  4. Test Adapter History 2.0.0
    5.9k
100 Beiträge 12 Kommentatoren 11.9k Aufrufe 12 Beobachtet
    @apollon77 Hab ich (oder du) ein Problem.
    Das debug müllt das log zu.
    ich erkenne nicht was zum löschen gehört
    Wie lange dauert das Ganze?
    fängt an mit:
    2022-04-27 14:53:18.765 - debug: history.0 (4085778) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2022-04-27 14:53:18.794 - debug: history.0 (4085778) Objects client ready ... initialize now
    2022-04-27 14:53:18.799 - debug: history.0 (4085778) Objects create System PubSub Client
    2022-04-27 14:53:18.800 - debug: history.0 (4085778) Objects create User PubSub Client
    2022-04-27 14:53:18.801 - debug: history.0 (4085778) Objects client initialize lua scripts
    2022-04-27 14:53:18.816 - debug: history.0 (4085778) Objects connected to redis: 0.0.0.0:9001
    2022-04-27 14:53:18.822 - debug: history.0 (4085778) objectDB connected
    2022-04-27 14:53:18.823 - debug: history.0 (4085778) Redis States: Use Redis connection: 0.0.0.0:9000
    2022-04-27 14:53:18.832 - debug: history.0 (4085778) States create System PubSub Client
    2022-04-27 14:53:18.833 - debug: history.0 (4085778) States create User PubSub Client
    2022-04-27 14:53:18.844 - debug: history.0 (4085778) States connected to redis: 0.0.0.0:9000
    2022-04-27 14:53:18.845 - debug: history.0 (4085778) statesDB connected
    2022-04-27 14:53:19.057 - debug: history.0 (4085778) Plugin sentry Initialize Plugin (enabled=true)
    Hab's nochmal versucht und finde:
    2022-04-27 14:59:41.657 - debug: history.0 (4085778) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
    2022-04-27 14:59:50.596 - debug: history.0 (4085778) deleteState 1 items
    2022-04-27 14:59:50.597 - warn: history.0 (4085778) States system pmessage io.messagebox.system.adapter.history.0 {"command":"delete","message":[{"state":{"ts":1651063995440},"id":"Messwerte.0.Stromzaehler.Summenwerte.Tagesendverbrauch"}],"from":"system.adapter.admin.0","callback":{"message":[{"state":{"ts":1651063995440},"id":"Messwerte.0.Stromzaehler.Summenwerte.Tagesendverbrauch"}],"id":325,"ack":false,"time":1651064390595},"_id":70540713} file is not defined
    2022-04-27 14:59:50.604 - warn: history.0 (4085778) ReferenceError: file is not defined
    at /opt/iobroker/node_modules/iobroker.history/main.js:1552:59
    at Array.forEach ()
    at _delete (/opt/iobroker/node_modules/iobroker.history/main.js:1505:15)
    at deleteState (/opt/iobroker/node_modules/iobroker.history/main.js:1628:17)
    at processMessage (/opt/iobroker/node_modules/iobroker.history/main.js:326:9)
    at Object.message (/opt/iobroker/node_modules/iobroker.history/main.js:233:25)
    at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5634:41)
    at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:232:37)
    at processImmediate (internal/timers.js:464:21)
    @homoran COngrats, you forund a bug :-)) Fixed ion GitHub
    • apollon77A apollon77
      @apollon77 Aber immer wieder gerne 😀
      EDIT:
      Works like a charm!
      Endlich kann ich meine Charts aufräumen.
      Sind natürlich jetzt unendlich viele DPs mit Dp*8 null drin :-(
        EDIT:
        Works like a charm!
        @homoran Viel Erfolg
          @apollon77 sagte in Test Adapter History 2.0.0:
          ich versuche es gleich nochmal :-)
          Ich habe gerade festgestellt, dass in einem Chart eine Linie fehlte.
          Beim Versuch die Daten des zuständigen Datenpunktes anzusehen scheint history abgestürzt zu sein:
          2022-04-28 14:41:30.041 - error: host.iobroker-VM03 Caught by controller[0]: <--- Last few GCs --->
          2022-04-28 14:41:30.043 - error: host.iobroker-VM03 Caught by controller[0]: [2034430:0x597ac00] 38402 ms: Mark-sweep 1862.1 (1987.9) -> 1858.1 (1990.6) MB, 1777.6 / 0.0 ms (average mu = 0.225, current mu = 0.029) allocation failure scavenge might not succeed
          2022-04-28 14:41:30.043 - error: host.iobroker-VM03 Caught by controller[0]: [2034430:0x597ac00] 40186 ms: Mark-sweep 1874.1 (1990.6) -> 1870.1 (1993.1) MB, 1712.1 / 0.0 ms (average mu = 0.147, current mu = 0.040) allocation failure scavenge might not succeed
          2022-04-28 14:41:30.043 - error: host.iobroker-VM03 Caught by controller[0]: <--- JS stacktrace --->
          2022-04-28 14:41:30.043 - error: host.iobroker-VM03 Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
          2022-04-28 14:41:30.043 - error: host.iobroker-VM03 Caught by controller[1]: 1: 0xa3aaf0 node::Abort() [io.history.0]
          2022-04-28 14:41:30.043 - error: host.iobroker-VM03 Caught by controller[2]: 2: 0x970199 node::FatalError(char const*, char const*) [io.history.0]
          2022-04-28 14:41:30.044 - error: host.iobroker-VM03 Caught by controller[3]: 3: 0xbba45e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.history.0]
          2022-04-28 14:41:30.044 - error: host.iobroker-VM03 Caught by controller[4]: 4: 0xbba7d7 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.history.0]
          2022-04-28 14:41:30.044 - error: host.iobroker-VM03 Caught by controller[5]: 5: 0xd769e5 [io.history.0]
          2022-04-28 14:41:30.044 - error: host.iobroker-VM03 Caught by controller[6]: 6: 0xd7756f [io.history.0]
          2022-04-28 14:41:30.044 - error: host.iobroker-VM03 Caught by controller[7]: 7: 0xd853ab v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.history.0]
          2022-04-28 14:41:30.044 - error: host.iobroker-VM03 Caught by controller[8]: 8: 0xd88f6c v8::internal::Heap::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.history.0]
          2022-04-28 14:41:30.044 - error: host.iobroker-VM03 Caught by controller[9]: 9: 0xd4e73d v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [io.history.0]
          2022-04-28 14:41:30.044 - error: host.iobroker-VM03 Caught by controller[10]: 10: 0xd4a999 v8::internal::FactoryBase::AllocateRawArray(int, v8::internal::AllocationType) [io.history.0]
          2022-04-28 14:41:30.044 - error: host.iobroker-VM03 Caught by controller[11]: 11: 0xd4aa54 v8::internal::FactoryBase::NewFixedArrayWithFiller(v8::internal::Handle, int, v8::internal::Handle, v8::internal::AllocationType) [io.history.0]
          2022-04-28 14:41:30.044 - error: host.iobroker-VM03 Caught by controller[12]: 12: 0xf80ffe v8::internal::Handle v8::internal::HashTable::New(v8::internal::Isolate*, int, v8::internal::AllocationType, v8::internal::MinimumCapacity) [io.history.0]
          2022-04-28 14:41:30.044 - error: host.iobroker-VM03 Caught by controller[13]: 13: 0xf81cf9 v8::internal::Handle v8::internal::BaseNameDictionary::New(v8::internal::Isolate*, int, v8::internal::AllocationType, v8::internal::MinimumCapacity) [io.history.0]
          2022-04-28 14:41:30.044 - error: host.iobroker-VM03 Caught by controller[14]: 14: 0xf35be1 v8::internal::JSObject::MigrateToMap(v8::internal::Isolate*, v8::internal::Handle, v8::internal::Handle, int) [io.history.0]
          2022-04-28 14:41:30.044 - error: host.iobroker-VM03 Caught by controller[15]: 15: 0xf556cc v8::internal::LookupIterator::Delete() [io.history.0]
          2022-04-28 14:41:30.044 - error: host.iobroker-VM03 Caught by controller[16]: 16: 0xf2c55b v8::internal::JSReceiver::DeleteProperty(v8::internal::LookupIterator*, v8::internal::LanguageMode) [io.history.0]
          2022-04-28 14:41:30.044 - error: host.iobroker-VM03 Caught by controller[17]: 17: 0x10b4600 v8::internal::Runtime::DeleteObjectProperty(v8::internal::Isolate*, v8::internal::Handle, v8::internal::Handle, v8::internal::LanguageMode) [io.history.0]
          2022-04-28 14:41:30.045 - error: host.iobroker-VM03 Caught by controller[18]: 18: 0x10b673a v8::internal::Runtime_DeleteProperty(int, unsigned long*, v8::internal::Isolate*) [io.history.0]
          2022-04-28 14:41:30.045 - error: host.iobroker-VM03 Caught by controller[19]: 19: 0x1448e19 [io.history.0]
          2022-04-28 14:41:30.045 - warn: host.iobroker-VM03 instance system.adapter.history.0 terminated due to SIGABRT
          EDIT:
          Habe bei dem Datenpunkt Logging deaktiviert und neu konfiguriert.
          Seitdem loggt er anscheinend wieder, aber sobald ich mir die Werte ansehen will stürzt history ab
            EDIT:
            @homoran Wie lange zurück schaust Du denn? Das ist ein "Out of memory" ... Ansonsten Debug wieder an und dann mal log von so einem crash senden
              Hatte ich gesehen
              habe 4GB RAM zugewiesen und etwa 0,5GB free und 1,5 - 2 GB available
              erst drei Tage, dann nur noch 10 Minuten.
              Allerdings loggt er (???) alle 6 Sekunden
              2022-04-28 16:03:08.838 - info: history.0 (2087532) Loglevel changed from "info" to "debug"
              2022-04-28 16:03:11.278 - debug: history.0 (2087532) getHistory call: {"id":"system.host.iobroker-VM03.load","path":"/opt/iobroker/iobroker-data/history/","start":1651151993789,"end":1651154589581,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":57,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:11.278 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:11.359 - debug: history.0 (2087532) got 2 datapoints for system.host.iobroker-VM03.load
              2022-04-28 16:03:11.388 - debug: history.0 (2087532) Send: 30 of: 178 in: 110ms
              2022-04-28 16:03:11.388 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
              2022-04-28 16:03:12.276 - debug: history.0 (2087532) getHistory call: {"id":"system.host.iobroker-VM03.freemem","path":"/opt/iobroker/iobroker-data/history/","start":1651151993789,"end":1651154589581,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"false","aggregate":"minmax","limit":2000,"addId":false,"sessionId":57,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:12.277 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:12.285 - debug: history.0 (2087532) getHistory call: {"id":"system.host.iobroker-VM03.inputCount","path":"/opt/iobroker/iobroker-data/history/","start":1651151993789,"end":1651154589581,"step":100000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":57,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:12.285 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:12.293 - debug: history.0 (2087532) getHistory call: {"id":"system.host.iobroker-VM03.outputCount","path":"/opt/iobroker/iobroker-data/history/","start":1651151993789,"end":1651154589581,"step":100000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":57,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:12.293 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:12.347 - debug: history.0 (2087532) got 2 datapoints for system.host.iobroker-VM03.freemem
              2022-04-28 16:03:12.369 - debug: history.0 (2087532) got 0 datapoints for system.host.iobroker-VM03.inputCount
              2022-04-28 16:03:12.380 - debug: history.0 (2087532) got 0 datapoints for system.host.iobroker-VM03.outputCount
              2022-04-28 16:03:12.397 - debug: history.0 (2087532) Send: 30 of: 180 in: 121ms
              2022-04-28 16:03:12.397 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
              2022-04-28 16:03:12.404 - debug: history.0 (2087532) Send: 16 of: 43 in: 111ms
              2022-04-28 16:03:12.404 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
              2022-04-28 16:03:12.405 - debug: history.0 (2087532) Send: 11 of: 29 in: 120ms
              2022-04-28 16:03:12.405 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
              2022-04-28 16:03:19.313 - debug: history.0 (2087532) getHistory call: {"id":"Messwerte.0.Stromzaehler.Summenwerte.Tagesendverbrauch","path":"/opt/iobroker/iobroker-data/history/","start":1650549799567,"end":1651154599567,"step":null,"count":300,"from":false,"ack":false,"q":false,"ignoreNull":"false","aggregate":"onchange","limit":300,"addId":false,"sessionId":27,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:19.313 - debug: history.0 (2087532) got 0 datapoints for Messwerte.0.Stromzaehler.Summenwerte.Tagesendverbrauch
              2022-04-28 16:03:19.328 - debug: history.0 (2087532) Send: 11 values in: 15ms
              2022-04-28 16:03:19.328 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
              2022-04-28 16:03:19.355 - debug: history.0 (2087532) getHistory call: {"id":"Messwerte.0.Solaranlage.Momentanwerte.Solarestimate2","path":"/opt/iobroker/iobroker-data/history/","start":1651096800000,"end":1651183200000,"step":null,"count":300,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":300,"addId":false,"sessionId":52,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:19.355 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:19.423 - debug: history.0 (2087532) got 1 datapoints for Messwerte.0.Solaranlage.Momentanwerte.Solarestimate2
              2022-04-28 16:03:19.446 - debug: history.0 (2087532) Send: 125 of: 577 in: 91ms
              2022-04-28 16:03:19.447 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
              2022-04-28 16:03:20.279 - debug: history.0 (2087532) getHistory call: {"id":"Messwerte.0.Stromzaehler.Summenwerte.Tagesendeinspeisung","path":"/opt/iobroker/iobroker-data/history/","start":1650539799567,"end":1651144599567,"step":null,"count":300,"from":false,"ack":false,"q":false,"ignoreNull":"false","aggregate":"onchange","limit":300,"addId":false,"sessionId":27,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:20.279 - debug: history.0 (2087532) got 0 datapoints for Messwerte.0.Stromzaehler.Summenwerte.Tagesendeinspeisung
              2022-04-28 16:03:20.290 - debug: history.0 (2087532) Send: 9 values in: 11ms
              2022-04-28 16:03:20.290 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
              2022-04-28 16:03:20.291 - debug: history.0 (2087532) getHistory call: {"id":"Messwerte.0.Stromzaehler.Summenwerte.Tagesendbezug","path":"/opt/iobroker/iobroker-data/history/","start":1650529799567,"end":1651134599567,"step":null,"count":300,"from":false,"ack":false,"q":false,"ignoreNull":"false","aggregate":"onchange","limit":300,"addId":false,"sessionId":27,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:20.291 - debug: history.0 (2087532) got 0 datapoints for Messwerte.0.Stromzaehler.Summenwerte.Tagesendbezug
              2022-04-28 16:03:20.302 - debug: history.0 (2087532) Send: 9 values in: 11ms
              2022-04-28 16:03:20.302 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
              2022-04-28 16:03:20.303 - debug: history.0 (2087532) getHistory call: {"id":"Messwerte.0.Solaranlage.Momentanwerte.Leistung_AC_aktuell","path":"/opt/iobroker/iobroker-data/history/","start":1651096800000,"end":1651183200000,"step":null,"count":300,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":300,"addId":false,"sessionId":52,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:20.303 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:20.310 - debug: history.0 (2087532) getHistory call: {"id":"Messwerte.0.Solaranlage.Momentanwerte.Eigenverbrauch","path":"/opt/iobroker/iobroker-data/history/","start":1651096800000,"end":1651183200000,"step":null,"count":300,"from":false,"ack":false,"q":false,"ignoreNull":"false","aggregate":"minmax","limit":300,"addId":false,"sessionId":52,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:20.310 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:20.319 - debug: history.0 (2087532) getHistory call: {"id":"Messwerte.0.Stromzaehler.Momentanwerte.akt_Verbrauch","path":"/opt/iobroker/iobroker-data/history/","start":1651096800000,"end":1651183200000,"step":null,"count":300,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":300,"addId":false,"sessionId":52,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:20.319 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:20.326 - debug: history.0 (2087532) getHistory call: {"id":"Messwerte.0.Stromzaehler.Momentanwerte.akt_Einspeisung","path":"/opt/iobroker/iobroker-data/history/","start":1651096800000,"end":1651183200000,"step":null,"count":300,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":300,"addId":false,"sessionId":52,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:20.327 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:20.399 - debug: history.0 (2087532) got 5 datapoints for Messwerte.0.Solaranlage.Momentanwerte.Leistung_AC_aktuell
              2022-04-28 16:03:20.403 - debug: history.0 (2087532) got 5 datapoints for Messwerte.0.Solaranlage.Momentanwerte.Eigenverbrauch
              2022-04-28 16:03:20.422 - debug: history.0 (2087532) got 5 datapoints for Messwerte.0.Stromzaehler.Momentanwerte.akt_Verbrauch
              2022-04-28 16:03:20.434 - debug: history.0 (2087532) got 5 datapoints for Messwerte.0.Stromzaehler.Momentanwerte.akt_Einspeisung
              2022-04-28 16:03:20.475 - debug: history.0 (2087532) Send: 124 of: 4473 in: 172ms
              2022-04-28 16:03:20.475 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
              2022-04-28 16:03:20.488 - debug: history.0 (2087532) Send: 140 of: 4709 in: 178ms
              2022-04-28 16:03:20.488 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
              2022-04-28 16:03:20.505 - debug: history.0 (2087532) Send: 133 of: 4387 in: 179ms
              2022-04-28 16:03:20.505 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
              2022-04-28 16:03:20.509 - debug: history.0 (2087532) Send: 204 of: 7340 in: 191ms
              2022-04-28 16:03:20.510 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
              2022-04-28 16:03:21.391 - debug: history.0 (2087532) getHistory call: {"id":"hm-rpc.0.NEQ0384904.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651111401646,"end":1651154601646,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":53,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:21.391 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:21.457 - debug: history.0 (2087532) got 0 datapoints for hm-rpc.0.NEQ0384904.2.POWER
              2022-04-28 16:03:21.478 - debug: history.0 (2087532) Send: 26 of: 27 in: 87ms
              2022-04-28 16:03:21.478 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
              2022-04-28 16:03:22.294 - debug: history.0 (2087532) getHistory call: {"id":"hm-rpc.0.LTK0124191.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651111401646,"end":1651154601646,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":53,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:22.294 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:22.303 - debug: history.0 (2087532) getHistory call: {"id":"hm-rpc.0.KEQ0966548.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651111401646,"end":1651154601646,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":53,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:22.304 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:22.311 - debug: history.0 (2087532) getHistory call: {"id":"hm-rpc.0.KEQ0967747.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651111401646,"end":1651154601646,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":53,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:22.311 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:22.321 - debug: history.0 (2087532) getHistory call: {"id":"hm-rpc.0.NEQ0386317.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651111401646,"end":1651154601646,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":53,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:22.322 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:22.332 - debug: history.0 (2087532) getHistory call: {"id":"hm-rpc.0.LTK0124795.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651111401646,"end":1651154601646,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":53,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:22.333 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:22.344 - debug: history.0 (2087532) getHistory call: {"id":"hm-rpc.0.LTK0124195.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651111401646,"end":1651154601646,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":53,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:22.344 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:22.374 - debug: history.0 (2087532) getHistory call: {"id":"hm-rpc.0.LTK0124798.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651111401646,"end":1651154601646,"step":100000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":53,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:22.375 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:22.395 - debug: history.0 (2087532) getHistory call: {"id":"hm-rpc.0.LTK0124143.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651111401646,"end":1651154601646,"step":100000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":53,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:22.395 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:22.446 - debug: history.0 (2087532) getHistory call: {"id":"hm-rpc.0.REQ0777349.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651111401646,"end":1651154601646,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":53,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:22.447 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:22.466 - debug: history.0 (2087532) getHistory call: {"id":"hm-rpc.0.NEQ0116043.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651111401646,"end":1651154601646,"step":100000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":53,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:22.467 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:22.483 - debug: history.0 (2087532) getHistory call: {"id":"hm-rpc.1.0001D3C99C3EFB.6.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651111401646,"end":1651154601646,"step":100000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":53,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:22.483 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:22.513 - debug: history.0 (2087532) got 0 datapoints for hm-rpc.0.LTK0124191.2.POWER
              2022-04-28 16:03:22.523 - debug: history.0 (2087532) got 0 datapoints for hm-rpc.0.KEQ0966548.2.POWER
              2022-04-28 16:03:22.525 - debug: history.0 (2087532) got 0 datapoints for hm-rpc.0.KEQ0967747.2.POWER
              2022-04-28 16:03:22.528 - debug: history.0 (2087532) got 0 datapoints for hm-rpc.0.NEQ0386317.2.POWER
              2022-04-28 16:03:22.530 - debug: history.0 (2087532) got 0 datapoints for hm-rpc.0.LTK0124795.2.POWER
              2022-04-28 16:03:22.552 - debug: history.0 (2087532) Send: 192 of: 193 in: 258ms
              2022-04-28 16:03:22.553 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
              2022-04-28 16:03:22.554 - debug: history.0 (2087532) Send: 165 of: 166 in: 251ms
              2022-04-28 16:03:22.554 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
              2022-04-28 16:03:22.555 - debug: history.0 (2087532) Send: 84 of: 86 in: 244ms
              2022-04-28 16:03:22.555 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
              2022-04-28 16:03:22.557 - debug: history.0 (2087532) got 0 datapoints for hm-rpc.0.LTK0124798.2.POWER
              2022-04-28 16:03:22.573 - debug: history.0 (2087532) Send: 129 of: 134 in: 252ms
              2022-04-28 16:03:22.574 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
              2022-04-28 16:03:22.584 - debug: history.0 (2087532) Send: 279 of: 339 in: 252ms
              2022-04-28 16:03:22.584 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
              2022-04-28 16:03:22.607 - debug: history.0 (2087532) got 2 datapoints for hm-rpc.0.LTK0124195.2.POWER
              2022-04-28 16:03:22.609 - debug: history.0 (2087532) Send: 292 of: 549 in: 235ms
              2022-04-28 16:03:22.609 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
              2022-04-28 16:03:22.619 - debug: history.0 (2087532) got 0 datapoints for hm-rpc.0.REQ0777349.2.POWER
              2022-04-28 16:03:22.652 - debug: history.0 (2087532) got 0 datapoints for hm-rpc.0.LTK0124143.2.POWER
              2022-04-28 16:03:22.654 - debug: history.0 (2087532) Send: 367 of: 1181 in: 309ms
              2022-04-28 16:03:22.654 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
              2022-04-28 16:03:22.670 - debug: history.0 (2087532) Send: 26 of: 27 in: 224ms
              2022-04-28 16:03:22.670 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
              2022-04-28 16:03:22.677 - debug: history.0 (2087532) got 0 datapoints for hm-rpc.0.NEQ0116043.2.POWER
              2022-04-28 16:03:22.681 - debug: history.0 (2087532) got 2 datapoints for hm-rpc.1.0001D3C99C3EFB.6.POWER
              2022-04-28 16:03:22.696 - debug: history.0 (2087532) Send: 278 of: 280 in: 301ms
              2022-04-28 16:03:22.697 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
              2022-04-28 16:03:22.705 - debug: history.0 (2087532) Send: 26 of: 27 in: 239ms
              2022-04-28 16:03:22.706 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
              2022-04-28 16:03:22.709 - debug: history.0 (2087532) Send: 221 of: 508 in: 226ms
              2022-04-28 16:03:22.709 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
              2022-04-28 16:03:24.438 - debug: history.0 (2087532) getHistory call: {"id":"Messwerte.0.Solaranlage.Momentanwerte.Eigenverbrauch","path":"/opt/iobroker/iobroker-data/history/","start":1651068000000,"end":1651154604692,"step":3600000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:24.438 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:24.450 - debug: history.0 (2087532) getHistory call: {"id":"Messwerte.0.Solaranlage.Momentanwerte.Eigenverbrauch","path":"/opt/iobroker/iobroker-data/history/","start":1651068000000,"end":1651154604705,"step":3600000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:24.450 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:24.473 - debug: history.0 (2087532) getHistory call: {"id":"Messwerte.0.Solaranlage.Momentanwerte.Eigenverbrauch","path":"/opt/iobroker/iobroker-data/history/","start":1651068000000,"end":1651154604727,"step":3600000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:24.473 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:24.488 - debug: history.0 (2087532) getHistory call: {"id":"Messwerte.0.Solaranlage.Momentanwerte.Eigenverbrauch","path":"/opt/iobroker/iobroker-data/history/","start":1651068000000,"end":1651154604743,"step":3600000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:24.489 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:24.520 - debug: history.0 (2087532) got 6 datapoints for Messwerte.0.Solaranlage.Momentanwerte.Eigenverbrauch
              2022-04-28 16:03:24.529 - debug: history.0 (2087532) getHistory call: {"id":"Messwerte.0.Solaranlage.Momentanwerte.Eigenverbrauch","path":"/opt/iobroker/iobroker-data/history/","start":1651068000000,"end":1651154604783,"step":3600000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:03:24.529 - debug: history.0 (2087532) use parallel requests for getHistory
              2022-04-28 16:03:24.549 - debug: history.0 (2087532) got 6 datapoints for Messwerte.0.Solaranlage.Momentanwerte.Eigenverbrauch
              2022-04-28 16:03:24.582 - debug: history.0 (2087532) got 6 datapoints for Messwerte.0.Solaranlage.Momentanwerte.Eigenverbrauch
              2022-04-28 16:03:24.591 - debug: history.0 (2087532) got 6 datapoints for Messwerte.0.Solaranlage.Momentanwerte.Eigenverbrauch
              2022-04-28 16:03:24.674 - debug: history.0 (2087532) got 6 datapoints for Messwerte.0.Solaranlage.Momentanwerte.Eigenverbrauch
              2022-04-28 16:03:24.676 - debug: history.0 (2087532) Send: 28 of: 7528 in: 226ms
              2022-04-28 16:03:24.676 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.admin.0 from system.adapter.history.0
              2022-04-28 16:03:24.700 - debug: history.0 (2087532) Send: 28 of: 7528 in: 262ms
              2022-04-28 16:03:24.701 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.admin.0 from system.adapter.history.0
              2022-04-28 16:03:24.712 - debug: history.0 (2087532) Send: 28 of: 7528 in: 239ms
              2022-04-28 16:03:24.713 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.admin.0 from system.adapter.history.0
              2022-04-28 16:03:24.724 - debug: history.0 (2087532) Send: 28 of: 7528 in: 236ms
              2022-04-28 16:03:24.724 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.admin.0 from system.adapter.history.0
              2022-04-28 16:03:24.765 - debug: history.0 (2087532) Send: 28 of: 7528 in: 236ms
              2022-04-28 16:03:24.766 - debug: history.0 (2087532) sendTo "getHistory" to system.adapter.admin.0 from system.adapter.history.0
              2022-04-28 16:03:26.310 - debug: history.0 (2087532) sendTo "features" to system.adapter.admin.0 from system.adapter.history.0
              2022-04-28 16:03:26.395 - debug: history.0 (2087532) getHistory call: {"id":"Messwerte.0.Solaranlage.Momentanwerte.Eigenverbrauch","path":"/opt/iobroker/iobroker-data/history/","start":946681200000,"end":1651154606644,"step":null,"count":500,"from":false,"ack":false,"q":false,"aggregate":"none","limit":1,"addId":false,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false}
              2022-04-28 16:04:00.486 - warn: javascript.1 (229936) script.js.Hardware.netScan_ganzneu: no Data
              2022-04-28 16:04:08.785 - error: host.iobroker-VM03 Caught by controller[0]: <--- Last few GCs --->
              2022-04-28 16:04:08.788 - error: host.iobroker-VM03 Caught by controller[0]: [2087532:0x4b72c00] 3086022 ms: Mark-sweep 1870.7 (1991.6) -> 1866.7 (1994.1) MB, 1783.6 / 0.0 ms (average mu = 0.209, current mu = 0.037) allocation failure scavenge might not succeed
              2022-04-28 16:04:08.788 - error: host.iobroker-VM03 Caught by controller[0]: [2087532:0x4b72c00] 3087879 ms: Mark-sweep 1882.7 (1994.1) -> 1878.8 (1996.6) MB, 1793.0 / 0.0 ms (average mu = 0.134, current mu = 0.035) allocation failure scavenge might not succeed
              2022-04-28 16:04:08.788 - error: host.iobroker-VM03 Caught by controller[0]: <--- JS stacktrace --->
              2022-04-28 16:04:08.788 - error: host.iobroker-VM03 Caught by controller[1]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
              2022-04-28 16:04:08.788 - error: host.iobroker-VM03 Caught by controller[2]: 1: 0xa3aaf0 node::Abort() [io.history.0]
              2022-04-28 16:04:08.788 - error: host.iobroker-VM03 Caught by controller[3]: 2: 0x970199 node::FatalError(char const*, char const*) [io.history.0]
              2022-04-28 16:04:08.788 - error: host.iobroker-VM03 Caught by controller[4]: 3: 0xbba45e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.history.0]
              2022-04-28 16:04:08.788 - error: host.iobroker-VM03 Caught by controller[5]: 4: 0xbba7d7 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.history.0]
              2022-04-28 16:04:08.788 - error: host.iobroker-VM03 Caught by controller[5]: 5: 0xd769e5 [io.history.0]
              2022-04-28 16:04:08.788 - error: host.iobroker-VM03 Caught by controller[6]: 6: 0xd7756f [io.history.0]
              2022-04-28 16:04:08.788 - error: host.iobroker-VM03 Caught by controller[7]: 7: 0xd853ab v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.history.0]
              2022-04-28 16:04:08.789 - error: host.iobroker-VM03 Caught by controller[8]: 8: 0xd88f6c v8::internal::Heap::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.history.0]
              2022-04-28 16:04:08.789 - error: host.iobroker-VM03 Caught by controller[9]: 9: 0xd4e73d v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [io.history.0]
              2022-04-28 16:04:08.789 - error: host.iobroker-VM03 Caught by controller[10]: 10: 0xd4a999 v8::internal::FactoryBase::AllocateRawArray(int, v8::internal::AllocationType) [io.history.0]
              2022-04-28 16:04:08.789 - error: host.iobroker-VM03 Caught by controller[11]: 11: 0xd4aa54 v8::internal::FactoryBase::NewFixedArrayWithFiller(v8::internal::Handle, int, v8::internal::Handle, v8::internal::AllocationType) [io.history.0]
              2022-04-28 16:04:08.789 - error: host.iobroker-VM03 Caught by controller[12]: 12: 0xf80ffe v8::internal::Handle v8::internal::HashTable::New(v8::internal::Isolate*, int, v8::internal::AllocationType, v8::internal::MinimumCapacity) [io.history.0]
              2022-04-28 16:04:08.789 - error: host.iobroker-VM03 Caught by controller[13]: 13: 0xf81cf9 v8::internal::Handle v8::internal::BaseNameDictionary::New(v8::internal::Isolate*, int, v8::internal::AllocationType, v8::internal::MinimumCapacity) [io.history.0]
              2022-04-28 16:04:08.789 - error: host.iobroker-VM03 Caught by controller[14]: 14: 0xf35be1 v8::internal::JSObject::MigrateToMap(v8::internal::Isolate*, v8::internal::Handle, v8::internal::Handle, int) [io.history.0]
              2022-04-28 16:04:08.789 - error: host.iobroker-VM03 Caught by controller[15]: 15: 0xf556cc v8::internal::LookupIterator::Delete() [io.history.0]
              2022-04-28 16:04:08.789 - error: host.iobroker-VM03 Caught by controller[16]: 16: 0xf2c55b v8::internal::JSReceiver::DeleteProperty(v8::internal::LookupIterator*, v8::internal::LanguageMode) [io.history.0]
              2022-04-28 16:04:08.789 - error: host.iobroker-VM03 Caught by controller[17]: 17: 0x10b4600 v8::internal::Runtime::DeleteObjectProperty(v8::internal::Isolate*, v8::internal::Handle, v8::internal::Handle, v8::internal::LanguageMode) [io.history.0]
              2022-04-28 16:04:08.789 - error: host.iobroker-VM03 Caught by controller[18]: 18: 0x10b673a v8::internal::Runtime_DeleteProperty(int, unsigned long*, v8::internal::Isolate*) [io.history.0]
              2022-04-28 16:04:08.789 - error: host.iobroker-VM03 Caught by controller[18]: 19: 0x1448e19 [io.history.0]
              2022-04-28 16:04:08.789 - warn: host.iobroker-VM03 instance system.adapter.history.0 terminated due to SIGABRT
              2022-04-28 16:04:08.790 - info: host.iobroker-VM03 instance system.adapter.history.0 terminated with code NaN ()
              scheint in Zeile 119 loszugehen
              apollon77A 2 Antworten Letzte Antwort
                Hatte ich gesehen
                @homoran siehst du wieviele getHistpry abfragen da quasi parallel kommen ?! Wow. Ixh schaue mal.
                  Hatte ich gesehen
                  @homoran Ich hab mal versucht was zu optimieren, aber das ist schwierig. versuch mal GitHub version. Sonst setzen wir einfach den Heap für deinen Prozess hoch
                  • apollon77A Offline
                    Auf GitHub sind einige Fixes hinzugekommen und auch noch zwei neue Features:
                    • Bei storeState kann nun mittels dem Parameter "rule=true" festlegen das die Daten nicht direkt geloggt werden sondern alle Rules angewendet werden wie für jeden normalen Wert - inkl. Debounce u.ä. Bitte vorsichtig nutzen das nicht unabsichtlich Werte nicht geschrieben werden!
                    • Eine Einstellung pro Datenpunkt ist dazugekommen, mit der man angeben kann auf wie viele Stellen nach dem Komma die Werte beim lesen (GetHistory) gerundet werden.
                      @apollon77 ich bekomme nicht mal einen sinnvollen debug-log zustande :-(
                      2022-05-01 14:31:34.235 - info: host.iobroker-VM03 stopInstance system.adapter.history.0 (force=false, process=true)
                      2022-05-01 14:31:38.374 - error: host.iobroker-VM03 Caught by controller[0]: <--- Last few GCs --->
                      2022-05-01 14:31:38.374 - error: host.iobroker-VM03 Caught by controller[0]: [4074178:0x543dc00] 60961 ms: Mark-sweep 1870.8 (1993.1) -> 1866.8 (1995.6) MB, 1798.0 / 0.0 ms (average mu = 0.216, current mu = 0.040) allocation failure scavenge might not succeed
                      2022-05-01 14:31:38.374 - error: host.iobroker-VM03 Caught by controller[0]: [4074178:0x543dc00] 62792 ms: Mark-sweep 1882.7 (1995.6) -> 1878.8 (1998.4) MB, 1761.4 / 0.0 ms (average mu = 0.139, current mu = 0.038) allocation failure scavenge might not succeed
                      2022-05-01 14:31:38.375 - error: host.iobroker-VM03 Caught by controller[0]: <--- JS stacktrace --->
                      2022-05-01 14:31:38.375 - error: host.iobroker-VM03 Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
                      2022-05-01 14:31:38.375 - error: host.iobroker-VM03 Caught by controller[1]: 1: 0xa3aaf0 node::Abort() [io.history.0]
                      2022-05-01 14:31:38.375 - error: host.iobroker-VM03 Caught by controller[2]: 2: 0x970199 node::FatalError(char const*, char const*) [io.history.0]
                      2022-05-01 14:31:38.375 - error: host.iobroker-VM03 Caught by controller[3]: 3: 0xbba45e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.history.0]
                      2022-05-01 14:31:38.375 - error: host.iobroker-VM03 Caught by controller[4]: 4: 0xbba7d7 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.history.0]
                      2022-05-01 14:31:38.375 - error: host.iobroker-VM03 Caught by controller[5]: 5: 0xd769e5 [io.history.0]
                      2022-05-01 14:31:38.375 - error: host.iobroker-VM03 Caught by controller[6]: 6: 0xd7756f [io.history.0]
                      2022-05-01 14:31:38.375 - error: host.iobroker-VM03 Caught by controller[7]: 7: 0xd853ab v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.history.0]
                      2022-05-01 14:31:38.375 - error: host.iobroker-VM03 Caught by controller[8]: 8: 0xd88f6c v8::internal::Heap::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.history.0]
                      2022-05-01 14:31:38.376 - error: host.iobroker-VM03 Caught by controller[9]: 9: 0xd4e73d v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [io.history.0]
                      2022-05-01 14:31:38.376 - error: host.iobroker-VM03 Caught by controller[10]: 10: 0xd4a999 v8::internal::FactoryBase::AllocateRawArray(int, v8::internal::AllocationType) [io.history.0]
                      2022-05-01 14:31:38.376 - error: host.iobroker-VM03 Caught by controller[11]: 11: 0xd4aa54 v8::internal::FactoryBase::NewFixedArrayWithFiller(v8::internal::Handle, int, v8::internal::Handle, v8::internal::AllocationType) [io.history.0]
                      2022-05-01 14:31:38.376 - error: host.iobroker-VM03 Caught by controller[12]: 12: 0xf80ffe v8::internal::Handle v8::internal::HashTable::New(v8::internal::Isolate*, int, v8::internal::AllocationType, v8::internal::MinimumCapacity) [io.history.0]
                      2022-05-01 14:31:38.376 - error: host.iobroker-VM03 Caught by controller[13]: 13: 0xf81cf9 v8::internal::Handle v8::internal::BaseNameDictionary::New(v8::internal::Isolate*, int, v8::internal::AllocationType, v8::internal::MinimumCapacity) [io.history.0]
                      2022-05-01 14:31:38.376 - error: host.iobroker-VM03 Caught by controller[14]: 14: 0xf35be1 v8::internal::JSObject::MigrateToMap(v8::internal::Isolate*, v8::internal::Handle, v8::internal::Handle, int) [io.history.0]
                      2022-05-01 14:31:38.376 - error: host.iobroker-VM03 Caught by controller[15]: 15: 0xf556cc v8::internal::LookupIterator::Delete() [io.history.0]
                      2022-05-01 14:31:38.376 - error: host.iobroker-VM03 Caught by controller[16]: 16: 0xf2c55b v8::internal::JSReceiver::DeleteProperty(v8::internal::LookupIterator*, v8::internal::LanguageMode) [io.history.0]
                      2022-05-01 14:31:38.376 - error: host.iobroker-VM03 Caught by controller[17]: 17: 0x10b4600 v8::internal::Runtime::DeleteObjectProperty(v8::internal::Isolate*, v8::internal::Handle, v8::internal::Handle, v8::internal::LanguageMode) [io.history.0]
                      2022-05-01 14:31:38.376 - error: host.iobroker-VM03 Caught by controller[18]: 18: 0x10b673a v8::internal::Runtime_DeleteProperty(int, unsigned long*, v8::internal::Isolate*) [io.history.0]
                      2022-05-01 14:31:38.376 - error: host.iobroker-VM03 Caught by controller[19]: 19: 0x1448e19 [io.history.0]
                      2022-05-01 14:31:38.376 - warn: host.iobroker-VM03 instance system.adapter.history.0 terminated due to SIGABRT
                      2022-05-01 14:31:38.376 - info: host.iobroker-VM03 instance system.adapter.history.0 terminated with code NaN ()
                      Habe dann immer relativ schnell den debug wieder abschalten wollen um das log nicht zu groß werden zu lassen, aber anscheinend kommt nach dem Absturz erst wieder dei Meldungen vom Neustart und dann..
                      2022-05-01 14:31:41.918 - debug: history.0 (4075723) getHistory call: {"id":"Messwerte.0.Stromzaehler.Summenwerte.Tagesendverbrauch","path":"/opt/iobroker/iobroker-data/history/","start":1650803341003,"end":1651408141003,"step":null,"count":300,"from":false,"ack":false,"q":false,"ignoreNull":"false","aggregate":"onchange","limit":300,"addId":false,"sessionId":305,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:41.918 - debug: history.0 (4075723) got 1 datapoints for Messwerte.0.Stromzaehler.Summenwerte.Tagesendverbrauch
                      2022-05-01 14:31:41.964 - debug: history.0 (4075723) Send: 11 values in: 47ms
                      2022-05-01 14:31:41.964 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:41.967 - debug: history.0 (4075723) getHistory call: {"id":"Messwerte.0.Stromzaehler.Summenwerte.Tagesendeinspeisung","path":"/opt/iobroker/iobroker-data/history/","start":1650793341003,"end":1651398141003,"step":null,"count":300,"from":false,"ack":false,"q":false,"ignoreNull":"false","aggregate":"onchange","limit":300,"addId":false,"sessionId":305,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:41.967 - debug: history.0 (4075723) got 1 datapoints for Messwerte.0.Stromzaehler.Summenwerte.Tagesendeinspeisung
                      2022-05-01 14:31:41.988 - debug: history.0 (4075723) Send: 9 values in: 22ms
                      2022-05-01 14:31:41.988 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:41.989 - debug: history.0 (4075723) getHistory call: {"id":"Messwerte.0.Stromzaehler.Summenwerte.Tagesendbezug","path":"/opt/iobroker/iobroker-data/history/","start":1650783341003,"end":1651388141003,"step":null,"count":300,"from":false,"ack":false,"q":false,"ignoreNull":"false","aggregate":"onchange","limit":300,"addId":false,"sessionId":305,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:41.989 - debug: history.0 (4075723) got 1 datapoints for Messwerte.0.Stromzaehler.Summenwerte.Tagesendbezug
                      2022-05-01 14:31:42.010 - debug: history.0 (4075723) Send: 9 values in: 21ms
                      2022-05-01 14:31:42.010 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:42.861 - debug: history.0 (4075723) getHistory call: {"id":"Messwerte.0.Solaranlage.Momentanwerte.Solarestimate2","path":"/opt/iobroker/iobroker-data/history/","start":1651356000000,"end":1651442400000,"step":null,"count":300,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":300,"addId":false,"sessionId":608,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:42.861 - debug: history.0 (4075723) use parallel requests for getHistory
                      2022-05-01 14:31:42.894 - debug: history.0 (4075723) getHistory call: {"id":"Messwerte.0.Solaranlage.Momentanwerte.Leistung_AC_aktuell","path":"/opt/iobroker/iobroker-data/history/","start":1651356000000,"end":1651442400000,"step":null,"count":300,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":300,"addId":false,"sessionId":608,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:42.894 - debug: history.0 (4075723) use parallel requests for getHistory
                      2022-05-01 14:31:42.910 - debug: history.0 (4075723) getHistory call: {"id":"Messwerte.0.Solaranlage.Momentanwerte.Eigenverbrauch","path":"/opt/iobroker/iobroker-data/history/","start":1651356000000,"end":1651442400000,"step":null,"count":300,"from":false,"ack":false,"q":false,"ignoreNull":"false","aggregate":"minmax","limit":300,"addId":false,"sessionId":608,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:42.910 - debug: history.0 (4075723) use parallel requests for getHistory
                      2022-05-01 14:31:42.921 - debug: history.0 (4075723) getHistory call: {"id":"Messwerte.0.Stromzaehler.Momentanwerte.akt_Verbrauch","path":"/opt/iobroker/iobroker-data/history/","start":1651356000000,"end":1651442400000,"step":null,"count":300,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":300,"addId":false,"sessionId":608,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:42.922 - debug: history.0 (4075723) use parallel requests for getHistory
                      2022-05-01 14:31:42.930 - debug: history.0 (4075723) getHistory call: {"id":"Messwerte.0.Stromzaehler.Momentanwerte.akt_Einspeisung","path":"/opt/iobroker/iobroker-data/history/","start":1651356000000,"end":1651442400000,"step":null,"count":300,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":300,"addId":false,"sessionId":608,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:42.930 - debug: history.0 (4075723) use parallel requests for getHistory
                      2022-05-01 14:31:42.987 - debug: history.0 (4075723) got 1 datapoints for Messwerte.0.Solaranlage.Momentanwerte.Solarestimate2
                      2022-05-01 14:31:43.008 - debug: history.0 (4075723) got 1 datapoints for Messwerte.0.Solaranlage.Momentanwerte.Leistung_AC_aktuell
                      2022-05-01 14:31:43.064 - debug: history.0 (4075723) got 3 datapoints for Messwerte.0.Solaranlage.Momentanwerte.Eigenverbrauch
                      2022-05-01 14:31:43.070 - debug: history.0 (4075723) got 2 datapoints for Messwerte.0.Stromzaehler.Momentanwerte.akt_Einspeisung
                      2022-05-01 14:31:43.079 - debug: history.0 (4075723) Send: 109 of: 508 in: 219ms
                      2022-05-01 14:31:43.080 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:43.112 - debug: history.0 (4075723) got 2 datapoints for Messwerte.0.Stromzaehler.Momentanwerte.akt_Verbrauch
                      2022-05-01 14:31:43.140 - debug: history.0 (4075723) Send: 106 of: 3896 in: 245ms
                      2022-05-01 14:31:43.140 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:43.176 - debug: history.0 (4075723) Send: 111 of: 3484 in: 246ms
                      2022-05-01 14:31:43.176 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:43.188 - debug: history.0 (4075723) Send: 122 of: 4157 in: 278ms
                      2022-05-01 14:31:43.189 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:43.222 - debug: history.0 (4075723) Send: 185 of: 6716 in: 301ms
                      2022-05-01 14:31:43.222 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:43.590 - debug: history.0 (4075723) getHistory call: {"id":"hm-rpc.0.NEQ0384904.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651364942685,"end":1651408142685,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":305,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:43.590 - debug: history.0 (4075723) use parallel requests for getHistory
                      2022-05-01 14:31:43.619 - debug: history.0 (4075723) getHistory call: {"id":"hm-rpc.0.JEQ0646431.1.STATE","path":"/opt/iobroker/iobroker-data/history/","start":1651148942708,"end":1651408142708,"step":4800000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"onchange","limit":2000,"addId":false,"sessionId":401,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:43.619 - debug: history.0 (4075723) got 2 datapoints for hm-rpc.0.JEQ0646431.1.STATE
                      2022-05-01 14:31:43.646 - debug: history.0 (4075723) Send: 181 values in: 27ms
                      2022-05-01 14:31:43.646 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:43.663 - debug: history.0 (4075723) got 1 datapoints for hm-rpc.0.NEQ0384904.2.POWER
                      2022-05-01 14:31:43.668 - debug: history.0 (4075723) getHistory call: {"id":"hm-rpc.0.LTK0124191.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651364942685,"end":1651408142685,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":305,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:43.669 - debug: history.0 (4075723) use parallel requests for getHistory
                      2022-05-01 14:31:43.676 - debug: history.0 (4075723) getHistory call: {"id":"hm-rpc.0.KEQ0966548.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651364942685,"end":1651408142685,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":305,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:43.676 - debug: history.0 (4075723) use parallel requests for getHistory
                      2022-05-01 14:31:43.687 - debug: history.0 (4075723) Send: 27 of: 31 in: 96ms
                      2022-05-01 14:31:43.687 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:43.714 - debug: history.0 (4075723) getHistory call: {"id":"hm-rpc.0.KEQ0967747.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651364942685,"end":1651408142685,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":305,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:43.714 - debug: history.0 (4075723) use parallel requests for getHistory
                      2022-05-01 14:31:43.723 - debug: history.0 (4075723) getHistory call: {"id":"hm-rpc.0.NEQ0386317.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651364942685,"end":1651408142685,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":305,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:43.724 - debug: history.0 (4075723) use parallel requests for getHistory
                      2022-05-01 14:31:43.732 - debug: history.0 (4075723) getHistory call: {"id":"hm-rpc.0.LTK0124795.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651364942685,"end":1651408142685,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":305,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:43.733 - debug: history.0 (4075723) use parallel requests for getHistory
                      2022-05-01 14:31:43.746 - debug: history.0 (4075723) getHistory call: {"id":"hm-rpc.0.LTK0124195.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651364942685,"end":1651408142685,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":305,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:43.746 - debug: history.0 (4075723) use parallel requests for getHistory
                      2022-05-01 14:31:43.754 - debug: history.0 (4075723) getHistory call: {"id":"hm-rpc.0.LTK0124798.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651364942685,"end":1651408142685,"step":100000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":305,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:43.755 - debug: history.0 (4075723) use parallel requests for getHistory
                      2022-05-01 14:31:43.772 - debug: history.0 (4075723) getHistory call: {"id":"hm-rpc.0.LTK0124143.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651364942685,"end":1651408142685,"step":100000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":305,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:43.773 - debug: history.0 (4075723) use parallel requests for getHistory
                      2022-05-01 14:31:43.790 - debug: history.0 (4075723) getHistory call: {"id":"hm-rpc.0.REQ0777349.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651364942685,"end":1651408142685,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":305,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:43.790 - debug: history.0 (4075723) use parallel requests for getHistory
                      2022-05-01 14:31:43.810 - debug: history.0 (4075723) getHistory call: {"id":"hm-rpc.0.NEQ0116043.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651364942685,"end":1651408142685,"step":100000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":305,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:43.810 - debug: history.0 (4075723) use parallel requests for getHistory
                      2022-05-01 14:31:43.833 - debug: history.0 (4075723) getHistory call: {"id":"hm-rpc.1.0001D3C99C3EFB.6.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651364942685,"end":1651408142685,"step":100000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":305,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:43.834 - debug: history.0 (4075723) use parallel requests for getHistory
                      2022-05-01 14:31:43.847 - debug: history.0 (4075723) getHistory call: {"id":"Messwerte.0.Pool.Druck_real","path":"/opt/iobroker/iobroker-data/history/","start":1651148942708,"end":1651408142708,"step":4800000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"false","aggregate":"onchange","limit":2000,"addId":false,"sessionId":401,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:43.848 - debug: history.0 (4075723) got 1 datapoints for Messwerte.0.Pool.Druck_real
                      2022-05-01 14:31:43.933 - debug: history.0 (4075723) Send: 3073 values in: 86ms
                      2022-05-01 14:31:43.933 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:43.972 - debug: history.0 (4075723) got 1 datapoints for hm-rpc.0.LTK0124191.2.POWER
                      2022-05-01 14:31:43.975 - debug: history.0 (4075723) got 1 datapoints for hm-rpc.0.KEQ0966548.2.POWER
                      2022-05-01 14:31:43.994 - debug: history.0 (4075723) got 1 datapoints for hm-rpc.0.KEQ0967747.2.POWER
                      2022-05-01 14:31:44.012 - debug: history.0 (4075723) got 1 datapoints for hm-rpc.0.NEQ0386317.2.POWER
                      2022-05-01 14:31:44.020 - debug: history.0 (4075723) got 1 datapoints for hm-rpc.0.LTK0124795.2.POWER
                      2022-05-01 14:31:44.022 - debug: history.0 (4075723) got 1 datapoints for hm-rpc.0.LTK0124195.2.POWER
                      2022-05-01 14:31:44.048 - debug: history.0 (4075723) getHistory call: {"id":"hm-rpc.0.JEQ0140901.1.TEMPERATURE","path":"/opt/iobroker/iobroker-data/history/","start":1651148942708,"end":1651408142708,"step":4800000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":401,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:44.048 - debug: history.0 (4075723) use parallel requests for getHistory
                      2022-05-01 14:31:44.071 - debug: history.0 (4075723) getHistory call: {"id":"hm-rpc.0.LEQ0773306.2.TEMPERATURE","path":"/opt/iobroker/iobroker-data/history/","start":1651148942708,"end":1651408142708,"step":4800000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":401,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:44.072 - debug: history.0 (4075723) use parallel requests for getHistory
                      2022-05-01 14:31:44.093 - debug: history.0 (4075723) Send: 180 of: 185 in: 425ms
                      2022-05-01 14:31:44.094 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:44.096 - debug: history.0 (4075723) Send: 194 of: 198 in: 420ms
                      2022-05-01 14:31:44.096 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:44.100 - debug: history.0 (4075723) Send: 192 of: 197 in: 385ms
                      2022-05-01 14:31:44.100 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:44.101 - debug: history.0 (4075723) Send: 186 of: 199 in: 378ms
                      2022-05-01 14:31:44.102 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:44.103 - debug: history.0 (4075723) Send: 282 of: 313 in: 371ms
                      2022-05-01 14:31:44.104 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:44.109 - debug: history.0 (4075723) Send: 334 of: 592 in: 363ms
                      2022-05-01 14:31:44.109 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:44.113 - debug: history.0 (4075723) got 1 datapoints for hm-rpc.0.REQ0777349.2.POWER
                      2022-05-01 14:31:44.132 - debug: history.0 (4075723) got 1 datapoints for hm-rpc.0.LTK0124798.2.POWER
                      2022-05-01 14:31:44.134 - debug: history.0 (4075723) got 1 datapoints for hm-rpc.0.LTK0124143.2.POWER
                      2022-05-01 14:31:44.142 - debug: history.0 (4075723) got 1 datapoints for hm-rpc.0.NEQ0116043.2.POWER
                      2022-05-01 14:31:44.147 - debug: history.0 (4075723) got 1 datapoints for hm-rpc.1.0001D3C99C3EFB.6.POWER
                      2022-05-01 14:31:44.168 - debug: history.0 (4075723) Send: 27 of: 31 in: 378ms
                      2022-05-01 14:31:44.169 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:44.170 - debug: history.0 (4075723) Send: 302 of: 494 in: 416ms
                      2022-05-01 14:31:44.171 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:44.176 - debug: history.0 (4075723) Send: 283 of: 290 in: 404ms
                      2022-05-01 14:31:44.176 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:44.181 - debug: history.0 (4075723) Send: 28 of: 31 in: 371ms
                      2022-05-01 14:31:44.181 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:44.183 - debug: history.0 (4075723) Send: 35 of: 38 in: 350ms
                      2022-05-01 14:31:44.183 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:44.209 - debug: history.0 (4075723) got 1 datapoints for hm-rpc.0.JEQ0140901.1.TEMPERATURE
                      2022-05-01 14:31:44.212 - debug: history.0 (4075723) got 1 datapoints for hm-rpc.0.LEQ0773306.2.TEMPERATURE
                      2022-05-01 14:31:44.238 - debug: history.0 (4075723) Send: 60 of: 365 in: 167ms
                      2022-05-01 14:31:44.238 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:44.244 - debug: history.0 (4075723) Send: 62 of: 1409 in: 197ms
                      2022-05-01 14:31:44.244 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:48.540 - debug: history.0 (4075723) getHistory call: {"id":"Messwerte.0.Solaranlage.Momentanwerte.Leistung_AC_aktuell","path":"/opt/iobroker/iobroker-data/history/","start":1651320000000,"end":1651408312584,"step":3600000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:48.540 - debug: history.0 (4075723) use parallel requests for getHistory
                      2022-05-01 14:31:48.632 - debug: history.0 (4075723) getHistory call: {"id":"Messwerte.0.Solaranlage.Momentanwerte.Leistung_AC_aktuell","path":"/opt/iobroker/iobroker-data/history/","start":1651320000000,"end":1651408312667,"step":3600000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:48.632 - debug: history.0 (4075723) use parallel requests for getHistory
                      2022-05-01 14:31:48.644 - debug: history.0 (4075723) got 1 datapoints for Messwerte.0.Solaranlage.Momentanwerte.Leistung_AC_aktuell
                      2022-05-01 14:31:48.687 - debug: history.0 (4075723) getHistory call: {"id":"Messwerte.0.Solaranlage.Momentanwerte.Leistung_AC_aktuell","path":"/opt/iobroker/iobroker-data/history/","start":1651320000000,"end":1651408312693,"step":3600000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:48.688 - debug: history.0 (4075723) use parallel requests for getHistory
                      2022-05-01 14:31:48.761 - debug: history.0 (4075723) got 1 datapoints for Messwerte.0.Solaranlage.Momentanwerte.Leistung_AC_aktuell
                      2022-05-01 14:31:48.775 - debug: history.0 (4075723) Send: 20 of: 7471 in: 235ms
                      2022-05-01 14:31:48.775 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.admin.0 from system.adapter.history.0
                      2022-05-01 14:31:48.800 - debug: history.0 (4075723) got 1 datapoints for Messwerte.0.Solaranlage.Momentanwerte.Leistung_AC_aktuell
                      2022-05-01 14:31:48.874 - debug: history.0 (4075723) Send: 20 of: 7471 in: 243ms
                      2022-05-01 14:31:48.874 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.admin.0 from system.adapter.history.0
                      2022-05-01 14:31:48.927 - debug: history.0 (4075723) Send: 20 of: 7471 in: 240ms
                      2022-05-01 14:31:48.927 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.admin.0 from system.adapter.history.0
                      2022-05-01 14:31:53.487 - debug: history.0 (4075723) getHistory call: {"id":"hm-rpc.0.JEQ0646431.1.STATE","path":"/opt/iobroker/iobroker-data/history/","start":1651149117531,"end":1651408317531,"step":4800000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"onchange","limit":2000,"addId":false,"sessionId":11,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:53.487 - debug: history.0 (4075723) got 2 datapoints for hm-rpc.0.JEQ0646431.1.STATE
                      2022-05-01 14:31:53.502 - debug: history.0 (4075723) Send: 186 values in: 15ms
                      2022-05-01 14:31:53.502 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:54.487 - debug: history.0 (4075723) getHistory call: {"id":"Messwerte.0.Pool.Druck_real","path":"/opt/iobroker/iobroker-data/history/","start":1651149117531,"end":1651408317531,"step":4800000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"false","aggregate":"onchange","limit":2000,"addId":false,"sessionId":11,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:54.487 - debug: history.0 (4075723) got 1 datapoints for Messwerte.0.Pool.Druck_real
                      2022-05-01 14:31:54.511 - debug: history.0 (4075723) Send: 3076 values in: 24ms
                      2022-05-01 14:31:54.511 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:54.517 - debug: history.0 (4075723) getHistory call: {"id":"hm-rpc.0.JEQ0140901.1.TEMPERATURE","path":"/opt/iobroker/iobroker-data/history/","start":1651149117531,"end":1651408317531,"step":4800000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":11,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:54.517 - debug: history.0 (4075723) use parallel requests for getHistory
                      2022-05-01 14:31:54.526 - debug: history.0 (4075723) getHistory call: {"id":"hm-rpc.0.LEQ0773306.2.TEMPERATURE","path":"/opt/iobroker/iobroker-data/history/","start":1651149117531,"end":1651408317531,"step":4800000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":11,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      2022-05-01 14:31:54.527 - debug: history.0 (4075723) use parallel requests for getHistory
                      2022-05-01 14:31:54.612 - debug: history.0 (4075723) got 1 datapoints for hm-rpc.0.JEQ0140901.1.TEMPERATURE
                      2022-05-01 14:31:54.625 - debug: history.0 (4075723) got 1 datapoints for hm-rpc.0.LEQ0773306.2.TEMPERATURE
                      2022-05-01 14:31:54.649 - debug: history.0 (4075723) Send: 63 of: 1409 in: 132ms
                      2022-05-01 14:31:54.650 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:54.651 - debug: history.0 (4075723) Send: 60 of: 366 in: 125ms
                      2022-05-01 14:31:54.651 - debug: history.0 (4075723) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                      2022-05-01 14:31:56.753 - debug: history.0 (4075723) sendTo "features" to system.adapter.admin.0 from system.adapter.history.0
                      2022-05-01 14:31:56.871 - debug: history.0 (4075723) getHistory call: {"id":"Messwerte.0.Solaranlage.Momentanwerte.Eigenverbrauch","path":"/opt/iobroker/iobroker-data/history/","start":946681200000,"end":1651408320907,"step":null,"count":500,"from":false,"ack":false,"q":false,"aggregate":"none","limit":1,"addId":false,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                      wobei ich da auf die Schnelle nichts finde was zu dem DP gehört, den ich öffnen will:
                      übrigens bei allen DPs, die im 6Sekunden-Takt loggen gleiches Problem.
                      @apollon77 sagte in Test Adapter History 2.0.0:
                      aber immer noch 2.0.0??
                        @homoran wo kommen denn diese massiv vielen gehHistory calls her? Das sind ja mehrere pro Sekunde???
                        Vor allem
                        Für den gleichen Datenpunkt. Weil am Ende ist’s sehr einfach: jeder der calls lädt mindestens die Daten des gesamten Tages und dann werden die auf die relevante Zeit gekürzt quasi. Ich schaue nochmal ob man das optimieren kann
                        Und ja. GitHub weiter auf 2.0.0
                        • apollon77A apollon77
                          Vor allem
                          Vor allem
                          Ich denke, das liegt daran, dass ich gerade die History des Datenpunktes aufrufe
                          (Hoffentlich)
                            Vor allem
                            (Hoffentlich)
                            @homoran dann wäre es aber schon ein Admin Bug das er soooooo oft fragt. Muss ich nochmal genau schauen.
                              ein Admin
                              ist aber noch 5.2.3
                                ein Admin
                                ist aber noch 5.2.3
                                @homoran Update mal?
                                    @apollon77 und wieder tausend null
                                    Wie gehabt, erst:
                                    2022-05-01 18:57:30.412 - error: host.iobroker-VM03 Caught by controller[0]: <--- Last few GCs --->
                                    2022-05-01 18:57:30.416 - error: host.iobroker-VM03 Caught by controller[0]: [320902:0x4c95c00] 73098 ms: Mark-sweep 1871.8 (1987.1) -> 1867.8 (1989.6) MB, 1742.9 / 0.0 ms (average mu = 0.153, current mu = 0.042) allocation failure scavenge might not succeed
                                    2022-05-01 18:57:30.416 - error: host.iobroker-VM03 Caught by controller[0]: [320902:0x4c95c00] 74837 ms: Mark-sweep 1883.8 (1989.6) -> 1879.9 (1992.1) MB, 1666.9 / 0.0 ms (average mu = 0.103, current mu = 0.041) allocation failure scavenge might not succeed
                                    2022-05-01 18:57:30.416 - error: host.iobroker-VM03 Caught by controller[1]: <--- JS stacktrace --->
                                    2022-05-01 18:57:30.416 - error: host.iobroker-VM03 Caught by controller[1]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
                                    2022-05-01 18:57:30.417 - error: host.iobroker-VM03 Caught by controller[2]: 1: 0xa3aaf0 node::Abort() [io.history.0]
                                    2022-05-01 18:57:30.417 - error: host.iobroker-VM03 Caught by controller[2]: 2: 0x970199 node::FatalError(char const*, char const*) [io.history.0]
                                    2022-05-01 18:57:30.417 - error: host.iobroker-VM03 Caught by controller[3]: 3: 0xbba45e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.history.0]
                                    2022-05-01 18:57:30.417 - error: host.iobroker-VM03 Caught by controller[4]: 4: 0xbba7d7 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.history.0]
                                    2022-05-01 18:57:30.417 - error: host.iobroker-VM03 Caught by controller[4]: 5: 0xd769e5 [io.history.0]
                                    2022-05-01 18:57:30.417 - error: host.iobroker-VM03 Caught by controller[4]: 6: 0xd7756f [io.history.0]
                                    2022-05-01 18:57:30.417 - error: host.iobroker-VM03 Caught by controller[4]: 7: 0xd853ab v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.history.0]
                                    2022-05-01 18:57:30.417 - error: host.iobroker-VM03 Caught by controller[4]: 8: 0xd88f6c v8::internal::Heap::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.history.0]
                                    2022-05-01 18:57:30.417 - error: host.iobroker-VM03 Caught by controller[5]: 9: 0xd4e73d v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [io.history.0]
                                    2022-05-01 18:57:30.417 - error: host.iobroker-VM03 Caught by controller[6]: 10: 0xd4a999 v8::internal::FactoryBase::AllocateRawArray(int, v8::internal::AllocationType) [io.history.0]
                                    2022-05-01 18:57:30.418 - error: host.iobroker-VM03 Caught by controller[7]: 11: 0xd4aa54 v8::internal::FactoryBase::NewFixedArrayWithFiller(v8::internal::Handle, int, v8::internal::Handle, v8::internal::AllocationType) [io.history.0]
                                    2022-05-01 18:57:30.418 - error: host.iobroker-VM03 Caught by controller[8]: 12: 0xf80ffe v8::internal::Handle v8::internal::HashTable::New(v8::internal::Isolate*, int, v8::internal::AllocationType, v8::internal::MinimumCapacity) [io.history.0]
                                    2022-05-01 18:57:30.418 - error: host.iobroker-VM03 Caught by controller[9]: 13: 0xf81cf9 v8::internal::Handle v8::internal::BaseNameDictionary::New(v8::internal::Isolate*, int, v8::internal::AllocationType, v8::internal::MinimumCapacity) [io.history.0]
                                    2022-05-01 18:57:30.418 - error: host.iobroker-VM03 Caught by controller[9]: 14: 0xf35be1 v8::internal::JSObject::MigrateToMap(v8::internal::Isolate*, v8::internal::Handle, v8::internal::Handle, int) [io.history.0]
                                    2022-05-01 18:57:30.418 - error: host.iobroker-VM03 Caught by controller[9]: 15: 0xf556cc v8::internal::LookupIterator::Delete() [io.history.0]
                                    2022-05-01 18:57:30.418 - error: host.iobroker-VM03 Caught by controller[9]: 16: 0xf2c55b v8::internal::JSReceiver::DeleteProperty(v8::internal::LookupIterator*, v8::internal::LanguageMode) [io.history.0]
                                    2022-05-01 18:57:30.418 - error: host.iobroker-VM03 Caught by controller[9]: 17: 0x10b4600 v8::internal::Runtime::DeleteObjectProperty(v8::internal::Isolate*, v8::internal::Handle, v8::internal::Handle, v8::internal::LanguageMode) [io.history.0]
                                    2022-05-01 18:57:30.418 - error: host.iobroker-VM03 Caught by controller[9]: 18: 0x10b673a v8::internal::Runtime_DeleteProperty(int, unsigned long*, v8::internal::Isolate*) [io.history.0]
                                    2022-05-01 18:57:30.418 - error: host.iobroker-VM03 Caught by controller[9]: 19: 0x1448e19 [io.history.0]
                                    2022-05-01 18:57:30.418 - warn: host.iobroker-VM03 instance system.adapter.history.0 terminated due to SIGABRT
                                    2022-05-01 18:57:30.418 - info: host.iobroker-VM03 instance system.adapter.history.0 terminated with code NaN ()
                                    2022-05-01 18:57:30.418 - info: host.iobroker-VM03 Restart adapter system.adapter.history.0 because enabled
                                    2022-05-01 18:58:00.450 - info: host.iobroker-VM03 instance system.adapter.history.0 started with pid 323469
                                    dann die tausend Meldungen enabled logging of....
                                    ein paar wenige debug mit found alias
                                    zwischendrin noch
                                    2022-05-01 18:58:09.706 - debug: history.0 (323704) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                    2022-05-01 18:58:09.729 - debug: history.0 (323704) Objects client ready ... initialize now
                                    2022-05-01 18:58:09.730 - debug: history.0 (323704) Objects create System PubSub Client
                                    2022-05-01 18:58:09.731 - debug: history.0 (323704) Objects create User PubSub Client
                                    2022-05-01 18:58:09.731 - debug: history.0 (323704) Objects client initialize lua scripts
                                    2022-05-01 18:58:09.746 - debug: history.0 (323704) Objects connected to redis: 0.0.0.0:9001
                                    2022-05-01 18:58:09.750 - debug: history.0 (323704) objectDB connected
                                    2022-05-01 18:58:09.751 - debug: history.0 (323704) Redis States: Use Redis connection: 0.0.0.0:9000
                                    2022-05-01 18:58:09.758 - debug: history.0 (323704) States create System PubSub Client
                                    2022-05-01 18:58:09.759 - debug: history.0 (323704) States create User PubSub Client
                                    2022-05-01 18:58:09.768 - debug: history.0 (323704) States connected to redis: 0.0.0.0:9000
                                    2022-05-01 18:58:09.768 - debug: history.0 (323704) statesDB connected
                                    2022-05-01 18:58:09.996 - debug: history.0 (323704) Plugin sentry Initialize Plugin (enabled=true)
                                    und dann wieder:
                                    2022-05-01 18:58:13.235 - debug: history.0 (323704) getHistory call: {"id":"hm-rpc.0.JEQ0646431.1.STATE","path":"/opt/iobroker/iobroker-data/history/","start":1651164932467,"end":1651424132467,"step":4800000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"onchange","limit":2000,"addId":false,"sessionId":934,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:13.236 - debug: history.0 (323704) got 2 datapoints for hm-rpc.0.JEQ0646431.1.STATE
                                    2022-05-01 18:58:13.260 - debug: history.0 (323704) Send: 176 values in: 25ms
                                    2022-05-01 18:58:13.261 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:13.263 - debug: history.0 (323704) getHistory call: {"id":"Messwerte.0.Pool.Druck_real","path":"/opt/iobroker/iobroker-data/history/","start":1651164932467,"end":1651424132467,"step":4800000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"false","aggregate":"onchange","limit":2000,"addId":false,"sessionId":934,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:13.264 - debug: history.0 (323704) got 1 datapoints for Messwerte.0.Pool.Druck_real
                                    2022-05-01 18:58:13.298 - debug: history.0 (323704) Send: 2951 values in: 35ms
                                    2022-05-01 18:58:13.298 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:13.303 - debug: history.0 (323704) getHistory call: {"id":"hm-rpc.0.JEQ0140901.1.TEMPERATURE","path":"/opt/iobroker/iobroker-data/history/","start":1651164932467,"end":1651424132467,"step":4800000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":934,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:13.303 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:13.311 - debug: history.0 (323704) getHistory call: {"id":"hm-rpc.0.LEQ0773306.2.TEMPERATURE","path":"/opt/iobroker/iobroker-data/history/","start":1651164932467,"end":1651424132467,"step":4800000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":934,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:13.312 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:13.397 - debug: history.0 (323704) got 1 datapoints for hm-rpc.0.JEQ0140901.1.TEMPERATURE
                                    2022-05-01 18:58:13.407 - debug: history.0 (323704) got 1 datapoints for hm-rpc.0.LEQ0773306.2.TEMPERATURE
                                    2022-05-01 18:58:13.433 - debug: history.0 (323704) Send: 63 of: 1413 in: 130ms
                                    2022-05-01 18:58:13.433 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:13.438 - debug: history.0 (323704) Send: 59 of: 418 in: 127ms
                                    2022-05-01 18:58:13.439 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:16.791 - debug: history.0 (323704) getHistory call: {"id":"hm-rpc.0.NEQ0384904.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651381096528,"end":1651424296528,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":60,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:16.791 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:16.863 - debug: history.0 (323704) got 1 datapoints for hm-rpc.0.NEQ0384904.2.POWER
                                    2022-05-01 18:58:16.892 - debug: history.0 (323704) Send: 26 of: 39 in: 101ms
                                    2022-05-01 18:58:16.893 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:17.777 - debug: history.0 (323704) getHistory call: {"id":"hm-rpc.0.LTK0124191.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651381096528,"end":1651424296528,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":60,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:17.778 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:17.786 - debug: history.0 (323704) getHistory call: {"id":"hm-rpc.0.KEQ0966548.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651381096528,"end":1651424296528,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":60,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:17.786 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:17.794 - debug: history.0 (323704) getHistory call: {"id":"hm-rpc.0.KEQ0967747.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651381096528,"end":1651424296528,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":60,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:17.794 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:17.801 - debug: history.0 (323704) getHistory call: {"id":"hm-rpc.0.NEQ0386317.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651381096528,"end":1651424296528,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":60,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:17.802 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:17.812 - debug: history.0 (323704) getHistory call: {"id":"hm-rpc.0.LTK0124795.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651381096528,"end":1651424296528,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":60,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:17.812 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:17.827 - debug: history.0 (323704) getHistory call: {"id":"hm-rpc.0.LTK0124195.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651381096528,"end":1651424296528,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":60,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:17.828 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:17.842 - debug: history.0 (323704) getHistory call: {"id":"hm-rpc.0.LTK0124798.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651381096528,"end":1651424296528,"step":100000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":60,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:17.842 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:17.860 - debug: history.0 (323704) getHistory call: {"id":"hm-rpc.0.LTK0124143.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651381096528,"end":1651424296528,"step":100000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":60,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:17.862 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:17.886 - debug: history.0 (323704) getHistory call: {"id":"hm-rpc.0.REQ0777349.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651381096528,"end":1651424296528,"step":100000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":2000,"addId":false,"sessionId":60,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:17.887 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:17.901 - debug: history.0 (323704) getHistory call: {"id":"hm-rpc.0.NEQ0116043.2.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651381096528,"end":1651424296528,"step":100000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":60,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:17.901 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:17.937 - debug: history.0 (323704) getHistory call: {"id":"hm-rpc.1.0001D3C99C3EFB.6.POWER","path":"/opt/iobroker/iobroker-data/history/","start":1651381096528,"end":1651424296528,"step":100000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":60,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:17.938 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:17.972 - debug: history.0 (323704) got 2 datapoints for hm-rpc.0.LTK0124795.2.POWER
                                    2022-05-01 18:58:18.003 - debug: history.0 (323704) got 1 datapoints for hm-rpc.0.LTK0124191.2.POWER
                                    2022-05-01 18:58:18.013 - debug: history.0 (323704) got 1 datapoints for hm-rpc.0.KEQ0967747.2.POWER
                                    2022-05-01 18:58:18.173 - debug: history.0 (323704) got 1 datapoints for hm-rpc.0.KEQ0966548.2.POWER
                                    2022-05-01 18:58:18.174 - debug: history.0 (323704) Send: 283 of: 331 in: 362ms
                                    2022-05-01 18:58:18.175 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:18.177 - debug: history.0 (323704) Send: 182 of: 195 in: 400ms
                                    2022-05-01 18:58:18.178 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:18.182 - debug: history.0 (323704) got 1 datapoints for hm-rpc.0.NEQ0386317.2.POWER
                                    2022-05-01 18:58:18.184 - debug: history.0 (323704) got 1 datapoints for hm-rpc.0.REQ0777349.2.POWER
                                    2022-05-01 18:58:18.193 - debug: history.0 (323704) Send: 179 of: 192 in: 399ms
                                    2022-05-01 18:58:18.194 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:18.203 - debug: history.0 (323704) got 2 datapoints for hm-rpc.0.LTK0124195.2.POWER
                                    2022-05-01 18:58:18.206 - debug: history.0 (323704) got 1 datapoints for hm-rpc.0.LTK0124798.2.POWER
                                    2022-05-01 18:58:18.232 - debug: history.0 (323704) Send: 200 of: 213 in: 446ms
                                    2022-05-01 18:58:18.233 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:18.237 - debug: history.0 (323704) Send: 192 of: 212 in: 436ms
                                    2022-05-01 18:58:18.238 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:18.240 - debug: history.0 (323704) Send: 28 of: 39 in: 354ms
                                    2022-05-01 18:58:18.242 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:18.243 - debug: history.0 (323704) Send: 364 of: 1318 in: 416ms
                                    2022-05-01 18:58:18.244 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:18.245 - debug: history.0 (323704) Send: 303 of: 570 in: 403ms
                                    2022-05-01 18:58:18.246 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:18.249 - debug: history.0 (323704) got 1 datapoints for hm-rpc.1.0001D3C99C3EFB.6.POWER
                                    2022-05-01 18:58:18.254 - debug: history.0 (323704) got 1 datapoints for hm-rpc.0.LTK0124143.2.POWER
                                    2022-05-01 18:58:18.261 - debug: history.0 (323704) got 1 datapoints for hm-rpc.0.NEQ0116043.2.POWER
                                    2022-05-01 18:58:18.265 - debug: history.0 (323704) Send: 40 of: 46 in: 328ms
                                    2022-05-01 18:58:18.265 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:18.266 - debug: history.0 (323704) Send: 284 of: 292 in: 406ms
                                    2022-05-01 18:58:18.267 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:18.274 - debug: history.0 (323704) Send: 33 of: 39 in: 372ms
                                    2022-05-01 18:58:18.274 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:21.810 - debug: history.0 (323704) getHistory call: {"id":"hm-rega.0.1995","path":"/opt/iobroker/iobroker-data/history/","start":1651165101563,"end":1651424301563,"step":null,"count":3000,"from":false,"ack":false,"q":false,"ignoreNull":"true","aggregate":"minmax","limit":3000,"addId":false,"sessionId":96,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:21.810 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:21.818 - debug: history.0 (323704) getHistory call: {"id":"hm-rpc.0.JEQ0140901.1.WIND_SPEED","path":"/opt/iobroker/iobroker-data/history/","start":1650819501567,"end":1651424301567,"step":null,"count":400,"from":false,"ack":false,"q":false,"aggregate":"max","limit":400,"addId":false,"sessionId":49,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:21.818 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:21.892 - debug: history.0 (323704) got 1 datapoints for hm-rpc.0.JEQ0140901.1.WIND_SPEED
                                    2022-05-01 18:58:21.927 - debug: history.0 (323704) got 1 datapoints for hm-rega.0.1995
                                    2022-05-01 18:58:21.938 - debug: history.0 (323704) Send: 153 of: 167 in: 127ms
                                    2022-05-01 18:58:21.938 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:21.942 - debug: history.0 (323704) Send: 356 of: 2640 in: 124ms
                                    2022-05-01 18:58:21.943 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:22.776 - debug: history.0 (323704) getHistory call: {"id":"Messwerte.0.Wetterdaten.Regenintensitaet","path":"/opt/iobroker/iobroker-data/history/","start":1651165101563,"end":1651424301563,"step":null,"count":3000,"from":false,"ack":false,"q":false,"ignoreNull":"false","aggregate":"minmax","limit":3000,"addId":false,"sessionId":96,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:22.776 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:22.783 - debug: history.0 (323704) getHistory call: {"id":"hm-rpc.0.KEQ1022589.1.STATE","path":"/opt/iobroker/iobroker-data/history/","start":1651165101563,"end":1651424301563,"step":null,"count":3000,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":3000,"addId":false,"sessionId":96,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:22.784 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:22.793 - debug: history.0 (323704) getHistory call: {"id":"hm-rega.0.12770","path":"/opt/iobroker/iobroker-data/history/","start":1650819501567,"end":1651424301567,"step":null,"count":400,"from":false,"ack":false,"q":false,"aggregate":"average","limit":400,"addId":false,"sessionId":49,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:22.793 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:22.801 - debug: history.0 (323704) getHistory call: {"id":"hm-rpc.0.JEQ0140901.1.WIND_SPEED","path":"/opt/iobroker/iobroker-data/history/","start":1650819501567,"end":1651424301567,"step":null,"count":400,"from":false,"ack":false,"q":false,"aggregate":"min","limit":400,"addId":false,"sessionId":49,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:22.802 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:22.906 - debug: history.0 (323704) got 1 datapoints for hm-rega.0.12770
                                    2022-05-01 18:58:22.920 - debug: history.0 (323704) got 1 datapoints for hm-rpc.0.JEQ0140901.1.WIND_SPEED
                                    2022-05-01 18:58:22.945 - debug: history.0 (323704) got 1 datapoints for Messwerte.0.Wetterdaten.Regenintensitaet
                                    2022-05-01 18:58:22.963 - debug: history.0 (323704) got 1 datapoints for hm-rpc.0.KEQ1022589.1.STATE
                                    2022-05-01 18:58:22.975 - debug: history.0 (323704) Send: 165 of: 179 in: 192ms
                                    2022-05-01 18:58:22.976 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:22.987 - debug: history.0 (323704) Send: 357 of: 2640 in: 186ms
                                    2022-05-01 18:58:22.988 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:23.006 - debug: history.0 (323704) Send: 16 of: 21 in: 230ms
                                    2022-05-01 18:58:23.006 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:23.010 - debug: history.0 (323704) Send: 368 of: 3430 in: 218ms
                                    2022-05-01 18:58:23.010 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:42.385 - debug: history.0 (323704) getHistory call: {"id":"Messwerte.0.Solaranlage.Momentanwerte.Solarestimate2","path":"/opt/iobroker/iobroker-data/history/","start":1651356000000,"end":1651442400000,"step":null,"count":300,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":300,"addId":false,"sessionId":875,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:42.386 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:42.393 - debug: history.0 (323704) getHistory call: {"id":"Messwerte.0.Solaranlage.Momentanwerte.Leistung_AC_aktuell","path":"/opt/iobroker/iobroker-data/history/","start":1651356000000,"end":1651442400000,"step":null,"count":300,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":300,"addId":false,"sessionId":875,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:42.393 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:42.398 - debug: history.0 (323704) getHistory call: {"id":"Messwerte.0.Solaranlage.Momentanwerte.Eigenverbrauch","path":"/opt/iobroker/iobroker-data/history/","start":1651356000000,"end":1651442400000,"step":null,"count":300,"from":false,"ack":false,"q":false,"ignoreNull":"false","aggregate":"minmax","limit":300,"addId":false,"sessionId":875,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:42.399 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:42.406 - debug: history.0 (323704) getHistory call: {"id":"Messwerte.0.Stromzaehler.Momentanwerte.akt_Verbrauch","path":"/opt/iobroker/iobroker-data/history/","start":1651356000000,"end":1651442400000,"step":null,"count":300,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":300,"addId":false,"sessionId":875,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:42.407 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:42.413 - debug: history.0 (323704) getHistory call: {"id":"Messwerte.0.Stromzaehler.Momentanwerte.akt_Einspeisung","path":"/opt/iobroker/iobroker-data/history/","start":1651356000000,"end":1651442400000,"step":null,"count":300,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":300,"addId":false,"sessionId":875,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:42.413 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:42.482 - debug: history.0 (323704) got 4 datapoints for Messwerte.0.Solaranlage.Momentanwerte.Leistung_AC_aktuell
                                    2022-05-01 18:58:42.499 - debug: history.0 (323704) got 6 datapoints for Messwerte.0.Solaranlage.Momentanwerte.Eigenverbrauch
                                    2022-05-01 18:58:42.512 - debug: history.0 (323704) got 2 datapoints for Messwerte.0.Stromzaehler.Momentanwerte.akt_Einspeisung
                                    2022-05-01 18:58:42.516 - debug: history.0 (323704) got 1 datapoints for Messwerte.0.Solaranlage.Momentanwerte.Solarestimate2
                                    2022-05-01 18:58:42.571 - debug: history.0 (323704) Send: 161 of: 6024 in: 178ms
                                    2022-05-01 18:58:42.571 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:42.589 - debug: history.0 (323704) Send: 157 of: 736 in: 204ms
                                    2022-05-01 18:58:42.589 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:42.595 - debug: history.0 (323704) Send: 152 of: 4825 in: 182ms
                                    2022-05-01 18:58:42.595 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:42.612 - debug: history.0 (323704) got 5 datapoints for Messwerte.0.Stromzaehler.Momentanwerte.akt_Verbrauch
                                    2022-05-01 18:58:42.652 - debug: history.0 (323704) Send: 178 of: 6341 in: 254ms
                                    2022-05-01 18:58:42.652 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:42.694 - debug: history.0 (323704) Send: 241 of: 8896 in: 288ms
                                    2022-05-01 18:58:42.694 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:43.234 - debug: history.0 (323704) getHistory call: {"id":"hm-rpc.0.JEQ0646431.1.STATE","path":"/opt/iobroker/iobroker-data/history/","start":1651164962469,"end":1651424162469,"step":4800000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"onchange","limit":2000,"addId":false,"sessionId":935,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:43.234 - debug: history.0 (323704) got 2 datapoints for hm-rpc.0.JEQ0646431.1.STATE
                                    2022-05-01 18:58:43.271 - debug: history.0 (323704) Send: 176 values in: 37ms
                                    2022-05-01 18:58:43.271 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:43.273 - debug: history.0 (323704) getHistory call: {"id":"Messwerte.0.Pool.Druck_real","path":"/opt/iobroker/iobroker-data/history/","start":1651164962469,"end":1651424162469,"step":4800000,"count":500,"from":false,"ack":false,"q":false,"ignoreNull":"false","aggregate":"onchange","limit":2000,"addId":false,"sessionId":935,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:43.273 - debug: history.0 (323704) got 1 datapoints for Messwerte.0.Pool.Druck_real
                                    2022-05-01 18:58:43.303 - debug: history.0 (323704) Send: 2951 values in: 30ms
                                    2022-05-01 18:58:43.303 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:43.310 - debug: history.0 (323704) getHistory call: {"id":"hm-rpc.0.JEQ0140901.1.TEMPERATURE","path":"/opt/iobroker/iobroker-data/history/","start":1651164962469,"end":1651424162469,"step":4800000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":935,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:43.310 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:43.316 - debug: history.0 (323704) getHistory call: {"id":"hm-rpc.0.LEQ0773306.2.TEMPERATURE","path":"/opt/iobroker/iobroker-data/history/","start":1651164962469,"end":1651424162469,"step":4800000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"sessionId":935,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:43.316 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:43.383 - debug: history.0 (323704) got 1 datapoints for hm-rpc.0.JEQ0140901.1.TEMPERATURE
                                    2022-05-01 18:58:43.396 - debug: history.0 (323704) got 1 datapoints for hm-rpc.0.LEQ0773306.2.TEMPERATURE
                                    2022-05-01 18:58:43.410 - debug: history.0 (323704) Send: 63 of: 1413 in: 100ms
                                    2022-05-01 18:58:43.411 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:43.419 - debug: history.0 (323704) Send: 59 of: 418 in: 103ms
                                    2022-05-01 18:58:43.419 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.web.0 from system.adapter.history.0
                                    2022-05-01 18:58:51.231 - debug: history.0 (323704) getHistory call: {"id":"Messwerte.0.Solaranlage.Momentanwerte.Leistung_String1","path":"/opt/iobroker/iobroker-data/history/","start":1651334400000,"end":1651424330980,"step":3600000,"count":500,"from":false,"ack":false,"q":false,"aggregate":"minmax","limit":2000,"addId":false,"returnNewestEntries":false,"percentile":null,"quantile":null,"integralUnit":null,"integralInterpolation":null,"removeBorderValues":false,"round":null}
                                    2022-05-01 18:58:51.232 - debug: history.0 (323704) use parallel requests for getHistory
                                    2022-05-01 18:58:51.293 - debug: history.0 (323704) got 6 datapoints for Messwerte.0.Solaranlage.Momentanwerte.Leistung_String1
                                    2022-05-01 18:58:51.372 - debug: history.0 (323704) Send: 19 of: 8168 in: 141ms
                                    2022-05-01 18:58:51.372 - debug: history.0 (323704) sendTo "getHistory" to system.adapter.admin.0 from system.adapter.history.0
                                    2022-05-01 18:58:52.856 - debug: history.0 (323704) sendTo "features" to system.adapter.admin.0 from system.adapter.history.0
                                    2022-05-01 18:58:52.966 - debug: history.0 (323704) getHistory call: {"id":"Messwerte.0.Solaranlage.Momentanwerte.Eigenverbrauch","path":"/opt/iobroker/iobroker-
                                    Hat lange gedauert, aber habe ich das richtig verstanden, dass erst der gesamte Tag eingelesen wird, mit allen DPs?
                                    Das sind bei mir etwa 50MB
                                      Wie gehabt, erst:
                                      zwischendrin noch
                                      und dann wieder:
                                      @homoran kann das sein das auch deine Vis so oft alles neu lädt?!
                                      Also die Abfolge passt ja. Zuerst der Crash (was genau loggt er denn VOR dem Crash??) dann startet er neu, aktiviert alle datenpunkte und dann kommen ggf von Vis oder admin Dinge rein.
                                      ich schaue heute Abend nochmal log weil an sich sollte das alles nicht sooooo wild sein mit RAM weil an sich die datenabfrage und nem extra Prozess passiert.
                                      • apollon77A Offline
                                        #66
                                        Hi All,
                                        GitHub hat nochmal ein paar nderungen erfahren - primär im Umgang mit dem Abfragen von Daten und versucht dort Dinge zu optimieren. Version bleibt weiterhin 2.0.0
                                          Hi All,
                                          Marty56
                                          schrieb am zuletzt editiert von Marty56
                                          #67
                                          @apollon77
                                          Super, dass der Adapter überarbeitet wird. Endlich!!! Juhuuu.
                                          Was mir immer wieder passiert ist,
                                          dass irgendein Sensor Mist in die History schreibt, die Daten versaut und die Diagramme unbrauchbar macht.
                                          Es wäre wünschenswert, wenn man
                                          1. Datenpunkte aus der History per UI löschen, ändern und hinzufügen könnte.
                                          2. beim Editieren von Datenpunkte in der History DB, muss natürlich auch der Zeitpunkt änderbar sein.
                                          3. Was auch noch super wäre, wenn man alle Datenpunkte, die man logt an einer Stelle, nämlich dem Adapter wiederfinden würde und dort zentral verwalten könnte.
                                            Man muss jedesmal in den Verzeichnisbäumen der Datenpunkte suchen, das nervt total und ist unübersichtlich. Was mir auch schon passiert ist, dass ich einen Datenpunkt vergessen habe, und der hat mir dann die Harddisk voll gemacht.
                                          Ich bin mir nicht ganz sicher, ob das im Change Log beinhaltet ist. Habe es aber beim Überfliegen nicht gefunden.
                                          Und ein verwandtes Thema: alle Grafik Module für VIS können max nur 2 Jahre darstellen. Flot kann, wenn man die URL umständlich editiert auch 9 Jahre darstellen. Es wäre schön, wenn man dieses Defizit auch beheben könnte.
                                          Liebe Grüße
                                          Martin
                                          HW:NUC (16 GB Ram)
                                          OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
                                          apollon77A HomoranH 2 Antworten Letzte Antwort
