18:56:30 2022] CPU features: detected: Spectre-v4
                      [Mo Jun 13 18:56:30 2022] CPU features: detected: Spectre-BHB
                      [Mo Jun 13 18:56:30 2022] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
                      [Mo Jun 13 18:56:30 2022] Built 1 zonelists, mobility grouping on.  Total pages: 2028596
                      [Mo Jun 13 18:56:30 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:E0:5D:E1 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=e16dce5c-02 rootfstype=ext4 fsck.repair=yes rootwait
                      [Mo Jun 13 18:56:30 2022] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
                      [Mo Jun 13 18:56:30 2022] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
                      [Mo Jun 13 18:56:30 2022] mem auto-init: stack:off, heap alloc:off, heap free:off
                      [Mo Jun 13 18:56:30 2022] software IO TLB: mapped [mem 0x0000000037300000-0x000000003b300000] (64MB)
                      [Mo Jun 13 18:56:30 2022] Memory: 7667488K/8244224K available (11456K kernel code, 1962K rwdata, 4144K rodata, 3776K init, 964K bss, 249056K reserved, 327680K cma-reserved)
                      [Mo Jun 13 18:56:30 2022] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                      [Mo Jun 13 18:56:30 2022] ftrace: allocating 37889 entries in 149 pages
                      [Mo Jun 13 18:56:30 2022] ftrace: allocated 149 pages with 4 groups
                      [Mo Jun 13 18:56:30 2022] trace event string verifier disabled
                      [Mo Jun 13 18:56:30 2022] rcu: Preemptible hierarchical RCU implementation.
                      [Mo Jun 13 18:56:30 2022] rcu:  RCU event tracing is enabled.
                      [Mo Jun 13 18:56:30 2022] rcu:  RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
                      [Mo Jun 13 18:56:30 2022]       Trampoline variant of Tasks RCU enabled.
                      [Mo Jun 13 18:56:30 2022]       Rude variant of Tasks RCU enabled.
                      [Mo Jun 13 18:56:30 2022]       Tracing variant of Tasks RCU enabled.
                      [Mo Jun 13 18:56:30 2022] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
                      [Mo Jun 13 18:56:30 2022] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
                      [Mo Jun 13 18:56:30 2022] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
                      [Mo Jun 13 18:56:30 2022] Root IRQ handler: gic_handle_irq
                      [Mo Jun 13 18:56:30 2022] GIC: Using split EOI/Deactivate mode
                      [Mo Jun 13 18:56:30 2022] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 10)
                      [Mo Jun 13 18:56:30 2022] random: get_random_bytes called from start_kernel+0x510/0x6f8 with crng_init=1
                      [Mo Jun 13 18:56:30 2022] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                      [Mo Jun 13 18:56:30 2022] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
                      [Mo Jun 13 18:56:30 2022] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
                      [Mo Jun 13 18:56:30 2022] Console: colour dummy device 80x25
                      [Mo Jun 13 18:56:30 2022] printk: console [tty1] enabled
                      [Mo Jun 13 18:56:30 2022] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
                      [Mo Jun 13 18:56:30 2022] pid_max: default: 32768 minimum: 301
                      [Mo Jun 13 18:56:30 2022] LSM: Security Framework initializing
                      [Mo Jun 13 18:56:30 2022] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
                      [Mo Jun 13 18:56:30 2022] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
                      [Mo Jun 13 18:56:30 2022] cgroup: Disabling memory control group subsystem
                      [Mo Jun 13 18:56:30 2022] rcu: Hierarchical SRCU implementation.
                      [Mo Jun 13 18:56:30 2022] EFI services will not be available.
                      [Mo Jun 13 18:56:30 2022] smp: Bringing up secondary CPUs ...
                      [Mo Jun 13 18:56:30 2022] Detected PIPT I-cache on CPU1
                      [Mo Jun 13 18:56:30 2022] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
                      [Mo Jun 13 18:56:30 2022] Detected PIPT I-cache on CPU2
                      [Mo Jun 13 18:56:30 2022] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
                      [Mo Jun 13 18:56:30 2022] Detected PIPT I-cache on CPU3
                      [Mo Jun 13 18:56:30 2022] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
                      [Mo Jun 13 18:56:30 2022] smp: Brought up 1 node, 4 CPUs
                      [Mo Jun 13 18:56:30 2022] SMP: Total of 4 processors activated.
                      [Mo Jun 13 18:56:30 2022] CPU features: detected: 32-bit EL0 Support
                      [Mo Jun 13 18:56:30 2022] CPU features: detected: 32-bit EL1 Support
                      [Mo Jun 13 18:56:30 2022] CPU features: detected: CRC32 instructions
                      [Mo Jun 13 18:56:30 2022] CPU: All CPU(s) started at EL2
                      [Mo Jun 13 18:56:30 2022] alternatives: patching kernel code
                      [Mo Jun 13 18:56:30 2022] devtmpfs: initialized
                      [Mo Jun 13 18:56:30 2022] Enabled cp15_barrier support
                      [Mo Jun 13 18:56:30 2022] Enabled setend support
                      [Mo Jun 13 18:56:30 2022] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
                      [Mo Jun 13 18:56:30 2022] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
                      [Mo Jun 13 18:56:30 2022] pinctrl core: initialized pinctrl subsystem
                      [Mo Jun 13 18:56:30 2022] DMI not present or invalid.
                      [Mo Jun 13 18:56:30 2022] NET: Registered PF_NETLINK/PF_ROUTE protocol family
                      [Mo Jun 13 18:56:30 2022] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
                      [Mo Jun 13 18:56:30 2022] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
                      [Mo Jun 13 18:56:30 2022] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
                      [Mo Jun 13 18:56:30 2022] audit: initializing netlink subsys (disabled)
                      [Mo Jun 13 18:56:30 2022] audit: type=2000 audit(0.076:1): state=initialized audit_enabled=0 res=1
                      [Mo Jun 13 18:56:30 2022] thermal_sys: Registered thermal governor 'step_wise'
                      [Mo Jun 13 18:56:30 2022] cpuidle: using governor menu
                      [Mo Jun 13 18:56:30 2022] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
                      [Mo Jun 13 18:56:30 2022] ASID allocator initialised with 65536 entries
                      [Mo Jun 13 18:56:30 2022] Serial: AMBA PL011 UART driver
                      [Mo Jun 13 18:56:30 2022] bcm2835-mbox fe00b880.mailbox: mailbox enabled
                      [Mo Jun 13 18:56:30 2022] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-03-24T13:19:26, variant start
                      [Mo Jun 13 18:56:30 2022] raspberrypi-firmware soc:firmware: Firmware hash is e5a963efa66a1974127860b42e913d2374139ff5
                      [Mo Jun 13 18:56:30 2022] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
                      [Mo Jun 13 18:56:30 2022] vgaarb: loaded
                      [Mo Jun 13 18:56:30 2022] SCSI subsystem initialized
                      [Mo Jun 13 18:56:30 2022] usbcore: registered new interface driver usbfs
                      [Mo Jun 13 18:56:30 2022] usbcore: registered new interface driver hub
                      [Mo Jun 13 18:56:30 2022] usbcore: registered new device driver usb
                      [Mo Jun 13 18:56:30 2022] usb_phy_generic phy: supply vcc not found, using dummy regulator
                      [Mo Jun 13 18:56:30 2022] pps_core: LinuxPPS API ver. 1 registered
                      [Mo Jun 13 18:56:30 2022] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
                      [Mo Jun 13 18:56:30 2022] PTP clock support registered
                      [Mo Jun 13 18:56:30 2022] clocksource: Switched to clocksource arch_sys_counter
                      [Mo Jun 13 18:56:30 2022] VFS: Disk quotas dquot_6.6.0
                      [Mo Jun 13 18:56:30 2022] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
                      [Mo Jun 13 18:56:30 2022] FS-Cache: Loaded
                      [Mo Jun 13 18:56:30 2022] CacheFiles: Loaded
                      [Mo Jun 13 18:56:30 2022] simple-framebuffer 3e2fe000.framebuffer: framebuffer at 0x3e2fe000, 0x7f8000 bytes
                      [Mo Jun 13 18:56:30 2022] simple-framebuffer 3e2fe000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
                      [Mo Jun 13 18:56:30 2022] Console: switching to colour frame buffer device 240x67
                      [Mo Jun 13 18:56:30 2022] simple-framebuffer 3e2fe000.framebuffer: fb0: simplefb registered!
                      [Mo Jun 13 18:56:30 2022] NET: Registered PF_INET protocol family
                      [Mo Jun 13 18:56:30 2022] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
                      [Mo Jun 13 18:56:30 2022] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
                      [Mo Jun 13 18:56:30 2022] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
                      [Mo Jun 13 18:56:30 2022] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
                      [Mo Jun 13 18:56:30 2022] TCP: Hash tables configured (established 65536 bind 65536)
                      [Mo Jun 13 18:56:30 2022] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
                      [Mo Jun 13 18:56:30 2022] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
                      [Mo Jun 13 18:56:30 2022] NET: Registered PF_UNIX/PF_LOCAL protocol family
                      [Mo Jun 13 18:56:30 2022] RPC: Registered named UNIX socket transport module.
                      [Mo Jun 13 18:56:30 2022] RPC: Registered udp transport module.
                      [Mo Jun 13 18:56:30 2022] RPC: Registered tcp transport module.
                      [Mo Jun 13 18:56:30 2022] RPC: Registered tcp NFSv4.1 backchannel transport module.
                      [Mo Jun 13 18:56:30 2022] PCI: CLS 0 bytes, default 64
                      [Mo Jun 13 18:56:30 2022] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
                      [Mo Jun 13 18:56:30 2022] kvm [1]: IPA Size Limit: 44 bits
                      [Mo Jun 13 18:56:30 2022] kvm [1]: vgic interrupt IRQ9
                      [Mo Jun 13 18:56:30 2022] kvm [1]: Hyp mode initialized successfully
                      [Mo Jun 13 18:56:31 2022] Initialise system trusted keyrings
                      [Mo Jun 13 18:56:31 2022] workingset: timestamp_bits=46 max_order=21 bucket_order=0
                      [Mo Jun 13 18:56:31 2022] zbud: loaded
                      [Mo Jun 13 18:56:31 2022] FS-Cache: Netfs 'nfs' registered for caching
                      [Mo Jun 13 18:56:31 2022] NFS: Registering the id_resolver key type
                      [Mo Jun 13 18:56:31 2022] Key type id_resolver registered
                      [Mo Jun 13 18:56:31 2022] Key type id_legacy registered
                      [Mo Jun 13 18:56:31 2022] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                      [Mo Jun 13 18:56:31 2022] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
                      [Mo Jun 13 18:56:31 2022] Key type asymmetric registered
                      [Mo Jun 13 18:56:31 2022] Asymmetric key parser 'x509' registered
                      [Mo Jun 13 18:56:31 2022] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
                      [Mo Jun 13 18:56:31 2022] io scheduler mq-deadline registered
                      [Mo Jun 13 18:56:31 2022] io scheduler kyber registered
                      [Mo Jun 13 18:56:31 2022] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
                      [Mo Jun 13 18:56:31 2022] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
                      [Mo Jun 13 18:56:31 2022] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
                      [Mo Jun 13 18:56:31 2022] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
                      [Mo Jun 13 18:56:31 2022] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
                      [Mo Jun 13 18:56:31 2022] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
                      [Mo Jun 13 18:56:31 2022] pci_bus 0000:00: root bus resource [bus 00-ff]
                      [Mo Jun 13 18:56:31 2022] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
                      [Mo Jun 13 18:56:31 2022] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
                      [Mo Jun 13 18:56:31 2022] pci 0000:00:00.0: PME# supported from D0 D3hot
                      [Mo Jun 13 18:56:31 2022] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
                      [Mo Jun 13 18:56:31 2022] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
                      [Mo Jun 13 18:56:31 2022] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
                      [Mo Jun 13 18:56:31 2022] pci 0000:01:00.0: PME# supported from D0 D3hot
                      [Mo Jun 13 18:56:31 2022] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
                      [Mo Jun 13 18:56:31 2022] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
                      [Mo Jun 13 18:56:31 2022] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
                      [Mo Jun 13 18:56:31 2022] pci 0000:00:00.0: PCI bridge to [bus 01]
                      [Mo Jun 13 18:56:31 2022] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
                      [Mo Jun 13 18:56:31 2022] iproc-rng200 fe104000.rng: hwrng registered
                      [Mo Jun 13 18:56:31 2022] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
                      [Mo Jun 13 18:56:31 2022] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
                      [Mo Jun 13 18:56:31 2022] cacheinfo: Unable to detect cache hierarchy for CPU 0
                      [Mo Jun 13 18:56:31 2022] brd: module loaded
                      [Mo Jun 13 18:56:31 2022] loop: module loaded
                      [Mo Jun 13 18:56:31 2022] Loading iSCSI transport class v2.0-870.
                      [Mo Jun 13 18:56:31 2022] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
                      [Mo Jun 13 18:56:31 2022] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
                      [Mo Jun 13 18:56:31 2022] usbcore: registered new interface driver r8152
                      [Mo Jun 13 18:56:31 2022] usbcore: registered new interface driver lan78xx
                      [Mo Jun 13 18:56:31 2022] usbcore: registered new interface driver smsc95xx
                      [Mo Jun 13 18:56:31 2022] pci 0000:00:00.0: enabling device (0000 -> 0002)
                      [Mo Jun 13 18:56:31 2022] xhci_hcd 0000:01:00.0: xHCI Host Controller
                      [Mo Jun 13 18:56:31 2022] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
                      [Mo Jun 13 18:56:31 2022] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x00003c0000000890
                      [Mo Jun 13 18:56:31 2022] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
                      [Mo Jun 13 18:56:31 2022] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                      [Mo Jun 13 18:56:31 2022] usb usb1: Product: xHCI Host Controller
                      [Mo Jun 13 18:56:31 2022] usb usb1: Manufacturer: Linux 5.15.32-v8+ xhci-hcd
                      [Mo Jun 13 18:56:31 2022] usb usb1: SerialNumber: 0000:01:00.0
                      [Mo Jun 13 18:56:31 2022] hub 1-0:1.0: USB hub found
                      [Mo Jun 13 18:56:31 2022] hub 1-0:1.0: 1 port detected
                      [Mo Jun 13 18:56:31 2022] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
                      [Mo Jun 13 18:56:31 2022] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
                      [Mo Jun 13 18:56:31 2022] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
                      [Mo Jun 13 18:56:31 2022] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                      [Mo Jun 13 18:56:31 2022] usb usb2: Product: xHCI Host Controller
                      [Mo Jun 13 18:56:31 2022] usb usb2: Manufacturer: Linux 5.15.32-v8+ xhci-hcd
                      [Mo Jun 13 18:56:31 2022] usb usb2: SerialNumber: 0000:01:00.0
                      [Mo Jun 13 18:56:31 2022] hub 2-0:1.0: USB hub found
                      [Mo Jun 13 18:56:31 2022] hub 2-0:1.0: 4 ports detected
                      [Mo Jun 13 18:56:31 2022] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                      [Mo Jun 13 18:56:31 2022] dwc_otg: FIQ enabled
                      [Mo Jun 13 18:56:31 2022] dwc_otg: NAK holdoff enabled
                      [Mo Jun 13 18:56:31 2022] dwc_otg: FIQ split-transaction FSM enabled
                      [Mo Jun 13 18:56:31 2022] Module dwc_common_port init
                      [Mo Jun 13 18:56:31 2022] usbcore: registered new interface driver uas
                      [Mo Jun 13 18:56:31 2022] usbcore: registered new interface driver usb-storage
                      [Mo Jun 13 18:56:31 2022] mousedev: PS/2 mouse device common for all mice
                      [Mo Jun 13 18:56:31 2022] sdhci: Secure Digital Host Controller Interface driver
                      [Mo Jun 13 18:56:31 2022] sdhci: Copyright(c) Pierre Ossman
                      [Mo Jun 13 18:56:31 2022] sdhci-pltfm: SDHCI platform and OF driver helper
                      [Mo Jun 13 18:56:31 2022] ledtrig-cpu: registered to indicate activity on CPUs
                      [Mo Jun 13 18:56:31 2022] hid: raw HID events driver (C) Jiri Kosina
                      [Mo Jun 13 18:56:31 2022] usbcore: registered new interface driver usbhid
                      [Mo Jun 13 18:56:31 2022] usbhid: USB HID core driver
                      [Mo Jun 13 18:56:31 2022] ashmem: initialized
                      [Mo Jun 13 18:56:31 2022] Initializing XFRM netlink socket
                      [Mo Jun 13 18:56:31 2022] NET: Registered PF_PACKET protocol family
                      [Mo Jun 13 18:56:31 2022] Key type dns_resolver registered
                      [Mo Jun 13 18:56:31 2022] registered taskstats version 1
                      [Mo Jun 13 18:56:31 2022] Loading compiled-in X.509 certificates
                      [Mo Jun 13 18:56:31 2022] Key type ._fscrypt registered
                      [Mo Jun 13 18:56:31 2022] Key type .fscrypt registered
                      [Mo Jun 13 18:56:31 2022] Key type fscrypt-provisioning registered
                      [Mo Jun 13 18:56:31 2022] uart-pl011 fe201000.serial: there is not valid maps for state default
                      [Mo Jun 13 18:56:31 2022] uart-pl011 fe201000.serial: cts_event_workaround enabled
                      [Mo Jun 13 18:56:31 2022] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 19, base_baud = 0) is a PL011 rev2
                      [Mo Jun 13 18:56:31 2022] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                      [Mo Jun 13 18:56:31 2022] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
                      [Mo Jun 13 18:56:31 2022] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                      [Mo Jun 13 18:56:31 2022] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                      [Mo Jun 13 18:56:31 2022] of_cfs_init
                      [Mo Jun 13 18:56:31 2022] of_cfs_init: OK
                      [Mo Jun 13 18:56:31 2022] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
                      [Mo Jun 13 18:56:31 2022] Waiting for root device PARTUUID=e16dce5c-02...
                      [Mo Jun 13 18:56:31 2022] usb 1-1: new high-speed USB device number 2 using xhci_hcd
                      [Mo Jun 13 18:56:31 2022] mmc1: new high speed SDIO card at address 0001
                      [Mo Jun 13 18:56:31 2022] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
                      [Mo Jun 13 18:56:31 2022] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
                      [Mo Jun 13 18:56:31 2022] usb 1-1: Product: USB2.0 Hub
                      [Mo Jun 13 18:56:31 2022] hub 1-1:1.0: USB hub found
                      [Mo Jun 13 18:56:31 2022] hub 1-1:1.0: 4 ports detected
                      [Mo Jun 13 18:56:32 2022] usb 2-2: new SuperSpeed USB device number 2 using xhci_hcd
                      [Mo Jun 13 18:56:32 2022] usb 2-2: New USB device found, idVendor=174c, idProduct=55aa, bcdDevice= 1.00
                      [Mo Jun 13 18:56:32 2022] usb 2-2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
                      [Mo Jun 13 18:56:32 2022] usb 2-2: Product: USB3-SATA-Device
                      [Mo Jun 13 18:56:32 2022] usb 2-2: Manufacturer: CnMemory
                      [Mo Jun 13 18:56:32 2022] usb 2-2: SerialNumber: 123456789012
                      [Mo Jun 13 18:56:32 2022] scsi host0: uas
                      [Mo Jun 13 18:56:32 2022] scsi 0:0:0:0: Direct-Access     SanDisk  SSD PLUS 240GB   0    PQ: 0 ANSI: 6
                      [Mo Jun 13 18:56:32 2022] sd 0:0:0:0: [sda] 468862128 512-byte logical blocks: (240 GB/224 GiB)
                      [Mo Jun 13 18:56:32 2022] sd 0:0:0:0: [sda] Write Protect is off
                      [Mo Jun 13 18:56:32 2022] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
                      [Mo Jun 13 18:56:32 2022] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
                      [Mo Jun 13 18:56:32 2022] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
                      [Mo Jun 13 18:56:32 2022]  sda: sda1 sda2
                      [Mo Jun 13 18:56:32 2022] sd 0:0:0:0: [sda] Attached SCSI disk
                      [Mo Jun 13 18:56:32 2022] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Mo Jun 13 18:56:32 2022] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                      [Mo Jun 13 18:56:32 2022] devtmpfs: mounted
                      [Mo Jun 13 18:56:32 2022] Freeing unused kernel memory: 3776K
                      [Mo Jun 13 18:56:32 2022] Run /sbin/init as init process
                      [Mo Jun 13 18:56:32 2022]   with arguments:
                      [Mo Jun 13 18:56:32 2022]     /sbin/init
                      [Mo Jun 13 18:56:32 2022]   with environment:
                      [Mo Jun 13 18:56:32 2022]     HOME=/
                      [Mo Jun 13 18:56:32 2022]     TERM=linux
                      [Mo Jun 13 18:56:32 2022] usb 1-1.1: new full-speed USB device number 3 using xhci_hcd
                      [Mo Jun 13 18:56:32 2022] usb 1-1.1: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
                      [Mo Jun 13 18:56:32 2022] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                      [Mo Jun 13 18:56:32 2022] usb 1-1.1: Product: Sonoff Zigbee 3.0 USB Dongle Plus
                      [Mo Jun 13 18:56:32 2022] usb 1-1.1: Manufacturer: ITead
                      [Mo Jun 13 18:56:32 2022] usb 1-1.1: SerialNumber: f87fbb8463c9eb11b1448b4f1d69213e
                      [Mo Jun 13 18:56:32 2022] systemd[1]: System time before build time, advancing clock.
                      [Mo Jun 13 18:56:32 2022] usb 1-1.3: new full-speed USB device number 4 using xhci_hcd
                      [Mo Jun 13 18:56:32 2022] NET: Registered PF_INET6 protocol family
                      [Mo Jun 13 18:56:32 2022] Segment Routing with IPv6
                      [Mo Jun 13 18:56:32 2022] In-situ OAM (IOAM) with IPv6
                      [Mo Jun 13 18:56:32 2022] systemd[1]: systemd 247.3-7 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
                      [Mo Jun 13 18:56:32 2022] systemd[1]: Detected architecture arm64.
                      [Mo Jun 13 18:56:32 2022] systemd[1]: Set hostname to <raspberrypi>.
                      [Mo Jun 13 18:56:32 2022] usb 1-1.3: New USB device found, idVendor=25a7, idProduct=fa23, bcdDevice= 2.32
                      [Mo Jun 13 18:56:32 2022] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
                      [Mo Jun 13 18:56:32 2022] usb 1-1.3: Product: 2.4G Receiver
                      [Mo Jun 13 18:56:32 2022] usb 1-1.3: Manufacturer: Compx
                      [Mo Jun 13 18:56:32 2022] input: Compx 2.4G Receiver as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:25A7:FA23.0001/input/input0
                      [Mo Jun 13 18:56:32 2022] hid-generic 0003:25A7:FA23.0001: input,hidraw0: USB HID v1.10 Keyboard [Compx 2.4G Receiver] on usb-0000:01:00.0-1.3/input0
                      [Mo Jun 13 18:56:32 2022] input: Compx 2.4G Receiver Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:25A7:FA23.0002/input/input1
                      [Mo Jun 13 18:56:32 2022] input: Compx 2.4G Receiver as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:25A7:FA23.0002/input/input2
                      [Mo Jun 13 18:56:32 2022] input: Compx 2.4G Receiver Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:25A7:FA23.0002/input/input3
                      [Mo Jun 13 18:56:32 2022] input: Compx 2.4G Receiver System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:25A7:FA23.0002/input/input4
                      [Mo Jun 13 18:56:32 2022] hid-generic 0003:25A7:FA23.0002: input,hiddev96,hidraw1: USB HID v1.10 Mouse [Compx 2.4G Receiver] on usb-0000:01:00.0-1.3/input1
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Queued start job for default target Multi-User System.
                      [Mo Jun 13 18:56:33 2022] random: systemd: uninitialized urandom read (16 bytes read)
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Created slice system-getty.slice.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Created slice system-modprobe.slice.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Created slice system-systemd\x2dfsck.slice.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Created slice User and Session Slice.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Reached target Local Encrypted Volumes.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Reached target Paths.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Reached target Slices.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Reached target Swap.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Listening on Syslog Socket.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Listening on fsck to fsckd communication Socket.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Listening on initctl Compatibility Named Pipe.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Listening on Journal Audit Socket.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Listening on Journal Socket (/dev/log).
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Listening on Journal Socket.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Listening on udev Control Socket.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Listening on udev Kernel Socket.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Mounting POSIX Message Queue File System...
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Mounting RPC Pipe File System...
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Mounting Kernel Debug File System...
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Mounting Kernel Trace File System...
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Starting Restore / save the current clock...
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Starting Set the console keyboard layout...
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Starting Create list of static device nodes for the current kernel...
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Starting Load Kernel Module configfs...
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Starting Load Kernel Module drm...
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Starting Load Kernel Module fuse...
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Starting File System Check on Root Device...
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Starting Journal Service...
                      [Mo Jun 13 18:56:33 2022] fuse: init (API version 7.34)
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Starting Load Kernel Modules...
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Starting Coldplug All udev Devices...
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Mounted POSIX Message Queue File System.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Mounted RPC Pipe File System.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Mounted Kernel Debug File System.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Mounted Kernel Trace File System.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Finished Restore / save the current clock.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Finished Create list of static device nodes for the current kernel.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: modprobe@configfs.service: Succeeded.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Finished Load Kernel Module configfs.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: modprobe@drm.service: Succeeded.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Finished Load Kernel Module drm.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: modprobe@fuse.service: Succeeded.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Finished Load Kernel Module fuse.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Finished Load Kernel Modules.
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Mounting FUSE Control File System...
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Mounting Kernel Configuration File System...
                      [Mo Jun 13 18:56:33 2022] systemd[1]: Started File System Check Daemon to report status.
                      [Mo Jun 13 18:56:34 2022] systemd[1]: Starting Apply Kernel Variables...
                      [Mo Jun 13 18:56:34 2022] systemd[1]: Mounted FUSE Control File System.
                      [Mo Jun 13 18:56:34 2022] systemd[1]: Mounted Kernel Configuration File System.
                      [Mo Jun 13 18:56:34 2022] systemd[1]: Finished Apply Kernel Variables.
                      [Mo Jun 13 18:56:34 2022] systemd[1]: Finished Set the console keyboard layout.
                      [Mo Jun 13 18:56:34 2022] systemd[1]: Started Journal Service.
                      [Mo Jun 13 18:56:34 2022] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
                      [Mo Jun 13 18:56:34 2022] systemd-journald[142]: Received client request to flush runtime journal.
                      [Mo Jun 13 18:56:35 2022] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
                      [Mo Jun 13 18:56:35 2022] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
                      [Mo Jun 13 18:56:35 2022] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
                      [Mo Jun 13 18:56:35 2022] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
                      [Mo Jun 13 18:56:35 2022] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                      [Mo Jun 13 18:56:35 2022] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                      [Mo Jun 13 18:56:35 2022] [vc_sm_connected_init]: start
                      [Mo Jun 13 18:56:35 2022] mc: Linux media interface: v0.10
                      [Mo Jun 13 18:56:35 2022] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                      [Mo Jun 13 18:56:35 2022] [vc_sm_connected_init]: installed successfully
                      [Mo Jun 13 18:56:35 2022] bcm2835_audio bcm2835_audio: card created with 8 channels
                      [Mo Jun 13 18:56:35 2022] brcmstb-i2c fef04500.i2c:  @97500hz registered in polling mode
                      [Mo Jun 13 18:56:35 2022] brcmstb-i2c fef09500.i2c:  @97500hz registered in polling mode
                      [Mo Jun 13 18:56:35 2022] videodev: Linux video capture interface: v2.00
                      [Mo Jun 13 18:56:35 2022] random: crng init done
                      [Mo Jun 13 18:56:35 2022] random: 7 urandom warning(s) missed due to ratelimiting
                      [Mo Jun 13 18:56:35 2022] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                      [Mo Jun 13 18:56:35 2022] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                      [Mo Jun 13 18:56:35 2022] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
                      [Mo Jun 13 18:56:35 2022] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                      [Mo Jun 13 18:56:35 2022] checking generic (3e2fe000 7f8000) vs hw (0 ffffffffffffffff)
                      [Mo Jun 13 18:56:35 2022] fb0: switching to vc4 from simple
                      [Mo Jun 13 18:56:35 2022] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
                      [Mo Jun 13 18:56:35 2022] Console: switching to colour dummy device 80x25
                      [Mo Jun 13 18:56:35 2022] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
                      [Mo Jun 13 18:56:35 2022] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
                      [Mo Jun 13 18:56:35 2022] Registered IR keymap rc-cec
                      [Mo Jun 13 18:56:35 2022] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
                      [Mo Jun 13 18:56:35 2022] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
                      [Mo Jun 13 18:56:35 2022] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
                      [Mo Jun 13 18:56:35 2022] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
                      [Mo Jun 13 18:56:35 2022] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                      [Mo Jun 13 18:56:35 2022] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                      [Mo Jun 13 18:56:35 2022] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                      [Mo Jun 13 18:56:35 2022] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                      [Mo Jun 13 18:56:35 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input6
                      [Mo Jun 13 18:56:35 2022] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
                      [Mo Jun 13 18:56:35 2022] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                      [Mo Jun 13 18:56:35 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                      [Mo Jun 13 18:56:35 2022] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                      [Mo Jun 13 18:56:35 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                      [Mo Jun 13 18:56:35 2022] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
                      [Mo Jun 13 18:56:35 2022] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                      [Mo Jun 13 18:56:35 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                      [Mo Jun 13 18:56:35 2022] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
                      [Mo Jun 13 18:56:35 2022] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
                      [Mo Jun 13 18:56:35 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
                      [Mo Jun 13 18:56:35 2022] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
                      [Mo Jun 13 18:56:35 2022] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                      [Mo Jun 13 18:56:35 2022] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                      [Mo Jun 13 18:56:35 2022] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
                      [Mo Jun 13 18:56:35 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
                      [Mo Jun 13 18:56:35 2022] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                      [Mo Jun 13 18:56:35 2022] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
                      [Mo Jun 13 18:56:36 2022] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
                      [Mo Jun 13 18:56:36 2022] Registered IR keymap rc-cec
                      [Mo Jun 13 18:56:36 2022] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
                      [Mo Jun 13 18:56:36 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input7
                      [Mo Jun 13 18:56:36 2022] brcmfmac: F1 signature read @0x18000000=0x15264345
                      [Mo Jun 13 18:56:36 2022] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                      [Mo Jun 13 18:56:36 2022] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.bin failed with error -2
                      [Mo Jun 13 18:56:36 2022] usbcore: registered new interface driver brcmfmac
                      [Mo Jun 13 18:56:36 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input8
                      [Mo Jun 13 18:56:36 2022] sd 0:0:0:0: Attached scsi generic sg0 type 0
                      [Mo Jun 13 18:56:36 2022] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov  1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
                      [Mo Jun 13 18:56:36 2022] usbcore: registered new interface driver usbserial_generic
                      [Mo Jun 13 18:56:36 2022] usbserial: USB Serial support registered for generic
                      [Mo Jun 13 18:56:36 2022] usbcore: registered new interface driver cp210x
                      [Mo Jun 13 18:56:36 2022] usbserial: USB Serial support registered for cp210x
                      [Mo Jun 13 18:56:36 2022] cp210x 1-1.1:1.0: cp210x converter detected
                      [Mo Jun 13 18:56:36 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input9
                      [Mo Jun 13 18:56:36 2022] usb 1-1.1: cp210x converter now attached to ttyUSB0
                      [Mo Jun 13 18:56:36 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input10
                      [Mo Jun 13 18:56:37 2022] Registered IR keymap rc-cec
                      [Mo Jun 13 18:56:37 2022] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
                      [Mo Jun 13 18:56:37 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input11
                      [Mo Jun 13 18:56:37 2022] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
                      [Mo Jun 13 18:56:37 2022] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
                      [Mo Jun 13 18:56:37 2022] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input12
                      [Mo Jun 13 18:56:37 2022] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
                      [Mo Jun 13 18:56:37 2022] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
                      [Mo Jun 13 18:56:37 2022] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
                      [Mo Jun 13 18:56:37 2022] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
                      [Mo Jun 13 18:56:37 2022] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
                      [Mo Jun 13 18:56:37 2022] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
                      [Mo Jun 13 18:56:37 2022] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
                      [Mo Jun 13 18:56:37 2022] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
                      [Mo Jun 13 18:56:37 2022] Console: switching to colour frame buffer device 240x67
                      [Mo Jun 13 18:56:37 2022] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
                      [Mo Jun 13 18:56:38 2022] 8021q: 802.1Q VLAN Support v1.8
                      [Mo Jun 13 18:56:38 2022] uart-pl011 fe201000.serial: no DMA platform data
                      [Mo Jun 13 18:56:38 2022] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
                      [Mo Jun 13 18:56:38 2022] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
                      [Mo Jun 13 18:56:39 2022] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
                      [Mo Jun 13 18:56:39 2022] bcmgenet fd580000.ethernet eth0: Link is Down
                      [Mo Jun 13 18:56:44 2022] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
                      [Mo Jun 13 18:56:44 2022] Bluetooth: Core ver 2.22
                      [Mo Jun 13 18:56:44 2022] NET: Registered PF_BLUETOOTH protocol family
                      [Mo Jun 13 18:56:44 2022] Bluetooth: HCI device and connection manager initialized
                      [Mo Jun 13 18:56:44 2022] Bluetooth: HCI socket layer initialized
                      [Mo Jun 13 18:56:44 2022] Bluetooth: L2CAP socket layer initialized
                      [Mo Jun 13 18:56:44 2022] Bluetooth: SCO socket layer initialized
                      [Mo Jun 13 18:56:44 2022] Bluetooth: HCI UART driver ver 2.3
                      [Mo Jun 13 18:56:44 2022] Bluetooth: HCI UART protocol H4 registered
                      [Mo Jun 13 18:56:44 2022] Bluetooth: HCI UART protocol Three-wire (H5) registered
                      [Mo Jun 13 18:56:44 2022] Bluetooth: HCI UART protocol Broadcom registered
                      [Mo Jun 13 18:56:45 2022] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                      [Mo Jun 13 18:56:45 2022] Bluetooth: BNEP filters: protocol multicast
                      [Mo Jun 13 18:56:45 2022] Bluetooth: BNEP socket layer initialized
                      [Mo Jun 13 18:56:45 2022] NET: Registered PF_ALG protocol family
                      [Mo Jun 13 18:57:03 2022] cam-dummy-reg: disabling
                      [Mo Jun 13 18:57:49 2022] device wlan0 entered promiscuous mode
                      [Mo Jun 13 18:57:53 2022] FS-Cache: Netfs 'cifs' registered for caching
                      [Mo Jun 13 18:57:53 2022] Key type cifs.spnego registered
                      [Mo Jun 13 18:57:53 2022] Key type cifs.idmap registered
                      [Mo Jun 13 18:57:53 2022] CIFS: Attempting to mount \\192.168.178.1\fritz.nas
                      Es sind wirklich nur die lampen betroffen wie man sieht
                      • D denjo
                        @denjo
                        Da sieht man nicht die Absteck/Einsteck-Aktion des Sticks.
                        Und räum mal die USB3.0-Ports frei.
                        Da hängt deine SSD dran, stimmt's?
                        Und die Funkmaus auch abklemmen. Per SSH auf den 'headless'-Rechner gehen.
                        • D denjo
                          OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          hm wenn du sagst du bist auf 64bit umgestiegen, was meinst du dann genau?
                          du hast doch dann das 64bit betriebssystem neu geladen?
                          wenn du dann den zigbee treiber installierst, dann wir automatisch der 64bit treiber installiert, sofern es den gibt. ansonsten wird der 32bit treiber installiert und dann besonders adressiert.
                          kannst du evtl noch ein bisschen mehr zu verwendete hardware, verwendetes betriebssystem und verwendeten zigbee-empfänger sagen?
                          wenn du nur das betriebssystem ausgetauscht hast, dann könnte das problem mehr auf betriebssystem/treiber ebene befinden und eher nicht am adapter/iobroker.
                          Meine Adapter und Widgets
                          Links im Profil
                          • DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            Wird bei der 64er Version auch Node und NPM in anderen(höheren) Versionen mitgegeben ?
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v16.15.1
                            v16.15.1
                            8.11.0
                            oder hat das damit nix zu tun?
                            Lehrling seit 1975 !!!
                            • DJMarc75D DJMarc75
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v16.15.1
                              v16.15.1
                              8.11.0
                              @djmarc75 sagte in zigbee 64 bit???:
                              Es wird die Version aus dem von dir eingestellten Repo eingespielt. Hat mit der Prozessorarchitektur nix zu tun.
                                denjo
                                @thomas-braun ich bekomme gerade den stick nicht in bootloader mode zum flashen, das kommt mir gerade komisch vor???
                                • D denjo
                                  Würde es mir auch.
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    v16.15.1
                                    v16.15.1
                                    8.11.0
                                    OliverIOO Offline
                                    OliverIOO Offline
                                    OliverIO
                                    @djmarc75
                                    @Thomas-Braun
                                    eigentlich schon, da 32bit und 64bit schon eine unterschiedliche prozessorarchitektur ist.
                                    auch wenn es die gleiche programmversion ist, wird ein unterschiedliches programm geladen, da für 32bit und 64bit schon unterschiedlich kompiliert wird.
                                    hier am beispiel des debian repositiory für nodejs
                                    https://packages.debian.org/bullseye/nodejs
                                    für diese architekturen liegt das programm vor. und das ist binär gesehen immer unterschiedlich
                                    amd64 arm64 armhf i386 mips mips64el mipsel ppc64el s390x
                                    wenn du 32bit hast wird armhf geladen
                                    wenn du 64bit hast wird arm64 geladen
                                    bei raspi ist die besonderheit, das ein 32bit betriebssystem auf einem 64bit prozessor läuft. für programme ist aber der typ des betriebssystem relevant. das betriebssystem regelt dann die kommunikation zwischen 32bit bs und 64bit prozessor
                                    Links im Profil
                                    • OliverIOO OliverIO
                                      @djmarc75
                                      @Thomas-Braun
                                      @oliverio sagte in zigbee 64 bit???:
                                      Ja, natürlich sind es anders gebaute Versionen.
                                      Ich vermute aber, dass es @DJMarc75 um die Version nodejs@16 ging.
                                      Und die installierte node-Version hängt primär vom eingestellten Repo ab, nicht von der Architektur.
                                      DJMarc75D D 2 Antworten Letzte Antwort
                                        DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        Richtig.
                                        Mir ist das halt bei @denjo aufgefallen dass bei ihm eben diese höheren Versionen installiert sind.
                                        Ich selbst bin auf 32bit und hab diese Versionen installiert 👇
                                          Richtig.
                                          denjo
                                          @djmarc75 ich habe die version installiert weil der ring adapter sie barucht.
