  3. Einsteigerfragen
  4. Einbindung elsner P03/ Modbus Wetterstation
    5.7k
18 Beiträge 2 Kommentatoren 2.1k Aufrufe 2 Beobachtet
  • wendy2702W wendy2702
    @sebastianiv Dann stelle den Adapter mal auf "Debug" und poste das log hier als Text in Code Tags </>
    SebastianIV
    @wendy2702 ```
    Hallo wendy2702, anbei das Log file. So wie es aussieht, meldet sich die Wetterstation nicht??
    code_text
    2022-03-01 18:12:46.942 - warn: modbus.3 (22629) Error: undefined
    2022-03-01 18:12:46.943 - error: modbus.3 (22629) Request timed out.
    2022-03-01 18:12:46.944 - warn: modbus.3 (22629) Poll error count: 10 code: {"err":"timeout","timeout":5000}
    2022-03-01 18:12:47.944 - info: modbus.3 (22629) Disconnected from slave
    2022-03-01 18:13:47.947 - info: modbus.3 (22629) Connected to slave
    2022-03-01 18:13:52.950 - warn: modbus.3 (22629) Error: undefined
    2022-03-01 18:13:52.951 - error: modbus.3 (22629) Request timed out.
    2022-03-01 18:13:52.952 - warn: modbus.3 (22629) Poll error count: 11 code: {"err":"timeout","timeout":5000}
    2022-03-01 18:13:53.952 - info: modbus.3 (22629) Disconnected from slave
    2022-03-01 18:14:53.956 - info: modbus.3 (22629) Connected to slave
    2022-03-01 18:14:58.960 - warn: modbus.3 (22629) Error: undefined
    2022-03-01 18:14:58.960 - error: modbus.3 (22629) Request timed out.
    2022-03-01 18:14:58.961 - warn: modbus.3 (22629) Poll error count: 12 code: {"err":"timeout","timeout":5000}
    2022-03-01 18:14:59.962 - info: modbus.3 (22629) Disconnected from slave
    2022-03-01 18:15:59.966 - info: modbus.3 (22629) Connected to slave
    2022-03-01 18:16:04.968 - warn: modbus.3 (22629) Error: undefined
    2022-03-01 18:16:04.969 - error: modbus.3 (22629) Request timed out.
    2022-03-01 18:16:04.970 - warn: modbus.3 (22629) Poll error count: 13 code: {"err":"timeout","timeout":5000}
    2022-03-01 18:16:04.971 - error: modbus.3 (22629) Reconnect did not help, restart adapter
    2022-03-01 18:16:04.975 - info: modbus.3 (22629) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-03-01 18:16:05.600 - info: host.raspberrypi instance system.adapter.modbus.3 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2022-03-01 18:16:05.605 - info: host.raspberrypi Restart adapter system.adapter.modbus.3 because enabled
    2022-03-01 18:16:06.672 - info: host.raspberrypi instance system.adapter.modbus.3 started with pid 22729
    2022-03-01 18:16:08.297 - info: modbus.3 (22729) starting. Version 3.4.17 in /opt/iobroker/node_modules/iobroker.modbus, node: v14.18.3, js-controller: 3.3.22
    2022-03-01 18:16:08.703 - info: modbus.3 (22729) Connected to slave
    2022-03-01 18:16:13.714 - warn: modbus.3 (22729) Error: undefined
    2022-03-01 18:16:13.715 - error: modbus.3 (22729) Request timed out.
    2022-03-01 18:16:13.716 - warn: modbus.3 (22729) Poll error count: 1 code: {"err":"timeout","timeout":5000}
    2022-03-01 18:16:14.725 - info: modbus.3 (22729) Disconnected from slave
    2022-03-01 18:16:35.365 - info: host.raspberrypi stopInstance system.adapter.modbus.3 (force=false, process=true)
    2022-03-01 18:16:35.383 - info: host.raspberrypi stopInstance system.adapter.modbus.3 send kill signal
    2022-03-01 18:16:35.383 - info: modbus.3 (22729) Got terminate signal TERMINATE_YOURSELF
    2022-03-01 18:16:35.395 - info: modbus.3 (22729) terminating
    2022-03-01 18:16:35.398 - info: modbus.3 (22729) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-03-01 18:16:35.969 - info: host.raspberrypi instance system.adapter.modbus.3 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-03-01 18:16:38.501 - info: host.raspberrypi instance system.adapter.modbus.3 started with pid 22744
    2022-03-01 18:16:39.655 - debug: modbus.3 (22744) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2022-03-01 18:16:39.704 - debug: modbus.3 (22744) Objects client ready ... initialize now
    2022-03-01 18:16:39.707 - debug: modbus.3 (22744) Objects create System PubSub Client
    2022-03-01 18:16:39.708 - debug: modbus.3 (22744) Objects create User PubSub Client
    2022-03-01 18:16:39.710 - debug: modbus.3 (22744) Objects client initialize lua scripts
    2022-03-01 18:16:39.723 - debug: modbus.3 (22744) Objects connected to redis: 127.0.0.1:9001
    2022-03-01 18:16:39.733 - debug: modbus.3 (22744) objectDB connected
    2022-03-01 18:16:39.735 - debug: modbus.3 (22744) Redis States: Use Redis connection: 127.0.0.1:9000
    2022-03-01 18:16:39.743 - debug: modbus.3 (22744) States create System PubSub Client
    2022-03-01 18:16:39.745 - debug: modbus.3 (22744) States create User PubSub Client
    2022-03-01 18:16:39.752 - debug: modbus.3 (22744) States connected to redis: 127.0.0.1:9000
    2022-03-01 18:16:39.754 - debug: modbus.3 (22744) statesDB connected
    2022-03-01 18:16:39.959 - debug: modbus.3 (22744) Plugin sentry Initialize Plugin (enabled=true)
    2022-03-01 18:16:40.203 - info: modbus.3 (22744) starting. Version 3.4.17 in /opt/iobroker/node_modules/iobroker.modbus, node: v14.18.3, js-controller: 3.3.22
    2022-03-01 18:16:40.507 - debug: modbus.3 (22744) Initialize Objects for disInputs: []
    2022-03-01 18:16:40.508 - debug: modbus.3 (22744) Initialize Objects for coils: []
    2022-03-01 18:16:40.509 - debug: modbus.3 (22744) Initialize Objects for inputRegs: []
    2022-03-01 18:16:40.509 - debug: modbus.3 (22744) Initialize Objects for holdingRegs: [{"_address":"40003","name":"Temp","description":"Außentemperatur","unit":"C","type":"int8le","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":2,"deviceId":1,"id":"holdingRegisters.40003_Temp"}]
    2022-03-01 18:16:40.510 - debug: modbus.3 (22744) Add holdingRegisters.40003_Temp: {"_id":"holdingRegisters.40003_Temp","type":"state","common":{"name":"Außentemperatur","role":"level","type":"number","read":true,"write":true,"def":0,"unit":"C"},"native":{"regType":"holdingRegs","address":2,"deviceId":1,"type":"int8le","len":1,"offset":0,"factor":1,"poll":true}}
    2022-03-01 18:16:40.794 - debug: modbus.3 (22744) connect to serial /dev/ttyAMA0 with 19200
    2022-03-01 18:16:40.802 - info: modbus.3 (22744) Connected to slave
    2022-03-01 18:16:40.803 - debug: modbus.3 (22744) [DevID_1] Poll start ---------------------
    2022-03-01 18:16:40.806 - debug: modbus.3 (22744) Initialization of scale factors done!
    2022-03-01 18:16:40.806 - debug: modbus.3 (22744) [DevID_1/holdingRegs] Poll address 2 - 1 registers
    2022-03-01 18:16:45.818 - warn: modbus.3 (22744) Error: undefined
    2022-03-01 18:16:45.819 - error: modbus.3 (22744) Request timed out.
    2022-03-01 18:16:45.820 - warn: modbus.3 (22744) Poll error count: 1 code: {"err":"timeout","timeout":5000}
    2022-03-01 18:16:46.822 - info: modbus.3 (22744) Disconnected from slave
    2022-03-01 18:16:46.827 - debug: modbus.3 (22744) Clearing timeout of the current request.
    2022-03-01 18:16:46.828 - debug: modbus.3 (22744) Cleaning up request fifo.
    2022-03-01 18:17:46.825 - debug: modbus.3 (22744) connect to serial /dev/ttyAMA0 with 19200
    2022-03-01 18:17:46.833 - info: modbus.3 (22744) Connected to slave
    2022-03-01 18:17:46.835 - debug: modbus.3 (22744) [DevID_1] Poll start ---------------------
    2022-03-01 18:17:46.837 - debug: modbus.3 (22744) [DevID_1/holdingRegs] Poll address 2 - 1 registers
    2022-03-01 18:17:51.841 - warn: modbus.3 (22744) Error: undefined
    2022-03-01 18:17:51.843 - error: modbus.3 (22744) Request timed out.
    2022-03-01 18:17:51.845 - warn: modbus.3 (22744) Poll error count: 2 code: {"err":"timeout","timeout":5000}
    2022-03-01 18:17:52.844 - info: modbus.3 (22744) Disconnected from slave
    2022-03-01 18:17:52.847 - debug: modbus.3 (22744) Clearing timeout of the current request.
    2022-03-01 18:17:52.848 - debug: modbus.3 (22744) Cleaning up request fifo.
    2022-03-01 18:18:52.847 - debug: modbus.3 (22744) connect to serial /dev/ttyAMA0 with 19200
    2022-03-01 18:18:52.851 - info: modbus.3 (22744) Connected to slave
    2022-03-01 18:18:52.852 - debug: modbus.3 (22744) [DevID_1] Poll start ---------------------
    2022-03-01 18:18:52.854 - debug: modbus.3 (22744) [DevID_1/holdingRegs] Poll address 2 - 1 registers
    2022-03-01 18:18:57.857 - warn: modbus.3 (22744) Error: undefined
    2022-03-01 18:18:57.858 - error: modbus.3 (22744) Request timed out.
    2022-03-01 18:18:57.860 - warn: modbus.3 (22744) Poll error count: 3 code: {"err":"timeout","timeout":5000}
    2022-03-01 18:18:58.860 - info: modbus.3 (22744) Disconnected from slave
    2022-03-01 18:18:58.864 - debug: modbus.3 (22744) Clearing timeout of the current request.
    2022-03-01 18:18:58.865 - debug: modbus.3 (22744) Cleaning up request fifo.
    • S SebastianIV
      @wendy2702 ```
      code_text
      wendy2702W Offline
      wendy2702W Offline
      @sebastianiv Kannst du das loggen mal auf Debug stellen:
      Die Adapter Einstellungen hier posten und auch das Logfile nach Adapter start.
      S 2 Antworten Letzte Antwort
        SebastianIV
        @wendy2702
        Hallo wendy, sorry hat ein wenig länger gedauert. Anebi das log in debug. Ich hatte den Adapter schon das letzte Mal umgestellt aber erst nach deinem Psot gesehen, das es veraltete Daten waren...
        code_text
        2022-03-06 10:39:07.887 - info: host.raspberrypi "system.adapter.modbus.3" enabled
        2022-03-06 10:39:07.994 - info: host.raspberrypi instance system.adapter.modbus.3 started with pid 12198
        2022-03-06 10:39:09.118 - debug: modbus.3 (12198) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2022-03-06 10:39:09.168 - debug: modbus.3 (12198) Objects client ready ... initialize now
        2022-03-06 10:39:09.171 - debug: modbus.3 (12198) Objects create System PubSub Client
        2022-03-06 10:39:09.172 - debug: modbus.3 (12198) Objects create User PubSub Client
        2022-03-06 10:39:09.173 - debug: modbus.3 (12198) Objects client initialize lua scripts
        2022-03-06 10:39:09.193 - debug: modbus.3 (12198) Objects connected to redis: 127.0.0.1:9001
        2022-03-06 10:39:09.202 - debug: modbus.3 (12198) objectDB connected
        2022-03-06 10:39:09.205 - debug: modbus.3 (12198) Redis States: Use Redis connection: 127.0.0.1:9000
        2022-03-06 10:39:09.213 - debug: modbus.3 (12198) States create System PubSub Client
        2022-03-06 10:39:09.215 - debug: modbus.3 (12198) States create User PubSub Client
        2022-03-06 10:39:09.222 - debug: modbus.3 (12198) States connected to redis: 127.0.0.1:9000
        2022-03-06 10:39:09.223 - debug: modbus.3 (12198) statesDB connected
        2022-03-06 10:39:09.386 - debug: modbus.3 (12198) Plugin sentry Initialize Plugin (enabled=true)
        2022-03-06 10:39:09.623 - info: modbus.3 (12198) starting. Version 3.4.17 in /opt/iobroker/node_modules/iobroker.modbus, node: v14.18.3, js-controller: 3.3.22
        2022-03-06 10:39:09.782 - debug: modbus.3 (12198) Initialize Objects for disInputs: []
        2022-03-06 10:39:09.782 - debug: modbus.3 (12198) Initialize Objects for coils: []
        2022-03-06 10:39:09.783 - debug: modbus.3 (12198) Initialize Objects for inputRegs: []
        2022-03-06 10:39:09.783 - debug: modbus.3 (12198) Initialize Objects for holdingRegs: [{"_address":"40003","name":"Temp","description":"Außentemperatur","unit":"C","type":"int8le","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":2,"deviceId":1,"id":"holdingRegisters.40003_Temp"}]
        2022-03-06 10:39:09.784 - debug: modbus.3 (12198) Add holdingRegisters.40003_Temp: {"_id":"holdingRegisters.40003_Temp","type":"state","common":{"name":"Außentemperatur","role":"level","type":"number","read":true,"write":true,"def":0,"unit":"C"},"native":{"regType":"holdingRegs","address":2,"deviceId":1,"type":"int8le","len":1,"offset":0,"factor":1,"poll":true}}
        2022-03-06 10:39:10.059 - debug: modbus.3 (12198) connect to serial /dev/ttyAMA0 with 19200
        2022-03-06 10:39:10.067 - info: modbus.3 (12198) Connected to slave
        2022-03-06 10:39:10.068 - debug: modbus.3 (12198) [DevID_1] Poll start ---------------------
        2022-03-06 10:39:10.070 - debug: modbus.3 (12198) Initialization of scale factors done!
        2022-03-06 10:39:10.070 - debug: modbus.3 (12198) [DevID_1/holdingRegs] Poll address 2 - 1 registers
        2022-03-06 10:39:15.079 - warn: modbus.3 (12198) Error: undefined
        2022-03-06 10:39:15.080 - error: modbus.3 (12198) Request timed out.
        2022-03-06 10:39:15.084 - warn: modbus.3 (12198) Poll error count: 1 code: {"err":"timeout","timeout":5000}
        2022-03-06 10:39:16.082 - info: modbus.3 (12198) Disconnected from slave
        2022-03-06 10:39:16.086 - debug: modbus.3 (12198) Clearing timeout of the current request.
        2022-03-06 10:39:16.088 - debug: modbus.3 (12198) Cleaning up request fifo.
        2022-03-06 10:40:16.084 - debug: modbus.3 (12198) connect to serial /dev/ttyAMA0 with 19200
        2022-03-06 10:40:16.091 - info: modbus.3 (12198) Connected to slave
        2022-03-06 10:40:16.093 - debug: modbus.3 (12198) [DevID_1] Poll start ---------------------
        2022-03-06 10:40:16.094 - debug: modbus.3 (12198) [DevID_1/holdingRegs] Poll address 2 - 1 registers
        2022-03-06 10:40:21.096 - warn: modbus.3 (12198) Error: undefined
        2022-03-06 10:40:21.097 - error: modbus.3 (12198) Request timed out.
        2022-03-06 10:40:21.099 - warn: modbus.3 (12198) Poll error count: 2 code: {"err":"timeout","timeout":5000}
        2022-03-06 10:40:22.098 - info: modbus.3 (12198) Disconnected from slave
        2022-03-06 10:40:22.101 - debug: modbus.3 (12198) Clearing timeout of the current request.
        2022-03-06 10:40:22.102 - debug: modbus.3 (12198) Cleaning up request fifo.
        2022-03-06 10:41:22.100 - debug: modbus.3 (12198) connect to serial /dev/ttyAMA0 with 19200
        2022-03-06 10:41:22.104 - info: modbus.3 (12198) Connected to slave
        2022-03-06 10:41:22.105 - debug: modbus.3 (12198) [DevID_1] Poll start ---------------------
        2022-03-06 10:41:22.106 - debug: modbus.3 (12198) [DevID_1/holdingRegs] Poll address 2 - 1 registers
        2022-03-06 10:41:27.108 - warn: modbus.3 (12198) Error: undefined
        2022-03-06 10:41:27.109 - error: modbus.3 (12198) Request timed out.
        2022-03-06 10:41:27.110 - warn: modbus.3 (12198) Poll error count: 3 code: {"err":"timeout","timeout":5000}
        2022-03-06 10:41:28.110 - info: modbus.3 (12198) Disconnected from slave
        2022-03-06 10:41:28.112 - debug: modbus.3 (12198) Clearing timeout of the current request.
        2022-03-06 10:41:28.114 - debug: modbus.3 (12198) Cleaning up request fifo.
          SebastianIV
          @wendy2702
          code_text
          • S SebastianIV
            @wendy2702
            code_text
            wendy2702W Offline
            wendy2702W Offline
            @sebastianiv Poste mal einen Screenshot der Adapter Einstellungen.
            Ist das RS485 Shield auch wirklich das Device „ttyAMA0“ ?
              SebastianIV
              @wendy2702
              Hallo wendy, hier die Einstellungen vom Adapter. Ich hScreenshot 2022-03-07 165903.png abe mir parallel noch ein weiteres Shield bzw. Adapter für RS485 via USB gekauft, vielleicht funktioniert dieser besser....
              • wendy2702W Offline
                wendy2702W Offline
                Mach mal den Haken bei „Use Aliases“ weg. Kontrolliere danach die Register und poste dann mal das logfile.
                  SebastianIV
                  @wendy2702
                  Hallo wendy, ich habe nun Tests mit dem USB Adapter gemacht. Hier stellt sich die Thematik so dar, dass ich keine Antwort von der Wetterstation erhalte. Also die TX LED am Adapter geht an, die COM an der Wetterstation auch aber die RX am Adapter nicht. Um die Funktion der Wetterstation zu prüfen, wurde nun mit einem PC, dem Adapter via Docklight eine Kommunikation aufgebaut. Hier funktioniert alles, also auch die RX LED vom Adapter.
                    SebastianIV
                    @wendy2702
                    Hallo wendy, die Wetterstation läuft mittlerweile. Mit Hilfe des USB Adapter, dem richtigenm Einstellungen und Regsitern steht die Kommunikation. Einzig den Parameter des Regens bekomme ich nicht ausgelesen. Hast du hier vielleicht noch einen Tipp? Die Register zuvor funktionieren auch weil der Typ Signed 16bit (Big Endian) aus der Anleitung klar ist. Bei Regen habe ich alles möglich versucht aber nichts funktioniert?? Der WErt bleibt konstant bei 0..
                    Vielen Dank
                    Screenshot 2022-03-08 180505.png Screenshot 2022-03-08 180441.png Screenshot 2022-03-08 180415.png
                    • S SebastianIV
                      @wendy2702
                      Vielen Dank
                      wendy2702W Offline
                      wendy2702W Offline
                      @sebastianiv Blöde Frage, regnet es denn?
                        SebastianIV
                        @wendy2702
                        :-) Nein ich habe aber versucht den Regen mit einem feuchten Lappen zu simulieren.
