  4. text2command Seite ist leer
    6.0k
text2command fehler
23 Beiträge 7 Kommentatoren 3.5k Aufrufe 7 Beobachtet
  • W wladm
    @apollon77
    Das bekomme ich in Firefox.
    [2021-11-04T21:18:16.107Z] ws connection error: CLOSE_GOING_AWAY instrument.ts:129:35
    Object { rules: [], isOpen: false, isEdit: false, isCopy: false, selectedRule: null, unsavedRules: {}, ready: false, isLeftBarOpen: false }
    [2021-11-04T21:18:16.113Z] Start reconnect 0 instrument.ts:129:35
    [2021-11-04T21:18:16.114Z] Try to connect instrument.ts:129:35
    iobroker.text2command@2.1.1 using theme "colored" index.js:17:8
    Nice to see you here! :) Join our dev community here https://github.com/ioBroker/ioBroker or here https://github.com/iobroker-community-adapters instrument.ts:129:35
    Help us to create open source project with reactJS! instrument.ts:129:35
    See you :) instrument.ts:129:35
    [2021-11-04T21:18:16.514Z] Try to connect instrument.ts:129:35
    Object { rules: (11) […], sayitInstance: "", language: "de", processorId: "", processorTimeout: 1000, writeEveryAnswer: false }
    Uncaught (in promise) TypeError: s is undefined
        s Layout.js:376
        getDataFromConfig Layout.js:370
        promise callback*a/n.getDataFromConfig Layout.js:366
        value Layout.js:66
        React 2
        unstable_runWithPriority scheduler.production.min.js:18
        React 4
        React 6
        value App.js:53
        promise callback*value App.js:51
        onReady GenericApp.js:166
        React 3
        React 4
        React 6
        promise callback*onReady/< GenericApp.js:160
        promise callback*onReady GenericApp.js:134
        value Connection.js:369
        promise callback*value/< Connection.js:332
        value Connection.js:302
        value Connection.js:313
        value Connection.js:264
        value Connection.js:168
        findAnswer socket.io.js:255
        onmessage socket.io.js:163
        connect socket.io.js:143
        value Connection.js:141
        e Connection.js:80
        _ GenericApp.js:117
        s Babel
        n App.js:24
        React 13
        e index.js:20
        382 index.js:43
        a tab.html:1
        r tab.html:1
        t tab.html:1
        <anonymous> main.98ec8eac.chunk.js:1
    Layout.js:376:28
    bei Chrome Opera Edge das gleiche problem.
    Bei Issues gibt's mehreren gleiche probleme und leider ohne Lösung
    W Offline
    W Offline
    W0RSCHD
    schrieb am zuletzt editiert von W0RSCHD
    ich Reihe mich mal ein, nun hat es mich auch getroffen (bei Github hab ichs schon mit Bild gemeldet, aber keine Rückmeldung bisher...)
    [2022-01-12T12:21:36.160Z] Try to connect instrument.ts:129:35
    Object { rules: (46) […], sayitInstance: "", language: "", processorId: "", processorTimeout: 1000, writeEveryAnswer: false }
        s Layout.js:376
        bt Layout.js:370
    Layout.js:376:28
    Service worker event waitUntil() was passed a promise that rejected with 'Error: bad-precaching-response :: [{"url":"https://192.168.178.105:8081/adapter/text2command/index.html?__WB_REVISION__=dcffee691a65276f5dd9a0eaab3f9d2e","status":404}]'. workbox-core.prod.js:1:240
    Error: Promised response from onMessage listener went out of scope
    Hat schon jemand eine Lösung wie man das fixen kann?
    apollon77A D 2 Antworten Letzte Antwort
    • W W0RSCHD
          s Layout.js:376
          bt Layout.js:370
      Layout.js:376:28
      @w0rschd Bitte am besten schauen das es ein GitHub issue gibt. Wenn nicht anlegen. Wenn es gibt dann dort „thumbs up“ machen beim
      Ersten post.
      • W W0RSCHD
            s Layout.js:376
            bt Layout.js:370
        Layout.js:376:28
        Dreamboy74de
        @w0rschd Hatte auch diesen Fehler bei Version 2.1.2, das Interface wird nicht mehr geladen. Mit Firefox Dev Edition und Safari probiert. Abhilfe schafft erstmal auf Version 2.1.0 zu gehen dort funktioniert es noch.
        Raspi4 4GB Home/CCU3 FW 3.85.7/Admin 7.7.23/Node.js v22.22.0/NPM 10.9.4/JS-Controller 7.1.0
        Raspi4 4GB Szd/CCU3 FW 3.73.9/Admin 6.13.15/Node.js v18.19.0/NPM 10.2.3/JS-Controller5.0.17
        • D Dreamboy74de
          Dreamboy74de
          @dreamboy74de sagte in text2command Seite ist leer:
          Update: Die Neue Version 2.1.6 funktioniert wieder wie gehabt. Dankeschön 👍
          W 1 Antwort Letzte Antwort
          • D Dreamboy74de
            W Offline
            W Offline
            W0RSCHD
            @dreamboy74de bei mir leider noch nicht :( aber es wird ja dran gearbeitet, warten wir einfach mal noch ab,
            danke trotzdem jetzt schon an die Devs !!
            • W W0RSCHD
              @w0rschd Wenn Du noch issues hast mit der letzten "Latest" Version dann bitte GitHub Issue mit der Fehlermeldung anlegen!
              • apollon77A apollon77
                W Offline
                W Offline
                W0RSCHD
                @apollon77 ein neues Issue dann oder zum alten noch offenen die Fehlermeldung anhängen?
                Ich habs mal an das vorhandene Issue angehängt (mit Log)
                • G Offline
                  Grace13
                  Abend zusammen, wo genau finden ich denn auf Github Infos zu dem Problem?
                  • G Grace13
                    W Offline
                    W Offline
                    W0RSCHD
                    @grace13 https://github.com/ioBroker/ioBroker.text2command/issues/92
                    ist aber gefixed mittlerweile :) Danke dafür an die DEVs
                    G 1 Antwort Letzte Antwort
                    • W W0RSCHD
                      Grace13
                      @w0rschd nach einem Upgrade auf 2.2.1 ging es dann auch wieder
