  4. WIEGAND TCP/IP Adapter (Alias UHPPOTE)
145 Beiträge 11 Kommentatoren 28.2k Aufrufe 11 Beobachtet
  • R RandyAndy
    @kbrausew
    es kam wieder kein Device gefunden.
    Im LOG sehe ich auch dass es eine Verbindung gibt. Hier ein Ausschnitt aus dem LOG
    wiegand-tcpip.0
    	2022-03-20 22:29:08.396	debug	received 192.168.178.48:60000 17 90 00 00 71 7f 38 19 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    wiegand-tcpip.0
    	2022-03-20 22:29:08.204	debug	sent 192.168.178.255:60000 17 90 00 00 71 7f 38 19 c0 a8 b2 ff 61 ea 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    wiegand-tcpip.0
    	2022-03-20 22:29:08.200	debug	received 192.168.178.48:60000 17 8e 00 00 71 7f 38 19 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    wiegand-tcpip.0
    	2022-03-20 22:29:08.138	debug	sent 192.168.178.255:60000 17 8e 00 00 71 7f 38 19 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    wiegand-tcpip.0
    	2022-03-20 22:29:08.136	info	Connect to controller: xxxxxxxxx
    wiegand-tcpip.0
    	2022-03-20 22:29:08.130	debug	received 192.168.178.48:60000 17 20 00 00 71 7f 38 19 73 1f 00 00 01 01 01 01 04 69 5a aa 20 22 03 20 22 14 37 01 01 01 01 01 00 00 00 00 00 22 29 07 00 00 00 00 00 00 00 00 00 00 00 22 03 20 00 00 00 00 00 00 00 00 00 00
    wiegand-tcpip.0
    	2022-03-20 22:29:08.128	debug	sent 192.168.178.255:60000 17 20 00 00 71 7f 38 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    wiegand-tcpip.0
    	2022-03-20 22:29:06.307	info	Create controller xxxxxxxxx for Model 4-Door Objects
    wiegand-tcpip.0
    	2022-03-20 22:29:06.253	info	starting. Version 0.4.6 (non-npm: kBrausew/ioBroker.wiegand-tcpip#v0.4.6) in /opt/iobroker/node_modules/iobroker.wiegand-tcpip, node: v14.19.0, js-controller: 4.0.21
    Scheint immer an der Adresse 192.168.178.48 und 192.168.178.255 hängen zu bleiben. 192.168.178.255 wird meines Wissen nach keinem physikalischen Gerät zugewiesen. 192.168.178.48 ist mein go-e charger, der ist aber momentan gar nicht angeschlossen.
    Andreas
    kBrausewK Offline
    kBrausewK Offline
    kBrausew
    @randyandy
    Alles in Ordnung
    ioBroker sendet Broadcast (192.168.178.255) und der Kontroller (192.168.178.48) antwortet.
    Schau mal im Web-GUI nach, schätze du hast hier "48" anstatt "23" stehen! ... in der Fritte sollte das auch erkennbar sein?!?
    Adapter funktioniert somit.
    Jetzt noch Card-Swipe...
    Das er kein Device findet im IP-Setup-Tool schau ich mir nochmal im Code an (der Antest gerade eben brachte aber auch kein Ergebnis bei mir) Spiel aber keine Rolle da man die IP sowieso über die originalen Tools einstellen sollte. Glaube deaktivier dieses Set-IP-Tool wieder wenn's eh nicht läuft.
    Pi 4/8GB + SSD + Docker \ DebMatic HM-IP + HM-RF \ ioBroker
    HikVision InterCom \ tedee SmartLook
    Wiegand - TCP/IP Door Access Controller \ MF-549 Fingerprint/Code/RFID \ FP100 Fingerprint/Code
    Fritz 7590 (ohne SmartHome)
    kBrausewK 1 Antwort Letzte Antwort
    • kBrausewK kBrausew
      @randyandy
      Alles in Ordnung
      kBrausewK Offline
      kBrausewK Offline
      kBrausew
      schrieb am zuletzt editiert von kBrausew
      @kbrausew sagte in WIEGAND TCP/IP Adapter (Alias UHPPOTE):
      ... "48" anstatt "23" stehen! ...
      Vergiss es, da passt was im Broadcast-Setup nicht. Das muss ich mir genau anschauen, je nach Netzwerk-Interface und Betriebssystem macht er was anderes => ???
      Solange muss die IP für Controller und ioBroker eigegeben werden
      BTW: Dein PHP-Server konsumiert ja auch die Events (Card-Swipe und der Gleichen)
      So wie ich das bis jetzt mal angeschaut habe PHP Server carbonsphere, werden nicht beide gleichzeitig auf den Controller zugreifen können. Du musst dich für einen von beiden entscheiden, leider... aber test mal lieber selber wer die Events erhält (einer / beide / keiner ??)
      siehe auch (im ioBroker Log)
      Extendend HeartBeat negative (try re-connect device): xxxxxxxx
      R 1 Antwort Letzte Antwort
        R Online
        R Online
        RandyAndy
        schrieb am zuletzt editiert von RandyAndy
        @kbrausew
        Habe nun mal die IP Adresse des Controllers eingetragen. Da scheint ja etwas zu geschehen.
        Bezüglich des gleichzeitigen Zugriffs sollte das eigentlich nicht so sein. Die php-Skripte die ich verwende werden immer angestoßen z.B. durch einen cron-job oder durch den iobroker z.B. kann ich die Zugangs-Tags und Codes per php-Skript sperren und wieder freischalten (Ist echt hilfreich in Corona-Zeiten 😀).
        Was bedeutet aber Incorrect controller-setup for non/broadcast: xxxxxxxxx.
        Ich habe mal alle Meldungen ab dem Neustart des Controller anbei zusammengestellt.
        wiegand-tcpip.0
        	2022-03-21 08:09:35.160	debug	received 192.168.178.29:60000 17 82 00 00 71 7f 38 19 04 03 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        wiegand-tcpip.0
        	2022-03-21 08:09:35.155	debug	sent 192.168.178.29:60000 17 82 00 00 71 7f 38 19 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        wiegand-tcpip.0
        	2022-03-21 08:09:35.153	debug	received 192.168.178.29:60000 17 82 00 00 71 7f 38 19 03 03 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        wiegand-tcpip.0
        	2022-03-21 08:09:35.150	debug	sent 192.168.178.29:60000 17 82 00 00 71 7f 38 19 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        wiegand-tcpip.0
        	2022-03-21 08:09:35.147	debug	received 192.168.178.29:60000 17 82 00 00 71 7f 38 19 02 03 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        wiegand-tcpip.0
        	2022-03-21 08:09:35.145	debug	sent 192.168.178.29:60000 17 82 00 00 71 7f 38 19 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        wiegand-tcpip.0
        	2022-03-21 08:09:35.141	debug	received 192.168.178.29:60000 17 82 00 00 71 7f 38 19 01 03 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        wiegand-tcpip.0
        	2022-03-21 08:09:35.138	debug	sent 192.168.178.29:60000 17 82 00 00 71 7f 38 19 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        wiegand-tcpip.0
        	2022-03-21 08:09:35.135	debug	received 192.168.178.29:60000 17 30 00 00 71 7f 38 19 20 22 03 21 08 09 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        wiegand-tcpip.0
        	2022-03-21 08:09:35.133	debug	sent 192.168.178.29:60000 17 30 00 00 71 7f 38 19 20 22 03 21 08 09 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        wiegand-tcpip.0
        	2022-03-21 08:09:35.130	info	Reset the device clock: 423133041
        wiegand-tcpip.0
        	2022-03-21 08:09:35.128	debug	received 192.168.178.29:60000 17 90 00 00 71 7f 38 19 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        wiegand-tcpip.0
        	2022-03-21 08:09:35.068	debug	sent 192.168.178.29:60000 17 90 00 00 71 7f 38 19 c0 a8 b2 31 61 ea 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        wiegand-tcpip.0
        	2022-03-21 08:09:35.064	debug	received 192.168.178.29:60000 17 8e 00 00 71 7f 38 19 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        wiegand-tcpip.0
        	2022-03-21 08:09:35.003	debug	sent 192.168.178.29:60000 17 8e 00 00 71 7f 38 19 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        wiegand-tcpip.0
        	2022-03-21 08:09:35.001	info	Connect to controller: xxxxxxxxx
        wiegand-tcpip.0
        	2022-03-21 08:09:34.996	debug	received 192.168.178.29:60000 17 20 00 00 71 7f 38 19 73 1f 00 00 01 01 01 01 04 69 5a aa 20 22 03 20 22 14 37 01 01 01 01 01 00 00 00 00 00 08 09 34 00 00 00 00 00 00 00 00 00 00 00 22 03 21 00 00 00 00 00 00 00 00 00 00
        wiegand-tcpip.0
        	2022-03-21 08:09:34.994	debug	sent 192.168.178.29:60000 17 20 00 00 71 7f 38 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        wiegand-tcpip.0
        	2022-03-21 08:09:34.977	warn	Incorrect controller-setup for non/broadcast: xxxxxxxxx
        wiegand-tcpip.0
        	2022-03-21 08:09:34.851	info	Create controller xxxxxxxxxx for Model 4-Door Objects
        wiegand-tcpip.0
        	2022-03-21 08:09:34.810	info	starting. Version 0.4.6 (non-npm: kBrausew/ioBroker.wiegand-tcpip#v0.4.6) in /opt/iobroker/node_modules/iobroker.wiegand-tcpip, node: v14.19.0, js-controller: 4.0.21
        • R RandyAndy
          @kbrausew
          wiegand-tcpip.0
          wiegand-tcpip.0
          wiegand-tcpip.0
          wiegand-tcpip.0
          wiegand-tcpip.0
          wiegand-tcpip.0
          wiegand-tcpip.0
          wiegand-tcpip.0
          wiegand-tcpip.0
          wiegand-tcpip.0
          wiegand-tcpip.0
          wiegand-tcpip.0
          wiegand-tcpip.0
          wiegand-tcpip.0
          wiegand-tcpip.0
          wiegand-tcpip.0
          wiegand-tcpip.0
          wiegand-tcpip.0
          wiegand-tcpip.0
          wiegand-tcpip.0
          wiegand-tcpip.0
          kBrausewK Offline
          kBrausewK Offline
          kBrausew
          #66
          @randyandy sagte in WIEGAND TCP/IP Adapter (Alias UHPPOTE):
          @kbrausew
          ... Incorrect controller-setup for ...
          Entweder alle drei ( Ctrl-IP + ioB-IP + Port) Felder füllen oder keins davon.
          ... php-Skripte ...
          Ok, dann sollte es gehen... würde einfach mal zwei drei Tage die Log beobachten auf:
          Das wäre der Indiz auf einen "Lauchangriff" durch die PHP-Scripte ;)
          Das wird aber nur ein paar mal am Tag ( jeder 10ten Heartbeat) geprüft. => "Extendend" eben ;-)
          BTW: Test Swipe und remoteOpen nicht vergessen
            @kbrausew
            ... php-Skripte ...
            R Online
            R Online
            RandyAndy
            #67
            remote Open muss ich noch machen, dazu muss ich aber am Objekt sein.
            Swipe wird bestimmt 30 mal am Tag gemacht. In diesem Feld taucht aber nie etwas auf, ist immer auf 0. Während das php Skript eben regelmäßig etwas anzeigt.
            Wie ich schon beschrieben habe, gibt das php Skript ein LOG aus und das Werte ich mit dem PARSER Adapter aus. ICh rufe das Skipt alle 5 Minuten auf und ziehe die letzten 3 zugänge ab.
            Andreas
            • R RandyAndy
              Andreas
              kBrausewK Offline
              kBrausewK Offline
              kBrausew
              #68
              Swipe wird bestimmt 30 mal am Tag gemacht...
              stimmen die?
              kannst du das LowLevel hier mitschneiden?
                stimmen die?
                R Online
                R Online
                RandyAndy
                #69
                @kbrausew
                Here we go
                Die Ports sind oben wie unten identisch auf 60001 eingestellt.
                wiegand-tcpip.0
                	2022-03-21 14:52:39.679	debug	Request remote open: xxxxxxxxx Door-1: {"deviceId":xxxxxxxxx,"opened":true}
                wiegand-tcpip.0
                	2022-03-21 14:52:39.678	debug	received 192.168.178.29:60000 17 40 00 00 71 7f 38 19 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                wiegand-tcpip.0
                	2022-03-21 14:52:39.677	debug	sent 192.168.178.29:60000 17 40 00 00 71 7f 38 19 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                wiegand-tcpip.0
                	2022-03-21 14:52:32.335	debug	Request remote open: xxxxxxxxx Door-1: {"deviceId":xxxxxxxxx,"opened":true}
                wiegand-tcpip.0
                	2022-03-21 14:52:32.334	debug	received 192.168.178.29:60000 17 40 00 00 71 7f 38 19 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                wiegand-tcpip.0
                	2022-03-21 14:52:32.333	debug	sent 192.168.178.29:60000 17 40 00 00 71 7f 38 19 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                wiegand-tcpip.0
                	2022-03-21 14:50:37.823	debug	received 192.168.178.29:60000 17 82 00 00 71 7f 38 19 04 03 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                wiegand-tcpip.0
                	2022-03-21 14:50:37.818	debug	sent 192.168.178.29:60000 17 82 00 00 71 7f 38 19 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                wiegand-tcpip.0
                	2022-03-21 14:50:37.815	debug	received 192.168.178.29:60000 17 82 00 00 71 7f 38 19 03 03 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                wiegand-tcpip.0
                	2022-03-21 14:50:37.812	debug	sent 192.168.178.29:60000 17 82 00 00 71 7f 38 19 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                wiegand-tcpip.0
                	2022-03-21 14:50:37.808	debug	received 192.168.178.29:60000 17 82 00 00 71 7f 38 19 02 03 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                wiegand-tcpip.0
                	2022-03-21 14:50:37.806	debug	sent 192.168.178.29:60000 17 82 00 00 71 7f 38 19 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                wiegand-tcpip.0
                	2022-03-21 14:50:37.800	debug	received 192.168.178.29:60000 17 82 00 00 71 7f 38 19 01 03 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                wiegand-tcpip.0
                	2022-03-21 14:50:37.798	debug	sent 192.168.178.29:60000 17 82 00 00 71 7f 38 19 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                wiegand-tcpip.0
                	2022-03-21 14:50:37.793	debug	received 192.168.178.29:60000 17 30 00 00 71 7f 38 19 20 22 03 21 14 50 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                wiegand-tcpip.0
                	2022-03-21 14:50:37.791	debug	sent 192.168.178.29:60000 17 30 00 00 71 7f 38 19 20 22 03 21 14 50 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                wiegand-tcpip.0
                	2022-03-21 14:50:37.786	info	Reset the device clock: xxxxxxxxx
                wiegand-tcpip.0
                	2022-03-21 14:50:37.785	debug	received 192.168.178.29:60000 17 90 00 00 71 7f 38 19 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                wiegand-tcpip.0
                	2022-03-21 14:50:37.595	debug	sent 192.168.178.29:60000 17 90 00 00 71 7f 38 19 c0 a8 b2 31 71 17 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                wiegand-tcpip.0
                	2022-03-21 14:50:37.591	debug	received 192.168.178.29:60000 17 8e 00 00 71 7f 38 19 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                wiegand-tcpip.0
                	2022-03-21 14:50:37.401	debug	sent 192.168.178.29:60000 17 8e 00 00 71 7f 38 19 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                wiegand-tcpip.0
                	2022-03-21 14:50:37.397	info	Connect to controller: xxxxxxxxx
                wiegand-tcpip.0
                	2022-03-21 14:50:37.392	debug	received 192.168.178.29:60000 17 20 00 00 71 7f 38 19 74 1f 00 00 01 01 01 01 04 78 70 aa 20 22 03 21 12 49 15 01 01 01 01 01 00 00 00 00 00 14 50 36 00 00 00 00 00 00 00 00 00 00 00 22 03 21 00 00 00 00 00 00 00 00 00 00
                wiegand-tcpip.0
                	2022-03-21 14:50:37.390	debug	sent 192.168.178.29:60000 17 20 00 00 71 7f 38 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                wiegand-tcpip.0
                	2022-03-21 14:50:37.278	info	Create controller xxxxxxxxx for Model 4-Door Objects
                wiegand-tcpip.0
                	2022-03-21 14:50:37.235	info	starting. Version 0.4.6 (non-npm: kBrausew/ioBroker.wiegand-tcpip#v0.4.6) in /opt/iobroker/node_modules/iobroker.wiegand-tcpip, node: v14.19.0, js-controller: 4.0.21
                wiegand-tcpip.0
                	2022-03-21 14:50:36.879	debug	States connected to redis: 127.0.0.1:9000
                wiegand-tcpip.0
                	2022-03-21 14:50:36.813	debug	States create User PubSub Client
                wiegand-tcpip.0
                	2022-03-21 14:50:36.812	debug	States create System PubSub Client
                wiegand-tcpip.0
                	2022-03-21 14:50:36.744	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                wiegand-tcpip.0
                	2022-03-21 14:50:36.662	debug	Objects connected to redis: 127.0.0.1:9001
                wiegand-tcpip.0
                	2022-03-21 14:50:36.655	debug	Objects client initialize lua scripts
                wiegand-tcpip.0
                	2022-03-21 14:50:36.510	debug	Objects create User PubSub Client
                wiegand-tcpip.0
                	2022-03-21 14:50:36.508	debug	Objects create System PubSub Client
                wiegand-tcpip.0
                	2022-03-21 14:50:36.506	debug	Objects client ready ... initialize now
                • R RandyAndy
                  @kbrausew
                  Here we go
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  wiegand-tcpip.0
                  kBrausewK Offline
                  kBrausewK Offline
                  kBrausew
                  #70
                  Muss dich leider enttäuschen; der untere hat eine '0' Zuwenig und steht auf 6001 anstatt auf 60001
                    R Online
                    R Online
                    RandyAndy
                    #71
                    @kbrausew
                    sorry das ist nun wirklich mein Fehler. Jetzt kommt in der Tat etwas an.
                    Mal sehen was geschieht wenn ein Tag verwendet wird. Dazu muss ich nun abwarten bis jemend die Tür öffnet.
                    • R RandyAndy
                      @kbrausew
                      kBrausewK Offline
                      kBrausewK Offline
                      kBrausew
                      #72
                      @randyandy LowLevel abschalten, wird jetzt nicht mehr benötigt.
                      Ohne Script wird ausser Logmeldungen nichts zu sehen sein.
                      Du müsstes jetzt lastSwipe auf irgend ein History Adapter loggen ... oder JS irgend etwas... usw ...
                      Hab schon mal mit den Karten begonnen... läuft schleppend da ich dreidimensionale Qube für die Config bräuchte ... leider gibt's die nicht in ioB config
                        R Online
                        R Online
                        RandyAndy
                        #73
                        @kbrausew
                        Vielen Dank für Deine Unterstützung.
                        Nur als Anregung. Eigentlich gibt es Zwei Arten von Karten/Codes:
                        • Das eigentliche Tag (also den Chip) und
                        • einen Code den man z.B. verschicken kann und den man manuell über ein Zahlenfeld eingeben kann. Der Zugangscode wird manuell (bzw. in meinem Fall im Buchungssystem) erzeugt und dann am Anreisetag an den PHPPote mit einem Zeitprofil übertragen,
                        Ich habe für meine Anwendung folgendes programmiert.
                        • Der Zugangscode wird um 8:00 Uhr früh in den PHPPOte übertragen und ist dann ab 16:00 Uhr (ist ein Profil im PHPPote, das man erstellen kann) z.B. für 2 Tage gültig.
                          2 Tage deshalb da ein Profil im PHPPote immer nur einen Zeitraum 0:00 - 24:00 oder in meinen Fall 16:00 bis 24:00 umfaßt. Ich kann aber kein Profil erstellen von 16:00 Uhr bis 5:00 Uhr des nächsten Tags.
                        • Daher lösche ich um 5:00 Uhr am nächsten Tag den Zugangscode. Ist ein Workaround funktioniert aber gut.
                        Für sehr wichtig hat sich erherausgestellt, dass man einen Tag oder einen Zugangscode sperren kann. Das hat uns wirklich in Corona viel Zeit erspart. Ohne Impfnachweis, Test usw. der nicht vorliegt konnten wir kurzfristig den Code sperren (nicht löschen) und nach Übermittlung dann wieder freigeben.
                        Ich habe das dann direkt an eine MYSQL Datenbank in der die Zugangsdaten gespeichert sind dran gehängt und alles funktioniert tadellos. Ist aber natürlich ein eigener RaspberryPi mit Web-Server, Apache Server usw der das alles verwaltet.
                        Angesprochen wird das über php-Skripte die aus iobroker heraus aufgerufen werden.
                        Bitte das alles nur als Anregung ansehen. Da gebe ich am Ende meine Erfahrung wieder die wir in den letzten Jahren zusammengetragen haben.
                        Andreas
                        • R RandyAndy
                          @kbrausew
                          Andreas
                          kBrausewK Offline
                          kBrausewK Offline
                          kBrausew
                          #74
                          ... Zwei Arten von Karten/Codes ...
                          Für den ioBroker-Adapter ist dies irrelevant da unabhängig vom Ursprung die Logik dahinter immer die gleiche ist.
                          Stimmt er == granted oder eben nicht == denied
                          Selbst der triviale "Button"-Klick wird intern mit einer Pseudo-Id gearbeitet
                          Ich habe für meine Anwendung folgendes programmiert...
                          Hier muss ich ganz klar auf das Schichtenmodel verweisen...
                          Du hast hier eine Business-Logik programmiert die in dem Adapter nichts zu suchen hat.
                          Der Adapter wird zwar im End-Ausbau Schnittstellen für deine Belange haben aber nichts von deinen Logiken enthalten.
                          Dies wird man dann in JS-Adapter, Scenen, Vis oder sonst wo implementieren müssen.
                          Sorry, aber das würde dann jeglichen Modellen (SOC, OSI, ISO OO-Template...) kontraproduktiv entgegen wirken.
                          Aber als Anregung "Welche SSt/API benötigt wird" willkommen...
                            R Online
                            R Online
                            RandyAndy
                            #75
                            @kbrausew
                            Als solches war es auch gedacht damit man auf diese Anforderungen bei der Implementierung gleich eingehen kann.
                            Vielleicht noch ein interessante Information, das wäre die ultimative Lösung. Unser Lesegerät reagiert auch auf NFC und mit dem Mobiltelefon kann man den Leser triggern und es wird eine ID im Controller generiert. Leider konnte ich keine Abhängigkeiten erkennen die ID ändert sich willkürlich. Mein Hoffnung war das das wie in einem Tag ist und dann immer die gleiche ID ist, ist es aber nicht.
                            Andreas
                            • R RandyAndy
                              @kbrausew
                              Andreas
                              kBrausewK Offline
                              kBrausewK Offline
                              kBrausew
                              #76
                              ... Lesegerät ... NFC ... Mobiltelefon ... eine ID im Controller ... willkürlich ID ...
                              Das ist leider so (zwischen Reader und Controller und kann aus diesem Grund nicht geändert werden) :-( :-( :-(
                                Dominic151617
                                #77
                                Hallo @kbrausew , erstmal vielen vielen Dank für die Arbeit, die Du Dir machst!
                                Allgemein läuft der Adapter jetzt bei mir und ich kann zuverlässig sehen, wer die Tür öffnet. Eine Sache konnte ich allerdings nicht umsetzen. Und zwar würde ich gerne über das Pinpad auch Funktionen auslösen, die nichts mit der Türöffnung zu tun haben. Beispiel: Wenn wir zu Hause sind, können die Kinder mit dem Pin 1111 die Garage öffnen. Leider wird aktuell das Objekt lastSwipe nur aktualisiert, wenn die Tür auch geöffnet wurde. Die EventNr. zählt allerdings hoch und im Webinterface vom Controller kann ich die Eingabe auch sehen. Kannst Du das eventuell in einer der nächsten Versionen anpassen?
                                Danke im Voraus!!
                                kBrausewK 2 Antworten Letzte Antwort
                                • D Dominic151617
                                  Danke im Voraus!!
                                  kBrausewK Offline
                                  kBrausewK Offline
                                  kBrausew
                                  #78
                                  @dominic151617 sagte in WIEGAND TCP/IP Adapter (Alias UHPPOTE):
                                  ... können die Kinder mit dem Pin 1111 die Garage öffnen ...
                                  Das must du im Kontroller einstellen...
                                  Angenommen:
                                  Deine Garage ist am Relais Door-3. Dann musst du Pin '1111' an Türe '3' zulassen.
                                  Wenn dir dann nur der physische Draht von Relais-3 zum Garagenöffner fehlt, spielt das keine Rolle...
                                  Durch diese Konfig bekommst du am Door-3 im ioBroker am Datenpunkt ".unlocked" einen kurzen Impuls den du in JS oder Szeneadapter für was-auch-immer benutzen kannst... z.B. die Garage öffnen.
                                  Ich habe z.B. kein Relais physisch beschaltet, alles läuft über ".unlocked" zum SmartDoor-Locker (z.B. TEDEE oder NUK...)
                                  Hast du nur ein TO :-( so muss der wohl über den Kontakt geschaltet werden?!
                                  Schlecht wird es erst wenn du keine Relais mehr "frei" hast... da deine Anforderung nicht umsetzbar ist, da ich vom Kontroller nichts bekomme (Hast du v0.4.6 installiert? dann schau dir ".unauthorized" an... wenn hier nichts steht, bekomme ich im Pin-denied-Fall keine ?Nummer? vom Kontroller zurück)
                                  • D Dominic151617
                                    Danke im Voraus!!
                                    kBrausewK Offline
                                    kBrausewK Offline
                                    kBrausew
                                    #79
                                    @Dominic151617
                                    Hat's funktioniert... ich weiß es ja, aber für die anderen ;)
                                      @Dominic151617
                                      Dominic151617
                                      schrieb am zuletzt editiert von Dominic151617
                                      #80
                                      @kbrausew, sorry, dass es mal wieder länger gedauert hat. Ich bräuchte mal son Sabbatjahr nur für private Projekte...
                                      Und dann sollte ich mir noch mal selber auf die Finger hauen. Man sollte nicht daran glauben, dass die 0.4.6 installiert ist, sondern dies auch einfach kontrollieren. Dann hätte man nicht den ganzen geschriebenen Text wieder löschen müssen. Aber egal.
                                      Fazit: jetzt funktioniert es.
                                      Vielleicht etwas Info:
                                      Board für zwei Türen. Zweite Tür bekommt aber kein Wiegand Signal.
                                      Board hat die Firmware V6.56.50703
                                      Adapterversion ist jetzt die 0.4.6
                                      Garage wird über einen Homematic Aktor geöffnet.
                                      Eingestellt habe ich einen User, für die Garage, der für Tür 2 berechtigt ist.
                                      Ob das überhaupt nötig ist, kann ich garnicht sagen, da eigentlich nur Tür 1 ausgewertet wird. Vermutlich weil der Wiegand Controller nur an Tür 1 angeschlossen ist.
                                      Das ganze kann man dann einfach auf .eventNr triggern lassen und eine beliebige Aktion ausführen lassen.
                                      Noch mal besten Dank für den tollen Adapter!
                                      • D Dominic151617
                                        kBrausewK Offline
                                        kBrausewK Offline
                                        kBrausew
                                        #81
                                        @dominic151617
                                        Diese Konfig kann ich nicht empfehlen:
                                        Irgendein Event tritt ein bei der die CardID nicht neu geschrieben wird...
                                        EventNr wird hochgezählt, CardID bleibt vom letzten Zugriff '1111' Eltern sind zuhause: Tor geht wie von Geisterhand auf :-(
                                        Schnelle Abhilfe: Trigger die CardID direkt (NICHT auf "wurde geändert", sondern auf "wurde aktualisiert" + '1111')
                                        Korrektes Setup: Schleife den Reader-1-Out zu Reder-2-In (Nur Wiegand D0 + D1) durch.
                                        Trenne alle Zugangsberechtigungen strickt (so das nicht irgend ein Pin, Karte oder FingerPrint beide "Türen" öffnet!!
                                        Jetzt kannst du an Türe-2 "...unlocked" (auf "ist Wahr") dein Garagentor öffnen wenn Eltern-Zuhause.
                                        Sollte es kein Reader-1-Out geben, kannst du bei den meisten Readern auch einfach D0 + D1 direkt durchschleifen (Das hängt aber von den Reader ab, nicht von dem Controller). Sollte der Reader zuwenig Pegel liefern für's durchschleifen, gibt es noch den "Multikanal-Wiegand". Wie gesagt, nur wenn's nicht mit ner trivialen Drahtbrücke klappt
                                        • D Dominic151617
                                          kBrausewK Offline
                                          kBrausewK Offline
                                          kBrausew
                                          #82
                                          @dominic151617 ... hast du es geändert?
