  4. eBus Adapter Vaillant
    6.3k
ebusebus adapterproblemerrorerste schritte
395 Beiträge 50 Kommentatoren 166.4k Aufrufe 51 Beobachtet
  • C Offline
    Cino
    #256
    Ich hab den hier, funktioniert top
    https://www.esera.de/produkte/ebus/135/1-wire-hub-platine
    IOB@RPI4
    Shelly, Zigbee, ebus
    F 1 Antwort Letzte Antwort
    • C Cino
      floret88
      #257
      @cino Den habe ich auch, und funkt leider nicht zufriedenstellend.
      C 1 Antwort Letzte Antwort
      • F floret88
        Cino
        schrieb am zuletzt editiert von Cino
        #258
        @floret88 wenn du willst kann ich dir meine config mal schicken.
        ebusctl i
        version: ebusd 21.2.v21.2
        update check: OK
        signal: acquired
        symbol rate: 23
        max symbol rate: 360
        min arbitration micros: 319
        max arbitration micros: 9955
        min symbol latency: 0
        max symbol latency: 28
        reconnects: 0
        masters: 3
        conditional: 3
        poll: 1
        update: 10
        address 03: master #11
        address 08: slave #11, scanned "MF=Vaillant;ID=BAI00;SW=0104;HW=7803", loaded "vaillant/bai.308523.inc", "vaillant/08.bai.csv"
        address 10: master #2
        address 15: slave #2, scanned "MF=Vaillant;ID=70000;SW=0614;HW=6903", loaded "vaillant/15.700.csv"
        address 31: master #8, ebusd
        address 36: slave #8, ebusd
        address ec: slave, scanned "MF=Vaillant;ID=SOL00;SW=0614;HW=6903", loaded "vaillant/ec.sol.sc.csv"
        a# /etc/default/ebusd:
        # config file for ebusd service.
        # Options to pass to ebusd (run "ebusd -?" for more info):
        #EBUSD_OPTS="--scanconfig"
        EBUSD_OPTS="--configpath=http://ebusd.eu/config/ -d /dev/ttyUSB0 -p 8888  --latency=0 --receivetimeout=100000 -l /var/log/ebusd.log  --scanconfig=full  --httpport=8889 --htmlpath=/var/ebusd/html"
        # MULTIPLE EBUSD INSTANCES WITH SYSV
        # In order to run multiple ebusd instances on a SysV enabled system, simply
        # define several EBUSD_OPTS with a unique suffix for each. Recommended is to
        # use a number as suffix for all EBUSD_OPTS settings. That number will then be
        # taken as additional "instance" parameter to the init.d script in order to
        # start/stop an individual ebusd instance instead of all instances.
        # Example: (uncomment the EBUSD_OPTS above)
        #EBUSD_OPTS1="--scanconfig -d /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0 -p 8888 -l /var/log/ebusd1.log"
        #EBUSD_OPTS2="--scanconfig -d /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A900acTF-if00-port0 -p 8889 -l /var/log/ebusd2.log"
        #EBUSD_OPTS3="--scanconfig -d /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A900beCG-if00-port0 -p 8890 -l /var/log/ebusd3.log"
        # MULTIPLE EBUSD INSTANCES WITH SYSTEMD
        # In order to run muiltiple ebusd instances on a systemd enabled system, just
        # copy the /usr/lib/systemd/system/ebusd.service file to /etc/systemd/system/
        # with a different name (e.g. ebusd-2.service), remove the line starting with
        # 'EnvironmentFile=', and replace the '$EBUSD_OPTS' with the options for that
        # particular ebusd instance.
        IOB@RPI4
          Dan.Master
          #259
          Also meine Config die quasi Fehlerfrei zusammen mit dem ESERA EBUS Adapter seit Januar läuft:
          EBUSD_OPTS="--scanconfig=full --configpath=/etc/ebusd/ -d /dev/ttyUSB0 -p 8888 --latency=0 --receivetimeout=
          100000 -l /var/log/ebusd.log --httpport=8889 --htmlpath=/var/www/"
          # MULLE EBUSD INSTANCES WITH SYSV In order to run multiple ebusd instances on a SysV enabled system,
          # simply define several EBUSD_OPTS with a unique suffix for each. Recommended is to use a number as
          # suffix for all EBUSD_OPTS settings. That number will then be taken as additional "instance"
          # parameter to the init.d script in order to start/stop an individual ebusd instance instead of all
          # instances. Example: (uncomment the EBUSD_OPTS above)
          /log/ebusd1.log"
          /log/ebusd2.log"
          /log/ebusd3.log"
          Und der Auszug aus dem ebusctl info
          pi@raspberrypi:~ $ ebusctl i
          signal: acquired
          symbol rate: 58
          max symbol rate: 150
          min arbitration micros: 326
          max arbitration micros: 573
          min symbol latency: 5
          max symbol latency: 14
          reconnects: 0
          masters: 5
          conditional: 0
          poll: 1
          update: 10
          address 00: master #1
          address 05: slave #1, scanned "MF=Vaillant;ID=VR921;SW=2206;HW=5703"
          address 08: slave #11, scanned "MF=Vaillant;ID=HMU00;SW=0308;HW=0403", loaded "vaillant/08.hmu.csv"
          address 71: master #9
          address 76: slave #9, scanned "MF=Vaillant;ID=VWZ00;SW=0308;HW=0403"
          Die 921 wird nicht erkannt (Das Internetmodul).
          Der ESERA ist Busmäig ca 2.5m entfernt von der Wärmepumpe vond dort wird er weiter geleitet zum 921 und 700er.
          Ich habe den abgleich direkt am ESERA mit Laptop via HTERM gemacht. Auch ich musste das Poti anpassen.
          DerDani
          • MassiveAttackM Online
            MassiveAttack
            #260
            Ich hatte auch den Esera Adapter, und damit so meine Probleme. Hauptsächlich gehts da um die latency. Kurzum, nachdem ich den selbstgebastelten Adapter von John verwende, funktioniert alles tadellos.
            Du kannst an der Config drehen und wenden was du willst, bringt aber nur mäßigen Erfolg. Glaub mir, ich habe Stunden oder eher Tage damit verbracht :)
            • HasontH Offline
              HasontH Offline
              Hasont
              schrieb am zuletzt editiert von Hasont
              #261
              Hallo, ich verwende den EBus schon einige Jahre zum Auslesen von Werten und der Einstellung der Heizkurve.
              Leider gelingt es mir nicht die Auto Raumtemperatur welche an der calorMatic 430 eingestellt werden kann auch über die VIS einzustellen.
              Wenn ich mir die eBusDaten über [IP IoBroker]:8891/data auslese werden meine Änderungen an der calorMatic 430 als "ActualRoomTempDesiredHc1" und "DisplayedHc1RoomTempDesired" angezeigt. Diese kann ich über das Terminal mit ebusctl r ActualRoomTempDesiredHc1 oder ebusctl r DisplayedHc1RoomTempDesired ebenfalls auslesen.
              Eine Änderung mit ebusctl w -c 430 ActualRoomTempDesiredHc1 22 oder ebusctl w -c 430 DisplayedHc1RoomTempDesired 22 wird mit ERR: element not found beantwortet. Somit gehe ich davon aus, dass er in "ActualRoomTempDesiredHc1" und "DisplayedHc1RoomTempDesired" keine Werte schreiben kann.
              Ich kann mir aber auch nicht vorstellen, dass man grad diesen Komfortwert zur kurzfristigen Erhöhung oder Absenkung der Soll Zimmertemperatur nicht auch extern verstellen kann.
              Hat hierzu jemand eine Idee oder Lösung?
              LG
              Horst
              • HasontH Hasont
                LG
                Horst
                cactus-online
                #262
                @hasont ist das nicht eine Frage für die eBus Leute und nicht für ioBroker?
                Btw: Warum postest Du den absolut identischen Text hier im Forum in zwei verschiedenen Threads?
                • R Offline
                  Rolf_Bfd
                  #263
                  @hasont
                  Hallo Horst,
                  hast du inzwischen eine Lösung gefunden, um den Raumsollwert zu ändern?
                  VG, Ralf
                  HasontH 1 Antwort Letzte Antwort
                  • R Rolf_Bfd
                    @hasont
                    Hallo Horst,
                    VG, Ralf
                    HasontH Offline
                    HasontH Offline
                    Hasont
                    #264
                    @rolf_bfd
                    Hallo Ralf, danke der Nachfrage aber leider nicht.
                    Auf manuell könnte ich Umschalten und da dann auch die Grad eingeben.
                    Wenn man es dann aber nicht wieder zurück stellt bleibt das so.
                    Bei Automatik geht das bei der nächsten Änderung nach Zeit auf den vorher eingestellten Wert zurück.
                    Wäre somit wesentlich komfortabler.
                    LG Horst
                    • C Offline
                      Cino
                      #265
                      Mal eine generelle Frage hier.
                      Ich musste den RPI mit dem Ebusd neu aufsetzen. Über HTTP habe ich jetzt eine Liste voll mit Sachen.
                       "700": {
                        "messages": {   "AdaptHeatCurve": {
                          "name": "AdaptHeatCurve",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "BankHolidayEndPeriod": {
                          "name": "BankHolidayEndPeriod",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "BankHolidayStartPeriod": {
                          "name": "BankHolidayStartPeriod",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ccTimer.Friday": {
                          "name": "ccTimer.Friday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ccTimer.Monday": {
                          "name": "ccTimer.Monday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ccTimer.Saturday": {
                          "name": "ccTimer.Saturday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ccTimer.Sunday": {
                          "name": "ccTimer.Sunday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ccTimer.Thursday": {
                          "name": "ccTimer.Thursday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ccTimer.Tuesday": {
                          "name": "ccTimer.Tuesday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ccTimer.Wednesday": {
                          "name": "ccTimer.Wednesday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ContinuosHeating": {
                          "name": "ContinuosHeating",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "currenterror": {
                          "name": "currenterror",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "CylinderChargeHyst": {
                          "name": "CylinderChargeHyst",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "CylinderChargeOffset": {
                          "name": "CylinderChargeOffset",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Date": {
                          "name": "Date",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "DisplayedOutsideTemp": {
                          "name": "DisplayedOutsideTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "errorhistory": {
                          "name": "errorhistory",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "FrostOverRideTime": {
                          "name": "FrostOverRideTime",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc1ActualFlowTempDesired": {
                          "name": "Hc1ActualFlowTempDesired",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc1AutoOffMode": {
                          "name": "Hc1AutoOffMode",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc1CircuitType": {
                          "name": "Hc1CircuitType",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc1ExcessTemp": {
                          "name": "Hc1ExcessTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc1FlowTemp": {
                          "name": "Hc1FlowTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc1HeatCurve": {
                          "name": "Hc1HeatCurve",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc1HeatCurveAdaption": {
                          "name": "Hc1HeatCurveAdaption",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc1MaxFlowTempDesired": {
                          "name": "Hc1MaxFlowTempDesired",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc1MinFlowTempDesired": {
                          "name": "Hc1MinFlowTempDesired",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc1MixerMovement": {
                          "name": "Hc1MixerMovement",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc1PumpStatus": {
                          "name": "Hc1PumpStatus",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc1RoomTempSwitchOn": {
                          "name": "Hc1RoomTempSwitchOn",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc1Status": {
                          "name": "Hc1Status",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc1SummerTempLimit": {
                          "name": "Hc1SummerTempLimit",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc2ActualFlowTempDesired": {
                          "name": "Hc2ActualFlowTempDesired",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc2AutoOffMode": {
                          "name": "Hc2AutoOffMode",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc2CircuitType": {
                          "name": "Hc2CircuitType",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc2ExcessTemp": {
                          "name": "Hc2ExcessTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc2FlowTemp": {
                          "name": "Hc2FlowTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc2HeatCurve": {
                          "name": "Hc2HeatCurve",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc2HeatCurveAdaption": {
                          "name": "Hc2HeatCurveAdaption",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc2MaxFlowTempDesired": {
                          "name": "Hc2MaxFlowTempDesired",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc2MinFlowTempDesired": {
                          "name": "Hc2MinFlowTempDesired",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc2MixerMovement": {
                          "name": "Hc2MixerMovement",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc2PumpStatus": {
                          "name": "Hc2PumpStatus",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc2RoomTempSwitchOn": {
                          "name": "Hc2RoomTempSwitchOn",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc2Status": {
                          "name": "Hc2Status",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc2SummerTempLimit": {
                          "name": "Hc2SummerTempLimit",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc3ActualFlowTempDesired": {
                          "name": "Hc3ActualFlowTempDesired",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc3AutoOffMode": {
                          "name": "Hc3AutoOffMode",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc3CircuitType": {
                          "name": "Hc3CircuitType",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc3ExcessTemp": {
                          "name": "Hc3ExcessTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc3FlowTemp": {
                          "name": "Hc3FlowTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc3HeatCurve": {
                          "name": "Hc3HeatCurve",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc3HeatCurveAdaption": {
                          "name": "Hc3HeatCurveAdaption",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc3MaxFlowTempDesired": {
                          "name": "Hc3MaxFlowTempDesired",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc3MinFlowTempDesired": {
                          "name": "Hc3MinFlowTempDesired",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc3MixerMovement": {
                          "name": "Hc3MixerMovement",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc3PumpStatus": {
                          "name": "Hc3PumpStatus",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc3RoomTempSwitchOn": {
                          "name": "Hc3RoomTempSwitchOn",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc3Status": {
                          "name": "Hc3Status",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc3SummerTempLimit": {
                          "name": "Hc3SummerTempLimit",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HcStorageTempBottom": {
                          "name": "HcStorageTempBottom",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HcStorageTempTop": {
                          "name": "HcStorageTempTop",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HolidayEndPeriod": {
                          "name": "HolidayEndPeriod",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HolidayStartPeriod": {
                          "name": "HolidayStartPeriod",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HolidayTemp": {
                          "name": "HolidayTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcBankHolidayEndPeriod": {
                          "name": "HwcBankHolidayEndPeriod",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcBankHolidayStartPeriod": {
                          "name": "HwcBankHolidayStartPeriod",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcFlowTemp": {
                          "name": "HwcFlowTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcHolidayEndPeriod": {
                          "name": "HwcHolidayEndPeriod",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcHolidayStartPeriod": {
                          "name": "HwcHolidayStartPeriod",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcLockTime": {
                          "name": "HwcLockTime",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcMaxFlowTempDesired": {
                          "name": "HwcMaxFlowTempDesired",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcOpMode": {
                          "name": "HwcOpMode",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcParallelLoading": {
                          "name": "HwcParallelLoading",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcSFMode": {
                          "name": "HwcSFMode",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcStorageTemp": {
                          "name": "HwcStorageTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcStorageTempBottom": {
                          "name": "HwcStorageTempBottom",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcStorageTempTop": {
                          "name": "HwcStorageTempTop",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcTempDesired": {
                          "name": "HwcTempDesired",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "hwcTimer.Friday": {
                          "name": "hwcTimer.Friday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "hwcTimer.Monday": {
                          "name": "hwcTimer.Monday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "hwcTimer.Saturday": {
                          "name": "hwcTimer.Saturday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "hwcTimer.Sunday": {
                          "name": "hwcTimer.Sunday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "hwcTimer.Thursday": {
                          "name": "hwcTimer.Thursday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "hwcTimer.Tuesday": {
                          "name": "hwcTimer.Tuesday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "hwcTimer.Wednesday": {
                          "name": "hwcTimer.Wednesday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HydraulicScheme": {
                          "name": "HydraulicScheme",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Installer1": {
                          "name": "Installer1",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Installer2": {
                          "name": "Installer2",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "KeyCodeforConfigMenu": {
                          "name": "KeyCodeforConfigMenu",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "MaintenanceDate": {
                          "name": "MaintenanceDate",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "MaintenanceDue": {
                          "name": "MaintenanceDue",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "MaxCylinderChargeTime": {
                          "name": "MaxCylinderChargeTime",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "MaxRoomHumidity": {
                          "name": "MaxRoomHumidity",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "MultiRelaySetting": {
                          "name": "MultiRelaySetting",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "noiseReductionTimer.Friday": {
                          "name": "noiseReductionTimer.Friday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "noiseReductionTimer.Monday": {
                          "name": "noiseReductionTimer.Monday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "noiseReductionTimer.Saturday": {
                          "name": "noiseReductionTimer.Saturday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "noiseReductionTimer.Sunday": {
                          "name": "noiseReductionTimer.Sunday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "noiseReductionTimer.Thursday": {
                          "name": "noiseReductionTimer.Thursday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "noiseReductionTimer.Tuesday": {
                          "name": "noiseReductionTimer.Tuesday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "noiseReductionTimer.Wednesday": {
                          "name": "noiseReductionTimer.Wednesday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "OpMode": {
                          "name": "OpMode",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "OpModeEffect": {
                          "name": "OpModeEffect",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "OutsideTempAvg": {
                          "name": "OutsideTempAvg",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PhoneNumber1": {
                          "name": "PhoneNumber1",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PhoneNumber2": {
                          "name": "PhoneNumber2",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrEnergySum": {
                          "name": "PrEnergySum",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrEnergySumHc": {
                          "name": "PrEnergySumHc",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrEnergySumHcLastMonth": {
                          "name": "PrEnergySumHcLastMonth",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrEnergySumHcThisMonth": {
                          "name": "PrEnergySumHcThisMonth",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrEnergySumHwc": {
                          "name": "PrEnergySumHwc",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrEnergySumHwcLastMonth": {
                          "name": "PrEnergySumHwcLastMonth",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrEnergySumHwcThisMonth": {
                          "name": "PrEnergySumHwcThisMonth",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrFuelSum": {
                          "name": "PrFuelSum",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrFuelSumHc": {
                          "name": "PrFuelSumHc",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrFuelSumHcLastMonth": {
                          "name": "PrFuelSumHcLastMonth",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrFuelSumHcThisMonth": {
                          "name": "PrFuelSumHcThisMonth",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrFuelSumHwc": {
                          "name": "PrFuelSumHwc",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrFuelSumHwcLastMonth": {
                          "name": "PrFuelSumHwcLastMonth",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrFuelSumHwcThisMonth": {
                          "name": "PrFuelSumHwcThisMonth",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PumpAdditionalTime": {
                          "name": "PumpAdditionalTime",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "SFMode": {
                          "name": "SFMode",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "SolarYieldTotal": {
                          "name": "SolarYieldTotal",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "SystemFlowTemp": {
                          "name": "SystemFlowTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "tariffTimer.Friday": {
                          "name": "tariffTimer.Friday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "tariffTimer.Monday": {
                          "name": "tariffTimer.Monday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "tariffTimer.Saturday": {
                          "name": "tariffTimer.Saturday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "tariffTimer.Sunday": {
                          "name": "tariffTimer.Sunday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "tariffTimer.Thursday": {
                          "name": "tariffTimer.Thursday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "tariffTimer.Tuesday": {
                          "name": "tariffTimer.Tuesday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "tariffTimer.Wednesday": {
                          "name": "tariffTimer.Wednesday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Time": {
                          "name": "Time",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ventilationTimer.Friday": {
                          "name": "ventilationTimer.Friday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ventilationTimer.Monday": {
                          "name": "ventilationTimer.Monday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ventilationTimer.Saturday": {
                          "name": "ventilationTimer.Saturday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ventilationTimer.Sunday": {
                          "name": "ventilationTimer.Sunday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ventilationTimer.Thursday": {
                          "name": "ventilationTimer.Thursday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ventilationTimer.Tuesday": {
                          "name": "ventilationTimer.Tuesday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ventilationTimer.Wednesday": {
                          "name": "ventilationTimer.Wednesday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "WaterPressure": {
                          "name": "WaterPressure",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "YieldTotal": {
                          "name": "YieldTotal",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1ActualRoomTempDesired": {
                          "name": "z1ActualRoomTempDesired",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1BankHolidayEndPeriod": {
                          "name": "z1BankHolidayEndPeriod",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1BankHolidayStartPeriod": {
                          "name": "z1BankHolidayStartPeriod",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1CoolingTemp": {
                          "name": "z1CoolingTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1CoolingTimer.Friday": {
                          "name": "z1CoolingTimer.Friday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1CoolingTimer.Monday": {
                          "name": "z1CoolingTimer.Monday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1CoolingTimer.Saturday": {
                          "name": "z1CoolingTimer.Saturday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1CoolingTimer.Sunday": {
                          "name": "z1CoolingTimer.Sunday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1CoolingTimer.Thursday": {
                          "name": "z1CoolingTimer.Thursday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1CoolingTimer.Tuesday": {
                          "name": "z1CoolingTimer.Tuesday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1CoolingTimer.Wednesday": {
                          "name": "z1CoolingTimer.Wednesday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1DayTemp": {
                          "name": "z1DayTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1HolidayEndPeriod": {
                          "name": "z1HolidayEndPeriod",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1HolidayStartPeriod": {
                          "name": "z1HolidayStartPeriod",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1HolidayTemp": {
                          "name": "z1HolidayTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1Name1": {
                          "name": "z1Name1",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1Name2": {
                          "name": "z1Name2",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1NightTemp": {
                          "name": "z1NightTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1OpMode": {
                          "name": "z1OpMode",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1QuickVetoTemp": {
                          "name": "z1QuickVetoTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1RoomTemp": {
                          "name": "z1RoomTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1RoomZoneMapping": {
                          "name": "z1RoomZoneMapping",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1SFMode": {
                          "name": "z1SFMode",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1Shortname": {
                          "name": "z1Shortname",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1Timer.Friday": {
                          "name": "z1Timer.Friday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1Timer.Monday": {
                          "name": "z1Timer.Monday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1Timer.Saturday": {
                          "name": "z1Timer.Saturday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1Timer.Sunday": {
                          "name": "z1Timer.Sunday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1Timer.Thursday": {
                          "name": "z1Timer.Thursday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1Timer.Tuesday": {
                          "name": "z1Timer.Tuesday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1Timer.Wednesday": {
                          "name": "z1Timer.Wednesday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z1ValveStatus": {
                          "name": "z1ValveStatus",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2ActualRoomTempDesired": {
                          "name": "z2ActualRoomTempDesired",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2BankHolidayEndPeriod": {
                          "name": "z2BankHolidayEndPeriod",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2BankHolidayStartPeriod": {
                          "name": "z2BankHolidayStartPeriod",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2CoolingTemp": {
                          "name": "z2CoolingTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2CoolingTimer.Friday": {
                          "name": "z2CoolingTimer.Friday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2CoolingTimer.Monday": {
                          "name": "z2CoolingTimer.Monday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2CoolingTimer.Saturday": {
                          "name": "z2CoolingTimer.Saturday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2CoolingTimer.Sunday": {
                          "name": "z2CoolingTimer.Sunday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2CoolingTimer.Thursday": {
                          "name": "z2CoolingTimer.Thursday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2CoolingTimer.Tuesday": {
                          "name": "z2CoolingTimer.Tuesday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2CoolingTimer.Wednesday": {
                          "name": "z2CoolingTimer.Wednesday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2DayTemp": {
                          "name": "z2DayTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2HolidayEndPeriod": {
                          "name": "z2HolidayEndPeriod",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2HolidayStartPeriod": {
                          "name": "z2HolidayStartPeriod",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2HolidayTemp": {
                          "name": "z2HolidayTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2Name1": {
                          "name": "z2Name1",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2Name2": {
                          "name": "z2Name2",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2NightTemp": {
                          "name": "z2NightTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2OpMode": {
                          "name": "z2OpMode",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2QuickVetoTemp": {
                          "name": "z2QuickVetoTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2RoomTemp": {
                          "name": "z2RoomTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2RoomZoneMapping": {
                          "name": "z2RoomZoneMapping",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2SFMode": {
                          "name": "z2SFMode",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2Shortname": {
                          "name": "z2Shortname",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2Timer.Friday": {
                          "name": "z2Timer.Friday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2Timer.Monday": {
                          "name": "z2Timer.Monday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2Timer.Saturday": {
                          "name": "z2Timer.Saturday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2Timer.Sunday": {
                          "name": "z2Timer.Sunday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2Timer.Thursday": {
                          "name": "z2Timer.Thursday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2Timer.Tuesday": {
                          "name": "z2Timer.Tuesday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2Timer.Wednesday": {
                          "name": "z2Timer.Wednesday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z2ValveStatus": {
                          "name": "z2ValveStatus",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z3ActualRoomTempDesired": {
                          "name": "z3ActualRoomTempDesired",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z3BankHolidayEndPeriod": {
                          "name": "z3BankHolidayEndPeriod",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z3BankHolidayStartPeriod": {
                          "name": "z3BankHolidayStartPeriod",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z3DayTemp": {
                          "name": "z3DayTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z3HolidayEndPeriod": {
                          "name": "z3HolidayEndPeriod",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z3HolidayStartPeriod": {
                          "name": "z3HolidayStartPeriod",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z3HolidayTemp": {
                          "name": "z3HolidayTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z3Name1": {
                          "name": "z3Name1",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z3Name2": {
                          "name": "z3Name2",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z3NightTemp": {
                          "name": "z3NightTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z3OpMode": {
                          "name": "z3OpMode",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z3QuickVetoTemp": {
                          "name": "z3QuickVetoTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z3RoomTemp": {
                          "name": "z3RoomTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z3RoomZoneMapping": {
                          "name": "z3RoomZoneMapping",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z3SFMode": {
                          "name": "z3SFMode",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z3Shortname": {
                          "name": "z3Shortname",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "z3ValveStatus": {
                          "name": "z3ValveStatus",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                       "bai": {
                        "messages": {   "AccessoriesOne": {
                          "name": "AccessoriesOne",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "AccessoriesTwo": {
                          "name": "AccessoriesTwo",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ACRoomthermostat": {
                          "name": "ACRoomthermostat",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "averageIgnitiontime": {
                          "name": "averageIgnitiontime",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "BlockTimeHcMax": {
                          "name": "BlockTimeHcMax",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "BoilerType": {
                          "name": "BoilerType",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ChangesDSN": {
                          "name": "ChangesDSN",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "CirPump": {
                          "name": "CirPump",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "CounterStartattempts1": {
                          "name": "CounterStartattempts1",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "CounterStartattempts2": {
                          "name": "CounterStartattempts2",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "CounterStartAttempts3": {
                          "name": "CounterStartAttempts3",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "CounterStartAttempts4": {
                          "name": "CounterStartAttempts4",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "currenterror": {
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "DateTime": {
                          "name": "DateTime",
                          "passive": false,
                          "write": false,
                          "lastup": 1645901322,
                          "zz": 8,
                          "fields": {
                           "dcfstate": {"value": "valid"},
                           "btime": {"value": "19:48:43"},
                           "bdate": {"value": "26.02.2022"},
                           "temp2": {"value": 6.438}
                         "dcfState": {
                          "name": "dcfState",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "DCFTimeDate": {
                          "name": "DCFTimeDate",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "DCRoomthermostat": {
                          "name": "DCRoomthermostat",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "DeactivationsIFC": {
                          "name": "DeactivationsIFC",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "DeactivationsTemplimiter": {
                          "name": "DeactivationsTemplimiter",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "DeltaFlowReturnMax": {
                          "name": "DeltaFlowReturnMax",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "DisplayMode": {
                          "name": "DisplayMode",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "DSN": {
                          "name": "DSN",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "DSNOffset": {
                          "name": "DSNOffset",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "DSNStart": {
                          "name": "DSNStart",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "EBusHeatcontrol": {
                          "name": "EBusHeatcontrol",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "EbusSourceOn": {
                          "name": "EbusSourceOn",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "EbusVoltage": {
                          "name": "EbusVoltage",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "errorhistory": {
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "expertlevel_ReturnTemp": {
                          "name": "expertlevel_ReturnTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ExternalFaultmessage": {
                          "name": "ExternalFaultmessage",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "externalFlowTempDesired": {
                          "name": "externalFlowTempDesired",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "externalHwcSwitch": {
                          "name": "externalHwcSwitch",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ExternGasvalve": {
                          "name": "ExternGasvalve",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ExtFlowTempDesiredMin": {
                          "name": "ExtFlowTempDesiredMin",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ExtStorageModulCon": {
                          "name": "ExtStorageModulCon",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "extWP": {
                          "name": "extWP",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "FanHours": {
                          "name": "FanHours",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "FanMaxSpeedOperation": {
                          "name": "FanMaxSpeedOperation",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "FanMinSpeedOperation": {
                          "name": "FanMinSpeedOperation",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "FanPWMSum": {
                          "name": "FanPWMSum",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "FanPWMTest": {
                          "name": "FanPWMTest",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "FanSpeed": {
                          "name": "FanSpeed",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "FanSpeedOffsetMax": {
                          "name": "FanSpeedOffsetMax",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "FanSpeedOffsetMin": {
                          "name": "FanSpeedOffsetMin",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "FanStarts": {
                          "name": "FanStarts",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Flame": {
                          "name": "Flame",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "FlameSensingASIC": {
                          "name": "FlameSensingASIC",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "FloorHeatingContact": {
                          "name": "FloorHeatingContact",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "FlowsetHcMax": {
                          "name": "FlowsetHcMax",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "FlowsetHwcMax": {
                          "name": "FlowsetHwcMax",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "FlowSetPotmeter": {
                          "name": "FlowSetPotmeter",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "FlowTemp": {
                          "name": "FlowTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "FlowTempDesired": {
                          "name": "FlowTempDesired",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "FlowTempMax": {
                          "name": "FlowTempMax",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Fluegasvalve": {
                          "name": "Fluegasvalve",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "FluegasvalveOpen": {
                          "name": "FluegasvalveOpen",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Gasvalve3UC": {
                          "name": "Gasvalve3UC",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Gasvalve": {
                          "name": "Gasvalve",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "GasvalveASICFeedback": {
                          "name": "GasvalveASICFeedback",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "GasvalveUC": {
                          "name": "GasvalveUC",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "GasvalveUCFeedback": {
                          "name": "GasvalveUCFeedback",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HcHours": {
                          "name": "HcHours",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HcPumpMode": {
                          "name": "HcPumpMode",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HcPumpStarts": {
                          "name": "HcPumpStarts",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HcStarts": {
                          "name": "HcStarts",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HcUnderHundredStarts": {
                          "name": "HcUnderHundredStarts",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HeatingSwitch": {
                          "name": "HeatingSwitch",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HoursTillService": {
                          "name": "HoursTillService",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcDemand": {
                          "name": "HwcDemand",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcHours": {
                          "name": "HwcHours",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcImpellorSwitch": {
                          "name": "HwcImpellorSwitch",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcPostrunTime": {
                          "name": "HwcPostrunTime",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcSetPotmeter": {
                          "name": "HwcSetPotmeter",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcStarts": {
                          "name": "HwcStarts",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcSwitch": {
                          "name": "HwcSwitch",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcTemp": {
                          "name": "HwcTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcTempDesired": {
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcTempMax": {
                          "name": "HwcTempMax",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcTypes": {
                          "name": "HwcTypes",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcUnderHundredStarts": {
                          "name": "HwcUnderHundredStarts",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcWaterflow": {
                          "name": "HwcWaterflow",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "HwcWaterflowMax": {
                          "name": "HwcWaterflowMax",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Ignitor": {
                          "name": "Ignitor",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "InitialisationEEPROM": {
                          "name": "InitialisationEEPROM",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "IonisationVoltageLevel": {
                          "name": "IonisationVoltageLevel",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "maintenancedata_HwcTempMax": {
                          "name": "maintenancedata_HwcTempMax",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "maxIgnitiontime": {
                          "name": "maxIgnitiontime",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "minIgnitiontime": {
                          "name": "minIgnitiontime",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ModulationTempDesired": {
                          "name": "ModulationTempDesired",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "OutdoorstempSensor": {
                          "name": "OutdoorstempSensor",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "OverflowCounter": {
                          "name": "OverflowCounter",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ParamToken": {
                          "name": "ParamToken",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PartloadHcKW": {
                          "name": "PartloadHcKW",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PartloadHwcKW": {
                          "name": "PartloadHwcKW",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PartnumberBox": {
                          "name": "PartnumberBox",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PositionValveSet": {
                          "name": "PositionValveSet",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PowerValue": {
                          "name": "PowerValue",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrAPSCounter": {
                          "name": "PrAPSCounter",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrAPSSum": {
                          "name": "PrAPSSum",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrEnergyCountHc1": {
                          "name": "PrEnergyCountHc1",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrEnergyCountHc2": {
                          "name": "PrEnergyCountHc2",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrEnergyCountHc3": {
                          "name": "PrEnergyCountHc3",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrEnergyCountHwc1": {
                          "name": "PrEnergyCountHwc1",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrEnergyCountHwc2": {
                          "name": "PrEnergyCountHwc2",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrEnergyCountHwc3": {
                          "name": "PrEnergyCountHwc3",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrEnergySumHc1": {
                          "name": "PrEnergySumHc1",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrEnergySumHc2": {
                          "name": "PrEnergySumHc2",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrEnergySumHc3": {
                          "name": "PrEnergySumHc3",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrEnergySumHwc1": {
                          "name": "PrEnergySumHwc1",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrEnergySumHwc2": {
                          "name": "PrEnergySumHwc2",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrEnergySumHwc3": {
                          "name": "PrEnergySumHwc3",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ProductionByte": {
                          "name": "ProductionByte",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PrVortexFlowSensorValue": {
                          "name": "PrVortexFlowSensorValue",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PumpHours": {
                          "name": "PumpHours",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PumpHwcFlowNumber": {
                          "name": "PumpHwcFlowNumber",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PumpHwcFlowSum": {
                          "name": "PumpHwcFlowSum",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "RemainingBoilerblocktime": {
                          "name": "RemainingBoilerblocktime",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ReturnRegulation": {
                          "name": "ReturnRegulation",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ReturnTemp": {
                          "name": "ReturnTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ReturnTempMax": {
                          "name": "ReturnTempMax",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "SecondPumpMode": {
                          "name": "SecondPumpMode",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "SerialNumber": {
                          "name": "SerialNumber",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "SetFactoryValues": {
                          "name": "SetFactoryValues",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "SetMode": {
                          "name": "SetMode",
                          "passive": true,
                          "write": true,
                          "lastup": 1645901332,
                          "zz": 8,
                          "fields": {
                           "hcmode": {"value": "auto"},
                           "flowtempdesired": {"value": 61.5},
                           "hwctempdesired": {"value": null},
                           "hwcflowtempdesired": {"value": null},
                           "disablehc": {"value": 0},
                           "disablehwctapping": {"value": 0},
                           "disablehwcload": {"value": 1},
                           "remoteControlHcPump": {"value": 0},
                           "releaseBackup": {"value": 0},
                           "releaseCooling": {"value": 0}
                         "SHEMaxDeltaHwcFlow": {
                          "name": "SHEMaxDeltaHwcFlow",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "SHEMaxFlowTemp": {
                          "name": "SHEMaxFlowTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "SolPostHeat": {
                          "name": "SolPostHeat",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Statenumber": {
                          "name": "Statenumber",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Status01": {
                          "name": "Status01",
                          "passive": false,
                          "write": false,
                          "lastup": 1645901342,
                          "zz": 8,
                          "fields": {
                           "0": {"name": "temp1", "value": 47.0},
                           "1": {"name": "temp1", "value": 42.0},
                           "2": {"name": "temp2", "value": 6.438},
                           "3": {"name": "temp1", "value": 32.5},
                           "4": {"name": "temp1", "value": 36.5},
                           "5": {"name": "pumpstate", "value": "on"}
                         "Status02": {
                          "name": "Status02",
                          "passive": false,
                          "write": false,
                          "zz": 8,
                          "fields": {
                           "0": {"name": "hwcmode", "value": "auto"},
                           "1": {"name": "temp0", "value": 60},
                           "2": {"name": "temp1", "value": 75.0},
                           "3": {"name": "temp0", "value": 70},
                           "4": {"name": "temp1", "value": 50.0}
                         "Status16": {
                          "name": "Status16",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Status": {
                          "name": "Status",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "StatusCirPump": {
                          "name": "StatusCirPump",
                          "passive": true,
                          "write": true,
                          "lastup": 1645901143,
                          "zz": 8,
                          "fields": {
                           "0": {"name": "", "value": "off"}
                         "Storageloadpump": {
                          "name": "Storageloadpump",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "StorageLoadPumpHours": {
                          "name": "StorageLoadPumpHours",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "StorageloadPumpStarts": {
                          "name": "StorageloadPumpStarts",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "StorageLoadTimeMax": {
                          "name": "StorageLoadTimeMax",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "StoragereleaseClock": {
                          "name": "StoragereleaseClock",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "StorageTemp": {
                          "name": "StorageTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "StorageTempDesired": {
                          "name": "StorageTempDesired",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "StorageTempMax": {
                          "name": "StorageTempMax",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "TargetFanSpeed": {
                          "name": "TargetFanSpeed",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "TargetFanSpeedOutput": {
                          "name": "TargetFanSpeedOutput",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "TempDiffBlock": {
                          "name": "TempDiffBlock",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "TempDiffFailure": {
                          "name": "TempDiffFailure",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "TempGradientFailure": {
                          "name": "TempGradientFailure",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Templimiter": {
                          "name": "Templimiter",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "TemplimiterWithNTC": {
                          "name": "TemplimiterWithNTC",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "TempMaxDiffExtTFT": {
                          "name": "TempMaxDiffExtTFT",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Testbyte": {
                          "name": "Testbyte",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "TimerInputHc": {
                          "name": "TimerInputHc",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ValveMode": {
                          "name": "ValveMode",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ValveStarts": {
                          "name": "ValveStarts",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "VolatileLockout": {
                          "name": "VolatileLockout",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "VolatileLockoutIFCGV": {
                          "name": "VolatileLockoutIFCGV",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "VortexFlowSensor": {
                          "name": "VortexFlowSensor",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "WarmstartDemand": {
                          "name": "WarmstartDemand",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "WarmstartOffset": {
                          "name": "WarmstartOffset",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "WaterHcFlowMax": {
                          "name": "WaterHcFlowMax",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "WaterPressure": {
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "WaterpressureBranchControlOff": {
                          "name": "WaterpressureBranchControlOff",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "WaterpressureMeasureCounter": {
                          "name": "WaterpressureMeasureCounter",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "WaterpressureVariantSum": {
                          "name": "WaterpressureVariantSum",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "WP": {
                          "name": "WP",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "WPPostrunTime": {
                          "name": "WPPostrunTime",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "WPSecondStage": {
                          "name": "WPSecondStage",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                       "broadcast": {
                        "messages": {   "datetime": {
                          "name": "datetime",
                          "passive": true,
                          "write": false,
                          "lastup": 0
                         "error": {
                          "name": "error",
                          "passive": true,
                          "write": false,
                          "lastup": 0
                         "hwcStatus": {
                          "name": "hwcStatus",
                          "passive": true,
                          "write": false,
                          "lastup": 0
                         "id-u": {
                          "name": "id",
                          "passive": true,
                          "write": false,
                          "lastup": 0
                         "load": {
                          "name": "load",
                          "passive": true,
                          "write": false,
                          "lastup": 0
                         "outsidetemp": {
                          "name": "outsidetemp",
                          "passive": true,
                          "write": false,
                          "lastup": 1645901323,
                          "zz": 254,
                          "fields": {
                         "signoflife": {
                          "name": "signoflife",
                          "passive": true,
                          "write": false,
                          "lastup": 0
                         "vdatetime": {
                          "name": "vdatetime",
                          "passive": true,
                          "write": false,
                          "zz": 254,
                          "fields": {
                           "time": {"value": "19:48:42"},
                           "date": {"value": "26.02.2022"}
                       "sc": {
                        "messages": {   "Col": {
                          "name": "Col",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ColKickPumpTime": {
                          "name": "ColKickPumpTime",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ColKickTempDelta": {
                          "name": "ColKickTempDelta",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "CollPump": {
                          "name": "CollPump",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "currenterror": {
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "D1Temp": {
                          "name": "D1Temp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "D2Temp": {
                          "name": "D2Temp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Date": {
                          "name": "Date",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "EDFunction": {
                          "name": "EDFunction",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "EnableScProtection": {
                          "name": "EnableScProtection",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "errorhistory": {
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "FlowRate": {
                          "name": "FlowRate",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "FrostProtectionEnabled": {
                          "name": "FrostProtectionEnabled",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "FrostProtectionLimit": {
                          "name": "FrostProtectionLimit",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc1PumpKol1PP1Port": {
                          "name": "Hc1PumpKol1PP1Port",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc2aLegPumpP2Port": {
                          "name": "Hc2aLegPumpP2Port",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Hc2zPort": {
                          "name": "Hc2zPort",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "InitCircuit": {
                          "name": "InitCircuit",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "IsInBoostMode": {
                          "name": "IsInBoostMode",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "KickFunction": {
                          "name": "KickFunction",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "LpZpMaPort": {
                          "name": "LpZpMaPort",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "MAPreferredStorage": {
                          "name": "MAPreferredStorage",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "MaximalTemp2": {
                          "name": "MaximalTemp2",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "MaximalTemp": {
                          "name": "MaximalTemp",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "MultifunctionOutput": {
                          "name": "MultifunctionOutput",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "OMultifunction": {
                          "name": "OMultifunction",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "PumpAntiLockingFlags": {
                          "name": "PumpAntiLockingFlags",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "QuickVetoStart": {
                          "name": "QuickVetoStart",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ResetSolGain": {
                          "name": "ResetSolGain",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "RuntimeCollPump": {
                          "name": "RuntimeCollPump",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "RuntimeCollPumpSeconds": {
                          "name": "RuntimeCollPumpSeconds",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ScProtectionHysteresis": {
                          "name": "ScProtectionHysteresis",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ScProtectionLimit": {
                          "name": "ScProtectionLimit",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "ScProtectionTime": {
                          "name": "ScProtectionTime",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "SolCollPumpDcIntegrator": {
                          "name": "SolCollPumpDcIntegrator",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "SolCollPumpED": {
                          "name": "SolCollPumpED",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "SolGain": {
                          "name": "SolGain",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "SolOperationMode": {
                          "name": "SolOperationMode",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "SP1": {
                          "name": "SP1",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "SP2": {
                          "name": "SP2",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "SumSolGain": {
                          "name": "SumSolGain",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "SumSolGainDayBefore": {
                          "name": "SumSolGainDayBefore",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "SystemMode": {
                          "name": "SystemMode",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "TempDifferenceOff2": {
                          "name": "TempDifferenceOff2",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "TempDifferenceOff": {
                          "name": "TempDifferenceOff",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "TempDifferenceOffTD12": {
                          "name": "TempDifferenceOffTD12",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "TempDifferenceOn2": {
                          "name": "TempDifferenceOn2",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "TempDifferenceOn": {
                          "name": "TempDifferenceOn",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "TempDifferenceOnTD12": {
                          "name": "TempDifferenceOnTD12",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Time": {
                          "name": "Time",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "Weekday": {
                          "name": "Weekday",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "YieldLastYear": {
                          "name": "YieldLastYear",
                          "passive": false,
                          "write": false,
                          "lastup": 0
                         "YieldThisYear": {
                          "name": "YieldThisYear",
                          "passive": false,
                          "write": false,
                          "lastup": 1645901350,
                          "zz": 236,
                          "decodeerror": "ERR: invalid position"
                       "scan.08": {
                        "messages": {   "": {
                          "name": "",
                          "passive": false,
                          "write": false,
                          "lastup": 1645900412,
                          "zz": 8,
                          "fields": {
                           "MF": {"value": "Vaillant"},
                           "ID": {"value": "BAI00"},
                           "SW": {"value": "0104"},
                           "HW": {"value": "7803"}
                         "id": {
                          "name": "id",
                          "passive": false,
                          "write": false,
                          "lastup": 1645900430,
                          "zz": 8,
                          "fields": {
                           "prefix": {"value": "21"},
                           "year": {"value": "19"},
                           "week": {"value": "48"},
                           "product": {"value": "0010021934"},
                           "supplier": {"value": "0001"},
                           "counter": {"value": "008767"},
                           "suffix": {"value": "N4"}
                       "scan.15": {
                        "messages": {   "": {
                          "name": "",
                          "passive": false,
                          "write": false,
                          "lastup": 1645900416,
                          "zz": 21,
                          "fields": {
                           "ID": {"value": "70000"},
                           "SW": {"value": "0614"},
                           "HW": {"value": "6903"}
                         "id": {
                          "name": "id",
                          "passive": false,
                          "write": false,
                          "lastup": 1645900435,
                          "zz": 21,
                          "fields": {
                           "year": {"value": "20"},
                           "week": {"value": "15"},
                           "product": {"value": "0020266797"},
                           "supplier": {"value": "0082"},
                           "counter": {"value": "019647"},
                           "suffix": {"value": "N5"}
                       "scan.ec": {
                        "messages": {   "": {
                          "name": "",
                          "passive": false,
                          "write": false,
                          "lastup": 1645900557,
                          "zz": 236,
                          "fields": {
                           "ID": {"value": "SOL00"},
                         "id": {
                          "name": "id",
                          "passive": false,
                          "write": false,
                          "lastup": 1645900568,
                          "zz": 236,
                          "fields": {
                       "global": {
                        "version": "21.3.v21.3",
                        "updatecheck": "version 22.1 available",
                        "signal": true,
                        "symbolrate": 35,
                        "maxsymbolrate": 134,
                        "minarbitrationmicros": 352,
                        "maxarbitrationmicros": 575,
                        "minsymbollatency": 0,
                        "maxsymbollatency": 7,
                        "qq": 49,
                        "reconnects": 0,
                        "masters": 3,
                        "messages": 718,
                      Was kann ich mit solchen Sachen anfangen?
                      "700": {
                      "passive": false,
                      "write": false,
                      "lastup": 0
                      "passive": false,
                      "write": false,
                      "lastup": 0
                      "passive": false,
                      "write": false,
                      "lastup": 0
                      "ccTimer.Friday": {
                      "passive": false,
                      "write": false,
                      "lastup": 0
                      Generell habe ich nur vereinzelt Werte drin.
                      IOB@RPI4
                      HiltexH 1 Antwort Letzte Antwort
                      • C Cino
                         "700": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "ccTimer.Friday": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "ccTimer.Monday": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "ccTimer.Sunday": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "currenterror": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Date": {
                            "name": "Date",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "errorhistory": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Hc1AutoOffMode": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Hc1CircuitType": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Hc1ExcessTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Hc1FlowTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Hc1HeatCurve": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Hc1PumpStatus": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Hc1Status": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Hc2AutoOffMode": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Hc2CircuitType": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Hc2ExcessTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Hc2FlowTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Hc2HeatCurve": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Hc2PumpStatus": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Hc2Status": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Hc3AutoOffMode": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Hc3CircuitType": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Hc3ExcessTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Hc3FlowTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Hc3HeatCurve": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Hc3PumpStatus": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Hc3Status": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "HolidayTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "HwcFlowTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "HwcLockTime": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "HwcOpMode": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "HwcSFMode": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "HwcStorageTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "HwcTempDesired": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Installer1": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Installer2": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "MaintenanceDue": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "OpMode": {
                            "name": "OpMode",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "OpModeEffect": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "OutsideTempAvg": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "PhoneNumber1": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "PhoneNumber2": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "PrEnergySum": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "PrEnergySumHc": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "PrEnergySumHwc": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "PrFuelSum": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "PrFuelSumHc": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "PrFuelSumHwc": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "SFMode": {
                            "name": "SFMode",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "SystemFlowTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Time": {
                            "name": "Time",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "WaterPressure": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "YieldTotal": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z1CoolingTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z1DayTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z1HolidayTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z1Name1": {
                            "name": "z1Name1",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z1Name2": {
                            "name": "z1Name2",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z1NightTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z1OpMode": {
                            "name": "z1OpMode",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z1RoomTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z1SFMode": {
                            "name": "z1SFMode",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z1Shortname": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z1Timer.Friday": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z1Timer.Monday": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z1Timer.Sunday": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z1ValveStatus": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z2CoolingTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z2DayTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z2HolidayTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z2Name1": {
                            "name": "z2Name1",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z2Name2": {
                            "name": "z2Name2",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z2NightTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z2OpMode": {
                            "name": "z2OpMode",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z2RoomTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z2SFMode": {
                            "name": "z2SFMode",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z2Shortname": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z2Timer.Friday": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z2Timer.Monday": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z2Timer.Sunday": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z2ValveStatus": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z3DayTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z3HolidayTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z3Name1": {
                            "name": "z3Name1",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z3Name2": {
                            "name": "z3Name2",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z3NightTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z3OpMode": {
                            "name": "z3OpMode",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z3RoomTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z3SFMode": {
                            "name": "z3SFMode",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z3Shortname": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "z3ValveStatus": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                         "bai": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "AccessoriesTwo": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "BlockTimeHcMax": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "BoilerType": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "ChangesDSN": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "CirPump": {
                            "name": "CirPump",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "currenterror": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "DateTime": {
                            "name": "DateTime",
                            "passive": false,
                            "write": false,
                            "zz": 8,
                            "fields": {
                           "dcfState": {
                            "name": "dcfState",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "DCFTimeDate": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "DisplayMode": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "DSN": {
                            "name": "DSN",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "DSNOffset": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "DSNStart": {
                            "name": "DSNStart",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "EbusSourceOn": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "EbusVoltage": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "errorhistory": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "ExternGasvalve": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "extWP": {
                            "name": "extWP",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "FanHours": {
                            "name": "FanHours",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "FanPWMSum": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "FanPWMTest": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "FanSpeed": {
                            "name": "FanSpeed",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "FanStarts": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Flame": {
                            "name": "Flame",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "FlowsetHcMax": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "FlowsetHwcMax": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "FlowTemp": {
                            "name": "FlowTemp",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "FlowTempMax": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Fluegasvalve": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Gasvalve3UC": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Gasvalve": {
                            "name": "Gasvalve",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "GasvalveUC": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "HcHours": {
                            "name": "HcHours",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "HcPumpMode": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "HcPumpStarts": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "HcStarts": {
                            "name": "HcStarts",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "HeatingSwitch": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "HwcDemand": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "HwcHours": {
                            "name": "HwcHours",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "HwcPostrunTime": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "HwcSetPotmeter": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "HwcStarts": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "HwcSwitch": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "HwcTemp": {
                            "name": "HwcTemp",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "HwcTempDesired": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "HwcTempMax": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "HwcTypes": {
                            "name": "HwcTypes",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "HwcWaterflow": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Ignitor": {
                            "name": "Ignitor",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "ParamToken": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "PartloadHcKW": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "PartloadHwcKW": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "PartnumberBox": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "PowerValue": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "PrAPSCounter": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "PrAPSSum": {
                            "name": "PrAPSSum",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "PrEnergySumHc1": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "PrEnergySumHc2": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "PrEnergySumHc3": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "ProductionByte": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "PumpHours": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "PumpHwcFlowSum": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "ReturnTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "ReturnTempMax": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "SecondPumpMode": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "SerialNumber": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "SetMode": {
                            "name": "SetMode",
                            "passive": true,
                            "write": true,
                            "zz": 8,
                            "fields": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "SHEMaxFlowTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "SolPostHeat": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Statenumber": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Status01": {
                            "name": "Status01",
                            "passive": false,
                            "write": false,
                            "zz": 8,
                            "fields": {
                           "Status02": {
                            "name": "Status02",
                            "passive": false,
                            "write": false,
                            "zz": 8,
                            "fields": {
                           "Status16": {
                            "name": "Status16",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Status": {
                            "name": "Status",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "StatusCirPump": {
                            "passive": true,
                            "write": true,
                            "zz": 8,
                            "fields": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "StorageTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "StorageTempMax": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "TargetFanSpeed": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "TempDiffBlock": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Templimiter": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Testbyte": {
                            "name": "Testbyte",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "TimerInputHc": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "ValveMode": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "ValveStarts": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "WaterHcFlowMax": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "WaterPressure": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "WP": {
                            "name": "WP",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "WPPostrunTime": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "WPSecondStage": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                         "broadcast": {
                            "name": "datetime",
                            "passive": true,
                            "write": false,
                            "lastup": 0
                           "error": {
                            "name": "error",
                            "passive": true,
                            "write": false,
                            "lastup": 0
                           "hwcStatus": {
                            "passive": true,
                            "write": false,
                            "lastup": 0
                           "id-u": {
                            "name": "id",
                            "passive": true,
                            "write": false,
                            "lastup": 0
                           "load": {
                            "name": "load",
                            "passive": true,
                            "write": false,
                            "lastup": 0
                           "outsidetemp": {
                            "passive": true,
                            "write": false,
                            "zz": 254,
                            "fields": {
                           "signoflife": {
                            "passive": true,
                            "write": false,
                            "lastup": 0
                           "vdatetime": {
                            "passive": true,
                            "write": false,
                            "zz": 254,
                            "fields": {
                         "sc": {
                            "name": "Col",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "CollPump": {
                            "name": "CollPump",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "currenterror": {
                            "name": "currenterror",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "D1Temp": {
                            "name": "D1Temp",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "D2Temp": {
                            "name": "D2Temp",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Date": {
                            "name": "Date",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "EDFunction": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "errorhistory": {
                            "name": "errorhistory",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "FlowRate": {
                            "name": "FlowRate",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Hc2zPort": {
                            "name": "Hc2zPort",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "HydraulicScheme": {
                            "name": "HydraulicScheme",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "InitCircuit": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "IsInBoostMode": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "KickFunction": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "LpZpMaPort": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "MaximalTemp2": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "MaximalTemp": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "OMultifunction": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "QuickVetoStart": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "ResetSolGain": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "SolCollPumpED": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "SolGain": {
                            "name": "SolGain",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "SP1": {
                            "name": "SP1",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "SP2": {
                            "name": "SP2",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "SumSolGain": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "SystemMode": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Time": {
                            "name": "Time",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "Weekday": {
                            "name": "Weekday",
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "YieldLastYear": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                           "YieldThisYear": {
                            "passive": false,
                            "write": false,
                            "zz": 236,
                         "scan.08": {
                          "messages": {   "": {
                            "name": "",
                            "passive": false,
                            "write": false,
                            "zz": 8,
                            "fields": {
                           "id": {
                            "name": "id",
                            "passive": false,
                            "write": false,
                            "zz": 8,
                            "fields": {
                         "scan.15": {
                          "messages": {   "": {
                            "name": "",
                            "passive": false,
                            "write": false,
                            "zz": 21,
                            "fields": {
                           "id": {
                            "name": "id",
                            "passive": false,
                            "write": false,
                            "zz": 21,
                            "fields": {
                         "scan.ec": {
                          "messages": {   "": {
                            "name": "",
                            "passive": false,
                            "write": false,
                            "zz": 236,
                            "fields": {
                           "id": {
                            "name": "id",
                            "passive": false,
                            "write": false,
                            "zz": 236,
                            "fields": {
                         "global": {
                          "signal": true,
                          "symbolrate": 35,
                          "qq": 49,
                          "reconnects": 0,
                          "masters": 3,
                          "messages": 718,
                        "700": {
                        "messages": { "AdaptHeatCurve": {
                        "name": "AdaptHeatCurve",
                        "passive": false,
                        "write": false,
                        "lastup": 0
                        "BankHolidayEndPeriod": {
                        "name": "BankHolidayEndPeriod",
                        "passive": false,
                        "write": false,
                        "lastup": 0
                        "BankHolidayStartPeriod": {
                        "name": "BankHolidayStartPeriod",
                        "passive": false,
                        "write": false,
                        "lastup": 0
                        "ccTimer.Friday": {
                        "name": "ccTimer.Friday",
                        "passive": false,
                        "write": false,
                        "lastup": 0
                        HiltexH Offline
                        HiltexH Offline
                        Hiltex
                        #266
                        @Cino was genau ist denn die Frage?
                        Die Bedeutung der Datenpunkte ist folgende:
                        AdaptHeatCurve = Adaptive Heizkurve (ist eine Einstellung in der Fachhandwerkerebene). Ich weiß nicht genau, was die macht. Anhand des Namens schätze euch jedoch, dass die Heizkurve dynamisch angepasst wird.
                        BankHolidayEndPeriod = Tage außer Haus (Ende)
                        BankHolidayStartPeriod = Tage außer Haus (Beginn)
                        ccTimer.Friday = Heizzeiten am Freitag
                        Was du jetzt damit machst, oder ob du diese Datenpunkte ignorierst, bleibt ganz dir überlassen 😉
                        Blog: indibit.de
                        C 1 Antwort Letzte Antwort
                        • HiltexH Hiltex
                          Cino
                          #267
                          @hiltex ja nimm doch mal z.B. jetzt
                          "700": {
                          "passive": false,
                          "write": false,
                          "lastup": 0
                          Ist die adaptive Heizkurve. Die ist bei mir deaktiviert. Jetzt habe ich hier aber bool was mir false oder true anzeigt.
                          messages ist klar, name auch.
                          Was ist jetzt passive, write und lastup?
                          Was ich sagen will ist, ich habe die messages, aber keine Werte mit denen ich arbeiten kann.
                          Muss ich die extra abfragen? Ich lausche ja am Bus nach meinem Verständnis. Und wenn ich in den Einstellungen nicht rumspiele dürfte ja kein message ankommen ausser die Broadcast Nachrichten.
                          Ich habe gerade ein Verständnisproblem.
                          IOB@RPI4
                          Shelly, Zigbee, ebus
                          • C Cino
                            "700": {
                            "passive": false,
                            "write": false,
                            "lastup": 0
                            HiltexH Offline
                            HiltexH Offline
                            Hiltex
                            #268
                            @cino ok, ich dachte das war die Frage danach, was die Datenpunkte bedeuten sollen.
                            passive - keine Ahnung
                            write - ob du den Wert verändern oder nur lesen kannst
                            Lastup - wann der Wert das letzte mal abgerufen wurde.
                            Vom Grunde her funktioniert das so: die Therme sendet ein paar Werte regelmäßig, die dann automatisch in ioBroker aktualisiert werden. Welche das genau sind hängt von deiner ganz speziellen Therme ab. Alle anderen Werte, die dich interessieren, musst du aktiv abfragen, sonst kommt da nix.
                            Da geht nur probieren und selbst herausfinden, was man gebrauchen kann und was nicht. Temperaturen sind oft sehr aussagekräftig, bzw. informativ. Mit solchen Sachen wir HcPumpStarts kann ich persönlich nicht viel anfangen
                            Blog: indibit.de
                            C 2 Antworten Letzte Antwort
                            • HiltexH Hiltex
                              Cino
                              #269
                              @hiltex Jepp, aktiv abfragen ist angesagt. Guck mal wie sich das verändert hat.
                              "700": {
                              "passive": false,
                              "write": false,
                              "lastup": 1645906922,
                              "zz": 21,
                              "fields": {
                              "yesno": {"value": "no"}
                              IOB@RPI4
                              • C Cino
                                "700": {
                                "passive": false,
                                "write": false,
                                "zz": 21,
                                "fields": {
                                HiltexH Offline
                                HiltexH Offline
                                Hiltex
                                #270
                                @cino In Lastup steht jetzt die Uhrzeit der Aktualisierung als Unix-Time. Das googelst du am besten mal.
                                Value: No erklärt sich vermutlich von selbst, was zz ist weiß ich nicht.
                                Blog: indibit.de
                                • HiltexH Hiltex
                                  Cino
                                  #271
                                  @hiltex said in eBus Adapter Vaillant:
                                  Sag das nicht. Mit den ganzen Werten kann man sich förmlich ein Diagnosetool bauen über VIS.
                                  IOB@RPI4
                                  • C Offline
                                    Cino
                                    #272
                                    Sind alle Werte in der Config eigentlich abrufbar? Hab mir einige ausgesucht und kriege Fehler.
                                    ebus.0
                                    2022-02-26 21:36:02.162	error	sent read -f -c Durchfluss FlowRate , received ERR: element not found for {"circuit":"Durchfluss","name":"FlowRate","parameter":""}
                                    ebus.0
                                    2022-02-26 21:36:02.159	error	sent read -f -c Gebläsedrehzahl FanSpeed , received ERR: element not found for {"circuit":"Gebläsedrehzahl","name":"FanSpeed","parameter":""}
                                    ebus.0
                                    2022-02-26 21:36:02.156	error	sent read -f -c Rücklauf expertlevel_ReturnTemp , received ERR: element not found for {"circuit":"Rücklauf","name":"expertlevel_ReturnTemp","parameter":""}
                                    ebus.0
                                    2022-02-26 21:36:02.153	error	sent read -f -c Pumpe1 CirPump , received ERR: element not found for {"circuit":"Pumpe1","name":"CirPump","parameter":""}
                                    ebus.0
                                    2022-02-26 21:36:02.150	error	sent read -f -c Wasserdruck WaterPressure , received ERR: element not found for {"circuit":"Wasserdruck","name":"WaterPressure","parameter":""}
                                    ebus.0
                                    2022-02-26 21:36:02.148	error	sent read -f -c Pumpe Hc1PumpStatus , received ERR: element not found for {"circuit":"Pumpe","name":"Hc1PumpStatus","parameter":""}
                                    ebus.0
                                    2022-02-26 21:36:02.144	error	sent read -f -c HK1Vorlauf Hc1FlowTemp , received ERR: element not found for {"circuit":"HK1Vorlauf","name":"Hc1FlowTemp","parameter":""}
                                    ebus.0
                                    2022-02-26 21:36:02.141	error	sent read -f -c HK1Vorlaufsoll Hc1ActualFlowTempDesired , received ERR: element not found for {"circuit":"HK1Vorlaufsoll","name":"Hc1ActualFlowTempDesired","parameter":""}
                                    IOB@RPI4
                                    • C Cino
                                      ebus.0
                                      ebus.0
                                      ebus.0
                                      ebus.0
                                      ebus.0
                                      ebus.0
                                      ebus.0
                                      ebus.0
                                      HiltexH Offline
                                      HiltexH Offline
                                      Hiltex
                                      #273
                                      @cino auch das ist abhängig von deiner ganz speziellen Konfiguration. Bei mir gibt es auch einige Werte, die nicht vorhanden sind und deshalb einen Fehler produzieren
                                      Blog: indibit.de
                                      • HiltexH Hiltex
                                        Cino
                                        #274
                                        @hiltex gibt jetzt aber auch keine Möglichkeit mal alles zu pollen und dann zu gucken was ein Wert zurückgibt?
                                        IOB@RPI4
                                        • C Cino
                                          HiltexH Offline
                                          HiltexH Offline
                                          Hiltex
                                          #275
                                          @cino kommt ganz darauf an, was du als Unterbau benutzt. Der Hauptteil meiner Automatisierung läuft über Loxone und LoxBerry. Dessen ebus-Plugin hat eine Schaltfläche „Read all“. Das ist natürlich sehr bequem.
                                          Bei ioBroker fällt mir nichts anderes ein, als alle Werte manuell einzutragen und das dann mal laufen zu lassen
                                          Blog: indibit.de
