  4. Fehler nach Update des "Admin" Adapters
    6.3k
14 Beiträge 3 Kommentatoren 458 Aufrufe 2 Beobachtet
  • I IFOX
    Ich habe nun ein upgrade durchlaufen lassen mit
    sudo apt update
    sudo apt upgrade
    und im Anschluss nach der Analeitung den Status anzeigen lassen
    pi@raspberrypi:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    armv7l
    /usr/bin/nodejs
    /usr/local/bin/node
    /usr/local/bin/npm
    v16.15.0
    v16.13.1
    8.1.2
    pi
    /home/pi
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
    Hit:4 https://www.pivccu.de/piVCCU stable InRelease
    Reading package lists... Done
    Building dependency tree
    All packages are up to date.
    nodejs:
      Installed: 16.15.0-deb-1nodesource1
      Candidate: 16.15.0-deb-1nodesource1
      Version table:
     *** 16.15.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u1 500
    pi@raspberrypi:~ $ iobroker status
    Uncaught Rejection: Error: Cannot find module '@sentry/integrations'
    Require stack:
    - /opt/iobroker/node_modules/@iobroker/plugin-sentry/index.js
    - /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginHandler.js
    - /opt/iobroker/node_modules/@iobroker/plugin-base/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
        at Function.Module._load (node:internal/modules/cjs/loader:778:27)
        at Module.require (node:internal/modules/cjs/loader:1005:19)
        at require (node:internal/modules/cjs/helpers:102:18)
        at SentryPlugin._registerSentry (/opt/iobroker/node_modules/@iobroker/plugin-sentry/index.js:103:36)
        at SentryPlugin.init (/opt/iobroker/node_modules/@iobroker/plugin-sentry/index.js:96:14)
    An den Versionen hat sich aber leider nichts geändert und der iobroker startet nach wie nicht.
    @ifox
    Du musst da was ändern. Das macht das System nicht von alleine.
    I 1 Antwort Letzte Antwort
      @ifox
      I Offline
      I Offline
      IFOX
      schrieb am zuletzt editiert von IFOX
      Ich habe nun nach der Anleitung "Node richtig installieren" unter "Sonderfall" Node deinstalliert und wieder installiert. Nun sind die Version zumindest beide gleich, liegen aber im Local Verzeichnis. wie dort auch angegeben. Ist das nun soweit richtig?
      /usr/local/bin/nodejs
      /usr/local/bin/node
      /usr/local/bin/npm
      v14.19.1
      v14.19.1
      6.14.16
      Das Anfangsproblem bleibt aber bestehen das er das Modul "sentry/integration" nicht findet. Denke das Hauptproblem liegt darin. Wie lässt sich dieses beheben?
      • I IFOX
        /usr/local/bin/node
        /usr/local/bin/npm
        v14.19.1
        v14.19.1
        6.14.16
        @ifox
        Warum Sonderfall? Du bist kein Sonderfall.
        Ganz normal über das apt-Repository installieren.
          @ifox
          I Offline
          I Offline
          IFOX
          habe es nun ganz normal installiert und liegen jetzt unter "/usr/bin/x".
          Ursprungsproblem besteht aber leider weiterhin!
          • I IFOX
            @ifox sagte in Fehler nach Update des "Admin" Adapters:
            also weiter mit dem Fundament:
            node hast du jetzt immer noch v14?
            Was hast du denn als controller?
            • I IFOX
              @ifox
              Zeig nochmal die komplette Statusabfrage.
                @ifox
                I Offline
                I Offline
                IFOX
                Require stack:
                    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                    at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                    at Module.require (internal/modules/cjs/loader.js:974:19)
                    at require (internal/modules/cjs/helpers.js:101:18)
                • I IFOX
                  Require stack:
                  @ifox
                  Ich meinte eigentlich die zu nodejs und Konsorten.
                    @ifox
                    I Offline
                    I Offline
                    IFOX
                    Meinst Du diese hier?
                    pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v14.19.1
                    v14.19.1
                    6.14.16
                    nodejs:
                      Installed: 14.19.1-deb-1nodesource1
                      Candidate: 14.19.1-deb-1nodesource1
                      Version table:
                     *** 14.19.1-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                    • I IFOX
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v14.19.1
                      v14.19.1
                      6.14.16
                      nodejs:
                        Version table:
                      @ifox
                      iobroker stop
                      iobroker fix
                      iobroker start
                      Wenn das nicht hilft:
                      cd /opt/iobroker
                      sudo -H -u iobroker npm install iobroker.js-controller
                        @ifox
                        iobroker stop
                        iobroker fix
                        iobroker start
                        cd /opt/iobroker
                        I Offline
                        I Offline
                        IFOX
                        der zweite Teil war die Lösung.
                        Einfach genial wenn es wieder läuft, vielen Dank für den Support.
                        Fürs erste scheint alles wieder da zu sein und zu funktionieren.
                        Bis auf ein Wetter Widget in VIS und backitup findet in dropbox die alten Backups aktuell nicht mehr.
