  4. [gelöst] Warn mit Javascript 5.5.0
    6.0k
47 Beiträge 6 Kommentatoren 2.1k Aufrufe 6 Beobachtet
  • liv-in-skyL liv-in-sky
    @apollon77
    da kommt was
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated fsevents@1.2.13: fsevents 1 will break on node v14+ and could be using insecure binaries. Upgrade to fsevents 2.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/@iobroker/js-controller-cli/node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/mocha/node_modules/chokidar/node_modules/fsevents):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.2.7 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/fsevents/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/socketwatcher/package.json'
    npm WARN http-cookie-agent@1.0.5 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.
    npm ERR! code ENOTSUP
    npm ERR! notsup Unsupported engine for dns@0.2.2: wanted: {"node":">= 0.10.0 < 0.11.0"} (current: {"node":"14.19.0","npm":"6.14.16"})
    npm ERR! notsup Not compatible with your version of node/npm: dns@0.2.2
    npm ERR! notsup Required: {"node":">= 0.10.0 < 0.11.0"}
    npm ERR! notsup Actual:   {"npm":"6.14.16","node":"14.19.0"}
    npm ERR!     /home/iobroker/.npm/_logs/2022-03-24T10_57_12_439Z-debug.log
    weiß nicht, ob da was drin ist
    @liv-in-sky sagte in [gelöst] Warn mit Javascript 5.5.0:
    dns
    Schau mal wo das hängt:
    cd /opt/iobroker
    npm ls dns
      dns
      cd /opt/iobroker
      npm ls dns
      liv-in-skyL Offline
      liv-in-skyL Offline
      weiß gar nicht ob ich das brauche
        dns
        cd /opt/iobroker
        npm ls dns
        liv-in-skyL Offline
        liv-in-skyL Offline
        @apollon77
        hab nur das gefunden - redis ?
        https://www.npmjs.com/package/dns
          weiß garnicht, ob ich das brauche
          Ich auch nicht.
          Aber ich würde an deiner Stelle auch mal durch die zusätzlich installierten Module schauen. Die Dinger sorgen dafür, dass die Dependency Hell immer unübersichtlicher wird.
            Ich auch nicht.
            liv-in-skyL Offline
            liv-in-skyL Offline
            gibt es einen befehl, damit ich rausfinde, ob eines meiner zusatzmodule eine dependency hat ?
            Thomas BraunT apollon77A 2 Antworten Letzte Antwort
              @liv-in-sky
              Interessant.
              Was läuft denn bei dir auf
              http://localhost:8053
              Ich an deiner Stelle hätte jedenfalls ungern einen mir unbekannten DNS-Server in meinem Netz hängen...
              Der dann auch seit Jahren nicht mehr gepflegt wird.
              https://github.com/hbouvier/dns
                @liv-in-sky
                Interessant.
                liv-in-skyL Offline
                liv-in-skyL Offline
                @thomas-braun sagte in [gelöst] Warn mit Javascript 5.5.0:
                nichts
                sudo lsof -i -P -n | grep LISTEN
                ergibt keinen treffer !
                dieses 53 erinnert mich an pihole
                  @liv-in-sky Naja du gibst diese Deps im Javascript Adapter direkt an??
                  • apollon77A apollon77
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    @apollon77 aber diese greifen wiederum auf andere dep zu - ich habe jetzt mal den großteil der zusätzlichen M. auf dieser npm seite nach depen. untersucht - da ist keine
                    es könnte schon mal sein, dass ich irgendwann mal was installiert hatte, was das dns modul gebraucht hat und dann beim deinstallieren, dass dns nicht deinstalliert hat
                    redis braucht das nicht ????
                    kann ich das irgendwie herausfinden, ob dieses dns module irgend ein anderes module braucht? auf meiner installation
                    ps: in node red ist auch nix angegeben
                      @liv-in-sky mach mal das "npm list dns" nochmal im Verzeichnis /opt/iobroekr/node_modules/iobroker.javascript/ Was kommt da als Ausgabe?
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        @apollon77 sagte in [gelöst] Warn mit Javascript 5.5.0:
                          @liv-in-sky dann komtmdas aber auch da von keinem anderen paket. Kann mal (im Verzeichnis /opt/iobroekr/node_modules/iobroker.javascript/ !!!) ein "npm uninstall dns" machen ... dann javascript restarten ... wenns von nem angegebene Paket kam dann wäre es nach dem start wieder da :-) So kannste kontrollieren
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            @apollon77
                            @Thomas-Braun
                            habe es "rausgeschmissen" - jetzt ist 5.5.2 installiert
                            • habe alte zusätzliche npm's deinstalliert
                            • dns.0.2.2 ist nicht mehr gekommen
                            • keine fehler eim start im log
                            vielen dank an euch beide !
                            @apollon77
                            noch eine frage: meine scripte werden nach /opt/iobroker/scripte-backup gespiegelt - das müßte doch noch laufen und in ordnung sein ?
                              @apollon77
                              @Thomas-Braun
                              @apollon77
                              Das sollte erlaubt sein. Schau doch mal ins Log. Wenn nicht dann würde er beim JavaScritpt adapter start zwei zeilen "error" loggen
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                @apollon77 ne - ist mir nix aufgefallen
                                nochmals danke
