  4. Test Alpha Homekit-Controller 0.0.x
260 Beiträge 27 Kommentatoren 62.5k Aufrufe 24 Beobachtet
  • apollon77A apollon77
    @fortune95 sagte in Test Alpha Homekit-Controller 0.0.x:
    2022-02-16 19:07:23.539 - debug: homekit-controller.0 (115115) Response to Command identify: {"success":false,"error":"Cannot identify device BLE-EA:80:43:5F:2E:FE because of error undefined: Identify returned error status: 5"}
    Also Fehler 5 sagt laut Specs
    Server reached its maximum number of authentication attempts.
    Resette mal ...
    Fortune95
    #150
    @apollon77
    So habe noch eine Ergänzung nach Google Recherche... im Bluetooth Service vorgenommen.
    Zumindest lieferte der Bluetooth Service danach keine Fehler mehr.
    Und auch das identifizieren ging dann wieder.
    Habe diese Zeile so abgeändert
    ExecStart=/usr/lib/bluetooth/bluetoothd --noplugin=sap
    Nur das pairen will einfach nicht.
    Hier das Log:
    iobroker@iobroker:~$ sudo systemctl status bluetooth.service
    ● bluetooth.service - Bluetooth service
         Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
         Active: active (running) since Thu 2022-02-17 18:58:26 CET; 13s ago
           Docs: man:bluetoothd(8)
       Main PID: 2443 (bluetoothd)
         Status: "Running"
          Tasks: 1 (limit: 7090)
         Memory: 740.0K
            CPU: 9ms
         CGroup: /system.slice/bluetooth.service
                 └─2443 /usr/libexec/bluetooth/bluetoothd --noplugin=sap
    Feb 17 18:58:26 iobroker systemd[1]: Starting Bluetooth service...
    Feb 17 18:58:26 iobroker bluetoothd[2443]: Bluetooth daemon 5.55
    Feb 17 18:58:26 iobroker systemd[1]: Started Bluetooth service.
    Feb 17 18:58:26 iobroker bluetoothd[2443]: Starting SDP server
    Feb 17 18:58:26 iobroker bluetoothd[2443]: Excluding (cli) sap
    Feb 17 18:58:26 iobroker bluetoothd[2443]: Bluetooth management interface 1.18 initialized
    iobroker@iobroker:~$ DEBUG=hap* node /opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js 0 --debug
    2022-02-17 19:00:01.818  - debug: homekit-controller.0 (2501) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2022-02-17 19:00:01.856  - debug: homekit-controller.0 (2501) Objects client ready ... initialize now
    2022-02-17 19:00:01.857  - debug: homekit-controller.0 (2501) Objects create System PubSub Client
    2022-02-17 19:00:01.858  - debug: homekit-controller.0 (2501) Objects create User PubSub Client
    2022-02-17 19:00:01.879  - debug: homekit-controller.0 (2501) Objects client initialize lua scripts
    2022-02-17 19:00:01.881  - debug: homekit-controller.0 (2501) Objects connected to redis: 127.0.0.1:9001
    2022-02-17 19:00:01.896  - debug: homekit-controller.0 (2501) Redis States: Use Redis connection: 127.0.0.1:6379
    2022-02-17 19:00:01.898  - debug: homekit-controller.0 (2501) States create System PubSub Client
    2022-02-17 19:00:01.899  - debug: homekit-controller.0 (2501) States create User PubSub Client
    2022-02-17 19:00:01.901  - debug: homekit-controller.0 (2501) States connected to redis: 127.0.0.1:6379
    2022-02-17 19:00:01.917  - debug: homekit-controller.0 (2501) Plugin sentry Initialize Plugin (enabled=true)
    2022-02-17 19:00:01.992  - error: homekit-controller.0 (2501) adapter disabled
    2022-02-17 19:00:02.039  - info: homekit-controller.0 (2501) starting. Version 0.4.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.19.0, js-controller: 4.0.10
    2022-02-17 19:00:02.112  - debug: homekit-controller.0 (2501) state homekit-controller.0.info.connection changed: false (ack = true)
    2022-02-17 19:00:02.114  - debug: homekit-controller.0 (2501) Init 1 known devices without discovery ...
    2022-02-17 19:00:02.115  - debug: homekit-controller.0 (2501) Init BLE-BA:0A:DB:84:F2:CE as known device
    2022-02-17 19:00:02.116  - info: homekit-controller.0 (2501) BLE-BA:0A:DB:84:F2:CE (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects
    2022-02-17 19:00:02.116  - debug: homekit-controller.0 (2501) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ba:0a:db:84:f2:ce","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"ba:0a:db:84:f2:ce","ci":10,"availableToPair":true}
    2022-02-17 19:00:02.128  - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connectionType changed: BLE (ack = true)
    2022-02-17 19:00:02.134  - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.id changed: ba:0a:db:84:f2:ce (ack = true)
    2022-02-17 19:00:02.138  - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connected changed: false (ack = true)
    2022-02-17 19:00:02.145  - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.admin.isPaired changed: false (ack = true)
    2022-02-17 19:00:02.149  - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.lastDiscovered changed: 1645120802117 (ack = true)
    2022-02-17 19:00:02.689  - debug: homekit-controller.0 (2501) Discovered BLE device up: ba:0a:db:84:f2:ce/Eve Degree 5980
    2022-02-17 19:00:02.689  - debug: homekit-controller.0 (2501) BLE-BA:0A:DB:84:F2:CE Discovered BLE device: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ba:0a:db:84:f2:ce","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"ba:0a:db:84:f2:ce","ci":10,"availableToPair":true}
    2022-02-17 19:00:02.690  - info: homekit-controller.0 (2501) BLE-BA:0A:DB:84:F2:CE (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects
    2022-02-17 19:00:02.690  - debug: homekit-controller.0 (2501) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ba:0a:db:84:f2:ce","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"ba:0a:db:84:f2:ce","ci":10,"availableToPair":true}
    2022-02-17 19:00:02.698  - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connectionType changed: BLE (ack = true)
    2022-02-17 19:00:02.701  - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.id changed: ba:0a:db:84:f2:ce (ack = true)
    2022-02-17 19:00:02.705  - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connected changed: false (ack = true)
    2022-02-17 19:00:02.710  - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.admin.isPaired changed: false (ack = true)
    2022-02-17 19:00:02.714  - debug: homekit-controller.0 (2501) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.lastDiscovered changed: 1645120802690 (ack = true)
    2022-02-17 19:00:07.994  - debug: homekit-controller.0 (2501) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":33,"ack":false,"time":1645120807993},"_id":16181580})
    2022-02-17 19:00:07.994  - debug: homekit-controller.0 (2501) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-BA:0A:DB:84:F2:CE","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 5980","discoveredCategory":"Sensor","pairedWithThisInstance":false}]}
    2022-02-17 19:00:09.643  - debug: homekit-controller.0 (2501) Message identify received: {"command":"identify","message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE"},"id":34,"ack":false,"time":1645120809642},"_id":16181581})
    2022-02-17 19:00:09.643  - debug: homekit-controller.0 (2501) Device BLE-BA:0A:DB:84:F2:CE: Identify triggered
      hap-controller:gatt-connection connect peripheral +0ms
      hap-controller:tlv Add 1 bytes for tag 1: 01 +0ms
      hap-controller:gatt-connection ff4feaecc339/ff:4f:ea:ec:c3:39 Write for characteristic 000000140000100080000026bb765291 00020003000300010101 +4s
      hap-controller:gatt-connection ff4feaecc339/ff:4f:ea:ec:c3:39 Received data for characteristic 000000140000100080000026bb765291 020000 +224ms
      hap-controller:gatt-connection disconnect peripheral +1ms
      hap-controller:gatt-connection Peripheral disconnected +45ms
    2022-02-17 19:00:13.890  - debug: homekit-controller.0 (2501) Response to Command identify: {"success":true,"error":false}
    2022-02-17 19:00:15.413  - debug: homekit-controller.0 (2501) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":35,"ack":false,"time":1645120815413},"_id":16181582})
    2022-02-17 19:00:15.414  - debug: homekit-controller.0 (2501) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-BA:0A:DB:84:F2:CE","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 5980","discoveredCategory":"Sensor","pairedWithThisInstance":false}]}
    2022-02-17 19:00:25.994  - debug: homekit-controller.0 (2501) Message identify received: {"command":"identify","message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE"},"id":36,"ack":false,"time":1645120825994},"_id":16181583})
    2022-02-17 19:00:25.995  - debug: homekit-controller.0 (2501) Device BLE-BA:0A:DB:84:F2:CE: Identify triggered
      hap-controller:gatt-connection connect peripheral +12s
      hap-controller:gatt-connection disconnect peripheral +5s
    2022-02-17 19:01:00.829  - debug: homekit-controller.0 (2501) Response to Command identify: {"success":false,"error":"Cannot identify device BLE-BA:0A:DB:84:F2:CE because of error undefined: Unknown Connection Identifier (0x2)"}
    ^Ciobroker@iobroker:~$ DEBUG=hap* node /opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js 0 --debug
    2022-02-17 19:01:16.958  - debug: homekit-controller.0 (2526) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2022-02-17 19:01:16.994  - debug: homekit-controller.0 (2526) Objects client ready ... initialize now
    2022-02-17 19:01:16.995  - debug: homekit-controller.0 (2526) Objects create System PubSub Client
    2022-02-17 19:01:16.996  - debug: homekit-controller.0 (2526) Objects create User PubSub Client
    2022-02-17 19:01:17.016  - debug: homekit-controller.0 (2526) Objects client initialize lua scripts
    2022-02-17 19:01:17.018  - debug: homekit-controller.0 (2526) Objects connected to redis: 127.0.0.1:9001
    2022-02-17 19:01:17.031  - debug: homekit-controller.0 (2526) Redis States: Use Redis connection: 127.0.0.1:6379
    2022-02-17 19:01:17.033  - debug: homekit-controller.0 (2526) States create System PubSub Client
    2022-02-17 19:01:17.034  - debug: homekit-controller.0 (2526) States create User PubSub Client
    2022-02-17 19:01:17.036  - debug: homekit-controller.0 (2526) States connected to redis: 127.0.0.1:6379
    2022-02-17 19:01:17.049  - debug: homekit-controller.0 (2526) Plugin sentry Initialize Plugin (enabled=true)
    2022-02-17 19:01:17.110  - error: homekit-controller.0 (2526) adapter disabled
    2022-02-17 19:01:17.159  - info: homekit-controller.0 (2526) starting. Version 0.4.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.19.0, js-controller: 4.0.10
    2022-02-17 19:01:17.232  - debug: homekit-controller.0 (2526) state homekit-controller.0.info.connection changed: false (ack = true)
    2022-02-17 19:01:17.235  - debug: homekit-controller.0 (2526) Init 1 known devices without discovery ...
    2022-02-17 19:01:17.236  - debug: homekit-controller.0 (2526) Init BLE-BA:0A:DB:84:F2:CE as known device
    2022-02-17 19:01:17.237  - info: homekit-controller.0 (2526) BLE-BA:0A:DB:84:F2:CE (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects
    2022-02-17 19:01:17.238  - debug: homekit-controller.0 (2526) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ba:0a:db:84:f2:ce","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"ba:0a:db:84:f2:ce","ci":10,"availableToPair":true}
    2022-02-17 19:01:17.248  - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connectionType changed: BLE (ack = true)
    2022-02-17 19:01:17.252  - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.id changed: ba:0a:db:84:f2:ce (ack = true)
    2022-02-17 19:01:17.255  - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connected changed: false (ack = true)
    2022-02-17 19:01:17.259  - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.admin.isPaired changed: false (ack = true)
    2022-02-17 19:01:17.262  - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.lastDiscovered changed: 1645120877239 (ack = true)
    2022-02-17 19:01:20.744  - debug: homekit-controller.0 (2526) Discovered BLE device up: ba:0a:db:84:f2:ce/Eve Degree 5980
    2022-02-17 19:01:20.745  - debug: homekit-controller.0 (2526) BLE-BA:0A:DB:84:F2:CE Discovered BLE device: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ba:0a:db:84:f2:ce","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"ba:0a:db:84:f2:ce","ci":10,"availableToPair":true}
    2022-02-17 19:01:20.745  - info: homekit-controller.0 (2526) BLE-BA:0A:DB:84:F2:CE (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects
    2022-02-17 19:01:20.745  - debug: homekit-controller.0 (2526) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ba:0a:db:84:f2:ce","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"ba:0a:db:84:f2:ce","ci":10,"availableToPair":true}
    2022-02-17 19:01:20.752  - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connectionType changed: BLE (ack = true)
    2022-02-17 19:01:20.755  - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.id changed: ba:0a:db:84:f2:ce (ack = true)
    2022-02-17 19:01:20.759  - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.connected changed: false (ack = true)
    2022-02-17 19:01:20.766  - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.admin.isPaired changed: false (ack = true)
    2022-02-17 19:01:20.769  - debug: homekit-controller.0 (2526) state homekit-controller.0.BLE-BA:0A:DB:84:F2:CE.info.lastDiscovered changed: 1645120880745 (ack = true)
    2022-02-17 19:01:25.279  - debug: homekit-controller.0 (2526) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":37,"ack":false,"time":1645120885278},"_id":16181584})
    2022-02-17 19:01:25.280  - debug: homekit-controller.0 (2526) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-BA:0A:DB:84:F2:CE","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 5980","discoveredCategory":"Sensor","pairedWithThisInstance":false}]}
    2022-02-17 19:01:26.989  - debug: homekit-controller.0 (2526) Message identify received: {"command":"identify","message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE"},"id":38,"ack":false,"time":1645120886988},"_id":16181585})
    2022-02-17 19:01:26.990  - debug: homekit-controller.0 (2526) Device BLE-BA:0A:DB:84:F2:CE: Identify triggered
      hap-controller:gatt-connection ff4feaecc339/ff:4f:ea:ec:c3:39 Write for characteristic 000000140000100080000026bb765291 00020003000300010101 +3s
      hap-controller:gatt-connection ff4feaecc339/ff:4f:ea:ec:c3:39 Received data for characteristic 000000140000100080000026bb765291 020000 +225ms
      hap-controller:gatt-connection disconnect peripheral +0ms
    2022-02-17 19:01:30.649  - debug: homekit-controller.0 (2526) Response to Command identify: {"success":true,"error":false}
    2022-02-17 19:01:32.166  - debug: homekit-controller.0 (2526) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":39,"ack":false,"time":1645120892163},"_id":16181586})
    2022-02-17 19:01:32.167  - debug: homekit-controller.0 (2526) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-BA:0A:DB:84:F2:CE","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 5980","discoveredCategory":"Sensor","pairedWithThisInstance":false}]}
    2022-02-17 19:01:51.108  - debug: homekit-controller.0 (2526) Message pairDevice received: {"command":"pairDevice","message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE","pin":"843-54-008"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-BA:0A:DB:84:F2:CE","pin":"843-54-008"},"id":40,"ack":false,"time":1645120911107},"_id":16181587})
      hap-controller:gatt-connection connect peripheral +20s
      hap-controller:gatt-connection disconnect peripheral +7s
    2022-02-17 19:02:27.867  - info: homekit-controller.0 (2526) Cannot retrieve BLE PairMethod for device BLE-BA:0A:DB:84:F2:CE because of error undefined: Unknown Connection Identifier (0x2), try default
    2022-02-17 19:02:27.868  - info: homekit-controller.0 (2526) Use PairMethod 0 to pair BLE-BA:0A:DB:84:F2:CE
    2022-02-17 19:02:27.868  - debug: homekit-controller.0 (2526) BLE-BA:0A:DB:84:F2:CE Start Homekit Device Client initialization
      hap-controller:gatt-connection disconnect peripheral to reconnect +30s
    2022-02-17 19:02:57.870  - debug: homekit-controller.0 (2526) Response to Command pairDevice: {"success":false,"error":"Cannot pair with device BLE-BA:0A:DB:84:F2:CE because of error undefined (undefined): undefined"}
    • apollon77A Offline
      #151
      Interessant, den Fehler hatte ich in einem Issue schonmal gesehen, aber tja dann wirds ganz interessant. Bitte schaumal da durch https://github.com/Apollon77/ioBroker.homekit-controller/#for-ble-devices und versuche es blt mach dieses Log parallel
      F 1 Antwort Letzte Antwort
        Fortune95
        #152
        @apollon77
        Habe den Adapter wie im Issue beschrieben von Gihub installiert und das Log erstellt:
        iobroker@iobroker:~$ DEBUG=hap* node /opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js 0 --debug --logs
        2022-02-18 16:07:47.793  - debug: homekit-controller.0 (6682) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2022-02-18 16:07:47.815  - debug: homekit-controller.0 (6682) Objects client ready ... initialize now
        2022-02-18 16:07:47.816  - debug: homekit-controller.0 (6682) Objects create System PubSub Client
        2022-02-18 16:07:47.817  - debug: homekit-controller.0 (6682) Objects create User PubSub Client
        2022-02-18 16:07:47.838  - debug: homekit-controller.0 (6682) Objects client initialize lua scripts
        2022-02-18 16:07:47.840  - debug: homekit-controller.0 (6682) Objects connected to redis: 127.0.0.1:9001
        2022-02-18 16:07:47.854  - debug: homekit-controller.0 (6682) Redis States: Use Redis connection: 127.0.0.1:6379
        2022-02-18 16:07:47.856  - debug: homekit-controller.0 (6682) States create System PubSub Client
        2022-02-18 16:07:47.857  - debug: homekit-controller.0 (6682) States create User PubSub Client
        2022-02-18 16:07:47.860  - debug: homekit-controller.0 (6682) States connected to redis: 127.0.0.1:6379
        2022-02-18 16:07:47.872  - debug: homekit-controller.0 (6682) Plugin sentry Initialize Plugin (enabled=true)
        2022-02-18 16:07:47.933  - error: homekit-controller.0 (6682) adapter disabled
        2022-02-18 16:07:47.978  - info: homekit-controller.0 (6682) starting. Version 0.4.3 (non-npm: Apollon77/ioBroker.homekit-controller#c614463e84bfe9c4e7d5d6038d0babdbcb55b852) in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.19.0, js-controller: 4.0.12
        2022-02-18 16:07:48.050  - debug: homekit-controller.0 (6682) state homekit-controller.0.info.connection changed: false (ack = true)
        2022-02-18 16:07:53.221  - debug: homekit-controller.0 (6682) Discovered BLE device up: 25:3e:f0:cc:4c:64/Eve
        2022-02-18 16:07:53.221  - debug: homekit-controller.0 (6682) BLE-25:3E:F0:CC:4C:64 Discovered BLE device: {"name":"Eve","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"25:3e:f0:cc:4c:64","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"25:3e:f0:cc:4c:64","ci":10,"availableToPair":true}
        2022-02-18 16:07:53.222  - info: homekit-controller.0 (6682) BLE-25:3E:F0:CC:4C:64 (Eve) found without pairing data but available for pairing: Create basic objects
        2022-02-18 16:07:53.222  - debug: homekit-controller.0 (6682) Service: {"name":"Eve","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"25:3e:f0:cc:4c:64","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"25:3e:f0:cc:4c:64","ci":10,"availableToPair":true}
        2022-02-18 16:07:53.235  - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.info.connectionType changed: BLE (ack = true)
        2022-02-18 16:07:53.237  - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.info.connectionType changed: BLE (ack = true)
        2022-02-18 16:07:53.240  - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.info.id changed: 25:3e:f0:cc:4c:64 (ack = true)
        2022-02-18 16:07:53.243  - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.info.connected changed: false (ack = true)
        2022-02-18 16:07:53.248  - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.admin.isPaired changed: false (ack = true)
        2022-02-18 16:07:53.251  - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.info.lastDiscovered changed: 1645196873223 (ack = true)
        2022-02-18 16:07:53.255  - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.admin.pairWithPin changed:  (ack = true)
        2022-02-18 16:07:53.258  - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.admin.identify changed: false (ack = true)
        2022-02-18 16:08:10.833  - debug: homekit-controller.0 (6682) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":112,"ack":false,"time":1645196890832},"_id":85128405})
        2022-02-18 16:08:10.833  - debug: homekit-controller.0 (6682) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-25:3E:F0:CC:4C:64","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve","discoveredCategory":"Sensor","pairedWithThisInstance":false}]}
        2022-02-18 16:08:12.873  - debug: homekit-controller.0 (6682) Message identify received: {"command":"identify","message":{"deviceId":"BLE-25:3E:F0:CC:4C:64"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-25:3E:F0:CC:4C:64"},"id":113,"ack":false,"time":1645196892872},"_id":85128406})
        2022-02-18 16:08:12.873  - debug: homekit-controller.0 (6682) Device BLE-25:3E:F0:CC:4C:64: Identify triggered
          hap-controller:gatt-connection e60614286935/e6:06:14:28:69:35 Write for characteristic 000000140000100080000026bb765291 00020003000300010101 +6s
          hap-controller:gatt-connection e60614286935/e6:06:14:28:69:35 Received data for characteristic 000000140000100080000026bb765291 020000 +180ms
        2022-02-18 16:08:18.600  - debug: homekit-controller.0 (6682) Response to Command identify: {"success":true,"error":false}
        2022-02-18 16:08:20.110  - debug: homekit-controller.0 (6682) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":114,"ack":false,"time":1645196900109},"_id":85128407})
        2022-02-18 16:08:20.110  - debug: homekit-controller.0 (6682) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-25:3E:F0:CC:4C:64","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve","discoveredCategory":"Sensor","pairedWithThisInstance":false}]}
        2022-02-18 16:08:46.277  - debug: homekit-controller.0 (6682) Message pairDevice received: {"command":"pairDevice","message":{"deviceId":"BLE-25:3E:F0:CC:4C:64","pin":"843-54-008"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-25:3E:F0:CC:4C:64","pin":"843-54-008"},"id":115,"ack":false,"time":1645196926277},"_id":85128408})
          hap-controller:gatt-connection connect peripheral +28s
          hap-controller:gatt-connection e60614286935/e6:06:14:28:69:35 Write for characteristic 0000004f0000100080000026bb765291 0003000f00 +4s
          hap-controller:gatt-connection e60614286935/e6:06:14:28:69:35 Received data for characteristic 0000004f0000100080000026bb765291 0200000300010101 +225ms
          hap-controller:gatt-connection Peripheral disconnected +46ms
        2022-02-18 16:08:50.462  - info: homekit-controller.0 (6682) Use PairMethod 0 to pair BLE-25:3E:F0:CC:4C:64
        2022-02-18 16:08:50.463  - debug: homekit-controller.0 (6682) BLE-25:3E:F0:CC:4C:64 Start Homekit Device Client initialization
          hap-controller:gatt-connection connect peripheral +2ms
        2022-02-18 16:08:55.788  - debug: homekit-controller.0 (6682) Response to Command pairDevice: {"success":false,"error":"Cannot pair with device BLE-25:3E:F0:CC:4C:64 because of error undefined (undefined): Unknown Connection Identifier (0x2)"}
        2022-02-18 16:11:45.843  - debug: homekit-controller.0 (6682) Discovered BLE device changed: 25:3e:f0:cc:4c:64/Eve Degree 5980
        2022-02-18 16:11:45.843  - debug: homekit-controller.0 (6682) BLE-25:3E:F0:CC:4C:64 Discovered BLE device: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"25:3e:f0:cc:4c:64","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"25:3e:f0:cc:4c:64","ci":10,"availableToPair":true}
        2022-02-18 16:11:45.843  - info: homekit-controller.0 (6682) BLE-25:3E:F0:CC:4C:64 (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects
        2022-02-18 16:11:45.844  - debug: homekit-controller.0 (6682) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"25:3e:f0:cc:4c:64","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"25:3e:f0:cc:4c:64","ci":10,"availableToPair":true}
        2022-02-18 16:11:45.852  - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.info.connectionType changed: BLE (ack = true)
        2022-02-18 16:11:45.854  - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.info.id changed: 25:3e:f0:cc:4c:64 (ack = true)
        2022-02-18 16:11:45.858  - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.info.connected changed: false (ack = true)
        2022-02-18 16:11:45.863  - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.admin.isPaired changed: false (ack = true)
        2022-02-18 16:11:45.866  - debug: homekit-controller.0 (6682) state homekit-controller.0.BLE-25:3E:F0:CC:4C:64.info.lastDiscovered changed: 1645197105844 (ack = true)
        • F Fortune95
          @apollon77
          #153
          @fortune95 Hi,
          sorry für die späte Antwort ... Kannst Du es nochmal machen und das zweite log mit dem hcitool auch parallel holen? Das ist denke ich dann interessant in Kombi
            @fortune95 Hi,
            Fortune95
            #154
            @apollon77
            Hi, hab es jetzt mal über die Shell versucht, hier bekomme ich ein Authentication Fehler.
            Hast Du eine Idee wie ich den beheben kann.
            iobroker@iobroker:~$ bluetoothctl
            Agent registered
            [CHG] Controller 08:BE:AC:20:8E:F2 Pairable: yes
            [bluetooth]# devices
            Device 4D:C8:A4:58:F8:96 4D-C8-A4-58-F8-96
            Device 09:CB:9E:AF:84:DF 09-CB-9E-AF-84-DF
            Device FE:4F:B0:DD:AA:22 Eve Degree 5980
            Device 71:B7:B8:6D:37:1D 71-B7-B8-6D-37-1D
            Device 51:DA:80:04:EA:0C 51-DA-80-04-EA-0C
            Device 50:2D:26:B8:7F:B1 50-2D-26-B8-7F-B1
            [DEL] Device 50:2D:26:B8:7F:B1 50-2D-26-B8-7F-B1
            [DEL] Device 71:B7:B8:6D:37:1D 71-B7-B8-6D-37-1D
            [DEL] Device 09:CB:9E:AF:84:DF 09-CB-9E-AF-84-DF
            [DEL] Device 51:DA:80:04:EA:0C 51-DA-80-04-EA-0C
            [DEL] Device 4D:C8:A4:58:F8:96 4D-C8-A4-58-F8-96
            [bluetooth]# pair FE:4F:B0:DD:AA:22
            Attempting to pair with FE:4F:B0:DD:AA:22
            [CHG] Device FE:4F:B0:DD:AA:22 Connected: yes
            Failed to pair: org.bluez.Error.AuthenticationFailed
            [CHG] Device FE:4F:B0:DD:AA:22 Connected: no
            • F Fortune95
              @apollon77
              Agent registered
              #155
              @fortune95 Denke diese bluetooth kommandos brauchen root ... also rum das mit sudo auf
                Fortune95
                #156
                @apollon77
                Mit sudo bekomme ich die gleiche Fehlermeldung😞
                • F Fortune95
                  @apollon77
                  #157
                  @fortune95 aber duuuuuuu. In der obigen Anleitung steht nichts von dem Kommando oder?‘
                  Ich meine das du das parallel zum Adapter laufen lassen sollst: „ sudo hcidump -t -x >log.txt“
                  • F Offline
                    Fortune95
                    #158
                    @apollon77
                    hab mich wohl verrannt, hab versucht den treiber des BLE adatpters zu updaten.
                    Jetzt findet bluetoothctl keinen Controller mehr.
                    • F Fortune95
                      @apollon77
                      #159
                      @fortune95 uuups ... was hast Du getan?
                      F Damrak2022D 2 Antworten Letzte Antwort
                        Fortune95
                        #160
                        @apollon77
                        Wie gesagt hatte versucht den Treiber zu updaten... leider war mein letztes Image Backup ein Monat alt..., hab jetzt alles wieder auf Stand und der BLE Adapter ist auch wieder auffindbar.
                        Habe den Adapter über den Admin gestartet und vorab über die Shell den hcidump angeworfen. Im Admin bekam ich beim Versuch das BLE zu identifizieren, die folgende Fehlermeldung:
                        HCI sniffer - Bluetooth packet analyzer ver 5.55
                        device: hci0 snap_len: 1500 filter: 0xffffffffffffffff
                        2022-03-14 20:06:06.432692 < HCI Command: Set Event Mask (0x03|0x0001) plen 8
                            Mask: 0xfffffbff07f8bf3d
                        2022-03-14 20:06:06.433869 > HCI Event: Command Complete (0x0e) plen 4
                            Set Event Mask (0x03|0x0001) ncmd 2
                            status 0x00
                        2022-03-14 20:06:06.433896 < HCI Command: LE Set Event Mask (0x08|0x0001) plen 8
                            mask 0x1f00000000000000 (Reserved)
                        2022-03-14 20:06:06.434835 > HCI Event: Command Complete (0x0e) plen 4
                            LE Set Event Mask (0x08|0x0001) ncmd 2
                            status 0x00
                        2022-03-14 20:06:06.434858 < HCI Command: Read Local Version Information (0x04|0x0001) plen 0
                        2022-03-14 20:06:06.435878 > HCI Event: Command Complete (0x0e) plen 12
                            Read Local Version Information (0x04|0x0001) ncmd 2
                            status 0x00
                            HCI Version: 5.1 (0xa) HCI Revision: 0xb
                            LMP Version: 5.1 (0xa) LMP Subversion: 0x8761
                            Manufacturer: Realtek Semiconductor Corporation (93)
                        2022-03-14 20:06:06.435902 < HCI Command: Write LE Host Supported (0x03|0x006d) plen 2
                          01 00
                        2022-03-14 20:06:06.436832 > HCI Event: Command Complete (0x0e) plen 4
                            Write LE Host Supported (0x03|0x006d) ncmd 2
                            00
                        2022-03-14 20:06:06.436858 < HCI Command: Read LE Host Supported (0x03|0x006c) plen 0
                        2022-03-14 20:06:06.437836 > HCI Event: Command Complete (0x0e) plen 6
                            Read LE Host Supported (0x03|0x006c) ncmd 2
                            00 01 00
                        2022-03-14 20:06:06.437860 < HCI Command: LE Read Buffer Size (0x08|0x0002) plen 0
                        2022-03-14 20:06:06.438834 > HCI Event: Command Complete (0x0e) plen 7
                            LE Read Buffer Size (0x08|0x0002) ncmd 2
                            status 0x00 pktlen 0x00fb maxpkt 0x08
                        2022-03-14 20:06:06.438858 < HCI Command: Read BD ADDR (0x04|0x0009) plen 0
                        2022-03-14 20:06:06.439837 > HCI Event: Command Complete (0x0e) plen 10
                            Read BD ADDR (0x04|0x0009) ncmd 2
                            status 0x00 bdaddr 08:BE:AC:20:8E:F2
                        2022-03-14 20:06:06.442284 < HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2
                            value 0x00 (scanning disabled)
                            filter duplicates 0x01 (enabled)
                        2022-03-14 20:06:06.443833 > HCI Event: Command Complete (0x0e) plen 4
                            LE Set Scan Enable (0x08|0x000c) ncmd 2
                            status 0x00
                        2022-03-14 20:06:06.443859 < HCI Command: LE Set Scan Parameters (0x08|0x000b) plen 7
                            type 0x01 (active)
                            interval 10.000ms window 10.000ms
                            own address: 0x00 (Public) policy: All
                        2022-03-14 20:06:06.444827 > HCI Event: Command Complete (0x0e) plen 4
                            LE Set Scan Parameters (0x08|0x000b) ncmd 2
                            status 0x00
                        2022-03-14 20:06:06.447855 < HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2
                        2022-03-14 20:06:06.448834 > HCI Event: Command Complete (0x0e) plen 4
                            status 0x00
                        2022-03-14 20:06:06.448861 < HCI Command: LE Set Scan Parameters (0x08|0x000b) plen 7
                            type 0x01 (active)
                        • F Fortune95
                          @apollon77
                              status 0x00
                              status 0x00
                              status 0x00
                            01 00
                              00
                              00 01 00
                              status 0x00
                              type 0x01 (active)
                              status 0x00
                              status 0x00
                              type 0x01 (active)
                          #161
                          @fortune95 Hasdt DU passend dazu auch das ausführliche Debug log des Adapters (Also adapter manuell starten mit DEBUG= ....? Idealerweise brauche ich beides Parallel das ich über die Zeitstempel mappen kann ... sonst rate ich wieder nur rum
                            Fortune95
                            #162
                            @apollon77
                            Wie kann ich denn beide Befehle über die Shell zeitgleich starten? Hast du da einen Tipp für mich. Wenn ich einen von beiden Befehle absetze, ist die Shell blockiert und lässt nur mit STRG - C abbrechen.
                            • F Fortune95
                              @apollon77
                              #163
                              @fortune95 Indem du zwei Shell Fenster parallel öffnest? ;-)
                                Fortune95
                                #164
                                @apollon77
                                Manchmal ist es so einfach...
                                Hier die Logs:
                                log.txt
                                2022-03-16 05:17:11.668  - debug: homekit-controller.0 (16117) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                2022-03-16 05:17:11.708  - debug: homekit-controller.0 (16117) Objects client ready ... initialize now
                                2022-03-16 05:17:11.709  - debug: homekit-controller.0 (16117) Objects create System PubSub Client
                                2022-03-16 05:17:11.710  - debug: homekit-controller.0 (16117) Objects create User PubSub Client
                                2022-03-16 05:17:11.733  - debug: homekit-controller.0 (16117) Objects client initialize lua scripts
                                2022-03-16 05:17:11.735  - debug: homekit-controller.0 (16117) Objects connected to redis: 127.0.0.1:9001
                                2022-03-16 05:17:11.749  - debug: homekit-controller.0 (16117) Redis States: Use Redis connection: 127.0.0.1:6379
                                2022-03-16 05:17:11.751  - debug: homekit-controller.0 (16117) States create System PubSub Client
                                2022-03-16 05:17:11.751  - debug: homekit-controller.0 (16117) States create User PubSub Client
                                2022-03-16 05:17:11.754  - debug: homekit-controller.0 (16117) States connected to redis: 127.0.0.1:6379
                                2022-03-16 05:17:11.766  - debug: homekit-controller.0 (16117) Plugin sentry Initialize Plugin (enabled=true)
                                2022-03-16 05:17:11.818  - error: homekit-controller.0 (16117) adapter disabled
                                2022-03-16 05:17:11.866  - info: homekit-controller.0 (16117) starting. Version 0.4.3 (non-npm: Apollon77/ioBroker.homekit-controller#b7c7f7174ee7700864d870c2125c4d00aba85aa5) in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.19.0, js-controller: 4.0.21
                                2022-03-16 05:17:11.936  - debug: homekit-controller.0 (16117) state homekit-controller.0.info.connection changed: false (ack = true)
                                2022-03-16 05:17:11.940  - debug: homekit-controller.0 (16117) Init 1 known devices without discovery ...
                                2022-03-16 05:17:11.940  - debug: homekit-controller.0 (16117) Init BLE-6E:B1:4A:68:AA:BB as known device
                                2022-03-16 05:17:11.940  - info: homekit-controller.0 (16117) BLE-6E:B1:4A:68:AA:BB (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects
                                2022-03-16 05:17:11.941  - debug: homekit-controller.0 (16117) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"6e:b1:4a:68:aa:bb","ACID":10,"GSN":6,"CN":3,"CV":2,"c#":3,"id":"6e:b1:4a:68:aa:bb","ci":10,"availableToPair":true}
                                2022-03-16 05:17:11.952  - debug: homekit-controller.0 (16117) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.info.connectionType changed: BLE (ack = true)
                                2022-03-16 05:17:11.955  - debug: homekit-controller.0 (16117) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.info.id changed: 6e:b1:4a:68:aa:bb (ack = true)
                                2022-03-16 05:17:11.958  - debug: homekit-controller.0 (16117) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.info.connected changed: false (ack = true)
                                2022-03-16 05:17:11.963  - debug: homekit-controller.0 (16117) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.admin.isPaired changed: false (ack = true)
                                2022-03-16 05:17:11.967  - debug: homekit-controller.0 (16117) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.info.lastDiscovered changed: 1647404231941 (ack = true)
                                2022-03-16 05:17:29.918  - debug: homekit-controller.0 (16117) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":119,"ack":false,"time":1647404249917},"_id":67504295})
                                2022-03-16 05:17:29.919  - debug: homekit-controller.0 (16117) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-6E:B1:4A:68:AA:BB","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 5980","discoveredCategory":"Sensor","pairedWithThisInstance":false}]}
                                2022-03-16 05:17:35.645  - debug: homekit-controller.0 (16117) Message identify received: {"command":"identify","message":{"deviceId":"BLE-6E:B1:4A:68:AA:BB"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-6E:B1:4A:68:AA:BB"},"id":120,"ack":false,"time":1647404255644},"_id":67504296})
                                2022-03-16 05:17:35.645  - debug: homekit-controller.0 (16117) Device BLE-6E:B1:4A:68:AA:BB: Identify triggered
                                2022-03-16 05:17:35.646  - debug: homekit-controller.0 (16117) Response to Command identify: {"success":false,"error":"Cannot identify device BLE-6E:B1:4A:68:AA:BB because of error undefined: Cannot read property 'state' of undefined"}
                                ^Ciobroker@iobroker:~$ DEBUG=hap* node /opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js 0 --debug --logs
                                2022-03-16 05:19:05.630  - debug: homekit-controller.0 (16134) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                2022-03-16 05:19:05.650  - debug: homekit-controller.0 (16134) Objects client ready ... initialize now
                                2022-03-16 05:19:05.656  - debug: homekit-controller.0 (16134) Objects create System PubSub Client
                                2022-03-16 05:19:05.657  - debug: homekit-controller.0 (16134) Objects create User PubSub Client
                                2022-03-16 05:19:05.688  - debug: homekit-controller.0 (16134) Objects client initialize lua scripts
                                2022-03-16 05:19:05.690  - debug: homekit-controller.0 (16134) Objects connected to redis: 127.0.0.1:9001
                                2022-03-16 05:19:05.703  - debug: homekit-controller.0 (16134) Redis States: Use Redis connection: 127.0.0.1:6379
                                2022-03-16 05:19:05.705  - debug: homekit-controller.0 (16134) States create System PubSub Client
                                2022-03-16 05:19:05.706  - debug: homekit-controller.0 (16134) States create User PubSub Client
                                2022-03-16 05:19:05.708  - debug: homekit-controller.0 (16134) States connected to redis: 127.0.0.1:6379
                                2022-03-16 05:19:05.720  - debug: homekit-controller.0 (16134) Plugin sentry Initialize Plugin (enabled=true)
                                2022-03-16 05:19:05.770  - error: homekit-controller.0 (16134) adapter disabled
                                2022-03-16 05:19:05.824  - info: homekit-controller.0 (16134) starting. Version 0.4.3 (non-npm: Apollon77/ioBroker.homekit-controller#b7c7f7174ee7700864d870c2125c4d00aba85aa5) in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.19.0, js-controller: 4.0.21
                                2022-03-16 05:19:05.893  - debug: homekit-controller.0 (16134) state homekit-controller.0.info.connection changed: false (ack = true)
                                2022-03-16 05:19:05.897  - debug: homekit-controller.0 (16134) Init 1 known devices without discovery ...
                                2022-03-16 05:19:05.897  - debug: homekit-controller.0 (16134) Init BLE-6E:B1:4A:68:AA:BB as known device
                                2022-03-16 05:19:05.898  - info: homekit-controller.0 (16134) BLE-6E:B1:4A:68:AA:BB (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects
                                2022-03-16 05:19:05.899  - debug: homekit-controller.0 (16134) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"6e:b1:4a:68:aa:bb","ACID":10,"GSN":6,"CN":3,"CV":2,"c#":3,"id":"6e:b1:4a:68:aa:bb","ci":10,"availableToPair":true}
                                2022-03-16 05:19:05.909  - debug: homekit-controller.0 (16134) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.info.connectionType changed: BLE (ack = true)
                                2022-03-16 05:19:05.913  - debug: homekit-controller.0 (16134) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.info.id changed: 6e:b1:4a:68:aa:bb (ack = true)
                                2022-03-16 05:19:05.915  - debug: homekit-controller.0 (16134) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.info.connected changed: false (ack = true)
                                2022-03-16 05:19:05.920  - debug: homekit-controller.0 (16134) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.admin.isPaired changed: false (ack = true)
                                2022-03-16 05:19:05.923  - debug: homekit-controller.0 (16134) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.info.lastDiscovered changed: 1647404345899 (ack = true)
                                2022-03-16 05:19:30.853  - debug: homekit-controller.0 (16134) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":121,"ack":false,"time":1647404370852},"_id":67504297})
                                2022-03-16 05:19:30.853  - debug: homekit-controller.0 (16134) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-6E:B1:4A:68:AA:BB","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 5980","discoveredCategory":"Sensor","pairedWithThisInstance":false}]}
                                2022-03-16 05:19:32.854  - debug: homekit-controller.0 (16134) Message identify received: {"command":"identify","message":{"deviceId":"BLE-6E:B1:4A:68:AA:BB"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-6E:B1:4A:68:AA:BB"},"id":122,"ack":false,"time":1647404372853},"_id":67504298})
                                2022-03-16 05:19:32.854  - debug: homekit-controller.0 (16134) Device BLE-6E:B1:4A:68:AA:BB: Identify triggered
                                2022-03-16 05:19:32.855  - debug: homekit-controller.0 (16134) Response to Command identify: {"success":false,"error":"Cannot identify device BLE-6E:B1:4A:68:AA:BB because of error undefined: Cannot read property 'state' of undefined"}
                                • F Fortune95
                                  @apollon77
                                  Hier die Logs:
                                  log.txt
                                  #165
                                  @fortune95 Ich glaube jetzt warste zu schnell ... der Adapter hatte das Gerät noch nicht mal gefunden als Du schon getriggert hast ... damit gaaaaanz anderer Fehler (aber fixe ich) ... Also gibt dem Adapter mal Zeit bis er auch BLE discovered hat :-)
                                    Fortune95
                                    #166
                                    @apollon77
                                    OK, also nochmal...
                                    Nachdem ich den Adapter über die Shell gestartet hatte passierte im Log erstmal gar nichts.
                                    Darufhin habe ich mal den Knopf am Eve gedrückt um ihn aufzuwecken. Wenn ich es richtig interpretiere hat er sich dann auch im Adapter kurz gemeldet.
                                    Beim nachfolgenden Identifizieren kam jedoch prompt die bekannte Fehlermeldung.
                                    2022-03-17 06:11:29.897  - debug: homekit-controller.0 (23910) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                    2022-03-17 06:11:29.922  - debug: homekit-controller.0 (23910) Objects client ready ... initialize now
                                    2022-03-17 06:11:29.923  - debug: homekit-controller.0 (23910) Objects create System PubSub Client
                                    2022-03-17 06:11:29.924  - debug: homekit-controller.0 (23910) Objects create User PubSub Client
                                    2022-03-17 06:11:29.957  - debug: homekit-controller.0 (23910) Objects client initialize lua scripts
                                    2022-03-17 06:11:29.959  - debug: homekit-controller.0 (23910) Objects connected to redis: 127.0.0.1:9001
                                    2022-03-17 06:11:29.975  - debug: homekit-controller.0 (23910) Redis States: Use Redis connection: 127.0.0.1:6379
                                    2022-03-17 06:11:29.977  - debug: homekit-controller.0 (23910) States create System PubSub Client
                                    2022-03-17 06:11:29.978  - debug: homekit-controller.0 (23910) States create User PubSub Client
                                    2022-03-17 06:11:29.980  - debug: homekit-controller.0 (23910) States connected to redis: 127.0.0.1:6379
                                    2022-03-17 06:11:29.991  - debug: homekit-controller.0 (23910) Plugin sentry Initialize Plugin (enabled=true)
                                    2022-03-17 06:11:30.043  - error: homekit-controller.0 (23910) adapter disabled
                                    2022-03-17 06:11:30.085  - info: homekit-controller.0 (23910) starting. Version 0.4.3 (non-npm: Apollon77/ioBroker.homekit-controller#b7c7f7174ee7700864d870c2125c4d00aba85aa5) in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.19.0, js-controller: 4.0.21
                                    2022-03-17 06:11:30.160  - debug: homekit-controller.0 (23910) state homekit-controller.0.info.connection changed: false (ack = true)
                                    2022-03-17 06:11:30.164  - debug: homekit-controller.0 (23910) Init 1 known devices without discovery ...
                                    2022-03-17 06:11:30.164  - debug: homekit-controller.0 (23910) Init BLE-6E:B1:4A:68:AA:BB as known device
                                    2022-03-17 06:11:30.165  - info: homekit-controller.0 (23910) BLE-6E:B1:4A:68:AA:BB (Eve Degree 5980) found without pairing data but available for pairing: Create basic objects
                                    2022-03-17 06:11:30.165  - debug: homekit-controller.0 (23910) Service: {"name":"Eve Degree 5980","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"6e:b1:4a:68:aa:bb","ACID":10,"GSN":6,"CN":3,"CV":2,"c#":3,"id":"6e:b1:4a:68:aa:bb","ci":10,"availableToPair":true}
                                    2022-03-17 06:11:30.174  - debug: homekit-controller.0 (23910) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.info.connectionType changed: BLE (ack = true)
                                    2022-03-17 06:11:30.177  - debug: homekit-controller.0 (23910) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.info.id changed: 6e:b1:4a:68:aa:bb (ack = true)
                                    2022-03-17 06:11:30.181  - debug: homekit-controller.0 (23910) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.info.connected changed: false (ack = true)
                                    2022-03-17 06:11:30.186  - debug: homekit-controller.0 (23910) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.admin.isPaired changed: false (ack = true)
                                    2022-03-17 06:11:30.190  - debug: homekit-controller.0 (23910) state homekit-controller.0.BLE-6E:B1:4A:68:AA:BB.info.lastDiscovered changed: 1647493890166 (ack = true)
                                    2022-03-17 06:14:23.793  - debug: homekit-controller.0 (23910) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":169,"ack":false,"time":1647494063792},"_id":67504347})
                                    2022-03-17 06:14:23.794  - debug: homekit-controller.0 (23910) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-6E:B1:4A:68:AA:BB","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 5980","discoveredCategory":"Sensor","pairedWithThisInstance":false}]}
                                    2022-03-17 06:15:33.249  - debug: homekit-controller.0 (23910) Message identify received: {"command":"identify","message":{"deviceId":"BLE-6E:B1:4A:68:AA:BB"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-6E:B1:4A:68:AA:BB"},"id":170,"ack":false,"time":1647494133248},"_id":67504348})
                                    2022-03-17 06:15:33.249  - debug: homekit-controller.0 (23910) Device BLE-6E:B1:4A:68:AA:BB: Identify triggered
                                    2022-03-17 06:15:33.250  - debug: homekit-controller.0 (23910) Response to Command identify: {"success":false,"error":"Cannot identify device BLE-6E:B1:4A:68:AA:BB because of error undefined: Cannot read property 'state' of undefined"}
                                    Im hcidump gibt es aber keinen Eintrag zu dem Zeitpunkt wo ich den Eve geweckt hatte?
                                    log.txt
                                      MartyBr
                                      #167
                                      @apollon77 Ich habe ein Schiebetür-Antrieb von Nice. Mit dem IT4WIFI Adapter ist das Teil HomeKit fähig. Ich konnte es erfolgreich mit dem HomeKit-Controller (Version 0.4.3) pairen.
                                      Die Statusmeldungen werden auch direkt angezeigt.
                                        "type": "state",
                                        "common": {
                                          "name": "",
                                          "read": true,
                                          "write": false,
                                          "type": "number",
                                          "min": 0,
                                          "max": 4,
                                          "step": 1,
                                          "role": "value",
                                          "states": {
                                            "0": "Open",
                                            "1": "Closed",
                                            "2": "Opening",
                                            "3": "Closing",
                                            "4": "Stopped"
                                        "native": {
                                          "iid": 10,
                                          "type": "0000000E-0000-1000-8000-0026BB765291",
                                          "perms": [
                                            "pr",
                                            "ev"
                                          "format": "uint8",
                                          "minValue": 0,
                                          "maxValue": 4,
                                          "minStep": 1,
                                          "aid": 1,
                                          "serviceUuid": "00000041-0000-1000-8000-0026BB765291"
                                        "from": "system.adapter.homekit-controller.0",
                                        "user": "system.user.admin",
                                        "ts": 1649497768186,
                                        "_id": "homekit-controller.0.IP-60:08:AA:24:96:AA.1.garage-door-opener-2.door-state-current",
                                        "acl": {
                                          "object": 1636,
                                          "state": 1636,
                                          "owner": "system.user.admin",
                                      Ich kann das Gerät leider nicht steuern. Sowohl über den Admin als auch per Test-Script gibt es keine Reaktion. Er zeigt dann im Datenpunkt den gewünschten Status an, aber der Motor reagiert überhaupt nicht.
                                      Hier das Test-Script:
                                      setState("homekit-controller.0.IP-60:08:AA:24:96:AA.1.garage-door-opener-2.door-state-current",2,true);
                                      Hier alle Datenpunkte, die der Adapter liefert:
                                      Ich bin mit meinem Latein jetzt am Ende. Kann es sein, dass dieses Gerät keinen DP zu steuern hat?
                                      Ich hatte vor dem Pairen das Gerät in Apple HomeKit integriert und konnte es ohne Probleme steuern.
                                      Martin
                                      Homematic und Homematic IP
                                      • M MartyBr
                                          "type": "state",
                                          "common": {
                                            "name": "",
                                            "read": true,
                                            "write": false,
                                            "type": "number",
                                            "min": 0,
                                            "max": 4,
                                            "step": 1,
                                            "role": "value",
                                            "states": {
                                              "0": "Open",
                                              "1": "Closed",
                                              "2": "Opening",
                                              "3": "Closing",
                                              "4": "Stopped"
                                          "native": {
                                            "iid": 10,
                                            "perms": [
                                              "pr",
                                              "ev"
                                            "format": "uint8",
                                            "minValue": 0,
                                            "maxValue": 4,
                                            "minStep": 1,
                                            "aid": 1,
                                          "acl": {
                                            "object": 1636,
                                            "state": 1636,
                                        #168
                                        @martybr ALso ich tippe das "current" den aktuellen Status beschreibt und du zum steuern "target" (Zielzustand) nutzen musst :-)
                                        Wie Du siehst ist "current" auch nicht beschreibbar.
                                        Versuch doch das mal :-)
                                          MartyBr
                                          #169
                                          @apollon77 Das funktioniert leider nicht. "target" kennt true/false.
                                          Ich habe beide Werte per Script und auch per Admin gesetzt. Leide keine Reaktion.
                                          Martin
