  4. Zigbee Adapter Geräte alle Offline
    6.3k
6 Beiträge 2 Kommentatoren 684 Aufrufe 2 Beobachtet
  • C Offline
    Cino
    Systemdata Bitte Ausfüllen
    Hardwaresystem: RPI4b
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte 64 GB
    Betriebssystem: RpiOS
    Node-Version: 14
    Nodejs-Version: 14.9.1
    NPM-Version: 6.x.x
    Installationsart: Skript
    Image genutzt: Nein
    Ich habe mit dem Zigbee Adapter über Nacht ein Problem gehabt.
    2022-04-29 00:33:45.970 - error: zigbee.0 (2861136) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-04-29 00:33:45.971 - error: zigbee.0 (2861136) unhandled promise rejection: Cannot read property 'mapped' of undefined
    2022-04-29 00:33:45.973 - error: zigbee.0 (2861136) TypeError: Cannot read property 'mapped' of undefined
    at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:502:36)
    at runMicrotasks ()
    at processTicksAndRejections (internal/process/task_queues.js:95:5)
    2022-04-29 00:33:45.974 - error: zigbee.0 (2861136) Cannot read property 'mapped' of undefined
    2022-04-29 00:33:45.984 - info: zigbee.0 (2861136) cleaned everything up...
    2022-04-29 00:33:45.995 - info: zigbee.0 (2861136) Zigbee: disabling joining new devices.
    2022-04-29 00:33:46.092 - info: wled.0 (560779) WLED_Monitor connected
    2022-04-29 00:33:46.431 - info: zigbee.0 (2861136) terminating
    2022-04-29 00:33:46.433 - warn: zigbee.0 (2861136) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-04-29 00:33:47.106 - error: host.server Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-04-29 00:33:47.107 - error: host.server Caught by controller[0]: TypeError: Cannot read property 'mapped' of undefined
    2022-04-29 00:33:47.107 - error: host.server Caught by controller[0]: at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:502:36)
    2022-04-29 00:33:47.108 - error: host.server Caught by controller[0]: at runMicrotasks ()
    2022-04-29 00:33:47.108 - error: host.server Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:95:5)
    2022-04-29 00:33:47.108 - error: host.server instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    Nach einem Neustart wird nur ein einziges Gerät erkannt.
    zigbee.0
    2022-04-29 01:32:45.698	info	Zigbee started
    zigbee.0
    2022-04-29 01:32:45.696	info	0xec1bbdfffea3e3fd (addr 56970): HG06336 - Lidl Silvercrest smart window and door sensor (EndDevice)
    zigbee.0
    2022-04-29 01:32:45.672	info	Currently 1 devices are joined:
    zigbee.0
    2022-04-29 01:32:45.635	info	--> transmitPower : normal
    zigbee.0
    2022-04-29 01:32:45.583	info	Unable to disable LED, unsupported function.
    {1}
    zigbee.0
    2022-04-29 01:32:45.564	info	Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20201127}}
    zigbee.0
    2022-04-29 01:32:45.126	info	Installed Version: iobroker.zigbee@1.6.18
    zigbee.0
    2022-04-29 01:32:44.368	info	Starting Zigbee npm ...
    zigbee.0
    2022-04-29 01:32:44.145	info	starting. Version 1.6.18 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.1, js-controller: 4.0.23
    Alle anderen Geräte sind Offline.
    IOB@RPI4
    Shelly, Zigbee, ebus
    • C Cino
      Node-Version: 14
      NPM-Version: 6.x.x
      Image genutzt: Nein
      at runMicrotasks ()
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      {1}
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @cino
      anscheinend wurde die device Datenbank nicht sauber geschrieben.
      bitte die Dateien /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json und /opt/iobroker/iobroker-data/zigbee_0/shepherd.db durch das letzte backup ersetzen. In dem Verzeichnis sollten einige Kandidaten fürs Backup verfügbar sein (gzipped)
      A.
      • C Offline
        Cino
        Habe ich gemacht. Danach kamen noch 2 Geräte online.
        Der Rest ist immer noch Offline. Leider. Habe jetzt einige Tage verstreichen lassen weil ich dachte das kommt schon. Ist aber leider nicht.
        IOB@RPI4
        • C Cino
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @cino Die Frage ist weniger wie viele Geräte online kommen als wieviele Geräte bei Adapterstart als "verbunden" gemeldet sind.
          zigbee.0 2022-04-29 01:32:45.672	info	Currently 1 devices are joined:
          A.
          C 1 Antwort Letzte Antwort
          • AsgothianA Asgothian
            A.
            Cino
            schrieb am zuletzt editiert von Cino
            @asgothian
            zigbee.0
            895141	2022-05-06 14:03:46.308	error	Device 0xb4e3f9fffe67f677 "undefined" not described in statesMapping.
            zigbee.0
            895141	2022-05-06 14:03:46.301	error	Device 0xb4e3f9fffe68009f "undefined" not described in statesMapping.
            zigbee.0
            895141	2022-05-06 14:03:46.293	error	Device 0x00124b00250485db "undefined" not described in statesMapping.
            zigbee.0
            895141	2022-05-06 14:03:46.281	error	Device 0xb4e3f9fffe67b790 "undefined" not described in statesMapping.
            zigbee.0
            895141	2022-05-06 14:03:46.274	error	Device 0xb4e3f9fffe80caac "undefined" not described in statesMapping.
            zigbee.0
            895141	2022-05-06 14:03:45.822	info	Zigbee started
            zigbee.0
            895141	2022-05-06 14:03:45.821	info	0xec1bbdfffea3e3fd (addr 56970): HG06336 - Lidl Silvercrest smart window and door sensor (EndDevice)
            zigbee.0
            895141	2022-05-06 14:03:45.819	info	0xb4e3f9fffe67f677 (addr 55114): Not supported (model undefined)(EndDevice)
            zigbee.0
            895141	2022-05-06 14:03:45.819	info	0xb4e3f9fffe68009f (addr 36114): Not supported (model undefined)(Unknown)
            zigbee.0
            895141	2022-05-06 14:03:45.818	info	0x00124b00250485db (addr 37696): Not supported (model undefined)(Unknown)
            zigbee.0
            895141	2022-05-06 14:03:45.817	info	0xb4e3f9fffe67b790 (addr 9348): Not supported (model undefined)(Unknown)
            zigbee.0
            895141	2022-05-06 14:03:45.817	info	0xb4e3f9fffe80caac (addr 55852): Not supported (model undefined)(EndDevice)
            zigbee.0
            895141	2022-05-06 14:03:45.816	info	0xb4e3f9fffe6811c2 (addr 3852): E1812 - IKEA TRADFRI shortcut button (EndDevice)
            zigbee.0
            895141	2022-05-06 14:03:45.814	info	0xb4e3f9fffe680259 (addr 14071): E1525/E1745 - IKEA TRADFRI motion sensor (EndDevice)
            zigbee.0
            895141	2022-05-06 14:03:45.812	info	0x847127fffe53e6e8 (addr 42442): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
            zigbee.0
            895141	2022-05-06 14:03:45.810	info	0x5c0272fffecbe6b7 (addr 26390): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice)
            zigbee.0
            895141	2022-05-06 14:03:45.807	info	0xec1bbdfffea3e3a7 (addr 5980): HG06336 - Lidl Silvercrest smart window and door sensor (EndDevice)
            zigbee.0
            895141	2022-05-06 14:03:45.805	info	0xec1bbdfffe8d3cb3 (addr 46572): HG06336 - Lidl Silvercrest smart window and door sensor (EndDevice)
            zigbee.0
            895141	2022-05-06 14:03:45.796	info	0xec1bbdfffeb7354c (addr 256): HG06336 - Lidl Silvercrest smart window and door sensor (EndDevice)
            zigbee.0
            895141	2022-05-06 14:03:45.715	info	Currently 13 devices are joined:
            zigbee.0
            895141	2022-05-06 14:03:45.696	info	--> transmitPower : normal
            zigbee.0
            895141	2022-05-06 14:03:45.668	info	Unable to disable LED, unsupported function.
            zigbee.0
            895141	2022-05-06 14:03:45.666	info	Disable LED
            zigbee.0
            895141	2022-05-06 14:03:45.657	info	Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20201127}}
            zigbee.0
            895141	2022-05-06 14:03:45.210	info	Installed Version: iobroker.zigbee@1.6.18
            zigbee.0
            895141	2022-05-06 14:03:44.576	info	Starting Zigbee npm ...
            zigbee.0
            895141	2022-05-06 14:03:44.443	info	starting. Version 1.6.18 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.1, js-controller: 4.0.23
            zigbee.0
            807672	2022-05-06 14:03:37.492	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            zigbee.0
            807672	2022-05-06 14:03:37.491	info	terminating
            zigbee.0
            807672	2022-05-06 14:03:37.043	info	Zigbee: disabling joining new devices.
            zigbee.0
            807672	2022-05-06 14:03:36.994	info	cleaned everything up...
            zigbee.0
            807672	2022-05-06 14:03:36.992	info	Got terminate signal TERMINATE_YOURSELF
            IOB@RPI4
            • C Offline
              Cino
              So sieht es nach einem Adapterneustart aus.
              IOB@RPI4
