  4. Logitech Harmony Adapter
    5.7k
118 Beiträge 22 Kommentatoren 34.2k Aufrufe
  • P Offline
    Pman
    #107
    Stand vorher schon was im LOG? "lost client" oder ähnliches?
    • F Offline
      Findus
      #108
      Am Vortag habe ich folgende Eintraege gefunden …
      2017-04-13 05:45:13.098 - ^[[32minfo^[[39m: harmony.0 client ended: Harmony_Hub
      2017-04-13 05:45:14.169 - ^[[32minfo^[[39m: harmony.0 keep alive failed: Error: Timed out after 5000 ms
      2017-04-13 05:45:24.204 - ^[[33mwarn^[[39m: harmony.0 could not connect to Harmony Hub: Error: Timed out after 5000 ms
      2017-04-13 05:45:42.002 - ^[[32minfo^[[39m: harmony.0 discovered Harmony Hub
      2017-04-13 05:45:42.071 - ^[[32minfo^[[39m: harmony.0 connecting to Harmony Hub
      2017-04-13 05:45:44.448 - ^[[32minfo^[[39m: harmony.0 connected to Harmony Hub
      2017-04-13 05:45:45.581 - ^[[32minfo^[[39m: harmony.0 synced hub config
      dies ist mehrmals aufgetreten
      2017-04-13 06:16:11.146 - ^[[32minfo^[[39m: harmony.0 keep alive failed: Error: Timed out after 5000 ms
      2017-04-13 06:16:11.148 - ^[[32minfo^[[39m: harmony.0 client ended: Harmony_Hub
      2017-04-13 06:16:11.423 - ^[[32minfo^[[39m: harmony.0 keep alive failed: Error: Timed out after 5000 ms
      2017-04-13 06:16:13.789 - ^[[33mwarn^[[39m: harmony.0 lost Harmony Hub
      2017-04-13 06:16:21.158 - ^[[33mwarn^[[39m: harmony.0 could not connect to Harmony Hub: Error: Timed out after 5000 ms
      2017-04-13 06:16:23.656 - ^[[32minfo^[[39m: harmony.0 discovered Harmony Hub
      2017-04-13 06:16:23.722 - ^[[32minfo^[[39m: harmony.0 connecting to Harmony Hub
      2017-04-13 06:16:26.101 - ^[[32minfo^[[39m: harmony.0 connected to Harmony Hub
      2017-04-13 06:16:27.197 - ^[[32minfo^[[39m: harmony.0 synced hub config
      danach aber war Ruhe... an diesem Tag mit Eintraegen
      erst am naechsten Tag dann sobald ich den HUB in den Airplaymode schalten wollte
      2017-04-14 09:58:28.666 - ^[[32minfo^[[39m: javascript.0 script.js.common.Activities: switch Harmony to Airplay mode
      2017-04-14 09:58:28.684 - ^[[33mwarn^[[39m: harmony.0 error changing activity, client offline
      2017-04-14 09:58:29.153 - ^[[32minfo^[[39m: javascript.0 script.js.common.Activities: Airplay
      Gruss
      Findus
      • SchubiS Offline
        SchubiS Offline
        Schubi
        #109
        Ich hatte früher das Problem, dass die WLAN Verbindung vom Hub abgebrochen ist (rote LED am Hub).
        Das wäre eine Erklärung für den LOG-Eintrag.
        Wenn die LED rot ist, funktioniert aber die "normale" Ferbedienung - man merkt also nix davon.
        Seit ich einen neuen WLAN-AP habe, ist Ruhe.
        Überprüfe vielleicht einmal ob es bei Problemen an der Verbindung liegt.
        LG Schubi
        / Synology DS716+ / Logitech Harmony Ultimate / Netatmo / ESP8266 / RPi 3 / 4* Möller Easy 820 / Lupusec XT2 Plus /
        • P Offline
          Pman
          #110
          Diese LOG Einträge sehen aus wie normale Verbindungsprobleme, die der Hub leider oft hat. WLAN-Kanal wechseln, Position des Hub oder Routers können helfen. Warum es dann genau im Moment der Nutzung passiert ist aber interessant, anscheinend wurde dieser Disconnect nicht vorzeitig erkannt.
          • F Offline
            Findus
            #111
            Vielen Dank fuer die Hinweise … benutzte Fritzbox 7390 Wlan und der Hub steht 1m davon entfernt...
            leider hat der Adapter heute Morgen wieder die falsche Aktivitaet. Hub defindet sich eindeutig in der "Power_OFF" Aktivitaet aber die Objekte zeigen folgenden Zustand..... "Fernsehen"
            Harmony_Hub device Harmony_Hub device Amazon_Fire_TV-Stick channel Amazon_Fire_TV-Stick channel media.device
            Microsoft-Media_Player channel Microsoft-Media_Player channel media.device
            Samsung_TV channel Samsung_TV channel media.device
            Vu+_UNO_4K channel Vu+_UNO_4K channel media.device
            Yamaha_AV-Empfänger channel Yamaha_AV-Empfänger channel media.device
            activities channel activities channel media.activities
            Airplay state activity:Airplay state switch 0
            Fernsehen state activity:Fernsehen state switch 2
            Fire_TV state activity:Fire_TV state switch 0
            Power_Off state activity:Power_Off state switch 0
            currentActivity state activity:currentActivity state indicator.activity Fernsehen
            currentStatus state activity:currentStatus state indicator.status 2
            hubBlocked state Harmony_Hub:hubBlocked state indicator.hubBlocked false
            hubConnected state Harmony_Hub:hubConnected state indicator.hubConnected true
            • P Offline
              Pman
              #112
              In diesem Moment wären dann die letzten LOG Einträge sehr interessant.
              • Holger76H Offline
                Holger76H Offline
                Holger76
                #113
                Ich habe momentan auch wieder massive Probleme mit dem Harmony Adapter, leider zeigt mein LOG gerade nichts weiter an, als dass die Activity nicht ausgeführt werden konnte, da der Adapter offline ist.
                Ich habe momentan die neueste 0.7 Version. Ich weiß nicht wann das letzte Update war, ggf kürzlich und es hängt damit zusammen… vorher ging jedenfalls alles wochenlang bestens.
                Es liegt jedenfall nicht an Verbindungsproblemen des Hubs, die Fernbedienung z.b. schaltet alles tadellos.
                ****Achso, fast vergessen: -Ich habe in meiner VIS ein Symbol, ob Harmony verbunden ist oder nicht- das zeigt dann nicht verbunden an (hubConnected=false)
                bei den Instanzen ist Harmony hingegen GRÜN, also Verbunden mit Host & Lebenszeichen. Das sieht für mich nach einem Fehler aus.****
                NUC12i7 -> Proxmox VM [ioBroker.Pro]+[InfluxDB/Grafana]+[AdGuard]+[ OpenCCU ]+[Conbee3] +[Graylog]+[Octopi]+[OpenClaw]
                NUC6CAYH (16GB) [Proxmox Backup Server]+[OMV]
                  andyb
                  #114
                  Bin heute per Backup/Restore von Rasp zu OrangePi umgezogen.
                  Neuer Hostname und neue IP.
                  Jetzt macht mir der Harmony Adapter Probleme.
                  Ich hab ihn schon gelöscht und neu installiert, leider keine Veränderung.
                  Funktionieren tut an sich alles.
                  Bei Aktion "Fernseher ausschalten" läuft alles problemlos.
                  Bei Aktion "Fernseher einschalten" läuft eigentlich auch, Aktion wird ordnungsgemäß ausgeführt, allerdings im Log:
                  host.orangepiplus2e	2017-04-29 21:51:55.560	error	instance system.adapter.harmony.0 terminated with code 0 (OK)
                  harmony.0	2017-04-29 21:51:55.455	info	terminating
                  harmony.0	2017-04-29 21:51:55.454	error	Error: Q can't apply finally callback at Promise.fin.Promise.finally (/opt/iobroker/node_modules/q/q.js:1775:15) at switchActivity (/opt/iobroker/node_modules/iobroker.harmony/harmony.js:137:9
                  harmony.0	2017-04-29 21:51:55.452	error	uncaught exception: Q can't apply finally callback
                  Fängt jemand damit was an?
                  OT: Wenn ich einen Adapter lösche, sind dann alle Daten weg oder bleibt irgendwo eine Datei mit den Einstellungen zurück welche ich manuell löschen müsste?
                    Karim
                    #115
                    Hallo alle zusammen,
                    Ich bin noch ganz neu in der Materie hier und bin schon echt stolz auf mich, dass ich es geschafft habe den Raspi auf zu setzten und ioBroker sowie die Adapter zu installieren.
                    In diesem Zuge auch schon mal vielen Dank für die ganze Arbeit, die ihr euch hier macht! Super!
                    Der Adapter funktioniert wirklich super, leider habe ich Probleme mit activitys in Szenen und ich weiß einfach nicht was ich falsch mache, oder ob ich einfach irgendwas vergessen habe.
                    Ich hoffe ich bin hier auch im richtigen Bereich. Das was ich nicht verstehe ist, dass es manchmal funktioniert und manchmal eben nicht.
                    Wenn etwas Zeit vergeht, ist die Wahrscheinlichkeit größer, dass es klappt. Wenn ich die activity aber einfach "nach bastel" und es als einzelne Befehle schicke, klappt alles prima.
                    Das hier spuckt der Log aus.
                    host.raspberrypi	2017-05-03 02:41:06.981	info	Restart adapter system.adapter.harmony.0 because enabled
                    host.raspberrypi	2017-05-03 02:41:06.981	error	instance system.adapter.harmony.0 terminated with code 0 (OK)
                    harmony.0	2017-05-03 02:41:06.960	info	terminating
                    harmony.0	2017-05-03 02:41:06.937	warn	change activities, not currentActivity
                    harmony.0	2017-05-03 02:41:06.923	info	terminating
                    harmony.0	2017-05-03 02:41:06.920	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3030:38)
                    harmony.0	2017-05-03 02:41:06.920	error	at Adapter.emit (events.js:172:7)
                    harmony.0	2017-05-03 02:41:06.920	error	at emitTwo (events.js:87:13)
                    harmony.0	2017-05-03 02:41:06.920	error	at Adapter. (/opt/iobroker/node_modules/iobroker.harmony/harmony.js:34:15)
                    harmony.0	2017-05-03 02:41:06.920	error	at Object.semaphore.take (/opt/iobroker/node_modules/iobroker.harmony/node_modules/semaphore/lib/semaphore.js:45:9)
                    harmony.0	2017-05-03 02:41:06.920	error	at Object.item.task (/opt/iobroker/node_modules/iobroker.harmony/node_modules/semaphore/lib/semaphore.js:34:29)
                    harmony.0	2017-05-03 02:41:06.920	error	at /opt/iobroker/node_modules/iobroker.harmony/harmony.js:36:9
                    harmony.0	2017-05-03 02:41:06.920	error	at processStateChange (/opt/iobroker/node_modules/iobroker.harmony/harmony.js:67:21)
                    harmony.0	2017-05-03 02:41:06.920	error	at switchActivity (/opt/iobroker/node_modules/iobroker.harmony/harmony.js:137:92)
                    harmony.0	2017-05-03 02:41:06.920	error	at Promise.fin.Promise.finally (/opt/iobroker/node_modules/iobroker.harmony/node_modules/harmonyhubjs-client/node_modules/q/q.js:1775:15)
                    harmony.0	2017-05-03 02:41:06.920	error	Error: Q can't apply finally callback
                    harmony.0	2017-05-03 02:41:06.907	error	uncaught exception: Q can't apply finally callback
                    harmony.0	2017-05-03 02:40:39.602	warn	change activities, not currentActivity
                    harmony.0	2017-05-03 02:40:39.032	info	hub busy, stateChange delayed: harmony.0.Karim's_Harmony_Hub.activities.currentActivity=PowerOff
                    harmony.0	2017-05-03 02:40:25.498	info	synced hub config
                    harmony.0	2017-05-03 02:40:24.418	info	connected to Karim's Harmony Hub
                    harmony.0	2017-05-03 02:40:22.035	info	connecting to Karim's Harmony Hub
                    harmony.0	2017-05-03 02:40:21.919	info	discovered Karim's Harmony Hub
                    harmony.0	2017-05-03 02:40:20.660	info	searching for Harmony Hubs...
                    harmony.0	2017-05-03 02:40:20.615	info	starting. Version 0.7.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v4.8.2
                    host.raspberrypi	2017-05-03 02:40:18.153	info	instance system.adapter.harmony.0 started with pid 10372
                    host.raspberrypi	2017-05-03 02:39:48.132	info	Restart adapter system.adapter.harmony.0 because enabled
                    host.raspberrypi	2017-05-03 02:39:48.131	error	instance system.adapter.harmony.0 terminated with code 0 (OK)
                    harmony.0	2017-05-03 02:39:48.106	info	terminating
                    harmony.0	2017-05-03 02:39:48.078	warn	change activities, not currentActivity
                    harmony.0	2017-05-03 02:39:48.055	info	terminating
                    harmony.0	2017-05-03 02:39:48.052	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3030:38)
                    harmony.0	2017-05-03 02:39:48.052	error	at Adapter.emit (events.js:172:7)
                    harmony.0	2017-05-03 02:39:48.052	error	at emitTwo (events.js:87:13)
                    harmony.0	2017-05-03 02:39:48.052	error	at Adapter. (/opt/iobroker/node_modules/iobroker.harmony/harmony.js:34:15)
                    harmony.0	2017-05-03 02:39:48.052	error	at Object.semaphore.take (/opt/iobroker/node_modules/iobroker.harmony/node_modules/semaphore/lib/semaphore.js:45:9)
                    harmony.0	2017-05-03 02:39:48.052	error	at Object.item.task (/opt/iobroker/node_modules/iobroker.harmony/node_modules/semaphore/lib/semaphore.js:34:29)
                    harmony.0	2017-05-03 02:39:48.052	error	at /opt/iobroker/node_modules/iobroker.harmony/harmony.js:36:9
                    harmony.0	2017-05-03 02:39:48.052	error	at processStateChange (/opt/iobroker/node_modules/iobroker.harmony/harmony.js:67:21)
                    harmony.0	2017-05-03 02:39:48.052	error	at switchActivity (/opt/iobroker/node_modules/iobroker.harmony/harmony.js:137:92)
                    harmony.0	2017-05-03 02:39:48.052	error	at Promise.fin.Promise.finally (/opt/iobroker/node_modules/iobroker.harmony/node_modules/harmonyhubjs-client/node_modules/q/q.js:1775:15)
                    harmony.0	2017-05-03 02:39:48.052	error	Error: Q can't apply finally callback
                    harmony.0	2017-05-03 02:39:48.040	error	uncaught exception: Q can't apply finally callback
                    harmony.0	2017-05-03 02:39:26.314	warn	change activities, not currentActivity
                    harmony.0	2017-05-03 02:39:25.585	info	hub busy, stateChange delayed: harmony.0.Karim's_Harmony_Hub.activities.currentActivity=PowerOff
                    Lieben Gruß, Karim.
                    • P Offline
                      Pman
                      #116
                      Über die neuen Probleme bitte hier weiter diskutieren:
                      http://forum.iobroker.net/viewtopic.php?f=22&t=6228
                        Karim
                        #117
                        Ah okay, danke für den Link. Das beschreibt ja genau mein Problem!
                        Lieben Gruß, Karim.
                          #118
                          bin gerade beim Stöbern über https://www.myharmony.com/de-de/harmony-api gestolpert:
                          Logitech arbeitet mit einer ausgesuchten Liste von Entwicklern an der Implementierung der Harmony-API. Wenn Sie teilnehmen möchten, geben Sie uns bekannt:
                          Arbeitet da jemand dran?
