  4. Influx History Event List
    2.3k
    4.2k
16 Beiträge 3 Kommentatoren 1.6k Aufrufe 3 Beobachtet
  • O oFbEQnpoLKKl6mbY5e13
    @apollon77
    2022-04-04 12:56:04.216  - debug: influxdb.0 (24307) Incoming message getHistory from system.adapter.socketio.0
    2022-04-04 12:56:04.217  - debug: influxdb.0 (24307) SELECT * from "alias.0.Haus.Obergeschoss.Bad.Klima.Temperature" WHERE  time < '2022-04-04T12:19:24.208Z' ORDER BY time DESC LIMIT 6;SELECT value from "alias.0.Haus.Obergeschoss.Bad.Klima.Temperature" WHERE time >= '2022-04-04T12:19:24.208Z' LIMIT 1
    2022-04-04 12:56:04.217  - debug: influxdb.0 (24307) Query to execute: SELECT * from "alias.0.Haus.Obergeschoss.Bad.Klima.Temperature" WHERE  time < '2022-04-04T12:19:24.208Z' ORDER BY time DESC LIMIT 6;SELECT value from "alias.0.Haus.Obergeschoss.Bad.Klima.Temperature" WHERE time >= '2022-04-04T12:19:24.208Z' LIMIT 1
    2022-04-04 12:56:04.239  - debug: influxdb.0 (24307) ROWS:[[{"time":"2022-04-04T10:53:04.991Z","ack":true,"from":"system.adapter.influxdb.0","q":0,"value":19.4},{"time":"2022-04-04T10:50:31.282Z","ack":true,"from":"system.adapter.netatmo.0","q":0,"value":19.4},{"time":"2022-04-04T10:30:31.186Z","ack":true,"from":"system.adapter.netatmo.0","q":0,"value":19},{"time":"2022-04-04T10:10:31.338Z","ack":true,"from":"system.adapter.netatmo.0","q":0,"value":19},{"time":"2022-04-04T09:50:31.635Z","ack":true,"from":"system.adapter.netatmo.0","q":0,"value":19.1},{"time":"2022-04-04T09:30:31.365Z","ack":true,"from":"system.adapter.netatmo.0","q":0,"value":19.1}],[]]
    2022-04-04 12:56:04.241  - debug: influxdb.0 (24307) Send: 1 of: 6 in: 24ms
    2022-04-04 12:56:05.503  - debug: influxdb.0 (24307) Incoming message getHistory from system.adapter.socketio.0
    2022-04-04 12:56:05.504  - debug: influxdb.0 (24307) SELECT * from "alias.0.Haus.Obergeschoss.Bad.Klima.Temperature" WHERE  time < '2022-04-04T12:19:25.502Z' ORDER BY time DESC LIMIT 6;SELECT value from "alias.0.Haus.Obergeschoss.Bad.Klima.Temperature" WHERE time >= '2022-04-04T12:19:25.502Z' LIMIT 1
    2022-04-04 12:56:05.504  - debug: influxdb.0 (24307) Query to execute: SELECT * from "alias.0.Haus.Obergeschoss.Bad.Klima.Temperature" WHERE  time < '2022-04-04T12:19:25.502Z' ORDER BY time DESC LIMIT 6;SELECT value from "alias.0.Haus.Obergeschoss.Bad.Klima.Temperature" WHERE time >= '2022-04-04T12:19:25.502Z' LIMIT 1
    2022-04-04 12:56:05.516  - debug: influxdb.0 (24307) ROWS:[[{"time":"2022-04-04T10:53:04.991Z","ack":true,"from":"system.adapter.influxdb.0","q":0,"value":19.4},{"time":"2022-04-04T10:50:31.282Z","ack":true,"from":"system.adapter.netatmo.0","q":0,"value":19.4},{"time":"2022-04-04T10:30:31.186Z","ack":true,"from":"system.adapter.netatmo.0","q":0,"value":19},{"time":"2022-04-04T10:10:31.338Z","ack":true,"from":"system.adapter.netatmo.0","q":0,"value":19},{"time":"2022-04-04T09:50:31.635Z","ack":true,"from":"system.adapter.netatmo.0","q":0,"value":19.1},{"time":"2022-04-04T09:30:31.365Z","ack":true,"from":"system.adapter.netatmo.0","q":0,"value":19.1}],[]]
    2022-04-04 12:56:05.516  - debug: influxdb.0 (24307) Send: 1 of: 6 in: 12ms
    @ofbeqnpolkkl6mby5e13 Tja ... irrgendwas sortiert da alles ausser eine response aus ... aber man sieht ie echte query nicht ... blöd. bin eh gerade an influxdb dran ... schaue mal mit rein ... ggf gibts mehr log :-)
    O 1 Antwort Letzte Antwort
    • apollon77A apollon77
      O Offline
      O Offline
      @apollon77
      Danke!
      Es ist gar nicht so eine einfache Sache, aus der Menge an Logs, die da reinrauschen, wenn man Influxdb auf Debug stellt, die relevanten Einträge zu finden, vor allem, wenn man keine Ahnung hat, welche das sein könnten...
      • S Sirfauntleroy
        Hallo Zusammen,
        nach der Umstellung des Influx-Adapters auf Version v2.6.3 habe ich ein kleines Problem mit dem Widget "History_Event-List" (v1.0.0)
        Es wird nur noch der letzte Wert angezeigt, nicht mehr die Liste der letzten Werte.
        Hat noch jemand das gleiche Problem, oder übersehe ich nur etwas in den Einstellungen?
        An den Einstellungen selbst habe ich nichts geändert, vor dem Upgrade der Influx-Instanz hat es auch super funktioniert.. ;)
        Danke schonmal! :)
        O Offline
        O Offline
        @sirfauntleroy
        Stell mal "Nicht älter als" von None auf z. B. 24 Stunden.
          @sirfauntleroy
          Sirfauntleroy
          mmh.
          Da die Werte, welche ich in dem Fall anzeigen möchte nur einmal am Tag gespeichert werden, wird mir dabei auch nur der letzte Wert angezeigt.
          Bei Werten, (z.B. Momentanleistungen) werden dann die Werte der letzten 24h bzw. des gewählten Intervalls gelistet.
          Offensichtlich liegt hier der Fehler. Auch bei der Auswahl "none" werden nur die letzten 24h abgerufen!
          • apollon77A Offline
            Versuch mal bitte influxdb adapter vom GitHub... ist es da besser? Falls nicht bitte nochmal neues InfluxDB Debug Log
              O Offline
              O Offline
              @apollon77
              Sieht gut aus!
                @apollon77
                Sieht gut aus!
                @ofbeqnpolkkl6mby5e13 Hatte ich gedacht ... Werkle noch an den drei History Adaptern bissl rum, dann release ich es
                  O Offline
                  O Offline
                  @apollon77
                  Vielen Dank!
                  Wie sieht es hiermit aus?
                  "Und müsste es nicht "Werteinstanz" und nicht "Wetterinstanz" heißen...?"
                    @apollon77
                    Vielen Dank!
                    @ofbeqnpolkkl6mby5e13 Bitte Issue beim vis-history anlegen ... scheint ja nur übersetzungsfehler zu sein, aber ja lann man da fixen
                      O Offline
                      O Offline
                      @apollon77
                      Erledigt.
                      https://github.com/ioBroker/ioBroker.vis-history/issues/11
