  4. iobroker startet nach Stromausfall nicht mehr
    5.9k
25 Beiträge 5 Kommentatoren 2.7k Aufrufe 4 Beobachtet
  • A avunculo
    Habe jetzt den Beitrag https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1616096619995 durchgeführt. Leider keine Besserung. Kann nach wie vor mein iobroker via web nicht öffnen.
    @avunculo
    iobroker status
    iobroker stop
    iobroker fix
    iobroker start
    sagt?
      @avunculo
      iobroker status
      iobroker stop
      iobroker fix
      iobroker start
      sagt?
      avunculo
      iobroker status
      Uncaught Rejection: TypeError: Cannot read properties of undefined (reading 'warning')
          at ObjectsInMemoryServer.initBackupDir (/opt/iobroker/node_modules/@iobroker/db-base/lib/inMemFileDB.js:187:22)
          at new InMemoryFileDB (/opt/iobroker/node_modules/@iobroker/db-base/lib/inMemFileDB.js:83:18)
          at new ObjectsInMemoryFileDB (/opt/iobroker/node_modules/@iobroker/db-objects-file/lib/objects/objectsInMemFileDB.js:34:9)
          at new ObjectsInMemoryJsonlDB (/opt/iobroker/node_modules/@iobroker/db-objects-jsonl/lib/objects/objectsInMemJsonlDB.js:58:9)
          at new ObjectsInMemoryServer (/opt/iobroker/node_modules/@iobroker/db-objects-jsonl/lib/objects/objectsInMemServerRedis.js:57:9)
          at new ObjectsInMemoryServerClass (/opt/iobroker/node_modules/@iobroker/db-objects-jsonl/lib/objects/objectsInMemServerClass.js:34:30)
          at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3123:27)
      iobroker stop
      pi@raspberrypi:/opt/iobroker/iobroker-data/backup-objects $ iobroker fix
      library: loaded
      Library version=2022-02-10
          Welcome to the ioBroker installation fixer!
          Script version: 2022-02-13
          You might need to enter your password a couple of times.
          Installing prerequisites (1/3)
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Get:2 http://archive.raspberrypi.org/debian bullseye InRelease [23.7 kB]
      Hit:3 https://repos.influxdata.com/debian bullseye InRelease
      Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
      Get:5 https://archive.raspbian.org/raspbian buster InRelease [15.0 kB]
      Get:6 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [279 kB]
      Fetched 317 kB in 1s (213 kB/s)
      Reading package lists... Done
      Installed gcc-c++
      Installed python-dev
          Checking ioBroker user and directory permissions (2/3)
          Checking autostart (3/3)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      pi@raspberrypi:/opt/iobroker/iobroker-data/backup-objects $ iobroker start
      Nach wie vor kein Zugriff via ip auf meinem iobroker
      • A avunculo
        iobroker status
        iobroker stop
        library: loaded
        Installed gcc-c++
        Autostart enabled!
        @avunculo
        Auch du fährst da einen Mix aus zwei Releases in den sources.lists
        Das gibt früher oder später Kopfschmerzen. Eher früher.
        Ist hier auch ein Problem:
        https://forum.iobroker.net/topic/54420/iobroker-mit-120-auslastung-und-no-connection-to-database/3
        Räum die Quellen auf.
          @avunculo
          avunculo
          nano /etc/apt/sources.list.d/influxdb.list
            GNU nano 5.4                               /etc/apt/sources.list.d/influxdb.list
          deb https://repos.influxdata.com/debian bullseye stable
          Was muss ich mit der Quelle machen?
          • A avunculo
            @avunculo
            Nee, die influxdb.list ist bei dir richtig.
            Du hast einen falschen Eintrag hier:
            Ich weiß aber so aus dem Kopf nicht, in welcher der Dateien in
            das drin steht.
            Kann auch aus der Datei
            kommen.
              @avunculo
              das drin steht.
              kommen.
              avunculo
              deb http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi
              # Uncomment line below then 'apt-get update' to enable 'apt-get source'
              #deb-src http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi
              deb https://archive.raspbian.org/raspbian buster main contrib non-free
              deb-src https://archive.raspbian.org/raspbian buster main contrib non-free
              Ich habe
              gelöscht. Und dann nochmal iobroker status
              iobroker stop
              iobroker fix
              iobroker start
              durchgeführt, leider nach wie vor kein Zugriff:/
              • A avunculo
                Ich habe
                iobroker stop
                iobroker fix
                iobroker start
                @avunculo
                Ich hätte ja einfach buster durch bullseye ersetzt.
                So bekommst du keine Updates mehr aus der Quelle und kannst nicht auf Pakete von dort zugreifen.
                Und bitte nix nacherzählen, komplette Ein- und Ausgaben aus der Konsole posten.
                  @avunculo
                  avunculo
                  schrieb am zuletzt editiert von avunculo
                  pi@raspberrypi:~ $ iobroker stop
                  pi@raspberrypi:~ $ iobroker fix
                  library: loaded
                  Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                  Get:5 https://archive.raspbian.org/raspbian bullseye InRelease [15.0 kB]
                  Get:6 https://archive.raspbian.org/raspbian bullseye/contrib Sources [81.9 kB]
                  Get:7 https://archive.raspbian.org/raspbian bullseye/main Sources [12.2 MB]
                  Get:8 https://archive.raspbian.org/raspbian bullseye/non-free Sources [140 kB]
                  Get:9 https://archive.raspbian.org/raspbian bullseye/main armhf Packages [13.2 MB]
                  Get:10 https://archive.raspbian.org/raspbian bullseye/contrib armhf Packages [60.2 kB]
                  Get:11 https://archive.raspbian.org/raspbian bullseye/non-free armhf Packages [106 kB]
                  Fetched 25.9 MB in 11s (2,460 kB/s)
                  Installed gcc-c++
                  Autostart enabled!
                  pi@raspberrypi:~ $ iobroker start
                  pi@raspberrypi:~ $ iobroker status
                  • A avunculo
                    library: loaded
                    Installed gcc-c++
                    Autostart enabled!
                    @avunculo
                    Versuch mal
                    iobroker stop
                    cd /opt/iobroker
                    sudo -H -u iobroker npm install iobroker.js-controller
                      @avunculo
                      Versuch mal
                      iobroker stop
                      cd /opt/iobroker
                      avunculo
                      @thomas-braun said in iobroker startet nach Stromausfall nicht mehr:
                      VIELEN DANK! :-) :-) Zugriff auf meinen iobroker habe ich schonmal!!!
