  4. Zigbee mal wieder kaputt
    1.0k
    6.1k
17 Beiträge 6 Kommentatoren 2.5k Aufrufe 6 Beobachtet
  • AsgothianA Asgothian
    @mpl1338 du hast ein Problem mit deiner seriellen Schnittstelle:
    Error while opening serialport 'Error: Error: Inappropriate ioctl for device setting custom baud rate of 115200'
    da stimmt etwas mit der Hardware oder dem OS nicht.
    A.
    @asgothian sagte in Zigbee mal wieder kaputt:
    Ja, deswegen die Frage ob das ein Container oder VM oder sowas ist.
      mpl1338
      ok hier nochgmal:
      zigbee.0
      2022-04-23 09:47:35.471	silly	States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1650700055469,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651377248}
      zigbee.0
      2022-04-23 09:47:35.471	silly	States user redis pmessage zigbee.0.*/zigbee.0.info.pairingMessage:{"val":"Error: Starting zigbee-herdsman problem : \"Error while opening serialport 'Error: Error: Inappropriate ioctl for device setting custom baud rate of 115200'\". undefined","ack":true,"ts":1650700055469,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651553035}
      zigbee.0
      2022-04-23 09:47:35.465	error	Error herdsman start
      zigbee.0
      2022-04-23 09:47:35.465	error	Failed to start Zigbee
      zigbee.0
      2022-04-23 09:47:35.465	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Inappropriate ioctl for device setting custom baud rate of 115200'"
      zigbee.0
      2022-04-23 09:47:35.374	info	Installed Version: iobroker.zigbee@1.6.18
      zigbee.0
      2022-04-23 09:47:35.366	debug	Starting zigbee-herdsman...
      zigbee.0
      2022-04-23 09:47:35.366	info	Starting Zigbee npm ...
      zigbee.0
      2022-04-23 09:47:35.365	info	Try to reconnect. 1 attempts left
      zigbee.0
      2022-04-23 09:47:25.396	silly	States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1650700045378,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651377248}
      zigbee.0
      2022-04-23 09:47:25.396	silly	States user redis pmessage zigbee.0.*/zigbee.0.info.pairingMessage:{"val":"Error: Starting zigbee-herdsman problem : \"Error while opening serialport 'Error: Error: Inappropriate ioctl for device setting custom baud rate of 115200'\". undefined","ack":true,"ts":1650700045377,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651553035}
      zigbee.0
      2022-04-23 09:47:25.377	silly	States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1650700045373,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651377248}
      zigbee.0
      2022-04-23 09:47:25.375	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2022_04_23-09_47_25.tar.gz success
      zigbee.0
      2022-04-23 09:47:25.365	error	Error herdsman start
      zigbee.0
      2022-04-23 09:47:25.365	error	Failed to start Zigbee
      zigbee.0
      2022-04-23 09:47:25.364	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Inappropriate ioctl for device setting custom baud rate of 115200'"
      zigbee.0
      2022-04-23 09:47:25.332	info	Installed Version: iobroker.zigbee@1.6.18
      zigbee.0
      2022-04-23 09:47:25.292	silly	States system redis pmessage system.adapter.zigbee.0.logLevel/system.adapter.zigbee.0.logLevel:{"val":"silly","ack":true,"ts":1650700045210,"q":0,"from":"system.adapter.zigbee.0","lc":1650651674279}
      zigbee.0
      2022-04-23 09:47:25.152	debug	Starting zigbee-herdsman...
      zigbee.0
      2022-04-23 09:47:25.152	info	Starting Zigbee npm ...
      zigbee.0
      2022-04-23 09:47:25.134	debug	Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[x],"extenedPanID":[x]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
      zigbee.0
      2022-04-23 09:47:25.120	info	starting. Version 1.6.18 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.1, js-controller: 4.0.23
      zigbee.0
      2022-04-23 09:47:25.003	debug	Plugin sentry Initialize Plugin (enabled=true)
      zigbee.0
      2022-04-23 09:47:24.949	silly	statesDB connected
      zigbee.0
      2022-04-23 09:47:24.949	debug	States connected to redis: 127.0.0.1:9000
      zigbee.0
      2022-04-23 09:47:24.939	debug	States create User PubSub Client
      zigbee.0
      2022-04-23 09:47:24.938	debug	States create System PubSub Client
      zigbee.0
      2022-04-23 09:47:24.932	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      zigbee.0
      2022-04-23 09:47:24.931	silly	objectDB connected
      zigbee.0
      2022-04-23 09:47:24.929	silly	redis psubscribe cfg.o.enum.*
      zigbee.0
      2022-04-23 09:47:24.920	silly	redis psubscribe cfg.o.system.user.*
      zigbee.0
      2022-04-23 09:47:24.919	debug	Objects connected to redis: 127.0.0.1:9001
      zigbee.0
      2022-04-23 09:47:24.917	debug	Objects client initialize lua scripts
      zigbee.0
      2022-04-23 09:47:24.900	debug	Objects create User PubSub Client
      zigbee.0
      2022-04-23 09:47:24.900	debug	Objects create System PubSub Client
      zigbee.0
      2022-04-23 09:47:24.899	debug	Objects client ready ... initialize now
      zigbee.0
      2022-04-23 09:47:24.878	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
      host.iobroker
      2022-04-23 09:47:24.050	info	instance system.adapter.zigbee.0 started with pid 46805
      host.iobroker
      2022-04-23 09:47:21.631	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      zigbee.0
      2022-04-23 09:47:21.170	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d0005816448.link_quality:{"val":0,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471794}
      zigbee.0
      2022-04-23 09:47:21.169	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d0005816448.available:{"val":false,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
      zigbee.0
      2022-04-23 09:47:21.169	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000577ed85.link_quality:{"val":0,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
      zigbee.0
      2022-04-23 09:47:21.167	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000577ed85.available:{"val":false,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
      zigbee.0
      2022-04-23 09:47:21.165	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000581710d.link_quality:{"val":0,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
      zigbee.0
      2022-04-23 09:47:21.165	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000581710d.available:{"val":false,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
      zigbee.0
      2022-04-23 09:47:21.165	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d0006954782.link_quality:{"val":0,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
      zigbee.0
      2022-04-23 09:47:21.156	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d0006954782.available:{"val":false,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
      zigbee.0
      2022-04-23 09:47:21.156	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d0006b36df2.link_quality:{"val":0,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
      zigbee.0
      2022-04-23 09:47:21.155	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d0006b36df2.available:{"val":false,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
      zigbee.0
      2022-04-23 09:47:21.154	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d0006b3f166.link_quality:{"val":0,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
      zigbee.0
      2022-04-23 09:47:21.153	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d0006b3f166.available:{"val":false,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
      zigbee.0
      2022-04-23 09:47:21.153	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000400e524.link_quality:{"val":0,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
      zigbee.0
      2022-04-23 09:47:21.151	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000400e524.available:{"val":false,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471697}
      zigbee.0
      2022-04-23 09:47:21.146	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000400c2e0.link_quality:{"val":0,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471695}
      zigbee.0
      2022-04-23 09:47:21.141	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000400c2e0.available:{"val":false,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471695}
      zigbee.0
      2022-04-23 09:47:21.140	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000416c1e5.link_quality:{"val":0,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471695}
      zigbee.0
      2022-04-23 09:47:21.139	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000416c1e5.available:{"val":false,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471694}
      zigbee.0
      2022-04-23 09:47:21.128	silly	States user redis pmessage zigbee.0.*/zigbee.0.info.undefinedDevices:{"val":"{}","ack":true,"ts":1650700041107,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651435076}
      zigbee.0
      2022-04-23 09:47:21.091	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0
      2022-04-23 09:47:21.090	debug	Plugin sentry destroyed
      zigbee.0
      2022-04-23 09:47:21.090	info	terminating
      zigbee.0
      2022-04-23 09:47:21.088	warn	Failed to stop zigbee during startup
      zigbee.0
      2022-04-23 09:47:21.039	info	Zigbee: disabling joining new devices.
      zigbee.0
      2022-04-23 09:47:21.037	debug	onDeviceStatusUpdate: 00158d0005816448: false
      zigbee.0
      2022-04-23 09:47:21.036	debug	DeviceAvailability:Publish LQ for 0x00158d0005816448 = 0
      zigbee.0
      2022-04-23 09:47:21.036	debug	onDeviceStatusUpdate: 00158d000577ed85: false
      zigbee.0
      2022-04-23 09:47:21.035	debug	DeviceAvailability:Publish LQ for 0x00158d000577ed85 = 0
      zigbee.0
      2022-04-23 09:47:21.036	debug	DeviceAvailability:Publish available for 0x00158d0005816448 = false
      zigbee.0
      2022-04-23 09:47:21.034	debug	DeviceAvailability:Publish available for 0x00158d000577ed85 = false
      zigbee.0
      2022-04-23 09:47:21.034	debug	onDeviceStatusUpdate: 00158d000581710d: false
      zigbee.0
      2022-04-23 09:47:21.033	debug	DeviceAvailability:Publish available for 0x00158d000581710d = false
      zigbee.0
      2022-04-23 09:47:21.033	debug	onDeviceStatusUpdate: 00158d0006954782: false
      zigbee.0
      2022-04-23 09:47:21.033	debug	DeviceAvailability:Publish LQ for 0x00158d000581710d = 0
      zigbee.0
      2022-04-23 09:47:21.032	debug	DeviceAvailability:Publish LQ for 0x00158d0006954782 = 0
      zigbee.0
      2022-04-23 09:47:21.031	debug	DeviceAvailability:Publish available for 0x00158d0006954782 = false
      zigbee.0
      2022-04-23 09:47:21.031	debug	onDeviceStatusUpdate: 00158d0006b36df2: false
      zigbee.0
      2022-04-23 09:47:21.030	debug	DeviceAvailability:Publish LQ for 0x00158d0006b36df2 = 0
      zigbee.0
      2022-04-23 09:47:21.030	debug	DeviceAvailability:Publish available for 0x00158d0006b36df2 = false
      zigbee.0
      2022-04-23 09:47:21.030	debug	onDeviceStatusUpdate: 00158d0006b3f166: false
      zigbee.0
      2022-04-23 09:47:21.029	debug	DeviceAvailability:Publish LQ for 0x00158d0006b3f166 = 0
      zigbee.0
      2022-04-23 09:47:21.028	debug	DeviceAvailability:Publish available for 0x00158d0006b3f166 = false
      zigbee.0
      2022-04-23 09:47:21.028	debug	onDeviceStatusUpdate: 00158d000400e524: false
      zigbee.0
      2022-04-23 09:47:21.027	debug	DeviceAvailability:Publish LQ for 0x00158d000400e524 = 0
      zigbee.0
      2022-04-23 09:47:21.026	debug	DeviceAvailability:Publish available for 0x00158d000400e524 = false
      zigbee.0
      2022-04-23 09:47:21.026	debug	onDeviceStatusUpdate: 00158d000400c2e0: false
      zigbee.0
      2022-04-23 09:47:21.025	debug	DeviceAvailability:Publish LQ for 0x00158d000400c2e0 = 0
      zigbee.0
      2022-04-23 09:47:21.023	debug	DeviceAvailability:Publish available for 0x00158d000400c2e0 = false
      zigbee.0
      2022-04-23 09:47:21.022	debug	onDeviceStatusUpdate: 00158d000416c1e5: false
      zigbee.0
      2022-04-23 09:47:21.019	debug	DeviceAvailability:Publish LQ for 0x00158d000416c1e5 = 0
      zigbee.0
      2022-04-23 09:47:21.016	debug	DeviceAvailability:Publish available for 0x00158d000416c1e5 = false
      zigbee.0
      2022-04-23 09:47:21.014	info	cleaned everything up...
      host.iobroker
      2022-04-23 09:47:21.015	info	stopInstance system.adapter.zigbee.0 send kill signal
      zigbee.0
      2022-04-23 09:47:21.014	silly	States system redis pmessage system.adapter.zigbee.0.sigKill/system.adapter.zigbee.0.sigKill:{"val":-1,"ack":false,"ts":1650700041013,"q":0,"from":"system.host.iobroker","lc":1650700041013}
      zigbee.0
      2022-04-23 09:47:21.014	info	Got terminate signal TERMINATE_YOURSELF
      IOB läuft auf einem Proxmox Container
      ls -l /dev/ttyACM0
      -------rw- 1 root root 0 Apr 22 19:53 /dev/ttyACM0
      • M mpl1338
        ok hier nochgmal:
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        host.iobroker
        host.iobroker
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        host.iobroker
        zigbee.0
        zigbee.0
        ls -l /dev/ttyACM0
        @mpl1338
        Gut, Container also...
        Auf einem nativen System schaut das jedenfalls so aus:
        ls -l /dev/ttyAMA0
        crw-rw---- 1 root dialout 204, 64 Apr 23 01:04 /dev/ttyAMA0
        Mein zigbee-Stick wird aber auch woanders (nämlich /dev/ttyUSB0) eingehängt:
        ls -la /dev/serial/by-id/
        total 0
        drwxr-xr-x 2 root root 60 Apr 23 01:04 .
        drwxr-xr-x 4 root root 80 Apr 23 01:04 ..
        lrwxrwxrwx 1 root root 13 Apr 23 01:04 usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0 -> ../../ttyUSB0
        ls -l /dev/ttyUSB0
        crw-rw---- 1 root dialout 188, 0 Apr 23 09:25 /dev/ttyUSB0
          mpl1338
          Ich weiß jetzt nicht warum, es geht jedoch wieder.
          lsusb
          Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
          Bus 001 Device 002: ID 0451:16c8 Texas Instruments, Inc.
          Bus 001 Device 003: ID 8087:0aaa Intel Corp.
          ls -l /dev/ttyACM0
          crw-rw---- 1 root dialout 166, 0 Apr 23 10:21 /dev/ttyACM0
          habe gestern 100te mal neu gestartet und nichts ist passiert. Eben nochmal neu gestartet und er findet ihn wieder
          • M mpl1338
            lsusb
            ls -l /dev/ttyACM0
            @mpl1338
            Dann stell den Link aus /dev/serial/by-id ein. Der ist robuster bei Neustarts.
              mpl1338
              gibts nicht
              ls: cannot access '/dev/serial/by-id/': No such file or directory
              Thomas BraunT S G 3 Antworten Letzte Antwort
              • M mpl1338
                gibts nicht
                @mpl1338
                Gut, liegt vielleicht an dem Container-Gedöns.
                Ich weiß schon, warum ich das nicht verwende.
                • M mpl1338
                  gibts nicht
                  Snopy_16
                  @mpl1338 Ich hatte auch mal den Fehler, Iobroker lief aber auf einem Raspi PI 4.
                  da war die serielle Schnittstelle nicht aktiviert.
                  Man kann nicht alle Probleme lösen, aber wenigstens verursachen.
                  LenovoThinkCentre M900 Tiny | i5-T6500 | 16 GB | 256 SSD
                  iobroker auf Proxmox VM
                  Node.js: v22.22.3 - NPM: 10.9.8 - js-controller: 7.0.6 - admin: v7.8.23
                  FritzBox-7530TX hinter Glasfasermodem, WiFi mit Unifi
                  • M mpl1338
                    gibts nicht
                    guergen
                    @mpl1338 sagte in Zigbee mal wieder kaputt:
                    Normal geht der Befehl unter Proxmox!
                    Hast Du den Stick auch richtig an den Container weitergegeben? Als VM ist das wesendlich entspannter!
                    Schau Dir das mal an : https://coldcorner.de/2018/07/12/proxmox-usb-passthrough-fuer-lxc-container-z-wave-uzb1/
                      mpl1338
                      ich habe die USB weitergabe nach der von dir geposteten Anleitung vor nem Jahr eingerichtet. Ohne dies ging Garnichts
                      G 1 Antwort Letzte Antwort
                      • M mpl1338
                        guergen
                        @mpl1338 Und das heisst jetzt?
                        Geht das nicht mehr?
                        • G guergen
                          Diamand2k22
                          ich hab das Problem, dass die Rechte bei dem Sonoff Zigbee Stick nicht passen.
                          Wie kann ich dem Stick die nötigen Rechte verpassen?
                          Bei mir sieht das ganze so aus:
                          proxmox@zigbee2mqtt:/opt/zigbee2mqtt$ ls -la /dev/serial/by-id/
                          total 0
                          drwxr-xr-x 2 root root 60 Feb 21 18:54 .
                          drwxr-xr-x 3 root root 60 Feb 21 18:54 ..
                          ---------- 1 root root  0 Feb 21 18:54 usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                          aktuell bekomme ich beim start von zigbee den Fehler:
                          Starting Zigbee2MQTT without watchdog.
                          [2025-02-21 19:03:02] error:    z2m: Error while starting zigbee-herdsman
                          [2025-02-21 19:03:02] error:    z2m: Failed to start zigbee-herdsman
                          [2025-02-21 19:03:02] error:    z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
                          [2025-02-21 19:03:02] error:    z2m: Exiting...
                          [2025-02-21 19:03:02] error:    z2m: Error: Error: Inappropriate ioctl for device setting custom baud rate of 115200
                           ELIFECYCLE  Command failed with exit code 1.
