  4. Homebridge-Adapter: Funktionierende Plugins und Beispiele
    6.3k
238 Beiträge 62 Kommentatoren 81.6k Aufrufe 44 Beobachtet
  • A AKuehnemann73
    @apollon77
    ham.0
    	2021-12-20 22:19:31.858	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    ham.0
    	2021-12-20 22:19:31.856	info	terminating
    ham.0
    	2021-12-20 22:19:31.849	info	cleaned everything up...
    ham.0
    	2021-12-20 22:19:31.841	error	Cannot read property 'status' of undefined
    ham.0
    	2021-12-20 22:19:31.841	error	TypeError: Cannot read property 'status' of undefined at LaundrifyApi.register (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-laundrify-official/src/helper/LaundrifyApi.ts:165:21) at processTicksAndRejections (internal/process/task_queues.js:95:5) at /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-laundrify-official/src/helper/LaundrifyApi.ts:56:38
    ham.0
    	2021-12-20 22:19:31.805	error	unhandled promise rejection: Cannot read property 'status' of undefined
    ham.0
    	2021-12-20 22:19:31.804	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    ham.0
    	2021-12-20 22:19:29.166	info	All Libraries installed/updated
    ham.0
    	2021-12-20 22:19:29.158	info	Install/Update homebridge-laundrify-official@1.2.0
    ham.0
    	2021-12-20 22:19:29.155	info	Install/Update the following Libraries: homebridge-laundrify-official@1.2.0
    ham.0
    	2021-12-20 22:19:29.105	info	starting. Version 4.0.2 in /opt/iobroker/node_modules/iobroker.ham, node: v14.18.1, js-controller: 3.3.21
    ham.0
    	2021-12-20 22:18:56.069	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    ham.0
    	2021-12-20 22:18:56.067	info	terminating
    ham.0
    	2021-12-20 22:18:56.062	info	cleaned everything up...
    ham.0
    	2021-12-20 22:18:56.041	error	Cannot read property 'status' of undefined
    ham.0
    	2021-12-20 22:18:56.040	error	TypeError: Cannot read property 'status' of undefined at LaundrifyApi.register (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-laundrify-official/src/helper/LaundrifyApi.ts:165:21) at processTicksAndRejections (internal/process/task_queues.js:95:5) at /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-laundrify-official/src/helper/LaundrifyApi.ts:56:38
    ham.0
    	2021-12-20 22:18:56.010	error	unhandled promise rejection: Cannot read property 'status' of undefined
    ham.0
    	2021-12-20 22:18:56.008	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    ham.0
    	2021-12-20 22:18:53.417	info	All Libraries installed/updated
    ham.0
    	2021-12-20 22:18:53.415	info	Install/Update homebridge-laundrify-official@1.2.0
    ham.0
    	2021-12-20 22:18:53.413	info	Install/Update the following Libraries: homebridge-laundrify-official@1.2.0
    ham.0
    	2021-12-20 22:18:53.371	info	starting. Version 4.0.2 in /opt/iobroker/node_modules/iobroker.ham, node: v14.18.1, js-controller: 3.3.21
    ham.0
    	2021-12-20 22:18:46.811	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    ham.0
    	2021-12-20 22:18:46.808	info	terminating
    ham.0
    	2021-12-20 22:18:46.802	info	cleaned everything up...
    ham.0
    	2021-12-20 22:18:46.798	info	Got terminate signal TERMINATE_YOURSELF
    Konfig:
    "bridge": {
    "name": "Homebridge 365F",
    "username": "0E:62:A1:2D:36:5F",
    "port": 51559,
    "pin": "736-16-448"
    "accessories": [],
    "platforms": [
    "name": "Config",
    "port": 8581,
    "platform": "config"
    "authCode": "XXX-XXX",
    "pollInterval": 60,
    "invertStatus": true,
    "platform": "laundrify"
    #182
    @akuehnemann73 sagte in Homebridge-Adapter: Funktionierende Plugins und Beispiele:
    Dann solltest Du dich mal da hin wenden ... Ich denke das der Fehler hier liegt https://github.com/laundrify/homebridge-laundrify-official/blob/master/src/helper/LaundrifyApi.ts#L158 ... typischer Zugriff auf pot nicht initialisierte Variablen
      TT-Tom
      #183
      @apollon77
      Hallo ich habe das Plugin Homebridge-Calendar eingebunden. Ich nutze es, um meine Heizung nach meinen Schichtplan zu steuern.
      Version 0.4.0 HAM 4.0.2
            "platform": "Calendar",
            "calendars": [
                "name": "Cal 1",
                "url": "webcal://",
                "pollingInterval": 5,
                "offset": "-8h",
                "sensors": [
                  "Sensor 1",
                  "Sensor 2"
      PS: vielleicht könnte man diese Funktion in iCal einbinden.
      Gruß Tom
      Gruß Tom
      Public Transport
      NSPanel Adapter Wiki
      • T TT-Tom
        @apollon77
              "calendars": [
                  "name": "Cal 1",
                  "url": "webcal://",
                  "offset": "-8h",
                  "sensors": [
                    "Sensor 1",
                    "Sensor 2"
        Gruß Tom
        #184
        @tt-tom wie meinen? iCal kann auf Text reagieren und States passend setzen. Der calendar adapter kann sowas ähnliches nur ohne iCal Kalender… aber ich weiß nicht mal genau was du meinst
        • apollon77A apollon77
          TT-Tom
          #185
          @apollon77 der Adapter bildet ein SensorContact nach und setzt zur Startzeit des Termins ein State auf 1 / true und beim Beenden wieder zurück. Der Termin wird genauso wie bei iCal gefiltert. Zusätzlich kann man zur Startzeit ein Offset setzen, was die Startzeit plus / minus verschiebt.
          Ich kenne diesen Adapter von der Homebridge noch und konnte es in iCal nicht einstellen. Kann man das mit iCal auch bauen?
          Gruß Tom
          Gruß Tom
          Public Transport
          • T TT-Tom
            Gruß Tom
            #186
            @tt-tom ohne den Offset kann das iCal auch. Heißt dort „Events“. Du definierst einen Text der in dem termin vorkommt und dann geht ein state auf true wenn Stein termin läuft und auf false wenn nicht mehr.
              TT-Tom
              #187
              @apollon77
              Okay danke für die Info. Ich benötige aber diesen Offset für die Steuerung meiner Badheizung. Frühdienst beginnt um x Uhr, plus offset geht meine Heizung an.
              Kannst du das als Option in iCal einbauen?
              Gruß Tom
              Public Transport
              • T TT-Tom
                @apollon77
                #188
                @tt-tom Mach ein Feature Request ... keine Ahnung wann jemand dafür zeit findet ... das ist recht schwierig dafür wie ical arbeitet
                  TT-Tom
                  #189
                  @apollon77 okay muss ich in GitHub machen, oder? Benötige ich dort dann ein Account oder kann man das ohne machen?
                  Gruß Tom
                  Public Transport
                  • T TT-Tom
                    #190
                    @tt-tom Ja bitte im Github. Und ja brauchst einen Account (Email/Passwort) ... geht fix :-)
                      TT-Tom
                      #191
                      Hallo @apollon77 habe Account angelegt und Feature Request angelegt. Da mein Englisch nicht das beste ist, hoffe ich es ist richtig platziert.
                      PS: my englisch is not the yellow from the egg
                      Gruß Tom
                      Gruß Tom
                      Public Transport
                      • T TT-Tom
                        Gruß Tom
                        #192
                        @tt-tom Koi Stress, Doitsch geht auch
                        • iPhilBlnI Offline
                          iPhilBlnI Offline
                          iPhilBln
                          #193
                          Gibt es hier jemanden, der das "homebridge-xiaomi-fan" Plugin erfolgreich zum laufen bekommen hat?
                          Bekomme zwar alle Datenpunkte rein und rudimentäres Ein- / Ausschalten funktioniert auch, jedoch lässt sich die Geschwindigkeit nicht verändern. Der Adapter übermittelt nicht den Wert, sodass er beim nächsten Polling auf den Ursprungswert zurückspringt. Aus dem Log ("Debug") werde ich nicht so wirklich schlau, da auch keine Fehler angezeigt werden. Der Adapter funktioniert in meiner externen Homebridge installation aber einwandfrei.
                          ham.1
                          2022-08-07 15:52:33.620	debug	lookup id: Standventilator.Standventilator.Rotation-Speed
                          ham.1
                          2022-08-07 15:52:33.620	info	stateChange ham.1.Standventilator.Standventilator.Rotation-Speed {"val":36,"ack":true,"ts":1659880353615,"q":0,"from":"system.adapter.ham.1","user":"system.user.admin","lc":1659880353615}
                          ham.1
                          2022-08-07 15:52:33.619	debug	lookup id: Standventilator.Standventilator.Active
                          ham.1
                          2022-08-07 15:52:33.619	info	stateChange ham.1.Standventilator.Standventilator.Active {"val":1,"ack":true,"ts":1659880353615,"q":0,"from":"system.adapter.ham.1","user":"system.user.admin","lc":1659880118500}
                          ham.1
                          2022-08-07 15:52:29.533	debug	lookup id: Standventilator.Standventilator.Rotation-Speed
                          ham.1
                          2022-08-07 15:52:29.532	info	stateChange ham.1.Standventilator.Standventilator.Rotation-Speed {"val":30,"ack":true,"ts":1659880349530,"q":0,"from":"system.adapter.ham.1","user":"system.user.admin","lc":1659880349524}
                          ham.1
                          2022-08-07 15:52:29.526	debug	ack is not set!
                          ham.1
                          2022-08-07 15:52:29.526	debug	lookup id: Standventilator.Standventilator.Rotation-Speed
                          ham.1
                          2022-08-07 15:52:29.526	info	stateChange ham.1.Standventilator.Standventilator.Rotation-Speed {"val":30,"ack":false,"ts":1659880349524,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1659880349524}
                          • iPhilBlnI iPhilBln
                            ham.1
                            ham.1
                            ham.1
                            ham.1
                            ham.1
                            ham.1
                            ham.1
                            ham.1
                            ham.1
                            #194
                            @iphilbln Also ddie Infos sagen jetzt was? :-)
                            Ich sehe das du den Wert 30 setzt. Der wird dann bestätigt und active wird auf 1 gesetzt und direkt drauf kommt die 36 ... Das ist falsch? Oder was sollte es sein? Sollte es die 30sein?
                            Setze Loglevel bitte mal auf Silly und poste das Log von so einer Aktion damit bitte
                            iPhilBlnI 1 Antwort Letzte Antwort
                              iPhilBlnI Offline
                              iPhilBlnI Offline
                              iPhilBln
                              schrieb am zuletzt editiert von iPhilBln
                              #195
                              @apollon77 Ja das habe ich mich auch gefragt um ehrlich zu sein. Hab es jetzt nochmal auf silly gesetzt anstatt debug und direkt mit der Konsole für den Adapter gefiltert. Sprengt nur leider die Anzahl der Zeichen hier. Reicht es dir als log file?
                              ham1.log
                              Im Prinzip hast du es richtig verstanden. Der Wert der Lüftergeschwindigkeit war 36. Diesen wollte ich über den DP auf 30 ändern aber die Änderung wird nicht im Lüfter übernommen. Über die Homekit App kann ich den Wert aber problemlos setzen.
                              Im jetzigen Versuch den Weert zu ändern wollte ich den Wert 1 auf 50 setzen.
                                ham1.log
                                #196
                                @iphilbln Und um sicherzugehen? Die Ham version ist die aktuellste 5.0.2 aus Beta? Oder noch ne 4? Wenn 4 dann bitte mit 5 versuchen bevor ich Geister suche. Musst dann aber ggf auch homebridge updaten und plugin oder so. Siehe Readme
                                • iPhilBlnI Offline
                                  iPhilBlnI Offline
                                  iPhilBln
                                  #197
                                  @apollon77 hab es jetzt mal auf beta gestellt und die 5.0.2 installiert. Unter changelog zu 5.0.0 steht, dass homebridge v1.4 mindestens benötigt wird und die Plugins geupdatet werden sollen. Passiert das Homebridge Update für den Wrapper Modus auch automatisch? Laut Ausgabe sollte dem so sein oder? Die Checkbox für die Plugin Updates hatte ich aktiviert in den Einstellungen der Instanz und neugestartet.
                                  iobroker@iobroker:/opt/iobroker/node_modules/iobroker.ham/node_modules$ sudo npm outdated
                                  Package                    Current  Wanted  Latest  Location
                                  homebridge-plugin-wrapper  MISSING   2.2.1   2.2.1  iobroker.ham
                                  string-argv                MISSING   0.3.1   0.3.1  iobroker.ham
                                  homebridge                   1.4.1   1.5.0   1.5.0  iobroker.ham
                                  iobroker@iobroker:/opt/iobroker/node_modules/iobroker.ham/node_modules$ npm update
                                  iobroker@iobroker:/opt/iobroker/node_modules/iobroker.ham/node_modules$ npm outdated
                                  Leider funktioniert jetzt nicht mal mehr simples Ein- / Ausschalten. Ich hab dir nochmal ein Log vom Start des Adapter bis zum ändern von Datenpunkten erstellt. Es wird aktuell wie gesagt gar keine Änderung mehr übernommen. Hoffe es hilft dir.
                                  ham1.log
                                    ham1.log
                                    #198
                                    @iphilbln naja, KEINER hat gesagt du sollst irgendwas mit npm befehlen anstellen ... wenn Du jetzt homebriddge 1.5.0 installiert hast dann geht natürlich ggf nix mehr weil ham auf homebridge 1.4 aufsetzt. Also Adapter komplett entfernen und neu installieren bitte das du das mal fixt.
                                    Und ehrlich: Ich suche auch im Log gerade nichts weil homebridge 1.5 falsch ist.
                                    Meine Aussage war darauf bezogen das Du schauen musst ob ggf neuere Versionen deiner genutzten Plugins nötig sind wegen der 1.4...
                                    • iPhilBlnI Offline
                                      iPhilBlnI Offline
                                      iPhilBln
                                      #199
                                      @apollon77 da hab ich dich in der Tat falsch verstanden. Naja alle guten Dinge sind 3. Ich hoffe nun passt alles.
                                      Hab jetzt nochmal alles runtergeworfen (beim Entfernen des Adapters die Checkbox 'custom daten löschen' aktiviert) und frisch v5.0.2 sowie das xiaomi-fan Plugin installiert. Gebracht hat es leider nichts. Die Änderungen in den Datenpunkten werden nach wie vor nicht übernommen. Eher im Gegenteil, jetzt wird außerdem nicht für jeden Parameter in der Modul config ein Datenpunk erstellt.
                                      Bsp.:
                                      Plugin Config: "sleepModeControl": true, -> gleiche config wie weiter oben
                                      Datenpunkte:
                                      aktualisiertes Log vom Start bis zur Änderung von Datenpunkten: ham.log
                                        Bsp.:
                                        Datenpunkte:
                                        #200
                                        @iphilbln Tja, da müssen wir reinschauen ...
                                        Am besten setze mal den deep debug mode in den settings ... https://github.com/merdok/homebridge-xiaomi-fan#troubleshooting
                                        Dann bitte nochmal ein Log
                                          iPhilBlnI Offline
                                          iPhilBlnI Offline
                                          iPhilBln
                                          #201
                                          @apollon77 gesagt, getan. Hier das neue log : ham.log
